    4. [Gelöst] Update js-controller geht nicht
      Stephan1966 @Thomas Braun last edited by
      Habe ich doch vor 3 Minuten gemacht!
        Thomas Braun Most Active @Stephan1966 last edited by
        @stephan1966
        Du hast das falsch geschrieben und eine entsprechende Rückmeldung erhalten, aber kein upgrade durchgeführt.
          Wer lesen kann ist klar im Vorteil 👍
            Skript v.2023-10-10
            *** BASE SYSTEM ***
               Static hostname: raspberrypismarthome
                     Icon name: computer
              Operating System: Raspbian GNU/Linux 11 (bullseye)
                        Kernel: Linux 6.1.21-v8+
                  Architecture: arm64
            Model           : Raspberry Pi 4 Model B Rev 1.2
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : armhf
            Systemuptime and Load:
             14:07:31 up  2:48,  1 user,  load average: 1.44, 0.89, 0.48
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
                           Local time: Mon 2023-12-18 14:07:32 CET
                       Universal time: Mon 2023-12-18 13:07:32 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            3.8G        606M        1.3G        1.0M        1.9G        3.1G
            Swap:            99M          0B         99M
            Total:          3.9G        606M        1.4G
                     3794 M total memory
                      606 M used memory
                      688 M active memory
                     1517 M inactive memory
                     1321 M free memory
                      207 M buffer memory
                     1658 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FAILED SERVICES ***
              UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
            * deconz-init.service   loaded failed failed deCONZ: ZigBee gateway -- Initialisation
            * deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
            * deconz-wifi.service   loaded failed failed deCONZ: ZigBee gateway -- WIFI Service
            LOAD   = Reflects whether the unit definition was properly loaded.
            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
            SUB    = The low-level unit activation state, values depend on unit type.
            3 loaded units listed.
            *** FILESYSTEM ***
            /dev/root      ext4       29G  6.1G   22G  22% /
            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     759M  1.8M  758M   1% /run
            /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
            tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
            [Mon Dec 18 11:19:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Mon Dec 18 11:19:30 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Mon Dec 18 11:19:30 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Mon Dec 18 11:19:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
            /var:
            1.9G    /var/
            1.1G    /var/log/journal/2db8461036a4455ab0afd36ad1c9f367
            1.1G    /var/log
            658M    /var/cache
            Archived and active journals take up 1.0G in the file system.
            /opt/iobroker/backups:
            393M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            313M    /opt/iobroker/iobroker-data/
            180M    /opt/iobroker/iobroker-data/files
            105M    /opt/iobroker/iobroker-data/backup-objects
            67M     /opt/iobroker/iobroker-data/files/javascript.admin
            48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
            33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
            9.7M    /opt/iobroker/iobroker-data/objects.jsonl
            8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
            8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
            USB-Devices by-id:
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.19.0
            /usr/bin/node           v18.19.0
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            /usr/bin/corepack       0.22.0
            nodejs:
              Installed: 18.19.0-1nodesource1
              Candidate: 18.19.0-1nodesource1
              Version table:
             *** 18.19.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                    100 /var/lib/dpkg/status
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
                 12.22.12~dfsg-1~deb11u4 500
                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.17
            admin:          6.12.0
            javascript:     7.1.6
            Adapters from github:   0
            Adapter State
            + system.adapter.admin.0                  : admin                 : raspberrypismarthome                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
            + system.adapter.backitup.0               : backitup              : raspberrypismarthome                     -  enabled
            + system.adapter.deconz.1                 : deconz                : raspberrypismarthome                     -  enabled, port: 80
            + system.adapter.discovery.0              : discovery             : raspberrypismarthome                     -  enabled
            + system.adapter.fritzdect.0              : fritzdect             : raspberrypismarthome                     -  enabled
            + system.adapter.info.0                   : info                  : raspberrypismarthome                     -  enabled
            + system.adapter.iot.0                    : iot                   : raspberrypismarthome                     -  enabled
            + system.adapter.javascript.0             : javascript            : raspberrypismarthome                     -  enabled
            + system.adapter.net-tools.0              : net-tools             : raspberrypismarthome                     -  enabled
            + system.adapter.ping.0                   : ping                  : raspberrypismarthome                     -  enabled
            + system.adapter.pushover.0               : pushover              : raspberrypismarthome                     -  enabled
            + system.adapter.tr-064.0                 : tr-064                : raspberrypismarthome                     -  enabled
              system.adapter.vis.0                    : vis                   : raspberrypismarthome                     -  enabled
            + system.adapter.web.0                    : web                   : raspberrypismarthome                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.12.0   , installed 6.12.0
            Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
            Adapter    "backitup"     : 2.8.7    , installed 2.8.7
            Adapter    "deconz"       : 1.3.23   , installed 1.3.23
            Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
            Adapter    "iot"          : 2.0.11   , installed 2.0.11
            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
            Controller "js-controller": 5.0.17   , installed 5.0.17
            Adapter    "pushover"     : 3.0.3    , installed 3.0.3
            Adapter    "web"          : 6.1.10   , installed 6.1.10
            Adapter    "ws"           : 2.5.8    , installed 2.5.8
            Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
            Objects and States
            Objects:        2050
            States:         1756
            Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       87946      15594/iobroker.js-c
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       87939      15594/iobroker.js-c
            tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          15069      831/smbd
            tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       11194      400/deCONZ
            tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          15070      831/smbd
            tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12931      400/deCONZ
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14170      535/sshd: /usr/sbin
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       90447      15612/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       90049      15972/io.web.0
            tcp6       0      0 :::445                  :::*                    LISTEN      0          15067      831/smbd
            tcp6       0      0 :::139                  :::*                    LISTEN      0          15068      831/smbd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          14172      535/sshd: /usr/sbin
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14033      392/avahi-daemon: r
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       91665      16022/io.deconz.1
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       14805      400/deCONZ
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14249      747/dhcpcd
            udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          16432      751/nmbd
            udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          16431      751/nmbd
            udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          16415      751/nmbd
            udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          16434      751/nmbd
            udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          16433      751/nmbd
            udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          16416      751/nmbd
            udp        0      0 0.0.0.0:45598           0.0.0.0:*                           108        14035      392/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        14034      392/avahi-daemon: r
            udp6       0      0 :::1900                 :::*                                1001       91667      16022/io.deconz.1
            udp6       0      0 :::1900                 :::*                                1001       91666      16022/io.deconz.1
            udp6       0      0 :::34833                :::*                                108        14036      392/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          14262      747/dhcpcd
            2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) no response part in returned error message
            2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
            2023-12-18 14:07:42.364  - error: fritzdect.0 (15942) login not possible, check user and permissions
            2023-12-18 14:07:43.505  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 15972
            2023-12-18 14:07:47.252  - info: web.0 (15972) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
            2023-12-18 14:07:47.570  - info: web.0 (15972) socket.io server listening on port 8082
            2023-12-18 14:07:47.582  - info: web.0 (15972) http server listening on port 8082
            2023-12-18 14:07:50.378  - info: vis.0 (15997) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
            2023-12-18 14:07:51.083  - info: vis.0 (15997) Terminated (NO_ERROR): Without reason
            2023-12-18 14:07:51.489  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 16022
            2023-12-18 14:07:51.682  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
            2023-12-18 14:07:54.669  - info: deconz.1 (16022) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
            2023-12-18 14:07:54.881  - info: deconz.1 (16022) deConz Version: 2.24.2; API version: 1.16.0
            2023-12-18 14:07:55.488  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 16046
            2023-12-18 14:07:59.511  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 16090
            2023-12-18 14:08:01.351  - info: info.0 (16046) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
            2023-12-18 14:08:01.666  - info: info.0 (16046) Reading/updating systemdata.
            2023-12-18 14:08:04.164  - info: info.0 (16046) cpu Temp res = {"main":47.225,"cores":[],"max":47.225,"socket":[],"chipset":null}
            2023-12-18 14:08:05.265  - info: iot.0 (16090) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
            2023-12-18 14:08:05.531  - info: iot.0 (16090) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
            2023-12-18 14:08:06.392  - info: iot.0 (16090) Connection changed: connect "s_glebe66_googlemail_com"
            2023-12-18 14:08:06.642  - info: alexa2.0 (15845) Subscribing to states...
            2023-12-18 14:08:06.650  - info: alexa2.0 (15845) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
            2023-12-18 14:08:08.370  - info: alexa2.0 (15845) Alexa-Push-Connection (macDms = true) established. Disable Polling
            2023-12-18 14:08:15.917  - info: alexa2.0 (15845) Initialization Done ...
            iob diag has finished.
              @stephan1966
              Hast du das boot target gesetzt?
              sudo systemctl set-default multi-user.target
              sudo reboot
              Was ist denn nun mit deconz los?
                @thomas-braun sagte in Update js-controller geht nicht:
                sudo reboot
                Muss ich diese beiden Befehle eingeben?
                ioBroker vorher anhalten?
                  @stephan1966 sagte in Update js-controller geht nicht:
                  Ja / Nein.
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : armhf
                     14:25:37 up 1 min,  1 user,  load average: 1.42, 0.45, 0.16
                    CPU threads: 4
                    Current issues:
                                   Local time: Mon 2023-12-18 14:25:37 CET
                               Universal time: Mon 2023-12-18 13:25:37 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    Boot Target:    multi-user.target
                    *** MEMORY ***
                    Mem:            3.8G        698M        2.8G        1.0M        293M        3.0G
                    Swap:            99M          0B         99M
                    Total:          3.9G        698M        2.9G
                             3794 M total memory
                              698 M used memory
                              767 M active memory
                              119 M inactive memory
                             2802 M free memory
                               40 M buffer memory
                              252 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    [Mon Dec 18 14:24:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Mon Dec 18 14:24:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Mon Dec 18 14:24:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Mon Dec 18 14:24:27 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    /var:
                    1.9G    /var/
                    1.1G    /var/log
                    658M    /var/cache
                    315M    /opt/iobroker/iobroker-data/
                    11M     /opt/iobroker/iobroker-data/objects.jsonl
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        2065
                    States:         1769
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       13818      399/deCONZ
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13783      523/sshd: /usr/sbin
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12213      504/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14838      504/iobroker.js-con
                    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14054      753/smbd
                    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       12175      399/deCONZ
                    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14053      753/smbd
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15694      676/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17553      1023/io.web.0
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          13785      523/sshd: /usr/sbin
                    tcp6       0      0 :::139                  :::*                    LISTEN      0          14052      753/smbd
                    tcp6       0      0 :::445                  :::*                    LISTEN      0          14051      753/smbd
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2041       393/avahi-daemon: r
                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17621      1083/io.deconz.1
                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15442      399/deCONZ
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13837      747/dhcpcd
                    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          13983      748/nmbd
                    udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          13982      748/nmbd
                    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          13966      748/nmbd
                    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          13985      748/nmbd
                    udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          13984      748/nmbd
                    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          13967      748/nmbd
                    udp        0      0 0.0.0.0:51768           0.0.0.0:*                           108        2043       393/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                108        2042       393/avahi-daemon: r
                    udp6       0      0 :::48542                :::*                                108        2044       393/avahi-daemon: r
                    udp6       0      0 :::1900                 :::*                                1001       17623      1083/io.deconz.1
                    udp6       0      0 :::1900                 :::*                                1001       17622      1083/io.deconz.1
                    udp6       0      0 :::546                  :::*                                0          13850      747/dhcpcd
                    2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) no response part in returned error message
                    2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                    2023-12-18 14:25:19.594  - error: fritzdect.0 (1008) login not possible, check user and permissions
                    2023-12-18 14:25:20.809  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1023
                    2023-12-18 14:25:24.559  - info: web.0 (1023) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                    2023-12-18 14:25:25.051  - info: web.0 (1023) socket.io server listening on port 8082
                    2023-12-18 14:25:25.059  - info: web.0 (1023) http server listening on port 8082
                    2023-12-18 14:25:27.639  - info: vis.0 (1059) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                    2023-12-18 14:25:28.699  - info: vis.0 (1059) Terminated (NO_ERROR): Without reason
                    2023-12-18 14:25:28.750  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1083
                    2023-12-18 14:25:29.290  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                    2023-12-18 14:25:31.643  - info: alexa2.0 (939) Subscribing to states...
                    2023-12-18 14:25:31.653  - info: alexa2.0 (939) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                    2023-12-18 14:25:31.867  - info: deconz.1 (1083) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                    2023-12-18 14:25:32.013  - info: deconz.1 (1083) deConz Version: 2.24.2; API version: 1.16.0
                    2023-12-18 14:25:32.791  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1107
                    2023-12-18 14:25:33.549  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                    2023-12-18 14:25:36.750  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1133
                    2023-12-18 14:25:38.276  - info: info.0 (1107) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                    2023-12-18 14:25:38.565  - info: info.0 (1107) Reading/updating systemdata.
                    2023-12-18 14:25:40.091  - info: info.0 (1107) cpu Temp res = {"main":46.738,"cores":[],"max":46.738,"socket":[],"chipset":null}
                    2023-12-18 14:25:40.203  - info: alexa2.0 (939) Initialization Done ...
                    2023-12-18 14:25:41.632  - info: iot.0 (1133) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                    2023-12-18 14:25:41.783  - info: iot.0 (1133) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                    2023-12-18 14:25:42.623  - info: iot.0 (1133) Connection changed: connect "s_glebe66_googlemail_com"
                      Ja / Nein.
                      ist erledigt
                        Was ist denn mit dem 'deconz' los?
                        Nachfolgend der aktuelle Stand, ich glaube es ist noch nicht OK oder?
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : armhf
                         12:52:33 up 22:28,  1 user,  load average: 0.15, 0.03, 0.01
                        CPU threads: 4
                        Current issues:
                                       Local time: Tue 2023-12-19 12:52:33 CET
                                   Universal time: Tue 2023-12-19 11:52:33 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            3.8G        816M        2.4G        1.0M        588M        2.9G
                        Swap:            99M          0B         99M
                        Total:          3.9G        816M        2.5G
                                 3794 M total memory
                                  816 M used memory
                                  895 M active memory
                                  367 M inactive memory
                                 2389 M free memory
                                   89 M buffer memory
                                  499 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /dev/root      ext4       29G  6.2G   22G  23% /
                        /var:
                        1.9G    /var/
                        1.1G    /var/log
                        658M    /var/cache
                        396M    /opt/iobroker/backups/
                        329M    /opt/iobroker/iobroker-data/
                        24M     /opt/iobroker/iobroker-data/objects.jsonl
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.6
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        2065
                        States:         1761
                        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Pending Updates: 0
                        2023-12-19 00:22:45.291  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                        2023-12-19 02:00:19.204  - error: backitup.0 (974) [iobroker/ftp] Error: Access to home directory not allowed.
                        2023-12-19 02:00:19.217  - error: backitup.0 (974) [iobroker] Error: Access to home directory not allowed.
                        2023-12-19 02:24:51.981  - info: admin.0 (676) Request actual repository...
                        2023-12-19 02:24:52.654  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                        2023-12-19 02:24:58.132  - info: admin.0 (676) Repository received successfully.
                        2023-12-19 02:25:47.031  - info: info.0 (1107) Reading/updating systemdata.
                        2023-12-19 02:25:47.675  - info: info.0 (1107) cpu Temp res = {"main":41.868,"cores":[],"max":41.868,"socket":[],"chipset":null}
                        2023-12-19 03:18:22.246  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                        2023-12-19 03:18:23.687  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                        2023-12-19 05:56:01.651  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                        2023-12-19 05:56:03.105  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                        2023-12-19 08:44:32.929  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                        2023-12-19 08:44:56.919  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                        2023-12-19 08:44:59.590  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                        2023-12-19 08:46:40.957  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                        2023-12-19 08:59:55.063  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                        2023-12-19 08:59:56.533  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                        2023-12-19 10:14:57.017  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                        2023-12-19 10:14:59.037  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                        2023-12-19 10:15:37.424  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                        2023-12-19 10:21:47.849  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                        2023-12-19 10:22:19.303  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                        2023-12-19 12:41:01.489  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                        2023-12-19 12:41:02.953  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                          Versuch mal, den deconz neuzuinstallieren.
                          sudo apt install --reinstall deconz
                              @stephan1966
                              Sollte egal sein. Vielleicht den deconz-Adapter danach mal neustarten.
                                Hier das Ergebnis, sieht soweit ich das beurteilen kann noch genauso aus!
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : armhf
                                 14:56:47 up 2 min,  1 user,  load average: 1.21, 0.66, 0.26
                                CPU threads: 4
                                Current issues:
                                               Local time: Tue 2023-12-19 14:56:47 CET
                                           Universal time: Tue 2023-12-19 13:56:47 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            3.8G        651M        2.8G        1.0M        302M        3.1G
                                Swap:            99M          0B         99M
                                Total:          3.9G        651M        2.9G
                                         3794 M total memory
                                          651 M used memory
                                          725 M active memory
                                          118 M inactive memory
                                         2840 M free memory
                                           41 M buffer memory
                                          260 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /dev/root      ext4       29G  6.2G   22G  22% /
                                [Tue Dec 19 14:54:28 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
                                [Tue Dec 19 14:54:29 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Tue Dec 19 14:54:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Tue Dec 19 14:54:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                /var:
                                1.9G    /var/
                                1.1G    /var/log
                                658M    /var/cache
                                310M    /opt/iobroker/iobroker-data/
                                8.6M    /opt/iobroker/iobroker-data/objects.jsonl
                                USB-Devices by-id:
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                nodejs:
                                  Version table:
                                Errors in npm tree:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.12.0
                                javascript:     7.1.6
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        2065
                                States:         1769
                                Pending Updates: 0
                                tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14205      816/smbd
                                tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       13015      400/deCONZ
                                tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14206      816/smbd
                                tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12989      400/deCONZ
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15042      537/sshd: /usr/sbin
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13070      501/iobroker.js-con
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12123      501/iobroker.js-con
                                tcp6       0      0 :::445                  :::*                    LISTEN      0          14203      816/smbd
                                tcp6       0      0 :::139                  :::*                    LISTEN      0          14204      816/smbd
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          15044      537/sshd: /usr/sbin
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13211      662/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17527      1040/io.web.0
                                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       16822      1070/io.deconz.1
                                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15097      400/deCONZ
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12103      749/dhcpcd
                                udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          14181      750/nmbd
                                udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          14180      750/nmbd
                                udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          14164      750/nmbd
                                udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          14183      750/nmbd
                                udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          14182      750/nmbd
                                udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          14165      750/nmbd
                                udp        0      0 0.0.0.0:41316           0.0.0.0:*                           108        14958      394/avahi-daemon: r
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14956      394/avahi-daemon: r
                                udp6       0      0 :::1900                 :::*                                1001       16824      1070/io.deconz.1
                                udp6       0      0 :::1900                 :::*                                1001       16823      1070/io.deconz.1
                                udp6       0      0 :::45045                :::*                                108        14959      394/avahi-daemon: r
                                udp6       0      0 :::546                  :::*                                0          13027      749/dhcpcd
                                udp6       0      0 :::5353                 :::*                                108        14957      394/avahi-daemon: r
                                2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                                2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) login not possible, check user and permissions
                                2023-12-19 14:55:24.974  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1040
                                2023-12-19 14:55:28.042  - info: web.0 (1040) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                                2023-12-19 14:55:28.584  - info: web.0 (1040) socket.io server listening on port 8082
                                2023-12-19 14:55:28.603  - info: web.0 (1040) http server listening on port 8082
                                2023-12-19 14:55:31.435  - info: vis.0 (1055) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                                2023-12-19 14:55:32.211  - info: vis.0 (1055) Terminated (NO_ERROR): Without reason
                                2023-12-19 14:55:32.794  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                                2023-12-19 14:55:32.972  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1070
                                2023-12-19 14:55:35.726  - info: deconz.1 (1070) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                                2023-12-19 14:55:35.883  - info: deconz.1 (1070) deConz Version: 2.24.2; API version: 1.16.0
                                2023-12-19 14:55:36.496  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                2023-12-19 14:55:38.641  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1086
                                2023-12-19 14:55:41.025  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1101
                                2023-12-19 14:55:45.888  - info: info.0 (1086) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                                2023-12-19 14:55:46.253  - info: info.0 (1086) Reading/updating systemdata.
                                2023-12-19 14:55:46.468  - info: iot.0 (1101) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                                2023-12-19 14:55:46.638  - info: iot.0 (1101) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                                2023-12-19 14:55:47.531  - info: iot.0 (1101) Connection changed: connect "s_glebe66_googlemail_com"
                                2023-12-19 14:55:47.731  - info: info.0 (1086) cpu Temp res = {"main":46.251,"cores":[],"max":46.251,"socket":[],"chipset":null}
                                2023-12-19 14:55:49.207  - info: alexa2.0 (987) Subscribing to states...
                                2023-12-19 14:55:49.216  - info: alexa2.0 (987) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                                2023-12-19 14:55:51.087  - info: alexa2.0 (987) Alexa-Push-Connection (macDms = true) established. Disable Polling
                                2023-12-19 14:55:55.552  - info: alexa2.0 (987) Initialization Done ...
                                  deconz-init.service
                                  Dann musst du mal schauen, was da klemmen könnte.
                                  systemctl status deconz*
                                    Ergebnis meiner Eingabe!
                                    pi@raspberrypismarthome:~ $ systemctl status deconz*
                                    Unit deconz-latest-beta.deb.service could not be found.
                                      @stephan1966
                                      Mal mit beta-Zeuch herumgespielt?
                                      apt policy deconz*
                                      sagt?
                                        Kann mich nicht erinnern, hier das Ergebnis:
                                        pi@raspberrypismarthome:~ $ apt policy deconz*
                                        N: Paket deconz-latest-beta.deb kann nicht gefunden werden.
                                        N: Mittels des Musters »deconz-latest-beta.deb« konnte kein Paket gefunden werden.
                                          @stephan1966
                                          ls -lAh
                                            ls -lAh
                                            Ergebnis:
                                            pi@raspberrypismarthome:~ $ ls -lAh
                                            insgesamt 6,6M
                                            drwxr-xr-x 2 root root 4,0K 10. Jan 2023 backup
                                            -rw------- 1 pi pi 3,9K 19. Dez 14:54 .bash_history
                                            -rw-r--r-- 1 pi pi 220 30. Okt 2021 .bash_logout
                                            -rw-r--r-- 1 pi pi 3,7K 18. Dez 12:12 .bashrc
                                            drwxr-xr-x 4 pi pi 4,0K 2. Dez 2021 .cache
                                            drwx------ 3 pi pi 4,0K 2. Dez 2021 .config
                                            -rw-r--r-- 1 pi pi 161K 20. Aug 2021 deCONZ_ConBeeII_0x26720700.bin.GCF
                                            -rw-r--r-- 1 pi pi 6,4M 30. Apr 2022 deconz-latest-beta.deb
                                            drwxr-xr-x 2 pi pi 4,0K 2. Dez 2021 .iobroker
                                            drwxr-xr-x 3 pi pi 4,0K 21. Dez 2021 .local
                                            drwxr-xr-x 5 pi pi 4,0K 2. Dez 2021 .npm
                                            -rw------- 1 pi pi 36 2. Dez 2021 .npmrc
                                            -rw-r--r-- 1 pi pi 807 30. Okt 2021 .profile
                                            2858
