    4. [Gelöst] Update js-controller geht nicht
      Stephan1966 @Thomas Braun last edited by
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypismarthome
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : armhf
      Systemuptime and Load:
       13:39:16 up  2:19,  1 user,  load average: 0.18, 0.07, 0.09
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Mon 2023-12-18 13:39:16 CET
                 Universal time: Mon 2023-12-18 12:39:16 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        728M        1.5G        1.0M        1.6G        3.0G
      Swap:            99M          0B         99M
      Total:          3.9G        728M        1.6G
               3794 M total memory
                728 M used memory
                801 M active memory
               1225 M inactive memory
               1495 M free memory
                202 M buffer memory
               1367 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
      * deconz-init.service   loaded failed failed deCONZ: ZigBee gateway -- Initialisation
      * deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
      * deconz-wifi.service   loaded failed failed deCONZ: ZigBee gateway -- WIFI Service
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      3 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G  6.1G   22G  22% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  1.8M  758M   1% /run
      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Mon Dec 18 11:19:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Mon Dec 18 11:19:30 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon Dec 18 11:19:30 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Mon Dec 18 11:19:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      1.9G    /var/
      1.1G    /var/log/journal/2db8461036a4455ab0afd36ad1c9f367
      1.1G    /var/log
      658M    /var/cache
      Archived and active journals take up 1.0G in the file system.
      /opt/iobroker/backups:
      393M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      295M    /opt/iobroker/iobroker-data/
      164M    /opt/iobroker/iobroker-data/files
      105M    /opt/iobroker/iobroker-data/backup-objects
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      43M     /opt/iobroker/iobroker-data/files/iot.admin
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      9.1M    /opt/iobroker/iobroker-data/objects.jsonl
      8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! invalid: @types/node@14.18.36 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-18T12_39_24_312Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     6.1.4
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypismarthome                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypismarthome                     -  enabled
      + system.adapter.deconz.1                 : deconz                : raspberrypismarthome                     -  enabled, port: 80
      + system.adapter.discovery.0              : discovery             : raspberrypismarthome                     -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypismarthome                     -  enabled
      + system.adapter.info.0                   : info                  : raspberrypismarthome                     -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypismarthome                     -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypismarthome                     -  enabled
      + system.adapter.net-tools.0              : net-tools             : raspberrypismarthome                     -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypismarthome                     -  enabled
      + system.adapter.pushover.0               : pushover              : raspberrypismarthome                     -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypismarthome                     -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypismarthome                     -  enabled
      + system.adapter.web.0                    : web                   : raspberrypismarthome                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.26.3   , installed 3.23.2 [Updatable]
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "deconz"       : 1.3.23   , installed 1.3.23
      Adapter    "fritzdect"    : 2.5.9    , installed 2.2.6  [Updatable]
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 6.1.4  [Updatable]
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "zigbee"       : 1.8.24   , installed 1.8.10 [Updatable]
      Objects and States
      Objects:        2017
      States:         1715
      Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       48602      8219/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       50489      8219/iobroker.js-co
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          15069      831/smbd
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       11194      400/deCONZ
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          15070      831/smbd
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12931      400/deCONZ
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14170      535/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54627      9795/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       64933      12757/io.web.0
      tcp6       0      0 :::445                  :::*                    LISTEN      0          15067      831/smbd
      tcp6       0      0 :::139                  :::*                    LISTEN      0          15068      831/smbd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14172      535/sshd: /usr/sbin
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14033      392/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       58563      10450/io.deconz.1
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       14805      400/deCONZ
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14249      747/dhcpcd
      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          16432      751/nmbd
      udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          16431      751/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          16415      751/nmbd
      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          16434      751/nmbd
      udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          16433      751/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          16416      751/nmbd
      udp        0      0 0.0.0.0:45598           0.0.0.0:*                           108        14035      392/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        14034      392/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1001       58565      10450/io.deconz.1
      udp6       0      0 :::1900                 :::*                                1001       58564      10450/io.deconz.1
      udp6       0      0 :::34833                :::*                                108        14036      392/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          14262      747/dhcpcd
      2023-12-18 12:32:44.197  - info: host.raspberrypismarthome iobroker upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/img/noSwipe.jpg widgets/swipe/img/noSwipe.jpg image/jpeg
      2023-12-18 12:32:44.210  - info: host.raspberrypismarthome iobroker upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout-shapes.js widgets/swipe/js/jquery.roundabout-shapes.js application/javascript
      2023-12-18 12:32:44.222  - info: host.raspberrypismarthome iobroker upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.roundabout.min.js widgets/swipe/js/jquery.roundabout.min.js application/javascript
      2023-12-18 12:32:44.236  - info: host.raspberrypismarthome iobroker upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe/js/jquery.touchSwipe.min.js widgets/swipe/js/jquery.touchSwipe.min.js application/javascript
      2023-12-18 12:32:44.248  - info: host.raspberrypismarthome iobroker upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/swipe.html widgets/swipe.html text/html
      2023-12-18 12:32:44.260  - info: host.raspberrypismarthome iobroker upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/jquery.sliderTabs.js widgets/tabs/jquery.sliderTabs.js application/javascript
      2023-12-18 12:32:44.277  - info: host.raspberrypismarthome iobroker upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicator.png widgets/tabs/styles/images/indicator.png image/png
      2023-12-18 12:32:44.289  - info: host.raspberrypismarthome iobroker upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/indicatorActive.png widgets/tabs/styles/images/indicatorActive.png image/png
      2023-12-18 12:32:44.301  - info: host.raspberrypismarthome iobroker upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftArrow.png widgets/tabs/styles/images/leftArrow.png image/png
      2023-12-18 12:32:44.313  - info: host.raspberrypismarthome iobroker upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/leftPanelArrow.png widgets/tabs/styles/images/leftPanelArrow.png image/png
      2023-12-18 12:32:44.325  - info: host.raspberrypismarthome iobroker upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png widgets/tabs/styles/images/rightArrow.png image/png
      2023-12-18 12:32:44.340  - info: host.raspberrypismarthome iobroker upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightPanelArrow.png widgets/tabs/styles/images/rightPanelArrow.png image/png
      2023-12-18 12:32:44.353  - info: host.raspberrypismarthome iobroker upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.css widgets/tabs/styles/jquery.sliderTabs.css text/css
      2023-12-18 12:32:44.365  - info: host.raspberrypismarthome iobroker upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
      2023-12-18 12:32:44.378  - info: host.raspberrypismarthome iobroker upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs.html widgets/tabs.html text/html
      2023-12-18 12:32:44.390  - info: host.raspberrypismarthome iobroker upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.html text/html
      2023-12-18 12:32:44.403  - info: host.raspberrypismarthome iobroker upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/homematic.html widgets/todo/homematic.html text/html
      2023-12-18 12:32:44.415  - info: host.raspberrypismarthome iobroker upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/special.html widgets/todo/special.html text/html
      2023-12-18 12:32:44.430  - info: host.raspberrypismarthome iobroker upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/weather.html widgets/todo/weather.html text/html
      2023-12-18 12:32:44.484  - info: host.raspberrypismarthome iobroker Update "system.adapter.vis.0"
      2023-12-18 12:32:44.541  - info: host.raspberrypismarthome iobroker upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
      2023-12-18 12:32:45.614  - info: host.raspberrypismarthome iobroker exit 0
      2023-12-18 12:32:46.690  - info: vis.0 (12885) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
      2023-12-18 12:32:47.358  - info: vis.0 (12885) Terminated (NO_ERROR): Without reason
      2023-12-18 12:32:47.928  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
      iob diag has finished.
        Thomas Braun Most Active @Stephan1966 last edited by
        @stephan1966
        sudo systemctl set-default multi-user.target
        Was ist denn mit dem 'deconz' los?
        würde mir auch zu denken geben. Renkt sich aber ggf. nach einem Neustart ein.
        Schmeiß die Adapter-Updates drauf.
        iob upgrade all
          === Mark text until here for copying ===
          pi@raspberrypismarthome:~ $ iob stop
          pi@raspberrypismarthome:~ $ iob ugrade all
          iobroker [command]
          Commands:
          iobroker setup Setup ioBroker
          iobroker start [all|<adapter>.<instance>|<adapter>] Starts the js-controller or a specified adapter instance or all instances of an adapter
          iobroker stop [<adapter>.<instance>|<adapter>] stops the js-controller or a specified adapter instance or all instances of an adapter
          iobroker restart [<adapter>.<instance>|<adapter>] Restarts js-controller or a specified adapter instance or all instances of an adapter [aliases: r]
          iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance
          iobroker info Shows the host info
          iobroker logs [<adapter>] Monitor log
          iobroker add <adapter> [desiredNumber] Add instance of adapter [aliases: a]
          iobroker install <adapter> Installs a specified adapter [aliases: i]
          iobroker rebuild [<module>] Rebuild all native modules or path
          iobroker url <url> [<name>] Install adapter from specified url, e.g. GitHub
          iobroker del <adapter> Remove adapter and all instances from this host [aliases: delete]
          iobroker del <adapter>.<instance> Remove adapter instance [aliases: delete]
          iobroker update [<repositoryUrl>] Update repository and list adapters
          iobroker upgrade Upgrade management
          iobroker upload [all|<adapter>] Upload management [aliases: u]
          iobroker object Object management [aliases: o]
          iobroker state State management [aliases: s]
          iobroker message <adapter>[.instance] <command> [<message>] Send message to adapter instance/s
          iobroker list <type> [<filter>] List all entries, like objects
          iobroker chmod <mode> <file> Change file rights
          iobroker chown <user> <group> <file> Change file ownership
          iobroker touch <file> Touch file
          iobroker rm <file> Remove file
          iobroker file File management
          iobroker user User commands
          iobroker group group management
          iobroker host <hostname> Set host to given hostname
          iobroker set <adapter>.<instance> Change settings of adapter config
          iobroker license <license.file or license.text> Update license by given file
          iobroker cert Certificate management
          iobroker clean <yes> Clears all objects and states
          iobroker backup Create backup
          iobroker restore <backup name or path> Restore a specified backup
          iobroker validate <backup name or path> Validate a specified backup
          iobroker status [all|<adapter>.<instance>] Status of ioBroker or adapter instance [aliases: isrun]
          iobroker repo [<name>] Show repo information
          iobroker uuid Show uuid of the installation [aliases: id]
          iobroker unsetup Reset license, installation secret and language
          iobroker fix Execute the installation fixer script, this updates your ioBroker installation
          iobroker nodejs-update [<major-version>] Upgrade the Node.JS installation to the current LTS
          iobroker multihost Multihost management
          iobroker compact compact group management
          iobroker plugin Plugin management
          iobroker vendor <passphrase> [<vendor.json>] Update the vendor information using given passphrase
          iobroker version [<adapter>] Show version of js-controller or specified adapter [aliases: v]
          Options:
          --help Show help [boolean]
            @stephan1966
            Das muss ja auch
            iob upgrade all
            heißen.
              Habe ich doch vor 3 Minuten gemacht!
                @stephan1966
                Du hast das falsch geschrieben und eine entsprechende Rückmeldung erhalten, aber kein upgrade durchgeführt.
                  Wer lesen kann ist klar im Vorteil 👍
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : armhf
                     14:07:31 up  2:48,  1 user,  load average: 1.44, 0.89, 0.48
                    CPU threads: 4
                    Current issues:
                                   Local time: Mon 2023-12-18 14:07:32 CET
                               Universal time: Mon 2023-12-18 13:07:32 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            3.8G        606M        1.3G        1.0M        1.9G        3.1G
                    Swap:            99M          0B         99M
                    Total:          3.9G        606M        1.4G
                             3794 M total memory
                              606 M used memory
                              688 M active memory
                             1517 M inactive memory
                             1321 M free memory
                              207 M buffer memory
                             1658 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    1.9G    /var/
                    1.1G    /var/log
                    658M    /var/cache
                    313M    /opt/iobroker/iobroker-data/
                    180M    /opt/iobroker/iobroker-data/files
                    67M     /opt/iobroker/iobroker-data/files/javascript.admin
                    48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                    9.7M    /opt/iobroker/iobroker-data/objects.jsonl
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
                    + instance is alive
                    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
                    Objects and States
                    Objects:        2050
                    States:         1756
                    Pending Updates: 0
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       87946      15594/iobroker.js-c
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       87939      15594/iobroker.js-c
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       90447      15612/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       90049      15972/io.web.0
                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       91665      16022/io.deconz.1
                    udp6       0      0 :::1900                 :::*                                1001       91667      16022/io.deconz.1
                    udp6       0      0 :::1900                 :::*                                1001       91666      16022/io.deconz.1
                    2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) no response part in returned error message
                    2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                    2023-12-18 14:07:42.364  - error: fritzdect.0 (15942) login not possible, check user and permissions
                    2023-12-18 14:07:43.505  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 15972
                    2023-12-18 14:07:47.252  - info: web.0 (15972) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                    2023-12-18 14:07:47.570  - info: web.0 (15972) socket.io server listening on port 8082
                    2023-12-18 14:07:47.582  - info: web.0 (15972) http server listening on port 8082
                    2023-12-18 14:07:50.378  - info: vis.0 (15997) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                    2023-12-18 14:07:51.083  - info: vis.0 (15997) Terminated (NO_ERROR): Without reason
                    2023-12-18 14:07:51.489  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 16022
                    2023-12-18 14:07:51.682  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                    2023-12-18 14:07:54.669  - info: deconz.1 (16022) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                    2023-12-18 14:07:54.881  - info: deconz.1 (16022) deConz Version: 2.24.2; API version: 1.16.0
                    2023-12-18 14:07:55.488  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 16046
                    2023-12-18 14:07:59.511  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 16090
                    2023-12-18 14:08:01.351  - info: info.0 (16046) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                    2023-12-18 14:08:01.666  - info: info.0 (16046) Reading/updating systemdata.
                    2023-12-18 14:08:04.164  - info: info.0 (16046) cpu Temp res = {"main":47.225,"cores":[],"max":47.225,"socket":[],"chipset":null}
                    2023-12-18 14:08:05.265  - info: iot.0 (16090) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                    2023-12-18 14:08:05.531  - info: iot.0 (16090) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                    2023-12-18 14:08:06.392  - info: iot.0 (16090) Connection changed: connect "s_glebe66_googlemail_com"
                    2023-12-18 14:08:06.642  - info: alexa2.0 (15845) Subscribing to states...
                    2023-12-18 14:08:06.650  - info: alexa2.0 (15845) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                    2023-12-18 14:08:08.370  - info: alexa2.0 (15845) Alexa-Push-Connection (macDms = true) established. Disable Polling
                    2023-12-18 14:08:15.917  - info: alexa2.0 (15845) Initialization Done ...
                      @stephan1966
                      Hast du das boot target gesetzt?
                      sudo reboot
                      Was ist denn nun mit deconz los?
                        @thomas-braun sagte in Update js-controller geht nicht:
                        sudo reboot
                        Muss ich diese beiden Befehle eingeben?
                        ioBroker vorher anhalten?
                          @stephan1966 sagte in Update js-controller geht nicht:
                          Ja / Nein.
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : armhf
                             14:25:37 up 1 min,  1 user,  load average: 1.42, 0.45, 0.16
                            CPU threads: 4
                            Current issues:
                                           Local time: Mon 2023-12-18 14:25:37 CET
                                       Universal time: Mon 2023-12-18 13:25:37 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            Boot Target:    multi-user.target
                            *** MEMORY ***
                            Mem:            3.8G        698M        2.8G        1.0M        293M        3.0G
                            Swap:            99M          0B         99M
                            Total:          3.9G        698M        2.9G
                                     3794 M total memory
                                      698 M used memory
                                      767 M active memory
                                      119 M inactive memory
                                     2802 M free memory
                                       40 M buffer memory
                                      252 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            [Mon Dec 18 14:24:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
                            [Mon Dec 18 14:24:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                            [Mon Dec 18 14:24:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            [Mon Dec 18 14:24:27 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                            /var:
                            1.9G    /var/
                            1.1G    /var/log
                            658M    /var/cache
                            315M    /opt/iobroker/iobroker-data/
                            11M     /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.12.0
                            javascript:     7.1.6
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        2065
                            States:         1769
                            Pending Updates: 0
                            tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       13818      399/deCONZ
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13783      523/sshd: /usr/sbin
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12213      504/iobroker.js-con
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14838      504/iobroker.js-con
                            tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14054      753/smbd
                            tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       12175      399/deCONZ
                            tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14053      753/smbd
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15694      676/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17553      1023/io.web.0
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          13785      523/sshd: /usr/sbin
                            tcp6       0      0 :::139                  :::*                    LISTEN      0          14052      753/smbd
                            tcp6       0      0 :::445                  :::*                    LISTEN      0          14051      753/smbd
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2041       393/avahi-daemon: r
                            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17621      1083/io.deconz.1
                            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15442      399/deCONZ
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13837      747/dhcpcd
                            udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          13983      748/nmbd
                            udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          13982      748/nmbd
                            udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          13966      748/nmbd
                            udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          13985      748/nmbd
                            udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          13984      748/nmbd
                            udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          13967      748/nmbd
                            udp        0      0 0.0.0.0:51768           0.0.0.0:*                           108        2043       393/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                108        2042       393/avahi-daemon: r
                            udp6       0      0 :::48542                :::*                                108        2044       393/avahi-daemon: r
                            udp6       0      0 :::1900                 :::*                                1001       17623      1083/io.deconz.1
                            udp6       0      0 :::1900                 :::*                                1001       17622      1083/io.deconz.1
                            udp6       0      0 :::546                  :::*                                0          13850      747/dhcpcd
                            2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) no response part in returned error message
                            2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                            2023-12-18 14:25:19.594  - error: fritzdect.0 (1008) login not possible, check user and permissions
                            2023-12-18 14:25:20.809  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1023
                            2023-12-18 14:25:24.559  - info: web.0 (1023) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                            2023-12-18 14:25:25.051  - info: web.0 (1023) socket.io server listening on port 8082
                            2023-12-18 14:25:25.059  - info: web.0 (1023) http server listening on port 8082
                            2023-12-18 14:25:27.639  - info: vis.0 (1059) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                            2023-12-18 14:25:28.699  - info: vis.0 (1059) Terminated (NO_ERROR): Without reason
                            2023-12-18 14:25:28.750  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1083
                            2023-12-18 14:25:29.290  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                            2023-12-18 14:25:31.643  - info: alexa2.0 (939) Subscribing to states...
                            2023-12-18 14:25:31.653  - info: alexa2.0 (939) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                            2023-12-18 14:25:31.867  - info: deconz.1 (1083) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                            2023-12-18 14:25:32.013  - info: deconz.1 (1083) deConz Version: 2.24.2; API version: 1.16.0
                            2023-12-18 14:25:32.791  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1107
                            2023-12-18 14:25:33.549  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                            2023-12-18 14:25:36.750  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1133
                            2023-12-18 14:25:38.276  - info: info.0 (1107) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                            2023-12-18 14:25:38.565  - info: info.0 (1107) Reading/updating systemdata.
                            2023-12-18 14:25:40.091  - info: info.0 (1107) cpu Temp res = {"main":46.738,"cores":[],"max":46.738,"socket":[],"chipset":null}
                            2023-12-18 14:25:40.203  - info: alexa2.0 (939) Initialization Done ...
                            2023-12-18 14:25:41.632  - info: iot.0 (1133) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                            2023-12-18 14:25:41.783  - info: iot.0 (1133) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                            2023-12-18 14:25:42.623  - info: iot.0 (1133) Connection changed: connect "s_glebe66_googlemail_com"
                              Ja / Nein.
                              ist erledigt
                                Nachfolgend der aktuelle Stand, ich glaube es ist noch nicht OK oder?
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : armhf
                                 12:52:33 up 22:28,  1 user,  load average: 0.15, 0.03, 0.01
                                CPU threads: 4
                                Current issues:
                                               Local time: Tue 2023-12-19 12:52:33 CET
                                           Universal time: Tue 2023-12-19 11:52:33 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            3.8G        816M        2.4G        1.0M        588M        2.9G
                                Swap:            99M          0B         99M
                                Total:          3.9G        816M        2.5G
                                         3794 M total memory
                                          816 M used memory
                                          895 M active memory
                                          367 M inactive memory
                                         2389 M free memory
                                           89 M buffer memory
                                          499 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /dev/root      ext4       29G  6.2G   22G  23% /
                                /var:
                                1.9G    /var/
                                1.1G    /var/log
                                658M    /var/cache
                                396M    /opt/iobroker/backups/
                                329M    /opt/iobroker/iobroker-data/
                                24M     /opt/iobroker/iobroker-data/objects.jsonl
                                USB-Devices by-id:
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.12.0
                                javascript:     7.1.6
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        2065
                                States:         1761
                                Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                Pending Updates: 0
                                2023-12-19 00:22:45.291  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                2023-12-19 02:00:19.204  - error: backitup.0 (974) [iobroker/ftp] Error: Access to home directory not allowed.
                                2023-12-19 02:00:19.217  - error: backitup.0 (974) [iobroker] Error: Access to home directory not allowed.
                                2023-12-19 02:24:51.981  - info: admin.0 (676) Request actual repository...
                                2023-12-19 02:24:52.654  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                2023-12-19 02:24:58.132  - info: admin.0 (676) Repository received successfully.
                                2023-12-19 02:25:47.031  - info: info.0 (1107) Reading/updating systemdata.
                                2023-12-19 02:25:47.675  - info: info.0 (1107) cpu Temp res = {"main":41.868,"cores":[],"max":41.868,"socket":[],"chipset":null}
                                2023-12-19 03:18:22.246  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                2023-12-19 03:18:23.687  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                2023-12-19 05:56:01.651  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                2023-12-19 05:56:03.105  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                2023-12-19 08:44:32.929  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                2023-12-19 08:44:56.919  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                2023-12-19 08:44:59.590  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                2023-12-19 08:46:40.957  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                                2023-12-19 08:59:55.063  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                2023-12-19 08:59:56.533  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                2023-12-19 10:14:57.017  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                2023-12-19 10:14:59.037  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                2023-12-19 10:15:37.424  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                                2023-12-19 10:21:47.849  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                2023-12-19 10:22:19.303  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                                2023-12-19 12:41:01.489  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                                2023-12-19 12:41:02.953  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                  Versuch mal, den deconz neuzuinstallieren.
                                  sudo apt install --reinstall deconz
                                      @stephan1966
                                      Sollte egal sein. Vielleicht den deconz-Adapter danach mal neustarten.
                                        Hier das Ergebnis, sieht soweit ich das beurteilen kann noch genauso aus!
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : armhf
                                         14:56:47 up 2 min,  1 user,  load average: 1.21, 0.66, 0.26
                                        CPU threads: 4
                                        Current issues:
                                                       Local time: Tue 2023-12-19 14:56:47 CET
                                                   Universal time: Tue 2023-12-19 13:56:47 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        /home/pi
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            3.8G        651M        2.8G        1.0M        302M        3.1G
                                        Swap:            99M          0B         99M
                                        Total:          3.9G        651M        2.9G
                                                 3794 M total memory
                                                  651 M used memory
                                                  725 M active memory
                                                  118 M inactive memory
                                                 2840 M free memory
                                                   41 M buffer memory
                                                  260 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        oom events: 0
                                        *** FILESYSTEM ***
                                        /dev/root      ext4       29G  6.2G   22G  22% /
                                        [Tue Dec 19 14:54:28 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Tue Dec 19 14:54:29 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Tue Dec 19 14:54:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                        [Tue Dec 19 14:54:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                        /var:
                                        1.9G    /var/
                                        1.1G    /var/log
                                        658M    /var/cache
                                        310M    /opt/iobroker/iobroker-data/
                                        8.6M    /opt/iobroker/iobroker-data/objects.jsonl
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                                        nodejs:
                                          Version table:
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.12.0
                                        javascript:     7.1.6
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        2065
                                        States:         1769
                                        Pending Updates: 0
                                        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14205      816/smbd
                                        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       13015      400/deCONZ
                                        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14206      816/smbd
                                        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12989      400/deCONZ
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15042      537/sshd: /usr/sbin
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13070      501/iobroker.js-con
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12123      501/iobroker.js-con
                                        tcp6       0      0 :::445                  :::*                    LISTEN      0          14203      816/smbd
                                        tcp6       0      0 :::139                  :::*                    LISTEN      0          14204      816/smbd
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          15044      537/sshd: /usr/sbin
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13211      662/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17527      1040/io.web.0
                                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       16822      1070/io.deconz.1
                                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15097      400/deCONZ
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12103      749/dhcpcd
                                        udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          14181      750/nmbd
                                        udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          14180      750/nmbd
                                        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          14164      750/nmbd
                                        udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          14183      750/nmbd
                                        udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          14182      750/nmbd
                                        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          14165      750/nmbd
                                        udp        0      0 0.0.0.0:41316           0.0.0.0:*                           108        14958      394/avahi-daemon: r
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14956      394/avahi-daemon: r
                                        udp6       0      0 :::1900                 :::*                                1001       16824      1070/io.deconz.1
                                        udp6       0      0 :::1900                 :::*                                1001       16823      1070/io.deconz.1
                                        udp6       0      0 :::45045                :::*                                108        14959      394/avahi-daemon: r
                                        udp6       0      0 :::546                  :::*                                0          13027      749/dhcpcd
                                        udp6       0      0 :::5353                 :::*                                108        14957      394/avahi-daemon: r
                                        2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                                        2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) login not possible, check user and permissions
                                        2023-12-19 14:55:24.974  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1040
                                        2023-12-19 14:55:28.042  - info: web.0 (1040) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                                        2023-12-19 14:55:28.584  - info: web.0 (1040) socket.io server listening on port 8082
                                        2023-12-19 14:55:28.603  - info: web.0 (1040) http server listening on port 8082
                                        2023-12-19 14:55:31.435  - info: vis.0 (1055) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                                        2023-12-19 14:55:32.211  - info: vis.0 (1055) Terminated (NO_ERROR): Without reason
                                        2023-12-19 14:55:32.794  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                                        2023-12-19 14:55:32.972  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1070
                                        2023-12-19 14:55:35.726  - info: deconz.1 (1070) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                                        2023-12-19 14:55:35.883  - info: deconz.1 (1070) deConz Version: 2.24.2; API version: 1.16.0
                                        2023-12-19 14:55:36.496  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                        2023-12-19 14:55:38.641  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1086
                                        2023-12-19 14:55:41.025  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1101
                                        2023-12-19 14:55:45.888  - info: info.0 (1086) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                                        2023-12-19 14:55:46.253  - info: info.0 (1086) Reading/updating systemdata.
                                        2023-12-19 14:55:46.468  - info: iot.0 (1101) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                                        2023-12-19 14:55:46.638  - info: iot.0 (1101) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                                        2023-12-19 14:55:47.531  - info: iot.0 (1101) Connection changed: connect "s_glebe66_googlemail_com"
                                        2023-12-19 14:55:47.731  - info: info.0 (1086) cpu Temp res = {"main":46.251,"cores":[],"max":46.251,"socket":[],"chipset":null}
                                        2023-12-19 14:55:49.207  - info: alexa2.0 (987) Subscribing to states...
                                        2023-12-19 14:55:49.216  - info: alexa2.0 (987) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                                        2023-12-19 14:55:51.087  - info: alexa2.0 (987) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                        2023-12-19 14:55:55.552  - info: alexa2.0 (987) Initialization Done ...
                                          deconz-init.service
                                          Dann musst du mal schauen, was da klemmen könnte.
                                          systemctl status deconz*
                                            Ergebnis meiner Eingabe!
                                            pi@raspberrypismarthome:~ $ systemctl status deconz*
                                            Unit deconz-latest-beta.deb.service could not be found.
                                            2860
