    4. [Gelöst] Update js-controller geht nicht
      Stephan1966 @Codierknecht last edited by
      @codierknecht
      Copy text starting here:
                              v.2023-10-10
         Static hostname: raspberrypismarthome
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               armhf
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      X-Server:               false
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    16
      /home/iobroker/.diag.sh: line 486: nodejs: command not found
      Nodejs-Installation:
                              /usr/bin/node           v14.21.3
                              /usr/bin/npm            6.14.18
                              /usr/bin/npx            6.14.18
                              /usr/bin/corepack       0.15.1
      Recommended versions are nodejs 16.20.2 and npm 8.19.4
      *** nodejs is NOT correctly installed ***
      Wrong installation path detected. This needs to be fixed.
      Please check
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      for more information on how to fix these errors.
      MEMORY:
      Mem:            3.8G        740M        2.5G        1.0M        577M        3.2G
      Swap:            99M          0B         99M
      Total:          3.9G        740M        2.6G
      Active iob-Instances:   13
      Active repo(s): stable
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : raspberrypismarthome                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : raspberrypismarthome                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                1994
      States:                 1715
      Size of iob-Database:
      11M     /opt/iobroker/iobroker-data/objects.jsonl
      6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
      6.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      4.2M    /opt/iobroker/iobroker-data/states.jsonl
      488K    /opt/iobroker/iobroker-data/states.json.migrated
      488K    /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
      =================== END OF SUMMARY =================
        @codierknecht sagte in Update js-controller geht nicht:
        wäre die Ausgabe des Log (in Code-Tags</>) hilfreich.
        Wie geht das?
        Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
        • Codierknecht
          Codierknecht Developer Most Active @Stephan1966 last edited by
          @stephan1966
            Thomas Braun Most Active @Stephan1966 last edited by Thomas Braun
            @stephan1966
            iob stop
            iob fix
            iob nodejs-update 18
            Danach:
            iob update
            iob update all
            iob stop
            iob upgrade self
            iob start
              Stephan1966 @Thomas Braun last edited by
              Hat funktioniert, Super, DANKE 👍
                @stephan1966
                Künftig das System WESENTLICH häufiger aktuell halten.
                nodejs14 ist schon geraume Zeit nicht mehr aktuell gewesen.
                  War schon länger nicht mehr eingeloggt und werde den Rat befolgen 👍
                    @stephan1966
                    Gib mal die Langfassung von
                    iob diag
                    bekannt.
                      Den ganzen Text welcher direkt nach der Befehlseingabe erscheint?
                        @stephan1966
                        Den ganzen langen Text...
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          Model           : Raspberry Pi 4 Model B Rev 1.2
                          Docker          : false
                          Virtualization  : none
                          Kernel          : aarch64
                          Userland        : armhf
                          Systemuptime and Load:
                           13:39:16 up  2:19,  1 user,  load average: 0.18, 0.07, 0.09
                          CPU threads: 4
                          *** RASPBERRY THROTTLING ***
                          Current issues:
                          Previously detected issues:
                          *** Time and Time Zones ***
                                         Local time: Mon 2023-12-18 13:39:16 CET
                                     Universal time: Mon 2023-12-18 12:39:16 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          *** User and Groups ***
                          pi
                          /home/pi
                          pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                          *** X-Server-Setup ***
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            3.8G        728M        1.5G        1.0M        1.6G        3.0G
                          Swap:            99M          0B         99M
                          Total:          3.9G        728M        1.6G
                                   3794 M total memory
                                    728 M used memory
                                    801 M active memory
                                   1225 M inactive memory
                                   1495 M free memory
                                    202 M buffer memory
                                   1367 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FAILED SERVICES ***
                            UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
                          * deconz-init.service   loaded failed failed deCONZ: ZigBee gateway -- Initialisation
                          * deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
                          * deconz-wifi.service   loaded failed failed deCONZ: ZigBee gateway -- WIFI Service
                          LOAD   = Reflects whether the unit definition was properly loaded.
                          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                          SUB    = The low-level unit activation state, values depend on unit type.
                          3 loaded units listed.
                          *** FILESYSTEM ***
                          /dev/root      ext4       29G  6.1G   22G  22% /
                          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                          tmpfs          tmpfs     759M  1.8M  758M   1% /run
                          /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                          [Mon Dec 18 11:19:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Mon Dec 18 11:19:30 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                          [Mon Dec 18 11:19:30 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                          [Mon Dec 18 11:19:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                          TARGET  SOURCE         FSTYPE OPTIONS
                          /       /dev/mmcblk0p2 ext4   rw,noatime
                          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                          /var:
                          1.9G    /var/
                          1.1G    /var/log/journal/2db8461036a4455ab0afd36ad1c9f367
                          1.1G    /var/log
                          658M    /var/cache
                          Archived and active journals take up 1.0G in the file system.
                          /opt/iobroker/backups:
                          393M    /opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          295M    /opt/iobroker/iobroker-data/
                          164M    /opt/iobroker/iobroker-data/files
                          105M    /opt/iobroker/iobroker-data/backup-objects
                          51M     /opt/iobroker/iobroker-data/files/javascript.admin
                          43M     /opt/iobroker/iobroker-data/files/iot.admin
                          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                          9.1M    /opt/iobroker/iobroker-data/objects.jsonl
                          8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
                          8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
                          USB-Devices by-id:
                          *** NodeJS-Installation ***
                          /usr/bin/nodejs         v18.19.0
                          /usr/bin/node           v18.19.0
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          /usr/bin/corepack       0.22.0
                          nodejs:
                            Installed: 18.19.0-1nodesource1
                            Candidate: 18.19.0-1nodesource1
                            Version table:
                           *** 18.19.0-1nodesource1 1001
                                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                  100 /var/lib/dpkg/status
                               18.18.2-1nodesource1 1001
                               18.18.1-1nodesource1 1001
                               18.18.0-1nodesource1 1001
                               18.17.1-1nodesource1 1001
                               18.17.0-1nodesource1 1001
                               18.16.1-1nodesource1 1001
                               18.16.0-1nodesource1 1001
                               18.15.0-1nodesource1 1001
                               18.14.2-1nodesource1 1001
                               18.14.1-1nodesource1 1001
                               18.14.0-1nodesource1 1001
                               18.13.0-1nodesource1 1001
                               18.12.0-1nodesource1 1001
                               18.11.0-1nodesource1 1001
                               18.10.0-1nodesource1 1001
                               18.9.1-1nodesource1 1001
                               18.9.0-1nodesource1 1001
                               18.8.0-1nodesource1 1001
                               18.7.0-1nodesource1 1001
                               18.6.0-1nodesource1 1001
                               18.5.0-1nodesource1 1001
                               18.4.0-1nodesource1 1001
                               18.3.0-1nodesource1 1001
                               18.2.0-1nodesource1 1001
                               18.1.0-1nodesource1 1001
                               18.0.0-1nodesource1 1001
                               12.22.12~dfsg-1~deb11u4 500
                                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
                          No problems detected
                          Errors in npm tree:
                          npm ERR! code ELSPROBLEMS
                          npm ERR! invalid: @types/node@14.18.36 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-18T12_39_24_312Z-debug-0.log
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Core adapters versions
                          js-controller:  5.0.17
                          admin:          6.12.0
                          javascript:     6.1.4
                          Adapters from github:   0
                          Adapter State
                            system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
                          + system.adapter.backitup.0               : backitup              : raspberrypismarthome                     -  enabled
                          + system.adapter.deconz.1                 : deconz                : raspberrypismarthome                     -  enabled, port: 80
                          + system.adapter.discovery.0              : discovery             : raspberrypismarthome                     -  enabled
                          + system.adapter.fritzdect.0              : fritzdect             : raspberrypismarthome                     -  enabled
                          + system.adapter.info.0                   : info                  : raspberrypismarthome                     -  enabled
                          + system.adapter.iot.0                    : iot                   : raspberrypismarthome                     -  enabled
                          + system.adapter.javascript.0             : javascript            : raspberrypismarthome                     -  enabled
                          + system.adapter.net-tools.0              : net-tools             : raspberrypismarthome                     -  enabled
                          + system.adapter.ping.0                   : ping                  : raspberrypismarthome                     -  enabled
                          + system.adapter.pushover.0               : pushover              : raspberrypismarthome                     -  enabled
                          + system.adapter.tr-064.0                 : tr-064                : raspberrypismarthome                     -  enabled
                            system.adapter.vis.0                    : vis                   : raspberrypismarthome                     -  enabled
                          + instance is alive
                          ioBroker-Repositories
                          Installed ioBroker-Instances
                          Used repository: stable
                          Adapter    "admin"        : 6.12.0   , installed 6.12.0
                          Adapter    "alexa2"       : 3.26.3   , installed 3.23.2 [Updatable]
                          Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                          Adapter    "deconz"       : 1.3.23   , installed 1.3.23
                          Adapter    "fritzdect"    : 2.5.9    , installed 2.2.6  [Updatable]
                          Adapter    "iot"          : 2.0.11   , installed 2.0.11
                          Adapter    "javascript"   : 7.1.6    , installed 6.1.4  [Updatable]
                          Controller "js-controller": 5.0.17   , installed 5.0.17
                          Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                          Adapter    "web"          : 6.1.10   , installed 6.1.10
                          Adapter    "ws"           : 2.5.8    , installed 2.5.8
                          Adapter    "zigbee"       : 1.8.24   , installed 1.8.10 [Updatable]
                          Objects and States
                          Objects:        2017
                          States:         1715
                          Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
                          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Reading package lists...
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       48602      8219/iobroker.js-co
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50489      8219/iobroker.js-co
                          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          15069      831/smbd
                          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       11194      400/deCONZ
                          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          15070      831/smbd
                          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12931      400/deCONZ
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14170      535/sshd: /usr/sbin
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54627      9795/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       64933      12757/io.web.0
                          tcp6       0      0 :::445                  :::*                    LISTEN      0          15067      831/smbd
                          tcp6       0      0 :::139                  :::*                    LISTEN      0          15068      831/smbd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          14172      535/sshd: /usr/sbin
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14033      392/avahi-daemon: r
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       58563      10450/io.deconz.1
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       14805      400/deCONZ
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14249      747/dhcpcd
                          udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          16432      751/nmbd
                          udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          16431      751/nmbd
                          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          16415      751/nmbd
                          udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          16434      751/nmbd
                          udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          16433      751/nmbd
                          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          16416      751/nmbd
                          udp        0      0 0.0.0.0:45598           0.0.0.0:*                           108        14035      392/avahi-daemon: r
                          udp6       0      0 :::5353                 :::*                                108        14034      392/avahi-daemon: r
                          udp6       0      0 :::1900                 :::*                                1001       58565      10450/io.deconz.1
                          udp6       0      0 :::1900                 :::*                                1001       58564      10450/io.deconz.1
                          udp6       0      0 :::34833                :::*                                108        14036      392/avahi-daemon: r
                          udp6       0      0 :::546                  :::*                                0          14262      747/dhcpcd
                          2023-12-18 12:32:44.197  - info: host.raspberrypismarthome iobroker upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/noSwipe.jpg widgets/swipe/img/noSwipe.jpg image/jpeg
                          2023-12-18 12:32:44.210  - info: host.raspberrypismarthome iobroker upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout-shapes.js widgets/swipe/js/jquery.roundabout-shapes.js application/javascript
                          2023-12-18 12:32:44.222  - info: host.raspberrypismarthome iobroker upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout.min.js widgets/swipe/js/jquery.roundabout.min.js application/javascript
                          2023-12-18 12:32:44.236  - info: host.raspberrypismarthome iobroker upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
                          2023-12-18 12:32:44.248  - info: host.raspberrypismarthome iobroker upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe.html widgets/swipe.html text/html
                          2023-12-18 12:32:44.260  - info: host.raspberrypismarthome iobroker upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets/tabs/jquery.sliderTabs.js application/javascript
                          2023-12-18 12:32:44.277  - info: host.raspberrypismarthome iobroker upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicator.png widgets/tabs/styles/images/indicator.png image/png
                          2023-12-18 12:32:44.289  - info: host.raspberrypismarthome iobroker upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicatorActive.png widgets/tabs/styles/images/indicatorActive.png image/png
                          2023-12-18 12:32:44.301  - info: host.raspberrypismarthome iobroker upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png widgets/tabs/styles/images/leftArrow.png image/png
                          2023-12-18 12:32:44.313  - info: host.raspberrypismarthome iobroker upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftPanelArrow.png widgets/tabs/styles/images/leftPanelArrow.png image/png
                          2023-12-18 12:32:44.325  - info: host.raspberrypismarthome iobroker upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png widgets/tabs/styles/images/rightArrow.png image/png
                          2023-12-18 12:32:44.340  - info: host.raspberrypismarthome iobroker upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightPanelArrow.png widgets/tabs/styles/images/rightPanelArrow.png image/png
                          2023-12-18 12:32:44.353  - info: host.raspberrypismarthome iobroker upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css widgets/tabs/styles/jquery.sliderTabs.css text/css
                          2023-12-18 12:32:44.365  - info: host.raspberrypismarthome iobroker upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
                          2023-12-18 12:32:44.378  - info: host.raspberrypismarthome iobroker upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/html
                          2023-12-18 12:32:44.390  - info: host.raspberrypismarthome iobroker upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.html text/html
                          2023-12-18 12:32:44.403  - info: host.raspberrypismarthome iobroker upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/homematic.html widgets/todo/homematic.html text/html
                          2023-12-18 12:32:44.415  - info: host.raspberrypismarthome iobroker upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/special.html text/html
                          2023-12-18 12:32:44.430  - info: host.raspberrypismarthome iobroker upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/weather.html widgets/todo/weather.html text/html
                          2023-12-18 12:32:44.484  - info: host.raspberrypismarthome iobroker Update "system.adapter.vis.0"
                          2023-12-18 12:32:44.541  - info: host.raspberrypismarthome iobroker upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                          2023-12-18 12:32:45.614  - info: host.raspberrypismarthome iobroker exit 0
                          2023-12-18 12:32:46.690  - info: vis.0 (12885) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                          2023-12-18 12:32:47.358  - info: vis.0 (12885) Terminated (NO_ERROR): Without reason
                          2023-12-18 12:32:47.928  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                          iob diag has finished.
                            @stephan1966
                            sudo systemctl set-default multi-user.target
                            Was ist denn mit dem 'deconz' los?
                            würde mir auch zu denken geben. Renkt sich aber ggf. nach einem Neustart ein.
                            Schmeiß die Adapter-Updates drauf.
                            iob upgrade all
                              === Mark text until here for copying ===
                              pi@raspberrypismarthome:~ $ iob stop
                              pi@raspberrypismarthome:~ $ iob ugrade all
                              iobroker [command]
                              Commands:
                              iobroker setup Setup ioBroker
                              iobroker start [all|<adapter>.<instance>|<adapter>] Starts the js-controller or a specified adapter instance or all instances of an adapter
                              iobroker stop [<adapter>.<instance>|<adapter>] stops the js-controller or a specified adapter instance or all instances of an adapter
                              iobroker restart [<adapter>.<instance>|<adapter>] Restarts js-controller or a specified adapter instance or all instances of an adapter [aliases: r]
                              iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance
                              iobroker info Shows the host info
                              iobroker logs [<adapter>] Monitor log
                              iobroker add <adapter> [desiredNumber] Add instance of adapter [aliases: a]
                              iobroker install <adapter> Installs a specified adapter [aliases: i]
                              iobroker rebuild [<module>] Rebuild all native modules or path
                              iobroker url <url> [<name>] Install adapter from specified url, e.g. GitHub
                              iobroker del <adapter> Remove adapter and all instances from this host [aliases: delete]
                              iobroker del <adapter>.<instance> Remove adapter instance [aliases: delete]
                              iobroker update [<repositoryUrl>] Update repository and list adapters
                              iobroker upgrade Upgrade management
                              iobroker upload [all|<adapter>] Upload management [aliases: u]
                              iobroker object Object management [aliases: o]
                              iobroker state State management [aliases: s]
                              iobroker message <adapter>[.instance] <command> [<message>] Send message to adapter instance/s
                              iobroker list <type> [<filter>] List all entries, like objects
                              iobroker chmod <mode> <file> Change file rights
                              iobroker chown <user> <group> <file> Change file ownership
                              iobroker touch <file> Touch file
                              iobroker rm <file> Remove file
                              iobroker file File management
                              iobroker user User commands
                              iobroker group group management
                              iobroker host <hostname> Set host to given hostname
                              iobroker set <adapter>.<instance> Change settings of adapter config
                              iobroker license <license.file or license.text> Update license by given file
                              iobroker cert Certificate management
                              iobroker clean <yes> Clears all objects and states
                              iobroker backup Create backup
                              iobroker restore <backup name or path> Restore a specified backup
                              iobroker validate <backup name or path> Validate a specified backup
                              iobroker status [all|<adapter>.<instance>] Status of ioBroker or adapter instance [aliases: isrun]
                              iobroker repo [<name>] Show repo information
                              iobroker uuid Show uuid of the installation [aliases: id]
                              iobroker unsetup Reset license, installation secret and language
                              iobroker fix Execute the installation fixer script, this updates your ioBroker installation
                              iobroker nodejs-update [<major-version>] Upgrade the Node.JS installation to the current LTS
                              iobroker multihost Multihost management
                              iobroker compact compact group management
                              iobroker plugin Plugin management
                              iobroker vendor <passphrase> [<vendor.json>] Update the vendor information using given passphrase
                              iobroker version [<adapter>] Show version of js-controller or specified adapter [aliases: v]
                              Options:
                              --help Show help [boolean]
                                @stephan1966
                                Das muss ja auch
                                iob upgrade all
                                heißen.
                                  Habe ich doch vor 3 Minuten gemacht!
                                    @stephan1966
                                    Du hast das falsch geschrieben und eine entsprechende Rückmeldung erhalten, aber kein upgrade durchgeführt.
                                      Wer lesen kann ist klar im Vorteil 👍
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : armhf
                                         14:07:31 up  2:48,  1 user,  load average: 1.44, 0.89, 0.48
                                        CPU threads: 4
                                        Current issues:
                                                       Local time: Mon 2023-12-18 14:07:32 CET
                                                   Universal time: Mon 2023-12-18 13:07:32 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        /home/pi
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            3.8G        606M        1.3G        1.0M        1.9G        3.1G
                                        Swap:            99M          0B         99M
                                        Total:          3.9G        606M        1.4G
                                                 3794 M total memory
                                                  606 M used memory
                                                  688 M active memory
                                                 1517 M inactive memory
                                                 1321 M free memory
                                                  207 M buffer memory
                                                 1658 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        /var:
                                        1.9G    /var/
                                        1.1G    /var/log
                                        658M    /var/cache
                                        313M    /opt/iobroker/iobroker-data/
                                        180M    /opt/iobroker/iobroker-data/files
                                        67M     /opt/iobroker/iobroker-data/files/javascript.admin
                                        48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                                        9.7M    /opt/iobroker/iobroker-data/objects.jsonl
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                                        nodejs:
                                          Version table:
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.12.0
                                        javascript:     7.1.6
                                        Adapter State
                                        + system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
                                        + instance is alive
                                        Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                                        Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                                        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                                        Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
                                        Objects and States
                                        Objects:        2050
                                        States:         1756
                                        Pending Updates: 0
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       87946      15594/iobroker.js-c
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       87939      15594/iobroker.js-c
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       90447      15612/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       90049      15972/io.web.0
                                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       91665      16022/io.deconz.1
                                        udp6       0      0 :::1900                 :::*                                1001       91667      16022/io.deconz.1
                                        udp6       0      0 :::1900                 :::*                                1001       91666      16022/io.deconz.1
                                        2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) no response part in returned error message
                                        2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                                        2023-12-18 14:07:42.364  - error: fritzdect.0 (15942) login not possible, check user and permissions
                                        2023-12-18 14:07:43.505  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 15972
                                        2023-12-18 14:07:47.252  - info: web.0 (15972) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                                        2023-12-18 14:07:47.570  - info: web.0 (15972) socket.io server listening on port 8082
                                        2023-12-18 14:07:47.582  - info: web.0 (15972) http server listening on port 8082
                                        2023-12-18 14:07:50.378  - info: vis.0 (15997) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                                        2023-12-18 14:07:51.083  - info: vis.0 (15997) Terminated (NO_ERROR): Without reason
                                        2023-12-18 14:07:51.489  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 16022
                                        2023-12-18 14:07:51.682  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                                        2023-12-18 14:07:54.669  - info: deconz.1 (16022) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                                        2023-12-18 14:07:54.881  - info: deconz.1 (16022) deConz Version: 2.24.2; API version: 1.16.0
                                        2023-12-18 14:07:55.488  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 16046
                                        2023-12-18 14:07:59.511  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 16090
                                        2023-12-18 14:08:01.351  - info: info.0 (16046) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                                        2023-12-18 14:08:01.666  - info: info.0 (16046) Reading/updating systemdata.
                                        2023-12-18 14:08:04.164  - info: info.0 (16046) cpu Temp res = {"main":47.225,"cores":[],"max":47.225,"socket":[],"chipset":null}
                                        2023-12-18 14:08:05.265  - info: iot.0 (16090) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                                        2023-12-18 14:08:05.531  - info: iot.0 (16090) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                                        2023-12-18 14:08:06.392  - info: iot.0 (16090) Connection changed: connect "s_glebe66_googlemail_com"
                                        2023-12-18 14:08:06.642  - info: alexa2.0 (15845) Subscribing to states...
                                        2023-12-18 14:08:06.650  - info: alexa2.0 (15845) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                                        2023-12-18 14:08:08.370  - info: alexa2.0 (15845) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                        2023-12-18 14:08:15.917  - info: alexa2.0 (15845) Initialization Done ...
                                          @stephan1966
                                          Hast du das boot target gesetzt?
                                          sudo reboot
                                          Was ist denn nun mit deconz los?
                                            @thomas-braun sagte in Update js-controller geht nicht:
                                            sudo reboot
                                            Muss ich diese beiden Befehle eingeben?
                                            ioBroker vorher anhalten?
                                            2858
