    4. [Gelöst] Update js-controller geht nicht
      Stephan1966 @Thomas Braun last edited by
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypismarthome
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : armhf
      Systemuptime and Load:
       14:07:31 up  2:48,  1 user,  load average: 1.44, 0.89, 0.48
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Mon 2023-12-18 14:07:32 CET
                 Universal time: Mon 2023-12-18 13:07:32 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        606M        1.3G        1.0M        1.9G        3.1G
      Swap:            99M          0B         99M
      Total:          3.9G        606M        1.4G
               3794 M total memory
                606 M used memory
                688 M active memory
               1517 M inactive memory
               1321 M free memory
                207 M buffer memory
               1658 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
      * deconz-init.service   loaded failed failed deCONZ: ZigBee gateway -- Initialisation
      * deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
      * deconz-wifi.service   loaded failed failed deCONZ: ZigBee gateway -- WIFI Service
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      3 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G  6.1G   22G  22% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  1.8M  758M   1% /run
      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Mon Dec 18 11:19:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Mon Dec 18 11:19:30 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon Dec 18 11:19:30 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Mon Dec 18 11:19:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      1.9G    /var/
      1.1G    /var/log/journal/2db8461036a4455ab0afd36ad1c9f367
      1.1G    /var/log
      658M    /var/cache
      Archived and active journals take up 1.0G in the file system.
      /opt/iobroker/backups:
      393M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      313M    /opt/iobroker/iobroker-data/
      180M    /opt/iobroker/iobroker-data/files
      105M    /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      9.7M    /opt/iobroker/iobroker-data/objects.jsonl
      8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypismarthome                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypismarthome                     -  enabled
      + system.adapter.deconz.1                 : deconz                : raspberrypismarthome                     -  enabled, port: 80
      + system.adapter.discovery.0              : discovery             : raspberrypismarthome                     -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypismarthome                     -  enabled
      + system.adapter.info.0                   : info                  : raspberrypismarthome                     -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypismarthome                     -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypismarthome                     -  enabled
      + system.adapter.net-tools.0              : net-tools             : raspberrypismarthome                     -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypismarthome                     -  enabled
      + system.adapter.pushover.0               : pushover              : raspberrypismarthome                     -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypismarthome                     -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypismarthome                     -  enabled
      + system.adapter.web.0                    : web                   : raspberrypismarthome                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "deconz"       : 1.3.23   , installed 1.3.23
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
      Objects and States
      Objects:        2050
      States:         1756
      Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       87946      15594/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       87939      15594/iobroker.js-c
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          15069      831/smbd
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       11194      400/deCONZ
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          15070      831/smbd
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12931      400/deCONZ
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14170      535/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       90447      15612/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       90049      15972/io.web.0
      tcp6       0      0 :::445                  :::*                    LISTEN      0          15067      831/smbd
      tcp6       0      0 :::139                  :::*                    LISTEN      0          15068      831/smbd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14172      535/sshd: /usr/sbin
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14033      392/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       91665      16022/io.deconz.1
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       14805      400/deCONZ
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14249      747/dhcpcd
      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          16432      751/nmbd
      udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          16431      751/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          16415      751/nmbd
      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          16434      751/nmbd
      udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          16433      751/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          16416      751/nmbd
      udp        0      0 0.0.0.0:45598           0.0.0.0:*                           108        14035      392/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        14034      392/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1001       91667      16022/io.deconz.1
      udp6       0      0 :::1900                 :::*                                1001       91666      16022/io.deconz.1
      udp6       0      0 :::34833                :::*                                108        14036      392/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          14262      747/dhcpcd
      2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) no response part in returned error message
      2023-12-18 14:07:42.363  - error: fritzdect.0 (15942) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
      2023-12-18 14:07:42.364  - error: fritzdect.0 (15942) login not possible, check user and permissions
      2023-12-18 14:07:43.505  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 15972
      2023-12-18 14:07:47.252  - info: web.0 (15972) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
      2023-12-18 14:07:47.570  - info: web.0 (15972) socket.io server listening on port 8082
      2023-12-18 14:07:47.582  - info: web.0 (15972) http server listening on port 8082
      2023-12-18 14:07:50.378  - info: vis.0 (15997) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
      2023-12-18 14:07:51.083  - info: vis.0 (15997) Terminated (NO_ERROR): Without reason
      2023-12-18 14:07:51.489  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 16022
      2023-12-18 14:07:51.682  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
      2023-12-18 14:07:54.669  - info: deconz.1 (16022) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
      2023-12-18 14:07:54.881  - info: deconz.1 (16022) deConz Version: 2.24.2; API version: 1.16.0
      2023-12-18 14:07:55.488  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 16046
      2023-12-18 14:07:59.511  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 16090
      2023-12-18 14:08:01.351  - info: info.0 (16046) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
      2023-12-18 14:08:01.666  - info: info.0 (16046) Reading/updating systemdata.
      2023-12-18 14:08:04.164  - info: info.0 (16046) cpu Temp res = {"main":47.225,"cores":[],"max":47.225,"socket":[],"chipset":null}
      2023-12-18 14:08:05.265  - info: iot.0 (16090) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
      2023-12-18 14:08:05.531  - info: iot.0 (16090) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2023-12-18 14:08:06.392  - info: iot.0 (16090) Connection changed: connect "s_glebe66_googlemail_com"
      2023-12-18 14:08:06.642  - info: alexa2.0 (15845) Subscribing to states...
      2023-12-18 14:08:06.650  - info: alexa2.0 (15845) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
      2023-12-18 14:08:08.370  - info: alexa2.0 (15845) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2023-12-18 14:08:15.917  - info: alexa2.0 (15845) Initialization Done ...
      iob diag has finished.
        Thomas Braun Most Active @Stephan1966 last edited by
        @stephan1966
        Hast du das boot target gesetzt?
        sudo systemctl set-default multi-user.target
        sudo reboot
        Was ist denn nun mit deconz los?
          @thomas-braun sagte in Update js-controller geht nicht:
          sudo reboot
          Muss ich diese beiden Befehle eingeben?
          ioBroker vorher anhalten?
            @stephan1966 sagte in Update js-controller geht nicht:
            Ja / Nein.
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : armhf
               14:25:37 up 1 min,  1 user,  load average: 1.42, 0.45, 0.16
              CPU threads: 4
              Current issues:
                             Local time: Mon 2023-12-18 14:25:37 CET
                         Universal time: Mon 2023-12-18 13:25:37 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            3.8G        698M        2.8G        1.0M        293M        3.0G
              Swap:            99M          0B         99M
              Total:          3.9G        698M        2.9G
                       3794 M total memory
                        698 M used memory
                        767 M active memory
                        119 M inactive memory
                       2802 M free memory
                         40 M buffer memory
                        252 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              [Mon Dec 18 14:24:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
              [Mon Dec 18 14:24:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
              [Mon Dec 18 14:24:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Mon Dec 18 14:24:27 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              /var:
              1.9G    /var/
              1.1G    /var/log
              658M    /var/cache
              315M    /opt/iobroker/iobroker-data/
              11M     /opt/iobroker/iobroker-data/objects.jsonl
              USB-Devices by-id:
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              javascript:     7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        2065
              States:         1769
              Pending Updates: 0
              tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       13818      399/deCONZ
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13783      523/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12213      504/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14838      504/iobroker.js-con
              tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14054      753/smbd
              tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       12175      399/deCONZ
              tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14053      753/smbd
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15694      676/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17553      1023/io.web.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          13785      523/sshd: /usr/sbin
              tcp6       0      0 :::139                  :::*                    LISTEN      0          14052      753/smbd
              tcp6       0      0 :::445                  :::*                    LISTEN      0          14051      753/smbd
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2041       393/avahi-daemon: r
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17621      1083/io.deconz.1
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15442      399/deCONZ
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13837      747/dhcpcd
              udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          13983      748/nmbd
              udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          13982      748/nmbd
              udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          13966      748/nmbd
              udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          13985      748/nmbd
              udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          13984      748/nmbd
              udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          13967      748/nmbd
              udp        0      0 0.0.0.0:51768           0.0.0.0:*                           108        2043       393/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                108        2042       393/avahi-daemon: r
              udp6       0      0 :::48542                :::*                                108        2044       393/avahi-daemon: r
              udp6       0      0 :::1900                 :::*                                1001       17623      1083/io.deconz.1
              udp6       0      0 :::1900                 :::*                                1001       17622      1083/io.deconz.1
              udp6       0      0 :::546                  :::*                                0          13850      747/dhcpcd
              2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) no response part in returned error message
              2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
              2023-12-18 14:25:19.594  - error: fritzdect.0 (1008) login not possible, check user and permissions
              2023-12-18 14:25:20.809  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1023
              2023-12-18 14:25:24.559  - info: web.0 (1023) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
              2023-12-18 14:25:25.051  - info: web.0 (1023) socket.io server listening on port 8082
              2023-12-18 14:25:25.059  - info: web.0 (1023) http server listening on port 8082
              2023-12-18 14:25:27.639  - info: vis.0 (1059) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
              2023-12-18 14:25:28.699  - info: vis.0 (1059) Terminated (NO_ERROR): Without reason
              2023-12-18 14:25:28.750  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1083
              2023-12-18 14:25:29.290  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
              2023-12-18 14:25:31.643  - info: alexa2.0 (939) Subscribing to states...
              2023-12-18 14:25:31.653  - info: alexa2.0 (939) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
              2023-12-18 14:25:31.867  - info: deconz.1 (1083) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
              2023-12-18 14:25:32.013  - info: deconz.1 (1083) deConz Version: 2.24.2; API version: 1.16.0
              2023-12-18 14:25:32.791  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1107
              2023-12-18 14:25:33.549  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
              2023-12-18 14:25:36.750  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1133
              2023-12-18 14:25:38.276  - info: info.0 (1107) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
              2023-12-18 14:25:38.565  - info: info.0 (1107) Reading/updating systemdata.
              2023-12-18 14:25:40.091  - info: info.0 (1107) cpu Temp res = {"main":46.738,"cores":[],"max":46.738,"socket":[],"chipset":null}
              2023-12-18 14:25:40.203  - info: alexa2.0 (939) Initialization Done ...
              2023-12-18 14:25:41.632  - info: iot.0 (1133) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
              2023-12-18 14:25:41.783  - info: iot.0 (1133) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
              2023-12-18 14:25:42.623  - info: iot.0 (1133) Connection changed: connect "s_glebe66_googlemail_com"
                Ja / Nein.
                ist erledigt
                  Was ist denn mit dem 'deconz' los?
                  Nachfolgend der aktuelle Stand, ich glaube es ist noch nicht OK oder?
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : armhf
                   12:52:33 up 22:28,  1 user,  load average: 0.15, 0.03, 0.01
                  CPU threads: 4
                  Current issues:
                                 Local time: Tue 2023-12-19 12:52:33 CET
                             Universal time: Tue 2023-12-19 11:52:33 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            3.8G        816M        2.4G        1.0M        588M        2.9G
                  Swap:            99M          0B         99M
                  Total:          3.9G        816M        2.5G
                           3794 M total memory
                            816 M used memory
                            895 M active memory
                            367 M inactive memory
                           2389 M free memory
                             89 M buffer memory
                            499 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /dev/root      ext4       29G  6.2G   22G  23% /
                  /var:
                  1.9G    /var/
                  1.1G    /var/log
                  658M    /var/cache
                  396M    /opt/iobroker/backups/
                  329M    /opt/iobroker/iobroker-data/
                  24M     /opt/iobroker/iobroker-data/objects.jsonl
                  USB-Devices by-id:
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.6
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        2065
                  States:         1761
                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Pending Updates: 0
                  2023-12-19 00:22:45.291  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                  2023-12-19 02:00:19.204  - error: backitup.0 (974) [iobroker/ftp] Error: Access to home directory not allowed.
                  2023-12-19 02:00:19.217  - error: backitup.0 (974) [iobroker] Error: Access to home directory not allowed.
                  2023-12-19 02:24:51.981  - info: admin.0 (676) Request actual repository...
                  2023-12-19 02:24:52.654  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                  2023-12-19 02:24:58.132  - info: admin.0 (676) Repository received successfully.
                  2023-12-19 02:25:47.031  - info: info.0 (1107) Reading/updating systemdata.
                  2023-12-19 02:25:47.675  - info: info.0 (1107) cpu Temp res = {"main":41.868,"cores":[],"max":41.868,"socket":[],"chipset":null}
                  2023-12-19 03:18:22.246  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                  2023-12-19 03:18:23.687  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                  2023-12-19 05:56:01.651  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                  2023-12-19 05:56:03.105  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                  2023-12-19 08:44:32.929  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                  2023-12-19 08:44:56.919  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                  2023-12-19 08:44:59.590  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                  2023-12-19 08:46:40.957  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                  2023-12-19 08:59:55.063  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                  2023-12-19 08:59:56.533  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                  2023-12-19 10:14:57.017  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                  2023-12-19 10:14:59.037  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                  2023-12-19 10:15:37.424  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                  2023-12-19 10:21:47.849  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
                  2023-12-19 10:22:19.303  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
                  2023-12-19 12:41:01.489  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
                  2023-12-19 12:41:02.953  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
                    Versuch mal, den deconz neuzuinstallieren.
                    sudo apt install --reinstall deconz
                        @stephan1966
                        Sollte egal sein. Vielleicht den deconz-Adapter danach mal neustarten.
                          Hier das Ergebnis, sieht soweit ich das beurteilen kann noch genauso aus!
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : armhf
                           14:56:47 up 2 min,  1 user,  load average: 1.21, 0.66, 0.26
                          CPU threads: 4
                          Current issues:
                                         Local time: Tue 2023-12-19 14:56:47 CET
                                     Universal time: Tue 2023-12-19 13:56:47 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            3.8G        651M        2.8G        1.0M        302M        3.1G
                          Swap:            99M          0B         99M
                          Total:          3.9G        651M        2.9G
                                   3794 M total memory
                                    651 M used memory
                                    725 M active memory
                                    118 M inactive memory
                                   2840 M free memory
                                     41 M buffer memory
                                    260 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /dev/root      ext4       29G  6.2G   22G  22% /
                          [Tue Dec 19 14:54:28 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Tue Dec 19 14:54:29 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                          [Tue Dec 19 14:54:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                          [Tue Dec 19 14:54:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                          /var:
                          1.9G    /var/
                          1.1G    /var/log
                          658M    /var/cache
                          310M    /opt/iobroker/iobroker-data/
                          8.6M    /opt/iobroker/iobroker-data/objects.jsonl
                          USB-Devices by-id:
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          javascript:     7.1.6
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        2065
                          States:         1769
                          Pending Updates: 0
                          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14205      816/smbd
                          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       13015      400/deCONZ
                          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14206      816/smbd
                          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12989      400/deCONZ
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15042      537/sshd: /usr/sbin
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13070      501/iobroker.js-con
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12123      501/iobroker.js-con
                          tcp6       0      0 :::445                  :::*                    LISTEN      0          14203      816/smbd
                          tcp6       0      0 :::139                  :::*                    LISTEN      0          14204      816/smbd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          15044      537/sshd: /usr/sbin
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13211      662/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17527      1040/io.web.0
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       16822      1070/io.deconz.1
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15097      400/deCONZ
                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12103      749/dhcpcd
                          udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          14181      750/nmbd
                          udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          14180      750/nmbd
                          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          14164      750/nmbd
                          udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          14183      750/nmbd
                          udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          14182      750/nmbd
                          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          14165      750/nmbd
                          udp        0      0 0.0.0.0:41316           0.0.0.0:*                           108        14958      394/avahi-daemon: r
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14956      394/avahi-daemon: r
                          udp6       0      0 :::1900                 :::*                                1001       16824      1070/io.deconz.1
                          udp6       0      0 :::1900                 :::*                                1001       16823      1070/io.deconz.1
                          udp6       0      0 :::45045                :::*                                108        14959      394/avahi-daemon: r
                          udp6       0      0 :::546                  :::*                                0          13027      749/dhcpcd
                          udp6       0      0 :::5353                 :::*                                108        14957      394/avahi-daemon: r
                          2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                          2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) login not possible, check user and permissions
                          2023-12-19 14:55:24.974  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1040
                          2023-12-19 14:55:28.042  - info: web.0 (1040) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                          2023-12-19 14:55:28.584  - info: web.0 (1040) socket.io server listening on port 8082
                          2023-12-19 14:55:28.603  - info: web.0 (1040) http server listening on port 8082
                          2023-12-19 14:55:31.435  - info: vis.0 (1055) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                          2023-12-19 14:55:32.211  - info: vis.0 (1055) Terminated (NO_ERROR): Without reason
                          2023-12-19 14:55:32.794  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                          2023-12-19 14:55:32.972  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1070
                          2023-12-19 14:55:35.726  - info: deconz.1 (1070) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                          2023-12-19 14:55:35.883  - info: deconz.1 (1070) deConz Version: 2.24.2; API version: 1.16.0
                          2023-12-19 14:55:36.496  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
                          2023-12-19 14:55:38.641  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1086
                          2023-12-19 14:55:41.025  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1101
                          2023-12-19 14:55:45.888  - info: info.0 (1086) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                          2023-12-19 14:55:46.253  - info: info.0 (1086) Reading/updating systemdata.
                          2023-12-19 14:55:46.468  - info: iot.0 (1101) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                          2023-12-19 14:55:46.638  - info: iot.0 (1101) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                          2023-12-19 14:55:47.531  - info: iot.0 (1101) Connection changed: connect "s_glebe66_googlemail_com"
                          2023-12-19 14:55:47.731  - info: info.0 (1086) cpu Temp res = {"main":46.251,"cores":[],"max":46.251,"socket":[],"chipset":null}
                          2023-12-19 14:55:49.207  - info: alexa2.0 (987) Subscribing to states...
                          2023-12-19 14:55:49.216  - info: alexa2.0 (987) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                          2023-12-19 14:55:51.087  - info: alexa2.0 (987) Alexa-Push-Connection (macDms = true) established. Disable Polling
                          2023-12-19 14:55:55.552  - info: alexa2.0 (987) Initialization Done ...
                            deconz-init.service
                            Dann musst du mal schauen, was da klemmen könnte.
                            systemctl status deconz*
                              Ergebnis meiner Eingabe!
                              pi@raspberrypismarthome:~ $ systemctl status deconz*
                              Unit deconz-latest-beta.deb.service could not be found.
                                @stephan1966
                                Mal mit beta-Zeuch herumgespielt?
                                apt policy deconz*
                                sagt?
                                  Kann mich nicht erinnern, hier das Ergebnis:
                                  pi@raspberrypismarthome:~ $ apt policy deconz*
                                  N: Paket deconz-latest-beta.deb kann nicht gefunden werden.
                                  N: Mittels des Musters »deconz-latest-beta.deb« konnte kein Paket gefunden werden.
                                    @stephan1966
                                    ls -lAh
                                      ls -lAh
                                      Ergebnis:
                                      pi@raspberrypismarthome:~ $ ls -lAh
                                      insgesamt 6,6M
                                      drwxr-xr-x 2 root root 4,0K 10. Jan 2023 backup
                                      -rw------- 1 pi pi 3,9K 19. Dez 14:54 .bash_history
                                      -rw-r--r-- 1 pi pi 220 30. Okt 2021 .bash_logout
                                      -rw-r--r-- 1 pi pi 3,7K 18. Dez 12:12 .bashrc
                                      drwxr-xr-x 4 pi pi 4,0K 2. Dez 2021 .cache
                                      drwx------ 3 pi pi 4,0K 2. Dez 2021 .config
                                      -rw-r--r-- 1 pi pi 161K 20. Aug 2021 deCONZ_ConBeeII_0x26720700.bin.GCF
                                      -rw-r--r-- 1 pi pi 6,4M 30. Apr 2022 deconz-latest-beta.deb
                                      drwxr-xr-x 2 pi pi 4,0K 2. Dez 2021 .iobroker
                                      drwxr-xr-x 3 pi pi 4,0K 21. Dez 2021 .local
                                      drwxr-xr-x 5 pi pi 4,0K 2. Dez 2021 .npm
                                      -rw------- 1 pi pi 36 2. Dez 2021 .npmrc
                                      -rw-r--r-- 1 pi pi 807 30. Okt 2021 .profile
                                        Thomas Braun Most Active @Stephan1966 last edited by Thomas Braun
                                        @stephan1966
                                        Das muss da weg:
                                        rm deconz-latest-beta.deb
                                        Und bitte Auszüge aus der Konsole immer in Code Tags setzen. Liest sich besser.
                                          Hier das Ergebnis nachdem ich rm deconz-latest-beta.deb ausgeführt habe: ```
                                          Skript v.2023-10-10
                                          *** BASE SYSTEM ***
                                                   Icon name: computer
                                                Architecture: arm64
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : armhf
                                           09:35:28 up 2 days, 18:41,  1 user,  load average: 0.07, 0.19, 0.22
                                          CPU threads: 4
                                          Current issues:
                                                         Local time: Fri 2023-12-22 09:35:28 CET
                                                     Universal time: Fri 2023-12-22 08:35:28 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          /home/pi
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            3.8G        803M        2.4G        1.0M        625M        2.9G
                                          Swap:            99M          0B         99M
                                          Total:          3.9G        803M        2.5G
                                                   3794 M total memory
                                                    803 M used memory
                                                    883 M active memory
                                                    401 M inactive memory
                                                   2364 M free memory
                                                     90 M buffer memory
                                                    535 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          /var:
                                          1.9G    /var/
                                          1.1G    /var/log
                                          658M    /var/cache
                                          403M    /opt/iobroker/backups/
                                          333M    /opt/iobroker/iobroker-data/
                                          106M    /opt/iobroker/iobroker-data/backup-objects
                                          28M     /opt/iobroker/iobroker-data/objects.jsonl
                                          USB-Devices by-id:
                                          /usr/bin/npm            10.2.3
                                          /usr/bin/npx            10.2.3
                                          nodejs:
                                            Version table:
                                          Errors in npm tree:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.12.0
                                          javascript:     7.1.6
                                          Adapter State
                                          + instance is alive
                                          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                                          Objects and States
                                          Objects:        2065
                                          States:         1761
                                          Pending Updates: 0
                                          2023-12-22 09:15:38.510  - info: host.raspberrypismarthome stopInstance system.adapter.pushover.0 send kill signal
                                          2023-12-22 09:15:38.738  - info: host.raspberrypismarthome iobroker upload [14] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/blockly.js blockly.js application/javascript
                                          2023-12-22 09:15:38.760  - info: host.raspberrypismarthome iobroker upload [13] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                          2023-12-22 09:15:38.771  - info: host.raspberrypismarthome iobroker upload [12] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                          2023-12-22 09:15:38.781  - info: host.raspberrypismarthome iobroker upload [11] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                          2023-12-22 09:15:38.792  - info: host.raspberrypismarthome iobroker upload [10] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                          2023-12-22 09:15:38.803  - info: host.raspberrypismarthome iobroker upload [9] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                          2023-12-22 09:15:38.815  - info: host.raspberrypismarthome iobroker upload [8] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                          2023-12-22 09:15:38.825  - info: host.raspberrypismarthome iobroker upload [7] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                          2023-12-22 09:15:38.839  - info: host.raspberrypismarthome iobroker upload [6] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                          2023-12-22 09:15:38.852  - info: host.raspberrypismarthome iobroker upload [5] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                          2023-12-22 09:15:38.864  - info: host.raspberrypismarthome iobroker upload [4] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                          2023-12-22 09:15:38.874  - info: host.raspberrypismarthome iobroker upload [3] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/index_m.html index_m.html text/html
                                          2023-12-22 09:15:38.884  - info: host.raspberrypismarthome iobroker upload [2] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/jsonConfig.json jsonConfig.json application/json
                                          2023-12-22 09:15:38.895  - info: host.raspberrypismarthome iobroker upload [1] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/pushover.png pushover.png image/png
                                          2023-12-22 09:15:38.905  - info: host.raspberrypismarthome iobroker upload [0] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/words.js words.js application/javascript
                                          2023-12-22 09:15:38.976  - info: pushover.0 (829) terminating
                                          2023-12-22 09:15:38.978  - info: pushover.0 (829) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2023-12-22 09:15:39.514  - info: host.raspberrypismarthome stopInstance system.adapter.pushover.0 killing pid 829
                                          2023-12-22 09:15:39.611  - info: host.raspberrypismarthome instance system.adapter.pushover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2023-12-22 09:15:39.947  - info: host.raspberrypismarthome iobroker exit 0
                                          2023-12-22 09:15:41.597  - info: host.raspberrypismarthome instance system.adapter.pushover.0 started with pid 17654
                                          2023-12-22 09:15:44.251  - info: pushover.0 (17654) starting. Version 3.0.6 in /opt/iobroker/node_modules/iobroker.pushover, node: v18.19.0, js-controller: 5.0.17
                                          2023-12-22 09:18:40.465  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                          2023-12-22 09:18:43.110  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                            @stephan1966
                                            wirft jetzt was raus?
                                            2858
