    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      mading last edited by
      @tombox seit ein paar Tagen wird der aktuelle SoC nicht mehr aktualisiert, ich habe auch die neuste Version des Adapters von Github installiert. Alle anderen Daten stimmen (z.B. Auto fährt/ Adresse etc.)
      Hier eine Debug Ausgabe beim Start des Adapters. Es gibt keine Fehler/ Warnings
      Zeit
      Nachricht
      vw-connect.0
      	2023-12-19 07:40:29.785	debug	No update lat ts 1702968024740 <-> lc 1702926256478, long ts 1702968024654 <-> lc 1702926256477
      vw-connect.0
      	2023-12-19 07:40:29.699	debug	No update lat ts 1702968024740 <-> lc 1702926256478, long ts 1702968024654 <-> lc 1702926256477
      vw-connect.0
      	2023-12-19 07:40:28.984	debug	{"place_id":60049425,"licence":"Data © OpenStreetMap contributors, ODbL 1.0. http://osm.org/copyright","osm_type":"way","osm_id":,"lat":".","lon":"9.","class":"building","type":"house","place_rank":30,"importance":0.00000999999999995449,"addresstype":"building","name":"","display_name":"h, Verwaltungsgemeinschaft Konstanz, Landkreis , Baden-Württemberg, , Deutschland","address":{"house_number":"1","road":"Im Garten","residential":"","village":"","municipality":"Verwaltungsgemeinschaft ","county":"Landkreis ","state":"Baden-Württemberg","ISO3166-2-lvl4":"DE-BW","postcode":"","country":"Deutschland","country_code":"de"},"boundingbox":[""]}
      vw-connect.0
      	2023-12-19 07:40:28.984	debug	reverse pos received
      vw-connect.0
      	2023-12-19 07:40:28.822	debug	reverse pos started
      vw-connect.0
      	2023-12-19 07:40:28.776	debug	No update lat ts 1702968024740 <-> lc 1702926256478, long ts 1702968024654 <-> lc 1702926256477
      vw-connect.0
      	2023-12-19 07:40:24.648	debug	Skip last trip check because of last check was less than 15min ago
      vw-connect.0
      	2023-12-19 07:40:24.648	debug	{"data":{"lon":975,"carCapturedTimestamp":"2023-12-18T19:03:27Z"}}
      vw-connect.0
      	2023-12-19 07:40:23.864	info	No last shorterm trips found. Please check if your car supports shortterm trips.
      vw-connect.0
      	2023-12-19 07:40:23.723	debug	{"data":{"lon":9.080263,"lat":47.746975,"carCapturedTimestamp":"2023-12-18T19:03:27Z"}}
      vw-connect.0
      	2023-12-19 07:40:23.429	debug	{}
      vw-connect.0
      	2023-12-19 07:40:23.427	debug	WVGZZZE2ZNxxx: set default homeregion
      vw-connect.0
      	2023-12-19 07:40:23.423	debug	{}
      vw-connect.0
      	2023-12-19 07:40:23.321	debug	getHomeRegion
      vw-connect.0
      	2023-12-19 07:40:23.318	info	Create vehicle WVGZZZE2ZNxxx
      vw-connect.0
      	2023-12-19 07:40:23.317	info	Found 1 vehicles
      vw-connect.0
      	2023-12-19 07:40:23.317	debug	{"data":[{"vin":"WVGZZZE2ZNP025704","role":"PRIMARY_USER","userRoleStatus":"ENABLED","enrollmentStatus":"COMPLETED","brandCode":"V","model":"ID.4","nickname":"ID4","capabilities":[{"id":"webApp","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":false},{"id":"automation","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"batteryChargingCare","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":true},{"id":"batteryColdWarning","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":true},{"id":"batterySupport","userDisablingAllowed":false},{"id":"charging","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"chargingProfiles","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":false},{"id":"chargingStations","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"climatisation","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"climatisationTimers","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":false},{"id":"cubicNetwork","userDisablingAllowed":false},{"id":"dealerAppointment","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":true},{"id":"destinations","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"fuelStatus","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":false},{"id":"ignition","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":false},{"id":"mapUpdate","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"measurements","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":false},{"id":"onlineSpeech","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"parkingBrake","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":false},{"id":"parkingInformation","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"parkingPosition","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":true},{"id":"personalizationOnline","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":true},{"id":"plugAndCharge","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":true},{"id":"poiSearch","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"readiness","userDisablingAllowed":false},{"id":"routing","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"state","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":true},{"id":"trafficInformation","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true},{"id":"vehicleHealth","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":true},{"id":"vehicleHealthInspection","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":false},{"id":"vehicleHealthWarnings","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":false},{"id":"vehicleLights","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":false},{"id":"vehicleWakeUpTrigger","expirationDate":"2052-12-28T23:59:59Z","userDisablingAllowed":false},{"id":"webRadio","expirationDate":"2028-12-29T23:59:59Z","userDisablingAllowed":true}],"images":{},"coUsers":[],"devicePlatform":"WCAR","tags":[]}]}
      vw-connect.0
      	2023-12-19 07:40:22.858	info	Login successful
      vw-connect.0
      	2023-12-19 07:40:22.857	info	History limit is set to -1, no wall charging login
      vw-connect.0
      	2023-12-19 07:40:22.857	info	History limit: -1, set to -1 to disable wallcharging login
      vw-connect.0
      	2023-12-19 07:40:22.857	info	ID login successfull
      vw-connect.0
      	2023-12-19 07:40:22.674	debug	Error: Invalid protocol: weconnect:
      vw-connect.0
      	2023-12-19 07:40:22.285	debug	{"date":"Tue, 19 Dec 2023 06:40:22 GMT","content-length":"0","connection":"close","apigw-requestid":"QLYhfgORFiAEJ6g=","x-content-type-options":"nosniff","x-xss-protection":"0","cache-control":"no-cache, no-store, max-age=0, must-revalidate","pragma":"no-cache","expires":"0","strict-transport-security":"max-age=31536000; includeSubDomains; preload","x-frame-options":"DENY","location":"https://identity.vwgroup.io/oidc/v1/oauth/sso?clientId=a24fba63-34b3-4d43-b181-942111e6bda8@apps_vw-dilab_com&relayState=2cb09e33a8c21b41b7516fb0b7e85f9654fbefe1&userId=aed7f161-5d05-4d8c-9e55-1d1df2ca88af&HMAC=1e6d1436d17c622efd394c8cada6b80a07f5d54251478f0a683300eb755aaba3","content-language":"en-US"}
      vw-connect.0
      	2023-12-19 07:40:22.285	debug	""
      vw-connect.0
      	2023-12-19 07:40:21.976	debug	emailPasswordForm2
      vw-connect.0
      	2023-12-19 07:40:21.702	debug	parseEmailForm
      vw-connect.0
      	2023-12-19 07:40:21.175	info	Login in with id
      vw-connect.0
      	2023-12-19 07:40:21.166	info	starting. Version 0.3.6 (non-npm: TA2k/ioBroker.vw-connect#a336d6b81048cf5cbdb5233d0a03862ce510a94b) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.19.0, js-controller: 5.0.17
      vw-connect.0
      	2023-12-19 07:40:21.029	debug	Plugin sentry Initialize Plugin (enabled=true)
      vw-connect.0
      	2023-12-19 07:40:21.005	debug	States connected to redis: 127.0.0.1:9000
      vw-connect.0
      	2023-12-19 07:40:20.933	debug	States create User PubSub Client
      vw-connect.0
      	2023-12-19 07:40:20.932	debug	States create System PubSub Client
      vw-connect.0
      	2023-12-19 07:40:20.916	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      vw-connect.0
      	2023-12-19 07:40:20.885	debug	Objects connected to redis: 127.0.0.1:9001
      vw-connect.0
      	2023-12-19 07:40:20.882	debug	Objects client initialize lua scripts
      vw-connect.0
      	2023-12-19 07:40:20.833	debug	Objects create User PubSub Client
      vw-connect.0
      	2023-12-19 07:40:20.832	debug	Objects create System PubSub Client
      vw-connect.0
      	2023-12-19 07:40:20.831	debug	Objects client ready ... initialize now
      vw-connect.0
      	2023-12-19 07:40:20.804	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      vw-connect.0
      	2023-12-19 07:40:17.734	info	terminating
      vw-connect.0
      	2023-12-19 07:40:17.234	debug	Plugin sentry destroyed
      vw-connect.0
      	2023-12-19 07:40:17.233	info	terminating
      vw-connect.0
      	2023-12-19 07:40:17.234	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      vw-connect.0
      	2023-12-19 07:40:17.233	info	cleaned everything up...
      vw-connect.0
      	2023-12-19 07:40:17.233	info	Got terminate signal TERMINATE_YOURSELF
        mick70 last edited by mick70
        Ich habe mit der Github-Version 0.3.6 seit 17.12.23 13:40 auch keine Aktualisierungen mehr, betrifft aber alle Datenpunkte. Die VW App funktioniert (e-Golf). Dafür gibt es Auffälligkeiten im Log (alle 20 Minuten):
        2023-12-19 07:41:17.368	info	Server not available:{"error":{"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2,"retry":true}}
        2023-12-19 07:41:08.692	info	Server not available:{"error":{"message":"Upstream service responded with 502 Bad Gateway"}}
        2023-12-19 07:40:48.569	info	Server not available:{"error":{"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2,"retry":true}}
        2023-12-19 07:40:39.993	info	Server not available:{"error":{"info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"retry":true,"group":2,"message":"Bad Gateway"}}
        2023-12-19 07:40:30.944	info	Server not available:{"error":{"retry":true,"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2}}
        2023-12-19 07:40:21.968	info	Server not available:{"error":{"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2,"retry":true}}
        Bei Neustart des Adapter klappt das Login zwar:
        2023-12-19 08:02:03.677	info	Create vehicle WVWZZZAUZL*****
        2023-12-19 08:02:03.672	info	Found 1 vehicles
        2023-12-19 08:02:03.382	info	Minimum update interval is 15min for Wallcharging data, to prevent blocking
        2023-12-19 08:02:03.381	info	Wallcharging login was successfull
        2023-12-19 08:02:02.659	info	Login successful
        2023-12-19 08:02:02.652	info	Login in with id
        2023-12-19 08:02:02.651	info	Start Wallcharging login
        2023-12-19 08:02:02.650	info	History limit: 100, set to -1 to disable wallcharging login
        2023-12-19 08:02:02.649	info	ID login successfull
        Aber danach kommen sofort wieder die o.g. Serverfehler.
        Zur Fehlermeldung 4105 habe ich zwar hier im Thread schon was gefunden, kann aber keinen Zusammenhang zu meinen Einstellungen feststellen, zumal ich eigentlich nichts bewusst geändert habe. Ich musste zwischenzeitlich ein iobroker Backup einspielen (10h alt), aber das hat bisher auch noch nie Probleme mit dem Adapter verursacht.
        Tl;dr: Woran könnts liegen? Bin ich der einzige mit diesen Serverproblemen? habe ich beim Restore des Backups doch was falsch gemacht?
          BobBruni last edited by
          Bei mir werden auch seit ca. 2 Tagen einige Werte nicht mehr aktualisiert z.B. Fuel Level Primary und Secundary Engine... Auch kann ich die Cliamtisation nicht mehr steuern. Das Log bleibt bei mir aber leer.
            Sneak-L8 @BobBruni last edited by Sneak-L8
            @bobbruni Bei mir wurde seit gestern 9:09 Uhr im Adapter nichts mehr aktualisiert. In der App kommen aber noch die korrekten Werte (=> ID.3). Im Log steht nichts.
            mcBirne B 2 Replies Last reply Reply Quote 0
            • mcBirne
              mcBirne @Sneak-L8 last edited by
              früher gabe es bei dem Adapter unter status den Punkt isCarLocked. bei mir gibt es unter Status eine Werte mehr. Ist der Wert jetzt an einer anderen Stelle zu finden? Ich konnte ihn bis jetzt nicht finden.
                schmuh last edited by
                Im EVCC Forum scheint der Fehler auch bekannt zu sein Link, vielleicht hilft das @tombox bei der Fehlersuche.
                  BobBruni @Sneak-L8 last edited by
                  @sneak-l8 said in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                  Bei mir ist es seit gestern 09.16 Uhr. Die App funktioniert. (VW Tiguan Hybrid)
                  • BananaJoe
                    BananaJoe Most Active @BobBruni last edited by
                    @bobbruni sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                    Ich habe auch einen Tiguan Hybrid und bei funktioniert es, laut Log auch ohne Unterbrechungen.
                      Maverick78 @mick70 last edited by Maverick78
                      @mick70 Kann ich bestätigen bei mir ebenfalls seit Samstag
                      Betroffen bei mir sowohl der e-Golf wie auch der Audi e-tron.
                      2023-12-19 08:38:05.025  - info: vw-connect.0 (255684) starting. Version 0.3.6 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.19.0, js-controller: 5.0.17
                      2023-12-19 08:38:05.082  - info: vw-connect.1 (255691) starting. Version 0.3.6 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.19.0, js-controller: 5.0.17
                      2023-12-19 08:38:05.214  - info: vw-connect.0 (255684) Login in with id
                      2023-12-19 08:38:05.257  - info: vw-connect.1 (255691) Login in with audietron
                      2023-12-19 08:38:08.053  - info: vw-connect.0 (255684) ID login successfull
                      2023-12-19 08:38:08.055  - info: vw-connect.0 (255684) History limit: -1, set to -1 to disable wallcharging login
                      2023-12-19 08:38:08.056  - info: vw-connect.0 (255684) History limit is set to -1, no wall charging login
                      2023-12-19 08:38:08.059  - info: vw-connect.0 (255684) Login successful
                      2023-12-19 08:38:08.319  - info: vw-connect.1 (255691) Login successful
                      2023-12-19 08:38:10.704  - info: vw-connect.0 (255684) Found 1 vehicles
                      2023-12-19 08:38:10.714  - info: vw-connect.0 (255684) Create vehicle WVWZZZxxxxxxxxxxxxxxxxxxx
                      2023-12-19 08:38:18.593  - error: vw-connect.1 (255691) [{"message":"network timeout at: ","locations":[{"line":2,"column":3}],"path":["userVehicles"],"extensions":{"code":"INTERNAL_SERVER_ERROR","exception":{"message":"network timeout at: ","type":"request-timeout"}}}]
                      2023-12-19 08:38:18.595  - error: vw-connect.1 (255691) Get Vehicles Failed
                      2023-12-19 08:38:20.573  - info: vw-connect.0 (255684) Server not available:{"error":{"retry":true,"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2}}
                      2023-12-19 08:38:32.048  - info: vw-connect.0 (255684) Server not available:{"error":{"group":2,"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"retry":true}}
                      2023-12-19 08:38:40.378  - info: vw-connect.0 (255684) Server not available:{"error":{"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2,"retry":true}}
                        jwedenig Most Active @Maverick78 last edited by
                        Hi!
                        Ich habe seit 2 Tagen bei meinem ID4 auch keine Aktualisierungen mehr im Adapter und bei EVCC bekomme ich auch keinen Ladestand mehr angezeigt!
                        Das liegt sicher bei VW, oder?
                          Maverick78 @jwedenig last edited by Maverick78
                          @jwedenig Da es bei EVCC einen fix gibt, scheint VAG was geändert zu haben.
                          • nik82
                            nik82 Most Active last edited by
                            Das ist ja komisch, scheint aber nicht bei allen zu sein, weil bei mir funktioniert das noch wunderbar.
                            Cupra Formentor mit Type "Seat Cupra #2 Alternative".
                              BobBruni @BananaJoe last edited by BobBruni
                              @bananajoe said in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                              Verstehe ich richtig, dass du überhaupt keine Probleme hast?
                                @maverick78
                                sorry, kenn mich nicht wirklich gut aus, was muss ich jetzt machen und mit VAG meinst du VW?
                                  Matis @jwedenig last edited by Matis
                                  Bekomme vom ID5 auf keinen Ladestand und keine Ladedauer mehr.
                                  2023-12-19 10:10:14.562 - error: vw-connect.1 (29223) AxiosError: Request failed with status code 404
                                  2023-12-19 10:10:14.581 - error: vw-connect.1 (29223) {"error":{"message":"Not Found","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4112,"group":2,"retry":true}}
                                  2023-12-19 10:10:14.853 - error: vw-connect.1 (29223) AxiosError: Request failed with status code 404
                                  2023-12-19 10:10:14.854 - error: vw-connect.1 (29223) {"error":{"message":"Not Found","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4112,"group":2,"retry":true}}
                                  2023-12-19 10:10:15.108 - error: vw-connect.1 (29223) AxiosError: Request failed with status code 404
                                  2023-12-19 10:10:15.111 - error: vw-connect.1 (29223) {"error":{"info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4112,"group":2,"retry":true,"message":"Not Found"}}
                                  2023-12-19 10:10:15.332 - error: vw-connect.1 (29223) AxiosError: Request failed with status code 404
                                  2023-12-19 10:10:15.333 - error: vw-connect.1 (29223) {"error":{"message":"Not Found","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4112,"group":2,"retry":true}}
                                    juggi1962 @mading last edited by
                                    @mading sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                                    Ich habe das selbe Problem, seit mindestens Gestern keine Aktualisierung mehr.
                                    Der Adapter ist grün und keine Fehler im Log.
                                      Maverick78 @juggi1962 last edited by Maverick78
                                      Habe gerade gesehen das im GitHub v0.4.0 liegt. Damit geht die Aktualisierung des SoC wieder.
                                      Allerdings bekomme ich weiterhin einige Fehler gemeldet:
                                      2023-12-19 15:28:38.455  - info: vw-connect.0 (288986) starting. Version 0.4.0 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.19.0, js-controller: 5.0.17
                                      2023-12-19 15:28:38.530  - info: vw-connect.1 (288992) starting. Version 0.4.0 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.19.0, js-controller: 5.0.17
                                      2023-12-19 15:28:38.637  - info: vw-connect.0 (288986) Login in with id
                                      2023-12-19 15:28:38.702  - info: vw-connect.1 (288992) Login in with audietron
                                      2023-12-19 15:28:41.259  - info: vw-connect.0 (288986) ID login successfull
                                      2023-12-19 15:28:41.262  - info: vw-connect.0 (288986) History limit: -1, set to -1 to disable wallcharging login
                                      2023-12-19 15:28:41.263  - info: vw-connect.0 (288986) History limit is set to -1, no wall charging login
                                      2023-12-19 15:28:41.266  - info: vw-connect.0 (288986) Login successful
                                      2023-12-19 15:28:41.764  - info: vw-connect.1 (288992) Login successful
                                      2023-12-19 15:28:42.350  - info: vw-connect.0 (288986) Found 1 vehicles
                                      2023-12-19 15:28:42.360  - info: vw-connect.0 (288986) Create vehicle WVWZZZxxxxxxxxxxxx
                                      2023-12-19 15:28:43.571  - info: vw-connect.1 (288992) Found 1 vehicles
                                      2023-12-19 15:28:47.113  - info: vw-connect.0 (288986) Server not available:{"error":{"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2,"retry":true}}
                                      2023-12-19 15:28:47.357  - info: vw-connect.0 (288986) Server not available:{"error":{"code":4105,"group":2,"retry":true,"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support."}}
                                      2023-12-19 15:28:47.686  - info: vw-connect.0 (288986) Server not available:{"error":{"info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2,"retry":true,"message":"Bad Gateway"}}
                                      2023-12-19 15:28:48.226  - info: vw-connect.1 (288992) Server not available:{"error":{"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2,"retry":true}}
                                      2023-12-19 15:28:48.655  - info: vw-connect.1 (288992) Server not available:{"error":{"message":"Bad Gateway","info":"Upstream service responded with an unexpected status. If the problem persists, please contact our support.","code":4105,"group":2,"retry":true}}
                                      2023-12-19 15:28:48.860  - info: vw-connect.1 (288992) Server not available:{"error":{"message":"Bad Gateway","info":"Looks like your service has expired. Please update your service subscription.","code":4104,"group":4,"retry":false}}
                                        Sneak-L8 @Maverick78 last edited by
                                        @maverick78 Ja, mit der github-Version bekomem ich auch wieder Daten.
                                        Nachdem ich wie im Log empfohlen die Trip-Daten deativiert habe, kommen (fast) keine Fehler mehr. Nur dieser:
                                        @tombox Es wird gemeldet, dass mit der aktuellen Version kein compact mode mehr geht:
                                        host.raspberrypi.compactgroup2
                                        	2023-12-19 16:15:43.447	info	instance system.adapter.vw-connect.0 started with pid 8369
                                        	2023-12-19 16:15:43.386	error	undefined
                                        	2023-12-19 16:15:43.386	error	Cannot start vw-connect.0 in compact mode. Fallback to normal start: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vw-connect/node_modules/axios/index.js'
                                          jwedenig Most Active last edited by
                                          Version 0.4.0 funkt wieder
                                            Maverick78 @Sneak-L8 last edited by
                                            @sneak-l8 Danke, nach dem abschalten der Trip Daten ist die Fehlermeldung weg
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            399
                                            3091
                                            1605922
