    4. Nach Plattformupdate Alles träge und CPU teilweise Volllast
      MegaMatze @Homoran last edited by
      Leider immer noch keine Besserung auch nach Updates und Herstellen von Stable zum größten Teil (BMW und Senec brauchen die Github Version da APIs geändert und noch nicht im Stable integriert)
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Ubuntu 22.04.3 LTS
                Kernel: Linux 5.15.0-91-generic
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       16:24:54 up 19:06,  2 users,  load average: 0.98, 0.89, 0.76
      CPU threads: 8
      *** Time and Time Zones ***
                     Local time: Mon 2023-12-18 15:24:54 UTC
                 Universal time: Mon 2023-12-18 15:24:54 UTC
                       RTC time: Mon 2023-12-18 15:24:54
                      Time zone: Etc/UTC (UTC, +0000)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      matze
      /home/matze
      matze adm cdrom sudo dip plugdev lxd iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            5.8G        3.0G        781M        1.0M        2.0G        2.5G
      Swap:           2.0G          0B        2.0G
      Total:          7.8G        3.0G        2.8G
               5779 M total memory
               2994 M used memory
                630 M active memory
               4021 M inactive memory
                781 M free memory
                134 M buffer memory
               1869 M swap cache
               2047 M total swap
                  0 M used swap
               2047 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                        Type   Size  Used Avail Use% Mounted on
      tmpfs                             tmpfs  578M  1.1M  577M   1% /run
      /dev/mapper/ubuntu--vg-ubuntu--lv ext4    15G   10G  4.0G  72% /
      tmpfs                             tmpfs  2.9G     0  2.9G   0% /dev/shm
      tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
      /dev/sda2                         ext4   2.0G  251M  1.6G  14% /boot
      tmpfs                             tmpfs  578M  4.0K  578M   1% /run/user/1000
      [Sun Dec 17 21:18:02 2023] EXT4-fs (dm-0): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
      [Sun Dec 17 21:18:03 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode:        none.
      [Sun Dec 17 21:18:05 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Opts: (null). Quota mode: none.
      TARGET              SOURCE                            FSTYPE   OPTIONS
      /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
      |-/snap/core20/2105 /dev/loop1                        squashfs ro,nodev,relatime        ,errors=continue
      |-/snap/core20/2015 /dev/loop0                        squashfs ro,nodev,relatime        ,errors=continue
      |-/snap/lxd/24322   /dev/loop2                        squashfs ro,nodev,relatime        ,errors=continue
      |-/snap/snapd/19457 /dev/loop3                        squashfs ro,nodev,relatime        ,errors=continue
      |-/snap/snapd/20290 /dev/loop4                        squashfs ro,nodev,relatime        ,errors=continue
      `-/boot             /dev/sda2                         ext4     rw,relatime
      /var:
      813M    /var/
      622M    /var/lib
      398M    /var/lib/snapd
      334M    /var/lib/snapd/snaps
      178M    /var/lib/apt/lists
      Archived and active journals take up 72.0M in the file system.
      /opt/iobroker/backups:
      27M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      977M    /opt/iobroker/iobroker-data/
      387M    /opt/iobroker/iobroker-data/history
      329M    /opt/iobroker/iobroker-data/files
      103M    /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      110M    /opt/iobroker/iobroker-data/states.jsonl
      50M     /opt/iobroker/iobroker-data/objects.jsonl
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.ma        p
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.m        ap
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m        ap
      USB-Devices by-id:
      USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
           12.22.9~dfsg-1ubuntu3.2 500
              500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Pac        kages
              500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Pack        ages
           12.22.9~dfsg-1ubuntu3 500
              500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   3
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker        -  enabled, port: 8081, bind: 192.168.178.101, run        as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker        -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker        -  enabled
      + system.adapter.bmw.0                    : bmw                   : iobroker        -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : iobroker        -  enabled
        system.adapter.chromecast.0             : chromecast            : iobroker        -  enabled
        system.adapter.cloud.0                  : cloud                 : iobroker        - disabled
      + system.adapter.deconz.0                 : deconz                : iobroker        -  enabled, port: 80
      + system.adapter.device-reminder.0        : device-reminder       : iobroker        -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker        -  enabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker        - disabled
        system.adapter.flot.0                   : flot                  : iobroker        - disabled
      + system.adapter.go-e.0                   : go-e                  : iobroker        -  enabled
      + system.adapter.haassohn.0               : haassohn              : iobroker        -  enabled
        system.adapter.habpanel.0               : habpanel              : iobroker        - disabled
      + system.adapter.history.0                : history               : iobroker        -  enabled
      + system.adapter.hmip.0                   : hmip                  : iobroker        -  enabled
      + system.adapter.info.0                   : info                  : iobroker        -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker        -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker        -  enabled
        system.adapter.material.0               : material              : iobroker        -  enabled
        system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker        - disabled, port: 54321
        system.adapter.mobile.0                 : mobile                : iobroker        - disabled
        system.adapter.mqtt.0                   : mqtt                  : iobroker        - disabled, port: 1885, bind: 0.0.0.0
      + system.adapter.ping.0                   : ping                  : iobroker        -  enabled
      + system.adapter.proxmox.0                : proxmox               : iobroker        -  enabled, port: 8006
      + system.adapter.pvforecast.0             : pvforecast            : iobroker        -  enabled
      + system.adapter.scenes.0                 : scenes                : iobroker        -  enabled
      + system.adapter.senec.0                  : senec                 : iobroker        -  enabled
        system.adapter.smartthings.0            : smartthings           : iobroker        - disabled
        system.adapter.sonoff.0                 : sonoff                : iobroker        - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : iobroker        -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : iobroker        -  enabled, port: 8088, bind: 0.0.0.0, run as: admi        n
      + system.adapter.text2command.0           : text2command          : iobroker        -  enabled
        system.adapter.tr-064.0                 : tr-064                : iobroker        - disabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker        -  enabled
        system.adapter.vis-history.0            : vis-history           : iobroker        -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker        -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker        -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker        -  enabled
        system.adapter.vis-map.0                : vis-map               : iobroker        -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker        -  enabled
        system.adapter.vis.0                    : vis                   : iobroker        -  enabled
        system.adapter.vofo-speedtest.0         : vofo-speedtest        : iobroker        - disabled
      + system.adapter.web.0                    : web                   : iobroker        -  enabled, port: 8082, bind: 192.168.178.101, run        as: admin
        system.adapter.worx.0                   : worx                  : iobroker        - disabled
      + system.adapter.yeelight-2.0             : yeelight-2            : iobroker        -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "bmw"          : 2.5.7    , installed 2.7.2
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
      Adapter    "deconz"       : 1.3.23   , installed 1.3.23
      Adapter    "device-reminder": 3.0.0  , installed 3.0.0
      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter    "go-e"         : 1.0.29   , installed 1.0.29
      Adapter    "haassohn"     : 1.0.9    , installed 1.0.9
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "hmip"         : 1.20.0   , installed 1.20.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
      Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
      Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "telegram"     : 3.0.0    , installed 3.0.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "worx"         : 2.3.4    , installed 2.3.4
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
      Objects and States
      Objects:        68286
      States:         66362
      Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:5 http://security.ubuntu.com/ubuntu jammy-security InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.178.101:8081    0.0.0.0:*               LISTEN      1001       34853      2668/io.admin.0
      tcp        0      0 192.168.178.101:8082    0.0.0.0:*               LISTEN      1001       36243      3236/io.web.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32732      2642/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       33148      2642/iobroker.js-co
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        22562      634/systemd-resolve
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14261      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21002      693/sshd: /usr/sbin
      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       36217      3177/io.terminal.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          15839      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          21013      693/sshd: /usr/sbin
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       91001      11682/io.deconz.0
      udp        0      0 0.0.0.0:59941           0.0.0.0:*                           1001       338175     32740/io.broadlink2
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       335701     32740/io.broadlink2
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        22561      634/systemd-resolve
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          19077      1/init
      udp        0      0 0.0.0.0:45198           0.0.0.0:*                           1001       338182     32740/io.broadlink2
      udp6       0      0 :::1900                 :::*                                1001       91003      11682/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       91002      11682/io.deconz.0
      udp6       0      0 :::111                  :::*                                0          2039       1/init
      2023-12-18 15:22:11.535  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
      2023-12-18 15:22:11.573  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
      2023-12-18 15:22:11.597  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
      2023-12-18 15:22:11.700  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
      2023-12-18 15:22:11.703  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
      2023-12-18 15:22:11.775  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
      2023-12-18 15:22:45.342  - info: admin.0 (2668) failed connection to socket.io from 192.168.178.79: Passport was not initialized
      2023-12-18 15:22:52.004  - info: admin.0 (2668) ==> Connected system.user.admin from 192.168.178.79
      2023-12-18 15:23:06.325  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 vis.0
      2023-12-18 15:23:09.133  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
      2023-12-18 15:23:09.294  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
      2023-12-18 15:23:09.385  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
      2023-12-18 15:23:09.401  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
      2023-12-18 15:23:09.540  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
      2023-12-18 15:23:09.600  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
      2023-12-18 15:23:16.514  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
      2023-12-18 15:24:48.037  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
      2023-12-18 15:24:49.990  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
      2023-12-18 15:25:10.188  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.152 vis.0
      2023-12-18 15:25:47.700  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
      2023-12-18 15:25:47.741  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
      2023-12-18 15:25:47.893  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
      2023-12-18 15:25:48.033  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
      2023-12-18 15:27:10.031  - info: web.0 (3236) <== Disconnect system.user.admin from 192.168.178.149 flot
      2023-12-18 15:27:10.250  - info: web.0 (3236) ==> Connected system.user.admin from 192.168.178.149
      ? Homoran 2 Replies Last reply Reply Quote 0
        A Former User @MegaMatze last edited by
        @megamatze sagte in Nach Plattformupdate Alles träge und CPU teilweise Volllast:
        Moin,
        Zeitzone ist nicht umgestellt, ist zwar nicht das Problem, aber richtig ist besser 😉
        Dann solltest/kannst Du ja mal darüber nachdenken, die Objekts und States Datenbank von jsonl auf Redis umzustellen, da du doch recht viele States und Objekte hast.
        Objects type: jsonl
        States  type: jsonl
        Objects and States
        Objects:        68286
        States:         66362
        VG
        Bernd
          Homoran Global Moderator Administrators @MegaMatze last edited by
          @megamatze
          und
          @homoran sagte in Nach Plattformupdate Alles träge und CPU teilweise Volllast:
          @megamatze Die Frage zu Proxmox bitte auch noch beantworten.
            @homoran Oh das hab ich ganz übersehen mit dem Proxmox. Das habe ich nie upgedatet, weil ich da sehr viel Respekt vor habe. Da läuft noch Virtual Environment 6.3-2. Muss das auch zwingend upgedatet werden? Falls ja, gibt es da auch ein Updateskript bei dem nix kaputt geht? Oder können die Backups der VMs einfach bei Neuinstallation wiederhergestellt werden?
            @dp20eic das verstehe ich nicht ganz, wenn ich in der Shell date eingebe kommt in Ubuntu die korrekte Uhrzeit. Muss das in iob auch noch angepasst werden?
            Meister Mopper Thomas Braun ? 3 Replies Last reply Reply Quote 0
              MegaMatze @Guest last edited by
              @dp20eic Wegen der Objects bin ich irgendwie überfragt. Kann ich irgendwie rausfinden, welche Instanz so viele Objects eingeführt hat? Eigenltich habe ich nicht so viele Komponenten im Smarthome....das wirkt ja als wäre die iob in einem Konzern installiert 😄
              • Meister Mopper
                Meister Mopper @MegaMatze last edited by Meister Mopper
                Um es philosophisch auszudrücken: "Alles fließt!"
                Die Hardware ändert sich ständig, und so sollten auch Betriebs- und Virtualisierungssysteme, die ja mit der Hardware arbeiten, ständig aktualisiert werden.
                Und dann gibt es noch die Liga derer, die Systeme infiltrieren möchten, um illegal Ressourcen zu ergattern oder illegal an mehr Geld zu kommen.
                Der Ausspruch: "Never change a running system" ist nicht nur in Richtung Hardware unsinnig sondern insbesondere in Sachen Sicherheit vollumfänglicher Unsinn.
                  Thomas Braun Most Active @MegaMatze last edited by
                  Ja, wie jegliche andere Software halt auch.
                    @thomas-braun und @Meister-Mopper Ok verstanden, dann werde ich mich da mal nach Weihnachten ransetzen und das aktualisieren. Gibt es dafür vielleicht eine Anleitung irgendwo, wie man das am geschicktesten mit Wiederherstellung der VMs hinkriegt?
                    Bezüglich der vielen Objects und States: Gibt es da eine Möglichkeit den Übertäter zu finden wo die alle herkommen? Ich vermute mal, dass das der Grund allen Übels ist.
                      Moin,
                      ich auch nicht, da ich nicht weis, was Du wo, wie eingestellt hast. Du sitzt vor der Kiste, dann solltest Du uns auch zeigen, was Du gemacht hast. Zudem nutze ich kein Ubuntu -> https://wiki.ubuntuusers.de/Systemzeit/, dann unter
                      Anpassungen in einem Terminal
                      Hier hast Du die Zeit total verschlafen, wir sind aktuell bei 8.1, eine Migration über zwei Releases ist keine gute Idee, außer Du hast genug Linux Erfahrungen. Also VMs und LXC Backupen auf extern Datenträgern, dann lieber Proxmox neu installieren und die Backups wieder Restoren.
                      Das ist auch wieder so was, wenn man alles Mögliche an Adaptern installiert aber nicht nutzt, dann liegen viele nutzlose Daten im System herum, was Du dann noch per Skript machst, kannst auch nur Du beantworten.
                      Ich würde mir mal wirklich Gedanken machen, was Du brauchst und was nicht, dann das was nicht deinstallieren.
                      VG
                      Bernd
                        Jetzt habe ich gerade einen Aha Moment gehabt. Euer Hinweis bezüglich der vielen Objekte hat mich tatsächlich zu dem als Fehlerursache geführt. Aus eigener Suche habe ich dann entdeckt, dass ich per JSON Download die 68k Elemente schnell und einfach lesbar downloaden kann und beim Öffnen festgestellt, dass 55k Objekte einfach mal vom Smartthings Adapter für meine Samsung Wärmepumpe gekommen sind. Offenbar ist dieser Adapter nicht ganz Banane. Ich versuche jetzt mal diesen zu löschen, aber vermute mal, dass er der Übeltäter war. Vermutlich hat der nach dem Nodejs Update Hohl gedreht oder so. Ich probier das jetzt mal aus alles zu löschen und dann bin ich gespannt, was dann Phase auf meinem iob ist. Nichts desto trotz werde ich mal das Proxmox Update über Weihnachten in Angriff nehmen. Ich halt euch mal uptodate was jetzt beim Löschen rauskommt. Danke für die HIlfe
                          wohl kaum.
                          oder so.
                          kann schon eher sein!
                          1790
