    4. [Gelöst] Update js-controller geht nicht
      Stephan1966 @Thomas Braun last edited by
      War schon länger nicht mehr eingeloggt und werde den Rat befolgen 👍
        Thomas Braun Most Active @Stephan1966 last edited by
        @stephan1966
        Gib mal die Langfassung von
        iob diag
        bekannt.
          Den ganzen Text welcher direkt nach der Befehlseingabe erscheint?
            @stephan1966
            Den ganzen langen Text...
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                 Static hostname: raspberrypismarthome
                       Icon name: computer
                Operating System: Raspbian GNU/Linux 11 (bullseye)
                          Kernel: Linux 6.1.21-v8+
                    Architecture: arm64
              Model           : Raspberry Pi 4 Model B Rev 1.2
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : armhf
              Systemuptime and Load:
               13:39:16 up  2:19,  1 user,  load average: 0.18, 0.07, 0.09
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                             Local time: Mon 2023-12-18 13:39:16 CET
                         Universal time: Mon 2023-12-18 12:39:16 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            3.8G        728M        1.5G        1.0M        1.6G        3.0G
              Swap:            99M          0B         99M
              Total:          3.9G        728M        1.6G
                       3794 M total memory
                        728 M used memory
                        801 M active memory
                       1225 M inactive memory
                       1495 M free memory
                        202 M buffer memory
                       1367 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FAILED SERVICES ***
                UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
              * deconz-init.service   loaded failed failed deCONZ: ZigBee gateway -- Initialisation
              * deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
              * deconz-wifi.service   loaded failed failed deCONZ: ZigBee gateway -- WIFI Service
              LOAD   = Reflects whether the unit definition was properly loaded.
              ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
              SUB    = The low-level unit activation state, values depend on unit type.
              3 loaded units listed.
              *** FILESYSTEM ***
              /dev/root      ext4       29G  6.1G   22G  22% /
              devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
              tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
              tmpfs          tmpfs     759M  1.8M  758M   1% /run
              /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
              tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
              [Mon Dec 18 11:19:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Mon Dec 18 11:19:30 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Mon Dec 18 11:19:30 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Mon Dec 18 11:19:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              TARGET  SOURCE         FSTYPE OPTIONS
              /       /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
              /var:
              1.9G    /var/
              1.1G    /var/log/journal/2db8461036a4455ab0afd36ad1c9f367
              1.1G    /var/log
              658M    /var/cache
              Archived and active journals take up 1.0G in the file system.
              /opt/iobroker/backups:
              393M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              295M    /opt/iobroker/iobroker-data/
              164M    /opt/iobroker/iobroker-data/files
              105M    /opt/iobroker/iobroker-data/backup-objects
              51M     /opt/iobroker/iobroker-data/files/javascript.admin
              43M     /opt/iobroker/iobroker-data/files/iot.admin
              33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
              9.1M    /opt/iobroker/iobroker-data/objects.jsonl
              8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
              8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
              USB-Devices by-id:
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.19.0
              /usr/bin/node           v18.19.0
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              /usr/bin/corepack       0.22.0
              nodejs:
                Installed: 18.19.0-1nodesource1
                Candidate: 18.19.0-1nodesource1
                Version table:
               *** 18.19.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                      100 /var/lib/dpkg/status
                   18.18.2-1nodesource1 1001
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
                   12.22.12~dfsg-1~deb11u4 500
                      500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
              No problems detected
              Errors in npm tree:
              npm ERR! code ELSPROBLEMS
              npm ERR! invalid: @types/node@14.18.36 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
              npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-18T12_39_24_312Z-debug-0.log
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.17
              admin:          6.12.0
              javascript:     6.1.4
              Adapters from github:   0
              Adapter State
              + system.adapter.admin.0                  : admin                 : raspberrypismarthome                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
              + system.adapter.backitup.0               : backitup              : raspberrypismarthome                     -  enabled
              + system.adapter.deconz.1                 : deconz                : raspberrypismarthome                     -  enabled, port: 80
              + system.adapter.discovery.0              : discovery             : raspberrypismarthome                     -  enabled
              + system.adapter.fritzdect.0              : fritzdect             : raspberrypismarthome                     -  enabled
              + system.adapter.info.0                   : info                  : raspberrypismarthome                     -  enabled
              + system.adapter.iot.0                    : iot                   : raspberrypismarthome                     -  enabled
              + system.adapter.javascript.0             : javascript            : raspberrypismarthome                     -  enabled
              + system.adapter.net-tools.0              : net-tools             : raspberrypismarthome                     -  enabled
              + system.adapter.ping.0                   : ping                  : raspberrypismarthome                     -  enabled
              + system.adapter.pushover.0               : pushover              : raspberrypismarthome                     -  enabled
              + system.adapter.tr-064.0                 : tr-064                : raspberrypismarthome                     -  enabled
                system.adapter.vis.0                    : vis                   : raspberrypismarthome                     -  enabled
              + system.adapter.web.0                    : web                   : raspberrypismarthome                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "alexa2"       : 3.26.3   , installed 3.23.2 [Updatable]
              Adapter    "backitup"     : 2.8.7    , installed 2.8.7
              Adapter    "deconz"       : 1.3.23   , installed 1.3.23
              Adapter    "fritzdect"    : 2.5.9    , installed 2.2.6  [Updatable]
              Adapter    "iot"          : 2.0.11   , installed 2.0.11
              Adapter    "javascript"   : 7.1.6    , installed 6.1.4  [Updatable]
              Controller "js-controller": 5.0.17   , installed 5.0.17
              Adapter    "pushover"     : 3.0.3    , installed 3.0.3
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Adapter    "zigbee"       : 1.8.24   , installed 1.8.10 [Updatable]
              Objects and States
              Objects:        2017
              States:         1715
              Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
              Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       48602      8219/iobroker.js-co
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50489      8219/iobroker.js-co
              tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          15069      831/smbd
              tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       11194      400/deCONZ
              tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          15070      831/smbd
              tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12931      400/deCONZ
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14170      535/sshd: /usr/sbin
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54627      9795/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       64933      12757/io.web.0
              tcp6       0      0 :::445                  :::*                    LISTEN      0          15067      831/smbd
              tcp6       0      0 :::139                  :::*                    LISTEN      0          15068      831/smbd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          14172      535/sshd: /usr/sbin
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14033      392/avahi-daemon: r
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       58563      10450/io.deconz.1
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       14805      400/deCONZ
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14249      747/dhcpcd
              udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          16432      751/nmbd
              udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          16431      751/nmbd
              udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          16415      751/nmbd
              udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          16434      751/nmbd
              udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          16433      751/nmbd
              udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          16416      751/nmbd
              udp        0      0 0.0.0.0:45598           0.0.0.0:*                           108        14035      392/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                108        14034      392/avahi-daemon: r
              udp6       0      0 :::1900                 :::*                                1001       58565      10450/io.deconz.1
              udp6       0      0 :::1900                 :::*                                1001       58564      10450/io.deconz.1
              udp6       0      0 :::34833                :::*                                108        14036      392/avahi-daemon: r
              udp6       0      0 :::546                  :::*                                0          14262      747/dhcpcd
              2023-12-18 12:32:44.197  - info: host.raspberrypismarthome iobroker upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/noSwipe.jpg widgets/swipe/img/noSwipe.jpg image/jpeg
              2023-12-18 12:32:44.210  - info: host.raspberrypismarthome iobroker upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout-shapes.js widgets/swipe/js/jquery.roundabout-shapes.js application/javascript
              2023-12-18 12:32:44.222  - info: host.raspberrypismarthome iobroker upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout.min.js widgets/swipe/js/jquery.roundabout.min.js application/javascript
              2023-12-18 12:32:44.236  - info: host.raspberrypismarthome iobroker upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
              2023-12-18 12:32:44.248  - info: host.raspberrypismarthome iobroker upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe.html widgets/swipe.html text/html
              2023-12-18 12:32:44.260  - info: host.raspberrypismarthome iobroker upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets/tabs/jquery.sliderTabs.js application/javascript
              2023-12-18 12:32:44.277  - info: host.raspberrypismarthome iobroker upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicator.png widgets/tabs/styles/images/indicator.png image/png
              2023-12-18 12:32:44.289  - info: host.raspberrypismarthome iobroker upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicatorActive.png widgets/tabs/styles/images/indicatorActive.png image/png
              2023-12-18 12:32:44.301  - info: host.raspberrypismarthome iobroker upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png widgets/tabs/styles/images/leftArrow.png image/png
              2023-12-18 12:32:44.313  - info: host.raspberrypismarthome iobroker upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftPanelArrow.png widgets/tabs/styles/images/leftPanelArrow.png image/png
              2023-12-18 12:32:44.325  - info: host.raspberrypismarthome iobroker upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png widgets/tabs/styles/images/rightArrow.png image/png
              2023-12-18 12:32:44.340  - info: host.raspberrypismarthome iobroker upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightPanelArrow.png widgets/tabs/styles/images/rightPanelArrow.png image/png
              2023-12-18 12:32:44.353  - info: host.raspberrypismarthome iobroker upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css widgets/tabs/styles/jquery.sliderTabs.css text/css
              2023-12-18 12:32:44.365  - info: host.raspberrypismarthome iobroker upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
              2023-12-18 12:32:44.378  - info: host.raspberrypismarthome iobroker upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/html
              2023-12-18 12:32:44.390  - info: host.raspberrypismarthome iobroker upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.html text/html
              2023-12-18 12:32:44.403  - info: host.raspberrypismarthome iobroker upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/homematic.html widgets/todo/homematic.html text/html
              2023-12-18 12:32:44.415  - info: host.raspberrypismarthome iobroker upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/special.html text/html
              2023-12-18 12:32:44.430  - info: host.raspberrypismarthome iobroker upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/weather.html widgets/todo/weather.html text/html
              2023-12-18 12:32:44.484  - info: host.raspberrypismarthome iobroker Update "system.adapter.vis.0"
              2023-12-18 12:32:44.541  - info: host.raspberrypismarthome iobroker upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
              2023-12-18 12:32:45.614  - info: host.raspberrypismarthome iobroker exit 0
              2023-12-18 12:32:46.690  - info: vis.0 (12885) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
              2023-12-18 12:32:47.358  - info: vis.0 (12885) Terminated (NO_ERROR): Without reason
              2023-12-18 12:32:47.928  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
              iob diag has finished.
                @stephan1966
                sudo systemctl set-default multi-user.target
                Was ist denn mit dem 'deconz' los?
                würde mir auch zu denken geben. Renkt sich aber ggf. nach einem Neustart ein.
                Schmeiß die Adapter-Updates drauf.
                iob upgrade all
                  === Mark text until here for copying ===
                  pi@raspberrypismarthome:~ $ iob stop
                  pi@raspberrypismarthome:~ $ iob ugrade all
                  iobroker [command]
                  Commands:
                  iobroker setup Setup ioBroker
                  iobroker start [all|<adapter>.<instance>|<adapter>] Starts the js-controller or a specified adapter instance or all instances of an adapter
                  iobroker stop [<adapter>.<instance>|<adapter>] stops the js-controller or a specified adapter instance or all instances of an adapter
                  iobroker restart [<adapter>.<instance>|<adapter>] Restarts js-controller or a specified adapter instance or all instances of an adapter [aliases: r]
                  iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance
                  iobroker info Shows the host info
                  iobroker logs [<adapter>] Monitor log
                  iobroker add <adapter> [desiredNumber] Add instance of adapter [aliases: a]
                  iobroker install <adapter> Installs a specified adapter [aliases: i]
                  iobroker rebuild [<module>] Rebuild all native modules or path
                  iobroker url <url> [<name>] Install adapter from specified url, e.g. GitHub
                  iobroker del <adapter> Remove adapter and all instances from this host [aliases: delete]
                  iobroker del <adapter>.<instance> Remove adapter instance [aliases: delete]
                  iobroker update [<repositoryUrl>] Update repository and list adapters
                  iobroker upgrade Upgrade management
                  iobroker upload [all|<adapter>] Upload management [aliases: u]
                  iobroker object Object management [aliases: o]
                  iobroker state State management [aliases: s]
                  iobroker message <adapter>[.instance] <command> [<message>] Send message to adapter instance/s
                  iobroker list <type> [<filter>] List all entries, like objects
                  iobroker chmod <mode> <file> Change file rights
                  iobroker chown <user> <group> <file> Change file ownership
                  iobroker touch <file> Touch file
                  iobroker rm <file> Remove file
                  iobroker file File management
                  iobroker user User commands
                  iobroker group group management
                  iobroker host <hostname> Set host to given hostname
                  iobroker set <adapter>.<instance> Change settings of adapter config
                  iobroker license <license.file or license.text> Update license by given file
                  iobroker cert Certificate management
                  iobroker clean <yes> Clears all objects and states
                  iobroker backup Create backup
                  iobroker restore <backup name or path> Restore a specified backup
                  iobroker validate <backup name or path> Validate a specified backup
                  iobroker status [all|<adapter>.<instance>] Status of ioBroker or adapter instance [aliases: isrun]
                  iobroker repo [<name>] Show repo information
                  iobroker uuid Show uuid of the installation [aliases: id]
                  iobroker unsetup Reset license, installation secret and language
                  iobroker fix Execute the installation fixer script, this updates your ioBroker installation
                  iobroker nodejs-update [<major-version>] Upgrade the Node.JS installation to the current LTS
                  iobroker multihost Multihost management
                  iobroker compact compact group management
                  iobroker plugin Plugin management
                  iobroker vendor <passphrase> [<vendor.json>] Update the vendor information using given passphrase
                  iobroker version [<adapter>] Show version of js-controller or specified adapter [aliases: v]
                  Options:
                  --help Show help [boolean]
                    @stephan1966
                    Das muss ja auch
                    iob upgrade all
                    heißen.
                      Habe ich doch vor 3 Minuten gemacht!
                        @stephan1966
                        Du hast das falsch geschrieben und eine entsprechende Rückmeldung erhalten, aber kein upgrade durchgeführt.
                          Wer lesen kann ist klar im Vorteil 👍
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : armhf
                             14:07:31 up  2:48,  1 user,  load average: 1.44, 0.89, 0.48
                            CPU threads: 4
                            Current issues:
                                           Local time: Mon 2023-12-18 14:07:32 CET
                                       Universal time: Mon 2023-12-18 13:07:32 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            3.8G        606M        1.3G        1.0M        1.9G        3.1G
                            Swap:            99M          0B         99M
                            Total:          3.9G        606M        1.4G
                                     3794 M total memory
                                      606 M used memory
                                      688 M active memory
                                     1517 M inactive memory
                                     1321 M free memory
                                      207 M buffer memory
                                     1658 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /var:
                            1.9G    /var/
                            1.1G    /var/log
                            658M    /var/cache
                            313M    /opt/iobroker/iobroker-data/
                            180M    /opt/iobroker/iobroker-data/files
                            67M     /opt/iobroker/iobroker-data/files/javascript.admin
                            48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                            9.7M    /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.12.0
                            javascript:     7.1.6
                            Adapter State
                            + system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
                            + instance is alive
                            Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                            Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                            Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
                            Objects and States
                            Objects:        2050
                            States:         1756
                            Pending Updates: 0
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       87946      15594/iobroker.js-c
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       87939      15594/iobroker.js-c
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       90447      15612/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       90049      15972/io.web.0
                            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       91665      16022/io.deconz.1
                            udp6       0      0 :::1900                 :::*                                1001       91667      16022/io.deconz.1
                            udp6       0      0 :::1900                 :::*                                1001       91666      16022/io.deconz.1
                            2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) no response part in returned error message
                            2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                            2023-12-18 14:07:42.364  - error: fritzdect.0 (15942) login not possible, check user and permissions
                            2023-12-18 14:07:43.505  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 15972
                            2023-12-18 14:07:47.252  - info: web.0 (15972) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                            2023-12-18 14:07:47.570  - info: web.0 (15972) socket.io server listening on port 8082
                            2023-12-18 14:07:47.582  - info: web.0 (15972) http server listening on port 8082
                            2023-12-18 14:07:50.378  - info: vis.0 (15997) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                            2023-12-18 14:07:51.083  - info: vis.0 (15997) Terminated (NO_ERROR): Without reason
                            2023-12-18 14:07:51.489  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 16022
                            2023-12-18 14:07:51.682  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                            2023-12-18 14:07:54.669  - info: deconz.1 (16022) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                            2023-12-18 14:07:54.881  - info: deconz.1 (16022) deConz Version: 2.24.2; API version: 1.16.0
                            2023-12-18 14:07:55.488  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 16046
                            2023-12-18 14:07:59.511  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 16090
                            2023-12-18 14:08:01.351  - info: info.0 (16046) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                            2023-12-18 14:08:01.666  - info: info.0 (16046) Reading/updating systemdata.
                            2023-12-18 14:08:04.164  - info: info.0 (16046) cpu Temp res = {"main":47.225,"cores":[],"max":47.225,"socket":[],"chipset":null}
                            2023-12-18 14:08:05.265  - info: iot.0 (16090) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                            2023-12-18 14:08:05.531  - info: iot.0 (16090) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                            2023-12-18 14:08:06.392  - info: iot.0 (16090) Connection changed: connect "s_glebe66_googlemail_com"
                            2023-12-18 14:08:06.642  - info: alexa2.0 (15845) Subscribing to states...
                            2023-12-18 14:08:06.650  - info: alexa2.0 (15845) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                            2023-12-18 14:08:08.370  - info: alexa2.0 (15845) Alexa-Push-Connection (macDms = true) established. Disable Polling
                            2023-12-18 14:08:15.917  - info: alexa2.0 (15845) Initialization Done ...
                              @stephan1966
                              Hast du das boot target gesetzt?
                              sudo reboot
                              Was ist denn nun mit deconz los?
                                @thomas-braun sagte in Update js-controller geht nicht:
                                sudo reboot
                                Muss ich diese beiden Befehle eingeben?
                                ioBroker vorher anhalten?
                                  @stephan1966 sagte in Update js-controller geht nicht:
                                  Ja / Nein.
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : armhf
                                     14:25:37 up 1 min,  1 user,  load average: 1.42, 0.45, 0.16
                                    CPU threads: 4
                                    Current issues:
                                                   Local time: Mon 2023-12-18 14:25:37 CET
                                               Universal time: Mon 2023-12-18 13:25:37 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    Boot Target:    multi-user.target
                                    *** MEMORY ***
                                    Mem:            3.8G        698M        2.8G        1.0M        293M        3.0G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        698M        2.9G
                                             3794 M total memory
                                              698 M used memory
                                              767 M active memory
                                              119 M inactive memory
                                             2802 M free memory
                                               40 M buffer memory
                                              252 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    [Mon Dec 18 14:24:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Mon Dec 18 14:24:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Mon Dec 18 14:24:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Mon Dec 18 14:24:27 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                    /var:
                                    1.9G    /var/
                                    1.1G    /var/log
                                    658M    /var/cache
                                    315M    /opt/iobroker/iobroker-data/
                                    11M     /opt/iobroker/iobroker-data/objects.jsonl
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.12.0
                                    javascript:     7.1.6
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        2065
                                    States:         1769
                                    Pending Updates: 0
                                    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       13818      399/deCONZ
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13783      523/sshd: /usr/sbin
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12213      504/iobroker.js-con
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14838      504/iobroker.js-con
                                    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14054      753/smbd
                                    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       12175      399/deCONZ
                                    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14053      753/smbd
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15694      676/io.admin.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17553      1023/io.web.0
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          13785      523/sshd: /usr/sbin
                                    tcp6       0      0 :::139                  :::*                    LISTEN      0          14052      753/smbd
                                    tcp6       0      0 :::445                  :::*                    LISTEN      0          14051      753/smbd
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2041       393/avahi-daemon: r
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17621      1083/io.deconz.1
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15442      399/deCONZ
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13837      747/dhcpcd
                                    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          13983      748/nmbd
                                    udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          13982      748/nmbd
                                    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          13966      748/nmbd
                                    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          13985      748/nmbd
                                    udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          13984      748/nmbd
                                    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          13967      748/nmbd
                                    udp        0      0 0.0.0.0:51768           0.0.0.0:*                           108        2043       393/avahi-daemon: r
                                    udp6       0      0 :::5353                 :::*                                108        2042       393/avahi-daemon: r
                                    udp6       0      0 :::48542                :::*                                108        2044       393/avahi-daemon: r
                                    udp6       0      0 :::1900                 :::*                                1001       17623      1083/io.deconz.1
                                    udp6       0      0 :::1900                 :::*                                1001       17622      1083/io.deconz.1
                                    udp6       0      0 :::546                  :::*                                0          13850      747/dhcpcd
                                    2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) no response part in returned error message
                                    2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                                    2023-12-18 14:25:19.594  - error: fritzdect.0 (1008) login not possible, check user and permissions
                                    2023-12-18 14:25:20.809  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1023
                                    2023-12-18 14:25:24.559  - info: web.0 (1023) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                                    2023-12-18 14:25:25.051  - info: web.0 (1023) socket.io server listening on port 8082
                                    2023-12-18 14:25:25.059  - info: web.0 (1023) http server listening on port 8082
                                    2023-12-18 14:25:27.639  - info: vis.0 (1059) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                                    2023-12-18 14:25:28.699  - info: vis.0 (1059) Terminated (NO_ERROR): Without reason
                                    2023-12-18 14:25:28.750  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1083
                                    2023-12-18 14:25:29.290  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                                    2023-12-18 14:25:31.643  - info: alexa2.0 (939) Subscribing to states...
                                    2023-12-18 14:25:31.653  - info: alexa2.0 (939) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                                    2023-12-18 14:25:31.867  - info: deconz.1 (1083) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                                    2023-12-18 14:25:32.013  - info: deconz.1 (1083) deConz Version: 2.24.2; API version: 1.16.0
                                    2023-12-18 14:25:32.791  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1107
                                    2023-12-18 14:25:33.549  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                    2023-12-18 14:25:36.750  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1133
                                    2023-12-18 14:25:38.276  - info: info.0 (1107) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                                    2023-12-18 14:25:38.565  - info: info.0 (1107) Reading/updating systemdata.
                                    2023-12-18 14:25:40.091  - info: info.0 (1107) cpu Temp res = {"main":46.738,"cores":[],"max":46.738,"socket":[],"chipset":null}
                                    2023-12-18 14:25:40.203  - info: alexa2.0 (939) Initialization Done ...
                                    2023-12-18 14:25:41.632  - info: iot.0 (1133) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                                    2023-12-18 14:25:41.783  - info: iot.0 (1133) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                                    2023-12-18 14:25:42.623  - info: iot.0 (1133) Connection changed: connect "s_glebe66_googlemail_com"
                                      Ja / Nein.
                                      ist erledigt
                                        Nachfolgend der aktuelle Stand, ich glaube es ist noch nicht OK oder?
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : armhf
                                         12:52:33 up 22:28,  1 user,  load average: 0.15, 0.03, 0.01
                                        CPU threads: 4
                                        Current issues:
                                                       Local time: Tue 2023-12-19 12:52:33 CET
                                                   Universal time: Tue 2023-12-19 11:52:33 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        /home/pi
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            3.8G        816M        2.4G        1.0M        588M        2.9G
                                        Swap:            99M          0B         99M
                                        Total:          3.9G        816M        2.5G
                                                 3794 M total memory
                                                  816 M used memory
                                                  895 M active memory
                                                  367 M inactive memory
                                                 2389 M free memory
                                                   89 M buffer memory
                                                  499 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       29G  6.2G   22G  23% /
                                        /var:
                                        1.9G    /var/
                                        1.1G    /var/log
                                        658M    /var/cache
                                        396M    /opt/iobroker/backups/
                                        329M    /opt/iobroker/iobroker-data/
                                        24M     /opt/iobroker/iobroker-data/objects.jsonl
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                                        nodejs:
                                          Version table:
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.12.0
                                        javascript:     7.1.6
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        2065
                                        States:         1761
                                        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                        Pending Updates: 0
                                        2023-12-19 00:22:45.291  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                        2023-12-19 02:00:19.204  - error: backitup.0 (974) [iobroker/ftp] Error: Access to home directory not allowed.
                                        2023-12-19 02:00:19.217  - error: backitup.0 (974) [iobroker] Error: Access to home directory not allowed.
                                        2023-12-19 02:24:51.981  - info: admin.0 (676) Request actual repository...
                                        2023-12-19 02:24:52.654  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                        2023-12-19 02:24:58.132  - info: admin.0 (676) Repository received successfully.
                                        2023-12-19 02:25:47.031  - info: info.0 (1107) Reading/updating systemdata.
                                        2023-12-19 02:25:47.675  - info: info.0 (1107) cpu Temp res = {"main":41.868,"cores":[],"max":41.868,"socket":[],"chipset":null}
                                        2023-12-19 03:18:22.246  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                        2023-12-19 03:18:23.687  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                        2023-12-19 05:56:01.651  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                        2023-12-19 05:56:03.105  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                        2023-12-19 08:44:32.929  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                        2023-12-19 08:44:56.919  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                        2023-12-19 08:44:59.590  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                        2023-12-19 08:46:40.957  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                                        2023-12-19 08:59:55.063  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                        2023-12-19 08:59:56.533  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                        2023-12-19 10:14:57.017  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                        2023-12-19 10:14:59.037  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                        2023-12-19 10:15:37.424  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                                        2023-12-19 10:21:47.849  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                        2023-12-19 10:22:19.303  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                                        2023-12-19 12:41:01.489  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                        2023-12-19 12:41:02.953  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                          Versuch mal, den deconz neuzuinstallieren.
                                          sudo apt install --reinstall deconz
                                            2858
