    3. Einsteigerfragen
    4. System updaten raspberry + iobroker + node
      Thomas Braun Most Active @TheAriba last edited by Thomas Braun
      @theariba sagte in System updaten raspberry + iobroker + node:
      Kann ich vorher meine komplette io broker Konfiguration sichern?
      Solltest du so oder so haben. Backitup-Adapter ist dir ein Begriff?
      Gib mal die Langfassung von
      iob diag
      bekannt.
      Ggf. zuvor:
      iob stop
      iob fix
        TheAriba @Thomas Braun last edited by
        wenn ich den backitup adapter installieren möchte, kommt leider folgenden Meldung:
        $ iobroker add backitup --host raspberrypi
        NPM version: 6.14.13
        Installing iobroker.backitup@2.8.7... (System call)
        host.raspberrypi Cannot install iobroker.backitup@2.8.7: 1
        ERROR: Process exited with code 25
        iob diag gibt :
        iobroker [command]
        Commands:
        iobroker setup Setup ioBroker
        iobroker start [all|<adapter>.<instance>] Starts the js-controller or a specified adapter instance
        iobroker stop [<adapter>.<instance>] stops the js-controller or a specified adapter instance
        iobroker restart [<adapter>.<instance>] Restarts js-controller or a specified adapter instance [aliases: r]
        iobroker debug <adapter>[.<instance>] Starts a Node.js debugging session for the adapter instance
        iobroker info Shows the host info
        iobroker logs [<adapter>] Monitor log
        iobroker add <adapter> [desiredNumber] Add instance of adapter [aliases: a]
        iobroker install <adapter> Installs a specified adapter [aliases: i]
        iobroker rebuild [<module>] Rebuild all native modules or path
        iobroker url <url> [<name>] Install adapter from specified url, e.g. GitHub
        iobroker del <adapter> Remove adapter and all instances from this host [aliases: delete]
        iobroker del <adapter>.<instance> Remove adapter instance [aliases: delete]
        iobroker update [<repositoryUrl>] Update repository and list adapters
        iobroker upgrade Upgrade management
        iobroker upload [all|<adapter>] Upload management [aliases: u]
        iobroker object Object management [aliases: o]
        iobroker state State management [aliases: s]
        iobroker message <adapter>[.instance] <command> [<message>] Send message to adapter instance/s
        iobroker list <type> [<filter>] List all entries, like objects
        iobroker chmod <mode> <file> Change file rights
        iobroker chown <user> <group> <file> Change file ownership
        iobroker touch <file> Touch file
        iobroker rm <file> Remove file
        iobroker file File management
        iobroker user User commands
        iobroker group group management
        iobroker host <hostname> Set host to given hostname
        iobroker set <adapter>.<instance> Change settings of adapter config
        iobroker license <license.file or license.text> Update license by given file
        iobroker cert Certificate management
        iobroker clean <yes> Clears all objects and states
        iobroker backup Create backup
        iobroker restore <backup name or path> Restore a specified backup
        iobroker validate <backup name or path> Validate a specified backup
        iobroker status [all|<adapter>.<instance>] Status of ioBroker or adapter instance [aliases: isrun]
        iobroker repo [<name>] Show repo information
        iobroker uuid Show uuid of the installation [aliases: id]
        iobroker unsetup Reset license, installation secret and language
        iobroker fix Execute the installation fixer script, this updates your ioBroker installation
        iobroker multihost Multihost management
        iobroker compact compact group management
        iobroker plugin Plugin management
        iobroker version [<adapter>] Show version of js-controller or specified adapter [aliases: v]
        Options:
        --help Show help [boolean]
          @theariba
          Bitte Texte aus der Konsole in CodeTags eingebettet posten.
          iob stop
          iob fix
          ausführen. Danach wird
          iob diag
          vorhanden sein.
            A Former User @TheAriba last edited by
            @theariba
            mach erstmal n backup der kompletten SD Karte, bevor du weiter machst... oder wenigstens ein backup von iobroker und kopiert dir das file aufn Stick oder aufs Nas..
              TheAriba @Guest last edited by
              @ilovegym gute Sache. Wie kann ich mir das denn auf einen stick sichern?
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                   Static hostname: raspberrypi
                         Icon name: computer
                  Operating System: Raspbian GNU/Linux 10 (buster)
                            Kernel: Linux 5.4.72-v7l+
                      Architecture: arm
                Model		: Raspberry Pi 4 Model B Rev 1.4
                Docker          : false
                Virtualization  : none
                Kernel          : armv7l
                Userland        : armhf
                Systemuptime and Load:
                 10:45:37 up 419 days, 17:11,  1 user,  load average: 0.40, 0.70, 0.50
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** Time and Time Zones ***
                               Local time: Mon 2023-12-18 10:45:37 GMT
                           Universal time: Mon 2023-12-18 10:45:37 UTC
                                 RTC time: n/a
                                Time zone: Europe/London (GMT, +0000)
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                *** X-Server-Setup ***
                X-Server: 	false
                Desktop:
                Terminal: 	tty
                Boot Target: 	graphical.target
                *** MEMORY ***
                Mem:           7.9G        850M        5.8G        400M        1.2G        6.6G
                Swap:           99M          0B         99M
                Total:         8.0G        850M        5.9G
                         7875 M total memory
                          850 M used memory
                         1117 M active memory
                          829 M inactive memory
                         5779 M free memory
                          144 M buffer memory
                         1101 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FAILED SERVICES ***
                0 loaded units listed. Pass --all to see loaded but inactive units, too.
                To show all installed unit files use 'systemctl list-unit-files'.
                *** FILESYSTEM ***
                /dev/root      ext4       59G  3.9G   53G   7% /
                devtmpfs       devtmpfs  3.8G     0  3.8G   0% /dev
                tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                tmpfs          tmpfs     3.9G  401M  3.5G  11% /run
                tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
                /dev/mmcblk0p1 vfat      253M   55M  198M  22% /boot
                tmpfs          tmpfs     788M     0  788M   0% /run/user/1000
                [Mon Oct 24 18:34:35 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1  smsc95xx.macaddr=DC:A6:32:D5:EF:A1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=39b6b4e5-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): 5 orphan inodes deleted
                [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): recovery complete
                [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                [Mon Oct 24 18:34:36 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Mon Oct 24 18:34:38 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                TARGET        SOURCE         FSTYPE OPTIONS
                /             /dev/mmcblk0p2 ext4   rw,noatime
                |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                416M	/var/
                217M	/var/cache
                212M	/var/cache/apt
                153M	/var/cache/apt/archives
                96M	/var/lib
                Archived and active journals take up 400.0M in the file system.
                /opt/iobroker/backups:
                20M	/opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                215M	/opt/iobroker/iobroker-data/
                106M	/opt/iobroker/iobroker-data/files
                79M	/opt/iobroker/iobroker-data/backup-objects
                48M	/opt/iobroker/iobroker-data/files/javascript.admin
                32M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                12M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
                8.3M	/opt/iobroker/iobroker-data/objects.jsonl
                6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                6.2M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
                6.1M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/2.e9a02d96.chunk.js.map
                USB-Devices by-id:
                /dev/serial/by-id/usb-EnOcean_GmbH_EnOcean_USB_300_DC_FT41KIFB-if00-port0
                /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                *** NodeJS-Installation ***
                /usr/bin/nodejs 	v12.22.2
                /usr/bin/node 		v12.22.2
                /usr/bin/npm 		6.14.13
                /usr/bin/npx 		6.14.13
                /home/iobroker/.diag.sh: line 281: corepack: command not found
                *** nodejs is NOT correctly installed ***
                nodejs:
                  Installed: 12.22.2-1nodesource1
                  Candidate: 12.22.12-deb-1nodesource1
                  Version table:
                     12.22.12-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                 *** 12.22.2-1nodesource1 100
                        100 /var/lib/dpkg/status
                     10.24.0~dfsg-1~deb10u1 500
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller: 	4.0.23
                admin: 		6.2.22
                javascript: 	6.0.3
                Adapters from github: 	3
                Adapter State
                + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                  system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                  system.adapter.doorbird.0               : doorbird              : raspberrypi                              -  enabled
                + system.adapter.enocean.0                : enocean               : raspberrypi                              -  enabled
                + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
                + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 192.168.0.122
                  system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
                + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                + system.adapter.yahka.1                  : yahka                 : raspberrypi                              -  enabled
                + system.adapter.yahka.2                  : yahka                 : raspberrypi                              -  enabled
                + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "admin"        : 6.12.0   , installed 6.2.22 [Updatable]
                Adapter    "alexa2"       : 3.26.3   , installed 3.23.2 [Updatable]
                Adapter    "cloud"        : 4.4.1    , installed 4.2.2  [Updatable]
                Adapter    "discovery"    : 4.2.0    , installed 3.0.5  [Updatable]
                Adapter    "doorbird"     : 1.3.0    , installed 0.1.5  [Updatable]
                Adapter    "info"         : 2.0.0    , installed 1.9.19 [Updatable]
                Adapter    "iot"          : 2.0.11   , installed 1.11.9 [Updatable]
                Adapter    "javascript"   : 7.1.6    , installed 6.0.3  [Updatable]
                Controller "js-controller": 5.0.17   , installed 4.0.23 [Updatable]
                Adapter    "sayit"        : 3.0.5    , installed 1.12.3 [Updatable]
                Adapter    "shelly"       : 6.6.1    , installed 4.0.7  [Updatable]
                Adapter    "simple-api"   : 2.7.2    , installed 2.7.0  [Updatable]
                Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
                Adapter    "sonos"        : 3.0.0    , installed 2.2.3  [Updatable]
                Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
                Adapter    "terminal"     : 1.0.0    , installed 0.2.6  [Updatable]
                Adapter    "web"          : 6.1.10   , installed 4.3.0  [Updatable]
                Adapter    "ws"           : 2.5.8    , installed 1.3.0  [Updatable]
                Adapter    "yahka"        : 1.0.3    , installed 0.13.1 [Updatable]
                Adapter    "zigbee"       : 1.8.24   , installed 1.8.10 [Updatable]
                Objects and States
                Objects: 	5746
                States: 	4775
                E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldoldstable'
                E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldoldstable'
                Pending Updates: 132
                *** Listening Ports ***
                tcp        0      0 127.0.0.1:38307         0.0.0.0:*               LISTEN      1001       131216559  14146/io.yahka.0
                tcp        0      0 127.0.0.1:41925         0.0.0.0:*               LISTEN      1001       131216564  14146/io.yahka.0
                tcp        0      0 127.0.0.1:33989         0.0.0.0:*               LISTEN      1001       131216547  14146/io.yahka.0
                tcp        0      0 127.0.0.1:41703         0.0.0.0:*               LISTEN      1001       131217334  14807/io.yahka.1
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       131213641  13946/iobroker.js-c
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       131213634  13946/iobroker.js-c
                tcp        0      0 127.0.0.1:45291         0.0.0.0:*               LISTEN      1001       131219694  14146/io.yahka.0
                tcp        0      0 127.0.0.1:43851         0.0.0.0:*               LISTEN      1001       131217891  14807/io.yahka.1
                tcp        0      0 127.0.0.1:43631         0.0.0.0:*               LISTEN      1001       131216552  14146/io.yahka.0
                tcp        0      0 127.0.0.1:34769         0.0.0.0:*               LISTEN      1001       131218669  14840/io.yahka.2
                tcp        0      0 127.0.0.1:38131         0.0.0.0:*               LISTEN      1001       131220567  14840/io.yahka.2
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16813      572/sshd
                tcp        0      0 127.0.0.1:33561         0.0.0.0:*               LISTEN      1001       131218665  14840/io.yahka.2
                tcp        0      0 127.0.0.1:42905         0.0.0.0:*               LISTEN      1001       131216015  14807/io.yahka.1
                tcp        0      0 127.0.0.1:37211         0.0.0.0:*               LISTEN      1001       131219699  14146/io.yahka.0
                tcp6       0      0 :::38783                :::*                    LISTEN      1001       131216908  14807/io.yahka.1
                tcp6       0      0 :::42977                :::*                    LISTEN      1001       131214296  14146/io.yahka.0
                tcp6       0      0 :::34243                :::*                    LISTEN      1001       131217947  14840/io.yahka.2
                tcp6       0      0 :::36049                :::*                    LISTEN      1001       131214295  14146/io.yahka.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       131213697  13964/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       131215920  14730/io.web.0
                tcp6       0      0 :::22                   :::*                    LISTEN      0          16815      572/sshd
                tcp6       0      0 :::8088                 :::*                    LISTEN      1001       131217864  14781/io.terminal.0
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       131218481  14650/io.shelly.0
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14315      564/dhcpcd
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       131217948  14840/io.yahka.2
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       131216909  14807/io.yahka.1
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       131214300  14146/io.yahka.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       131214297  14146/io.yahka.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15108      382/avahi-daemon: r
                udp        0      0 0.0.0.0:43289           0.0.0.0:*                           108        15110      382/avahi-daemon: r
                udp6       0      0 :::546                  :::*                                0          31124735   564/dhcpcd
                udp6       0      0 :::5353                 :::*                                108        15109      382/avahi-daemon: r
                udp6       0      0 :::42292                :::*                                108        15111      382/avahi-daemon: r
                2023-12-18 10:40:51.439  - info: host.raspberrypi Restart adapter system.adapter.doorbird.0 because enabled
                2023-12-18 10:41:17.821  - info: alexa2.0 (14089) Unknown Device, but enabling commands, Try it and report back if commands work.
                2023-12-18 10:41:17.821  - info: alexa2.0 (14089) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                2023-12-18 10:41:17.822  - info: alexa2.0 (14089)     Device-type:A2RG3FY1YV97SS - Sascha's Sonos Move (Sonos Move) (HANDS_FREE,SET_LOCALE,DEEZER,DIALOG_INTERFACE_VERSION,SLEEP,VOLUME_SETTING,TIDAL,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,SOUND_SETTINGS,SUPPORTS_LOCALE,MULTI_WAKEWORDS_SUPPORTED,CUSTOM_ALARM_TONE,SIRIUSXM,I_HEART_RADIO,ADAPTIVE_LISTENING,GOLDFISH,CHANGE_NAME,MICROPHONE,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,SPEECH_RECOGNIZER_USS,APPLE_MUSIC,FAR_FIELD,AUDIO_PLAYER,EARCONS,SUPPORTS_LOCALE_SWITCH,SET_TIME_ZONE,REMINDERS,DREAM_TRAINING,MUSIC_SKILL,AMAZON_MUSIC,DEREGISTER_DEVICE,KINDLE_BOOKS,AUDIBLE,PERSISTENT_CONNECTION,TUNE_IN,ASCENDING_ALARM_VOLUME,TIMERS_AND_ALARMS)
                2023-12-18 10:41:21.475  - info: host.raspberrypi instance system.adapter.doorbird.0 started with pid 15127
                2023-12-18 10:41:24.179  - info: doorbird.0 (15127) starting. Version 0.1.5 (non-npm: https://github.com/BuZZy1337/ioBroker.doorbird/tarball/47440ddff9a9074ef1e0beb8ff7b7f2a6e368efb) in /opt/iobroker/node_modules/iobroker.doorbird, node: v12.22.2, js-controller: 4.0.23
                2023-12-18 10:41:24.275  - error: doorbird.0 (15127) uncaught exception: listen EADDRNOTAVAIL: address not available 192.168.0.122:8100
                2023-12-18 10:41:24.277  - error: doorbird.0 (15127) Error: listen EADDRNOTAVAIL: address not available 192.168.0.122:8100
                    at Server.setupListenHandle [as _listen2] (net.js:1299:21)
                    at listenInCluster (net.js:1364:12)
                    at doListen (net.js:1501:7)
                    at processTicksAndRejections (internal/process/task_queues.js:85:21)
                2023-12-18 10:41:24.278  - error: doorbird.0 (15127) Exception-Code: EADDRNOTAVAIL: listen EADDRNOTAVAIL: address not available 192.168.0.122:8100
                2023-12-18 10:41:24.299  - info: doorbird.0 (15127) terminating
                2023-12-18 10:41:24.300  - warn: doorbird.0 (15127) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2023-12-18 10:41:24.899  - error: host.raspberrypi instance system.adapter.doorbird.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2023-12-18 10:41:24.900  - info: host.raspberrypi Restart adapter system.adapter.doorbird.0 because enabled
                2023-12-18 10:41:24.900  - warn: host.raspberrypi Do not restart adapter system.adapter.doorbird.0 because restart loop detected
                2023-12-18 10:41:32.861  - info: alexa2.0 (14089) No smart home devices to query
                2023-12-18 10:41:36.052  - info: alexa2.0 (14089) Subscribing to states...
                2023-12-18 10:41:36.056  - info: alexa2.0 (14089) Deleting the following states: ["Smart-Home-Devices.0a811299-fb7f-4ea9-b76c-42ce750e89b6.lowerSetpoint","Smart-Home-Devices.0a811299-fb7f-4ea9-b76c-42ce750e89b6.lowerSetpoint-scale","Smart-Home-Devices.0a811299-fb7f-4ea9-b76c-42ce750e89b6.upperSetpoint","Smart-Home-Devices.0a811299-fb7f-4ea9-b76c-42ce750e89b6.upperSetpoint-scale","Smart-Home-Devices.9182c302-7eb1-4d03-a40b-a0f305a5dea7.lowerSetpoint","Smart-Home-Devices.9182c302-7eb1-4d03-a40b-a0f305a5dea7.lowerSetpoint-scale","Smart-Home-Devices.9182c302-7eb1-4d03-a40b-a0f305a5dea7.upperSetpoint","Smart-Home-Devices.9182c302-7eb1-4d03-a40b-a0f305a5dea7.upperSetpoint-scale","Smart-Home-Devices.715097f8-0444-409a-ba9b-97c872c95c91.lowerSetpoint","Smart-Home-Devices.715097f8-0444-409a-ba9b-97c872c95c91.lowerSetpoint-scale","Smart-Home-Devices.715097f8-0444-409a-ba9b-97c872c95c91.upperSetpoint","Smart-Home-Devices.715097f8-0444-409a-ba9b-97c872c95c91.upperSetpoint-scale","Smart-Home-Devices.770c27df-9728-4765-b41e-011704586681.lowerSetpoint","Smart-Home-Devices.770c27df-9728-4765-b41e-011704586681.lowerSetpoint-scale","Smart-Home-Devices.770c27df-9728-4765-b41e-011704586681.upperSetpoint","Smart-Home-Devices.770c27df-9728-4765-b41e-011704586681.upperSetpoint-scale"]
                2023-12-18 10:41:37.858  - info: alexa2.0 (14089) Alexa-Push-Connection (macDms = true) established. Disable Polling
                2023-12-18 10:41:52.977  - info: alexa2.0 (14089) Initialization Done ...
                2023-12-18 10:45:27.558  - info: enocean.0 (14745) state 0584df18.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1702896327553,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1702896327553}
                2023-12-18 10:45:28.908  - info: enocean.0 (14745) state 0584df18.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1702896328901,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1702896328901}
                  @theariba
                  Zeitzone falsch.
                  sudo timedatectl set-timezone "Europe/Berlin"
                  Dein Dateisystem hat einen Treffer:
                  Die Pending Updates: 132 zuerst einspielen:
                  sudo apt update
                  iob stop
                  sudo apt full-upgrade
                  iob nodejs-update
                  sudo reboot
                  Wenn der Server wieder auf die Beine gekommen ist:
                  iob update
                  iob upgrade all -y
                  iob stop
                  iob upgrade self
                  iob start
                  Dann davon ein Backup extern ablegen und das ganze System NEU als Raspberry OS 64Bit Lite installieren. Dort das Backup wieder einspielen, fertig.
                    für mich als Noob:
                    1. Zeitzone korrigieren
                    1. diese Befehle ausführen:
                    sudo apt update
                    iob stop
                    iob nodejs-update
                    sudo reboot
                    iob update
                    iob upgrade all -y
                    iob stop
                    iob upgrade self
                    iob start
                    Wie ich dann ein Backup extern ablegen kann muss ich dann noch recherchieren.
                    Dann mache ich quasi den pi platt und setze es mit raspberry 64 OS bit Lite neu auf und spiele dann das backup ein?
                      Ja, das ist der Plan.
                        Ok. Werde nachher mal die Befehle so durchführen.
                        Kannst du mir evtl. Sagen wie ich das mit dem Backup auf usb Stick oder so hinbekomme?
                        Und wie macht man den Pi platt und setzt ihn neu auf?
                          Ich würde es per Backitup-Adapter machen.
                          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                          T 1 Reply Last reply Reply Quote 2
                            @thomas-braun so, habe die erste Runde der Befehle mal ausgeführt. Nun Backitup Adapter installiert und versuche ein Backup auf Google Drive zu erstellen. Finde leider keinen USB Stick gerade...
                            wie kann ich sehen ob es erfolgreich war bzw. ob alles dabei ist? Am wichtigsiten ist mir mein Enocean Adapter...
                              @theariba
                              Im Backup sind die Adapter und deren Einstellungen enthalten.
                                @thomas-braun ok danke. Habe irgendwie Bedenken dass ich mir das zerschiesse. Warum genau empfiehlt es sich denn das Raspberry OS zu aktualisieren?
                                  Weil deine Version 10 'Buster' abgekündigt wurde, das EndOfLife erreicht hat und weil du da seinerzeit eine 32Bit-Version installiert hast, mittlerweile aber die 64Bit-Variante die besser für einen Raspberry Pi geeignete ist.
                                  Und ganz allgemein, weil man seinen Softwarestack immer auf Stand hält.
                                    @thomas-braun ok alles klar. Dann mache ich mich da heute Abend mal dran. Kurz zum Verständnis der Vorgehensweise:
                                    • Über den Backitup auf einen beliebigen USB Stick das Backup ablegen.
                                      Dafür gebe ich im Backitup Adapter unter NAS/Kopieren den Pfad /media/usbstick/backupDir an. Muss ich hier sonst noch etwas beachten?
                                    • Dann formatiere ich die SD Karte, und setze dann das neue OS so auf wie in deiner Beschreibung
                                    • Wie spielt man dann das Backup wieder auf?
                                      Die Geräte muss ich sicher nicht mehr neu einlernen?
                                    Sorry aber ich habe ein wenig Schiss 🙂
                                    • OliverIO
                                      OliverIO last edited by
                                      @theariba
                                      ich würde lieber eine neue SD-Karte nehmen. dann hast du a) die alte zur Sicherheit noch zur Hand und b) das Risiko, das die SD-Karte bereits einen Hau hat (wegen den verwaisten inodes) ist weg.
                                        TheAriba @OliverIO last edited by
                                        @oliverio ok verstehe. Bedeutet das sobald ich die alte Karte einstecke habe ich den aktuellen Stand wieder und das funktioniert alles wie gehabt? Habe ich das mit dem Backup soweit richtig verstanden? Wie füge ich das dann wieder auf im neuen System ein? Muss ich dazu einen neuen iobroker aufsetzen oder geht das über Befehle? bspw. hole dir die Datei vom USB Stick?
                                        • OliverIO
                                          OliverIO @TheAriba last edited by
                                          ja, das ist wie die Festplatte wechseln. Wenn die alte wieder einbaust, dann gehts genau mit dem letzten stand weiter. der raspi ist nur hardware und hat kein weiteres "Gedächtnis".
                                          Dann kannst du zur Not immer mal noch nachschauen
                                          3940
