    4. Linuxneustart nach Systemupdate nicht möglich // Paketupdate
    • Marc Berg
      Marc Berg Most Active @tklein last edited by
      @tklein sagte in Neuer Befehl: "iob nodejs-update":
      iobroker nodejs-update 18.19.0
      Das ist falsch, richtig wäre:
      T 2 Replies Last reply Reply Quote 1
        tklein @mcm1957 last edited by
        @mcm57 ok
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypi-iob
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.103-v7l+
              Architecture: arm
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
         17:37:17 up 30 min,  2 users,  load average: 4.06, 3.35, 2.69
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Mon 2023-12-18 17:37:18 CET
                   Universal time: Mon 2023-12-18 16:37:18 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           3.8G        2.8G        449M        4.0M        562M        1.3G
        Swap:           10G        128M         10G
        Total:          14G        3.0G         10G
                 3837 M total memory
                 2826 M used memory
                  327 M active memory
                 2916 M inactive memory
                  449 M free memory
                   61 M buffer memory
                  501 M swap cache
                10239 M total swap
                  128 M used swap
                10111 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
          UNIT            LOAD   ACTIVE SUB    DESCRIPTION
        * lightdm.service loaded failed failed Light Display Manager
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4      220G   30G  182G  14% /
        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     1.9G  8.6M  1.9G   1% /run
        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
        /dev/sda1      vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
        [Mon Dec 18 17:06:33 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:54:0B:45 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=74cbdb6a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Mon Dec 18 17:06:35 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
        [Mon Dec 18 17:06:35 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Mon Dec 18 17:06:37 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
        TARGET        SOURCE    FSTYPE OPTIONS
        /             /dev/sda2 ext4   rw,noatime
        |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        6.7G    /var/
        1.4G    /var/cache/apt
        1.4G    /var/cache
        1.3G    /var/cache/apt/archives
        1.1G    /var/lib
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        1.9G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.4G    /opt/iobroker/iobroker-data/
        601M    /opt/iobroker/iobroker-data/backup-objects
        551M    /opt/iobroker/iobroker-data/files
        90M     /opt/iobroker/iobroker-data/files/echarts.admin
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        52M     /opt/iobroker/iobroker-data/objects.jsonl
        49M     /opt/iobroker/iobroker-data/states.jsonl
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        27M     /opt/iobroker/iobroker-data/objects.json.migrated
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2219042-if00
        /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A94ZVX1D-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v16.19.0
        /usr/bin/node           v16.19.0
        /usr/bin/npm            8.19.3
        /usr/bin/npx            8.19.3
        /usr/bin/corepack       0.15.1
        nodejs:
          Installed: 16.19.0-deb-1nodesource1
          Candidate: 16.19.0-deb-1nodesource1
          Version table:
         *** 16.19.0-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
         Connection is closed.
        Uncaught Rejection: Error: Objects DB is not allowed to start in the current Multihost environment
            at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:493:23)
            at processTicksAndRejections (node:internal/process/task_queues:96:5)
         Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
         Unable to subscribe to meta namespace "meta." changes: Connection is closed.
        Core adapters versions
        js-controller:  5.0.16
        admin:          6.12.0
        javascript:     7.1.6
        Adapters from github:   5
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : raspberrypi-iob                          -  enabled
        + system.adapter.admin.0                  : admin                 : raspberrypi-iob                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi-iob                          -  enabled
          system.adapter.alias-manager.0          : alias-manager         : raspberrypi-iob                          -  enabled
          system.adapter.apple-find-me.0          : apple-find-me         : raspberrypi-iob                          - disabled
          system.adapter.apple-find-me.1          : apple-find-me         : raspberrypi-iob                          - disabled
          system.adapter.apple-find-me.2          : apple-find-me         : raspberrypi-iob                          - disabled
        + system.adapter.backitup.0               : backitup              : raspberrypi-iob                          -  enabled
          system.adapter.bmw.0                    : bmw                   : raspberrypi-iob                          - disabled
          system.adapter.bmw.1                    : bmw                   : raspberrypi-iob                          - disabled
          system.adapter.bring.0                  : bring                 : raspberrypi-iob                          - disabled
        + system.adapter.broadlink2.0             : broadlink2            : raspberrypi-iob                          -  enabled
        + system.adapter.cloud.0                  : cloud                 : raspberrypi-iob                          -  enabled
          system.adapter.coronavirus-statistics.0 : coronavirus-statistics: raspberrypi-iob                          - disabled
          system.adapter.daswetter.0              : daswetter             : raspberrypi-iob                          - disabled
          system.adapter.device-reminder.0        : device-reminder       : raspberrypi-iob                          - disabled
          system.adapter.device-watcher.0         : device-watcher        : raspberrypi-iob                          - disabled
          system.adapter.devices.0                : devices               : raspberrypi-iob                          -  enabled
          system.adapter.discovery.0              : discovery             : raspberrypi-iob                          - disabled
          system.adapter.dwd.0                    : dwd                   : raspberrypi-iob                          -  enabled
        + system.adapter.echarts.0                : echarts               : raspberrypi-iob                          -  enabled
        + system.adapter.email.0                  : email                 : raspberrypi-iob                          -  enabled
        + system.adapter.enigma2.1                : enigma2               : raspberrypi-iob                          -  enabled
          system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi-iob                          - disabled
          system.adapter.feiertage.0              : feiertage             : raspberrypi-iob                          -  enabled
        + system.adapter.fhem.0                   : fhem                  : raspberrypi-iob                          -  enabled, port: 7072
        + system.adapter.firetv.0                 : firetv                : raspberrypi-iob                          -  enabled
          system.adapter.flot.0                   : flot                  : raspberrypi-iob                          -  enabled
          system.adapter.followthesun.0           : followthesun          : raspberrypi-iob                          - disabled
          system.adapter.geofency.0               : geofency              : raspberrypi-iob                          - disabled, port: 7999, bind: 0.0.0.0
          system.adapter.govee.0                  : govee                 : raspberrypi-iob                          - disabled
          system.adapter.habpanel.0               : habpanel              : raspberrypi-iob                          -  enabled
        + system.adapter.ham.0                    : ham                   : raspberrypi-iob                          -  enabled
          system.adapter.history.0                : history               : raspberrypi-iob                          - disabled
        + system.adapter.homeconnect.0            : homeconnect           : raspberrypi-iob                          -  enabled
          system.adapter.homekit-controller.0     : homekit-controller    : raspberrypi-iob                          - disabled
          system.adapter.ical.0                   : ical                  : raspberrypi-iob                          -  enabled
          system.adapter.ico-cloud.0              : ico-cloud             : raspberrypi-iob                          -  enabled
        + system.adapter.influxdb.0               : influxdb              : raspberrypi-iob                          -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : raspberrypi-iob                          -  enabled
        + system.adapter.iot.1                    : iot                   : raspberrypi-iob                          -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi-iob                          -  enabled
          system.adapter.labcom.0                 : labcom                : raspberrypi-iob                          -  enabled
        + system.adapter.linkeddevices.0          : linkeddevices         : raspberrypi-iob                          -  enabled
        + system.adapter.linux-control.0          : linux-control         : raspberrypi-iob                          -  enabled
          system.adapter.meater.0                 : meater                : raspberrypi-iob                          - disabled
          system.adapter.meross.0                 : meross                : raspberrypi-iob                          - disabled
          system.adapter.milight-smart-light.0    : milight-smart-light   : raspberrypi-iob                          - disabled
          system.adapter.milight-smart-light.2    : milight-smart-light   : raspberrypi-iob                          - disabled
          system.adapter.milight-smart-light.3    : milight-smart-light   : raspberrypi-iob                          - disabled
          system.adapter.milight-smart-light.4    : milight-smart-light   : raspberrypi-iob                          - disabled
        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi-iob                          -  enabled, port: 1888, bind: 192.168.0.20
        + system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi-iob                          -  enabled
        + system.adapter.nina.0                   : nina                  : raspberrypi-iob                          -  enabled
          system.adapter.openweathermap.0         : openweathermap        : raspberrypi-iob                          - disabled
          system.adapter.parcel.0                 : parcel                : raspberrypi-iob                          - disabled
          system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi-iob                          - disabled
        + system.adapter.ping.0                   : ping                  : raspberrypi-iob                          -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : raspberrypi-iob                          -  enabled
        + system.adapter.pushover.0               : pushover              : raspberrypi-iob                          -  enabled
        + system.adapter.reolink.0                : reolink               : raspberrypi-iob                          -  enabled
          system.adapter.ring.0                   : ring                  : raspberrypi-iob                          - disabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi-iob                          -  enabled
          system.adapter.sayit.0                  : sayit                 : raspberrypi-iob                          - disabled
          system.adapter.schoolfree.0             : schoolfree            : raspberrypi-iob                          -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi-iob                          -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : raspberrypi-iob                          -  enabled, port: 1889, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : raspberrypi-iob                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi-iob                          - disabled
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi-iob                          -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.sonos.0                  : sonos                 : raspberrypi-iob                          - disabled
          system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi-iob                          - disabled
          system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi-iob                          - disabled
          system.adapter.sql.0                    : sql                   : raspberrypi-iob                          - disabled, port: 3306
          system.adapter.systeminfo.0             : systeminfo            : raspberrypi-iob                          - disabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi-iob                          -  enabled
        + system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi-iob                          -  enabled
        + system.adapter.telegram.0               : telegram              : raspberrypi-iob                          -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.terminal.0               : terminal              : raspberrypi-iob                          - disabled, port: 8089, bind: 192.168.0.20, run as: admin
          system.adapter.text2command.0           : text2command          : raspberrypi-iob                          - disabled
          system.adapter.tr-064.0                 : tr-064                : raspberrypi-iob                          - disabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi-iob                          -  enabled
        + system.adapter.tuya.0                   : tuya                  : raspberrypi-iob                          -  enabled
        + system.adapter.twinkly.0                : twinkly               : raspberrypi-iob                          -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi-iob                          -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi-iob                          -  enabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi-iob                          - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi-iob                          -  enabled
          system.adapter.vis-weather.0            : vis-weather           : raspberrypi-iob                          -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypi-iob                          - disabled
          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi-iob                          - disabled
        + system.adapter.web.0                    : web                   : raspberrypi-iob                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.wled.0                   : wled                  : raspberrypi-iob                          -  enabled
          system.adapter.yahka.0                  : yahka                 : raspberrypi-iob                          - disabled
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi-iob                          -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2219042-if00
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alarm"        : 3.4.3    , installed 3.4.3
        Adapter    "alexa2"       : 3.26.3   , installed 3.25.5 [Updatable]
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Adapter    "bmw"          : 2.5.7    , installed 2.6.3
        Adapter    "bring"        : 1.8.4    , installed 1.8.4
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
        Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
        Adapter    "deconz"       : 1.3.23   , installed 1.3.23
        Adapter    "device-reminder": 3.0.0  , installed 3.0.0
        Adapter    "device-watcher": 2.9.6   , installed 2.9.6
        Adapter    "echarts"      : 1.5.4    , installed 1.5.4
        Adapter    "email"        : 1.2.0    , installed 1.2.0
        Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
        Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "fhem"         : 2.0.5    , installed 2.0.5
        Adapter    "firetv"       : 2.0.2    , installed 2.0.2
        Adapter    "followthesun" : 0.5.0    , installed 0.4.2  [Updatable]
        Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
        Adapter    "geofency"     : 1.2.4    , installed 1.2.4
        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
        Adapter    "homekit-controller": 0.5.8, installed 0.5.8
        Adapter    "ico-cloud"    : 1.1.0    , installed 1.1.0
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.16 [Updatable]
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
        Adapter    "meater"       : 1.0.2    , installed 1.0.2
        Adapter    "meross"       : 1.15.1   , installed 1.15.1
        Adapter    "milight"      : 0.4.0    , installed 0.4.0
        Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "openweathermap": 0.4.5   , installed 0.4.5
        Adapter    "parcel"       : 0.0.27   , installed 0.0.27
        Adapter    "pegelalarm"   : 1.3.1    , installed 1.3.1
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "pushover"     : 3.0.3    , installed 3.0.3
        Adapter    "radar2"       : 2.1.0    , installed 2.1.0
        Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
        Adapter    "rflink"       : 2.1.6    , installed 2.1.6
        Adapter    "ring"         : 5.0.10   , installed 3.2.2  [Updatable]
        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
        Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
        Adapter    "sql"          : 2.2.0    , installed 2.2.0
        Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
        Adapter    "tankerkoenig" : 3.3.7    , installed 2.1.1  [Updatable]
        Adapter    "tapo"         : 0.0.8    , installed 0.0.8
        Adapter    "telegram"     : 3.0.0    , installed 3.0.0
        Adapter    "telegram-menu": 0.8.5    , installed 0.8.5
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "text2command" : 3.0.2    , installed 3.0.2
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "tuya"         : 3.14.2   , installed 3.14.2
        Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
        Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
        Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
        Adapter    "vis-justgage" : 2.0.2    , installed 2.0.2
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "wled"         : 0.7.1    , installed 0.7.1
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
        Objects and States
        Objects:        43653
        States:         37501
        E: The repository 'https://deb.nodesource.com/node_18.19.0.x nodistro Release' does not have a Release file.
        E: Broken packages
        Pending Updates:
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        17345      621/perl
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19631      513/sshd
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18458      436/cupsd
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        19621      493/influxd
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          21635      949/exim4
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       75799      5992/io.sonoff.0
        tcp        0      0 192.168.0.20:1888       0.0.0.0:*               LISTEN      1001       72690      6100/io.mqtt.0
        tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        17371      621/perl
        tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       79161      6178/io.shelly.1
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       73755      5881/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       72866      5881/iobroker.js-co
        tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       76083      6370/adb
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       73796      5899/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       78212      6249/io.web.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      116        21263      493/influxd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          19633      513/sshd
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       77328      6444/io.simple-api.
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18457      436/cupsd
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          21636      949/exim4
        tcp6       0      0 :::3306                 :::*                    LISTEN      115        17155      614/mysqld
        udp        0      0 0.0.0.0:51165           0.0.0.0:*                           1001       77090      6261/io.broadlink2.
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       78167      6051/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       78168      6051/io.tuya.0
        udp        0      0 0.0.0.0:53777           0.0.0.0:*                           1001       96911      8510/python3
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       83026      6018/io.shelly.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18113      437/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18732      487/cups-browsed
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       76985      6261/io.broadlink2.
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       77110      6069/io.ham.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       79008      6552/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16041      428/avahi-daemon: r
        udp        0      0 0.0.0.0:59149           0.0.0.0:*                           108        16043      428/avahi-daemon: r
        udp        0      0 0.0.0.0:59733           0.0.0.0:*                           1001       91594      6261/io.broadlink2.
        udp        0      0 0.0.0.0:51554           0.0.0.0:*                           1001       76325      6261/io.broadlink2.
        udp6       0      0 :::546                  :::*                                0          18303      437/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        16042      428/avahi-daemon: r
        udp6       0      0 :::40783                :::*                                108        16044      428/avahi-daemon: r
        2023-12-18 17:41:15.739  - warn: broadlink2.0 (6261) stateChange error no device found: RM:RMMINI-40-a3-13-kueche {val: true,ack: false,ts: 1702917675326,q: 0,c: 'script.js.common.X-Mas.kuechenlichterketten_led_schalten',from: 'system.adapter.javascript.0',user: 'system.user.admin',lc: 1671365973247}
        2023-12-18 17:41:16.502  - info: host.raspberrypi-iob instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-12-18 17:41:24.977  - error: shelly.1 (6178) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a875ec8"
        2023-12-18 17:41:25.038  - error: shelly.1 (6178) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-c049ef85d2c0"
        2023-12-18 17:41:25.044  - error: shelly.1 (6178) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-ccdba7d07e04"
        2023-12-18 17:41:25.087  - error: shelly.1 (6178) [MQTT] Unable to get mqttprefix of client with id "shellyplus1-b8d61a86c578"
        2023-12-18 17:41:25.094  - error: shelly.1 (6178) [MQTT] Unable to get mqttprefix of client with id "shellyplusi4-fcb467b9454c"
        2023-12-18 17:41:36.670  - error: zigbee.0 (6080) Send command to 0x7cb03eaa00afc418 failed with no error code (no response received (162)
        2023-12-18 17:41:46.653  - error: shelly.1 (6178) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for  (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
        2023-12-18 17:41:46.654  - error: shelly.1 (6178) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-ccdba7d07e04"
        2023-12-18 17:41:57.373  - warn: fhem.0 (6029) CHECK id: fhem.0.info.Info.buildDate
        2023-12-18 17:41:57.381  - warn: fhem.0 (6029) CHECK id: fhem.0.info.Info.roomioBroker
        2023-12-18 17:41:57.382  - warn: fhem.0 (6029) CHECK id: fhem.0.info.Info.numberDevicesFHEM
        2023-12-18 17:41:57.382  - warn: fhem.0 (6029) CHECK id: fhem.0.info.Info.numberDevicesFHEMsync
        2023-12-18 17:41:57.383  - warn: fhem.0 (6029) CHECK id: fhem.0.info.Info.numberObjectsIOBout
        2023-12-18 17:41:57.384  - warn: fhem.0 (6029) CHECK id: fhem.0.info.Info.numberObjectsIOBoutSub
        2023-12-18 17:41:57.385  - warn: fhem.0 (6029) CHECK id: fhem.0.info.Info.numberObjectsIOBin
        2023-12-18 17:41:57.385  - warn: fhem.0 (6029) CHECK id: fhem.0.info.Info.alive
        2023-12-18 17:41:57.386  - warn: fhem.0 (6029) CHECK id: fhem.0.info.Info.numberDevicesFHEMignored
        2023-12-18 17:41:57.387  - warn: fhem.0 (6029) CHECK id: fhem.0.info.Info.lastWarn
        2023-12-18 17:41:57.388  - warn: fhem.0 (6029) CHECK id: fhem.0.info.Info.lastError
        2023-12-18 17:41:57.389  - warn: fhem.0 (6029) CHECK id: fhem.0.info.Info.lastInfo
        2023-12-18 17:41:57.390  - warn: fhem.0 (6029) CHECK id: fhem.0.info.Info.lastSend2ioB
        2023-12-18 17:41:57.390  - warn: fhem.0 (6029) CHECK id: fhem.0.info.Info.lastIOBout
        2023-12-18 17:41:57.480  - warn: fhem.0 (6029) > more info FHEM Adapter visit https://github.com/iobroker-community-adapters/ioBroker.fhem/blob/master/docs/de/README.md
          tklein @Marc Berg last edited by
          @marc-berg thx, probiere ich dann jetzt direkt aus
            @marc-berg das sieht so schon viel besser aus. Allerding sind da auch noch Errors:
            Installing the recommended nodejs version now!
            Exact recommended version unknown, installing a fallback!
            (Reading database ... 126524 files and directories currently installed.)
            Preparing to unpack .../nodejs_18.0.0-1nodesource1_armhf.deb ...
            Detected old npm client, removing...
            Unpacking nodejs (18.0.0-1nodesource1) over (16.19.0-deb-1nodesource1) ...
            Setting up nodejs (18.0.0-1nodesource1) ...
            Processing triggers for man-db (2.8.5-2) ...
            Updating fallback to latest nodejs v18 release
            E: Broken packages
            v18.0.0 has been installed! You are using the latest version now!
            E: Broken packages
            Installing the recommended nodejs version!
            E: Broken packages
            We tried our best to fix your nodejs. Please run iob diag again to verify.
            *** RESTARTING ioBroker NOW! ***
             Please refresh or restart your browser in a few moments.
            pi@raspberrypi-iob:/opt/iobroker $ nodejs -v
            v18.0.0
            Wird die NPM eigentlich nicht auch mit angehoben?
            Wie kann ich die manuell updaten?
            Marc Berg Thomas Braun 2 Replies Last reply Reply Quote 0
            • Marc Berg
              @Thomas-Braun ist der Autor des Scriptes und der Experte. Wenn mich aber nicht alles täuscht, kannst oder musst du bei besonderen Konstellationen das Skript mehrfach ausführen. NPM wird in jedem Fall passend mit angehoben. Nix manuell tun!
                @marc-berg vielen dank dr für die infos!
                  Thomas Braun Most Active @tklein last edited by Thomas Braun
                  Ja, ist aber im Paket 'nodejs' enthalten und darf nicht separat angepackt werden
                  Dein 'buster' ist allerdings tot und muss ersetzt werden, am Besten durch eine komplette NEUINSTALLATION von Raspberry OS 12 'Bookworm' (64bit - Lite).
                  Ein
                  sudo apt update
                  sagt nun was?
                    tklein @Thomas Braun last edited by
                    @thomas-braun said in Neuer Befehl: "iob nodejs-update":
                    sudo apt update
                    sorry für die verspätung:
                    pi@raspberrypi-iob:~ $ sudo apt update
                    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                    Hit:3 https://repos.influxdata.com/debian buster InRelease
                    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Reading package lists... Done
                    Building dependency tree
                    241 packages can be upgraded. Run 'apt list --upgradable' to see them.
                    das system ist so alt, da es jedes mal nicht mehr gestartet ist, nachdem ich das upgrade gestartet ist.
                    hat wohl etwas mit der angeschlossenen ssd platte und der manuellen swapvergrößerung zu tun.
                    leider bin ich ein relativer linux laie. ich musste immer wieder das systembackup einspielen.
                    eigentlich wollte ich auf eine neue hardware umsteigen und das backup auf ein aktuelles system einspielen.
                    so wie mir bekannt, müsste ich leider alle zigbeedevices (ca. 100 stück) neu anlernen. 😞
                      WARUM packt ihr die Systeme eigentlich nie an?
                      Je älter das Zeug wird, desto schwieriger wird das zu unterhalten.
                      'Never toucht irgendwas' ist der allerschlechteste Rat.
                      Bring das Betriebssystem auf den letzten Stand, bring nodejs auf Stand, bring den ioBroker auf Stand und dann ziehst du mit dem ganzen Ding auf ein lebendiges Release. Buster ist nämlich tot.
                      iob stop
                      sudo apt full-upgrade
                      sudo reboot
                      wäre schon mal ein Schritt in die richtige Richtung.
                        @thomas-braun danke dafür. nur bootet der raspi danach nicht mehr. da wurde mal von einem dev op kollegen etwas am system geändert. seitdem klappt es mit dem update nicht mehr. muss dann erst rausfinden, was/wie geändert wurde.
                          @tklein
                          apt full-upgrade -s
                          spuckt was aus?
                            @thomas-braun nein, aber ich wollte ihn damit nicht noch weiter "belästigen"
                              apt full-upgrade -s
                              damit wird aber noch nix installiert, oder?
                                Wildbill @tklein last edited by Wildbill
                                @tklein Nein, das -s hinten bewirkt, dass das nur mal simuliert wird. Dann sieht man, wo bei Dir eventuelle Probleme liegen.
                                Gruss, Jürgen
                                EDIT: Die Ausgabe dann natürlich hier posten. Komplett, von Anfang bis Ende inklusive Eingabezeile und Allem!
                                  tklein @Wildbill last edited by
                                  @wildbill hi jürgen, hier die info:
                                  pi@raspberrypi-iob:~ $ apt full-upgrade -s
                                  NOTE: This is only a simulation!
                                        apt needs root privileges for real execution.
                                        Keep also in mind that locking is deactivated,
                                        so don't depend on the relevance to the real current situation!
                                  Calculating upgrade... Done
                                  The following package was automatically installed and is no longer required:
                                    libdav1d3
                                  Use 'apt autoremove' to remove it.
                                  The following NEW packages will be installed:
                                    libva-wayland2
                                  The following packages will be upgraded:
                                    avahi-daemon bind9-host bluetooth bluez bluez-cups bluez-obexd cpio cups cups-browsed cups-client cups-common cups-core-drivers cups-daemon cups-filters cups-filters-core-drivers cups-ipp-utils cups-ppdc cups-server-common curl dbus
                                    dbus-user-session dbus-x11 distro-info-data exim4-base exim4-config exim4-daemon-light ffmpeg firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek ghostscript git git-man gstreamer1.0-alsa
                                    gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-x influxdb isc-dhcp-client isc-dhcp-common libaom0 libarchive13 libavahi-client-dev libavahi-client3 libavahi-common-data libavahi-common-dev
                                    libavahi-common3 libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libavahi-core7 libavahi-glib1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4 libavutil56 libbind9-161 libbluetooth-dev libbluetooth3
                                    libc-bin libc-dev-bin libc-l10n libc6 libc6-dbg libc6-dev libcups2 libcupsfilters1 libcupsimage2 libcurl3-gnutls libcurl4 libdbus-1-3 libdbus-1-dev libde265-0 libdns-export1104 libdns1104 libdw1 libelf1 libfastjson4 libflac8
                                    libfontembed1 libgnutls-dane0 libgnutls30 libgs9 libgs9-common libgssapi-krb5-2 libgstreamer-gl1.0-0 libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base1.0-0 libisc-export1100 libisc1100 libisccc161 libisccfg163
                                    libjavascriptcoregtk-4.0-18 libk5crypto3 libkrb5-3 libkrb5support0 liblwres161 libmariadb3 libncurses-dev libncurses5-dev libncurses6 libncursesw5 libncursesw5-dev libncursesw6 libnghttp2-14 libnss3 libopenexr23 libpam-systemd
                                    libpcre2-16-0 libpcre2-8-0 libpcre2-posix0 libpoppler-qt5-1 libpoppler82 libpostproc55 libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib libpython3.7 libpython3.7-dev libpython3.7-minimal libpython3.7-stdlib
                                    libqpdf21 librados2 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 librbd1 libsnmp-base libsnmp30 libssh2-1 libssl-dev libssl1.1 libswresample3 libswscale5 libsynctex2 libsystemd0 libtasn1-6 libtcl8.6
                                    libtiff5 libtinfo5 libtinfo6 libudev-dev libudev1 libudisks2-0 libunbound8 libvlc-bin libvlc5 libvlccore9 libvpx5 libwebkit2gtk-4.0-37 libwebp6 libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev libx11-xcb1 libxml2 libxpm4
                                    libzbar0 linux-libc-dev locales mariadb-client mariadb-client-10.3 mariadb-client-core-10.3 mariadb-common mariadb-server mariadb-server-10.3 mariadb-server-core-10.3 multiarch-support ncurses-base ncurses-bin ncurses-term nodejs
                                    openssh-client openssh-server openssh-sftp-server openssl poppler-utils python-cryptography python-flask python-ipaddress python-requests python-urllib3 python-werkzeug python2.7 python2.7-dev python2.7-minimal python3-cryptography
                                    python3-distro-info python3-flask python3-renderpm python3-reportlab python3-reportlab-accel python3-requests python3-urllib3 python3-werkzeug python3.7 python3.7-dev python3.7-minimal python3.7-venv raspberrypi-bootloader
                                    raspberrypi-kernel rpi-eeprom ssh sudo systemd systemd-sysv tcl tcl-dev tcl8.6 tcl8.6-dev tk tk-dev tzdata udev udisks2 vim-common vim-tiny vlc vlc-bin vlc-data vlc-l10n vlc-plugin-base vlc-plugin-notify vlc-plugin-qt
                                    vlc-plugin-samba vlc-plugin-skins2 vlc-plugin-video-output vlc-plugin-video-splitter vlc-plugin-visualization wireless-regdb xserver-common xserver-xorg-core xxd
                                  241 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                  Inst ncurses-bin [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
                                  Conf ncurses-bin (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
                                  Inst libc6-dbg [2.28-10+rpt2+rpi1+deb10u1] (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libc6-dev [2.28-10+rpt2+rpi1+deb10u1] (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libc-dev-bin [2.28-10+rpt2+rpi1+deb10u1] (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst linux-libc-dev [1:1.20220308~buster-1] (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libc6 [2.28-10+rpt2+rpi1+deb10u1] (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libc6 (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Inst libc-bin [2.28-10+rpt2+rpi1+deb10u1] (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libc-bin (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Inst ncurses-base [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [all])
                                  Conf ncurses-base (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [all])
                                  Inst libdbus-1-dev [1.12.24-0+deb10u1] (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf]) []
                                  Inst dbus-user-session [1.12.24-0+deb10u1] (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf]) []
                                  Inst libx11-dev [2:1.6.7-1+deb10u2] (2:1.6.7-1+deb10u4 Raspbian:oldoldstable [armhf]) []
                                  Inst libx11-data [2:1.6.7-1+deb10u2] (2:1.6.7-1+deb10u4 Raspbian:oldoldstable [all]) []
                                  Inst libx11-6 [2:1.6.7-1+deb10u2] (2:1.6.7-1+deb10u4 Raspbian:oldoldstable [armhf]) []
                                  Inst dbus-x11 [1.12.24-0+deb10u1] (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf]) []
                                  Inst dbus [1.12.24-0+deb10u1] (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf]) []
                                  Inst libdbus-1-3 [1.12.24-0+deb10u1] (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst systemd-sysv [241-7~deb10u8+rpi1] (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf])
                                  Inst libpam-systemd [241-7~deb10u8+rpi1] (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf]) []
                                  Inst xserver-common [2:1.20.4-1+rpt4+deb10u6] (2:1.20.4-1+rpt4+deb10u9 Raspberry Pi Foundation:oldoldstable [all]) []
                                  Inst libudev-dev [241-7~deb10u8+rpi1] (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf]) []
                                  Inst libsystemd0 [241-7~deb10u8+rpi1] (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf]) [systemd:armhf ]
                                  Conf libsystemd0 (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf]) [systemd:armhf ]
                                  Inst xserver-xorg-core [2:1.20.4-1+rpt4+deb10u6] (2:1.20.4-1+rpt4+deb10u9 Raspberry Pi Foundation:oldoldstable [armhf]) [systemd:armhf ]
                                  Inst systemd [241-7~deb10u8+rpi1] (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf]) []
                                  Inst bluez [5.50-1.2~deb10u3+rpt1] (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf]) []
                                  Inst udev [241-7~deb10u8+rpi1] (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf]) []
                                  Inst libudev1 [241-7~deb10u8+rpi1] (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf])
                                  Conf libudev1 (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf])
                                  Inst libdw1 [0.176-1.1] (0.176-1.1+deb10u1 Raspbian:oldoldstable [armhf]) []
                                  Inst libelf1 [0.176-1.1] (0.176-1.1+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst libunbound8 [1.9.0-2+deb10u2] (1.9.0-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Inst libgnutls-dane0 [3.6.7-4+deb10u9] (3.6.7-4+deb10u11 Raspbian:oldoldstable [armhf]) []
                                  Inst libtasn1-6 [4.13-3] (4.13-3+deb10u1 Raspbian:oldoldstable [armhf]) []
                                  Conf libtasn1-6 (4.13-3+deb10u1 Raspbian:oldoldstable [armhf]) []
                                  Inst libgnutls30 [3.6.7-4+deb10u9] (3.6.7-4+deb10u11 Raspbian:oldoldstable [armhf])
                                  Conf libgnutls30 (3.6.7-4+deb10u11 Raspbian:oldoldstable [armhf])
                                  Inst mariadb-common [1:10.3.36-0+deb10u2] (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [all])
                                  Inst mariadb-server-core-10.3 [1:10.3.36-0+deb10u2] (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst libncurses6 [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf]) [libncurses-dev:armhf ]
                                  Inst libncurses5-dev [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf]) [libncurses-dev:armhf ]
                                  Inst libncursesw5-dev [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf]) [libncurses-dev:armhf ]
                                  Inst libncurses-dev [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf]) []
                                  Inst libtinfo6 [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf]) [libncursesw6:armhf ]
                                  Conf libtinfo6 (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf]) [libncursesw6:armhf ]
                                  Inst libncursesw6 [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
                                  Conf libncursesw6 (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
                                  Inst mariadb-client-core-10.3 [1:10.3.36-0+deb10u2] (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst mariadb-client-10.3 [1:10.3.36-0+deb10u2] (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf mariadb-common (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [all])
                                  Inst mariadb-server-10.3 [1:10.3.36-0+deb10u2] (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst python2.7-dev [2.7.16-2+deb10u1] (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf]) []
                                  Inst libpython2.7-dev [2.7.16-2+deb10u1] (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf]) []
                                  Inst libpython2.7 [2.7.16-2+deb10u1] (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf]) []
                                  Inst python2.7 [2.7.16-2+deb10u1] (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf]) []
                                  Inst libpython2.7-stdlib [2.7.16-2+deb10u1] (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf]) []
                                  Inst python2.7-minimal [2.7.16-2+deb10u1] (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf]) []
                                  Inst libpython2.7-minimal [2.7.16-2+deb10u1] (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Inst libssl-dev [1.1.1n-0+deb10u3] (1.1.1n-0+deb10u6 Raspbian:oldoldstable [armhf]) []
                                  Inst libssl1.1 [1.1.1n-0+deb10u3] (1.1.1n-0+deb10u6 Raspbian:oldoldstable [armhf])
                                  Inst python3.7-dev [3.7.3-2+deb10u4] (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf]) []
                                  Inst libpython3.7-dev [3.7.3-2+deb10u4] (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf]) []
                                  Inst libpython3.7 [3.7.3-2+deb10u4] (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf]) []
                                  Inst python3.7-venv [3.7.3-2+deb10u4] (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf]) []
                                  Inst python3.7 [3.7.3-2+deb10u4] (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf]) []
                                  Inst libpython3.7-stdlib [3.7.3-2+deb10u4] (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf]) []
                                  Inst python3.7-minimal [3.7.3-2+deb10u4] (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf]) []
                                  Inst libpython3.7-minimal [3.7.3-2+deb10u4] (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
                                  Inst git-man [1:2.20.1-2+deb10u6] (1:2.20.1-2+deb10u8 Raspbian:oldoldstable [all])
                                  Inst libgssapi-krb5-2 [1.17-3+deb10u5] (1.17-3+deb10u6 Raspbian:oldoldstable [armhf]) []
                                  Inst libkrb5-3 [1.17-3+deb10u5] (1.17-3+deb10u6 Raspbian:oldoldstable [armhf]) []
                                  Inst libkrb5support0 [1.17-3+deb10u5] (1.17-3+deb10u6 Raspbian:oldoldstable [armhf])
                                  Inst libk5crypto3 [1.17-3+deb10u5] (1.17-3+deb10u6 Raspbian:oldoldstable [armhf])
                                  Inst libnghttp2-14 [1.36.0-2+deb10u1] (1.36.0-2+deb10u2 Raspbian:oldoldstable [armhf])
                                  Inst libssh2-1 [1.8.0-2.1] (1.8.0-2.1+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst libcurl3-gnutls [7.64.0-4+deb10u3] (7.64.0-4+deb10u8 Raspbian:oldoldstable [armhf])
                                  Inst libpcre2-8-0 [10.32-5] (10.32-5+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst git [1:2.20.1-2+deb10u6] (1:2.20.1-2+deb10u8 Raspbian:oldoldstable [armhf])
                                  Inst openssh-sftp-server [1:7.9p1-10+deb10u2+rpt1] (1:7.9p1-10+deb10u3 Raspbian:oldoldstable [armhf]) []
                                  Inst openssh-server [1:7.9p1-10+deb10u2+rpt1] (1:7.9p1-10+deb10u3 Raspbian:oldoldstable [armhf]) []
                                  Inst openssh-client [1:7.9p1-10+deb10u2+rpt1] (1:7.9p1-10+deb10u3 Raspbian:oldoldstable [armhf])
                                  Inst ssh [1:7.9p1-10+deb10u2+rpt1] (1:7.9p1-10+deb10u3 Raspbian:oldoldstable [all])
                                  Inst tzdata [2021a-0+deb10u8] (2021a-0+deb10u12 Raspbian:oldoldstable [all])
                                  Inst cpio [2.12+dfsg-9] (2.12+dfsg-9+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst libisc-export1100 [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
                                  Inst libdns-export1104 [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
                                  Inst isc-dhcp-client [4.4.1-2+deb10u2] (4.4.1-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Inst isc-dhcp-common [4.4.1-2+deb10u2] (4.4.1-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Inst vim-tiny [2:8.1.0875-5+deb10u4] (2:8.1.0875-5+deb10u6 Raspbian:oldoldstable [armhf]) []
                                  Inst xxd [2:8.1.0875-5+deb10u4] (2:8.1.0875-5+deb10u6 Raspbian:oldoldstable [armhf]) []
                                  Inst vim-common [2:8.1.0875-5+deb10u4] (2:8.1.0875-5+deb10u6 Raspbian:oldoldstable [all])
                                  Inst libxml2 [2.9.4+dfsg1-7+deb10u5] (2.9.4+dfsg1-7+deb10u6 Raspbian:oldoldstable [armhf])
                                  Inst bind9-host [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf]) []
                                  Inst libbind9-161 [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf]) []
                                  Inst libisccfg163 [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf]) []
                                  Inst libisccc161 [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf]) []
                                  Inst libdns1104 [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf]) []
                                  Inst libisc1100 [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf]) []
                                  Inst liblwres161 [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
                                  Inst libc-l10n [2.28-10+rpt2+rpi1+deb10u1] (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [all])
                                  Inst locales [2.28-10+rpt2+rpi1+deb10u1] (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [all])
                                  Inst ncurses-term [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [all])
                                  Inst libavahi-common-dev [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf]) []
                                  Inst libavahi-common-data [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf]) []
                                  Inst libavahi-common3 [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Inst libavahi-core7 [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Inst avahi-daemon [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Inst bluetooth [5.50-1.2~deb10u3+rpt1] (5.50-1.2~deb10u4 Raspbian:oldoldstable [all])
                                  Inst libcupsimage2 [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf]) []
                                  Inst libavahi-client-dev [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf]) []
                                  Inst libavahi-client3 [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf]) []
                                  Inst cups-ipp-utils [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf]) []
                                  Inst cups-daemon [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf]) []
                                  Inst cups-core-drivers [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf]) []
                                  Inst cups-server-common [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [all]) []
                                  Inst cups-common [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [all]) []
                                  Inst cups-client [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf]) []
                                  Inst cups [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf]) []
                                  Inst libcups2 [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
                                  Inst libwebp6 [0.6.1-2+deb10u1] (0.6.1-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Inst libtiff5 [4.1.0+git191117-2~deb10u4] (4.1.0+git191117-2~deb10u8 Raspbian:oldoldstable [armhf])
                                  Inst libcupsfilters1 [1.21.6-5+rpt1] (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Inst libpoppler-qt5-1 [0.71.0-5+deb10u1] (0.71.0-5+deb10u3 Raspbian:oldoldstable [armhf]) []
                                  Inst poppler-utils [0.71.0-5+deb10u1] (0.71.0-5+deb10u3 Raspbian:oldoldstable [armhf]) []
                                  Inst libnss3 [2:3.42.1-1+deb10u5] (2:3.42.1-1+deb10u7 Raspbian:oldoldstable [armhf]) []
                                  Inst libpoppler82 [0.71.0-5+deb10u1] (0.71.0-5+deb10u3 Raspbian:oldoldstable [armhf])
                                  Inst libqpdf21 [8.4.0-2] (8.4.0-2+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst cups-filters-core-drivers [1.21.6-5+rpt1] (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Inst ghostscript [9.27~dfsg-2+deb10u6] (9.27~dfsg-2+deb10u9 Raspbian:oldoldstable [armhf]) []
                                  Inst libgs9 [9.27~dfsg-2+deb10u6] (9.27~dfsg-2+deb10u9 Raspbian:oldoldstable [armhf]) []
                                  Inst libgs9-common [9.27~dfsg-2+deb10u6] (9.27~dfsg-2+deb10u9 Raspbian:oldoldstable [all])
                                  Inst libavahi-glib1 [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Inst cups-browsed [1.21.6-5+rpt1] (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Inst libfontembed1 [1.21.6-5+rpt1] (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Inst cups-filters [1.21.6-5+rpt1] (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Inst cups-ppdc [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
                                  Inst bluez-cups [5.50-1.2~deb10u3+rpt1] (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf])
                                  Inst bluez-obexd [5.50-1.2~deb10u3+rpt1] (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf])
                                  Inst curl [7.64.0-4+deb10u7] (7.64.0-4+deb10u8 Raspbian:oldoldstable [armhf]) []
                                  Inst libcurl4 [7.64.0-4+deb10u7] (7.64.0-4+deb10u8 Raspbian:oldoldstable [armhf])
                                  Inst distro-info-data [0.41+deb10u6] (0.41+deb10u8 Raspbian:oldoldstable [all])
                                  Inst exim4-config [4.92-8+deb10u7] (4.92-8+deb10u8 Raspbian:oldoldstable [all])
                                  Inst exim4-base [4.92-8+deb10u7] (4.92-8+deb10u8 Raspbian:oldoldstable [armhf])
                                  Inst exim4-daemon-light [4.92-8+deb10u7] (4.92-8+deb10u8 Raspbian:oldoldstable [armhf])
                                  Inst ffmpeg [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libavdevice58 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libavfilter7 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libswscale5 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libavformat58 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libavcodec58 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libswresample3 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libpostproc55 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libavresample4 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libavutil56 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libraspberrypi-bin [1:1.20220308~buster-1] (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libraspberrypi-doc [1:1.20220308~buster-1] (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libraspberrypi-dev [1:1.20220308~buster-1] (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst raspberrypi-kernel [1:1.20220308~buster-1] (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libraspberrypi0 [1:1.20220308~buster-1] (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst raspberrypi-bootloader [1:1.20220308~buster-1] (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libaom0 [1.0.0-3] (1.0.0-3+deb10u1 Raspbian:oldoldstable [armhf]) []
                                  Inst libvpx5 [1.7.0-3+deb10u1] (1.7.0-3+deb10u2 Raspbian:oldoldstable [armhf]) []
                                  Inst libwebpmux3 [0.6.1-2+deb10u1] (0.6.1-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Inst firmware-atheros [1:20190114-2+rpt4] (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
                                  Inst firmware-brcm80211 [1:20190114-2+rpt4] (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
                                  Inst firmware-libertas [1:20190114-2+rpt4] (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
                                  Inst firmware-misc-nonfree [1:20190114-2+rpt4] (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
                                  Inst firmware-realtek [1:20190114-2+rpt4] (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
                                  Inst libgstreamer-plugins-base1.0-0 [1.14.4-2+deb10u1] (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
                                  Inst gstreamer1.0-alsa [1.14.4-2+deb10u1] (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
                                  Inst libflac8 [1.3.2-3+deb10u2] (1.3.2-3+deb10u3 Raspbian:oldoldstable [armhf])
                                  Inst gstreamer1.0-plugins-base [1.14.4-2+deb10u1] (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
                                  Inst gstreamer1.0-plugins-bad [1.14.4-1+rvt+deb10u2] (1.14.4-1+rvt+deb10u5 Raspbian:oldoldstable [armhf]) []
                                  Inst gstreamer1.0-plugins-good [1.14.4-1+rpt1+deb10u2] (1.14.4-1+rpt1+deb10u3 Raspberry Pi Foundation:oldoldstable [armhf]) []
                                  Inst libde265-0 [1.0.3-1+rpi1+deb10u1] (1.0.11-0+deb10u5+rpi1 Raspbian:oldoldstable [armhf]) []
                                  Inst libx11-xcb1 [2:1.6.7-1+deb10u2] (2:1.6.7-1+deb10u4 Raspbian:oldoldstable [armhf]) []
                                  Inst libgstreamer-gl1.0-0 [1.14.4-2+deb10u1] (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf]) []
                                  Inst libgstreamer-plugins-bad1.0-0 [1.14.4-1+rvt+deb10u2] (1.14.4-1+rvt+deb10u5 Raspbian:oldoldstable [armhf])
                                  Inst libopenexr23 [2.2.1-4.1+deb10u1] (2.2.1-4.1+deb10u2 Raspbian:oldoldstable [armhf])
                                  Inst libzbar0 [0.22-1] (0.22-1+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst gstreamer1.0-x [1.14.4-2+deb10u1] (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
                                  Inst libarchive13 [3.3.3-4+deb10u2] (3.3.3-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Inst libavahi-compat-libdnssd-dev [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf]) []
                                  Inst libavahi-compat-libdnssd1 [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Inst libbluetooth-dev [5.50-1.2~deb10u3+rpt1] (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf]) []
                                  Inst libbluetooth3 [5.50-1.2~deb10u3+rpt1] (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf])
                                  Inst libfastjson4 [0.99.8-2] (0.99.8-2+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst libwebpdemux2 [0.6.1-2+deb10u1] (0.6.1-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Inst libwebkit2gtk-4.0-37 [2.38.2-1~deb10u1+rpi1] (2.38.6-0+deb10u1+rpi1 Raspbian:oldoldstable [armhf]) []
                                  Inst libjavascriptcoregtk-4.0-18 [2.38.2-1~deb10u1+rpi1] (2.38.6-0+deb10u1+rpi1 Raspbian:oldoldstable [armhf])
                                  Inst libmariadb3 [1:10.3.36-0+deb10u2] (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst libncursesw5 [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf]) []
                                  Inst libtinfo5 [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
                                  Inst libpcre2-16-0 [10.32-5] (10.32-5+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst libpcre2-posix0 [10.32-5] (10.32-5+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst librbd1 [12.2.11+dfsg1-2.1+rpi1] (12.2.11+dfsg1-2.1+rpi1+deb10u1 Raspbian:oldoldstable [armhf]) []
                                  Inst librados2 [12.2.11+dfsg1-2.1+rpi1] (12.2.11+dfsg1-2.1+rpi1+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst libsnmp-base [5.7.3+dfsg-5+deb10u3] (5.7.3+dfsg-5+deb10u4 Raspbian:oldoldstable [all])
                                  Inst libsnmp30 [5.7.3+dfsg-5+deb10u3] (5.7.3+dfsg-5+deb10u4 Raspbian:oldoldstable [armhf])
                                  Inst libsynctex2 [2018.20181218.49446-1] (2018.20181218.49446-1+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst tcl [8.6.9+1] (8.6.9+1+b1 Raspbian:oldoldstable [armhf])
                                  Inst tcl8.6 [8.6.9+dfsg-2] (8.6.9+dfsg-2+b1 Raspbian:oldoldstable [armhf])
                                  Inst tcl8.6-dev [8.6.9+dfsg-2] (8.6.9+dfsg-2+b1 Raspbian:oldoldstable [armhf]) []
                                  Inst libtcl8.6 [8.6.9+dfsg-2] (8.6.9+dfsg-2+b1 Raspbian:oldoldstable [armhf])
                                  Inst libudisks2-0 [2.8.1-4] (2.8.1-4+deb10u2 Raspbian:oldoldstable [armhf])
                                  Inst libva-wayland2 (2.4.0-1 Raspbian:oldoldstable [armhf])
                                  Inst libvlccore9 [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst vlc-plugin-skins2 [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf]) []
                                  Inst vlc [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf]) []
                                  Inst vlc-plugin-qt [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf]) []
                                  Inst libxpm4 [1:3.5.12-1] (1:3.5.12-1+deb10u2 Raspbian:oldoldstable [armhf]) []
                                  Inst vlc-plugin-video-output [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf]) []
                                  Inst vlc-l10n [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [all]) []
                                  Inst vlc-plugin-base [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf]) []
                                  Inst vlc-data [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [all]) []
                                  Inst libvlc5 [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf]) []
                                  Inst vlc-bin [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf]) []
                                  Inst libvlc-bin [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst mariadb-client [1:10.3.36-0+deb10u2] (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [all])
                                  Inst mariadb-server [1:10.3.36-0+deb10u2] (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [all])
                                  Inst multiarch-support [2.28-10+rpt2+rpi1+deb10u1] (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Inst nodejs [18.0.0-1nodesource1] (18.19.0-1nodesource1 . nodistro:nodistro [armhf])
                                  Inst openssl [1.1.1n-0+deb10u3] (1.1.1n-0+deb10u6 Raspbian:oldoldstable [armhf])
                                  Inst python-ipaddress [1.0.17-1] (1.0.17-1+deb10u1 Raspbian:oldoldstable [all])
                                  Inst python-cryptography [2.6.1-3+deb10u2] (2.6.1-3+deb10u4 Raspbian:oldoldstable [armhf])
                                  Inst python-werkzeug [0.14.1+dfsg1-4+deb10u1] (0.14.1+dfsg1-4+deb10u2 Raspbian:oldoldstable [all])
                                  Inst python-flask [1.0.2-3] (1.0.2-3+deb10u1 Raspbian:oldoldstable [all])
                                  Inst python-urllib3 [1.24.1-1] (1.24.1-1+deb10u2 Raspbian:oldoldstable [all])
                                  Inst python-requests [2.21.0-1] (2.21.0-1+deb10u1 Raspbian:oldoldstable [all])
                                  Inst python3-cryptography [2.6.1-3+deb10u2] (2.6.1-3+deb10u4 Raspbian:oldoldstable [armhf])
                                  Inst python3-distro-info [0.21] (0.21+deb10u1 Raspbian:oldoldstable [all])
                                  Inst python3-werkzeug [0.14.1+dfsg1-4+deb10u1] (0.14.1+dfsg1-4+deb10u2 Raspbian:oldoldstable [all])
                                  Inst python3-flask [1.0.2-3] (1.0.2-3+deb10u1 Raspbian:oldoldstable [all])
                                  Inst python3-renderpm [3.5.13-1+deb10u1] (3.5.13-1+deb10u2 Raspbian:oldoldstable [armhf])
                                  Inst python3-reportlab-accel [3.5.13-1+deb10u1] (3.5.13-1+deb10u2 Raspbian:oldoldstable [armhf])
                                  Inst python3-reportlab [3.5.13-1+deb10u1] (3.5.13-1+deb10u2 Raspbian:oldoldstable [all])
                                  Inst python3-urllib3 [1.24.1-1] (1.24.1-1+deb10u2 Raspbian:oldoldstable [all])
                                  Inst python3-requests [2.21.0-1] (2.21.0-1+deb10u1 Raspbian:oldoldstable [all])
                                  Inst rpi-eeprom [13.12-1~buster] (16.0-1~buster Raspberry Pi Foundation:oldoldstable [armhf])
                                  Inst sudo [1.8.27-1+deb10u4] (1.8.27-1+deb10u5 Raspbian:oldoldstable [armhf])
                                  Inst tcl-dev [8.6.9+1] (8.6.9+1+b1 Raspbian:oldoldstable [armhf])
                                  Inst tk [8.6.9+1] (8.6.9+1+b1 Raspbian:oldoldstable [armhf])
                                  Inst tk-dev [8.6.9+1] (8.6.9+1+b1 Raspbian:oldoldstable [armhf])
                                  Inst udisks2 [2.8.1-4] (2.8.1-4+deb10u2 Raspbian:oldoldstable [armhf])
                                  Inst vlc-plugin-notify [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst vlc-plugin-samba [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst vlc-plugin-video-splitter [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst vlc-plugin-visualization [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Inst wireless-regdb [2018.05.09-0~rpt1] (2022.04.08-2~deb10u1 Raspbian:oldoldstable [all])
                                  Inst influxdb [1.6.4-1+deb10u1] (1.8.10-1 InfluxDB:repos.influxdata.com [armhf])
                                  Conf libc6-dbg (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libc6-dev (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libc-dev-bin (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf linux-libc-dev (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libdbus-1-dev (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf dbus-user-session (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf libx11-dev (2:1.6.7-1+deb10u4 Raspbian:oldoldstable [armhf])
                                  Conf libx11-data (2:1.6.7-1+deb10u4 Raspbian:oldoldstable [all])
                                  Conf libx11-6 (2:1.6.7-1+deb10u4 Raspbian:oldoldstable [armhf])
                                  Conf dbus-x11 (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf dbus (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf libdbus-1-3 (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf systemd-sysv (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf])
                                  Conf libpam-systemd (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf])
                                  Conf xserver-common (2:1.20.4-1+rpt4+deb10u9 Raspberry Pi Foundation:oldoldstable [all])
                                  Conf libudev-dev (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf])
                                  Conf xserver-xorg-core (2:1.20.4-1+rpt4+deb10u9 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf systemd (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf])
                                  Conf bluez (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf])
                                  Conf udev (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf])
                                  Conf libdw1 (0.176-1.1+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf libelf1 (0.176-1.1+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf libunbound8 (1.9.0-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libgnutls-dane0 (3.6.7-4+deb10u11 Raspbian:oldoldstable [armhf])
                                  Conf mariadb-server-core-10.3 (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf libncurses6 (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
                                  Conf libncurses5-dev (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
                                  Conf libncursesw5-dev (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
                                  Conf libncurses-dev (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
                                  Conf mariadb-client-core-10.3 (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf mariadb-client-10.3 (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf mariadb-server-10.3 (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf python2.7-dev (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libpython2.7-dev (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libpython2.7 (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf python2.7 (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libpython2.7-stdlib (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf python2.7-minimal (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libpython2.7-minimal (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libssl-dev (1.1.1n-0+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf libssl1.1 (1.1.1n-0+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf python3.7-dev (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf libpython3.7-dev (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf libpython3.7 (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf python3.7-venv (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf python3.7 (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf libpython3.7-stdlib (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf python3.7-minimal (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf libpython3.7-minimal (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf git-man (1:2.20.1-2+deb10u8 Raspbian:oldoldstable [all])
                                  Conf libgssapi-krb5-2 (1.17-3+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf libkrb5-3 (1.17-3+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf libkrb5support0 (1.17-3+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf libk5crypto3 (1.17-3+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf libnghttp2-14 (1.36.0-2+deb10u2 Raspbian:oldoldstable [armhf])
                                  Conf libssh2-1 (1.8.0-2.1+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf libcurl3-gnutls (7.64.0-4+deb10u8 Raspbian:oldoldstable [armhf])
                                  Conf libpcre2-8-0 (10.32-5+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf git (1:2.20.1-2+deb10u8 Raspbian:oldoldstable [armhf])
                                  Conf openssh-sftp-server (1:7.9p1-10+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf openssh-server (1:7.9p1-10+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf openssh-client (1:7.9p1-10+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf ssh (1:7.9p1-10+deb10u3 Raspbian:oldoldstable [all])
                                  Conf tzdata (2021a-0+deb10u12 Raspbian:oldoldstable [all])
                                  Conf cpio (2.12+dfsg-9+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf libisc-export1100 (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
                                  Conf libdns-export1104 (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
                                  Conf isc-dhcp-client (4.4.1-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf isc-dhcp-common (4.4.1-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf vim-tiny (2:8.1.0875-5+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf xxd (2:8.1.0875-5+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf vim-common (2:8.1.0875-5+deb10u6 Raspbian:oldoldstable [all])
                                  Conf libxml2 (2.9.4+dfsg1-7+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf bind9-host (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
                                  Conf libbind9-161 (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
                                  Conf libisccfg163 (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
                                  Conf libisccc161 (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
                                  Conf libdns1104 (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
                                  Conf libisc1100 (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
                                  Conf liblwres161 (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
                                  Conf libc-l10n (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [all])
                                  Conf locales (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [all])
                                  Conf ncurses-term (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [all])
                                  Conf libavahi-common-dev (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libavahi-common-data (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libavahi-common3 (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libavahi-core7 (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf avahi-daemon (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf bluetooth (5.50-1.2~deb10u4 Raspbian:oldoldstable [all])
                                  Conf libcupsimage2 (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
                                  Conf libavahi-client-dev (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libavahi-client3 (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf cups-ipp-utils (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
                                  Conf cups-daemon (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
                                  Conf cups-core-drivers (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
                                  Conf cups-server-common (2.2.10-6+deb10u7 Raspbian:oldoldstable [all])
                                  Conf cups-common (2.2.10-6+deb10u7 Raspbian:oldoldstable [all])
                                  Conf cups-client (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
                                  Conf cups (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
                                  Conf libcups2 (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
                                  Conf libwebp6 (0.6.1-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libtiff5 (4.1.0+git191117-2~deb10u8 Raspbian:oldoldstable [armhf])
                                  Conf libcupsfilters1 (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libpoppler-qt5-1 (0.71.0-5+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf poppler-utils (0.71.0-5+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libnss3 (2:3.42.1-1+deb10u7 Raspbian:oldoldstable [armhf])
                                  Conf libpoppler82 (0.71.0-5+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libqpdf21 (8.4.0-2+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf cups-filters-core-drivers (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf ghostscript (9.27~dfsg-2+deb10u9 Raspbian:oldoldstable [armhf])
                                  Conf libgs9 (9.27~dfsg-2+deb10u9 Raspbian:oldoldstable [armhf])
                                  Conf libgs9-common (9.27~dfsg-2+deb10u9 Raspbian:oldoldstable [all])
                                  Conf libavahi-glib1 (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf cups-browsed (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libfontembed1 (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf cups-filters (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf cups-ppdc (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
                                  Conf bluez-cups (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf])
                                  Conf bluez-obexd (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf])
                                  Conf curl (7.64.0-4+deb10u8 Raspbian:oldoldstable [armhf])
                                  Conf libcurl4 (7.64.0-4+deb10u8 Raspbian:oldoldstable [armhf])
                                  Conf distro-info-data (0.41+deb10u8 Raspbian:oldoldstable [all])
                                  Conf exim4-config (4.92-8+deb10u8 Raspbian:oldoldstable [all])
                                  Conf exim4-base (4.92-8+deb10u8 Raspbian:oldoldstable [armhf])
                                  Conf exim4-daemon-light (4.92-8+deb10u8 Raspbian:oldoldstable [armhf])
                                  Conf ffmpeg (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libavdevice58 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libavfilter7 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libswscale5 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libavformat58 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libavcodec58 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libswresample3 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libpostproc55 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libavresample4 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libavutil56 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libraspberrypi-bin (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libraspberrypi-doc (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libraspberrypi-dev (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf raspberrypi-kernel (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libraspberrypi0 (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf raspberrypi-bootloader (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libaom0 (1.0.0-3+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf libvpx5 (1.7.0-3+deb10u2 Raspbian:oldoldstable [armhf])
                                  Conf libwebpmux3 (0.6.1-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf firmware-atheros (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
                                  Conf firmware-brcm80211 (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
                                  Conf firmware-libertas (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
                                  Conf firmware-misc-nonfree (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
                                  Conf firmware-realtek (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
                                  Conf libgstreamer-plugins-base1.0-0 (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
                                  Conf gstreamer1.0-alsa (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
                                  Conf libflac8 (1.3.2-3+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf gstreamer1.0-plugins-base (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
                                  Conf gstreamer1.0-plugins-bad (1.14.4-1+rvt+deb10u5 Raspbian:oldoldstable [armhf])
                                  Conf gstreamer1.0-plugins-good (1.14.4-1+rpt1+deb10u3 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf libde265-0 (1.0.11-0+deb10u5+rpi1 Raspbian:oldoldstable [armhf])
                                  Conf libx11-xcb1 (2:1.6.7-1+deb10u4 Raspbian:oldoldstable [armhf])
                                  Conf libgstreamer-gl1.0-0 (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
                                  Conf libgstreamer-plugins-bad1.0-0 (1.14.4-1+rvt+deb10u5 Raspbian:oldoldstable [armhf])
                                  Conf libopenexr23 (2.2.1-4.1+deb10u2 Raspbian:oldoldstable [armhf])
                                  Conf libzbar0 (0.22-1+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf gstreamer1.0-x (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
                                  Conf libarchive13 (3.3.3-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libavahi-compat-libdnssd-dev (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libavahi-compat-libdnssd1 (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libbluetooth-dev (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf])
                                  Conf libbluetooth3 (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf])
                                  Conf libfastjson4 (0.99.8-2+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf libwebpdemux2 (0.6.1-2+deb10u3 Raspbian:oldoldstable [armhf])
                                  Conf libwebkit2gtk-4.0-37 (2.38.6-0+deb10u1+rpi1 Raspbian:oldoldstable [armhf])
                                  Conf libjavascriptcoregtk-4.0-18 (2.38.6-0+deb10u1+rpi1 Raspbian:oldoldstable [armhf])
                                  Conf libmariadb3 (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf libncursesw5 (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
                                  Conf libtinfo5 (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
                                  Conf libpcre2-16-0 (10.32-5+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf libpcre2-posix0 (10.32-5+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf librbd1 (12.2.11+dfsg1-2.1+rpi1+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf librados2 (12.2.11+dfsg1-2.1+rpi1+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf libsnmp-base (5.7.3+dfsg-5+deb10u4 Raspbian:oldoldstable [all])
                                  Conf libsnmp30 (5.7.3+dfsg-5+deb10u4 Raspbian:oldoldstable [armhf])
                                  Conf libsynctex2 (2018.20181218.49446-1+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf tcl (8.6.9+1+b1 Raspbian:oldoldstable [armhf])
                                  Conf tcl8.6 (8.6.9+dfsg-2+b1 Raspbian:oldoldstable [armhf])
                                  Conf tcl8.6-dev (8.6.9+dfsg-2+b1 Raspbian:oldoldstable [armhf])
                                  Conf libtcl8.6 (8.6.9+dfsg-2+b1 Raspbian:oldoldstable [armhf])
                                  Conf libudisks2-0 (2.8.1-4+deb10u2 Raspbian:oldoldstable [armhf])
                                  Conf libva-wayland2 (2.4.0-1 Raspbian:oldoldstable [armhf])
                                  Conf libvlccore9 (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf vlc-plugin-skins2 (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf vlc (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf vlc-plugin-qt (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf libxpm4 (1:3.5.12-1+deb10u2 Raspbian:oldoldstable [armhf])
                                  Conf vlc-plugin-video-output (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf vlc-l10n (3.0.20-0+deb10u1 Raspbian:oldoldstable [all])
                                  Conf vlc-plugin-base (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf vlc-data (3.0.20-0+deb10u1 Raspbian:oldoldstable [all])
                                  Conf libvlc5 (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf vlc-bin (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf libvlc-bin (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf mariadb-client (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [all])
                                  Conf mariadb-server (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [all])
                                  Conf multiarch-support (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf nodejs (18.19.0-1nodesource1 . nodistro:nodistro [armhf])
                                  Conf openssl (1.1.1n-0+deb10u6 Raspbian:oldoldstable [armhf])
                                  Conf python-ipaddress (1.0.17-1+deb10u1 Raspbian:oldoldstable [all])
                                  Conf python-cryptography (2.6.1-3+deb10u4 Raspbian:oldoldstable [armhf])
                                  Conf python-werkzeug (0.14.1+dfsg1-4+deb10u2 Raspbian:oldoldstable [all])
                                  Conf python-flask (1.0.2-3+deb10u1 Raspbian:oldoldstable [all])
                                  Conf python-urllib3 (1.24.1-1+deb10u2 Raspbian:oldoldstable [all])
                                  Conf python-requests (2.21.0-1+deb10u1 Raspbian:oldoldstable [all])
                                  Conf python3-cryptography (2.6.1-3+deb10u4 Raspbian:oldoldstable [armhf])
                                  Conf python3-distro-info (0.21+deb10u1 Raspbian:oldoldstable [all])
                                  Conf python3-werkzeug (0.14.1+dfsg1-4+deb10u2 Raspbian:oldoldstable [all])
                                  Conf python3-flask (1.0.2-3+deb10u1 Raspbian:oldoldstable [all])
                                  Conf python3-renderpm (3.5.13-1+deb10u2 Raspbian:oldoldstable [armhf])
                                  Conf python3-reportlab-accel (3.5.13-1+deb10u2 Raspbian:oldoldstable [armhf])
                                  Conf python3-reportlab (3.5.13-1+deb10u2 Raspbian:oldoldstable [all])
                                  Conf python3-urllib3 (1.24.1-1+deb10u2 Raspbian:oldoldstable [all])
                                  Conf python3-requests (2.21.0-1+deb10u1 Raspbian:oldoldstable [all])
                                  Conf rpi-eeprom (16.0-1~buster Raspberry Pi Foundation:oldoldstable [armhf])
                                  Conf sudo (1.8.27-1+deb10u5 Raspbian:oldoldstable [armhf])
                                  Conf tcl-dev (8.6.9+1+b1 Raspbian:oldoldstable [armhf])
                                  Conf tk (8.6.9+1+b1 Raspbian:oldoldstable [armhf])
                                  Conf tk-dev (8.6.9+1+b1 Raspbian:oldoldstable [armhf])
                                  Conf udisks2 (2.8.1-4+deb10u2 Raspbian:oldoldstable [armhf])
                                  Conf vlc-plugin-notify (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf vlc-plugin-samba (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf vlc-plugin-video-splitter (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf vlc-plugin-visualization (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
                                  Conf wireless-regdb (2022.04.08-2~deb10u1 Raspbian:oldoldstable [all])
                                  Conf influxdb (1.8.10-1 InfluxDB:repos.influxdata.com [armhf])
                                  W Thomas Braun 2 Replies Last reply Reply Quote 0
                                    @tklein Davon abgesehen, dass das wohl so ziemlich das komplette Betriebssystem betrifft und wohl wirklich nie upgedated wurde, sieht es für mich nicht fehlerhaft aus. Mal sehen, was @Thomas-Braun meint.
                                    Gruss, Jürgen
                                      @wildbill habe noch den screen vom letzten missglückten update gefunden:
                                        @tklein
                                        Da fehlt das Ende der Ausgabe.
                                          @thomas-braun das war das ende:
                                          pi@raspberrypi-iob:~ $ ^C
                                          oder meintest du das bild vom raspi?
                                            @tklein
                                            In der Simulation ist nichts wildes zu sehen. Mal davon abgesehen das ein großer Teil der Updates gar nicht anfallen sollten, weil die aus dem Bereich 'graphische Oberfläche' stammen, die auf einem Server nix zu suchen hat und daher erst gar nicht installiert sein sollten. Macht es alles nur komplizierter.
                                            Warum das Ding nicht mehr booten sollte kann ich da jedenfalls nicht sehen. Vielleicht kann man der Langfassung von
                                            iob diag
                                            was entnehmen. Ist aber eigentlich OT und was für einen eigenen Thread. Vielleicht kann @Homoran das abspalten.
                                            T Homoran 3 Replies Last reply Reply Quote 0
                                            1377
