    4. [SCRIPT] Grafana-Dashboards in VIS
      dna909 last edited by
      Moin,
      hier mal ein kleines Script, um Snapshots von Grafana in VIS einzubinden.
      Vielleicht ist es ja für den einen oder anderen nützlich, oder dient zumindest als Vorlage/Anregung….
      ////*** GrafanaStats VIS *** //////////////////////////////////////////////////
      ////V0.1 initial
      ////V0.2 Delete Snapshot hinzugefügt
      ////////////// CONFIG //////////////////////////////////////////////////////////
      ! const apiKey = "API-KEY GRAFANA";
      const grafanaIP = "192.168.0.46";
      const grafanaPort = "3000";
      const protocol = "http";
      const user = "GRAFANA-USER";
      const pass = "GRAFANA-PASSWORT";
      ! let request = require("request");
      let deleteUrl = "";
      const path = "javascript.0.Grafana.";
      const dashboardUrl = path+"DashboardURL"; //Datenpunkt der die Snapshot-URL enthält
      const dashboardName = path+"DashboardName"; //Datenpunkt um den Dashboardnamen zu übergeben
      const grafanaUrl = protocol + "://" + grafanaIP + ":" + grafanaPort;
      const dashData = grafanaUrl+"/api/dashboards/db/";
      const dashGet = grafanaUrl+"/api/snapshots";
      const apiKeyStr = "Bearer " + apiKey;
      ! createAllStates();
      ! on({id: (dashboardName) , change: "ne"}, function (obj) {
      ! if (deleteUrl !== "") {
      deleteSnapshot();
      dashName=getState(dashboardName).val;
      getDashJSON();
      setTimeout(getDashSnapshot,1000);
      ! function deleteSnapshot(){
      console.log("Deleting old Snapshot");
      request(
      { method: 'GET',
      url: deleteUrl,
      headers: {
      'Content-Type': 'application/json'
      function (error, response, body)
      jsonArray=JSON.parse(body);
      console.log("Fehlercode: " + error);
      console.log(JSON.stringify(jsonArray.message));
      ! function getDashJSON(){
      ! request(
      { method: 'GET',
      url: dashData+dashName,
      headers: {
      Authorization: apiKeyStr
      jsonPost='{"dashboard":' + JSON.stringify(jsonArray.dashboard) + ', "expires": 0}';
      ! function getDashSnapshot(){
      request(
      { method: 'POST',
        url: dashGet,
        body: jsonPost,
        headers: {
              'Accept': 'application/json',
              'Content-Type': 'application/json',
      	    'Authorization': apiKeyStr
       snapshotUrl=JSON.stringify(jsonArray.url);
       snapshotUrl=snapshotUrl.replace("localhost",grafanaIP);
       snapshotUrl=snapshotUrl.replace("\"", "");
       console.log("Die URL lautet: " + snapshotUrl);
       setState(dashboardUrl, snapshotUrl);
       deleteUrl=JSON.stringify(jsonArray.deleteUrl);
       deleteUrl=deleteUrl.replace("localhost",grafanaIP);
       deleteUrl=deleteUrl.replace(protocol +"://", protocol + "://" + user + ":" + pass + "@");
       deleteUrl=deleteUrl.replace("\"", "");
       console.log("Die URL zum löschen lautet: " + deleteUrl);
      ! function createAllStates(){
      createState(dashboardUrl, "", {
      desc: 'Dashboard',
      type: 'string',
      role: 'value',
      unit: ''
      ! createState(dashboardName, "", {
      desc: 'Dashboard Name',
      type: 'string',
      role: 'value',
      unit: ''
      2269_grafana.pdf
      dna909
        pix last edited by
        Hallo dna909,
        danke für die Arbeit.
        Ich hab mich mal in Grafana eingearbeitet und es läuft mit influxdb. Die Charts sehen wunderbar aus. Dein Skript erzeugt aber diesen Fehler:
        `2017-11-27 19:27:02.158  - [32minfo[39m: javascript.2 Start javascript script.js.Test.Test_Grafana_dna909
        2017-11-27 19:27:02.162  - [31merror[39m: javascript.2 script.js.Test.Test_Grafana_dna909 compile failed: SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode[/code]`
        Idee?
        Pix
          Hallo Pix
          @pix:
          Ich hab mich mal in Grafana eingearbeitet und es läuft mit influxdb. `
          deshalb hatte ich damals ganz zu Beginn mit influxDB begonnen (da gibt es noch mehr Gründe für).
          Ich bin nämlich auch der Meinung, dass
          @pix:
          Die Charts sehen wunderbar aus `
          Leider habe ich damals es nicht geschafft grafana auf dem Pi2 oder Cubieboard3 zu installieren
          Wie bitte hast du es gemacht.
          Rainer
            @pix:
            Hallo dna909,
            Idee?
            PixHallo pix,
            die Fehlermeldung kannte ich bis heute noch nicht. Könnte aber möglicherweise an Deiner Nodejs-Version liegen. Bei mir läuft es ohne Probleme. Ich habe die Node 6.11.4.
            dna909
              @Homoran:
              Hallo Pix
              @pix:
              @pix:
              Rainer ` Hallo Rainer,
              für meinen odroid u2 mit ubuntu 14.04 hat die Version von hier funktioniert:
              https://bintray.com/fg2it/deb/grafana-o … rry/v4.0.1
              Möglicherweise gehts ja damit auch bei dir.
              dna909
                pix last edited by
                @Homoran:
                Hallo Pix
                @pix:
                @pix:
                Rainer `
                Hallo Rainer,
                ich habe Grafana mit brew auf einem Mac (derzeit OS 10.12.6 Sierra) installiert. Die Dokumentation ist eigentlich sehr gut. Aber nur in Englisch. Schließlich gibt es noch viele Youtube-Videos.
                Etwas holperig war die Einrichtung eines Admins ohne WebUI. Da muss man im Terminal mit dem nano-Editor eine Config-Datei bearbeiten (so wie später auch für dieses Projekt hier).
                Ich habe auch nicht soviel auf die ganze Struktur gegeben. Es gibt einen Admin und eine Organization und gut ist. Das wird mir zuviel sonst.
                Wenn die Datenpunkte in InfluxDB geloggt sind, tauchen sie nach dem korrekten Einrichten der Datenquelle (mit Adresse, Name der influx-DB, User, Pass) auch auf und können angezeigt werden.
                Bin jetzt kein Experte, aber wo hakt es denn?
                Pix
                  pix last edited by
                  @dna909:
                  @pix:
                  Hallo dna909,
                  Idee?
                  PixHallo pix,
                  dna909
                  Hallo dna909,
                  [https://github.com/JeffreyWay/laravel-mix/issues/264](https://github.com/JeffreyWay/laravel-mix/issues/264). Mit nodejs 4.8.4 komme ich wohl nicht mehr sehr lange weiter. Ich sollte mal auf 6.x gehen. Allerdings ist das Upgrade am Mac zwar schnell gemacht, aber nicht so trivial wieder entfernt, wenn etwas schiefgeht oder andere Effekte auftreten. Mal sehen...
                  Pix
                    @pix:
                    @dna909:
                    @pix:
                    Hallo dna909,
                    Idee?
                    PixHallo pix,
                    dna909
                    Hallo dna909,
                    Pix
                    Vielleicht hilft es auch erstmal const und let gegen var auszutauschen. Dann müsste das theoretisch auch funktionieren.
                    dna909
                      pix last edited by
                      Gute Idee,
                      const nutze ich auch in anderen Skripten.
                      let könnte das Problem sein.
                      Werde berichten.
                      Pix
                        pix last edited by
                        Hallo dna909,
                        ich habe das Skript etwas für mich angepasst. Jetzt klappt alles!
                        Tatasächlich startet es erstmal fehlerlos, wenn man let gegen var austauscht (2x).
                        Ich habe ausserdem ein wenig verschönert (Leerzeilen, Tabs, Kommentare)
                        Hier meine Version:
                        ! /* GrafanaStats VIS ! V0.1 initial V0.2 Delete Snapshot hinzugefügt ! von dna909 28.11.2017 code angepasst ! http://forum.iobroker.net/viewtopic.php?f=21&t=9249 */ ! // CONFIG const apiKey = "XXXXXXXXXXXX"; const grafanaIP = "192.168.XXX.XXX"; const grafanaPort = "3000"; const protocol = "http"; const user = "XXXX"; const pass = "XXXX"; ! // ab hier nix mehr ändern var request = require("request"); var deleteUrl = ""; const path = "javascript." + instance + ".Grafana."; const dashboardUrl = path + "DashboardURL"; // Datenpunkt der die Snapshot-URL enthält const dashboardName = path + "DashboardName"; // Datenpunkt um den Dashboardnamen zu übergeben const grafanaUrl = protocol + "://" + grafanaIP + ":" + grafanaPort; const dashData = grafanaUrl + "/api/dashboards/db/"; const dashGet = grafanaUrl + "/api/snapshots"; const apiKeyStr = "Bearer " + apiKey; ! createAllStates(); ! on({ id: (dashboardName), change: "ne" }, function(obj) { if (deleteUrl !== "") { deleteSnapshot(); } dashName = getState(dashboardName).val; getDashJSON(); setTimeout(getDashSnapshot, 1000); }); ! function deleteSnapshot() { log("Deleting old Snapshot"); request({ method: 'GET', url: deleteUrl, headers: { 'Content-Type': 'application/json' } }, function(error, response, body) { jsonArray = JSON.parse(body); log("Fehlercode: " + error); log(JSON.stringify(jsonArray.message)); } ); } ! function getDashJSON() { request({ method: 'GET', url: dashData + dashName, headers: { Authorization: apiKeyStr } }, function(error, response, body) { jsonArray = JSON.parse(body); jsonPost = '{"dashboard":' + JSON.stringify(jsonArray.dashboard) + ', "expires": 0}'; } ); } ! function getDashSnapshot() { request({ method: 'POST', url: dashGet, body: jsonPost, headers: { 'Accept': 'application/json', 'Content-Type': 'application/json', 'Authorization': apiKeyStr } }, function(error, response, body) { jsonArray = JSON.parse(body); snapshotUrl = JSON.stringify(jsonArray.url); snapshotUrl = snapshotUrl.replace("localhost", grafanaIP); snapshotUrl = snapshotUrl.replace("\"", ""); snapshotUrl = snapshotUrl.replace("\"", ""); log("Die URL lautet: " + snapshotUrl); setState(dashboardUrl, snapshotUrl); deleteUrl = JSON.stringify(jsonArray.deleteUrl); deleteUrl = deleteUrl.replace("localhost", grafanaIP); deleteUrl = deleteUrl.replace(protocol + "://", protocol + "://" + user + ":" + pass + "@"); deleteUrl = deleteUrl.replace("\"", ""); deleteUrl = deleteUrl.replace("\"", ""); log("Die URL zum löschen lautet: " + deleteUrl); } ); } ! function createAllStates() { createState(dashboardUrl, "", { name: 'Dashboard', desc: 'Dashboard', type: 'string', role: 'value', unit: '' }); createState(dashboardName, "", { name: 'Dashboard_Name', desc: 'Dashboard Name', type: 'string', role: 'value', unit: '' }); } !
                        Die Objekte werden korrekt angelegt.
                        Wenn ich nun den Namen des Dashboards ("ioBroker") in das Objekt DashboardName schreibe, dann wird mit meinen LoginDaten auf dem Grafana Server ein Snapshot erstellt und der Sharing-URL in den Datenpunkt DashboardURL geschrieben. Damit ist er für ein iframe-Widget in VIS erreichbar. Super!
                        Ein Fallstrick ist der Name des Dahboards. Es sollte noch der schwere Fehler abgefangen werden, wenn der Name des Dashboards falsch ist. Dann stürzt nämlich die ganze JS-Instanz ab.
                        Frage:
                        Wie bekomme ich die Titelzeile aus dem Snapshot (siehe Screenshot).
                        Ich meine nicht den Workaround über die Änderung des Viewports, sondern eine Einstellung in Grafana.
                        Vielen Dank für die tolle Arbeit, dna909.
                        Pix
                          Hi pix,
                          das mit dem Fehler abfangen mach ich noch.
                          Das mit dem Ausblenden der oberen Zeile habe ich auch noch nicht geschafft. Werde mich aber nochmal damit auseinandersetzen. Schön das das Script nun bei dir läuft [emoji3]
                          dna909
                            Hallo pix,
                            ` > Frage:
                            Ich meine nicht den Workaround über die Änderung des Viewports, sondern eine Einstellung in Grafana. `
                            Ist leider nicht möglich, siehe https://github.com/grafana/grafana/issues/7299
                            dna909
                            kotwal13aditya created this issue in grafana/grafana
                            closed [Feature Request] Option to disable dashboard dropdown in nav-bar #7299
                              pix last edited by
                              dann muss ich es doch über diesen Weg probieren:
                              http://forum.iobroker.net/viewtopic.php … 762#p38762
                              (gezeigten iFrame Ausschnitt bestimmen)
                              Ausprobiert:
                              ! HTML-Widget: 261_bildschirmfoto_2017-11-29_um_12.11.02.jpg ````
                              ! <iframe src="{javascript.2.Grafana.DashboardURL}" id="my-iframe" scrolling="no"></iframe>
                              Dieses Widget:
                              [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"\n<iframe src="&quot;{javascript.2.Grafana.DashboardURL}&quot;" id="&quot;my-iframe&quot;" scrolling="&quot;no&quot;"></iframe>\n\n\n\n"},"style":{"left":"89px","top":"1306px","z-index":"25","width":"916px","height":"270px"},"widgetSet":"basic"}]
                              Pix
                              4035
