    4. [Gelöst] Update js-controller geht nicht
      Thomas Braun Most Active @Stephan1966 last edited by
      @stephan1966
      Du hast das falsch geschrieben und eine entsprechende Rückmeldung erhalten, aber kein upgrade durchgeführt.
        Stephan1966 @Thomas Braun last edited by
        Wer lesen kann ist klar im Vorteil 👍
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: raspberrypismarthome
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.2
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : armhf
          Systemuptime and Load:
           14:07:31 up  2:48,  1 user,  load average: 1.44, 0.89, 0.48
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Mon 2023-12-18 14:07:32 CET
                     Universal time: Mon 2023-12-18 13:07:32 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            3.8G        606M        1.3G        1.0M        1.9G        3.1G
          Swap:            99M          0B         99M
          Total:          3.9G        606M        1.4G
                   3794 M total memory
                    606 M used memory
                    688 M active memory
                   1517 M inactive memory
                   1321 M free memory
                    207 M buffer memory
                   1658 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
            UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
          * deconz-init.service   loaded failed failed deCONZ: ZigBee gateway -- Initialisation
          * deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
          * deconz-wifi.service   loaded failed failed deCONZ: ZigBee gateway -- WIFI Service
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          3 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4       29G  6.1G   22G  22% /
          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs          tmpfs     759M  1.8M  758M   1% /run
          /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
          [Mon Dec 18 11:19:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Mon Dec 18 11:19:30 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Mon Dec 18 11:19:30 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Mon Dec 18 11:19:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          /var:
          1.9G    /var/
          1.1G    /var/log/journal/2db8461036a4455ab0afd36ad1c9f367
          1.1G    /var/log
          658M    /var/cache
          Archived and active journals take up 1.0G in the file system.
          /opt/iobroker/backups:
          393M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          313M    /opt/iobroker/iobroker-data/
          180M    /opt/iobroker/iobroker-data/files
          105M    /opt/iobroker/iobroker-data/backup-objects
          67M     /opt/iobroker/iobroker-data/files/javascript.admin
          48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
          9.7M    /opt/iobroker/iobroker-data/objects.jsonl
          8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
          8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          /usr/bin/corepack       0.22.0
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
           *** 18.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.17
          admin:          6.12.0
          javascript:     7.1.6
          Adapters from github:   0
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypismarthome                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
          + system.adapter.backitup.0               : backitup              : raspberrypismarthome                     -  enabled
          + system.adapter.deconz.1                 : deconz                : raspberrypismarthome                     -  enabled, port: 80
          + system.adapter.discovery.0              : discovery             : raspberrypismarthome                     -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : raspberrypismarthome                     -  enabled
          + system.adapter.info.0                   : info                  : raspberrypismarthome                     -  enabled
          + system.adapter.iot.0                    : iot                   : raspberrypismarthome                     -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypismarthome                     -  enabled
          + system.adapter.net-tools.0              : net-tools             : raspberrypismarthome                     -  enabled
          + system.adapter.ping.0                   : ping                  : raspberrypismarthome                     -  enabled
          + system.adapter.pushover.0               : pushover              : raspberrypismarthome                     -  enabled
          + system.adapter.tr-064.0                 : tr-064                : raspberrypismarthome                     -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypismarthome                     -  enabled
          + system.adapter.web.0                    : web                   : raspberrypismarthome                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.12.0   , installed 6.12.0
          Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
          Adapter    "backitup"     : 2.8.7    , installed 2.8.7
          Adapter    "deconz"       : 1.3.23   , installed 1.3.23
          Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "pushover"     : 3.0.3    , installed 3.0.3
          Adapter    "web"          : 6.1.10   , installed 6.1.10
          Adapter    "ws"           : 2.5.8    , installed 2.5.8
          Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
          Objects and States
          Objects:        2050
          States:         1756
          Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       87946      15594/iobroker.js-c
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       87939      15594/iobroker.js-c
          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          15069      831/smbd
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       11194      400/deCONZ
          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          15070      831/smbd
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12931      400/deCONZ
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14170      535/sshd: /usr/sbin
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       90447      15612/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       90049      15972/io.web.0
          tcp6       0      0 :::445                  :::*                    LISTEN      0          15067      831/smbd
          tcp6       0      0 :::139                  :::*                    LISTEN      0          15068      831/smbd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          14172      535/sshd: /usr/sbin
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14033      392/avahi-daemon: r
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       91665      16022/io.deconz.1
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       14805      400/deCONZ
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14249      747/dhcpcd
          udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          16432      751/nmbd
          udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          16431      751/nmbd
          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          16415      751/nmbd
          udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          16434      751/nmbd
          udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          16433      751/nmbd
          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          16416      751/nmbd
          udp        0      0 0.0.0.0:45598           0.0.0.0:*                           108        14035      392/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        14034      392/avahi-daemon: r
          udp6       0      0 :::1900                 :::*                                1001       91667      16022/io.deconz.1
          udp6       0      0 :::1900                 :::*                                1001       91666      16022/io.deconz.1
          udp6       0      0 :::34833                :::*                                108        14036      392/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          14262      747/dhcpcd
          2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) no response part in returned error message
          2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
          2023-12-18 14:07:42.364  - error: fritzdect.0 (15942) login not possible, check user and permissions
          2023-12-18 14:07:43.505  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 15972
          2023-12-18 14:07:47.252  - info: web.0 (15972) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
          2023-12-18 14:07:47.570  - info: web.0 (15972) socket.io server listening on port 8082
          2023-12-18 14:07:47.582  - info: web.0 (15972) http server listening on port 8082
          2023-12-18 14:07:50.378  - info: vis.0 (15997) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
          2023-12-18 14:07:51.083  - info: vis.0 (15997) Terminated (NO_ERROR): Without reason
          2023-12-18 14:07:51.489  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 16022
          2023-12-18 14:07:51.682  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
          2023-12-18 14:07:54.669  - info: deconz.1 (16022) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
          2023-12-18 14:07:54.881  - info: deconz.1 (16022) deConz Version: 2.24.2; API version: 1.16.0
          2023-12-18 14:07:55.488  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 16046
          2023-12-18 14:07:59.511  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 16090
          2023-12-18 14:08:01.351  - info: info.0 (16046) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
          2023-12-18 14:08:01.666  - info: info.0 (16046) Reading/updating systemdata.
          2023-12-18 14:08:04.164  - info: info.0 (16046) cpu Temp res = {"main":47.225,"cores":[],"max":47.225,"socket":[],"chipset":null}
          2023-12-18 14:08:05.265  - info: iot.0 (16090) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
          2023-12-18 14:08:05.531  - info: iot.0 (16090) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
          2023-12-18 14:08:06.392  - info: iot.0 (16090) Connection changed: connect "s_glebe66_googlemail_com"
          2023-12-18 14:08:06.642  - info: alexa2.0 (15845) Subscribing to states...
          2023-12-18 14:08:06.650  - info: alexa2.0 (15845) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
          2023-12-18 14:08:08.370  - info: alexa2.0 (15845) Alexa-Push-Connection (macDms = true) established. Disable Polling
          2023-12-18 14:08:15.917  - info: alexa2.0 (15845) Initialization Done ...
          iob diag has finished.
            @stephan1966
            Hast du das boot target gesetzt?
            sudo systemctl set-default multi-user.target
            sudo reboot
            Was ist denn nun mit deconz los?
              @thomas-braun sagte in Update js-controller geht nicht:
              sudo reboot
              Muss ich diese beiden Befehle eingeben?
              ioBroker vorher anhalten?
                @stephan1966 sagte in Update js-controller geht nicht:
                Ja / Nein.
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : armhf
                   14:25:37 up 1 min,  1 user,  load average: 1.42, 0.45, 0.16
                  CPU threads: 4
                  Current issues:
                                 Local time: Mon 2023-12-18 14:25:37 CET
                             Universal time: Mon 2023-12-18 13:25:37 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            3.8G        698M        2.8G        1.0M        293M        3.0G
                  Swap:            99M          0B         99M
                  Total:          3.9G        698M        2.9G
                           3794 M total memory
                            698 M used memory
                            767 M active memory
                            119 M inactive memory
                           2802 M free memory
                             40 M buffer memory
                            252 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  [Mon Dec 18 14:24:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Mon Dec 18 14:24:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Mon Dec 18 14:24:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                  [Mon Dec 18 14:24:27 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  /var:
                  1.9G    /var/
                  1.1G    /var/log
                  658M    /var/cache
                  315M    /opt/iobroker/iobroker-data/
                  11M     /opt/iobroker/iobroker-data/objects.jsonl
                  USB-Devices by-id:
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        2065
                  States:         1769
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       13818      399/deCONZ
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13783      523/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12213      504/iobroker.js-con
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14838      504/iobroker.js-con
                  tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14054      753/smbd
                  tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       12175      399/deCONZ
                  tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14053      753/smbd
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15694      676/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17553      1023/io.web.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          13785      523/sshd: /usr/sbin
                  tcp6       0      0 :::139                  :::*                    LISTEN      0          14052      753/smbd
                  tcp6       0      0 :::445                  :::*                    LISTEN      0          14051      753/smbd
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2041       393/avahi-daemon: r
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17621      1083/io.deconz.1
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15442      399/deCONZ
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13837      747/dhcpcd
                  udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          13983      748/nmbd
                  udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          13982      748/nmbd
                  udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          13966      748/nmbd
                  udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          13985      748/nmbd
                  udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          13984      748/nmbd
                  udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          13967      748/nmbd
                  udp        0      0 0.0.0.0:51768           0.0.0.0:*                           108        2043       393/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                108        2042       393/avahi-daemon: r
                  udp6       0      0 :::48542                :::*                                108        2044       393/avahi-daemon: r
                  udp6       0      0 :::1900                 :::*                                1001       17623      1083/io.deconz.1
                  udp6       0      0 :::1900                 :::*                                1001       17622      1083/io.deconz.1
                  udp6       0      0 :::546                  :::*                                0          13850      747/dhcpcd
                  2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) no response part in returned error message
                  2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                  2023-12-18 14:25:19.594  - error: fritzdect.0 (1008) login not possible, check user and permissions
                  2023-12-18 14:25:20.809  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1023
                  2023-12-18 14:25:24.559  - info: web.0 (1023) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                  2023-12-18 14:25:25.051  - info: web.0 (1023) socket.io server listening on port 8082
                  2023-12-18 14:25:25.059  - info: web.0 (1023) http server listening on port 8082
                  2023-12-18 14:25:27.639  - info: vis.0 (1059) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                  2023-12-18 14:25:28.699  - info: vis.0 (1059) Terminated (NO_ERROR): Without reason
                  2023-12-18 14:25:28.750  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1083
                  2023-12-18 14:25:29.290  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                  2023-12-18 14:25:31.643  - info: alexa2.0 (939) Subscribing to states...
                  2023-12-18 14:25:31.653  - info: alexa2.0 (939) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                  2023-12-18 14:25:31.867  - info: deconz.1 (1083) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                  2023-12-18 14:25:32.013  - info: deconz.1 (1083) deConz Version: 2.24.2; API version: 1.16.0
                  2023-12-18 14:25:32.791  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1107
                  2023-12-18 14:25:33.549  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                  2023-12-18 14:25:36.750  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1133
                  2023-12-18 14:25:38.276  - info: info.0 (1107) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                  2023-12-18 14:25:38.565  - info: info.0 (1107) Reading/updating systemdata.
                  2023-12-18 14:25:40.091  - info: info.0 (1107) cpu Temp res = {"main":46.738,"cores":[],"max":46.738,"socket":[],"chipset":null}
                  2023-12-18 14:25:40.203  - info: alexa2.0 (939) Initialization Done ...
                  2023-12-18 14:25:41.632  - info: iot.0 (1133) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                  2023-12-18 14:25:41.783  - info: iot.0 (1133) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                  2023-12-18 14:25:42.623  - info: iot.0 (1133) Connection changed: connect "s_glebe66_googlemail_com"
                    Ja / Nein.
                    ist erledigt
                      Was ist denn mit dem 'deconz' los?
                      Nachfolgend der aktuelle Stand, ich glaube es ist noch nicht OK oder?
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : armhf
                       12:52:33 up 22:28,  1 user,  load average: 0.15, 0.03, 0.01
                      CPU threads: 4
                      Current issues:
                                     Local time: Tue 2023-12-19 12:52:33 CET
                                 Universal time: Tue 2023-12-19 11:52:33 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            3.8G        816M        2.4G        1.0M        588M        2.9G
                      Swap:            99M          0B         99M
                      Total:          3.9G        816M        2.5G
                               3794 M total memory
                                816 M used memory
                                895 M active memory
                                367 M inactive memory
                               2389 M free memory
                                 89 M buffer memory
                                499 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /dev/root      ext4       29G  6.2G   22G  23% /
                      /var:
                      1.9G    /var/
                      1.1G    /var/log
                      658M    /var/cache
                      396M    /opt/iobroker/backups/
                      329M    /opt/iobroker/iobroker-data/
                      24M     /opt/iobroker/iobroker-data/objects.jsonl
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.6
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        2065
                      States:         1761
                      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Pending Updates: 0
                      2023-12-19 00:22:45.291  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                      2023-12-19 02:00:19.204  - error: backitup.0 (974) [iobroker/ftp] Error: Access to home directory not allowed.
                      2023-12-19 02:00:19.217  - error: backitup.0 (974) [iobroker] Error: Access to home directory not allowed.
                      2023-12-19 02:24:51.981  - info: admin.0 (676) Request actual repository...
                      2023-12-19 02:24:52.654  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                      2023-12-19 02:24:58.132  - info: admin.0 (676) Repository received successfully.
                      2023-12-19 02:25:47.031  - info: info.0 (1107) Reading/updating systemdata.
                      2023-12-19 02:25:47.675  - info: info.0 (1107) cpu Temp res = {"main":41.868,"cores":[],"max":41.868,"socket":[],"chipset":null}
                      2023-12-19 03:18:22.246  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                      2023-12-19 03:18:23.687  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                      2023-12-19 05:56:01.651  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                      2023-12-19 05:56:03.105  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                      2023-12-19 08:44:32.929  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                      2023-12-19 08:44:56.919  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                      2023-12-19 08:44:59.590  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                      2023-12-19 08:46:40.957  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                      2023-12-19 08:59:55.063  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                      2023-12-19 08:59:56.533  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                      2023-12-19 10:14:57.017  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                      2023-12-19 10:14:59.037  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                      2023-12-19 10:15:37.424  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                      2023-12-19 10:21:47.849  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                      2023-12-19 10:22:19.303  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                      2023-12-19 12:41:01.489  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                      2023-12-19 12:41:02.953  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                        Versuch mal, den deconz neuzuinstallieren.
                        sudo apt install --reinstall deconz
                            @stephan1966
                            Sollte egal sein. Vielleicht den deconz-Adapter danach mal neustarten.
                              Hier das Ergebnis, sieht soweit ich das beurteilen kann noch genauso aus!
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : armhf
                               14:56:47 up 2 min,  1 user,  load average: 1.21, 0.66, 0.26
                              CPU threads: 4
                              Current issues:
                                             Local time: Tue 2023-12-19 14:56:47 CET
                                         Universal time: Tue 2023-12-19 13:56:47 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            3.8G        651M        2.8G        1.0M        302M        3.1G
                              Swap:            99M          0B         99M
                              Total:          3.9G        651M        2.9G
                                       3794 M total memory
                                        651 M used memory
                                        725 M active memory
                                        118 M inactive memory
                                       2840 M free memory
                                         41 M buffer memory
                                        260 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /dev/root      ext4       29G  6.2G   22G  22% /
                              [Tue Dec 19 14:54:28 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
                              [Tue Dec 19 14:54:29 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                              [Tue Dec 19 14:54:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                              [Tue Dec 19 14:54:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                              /var:
                              1.9G    /var/
                              1.1G    /var/log
                              658M    /var/cache
                              310M    /opt/iobroker/iobroker-data/
                              8.6M    /opt/iobroker/iobroker-data/objects.jsonl
                              USB-Devices by-id:
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
                              nodejs:
                                Version table:
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.12.0
                              javascript:     7.1.6
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        2065
                              States:         1769
                              Pending Updates: 0
                              tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14205      816/smbd
                              tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       13015      400/deCONZ
                              tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14206      816/smbd
                              tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12989      400/deCONZ
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15042      537/sshd: /usr/sbin
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13070      501/iobroker.js-con
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12123      501/iobroker.js-con
                              tcp6       0      0 :::445                  :::*                    LISTEN      0          14203      816/smbd
                              tcp6       0      0 :::139                  :::*                    LISTEN      0          14204      816/smbd
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          15044      537/sshd: /usr/sbin
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13211      662/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17527      1040/io.web.0
                              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       16822      1070/io.deconz.1
                              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15097      400/deCONZ
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12103      749/dhcpcd
                              udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          14181      750/nmbd
                              udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          14180      750/nmbd
                              udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          14164      750/nmbd
                              udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          14183      750/nmbd
                              udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          14182      750/nmbd
                              udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          14165      750/nmbd
                              udp        0      0 0.0.0.0:41316           0.0.0.0:*                           108        14958      394/avahi-daemon: r
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14956      394/avahi-daemon: r
                              udp6       0      0 :::1900                 :::*                                1001       16824      1070/io.deconz.1
                              udp6       0      0 :::1900                 :::*                                1001       16823      1070/io.deconz.1
                              udp6       0      0 :::45045                :::*                                108        14959      394/avahi-daemon: r
                              udp6       0      0 :::546                  :::*                                0          13027      749/dhcpcd
                              udp6       0      0 :::5353                 :::*                                108        14957      394/avahi-daemon: r
                              2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                              2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) login not possible, check user and permissions
                              2023-12-19 14:55:24.974  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1040
                              2023-12-19 14:55:28.042  - info: web.0 (1040) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                              2023-12-19 14:55:28.584  - info: web.0 (1040) socket.io server listening on port 8082
                              2023-12-19 14:55:28.603  - info: web.0 (1040) http server listening on port 8082
                              2023-12-19 14:55:31.435  - info: vis.0 (1055) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                              2023-12-19 14:55:32.211  - info: vis.0 (1055) Terminated (NO_ERROR): Without reason
                              2023-12-19 14:55:32.794  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                              2023-12-19 14:55:32.972  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1070
                              2023-12-19 14:55:35.726  - info: deconz.1 (1070) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                              2023-12-19 14:55:35.883  - info: deconz.1 (1070) deConz Version: 2.24.2; API version: 1.16.0
                              2023-12-19 14:55:36.496  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
                              2023-12-19 14:55:38.641  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1086
                              2023-12-19 14:55:41.025  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1101
                              2023-12-19 14:55:45.888  - info: info.0 (1086) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                              2023-12-19 14:55:46.253  - info: info.0 (1086) Reading/updating systemdata.
                              2023-12-19 14:55:46.468  - info: iot.0 (1101) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                              2023-12-19 14:55:46.638  - info: iot.0 (1101) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                              2023-12-19 14:55:47.531  - info: iot.0 (1101) Connection changed: connect "s_glebe66_googlemail_com"
                              2023-12-19 14:55:47.731  - info: info.0 (1086) cpu Temp res = {"main":46.251,"cores":[],"max":46.251,"socket":[],"chipset":null}
                              2023-12-19 14:55:49.207  - info: alexa2.0 (987) Subscribing to states...
                              2023-12-19 14:55:49.216  - info: alexa2.0 (987) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                              2023-12-19 14:55:51.087  - info: alexa2.0 (987) Alexa-Push-Connection (macDms = true) established. Disable Polling
                              2023-12-19 14:55:55.552  - info: alexa2.0 (987) Initialization Done ...
                                deconz-init.service
                                Dann musst du mal schauen, was da klemmen könnte.
                                systemctl status deconz*
                                  Ergebnis meiner Eingabe!
                                  pi@raspberrypismarthome:~ $ systemctl status deconz*
                                  Unit deconz-latest-beta.deb.service could not be found.
                                    @stephan1966
                                    Mal mit beta-Zeuch herumgespielt?
                                    apt policy deconz*
                                    sagt?
                                      Kann mich nicht erinnern, hier das Ergebnis:
                                      pi@raspberrypismarthome:~ $ apt policy deconz*
                                      N: Paket deconz-latest-beta.deb kann nicht gefunden werden.
                                      N: Mittels des Musters »deconz-latest-beta.deb« konnte kein Paket gefunden werden.
                                        @stephan1966
                                        ls -lAh
                                          ls -lAh
                                          Ergebnis:
                                          pi@raspberrypismarthome:~ $ ls -lAh
                                          insgesamt 6,6M
                                          drwxr-xr-x 2 root root 4,0K 10. Jan 2023 backup
                                          -rw------- 1 pi pi 3,9K 19. Dez 14:54 .bash_history
                                          -rw-r--r-- 1 pi pi 220 30. Okt 2021 .bash_logout
                                          -rw-r--r-- 1 pi pi 3,7K 18. Dez 12:12 .bashrc
                                          drwxr-xr-x 4 pi pi 4,0K 2. Dez 2021 .cache
                                          drwx------ 3 pi pi 4,0K 2. Dez 2021 .config
                                          -rw-r--r-- 1 pi pi 161K 20. Aug 2021 deCONZ_ConBeeII_0x26720700.bin.GCF
                                          -rw-r--r-- 1 pi pi 6,4M 30. Apr 2022 deconz-latest-beta.deb
                                          drwxr-xr-x 2 pi pi 4,0K 2. Dez 2021 .iobroker
                                          drwxr-xr-x 3 pi pi 4,0K 21. Dez 2021 .local
                                          drwxr-xr-x 5 pi pi 4,0K 2. Dez 2021 .npm
                                          -rw------- 1 pi pi 36 2. Dez 2021 .npmrc
                                          -rw-r--r-- 1 pi pi 807 30. Okt 2021 .profile
                                            Thomas Braun Most Active @Stephan1966 last edited by Thomas Braun
                                            @stephan1966
                                            Das muss da weg:
                                            rm deconz-latest-beta.deb
                                            Und bitte Auszüge aus der Konsole immer in Code Tags setzen. Liest sich besser.
                                            2858
