    4. [Gelöst] Update js-controller geht nicht
      Thomas Braun Most Active @Stephan1966 last edited by
      @stephan1966 sagte in Update js-controller geht nicht:
      Muss ich diese beiden Befehle eingeben?
      ioBroker vorher anhalten?
      Ja / Nein.
        Stephan1966 @Thomas Braun last edited by
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypismarthome
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : armhf
        Systemuptime and Load:
         14:25:37 up 1 min,  1 user,  load average: 1.42, 0.45, 0.16
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Mon 2023-12-18 14:25:37 CET
                   Universal time: Mon 2023-12-18 13:25:37 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            3.8G        698M        2.8G        1.0M        293M        3.0G
        Swap:            99M          0B         99M
        Total:          3.9G        698M        2.9G
                 3794 M total memory
                  698 M used memory
                  767 M active memory
                  119 M inactive memory
                 2802 M free memory
                   40 M buffer memory
                  252 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
          UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
        * deconz-init.service   loaded failed failed deCONZ: ZigBee gateway -- Initialisation
        * deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
        * deconz-wifi.service   loaded failed failed deCONZ: ZigBee gateway -- WIFI Service
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        3 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       29G  6.1G   22G  22% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     759M  1.8M  758M   1% /run
        /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [Mon Dec 18 14:24:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Mon Dec 18 14:24:24 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Mon Dec 18 14:24:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Mon Dec 18 14:24:27 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        1.9G    /var/
        1.1G    /var/log/journal/2db8461036a4455ab0afd36ad1c9f367
        1.1G    /var/log
        658M    /var/cache
        Archived and active journals take up 1.0G in the file system.
        /opt/iobroker/backups:
        393M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        315M    /opt/iobroker/iobroker-data/
        180M    /opt/iobroker/iobroker-data/files
        105M    /opt/iobroker/iobroker-data/backup-objects
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        11M     /opt/iobroker/iobroker-data/objects.jsonl
        8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.12.0
        javascript:     7.1.6
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypismarthome                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypismarthome                     -  enabled
        + system.adapter.deconz.1                 : deconz                : raspberrypismarthome                     -  enabled, port: 80
        + system.adapter.discovery.0              : discovery             : raspberrypismarthome                     -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : raspberrypismarthome                     -  enabled
        + system.adapter.info.0                   : info                  : raspberrypismarthome                     -  enabled
        + system.adapter.iot.0                    : iot                   : raspberrypismarthome                     -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypismarthome                     -  enabled
        + system.adapter.net-tools.0              : net-tools             : raspberrypismarthome                     -  enabled
        + system.adapter.ping.0                   : ping                  : raspberrypismarthome                     -  enabled
        + system.adapter.pushover.0               : pushover              : raspberrypismarthome                     -  enabled
        + system.adapter.tr-064.0                 : tr-064                : raspberrypismarthome                     -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypismarthome                     -  enabled
        + system.adapter.web.0                    : web                   : raspberrypismarthome                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Adapter    "deconz"       : 1.3.23   , installed 1.3.23
        Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "pushover"     : 3.0.3    , installed 3.0.3
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
        Objects and States
        Objects:        2065
        States:         1769
        Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       13818      399/deCONZ
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13783      523/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12213      504/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14838      504/iobroker.js-con
        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14054      753/smbd
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       12175      399/deCONZ
        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14053      753/smbd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15694      676/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17553      1023/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          13785      523/sshd: /usr/sbin
        tcp6       0      0 :::139                  :::*                    LISTEN      0          14052      753/smbd
        tcp6       0      0 :::445                  :::*                    LISTEN      0          14051      753/smbd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2041       393/avahi-daemon: r
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17621      1083/io.deconz.1
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15442      399/deCONZ
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13837      747/dhcpcd
        udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          13983      748/nmbd
        udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          13982      748/nmbd
        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          13966      748/nmbd
        udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          13985      748/nmbd
        udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          13984      748/nmbd
        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          13967      748/nmbd
        udp        0      0 0.0.0.0:51768           0.0.0.0:*                           108        2043       393/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        2042       393/avahi-daemon: r
        udp6       0      0 :::48542                :::*                                108        2044       393/avahi-daemon: r
        udp6       0      0 :::1900                 :::*                                1001       17623      1083/io.deconz.1
        udp6       0      0 :::1900                 :::*                                1001       17622      1083/io.deconz.1
        udp6       0      0 :::546                  :::*                                0          13850      747/dhcpcd
        2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) no response part in returned error message
        2023-12-18 14:25:19.593  - error: fritzdect.0 (1008) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
        2023-12-18 14:25:19.594  - error: fritzdect.0 (1008) login not possible, check user and permissions
        2023-12-18 14:25:20.809  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1023
        2023-12-18 14:25:24.559  - info: web.0 (1023) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
        2023-12-18 14:25:25.051  - info: web.0 (1023) socket.io server listening on port 8082
        2023-12-18 14:25:25.059  - info: web.0 (1023) http server listening on port 8082
        2023-12-18 14:25:27.639  - info: vis.0 (1059) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
        2023-12-18 14:25:28.699  - info: vis.0 (1059) Terminated (NO_ERROR): Without reason
        2023-12-18 14:25:28.750  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1083
        2023-12-18 14:25:29.290  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
        2023-12-18 14:25:31.643  - info: alexa2.0 (939) Subscribing to states...
        2023-12-18 14:25:31.653  - info: alexa2.0 (939) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
        2023-12-18 14:25:31.867  - info: deconz.1 (1083) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
        2023-12-18 14:25:32.013  - info: deconz.1 (1083) deConz Version: 2.24.2; API version: 1.16.0
        2023-12-18 14:25:32.791  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1107
        2023-12-18 14:25:33.549  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
        2023-12-18 14:25:36.750  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1133
        2023-12-18 14:25:38.276  - info: info.0 (1107) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
        2023-12-18 14:25:38.565  - info: info.0 (1107) Reading/updating systemdata.
        2023-12-18 14:25:40.091  - info: info.0 (1107) cpu Temp res = {"main":46.738,"cores":[],"max":46.738,"socket":[],"chipset":null}
        2023-12-18 14:25:40.203  - info: alexa2.0 (939) Initialization Done ...
        2023-12-18 14:25:41.632  - info: iot.0 (1133) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
        2023-12-18 14:25:41.783  - info: iot.0 (1133) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
        2023-12-18 14:25:42.623  - info: iot.0 (1133) Connection changed: connect "s_glebe66_googlemail_com"
        iob diag has finished.
          @thomas-braun sagte in Update js-controller geht nicht:
          Ja / Nein.
          ist erledigt
            Was ist denn mit dem 'deconz' los?
            Nachfolgend der aktuelle Stand, ich glaube es ist noch nicht OK oder?
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : armhf
             12:52:33 up 22:28,  1 user,  load average: 0.15, 0.03, 0.01
            CPU threads: 4
            Current issues:
                           Local time: Tue 2023-12-19 12:52:33 CET
                       Universal time: Tue 2023-12-19 11:52:33 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            3.8G        816M        2.4G        1.0M        588M        2.9G
            Swap:            99M          0B         99M
            Total:          3.9G        816M        2.5G
                     3794 M total memory
                      816 M used memory
                      895 M active memory
                      367 M inactive memory
                     2389 M free memory
                       89 M buffer memory
                      499 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /dev/root      ext4       29G  6.2G   22G  23% /
            /var:
            1.9G    /var/
            1.1G    /var/log
            658M    /var/cache
            396M    /opt/iobroker/backups/
            329M    /opt/iobroker/iobroker-data/
            24M     /opt/iobroker/iobroker-data/objects.jsonl
            USB-Devices by-id:
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.12.0
            javascript:     7.1.6
            Adapter State
            + instance is alive
            Objects and States
            Objects:        2065
            States:         1761
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Pending Updates: 0
            2023-12-19 00:22:45.291  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
            2023-12-19 02:00:19.204  - error: backitup.0 (974) [iobroker/ftp] Error: Access to home directory not allowed.
            2023-12-19 02:00:19.217  - error: backitup.0 (974) [iobroker] Error: Access to home directory not allowed.
            2023-12-19 02:24:51.981  - info: admin.0 (676) Request actual repository...
            2023-12-19 02:24:52.654  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
            2023-12-19 02:24:58.132  - info: admin.0 (676) Repository received successfully.
            2023-12-19 02:25:47.031  - info: info.0 (1107) Reading/updating systemdata.
            2023-12-19 02:25:47.675  - info: info.0 (1107) cpu Temp res = {"main":41.868,"cores":[],"max":41.868,"socket":[],"chipset":null}
            2023-12-19 03:18:22.246  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
            2023-12-19 03:18:23.687  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
            2023-12-19 05:56:01.651  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
            2023-12-19 05:56:03.105  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
            2023-12-19 08:44:32.929  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
            2023-12-19 08:44:56.919  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
            2023-12-19 08:44:59.590  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
            2023-12-19 08:46:40.957  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
            2023-12-19 08:59:55.063  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
            2023-12-19 08:59:56.533  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
            2023-12-19 10:14:57.017  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
            2023-12-19 10:14:59.037  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
            2023-12-19 10:15:37.424  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
            2023-12-19 10:21:47.849  - info: admin.0 (676) ==> Connected system.user.admin from ::ffff:192.168.178.59
            2023-12-19 10:22:19.303  - info: admin.0 (676) <== Disconnect system.user.admin from ::ffff:192.168.178.59
            2023-12-19 12:41:01.489  - info: alexa2.0 (939) Alexa-Push-Connection disconnected - retry: Retry Connection in 1s (undefined: undefined)
            2023-12-19 12:41:02.953  - info: alexa2.0 (939) Alexa-Push-Connection (macDms = true) established. Disable Polling
              Versuch mal, den deconz neuzuinstallieren.
              sudo apt install --reinstall deconz
                  @stephan1966
                  Sollte egal sein. Vielleicht den deconz-Adapter danach mal neustarten.
                    Hier das Ergebnis, sieht soweit ich das beurteilen kann noch genauso aus!
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : armhf
                     14:56:47 up 2 min,  1 user,  load average: 1.21, 0.66, 0.26
                    CPU threads: 4
                    Current issues:
                                   Local time: Tue 2023-12-19 14:56:47 CET
                               Universal time: Tue 2023-12-19 13:56:47 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            3.8G        651M        2.8G        1.0M        302M        3.1G
                    Swap:            99M          0B         99M
                    Total:          3.9G        651M        2.9G
                             3794 M total memory
                              651 M used memory
                              725 M active memory
                              118 M inactive memory
                             2840 M free memory
                               41 M buffer memory
                              260 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /dev/root      ext4       29G  6.2G   22G  22% /
                    [Tue Dec 19 14:54:28 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Tue Dec 19 14:54:29 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Tue Dec 19 14:54:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Tue Dec 19 14:54:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    /var:
                    1.9G    /var/
                    1.1G    /var/log
                    658M    /var/cache
                    310M    /opt/iobroker/iobroker-data/
                    8.6M    /opt/iobroker/iobroker-data/objects.jsonl
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        2065
                    States:         1769
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14205      816/smbd
                    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       13015      400/deCONZ
                    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14206      816/smbd
                    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12989      400/deCONZ
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15042      537/sshd: /usr/sbin
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13070      501/iobroker.js-con
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12123      501/iobroker.js-con
                    tcp6       0      0 :::445                  :::*                    LISTEN      0          14203      816/smbd
                    tcp6       0      0 :::139                  :::*                    LISTEN      0          14204      816/smbd
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          15044      537/sshd: /usr/sbin
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13211      662/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17527      1040/io.web.0
                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       16822      1070/io.deconz.1
                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15097      400/deCONZ
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12103      749/dhcpcd
                    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          14181      750/nmbd
                    udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          14180      750/nmbd
                    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          14164      750/nmbd
                    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          14183      750/nmbd
                    udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          14182      750/nmbd
                    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          14165      750/nmbd
                    udp        0      0 0.0.0.0:41316           0.0.0.0:*                           108        14958      394/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14956      394/avahi-daemon: r
                    udp6       0      0 :::1900                 :::*                                1001       16824      1070/io.deconz.1
                    udp6       0      0 :::1900                 :::*                                1001       16823      1070/io.deconz.1
                    udp6       0      0 :::45045                :::*                                108        14959      394/avahi-daemon: r
                    udp6       0      0 :::546                  :::*                                0          13027      749/dhcpcd
                    udp6       0      0 :::5353                 :::*                                108        14957      394/avahi-daemon: r
                    2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
                    2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) login not possible, check user and permissions
                    2023-12-19 14:55:24.974  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1040
                    2023-12-19 14:55:28.042  - info: web.0 (1040) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
                    2023-12-19 14:55:28.584  - info: web.0 (1040) socket.io server listening on port 8082
                    2023-12-19 14:55:28.603  - info: web.0 (1040) http server listening on port 8082
                    2023-12-19 14:55:31.435  - info: vis.0 (1055) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                    2023-12-19 14:55:32.211  - info: vis.0 (1055) Terminated (NO_ERROR): Without reason
                    2023-12-19 14:55:32.794  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
                    2023-12-19 14:55:32.972  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1070
                    2023-12-19 14:55:35.726  - info: deconz.1 (1070) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
                    2023-12-19 14:55:35.883  - info: deconz.1 (1070) deConz Version: 2.24.2; API version: 1.16.0
                    2023-12-19 14:55:36.496  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
                    2023-12-19 14:55:38.641  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1086
                    2023-12-19 14:55:41.025  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1101
                    2023-12-19 14:55:45.888  - info: info.0 (1086) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
                    2023-12-19 14:55:46.253  - info: info.0 (1086) Reading/updating systemdata.
                    2023-12-19 14:55:46.468  - info: iot.0 (1101) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                    2023-12-19 14:55:46.638  - info: iot.0 (1101) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                    2023-12-19 14:55:47.531  - info: iot.0 (1101) Connection changed: connect "s_glebe66_googlemail_com"
                    2023-12-19 14:55:47.731  - info: info.0 (1086) cpu Temp res = {"main":46.251,"cores":[],"max":46.251,"socket":[],"chipset":null}
                    2023-12-19 14:55:49.207  - info: alexa2.0 (987) Subscribing to states...
                    2023-12-19 14:55:49.216  - info: alexa2.0 (987) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                    2023-12-19 14:55:51.087  - info: alexa2.0 (987) Alexa-Push-Connection (macDms = true) established. Disable Polling
                    2023-12-19 14:55:55.552  - info: alexa2.0 (987) Initialization Done ...
                      deconz-init.service
                      Dann musst du mal schauen, was da klemmen könnte.
                      systemctl status deconz*
                        Ergebnis meiner Eingabe!
                        pi@raspberrypismarthome:~ $ systemctl status deconz*
                        Unit deconz-latest-beta.deb.service could not be found.
                          @stephan1966
                          Mal mit beta-Zeuch herumgespielt?
                          apt policy deconz*
                          sagt?
                            Kann mich nicht erinnern, hier das Ergebnis:
                            pi@raspberrypismarthome:~ $ apt policy deconz*
                            N: Paket deconz-latest-beta.deb kann nicht gefunden werden.
                            N: Mittels des Musters »deconz-latest-beta.deb« konnte kein Paket gefunden werden.
                              @stephan1966
                              ls -lAh
                                ls -lAh
                                Ergebnis:
                                pi@raspberrypismarthome:~ $ ls -lAh
                                insgesamt 6,6M
                                drwxr-xr-x 2 root root 4,0K 10. Jan 2023 backup
                                -rw------- 1 pi pi 3,9K 19. Dez 14:54 .bash_history
                                -rw-r--r-- 1 pi pi 220 30. Okt 2021 .bash_logout
                                -rw-r--r-- 1 pi pi 3,7K 18. Dez 12:12 .bashrc
                                drwxr-xr-x 4 pi pi 4,0K 2. Dez 2021 .cache
                                drwx------ 3 pi pi 4,0K 2. Dez 2021 .config
                                -rw-r--r-- 1 pi pi 161K 20. Aug 2021 deCONZ_ConBeeII_0x26720700.bin.GCF
                                -rw-r--r-- 1 pi pi 6,4M 30. Apr 2022 deconz-latest-beta.deb
                                drwxr-xr-x 2 pi pi 4,0K 2. Dez 2021 .iobroker
                                drwxr-xr-x 3 pi pi 4,0K 21. Dez 2021 .local
                                drwxr-xr-x 5 pi pi 4,0K 2. Dez 2021 .npm
                                -rw------- 1 pi pi 36 2. Dez 2021 .npmrc
                                -rw-r--r-- 1 pi pi 807 30. Okt 2021 .profile
                                  Thomas Braun Most Active @Stephan1966 last edited by Thomas Braun
                                  @stephan1966
                                  Das muss da weg:
                                  rm deconz-latest-beta.deb
                                  Und bitte Auszüge aus der Konsole immer in Code Tags setzen. Liest sich besser.
                                    Hier das Ergebnis nachdem ich rm deconz-latest-beta.deb ausgeführt habe: ```
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : armhf
                                     09:35:28 up 2 days, 18:41,  1 user,  load average: 0.07, 0.19, 0.22
                                    CPU threads: 4
                                    Current issues:
                                                   Local time: Fri 2023-12-22 09:35:28 CET
                                               Universal time: Fri 2023-12-22 08:35:28 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            3.8G        803M        2.4G        1.0M        625M        2.9G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        803M        2.5G
                                             3794 M total memory
                                              803 M used memory
                                              883 M active memory
                                              401 M inactive memory
                                             2364 M free memory
                                               90 M buffer memory
                                              535 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    1.9G    /var/
                                    1.1G    /var/log
                                    658M    /var/cache
                                    403M    /opt/iobroker/backups/
                                    333M    /opt/iobroker/iobroker-data/
                                    106M    /opt/iobroker/iobroker-data/backup-objects
                                    28M     /opt/iobroker/iobroker-data/objects.jsonl
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.12.0
                                    javascript:     7.1.6
                                    Adapter State
                                    + instance is alive
                                    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                                    Objects and States
                                    Objects:        2065
                                    States:         1761
                                    Pending Updates: 0
                                    2023-12-22 09:15:38.510  - info: host.raspberrypismarthome stopInstance system.adapter.pushover.0 send kill signal
                                    2023-12-22 09:15:38.738  - info: host.raspberrypismarthome iobroker upload [14] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/blockly.js blockly.js application/javascript
                                    2023-12-22 09:15:38.760  - info: host.raspberrypismarthome iobroker upload [13] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                    2023-12-22 09:15:38.771  - info: host.raspberrypismarthome iobroker upload [12] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                    2023-12-22 09:15:38.781  - info: host.raspberrypismarthome iobroker upload [11] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                    2023-12-22 09:15:38.792  - info: host.raspberrypismarthome iobroker upload [10] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                    2023-12-22 09:15:38.803  - info: host.raspberrypismarthome iobroker upload [9] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                    2023-12-22 09:15:38.815  - info: host.raspberrypismarthome iobroker upload [8] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                    2023-12-22 09:15:38.825  - info: host.raspberrypismarthome iobroker upload [7] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                    2023-12-22 09:15:38.839  - info: host.raspberrypismarthome iobroker upload [6] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                    2023-12-22 09:15:38.852  - info: host.raspberrypismarthome iobroker upload [5] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                    2023-12-22 09:15:38.864  - info: host.raspberrypismarthome iobroker upload [4] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                    2023-12-22 09:15:38.874  - info: host.raspberrypismarthome iobroker upload [3] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/index_m.html index_m.html text/html
                                    2023-12-22 09:15:38.884  - info: host.raspberrypismarthome iobroker upload [2] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/jsonConfig.json jsonConfig.json application/json
                                    2023-12-22 09:15:38.895  - info: host.raspberrypismarthome iobroker upload [1] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/pushover.png pushover.png image/png
                                    2023-12-22 09:15:38.905  - info: host.raspberrypismarthome iobroker upload [0] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/words.js words.js application/javascript
                                    2023-12-22 09:15:38.976  - info: pushover.0 (829) terminating
                                    2023-12-22 09:15:38.978  - info: pushover.0 (829) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2023-12-22 09:15:39.514  - info: host.raspberrypismarthome stopInstance system.adapter.pushover.0 killing pid 829
                                    2023-12-22 09:15:39.611  - info: host.raspberrypismarthome instance system.adapter.pushover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2023-12-22 09:15:39.947  - info: host.raspberrypismarthome iobroker exit 0
                                    2023-12-22 09:15:41.597  - info: host.raspberrypismarthome instance system.adapter.pushover.0 started with pid 17654
                                    2023-12-22 09:15:44.251  - info: pushover.0 (17654) starting. Version 3.0.6 in /opt/iobroker/node_modules/iobroker.pushover, node: v18.19.0, js-controller: 5.0.17
                                    2023-12-22 09:18:40.465  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
                                    2023-12-22 09:18:43.110  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                      @stephan1966
                                      wirft jetzt was raus?
                                        @thomas-braun ```
                                        Copy text starting here:
        v.2023-10-10
                                                 Icon name: computer
                                              Architecture: arm64
                                        Installation:           native
                                        Kernel:                 aarch64
                                        Userland:               armhf
                                        Timezone:               Europe/Berlin (CET, +0100)
                                        User-ID:                1000
                                        X-Server:               false
                                        Pending OS-Updates:     0
                                        Pending iob updates:    0
                                        Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
                                        Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                        MEMORY:
                                        Mem:            3.8G        848M        2.3G        1.0M        626M        2.9G
                                        Swap:            99M          0B         99M
                                        Total:          3.9G        848M        2.4G
                                        Active iob-Instances:   15
                                        ioBroker Core:          js-controller           5.0.17
        admin                   6.12.0
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                2065
                                        States:                 1761
                                        Size of iob-Database:
                                        6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
                                        6.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                        6.8M    /opt/iobroker/iobroker-data/states.jsonl
                                        488K    /opt/iobroker/iobroker-data/states.json.migrated
                                        488K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                        0       /opt/iobroker/iobroker-data/states.json.broken
                                          @thomas-braun ```
                                          === Mark text until here for copying ===
                                          ● deconz-update.service - deCONZ: ZigBee gateway -- Update Service
                                               Loaded: loaded (/lib/systemd/system/deconz-update.service; disabled; vendor preset: enabled)
                                               Active: failed (Result: exit-code) since Tue 2023-12-19 14:54:22 CET; 2 days ago
                                              Process: 542 ExecStart=/usr/bin/deCONZ-update2.sh (code=exited, status=203/EXEC)
                                             Main PID: 542 (code=exited, status=203/EXEC)
                                                  CPU: 3ms
                                          Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-update.service: Scheduled restart job, restart counter is at 5.
                                          Dez 19 14:54:22 raspberrypismarthome systemd[1]: Stopped deCONZ: ZigBee gateway -- Update Service.
                                          Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-update.service: Start request repeated too quickly.
                                          Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-update.service: Failed with result 'exit-code'.
                                          Dez 19 14:54:22 raspberrypismarthome systemd[1]: Failed to start deCONZ: ZigBee gateway -- Update Service.
                                          ● deconz-init.service - deCONZ: ZigBee gateway -- Initialisation
                                               Loaded: loaded (/lib/systemd/system/deconz-init.service; disabled; vendor preset: enabled)
                                               Active: failed (Result: exit-code) since Tue 2023-12-19 14:54:21 CET; 2 days ago
                                              Process: 397 ExecStart=/usr/bin/deCONZ-init.sh (code=exited, status=203/EXEC)
                                             Main PID: 397 (code=exited, status=203/EXEC)
                                                  CPU: 4ms
                                          Dez 19 14:54:21 raspberrypismarthome systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
                                          Dez 19 14:54:21 raspberrypismarthome systemd[397]: deconz-init.service: Failed to locate executable /usr/bin/deCONZ-init.sh: No such file or directory
                                          Dez 19 14:54:21 raspberrypismarthome systemd[397]: deconz-init.service: Failed at step EXEC spawning /usr/bin/deCONZ-init.sh: No such file or directory
                                          Dez 19 14:54:21 raspberrypismarthome systemd[1]: deconz-init.service: Main process exited, code=exited, status=203/EXEC
                                          Dez 19 14:54:21 raspberrypismarthome systemd[1]: deconz-init.service: Failed with result 'exit-code'.
                                          Dez 19 14:54:21 raspberrypismarthome systemd[1]: Failed to start deCONZ: ZigBee gateway -- Initialisation.
                                          ● deconz-wifi.service - deCONZ: ZigBee gateway -- WIFI Service
                                               Loaded: loaded (/lib/systemd/system/deconz-wifi.service; enabled; vendor preset: enabled)
                                              Process: 547 ExecStart=/usr/bin/deCONZ-WIFI2.sh (code=exited, status=203/EXEC)
                                             Main PID: 547 (code=exited, status=203/EXEC)
                                                  CPU: 2ms
                                          Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-wifi.service: Scheduled restart job, restart counter is at 5.
                                          Dez 19 14:54:22 raspberrypismarthome systemd[1]: Stopped deCONZ: ZigBee gateway -- WIFI Service.
                                          Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-wifi.service: Start request repeated too quickly.
                                          Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-wifi.service: Failed with result 'exit-code'.
                                          Dez 19 14:54:22 raspberrypismarthome systemd[1]: Failed to start deCONZ: ZigBee gateway -- WIFI Service.
                                          ● deconz.service - deCONZ: ZigBee gateway -- REST API
                                               Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: enabled)
                                               Active: active (running) since Tue 2023-12-19 14:54:21 CET; 2 days ago
                                             Main PID: 400 (deCONZ)
                                                Tasks: 6 (limit: 3933)
                                                  CPU: 55min 35.525s
                                               CGroup: /system.slice/deconz.service
                                                       └─400 /usr/bin/deCONZ -platform minimal --http-port=80
                                          Dez 19 14:54:21 raspberrypismarthome systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
                                          Dez 19 14:54:22 raspberrypismarthome deCONZ[400]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
                                          Dez 19 14:54:23 raspberrypismarthome deCONZ[400]: libpng warning: iCCP: known incorrect sRGB profile
                                          Dez 19 14:54:25 raspberrypismarthome deCONZ[400]: This plugin does not support propagateSizeHints()
                                          Dez 19 14:54:28 raspberrypismarthome deCONZ[400]: This plugin does not support propagateSizeHints()
                                            ls -lAh /usr/bin/deCONZ-WIFI2.sh
                                            ls -lAh /usr/bin/deCONZ-update2.sh
                                            2858
