    3. Einsteigerfragen
    4. System updaten raspberry + iobroker + node
      TheAriba @Guest last edited by
      @ilovegym gute Sache. Wie kann ich mir das denn auf einen stick sichern?
        TheAriba @Thomas Braun last edited by
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.4.72-v7l+
              Architecture: arm
        Model		: Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
         10:45:37 up 419 days, 17:11,  1 user,  load average: 0.40, 0.70, 0.50
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Mon 2023-12-18 10:45:37 GMT
                   Universal time: Mon 2023-12-18 10:45:37 UTC
                         RTC time: n/a
                        Time zone: Europe/London (GMT, +0000)
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:           7.9G        850M        5.8G        400M        1.2G        6.6G
        Swap:           99M          0B         99M
        Total:         8.0G        850M        5.9G
                 7875 M total memory
                  850 M used memory
                 1117 M active memory
                  829 M inactive memory
                 5779 M free memory
                  144 M buffer memory
                 1101 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4       59G  3.9G   53G   7% /
        devtmpfs       devtmpfs  3.8G     0  3.8G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     3.9G  401M  3.5G  11% /run
        tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   55M  198M  22% /boot
        tmpfs          tmpfs     788M     0  788M   0% /run/user/1000
        [Mon Oct 24 18:34:35 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1  smsc95xx.macaddr=DC:A6:32:D5:EF:A1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=39b6b4e5-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
        [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
        [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
        [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): 5 orphan inodes deleted
        [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): recovery complete
        [Mon Oct 24 18:34:36 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Mon Oct 24 18:34:36 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Mon Oct 24 18:34:38 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        TARGET        SOURCE         FSTYPE OPTIONS
        /             /dev/mmcblk0p2 ext4   rw,noatime
        |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        416M	/var/
        217M	/var/cache
        212M	/var/cache/apt
        153M	/var/cache/apt/archives
        96M	/var/lib
        Archived and active journals take up 400.0M in the file system.
        /opt/iobroker/backups:
        20M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        215M	/opt/iobroker/iobroker-data/
        106M	/opt/iobroker/iobroker-data/files
        79M	/opt/iobroker/iobroker-data/backup-objects
        48M	/opt/iobroker/iobroker-data/files/javascript.admin
        32M	/opt/iobroker/iobroker-data/files/javascript.admin/static
        12M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
        8.3M	/opt/iobroker/iobroker-data/objects.jsonl
        6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        6.2M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
        6.1M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/2.e9a02d96.chunk.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-EnOcean_GmbH_EnOcean_USB_300_DC_FT41KIFB-if00-port0
        /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v12.22.2
        /usr/bin/node 		v12.22.2
        /usr/bin/npm 		6.14.13
        /usr/bin/npx 		6.14.13
        /home/iobroker/.diag.sh: line 281: corepack: command not found
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: 12.22.2-1nodesource1
          Candidate: 12.22.12-deb-1nodesource1
          Version table:
             12.22.12-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
         *** 12.22.2-1nodesource1 100
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u1 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	4.0.23
        admin: 		6.2.22
        javascript: 	6.0.3
        Adapters from github: 	3
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
          system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          system.adapter.doorbird.0               : doorbird              : raspberrypi                              -  enabled
        + system.adapter.enocean.0                : enocean               : raspberrypi                              -  enabled
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 192.168.0.122
          system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
        + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
        + system.adapter.yahka.1                  : yahka                 : raspberrypi                              -  enabled
        + system.adapter.yahka.2                  : yahka                 : raspberrypi                              -  enabled
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.2.22 [Updatable]
        Adapter    "alexa2"       : 3.26.3   , installed 3.23.2 [Updatable]
        Adapter    "cloud"        : 4.4.1    , installed 4.2.2  [Updatable]
        Adapter    "discovery"    : 4.2.0    , installed 3.0.5  [Updatable]
        Adapter    "doorbird"     : 1.3.0    , installed 0.1.5  [Updatable]
        Adapter    "info"         : 2.0.0    , installed 1.9.19 [Updatable]
        Adapter    "iot"          : 2.0.11   , installed 1.11.9 [Updatable]
        Adapter    "javascript"   : 7.1.6    , installed 6.0.3  [Updatable]
        Controller "js-controller": 5.0.17   , installed 4.0.23 [Updatable]
        Adapter    "sayit"        : 3.0.5    , installed 1.12.3 [Updatable]
        Adapter    "shelly"       : 6.6.1    , installed 4.0.7  [Updatable]
        Adapter    "simple-api"   : 2.7.2    , installed 2.7.0  [Updatable]
        Adapter    "socketio"     : 6.6.0    , installed 4.2.0  [Updatable]
        Adapter    "sonos"        : 3.0.0    , installed 2.2.3  [Updatable]
        Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
        Adapter    "terminal"     : 1.0.0    , installed 0.2.6  [Updatable]
        Adapter    "web"          : 6.1.10   , installed 4.3.0  [Updatable]
        Adapter    "ws"           : 2.5.8    , installed 1.3.0  [Updatable]
        Adapter    "yahka"        : 1.0.3    , installed 0.13.1 [Updatable]
        Adapter    "zigbee"       : 1.8.24   , installed 1.8.10 [Updatable]
        Objects and States
        Objects: 	5746
        States: 	4775
        E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldoldstable'
        E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldoldstable'
        Pending Updates: 132
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:38307         0.0.0.0:*               LISTEN      1001       131216559  14146/io.yahka.0
        tcp        0      0 127.0.0.1:41925         0.0.0.0:*               LISTEN      1001       131216564  14146/io.yahka.0
        tcp        0      0 127.0.0.1:33989         0.0.0.0:*               LISTEN      1001       131216547  14146/io.yahka.0
        tcp        0      0 127.0.0.1:41703         0.0.0.0:*               LISTEN      1001       131217334  14807/io.yahka.1
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       131213641  13946/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       131213634  13946/iobroker.js-c
        tcp        0      0 127.0.0.1:45291         0.0.0.0:*               LISTEN      1001       131219694  14146/io.yahka.0
        tcp        0      0 127.0.0.1:43851         0.0.0.0:*               LISTEN      1001       131217891  14807/io.yahka.1
        tcp        0      0 127.0.0.1:43631         0.0.0.0:*               LISTEN      1001       131216552  14146/io.yahka.0
        tcp        0      0 127.0.0.1:34769         0.0.0.0:*               LISTEN      1001       131218669  14840/io.yahka.2
        tcp        0      0 127.0.0.1:38131         0.0.0.0:*               LISTEN      1001       131220567  14840/io.yahka.2
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16813      572/sshd
        tcp        0      0 127.0.0.1:33561         0.0.0.0:*               LISTEN      1001       131218665  14840/io.yahka.2
        tcp        0      0 127.0.0.1:42905         0.0.0.0:*               LISTEN      1001       131216015  14807/io.yahka.1
        tcp        0      0 127.0.0.1:37211         0.0.0.0:*               LISTEN      1001       131219699  14146/io.yahka.0
        tcp6       0      0 :::38783                :::*                    LISTEN      1001       131216908  14807/io.yahka.1
        tcp6       0      0 :::42977                :::*                    LISTEN      1001       131214296  14146/io.yahka.0
        tcp6       0      0 :::34243                :::*                    LISTEN      1001       131217947  14840/io.yahka.2
        tcp6       0      0 :::36049                :::*                    LISTEN      1001       131214295  14146/io.yahka.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       131213697  13964/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       131215920  14730/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          16815      572/sshd
        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       131217864  14781/io.terminal.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       131218481  14650/io.shelly.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14315      564/dhcpcd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       131217948  14840/io.yahka.2
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       131216909  14807/io.yahka.1
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       131214300  14146/io.yahka.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       131214297  14146/io.yahka.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15108      382/avahi-daemon: r
        udp        0      0 0.0.0.0:43289           0.0.0.0:*                           108        15110      382/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          31124735   564/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        15109      382/avahi-daemon: r
        udp6       0      0 :::42292                :::*                                108        15111      382/avahi-daemon: r
        2023-12-18 10:40:51.439  - info: host.raspberrypi Restart adapter system.adapter.doorbird.0 because enabled
        2023-12-18 10:41:17.821  - info: alexa2.0 (14089) Unknown Device, but enabling commands, Try it and report back if commands work.
        2023-12-18 10:41:17.821  - info: alexa2.0 (14089) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
        2023-12-18 10:41:17.822  - info: alexa2.0 (14089)     Device-type:A2RG3FY1YV97SS - Sascha's Sonos Move (Sonos Move) (HANDS_FREE,SET_LOCALE,DEEZER,DIALOG_INTERFACE_VERSION,SLEEP,VOLUME_SETTING,TIDAL,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,SOUND_SETTINGS,SUPPORTS_LOCALE,MULTI_WAKEWORDS_SUPPORTED,CUSTOM_ALARM_TONE,SIRIUSXM,I_HEART_RADIO,ADAPTIVE_LISTENING,GOLDFISH,CHANGE_NAME,MICROPHONE,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,SPEECH_RECOGNIZER_USS,APPLE_MUSIC,FAR_FIELD,AUDIO_PLAYER,EARCONS,SUPPORTS_LOCALE_SWITCH,SET_TIME_ZONE,REMINDERS,DREAM_TRAINING,MUSIC_SKILL,AMAZON_MUSIC,DEREGISTER_DEVICE,KINDLE_BOOKS,AUDIBLE,PERSISTENT_CONNECTION,TUNE_IN,ASCENDING_ALARM_VOLUME,TIMERS_AND_ALARMS)
        2023-12-18 10:41:21.475  - info: host.raspberrypi instance system.adapter.doorbird.0 started with pid 15127
        2023-12-18 10:41:24.179  - info: doorbird.0 (15127) starting. Version 0.1.5 (non-npm: https://github.com/BuZZy1337/ioBroker.doorbird/tarball/47440ddff9a9074ef1e0beb8ff7b7f2a6e368efb) in /opt/iobroker/node_modules/iobroker.doorbird, node: v12.22.2, js-controller: 4.0.23
        2023-12-18 10:41:24.275  - error: doorbird.0 (15127) uncaught exception: listen EADDRNOTAVAIL: address not available 192.168.0.122:8100
        2023-12-18 10:41:24.277  - error: doorbird.0 (15127) Error: listen EADDRNOTAVAIL: address not available 192.168.0.122:8100
            at Server.setupListenHandle [as _listen2] (net.js:1299:21)
            at listenInCluster (net.js:1364:12)
            at doListen (net.js:1501:7)
            at processTicksAndRejections (internal/process/task_queues.js:85:21)
        2023-12-18 10:41:24.278  - error: doorbird.0 (15127) Exception-Code: EADDRNOTAVAIL: listen EADDRNOTAVAIL: address not available 192.168.0.122:8100
        2023-12-18 10:41:24.299  - info: doorbird.0 (15127) terminating
        2023-12-18 10:41:24.300  - warn: doorbird.0 (15127) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-12-18 10:41:24.899  - error: host.raspberrypi instance system.adapter.doorbird.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2023-12-18 10:41:24.900  - info: host.raspberrypi Restart adapter system.adapter.doorbird.0 because enabled
        2023-12-18 10:41:24.900  - warn: host.raspberrypi Do not restart adapter system.adapter.doorbird.0 because restart loop detected
        2023-12-18 10:41:32.861  - info: alexa2.0 (14089) No smart home devices to query
        2023-12-18 10:41:36.052  - info: alexa2.0 (14089) Subscribing to states...
        2023-12-18 10:41:36.056  - info: alexa2.0 (14089) Deleting the following states: ["Smart-Home-Devices.0a811299-fb7f-4ea9-b76c-42ce750e89b6.lowerSetpoint","Smart-Home-Devices.0a811299-fb7f-4ea9-b76c-42ce750e89b6.lowerSetpoint-scale","Smart-Home-Devices.0a811299-fb7f-4ea9-b76c-42ce750e89b6.upperSetpoint","Smart-Home-Devices.0a811299-fb7f-4ea9-b76c-42ce750e89b6.upperSetpoint-scale","Smart-Home-Devices.9182c302-7eb1-4d03-a40b-a0f305a5dea7.lowerSetpoint","Smart-Home-Devices.9182c302-7eb1-4d03-a40b-a0f305a5dea7.lowerSetpoint-scale","Smart-Home-Devices.9182c302-7eb1-4d03-a40b-a0f305a5dea7.upperSetpoint","Smart-Home-Devices.9182c302-7eb1-4d03-a40b-a0f305a5dea7.upperSetpoint-scale","Smart-Home-Devices.715097f8-0444-409a-ba9b-97c872c95c91.lowerSetpoint","Smart-Home-Devices.715097f8-0444-409a-ba9b-97c872c95c91.lowerSetpoint-scale","Smart-Home-Devices.715097f8-0444-409a-ba9b-97c872c95c91.upperSetpoint","Smart-Home-Devices.715097f8-0444-409a-ba9b-97c872c95c91.upperSetpoint-scale","Smart-Home-Devices.770c27df-9728-4765-b41e-011704586681.lowerSetpoint","Smart-Home-Devices.770c27df-9728-4765-b41e-011704586681.lowerSetpoint-scale","Smart-Home-Devices.770c27df-9728-4765-b41e-011704586681.upperSetpoint","Smart-Home-Devices.770c27df-9728-4765-b41e-011704586681.upperSetpoint-scale"]
        2023-12-18 10:41:37.858  - info: alexa2.0 (14089) Alexa-Push-Connection (macDms = true) established. Disable Polling
        2023-12-18 10:41:52.977  - info: alexa2.0 (14089) Initialization Done ...
        2023-12-18 10:45:27.558  - info: enocean.0 (14745) state 0584df18.CMD changed: 1 (ack = false) state: {"val":1,"ack":false,"ts":1702896327553,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1702896327553}
        2023-12-18 10:45:28.908  - info: enocean.0 (14745) state 0584df18.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1702896328901,"q":0,"from":"system.adapter.yahka.0","user":"system.user.admin","lc":1702896328901}
          Thomas Braun Most Active @TheAriba last edited by
          @theariba
          Zeitzone falsch.
          sudo timedatectl set-timezone "Europe/Berlin"
          Dein Dateisystem hat einen Treffer:
          Die Pending Updates: 132 zuerst einspielen:
          sudo apt update
          iob stop
          sudo apt full-upgrade
          iob nodejs-update
          sudo reboot
          Wenn der Server wieder auf die Beine gekommen ist:
          iob update
          iob upgrade all -y
          iob stop
          iob upgrade self
          iob start
          Dann davon ein Backup extern ablegen und das ganze System NEU als Raspberry OS 64Bit Lite installieren. Dort das Backup wieder einspielen, fertig.
            für mich als Noob:
            1. Zeitzone korrigieren
            1. diese Befehle ausführen:
            sudo apt update
            iob stop
            iob nodejs-update
            sudo reboot
            iob update
            iob upgrade all -y
            iob stop
            iob upgrade self
            iob start
            Wie ich dann ein Backup extern ablegen kann muss ich dann noch recherchieren.
            Dann mache ich quasi den pi platt und setze es mit raspberry 64 OS bit Lite neu auf und spiele dann das backup ein?
              @theariba sagte in System updaten raspberry + iobroker + node:
              Ja, das ist der Plan.
                Ok. Werde nachher mal die Befehle so durchführen.
                Kannst du mir evtl. Sagen wie ich das mit dem Backup auf usb Stick oder so hinbekomme?
                Und wie macht man den Pi platt und setzt ihn neu auf?
                  Ich würde es per Backitup-Adapter machen.
                  https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                  T 1 Reply Last reply Reply Quote 2
                    @thomas-braun so, habe die erste Runde der Befehle mal ausgeführt. Nun Backitup Adapter installiert und versuche ein Backup auf Google Drive zu erstellen. Finde leider keinen USB Stick gerade...
                    wie kann ich sehen ob es erfolgreich war bzw. ob alles dabei ist? Am wichtigsiten ist mir mein Enocean Adapter...
                      @theariba
                      Im Backup sind die Adapter und deren Einstellungen enthalten.
                        @thomas-braun ok danke. Habe irgendwie Bedenken dass ich mir das zerschiesse. Warum genau empfiehlt es sich denn das Raspberry OS zu aktualisieren?
                          Weil deine Version 10 'Buster' abgekündigt wurde, das EndOfLife erreicht hat und weil du da seinerzeit eine 32Bit-Version installiert hast, mittlerweile aber die 64Bit-Variante die besser für einen Raspberry Pi geeignete ist.
                          Und ganz allgemein, weil man seinen Softwarestack immer auf Stand hält.
                            @thomas-braun ok alles klar. Dann mache ich mich da heute Abend mal dran. Kurz zum Verständnis der Vorgehensweise:
                            • Über den Backitup auf einen beliebigen USB Stick das Backup ablegen.
                              Dafür gebe ich im Backitup Adapter unter NAS/Kopieren den Pfad /media/usbstick/backupDir an. Muss ich hier sonst noch etwas beachten?
                            • Dann formatiere ich die SD Karte, und setze dann das neue OS so auf wie in deiner Beschreibung
                            • Wie spielt man dann das Backup wieder auf?
                              Die Geräte muss ich sicher nicht mehr neu einlernen?
                            Sorry aber ich habe ein wenig Schiss 🙂
                            • OliverIO
                              OliverIO last edited by
                              @theariba
                              ich würde lieber eine neue SD-Karte nehmen. dann hast du a) die alte zur Sicherheit noch zur Hand und b) das Risiko, das die SD-Karte bereits einen Hau hat (wegen den verwaisten inodes) ist weg.
                                TheAriba @OliverIO last edited by
                                @oliverio ok verstehe. Bedeutet das sobald ich die alte Karte einstecke habe ich den aktuellen Stand wieder und das funktioniert alles wie gehabt? Habe ich das mit dem Backup soweit richtig verstanden? Wie füge ich das dann wieder auf im neuen System ein? Muss ich dazu einen neuen iobroker aufsetzen oder geht das über Befehle? bspw. hole dir die Datei vom USB Stick?
                                • OliverIO
                                  OliverIO @TheAriba last edited by
                                  ja, das ist wie die Festplatte wechseln. Wenn die alte wieder einbaust, dann gehts genau mit dem letzten stand weiter. der raspi ist nur hardware und hat kein weiteres "Gedächtnis".
                                  Dann kannst du zur Not immer mal noch nachschauen
                                  3940
