    4. File tab_m.html not found
    • I
      Int17 @Thomas Braun last edited by
      klu@iobroker:~$ iob nodejs-update
      iobroker nodejs-update [<major-version>]
      Upgrade the Node.JS installation to the current LTS
      Options:
      --help Show help [boolean]
        Thomas Braun Most Active @Int17 last edited by
        @int17
        iob stop
        iob fix
        Danach dürfte
        iob nodejs-update
        dann funktionieren.
        • I
          Int17 @Thomas Braun last edited by Int17
          ioBroker nodejs fixer 2023-10-13
          Recommended nodejs-version is: 18.19.0
          Checking your installation now. Please be patient!
          Your current setup is:
          /usr/bin/nodejs         v18.17.1
          /usr/bin/node           v18.17.1
          /usr/bin/npm            10.2.0
          /usr/bin/npx            10.2.0
          /usr/bin/corepack       0.18.0
          We found these nodejs versions available for installation:
          nodejs:
            Installed: 18.17.1-deb-1nodesource1
            Candidate: 18.17.1-deb-1nodesource1
            Version table:
           *** 18.17.1-deb-1nodesource1 100
                  100 /var/lib/dpkg/status
               12.22.9~dfsg-1ubuntu3.2 500
                  500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                  500 http://de.archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
               12.22.9~dfsg-1ubuntu3 500
                  500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
          Nothing to do - Your installation is using the correct paths.
          You are running nodejs v18.17.1. Do you want to install recommended version 18.19.0?
          Press <y> to continue or any other key to quit
          Trying to update your installation now. Please be patient.
          Virtualization: kvm
          Waiting for ioBroker to shut down - Give me a minute...
          *** These repos are active on your system:
          Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
          Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
          Hit:3 https://repos.influxdata.com/debian jammy InRelease
          Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
          Hit:5 https://dl.yarnpkg.com/debian stable InRelease
          Hit:6 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
          Hit:7 https://apt.grafana.com stable InRelease
          Reading package lists... Done
          *** Installing ca-certificates, curl and gnupg, just in case they are missing.
          *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
          Package: nodejs
          Pin: origin deb.nodesource.com
          Pin-Priority: 1001
          *** These repos are active after the adjustments:
          Hit:1 https://apt.grafana.com stable InRelease
          Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
          Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
          Hit:6 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
          Hit:7 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
          Get:8 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
          Get:9 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [6451 B]
          Fetched 18.6 kB in 0s (42.1 kB/s)
          Installing the recommended nodejs version now!
          Installing the recommended nodejs version!
          (Reading database ... 134957 files and directories currently installed.)
          Preparing to unpack .../nodejs_18.19.0-1nodesource1_amd64.deb ...
          Detected old npm client, removing...
          Unpacking nodejs (18.19.0-1nodesource1) over (18.17.1-deb-1nodesource1) ...
          Setting up nodejs (18.19.0-1nodesource1) ...
          Processing triggers for man-db (2.10.2-1) ...
          Scanning processes...
          Scanning linux images...
          Running kernel seems to be up-to-date.
          No services need to be restarted.
          No containers need to be restarted.
          No user sessions are running outdated binaries.
          No VM guests are running outdated hypervisor (qemu) binaries on this host.
          *** You need to manually restart your container/virtual machine now! ***
          We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
          klu@iobroker:~$
          Habe danach text2command deinstalliert/installiert. Fehler bleibt.
            @int17
            Hast du den Container jetzt neugestartet?
            Ist nodejs jetzt aktuell?
            Dann
            iob upload all
            ausführen.
            • I
              ja, es wird keine neuere Version angezeigt.
              Was für einen Container meinst du? Ich habe keine Docker Installation.
              iobroker wurde natürlich neu gestartet, da ich ihn ja gestoppt hatte.
              Danach text2command deinstalliert/installiert.
              Log vom upload all:
              upload all.txt
                @int17 sagte in File tab_m.html not found:
                Nee, aber eine kvm-Installation.
                • I
                  die VM habe ich neu gestartet. Dann noch mal iob upload all. Fehler bleibt.
                  • mcm1957
                    mcm1957 @Int17 last edited by mcm1957
                    @int17
                    Also die Datei tab_m.html gibt es nicht. Es existiert nur die Datei tab.html.
                    Mach mal ein Issue beim Adapter auf.
                    Und bitte gib ALLE relevanten Versionen an
                    Adapter: 3.0.2
                    Admin
                    js-controller
                    node
                    Könnte sein, dass sich da was am admin geändert hat.
                    • I
                      Int17 @mcm1957 last edited by
                      @mcm57
                      Hört sich nach einem Plan an. Danke für den Tipp.
                      • mcm1957
                        @int17
                        Bitte Release 3.0.3 testen. Ist ab sofort via npm und ab spätestens morgen via LATEST Repository verfügbar.
                        (Note: Dank für Korrektur geht an @Bluefox !)
                        Ref: https://github.com/ioBroker/ioBroker.text2command/issues/299
                        Klaus-Lucas created this issue in ioBroker/ioBroker.text2command
                        open tab_m.html not found #299
                        • PeterLe
                          PeterLe last edited by PeterLe
                          bei mir kommt nun auch der Fehler "File tab_m.html not found" hoch.
                          Was war denn nun die Lösung?
                          (iobroker gerade erst frisch installiert und Backup eingespielt)
                          Peter
                            Homoran Global Moderator Administrators @PeterLe last edited by
                            @peterle sagte in File tab_m.html not found:
                            restore noch nicht fertig!???
                            nicht diesen Vorgang durch irgendwelche Aktionen stören.
                            PeterLe 1 Reply Last reply Reply Quote 0
                            • PeterLe
                              PeterLe @Homoran last edited by
                              ich hab den restore mit dem Adapter "backitup" gemacht und gewartet bis die Meldung kam, das der Vorgang abgeschlossen ist,
                              dann erst weiter gemacht.
                              Die anderen Adapter funktionieren alle.
                              W Homoran 2 Replies Last reply Reply Quote 0
                                Wildbill @PeterLe last edited by
                                @peterle Wenn die Meldung kommt, fängt der restore erst mit der eigentlichen Arbeit an. Es werden nach und nach alle Adapter, die benötigt werden, installiert. Kann auch mal bis zu einer Stunde dauern und sollte nicht gestört werden, indem man da bereits manuell eingreift, oder ein System bedienen will, was erst gerade im Aufbau ist.
                                Gruss, Jürgen
                                  Homoran Global Moderator Administrators @PeterLe last edited by Homoran
                                  dann war zwat backitup mit seiner Arbeit die gesicherten Konfigurationen wiederherzustellen fertig, aber das System noch lange nicht.
                                  Danach werden alle Adapter neu gebaut.
                                  Das kann man mit iob logs --watch verfolgen oder im Admin zusehen, wie weitestgrhrnd alphabetisch die Instanzen ihre Icons erhalten.
                                  Etwas anderes sollte nicht gemacht werden, da es sonst zu einem inconsistenten System komnen kann.
                                  • PeterLe
                                    PeterLe @Homoran last edited by PeterLe
                                    Danke für die Info
                                    Dann muss ich den Restore wohl nochmal machen... Schade ...
                                    Es wäre vermutlich gut die Meldung des backitup Adapters entsprechend anzupassen
                                    (zB "Restore gestartet und läuft im Hintergrund. Fortschritt kann in der Konsole per <iob logs --watch> geprüft werden")
                                      naja, backitup hat ja das was es gesichert hat vollständig wieder hergestellt.
                                      Also stimmt die Meldung.
                                      Der Rest ist ein neuer Build passend zur möglicherweise neuen Hardware, neuem Betriebssystem und neuem nodejs und hat mit backitup nichts zu tun.
                                      • PeterLe
                                        @Homoran
                                        nach einigen Versuchen habe ich am Ende nun den Raspi komplett neu aufgesetzt,
                                        iobroker neu installiert und das Backup über "backitup" angestossen.
                                        Dann das System in Ruhe gelassen bis im Log keine Aktivitäten mehr geloggt wurden,
                                        dann sicherheitshalber noch zusätzlich 1 Stunde nix gemacht
                                        (gem. Unix "top" war das System mit 1% ausgelastet - da lief aus meiner Sicht kein Compiler o.ä. mehr)
                                        Ergebnis ist das gleich:
                                        Beim Klicken auf den Punkt "Info" im Menü kommt die Meldung "File tab_m.html not found".
                                        Was mich auch wundert ist das nach Neuinstallation des iobroker (also VOR Einspielen des Backups)
                                        der Menüpunkt "Info" gar nicht existiert hat.
                                        D.h. der muss erst durch den Restore reingekommen sein.
                                        Einen eigenen Adapter "Info" hab' ich nicht gefunden - durch welchen Adapter wird der Menüpunkt "Info" denn installiert?
                                        Danke!
                                          Thomas Braun Most Active @PeterLe last edited by
                                          Wo meinst du genau?
                                          Zeig mal die Langfassung von
                                          iob diag
                                            info ist in diesem Fall ein Sonderfall, weil es den nicht mehr im offiziellen Repo gibt, und er somit nicht wieder installiert werden konnte.
                                            dann ist die Meldung auch "normal"
                                            60
                                            3332
