    4. Linuxneustart nach Systemupdate nicht möglich // Paketupdate
      tklein @Thomas Braun last edited by
      @thomas-braun nein, aber ich wollte ihn damit nicht noch weiter "belästigen"
        @thomas-braun said in Neuer Befehl: "iob nodejs-update":
        apt full-upgrade -s
        damit wird aber noch nix installiert, oder?
          Wildbill @tklein last edited by Wildbill
          @tklein Nein, das -s hinten bewirkt, dass das nur mal simuliert wird. Dann sieht man, wo bei Dir eventuelle Probleme liegen.
          Gruss, Jürgen
          EDIT: Die Ausgabe dann natürlich hier posten. Komplett, von Anfang bis Ende inklusive Eingabezeile und Allem!
            tklein @Wildbill last edited by
            @wildbill hi jürgen, hier die info:
            pi@raspberrypi-iob:~ $ apt full-upgrade -s
            NOTE: This is only a simulation!
                  apt needs root privileges for real execution.
                  Keep also in mind that locking is deactivated,
                  so don't depend on the relevance to the real current situation!
            Reading package lists... Done
            Building dependency tree
            Calculating upgrade... Done
            The following package was automatically installed and is no longer required:
              libdav1d3
            Use 'apt autoremove' to remove it.
            The following NEW packages will be installed:
              libva-wayland2
            The following packages will be upgraded:
              avahi-daemon bind9-host bluetooth bluez bluez-cups bluez-obexd cpio cups cups-browsed cups-client cups-common cups-core-drivers cups-daemon cups-filters cups-filters-core-drivers cups-ipp-utils cups-ppdc cups-server-common curl dbus
              dbus-user-session dbus-x11 distro-info-data exim4-base exim4-config exim4-daemon-light ffmpeg firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek ghostscript git git-man gstreamer1.0-alsa
              gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-x influxdb isc-dhcp-client isc-dhcp-common libaom0 libarchive13 libavahi-client-dev libavahi-client3 libavahi-common-data libavahi-common-dev
              libavahi-common3 libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libavahi-core7 libavahi-glib1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4 libavutil56 libbind9-161 libbluetooth-dev libbluetooth3
              libc-bin libc-dev-bin libc-l10n libc6 libc6-dbg libc6-dev libcups2 libcupsfilters1 libcupsimage2 libcurl3-gnutls libcurl4 libdbus-1-3 libdbus-1-dev libde265-0 libdns-export1104 libdns1104 libdw1 libelf1 libfastjson4 libflac8
              libfontembed1 libgnutls-dane0 libgnutls30 libgs9 libgs9-common libgssapi-krb5-2 libgstreamer-gl1.0-0 libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base1.0-0 libisc-export1100 libisc1100 libisccc161 libisccfg163
              libjavascriptcoregtk-4.0-18 libk5crypto3 libkrb5-3 libkrb5support0 liblwres161 libmariadb3 libncurses-dev libncurses5-dev libncurses6 libncursesw5 libncursesw5-dev libncursesw6 libnghttp2-14 libnss3 libopenexr23 libpam-systemd
              libpcre2-16-0 libpcre2-8-0 libpcre2-posix0 libpoppler-qt5-1 libpoppler82 libpostproc55 libpython2.7 libpython2.7-dev libpython2.7-minimal libpython2.7-stdlib libpython3.7 libpython3.7-dev libpython3.7-minimal libpython3.7-stdlib
              libqpdf21 librados2 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 librbd1 libsnmp-base libsnmp30 libssh2-1 libssl-dev libssl1.1 libswresample3 libswscale5 libsynctex2 libsystemd0 libtasn1-6 libtcl8.6
              libtiff5 libtinfo5 libtinfo6 libudev-dev libudev1 libudisks2-0 libunbound8 libvlc-bin libvlc5 libvlccore9 libvpx5 libwebkit2gtk-4.0-37 libwebp6 libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev libx11-xcb1 libxml2 libxpm4
              libzbar0 linux-libc-dev locales mariadb-client mariadb-client-10.3 mariadb-client-core-10.3 mariadb-common mariadb-server mariadb-server-10.3 mariadb-server-core-10.3 multiarch-support ncurses-base ncurses-bin ncurses-term nodejs
              openssh-client openssh-server openssh-sftp-server openssl poppler-utils python-cryptography python-flask python-ipaddress python-requests python-urllib3 python-werkzeug python2.7 python2.7-dev python2.7-minimal python3-cryptography
              python3-distro-info python3-flask python3-renderpm python3-reportlab python3-reportlab-accel python3-requests python3-urllib3 python3-werkzeug python3.7 python3.7-dev python3.7-minimal python3.7-venv raspberrypi-bootloader
              raspberrypi-kernel rpi-eeprom ssh sudo systemd systemd-sysv tcl tcl-dev tcl8.6 tcl8.6-dev tk tk-dev tzdata udev udisks2 vim-common vim-tiny vlc vlc-bin vlc-data vlc-l10n vlc-plugin-base vlc-plugin-notify vlc-plugin-qt
              vlc-plugin-samba vlc-plugin-skins2 vlc-plugin-video-output vlc-plugin-video-splitter vlc-plugin-visualization wireless-regdb xserver-common xserver-xorg-core xxd
            241 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
            Inst ncurses-bin [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
            Conf ncurses-bin (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
            Inst libc6-dbg [2.28-10+rpt2+rpi1+deb10u1] (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libc6-dev [2.28-10+rpt2+rpi1+deb10u1] (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libc-dev-bin [2.28-10+rpt2+rpi1+deb10u1] (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst linux-libc-dev [1:1.20220308~buster-1] (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libc6 [2.28-10+rpt2+rpi1+deb10u1] (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libc6 (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
            Inst libc-bin [2.28-10+rpt2+rpi1+deb10u1] (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libc-bin (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
            Inst ncurses-base [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [all])
            Conf ncurses-base (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [all])
            Inst libdbus-1-dev [1.12.24-0+deb10u1] (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf]) []
            Inst dbus-user-session [1.12.24-0+deb10u1] (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf]) []
            Inst libx11-dev [2:1.6.7-1+deb10u2] (2:1.6.7-1+deb10u4 Raspbian:oldoldstable [armhf]) []
            Inst libx11-data [2:1.6.7-1+deb10u2] (2:1.6.7-1+deb10u4 Raspbian:oldoldstable [all]) []
            Inst libx11-6 [2:1.6.7-1+deb10u2] (2:1.6.7-1+deb10u4 Raspbian:oldoldstable [armhf]) []
            Inst dbus-x11 [1.12.24-0+deb10u1] (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf]) []
            Inst dbus [1.12.24-0+deb10u1] (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf]) []
            Inst libdbus-1-3 [1.12.24-0+deb10u1] (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf])
            Inst systemd-sysv [241-7~deb10u8+rpi1] (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf])
            Inst libpam-systemd [241-7~deb10u8+rpi1] (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf]) []
            Inst xserver-common [2:1.20.4-1+rpt4+deb10u6] (2:1.20.4-1+rpt4+deb10u9 Raspberry Pi Foundation:oldoldstable [all]) []
            Inst libudev-dev [241-7~deb10u8+rpi1] (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf]) []
            Inst libsystemd0 [241-7~deb10u8+rpi1] (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf]) [systemd:armhf ]
            Conf libsystemd0 (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf]) [systemd:armhf ]
            Inst xserver-xorg-core [2:1.20.4-1+rpt4+deb10u6] (2:1.20.4-1+rpt4+deb10u9 Raspberry Pi Foundation:oldoldstable [armhf]) [systemd:armhf ]
            Inst systemd [241-7~deb10u8+rpi1] (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf]) []
            Inst bluez [5.50-1.2~deb10u3+rpt1] (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf]) []
            Inst udev [241-7~deb10u8+rpi1] (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf]) []
            Inst libudev1 [241-7~deb10u8+rpi1] (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf])
            Conf libudev1 (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf])
            Inst libdw1 [0.176-1.1] (0.176-1.1+deb10u1 Raspbian:oldoldstable [armhf]) []
            Inst libelf1 [0.176-1.1] (0.176-1.1+deb10u1 Raspbian:oldoldstable [armhf])
            Inst libunbound8 [1.9.0-2+deb10u2] (1.9.0-2+deb10u3 Raspbian:oldoldstable [armhf])
            Inst libgnutls-dane0 [3.6.7-4+deb10u9] (3.6.7-4+deb10u11 Raspbian:oldoldstable [armhf]) []
            Inst libtasn1-6 [4.13-3] (4.13-3+deb10u1 Raspbian:oldoldstable [armhf]) []
            Conf libtasn1-6 (4.13-3+deb10u1 Raspbian:oldoldstable [armhf]) []
            Inst libgnutls30 [3.6.7-4+deb10u9] (3.6.7-4+deb10u11 Raspbian:oldoldstable [armhf])
            Conf libgnutls30 (3.6.7-4+deb10u11 Raspbian:oldoldstable [armhf])
            Inst mariadb-common [1:10.3.36-0+deb10u2] (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [all])
            Inst mariadb-server-core-10.3 [1:10.3.36-0+deb10u2] (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
            Inst libncurses6 [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf]) [libncurses-dev:armhf ]
            Inst libncurses5-dev [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf]) [libncurses-dev:armhf ]
            Inst libncursesw5-dev [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf]) [libncurses-dev:armhf ]
            Inst libncurses-dev [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf]) []
            Inst libtinfo6 [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf]) [libncursesw6:armhf ]
            Conf libtinfo6 (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf]) [libncursesw6:armhf ]
            Inst libncursesw6 [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
            Conf libncursesw6 (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
            Inst mariadb-client-core-10.3 [1:10.3.36-0+deb10u2] (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
            Inst mariadb-client-10.3 [1:10.3.36-0+deb10u2] (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf mariadb-common (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [all])
            Inst mariadb-server-10.3 [1:10.3.36-0+deb10u2] (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
            Inst python2.7-dev [2.7.16-2+deb10u1] (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf]) []
            Inst libpython2.7-dev [2.7.16-2+deb10u1] (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf]) []
            Inst libpython2.7 [2.7.16-2+deb10u1] (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf]) []
            Inst python2.7 [2.7.16-2+deb10u1] (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf]) []
            Inst libpython2.7-stdlib [2.7.16-2+deb10u1] (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf]) []
            Inst python2.7-minimal [2.7.16-2+deb10u1] (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf]) []
            Inst libpython2.7-minimal [2.7.16-2+deb10u1] (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf])
            Inst libssl-dev [1.1.1n-0+deb10u3] (1.1.1n-0+deb10u6 Raspbian:oldoldstable [armhf]) []
            Inst libssl1.1 [1.1.1n-0+deb10u3] (1.1.1n-0+deb10u6 Raspbian:oldoldstable [armhf])
            Inst python3.7-dev [3.7.3-2+deb10u4] (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf]) []
            Inst libpython3.7-dev [3.7.3-2+deb10u4] (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf]) []
            Inst libpython3.7 [3.7.3-2+deb10u4] (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf]) []
            Inst python3.7-venv [3.7.3-2+deb10u4] (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf]) []
            Inst python3.7 [3.7.3-2+deb10u4] (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf]) []
            Inst libpython3.7-stdlib [3.7.3-2+deb10u4] (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf]) []
            Inst python3.7-minimal [3.7.3-2+deb10u4] (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf]) []
            Inst libpython3.7-minimal [3.7.3-2+deb10u4] (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
            Inst git-man [1:2.20.1-2+deb10u6] (1:2.20.1-2+deb10u8 Raspbian:oldoldstable [all])
            Inst libgssapi-krb5-2 [1.17-3+deb10u5] (1.17-3+deb10u6 Raspbian:oldoldstable [armhf]) []
            Inst libkrb5-3 [1.17-3+deb10u5] (1.17-3+deb10u6 Raspbian:oldoldstable [armhf]) []
            Inst libkrb5support0 [1.17-3+deb10u5] (1.17-3+deb10u6 Raspbian:oldoldstable [armhf])
            Inst libk5crypto3 [1.17-3+deb10u5] (1.17-3+deb10u6 Raspbian:oldoldstable [armhf])
            Inst libnghttp2-14 [1.36.0-2+deb10u1] (1.36.0-2+deb10u2 Raspbian:oldoldstable [armhf])
            Inst libssh2-1 [1.8.0-2.1] (1.8.0-2.1+deb10u1 Raspbian:oldoldstable [armhf])
            Inst libcurl3-gnutls [7.64.0-4+deb10u3] (7.64.0-4+deb10u8 Raspbian:oldoldstable [armhf])
            Inst libpcre2-8-0 [10.32-5] (10.32-5+deb10u1 Raspbian:oldoldstable [armhf])
            Inst git [1:2.20.1-2+deb10u6] (1:2.20.1-2+deb10u8 Raspbian:oldoldstable [armhf])
            Inst openssh-sftp-server [1:7.9p1-10+deb10u2+rpt1] (1:7.9p1-10+deb10u3 Raspbian:oldoldstable [armhf]) []
            Inst openssh-server [1:7.9p1-10+deb10u2+rpt1] (1:7.9p1-10+deb10u3 Raspbian:oldoldstable [armhf]) []
            Inst openssh-client [1:7.9p1-10+deb10u2+rpt1] (1:7.9p1-10+deb10u3 Raspbian:oldoldstable [armhf])
            Inst ssh [1:7.9p1-10+deb10u2+rpt1] (1:7.9p1-10+deb10u3 Raspbian:oldoldstable [all])
            Inst tzdata [2021a-0+deb10u8] (2021a-0+deb10u12 Raspbian:oldoldstable [all])
            Inst cpio [2.12+dfsg-9] (2.12+dfsg-9+deb10u1 Raspbian:oldoldstable [armhf])
            Inst libisc-export1100 [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
            Inst libdns-export1104 [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
            Inst isc-dhcp-client [4.4.1-2+deb10u2] (4.4.1-2+deb10u3 Raspbian:oldoldstable [armhf])
            Inst isc-dhcp-common [4.4.1-2+deb10u2] (4.4.1-2+deb10u3 Raspbian:oldoldstable [armhf])
            Inst vim-tiny [2:8.1.0875-5+deb10u4] (2:8.1.0875-5+deb10u6 Raspbian:oldoldstable [armhf]) []
            Inst xxd [2:8.1.0875-5+deb10u4] (2:8.1.0875-5+deb10u6 Raspbian:oldoldstable [armhf]) []
            Inst vim-common [2:8.1.0875-5+deb10u4] (2:8.1.0875-5+deb10u6 Raspbian:oldoldstable [all])
            Inst libxml2 [2.9.4+dfsg1-7+deb10u5] (2.9.4+dfsg1-7+deb10u6 Raspbian:oldoldstable [armhf])
            Inst bind9-host [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf]) []
            Inst libbind9-161 [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf]) []
            Inst libisccfg163 [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf]) []
            Inst libisccc161 [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf]) []
            Inst libdns1104 [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf]) []
            Inst libisc1100 [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf]) []
            Inst liblwres161 [1:9.11.5.P4+dfsg-5.1+deb10u8] (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
            Inst libc-l10n [2.28-10+rpt2+rpi1+deb10u1] (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [all])
            Inst locales [2.28-10+rpt2+rpi1+deb10u1] (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [all])
            Inst ncurses-term [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [all])
            Inst libavahi-common-dev [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf]) []
            Inst libavahi-common-data [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf]) []
            Inst libavahi-common3 [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
            Inst libavahi-core7 [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
            Inst avahi-daemon [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
            Inst bluetooth [5.50-1.2~deb10u3+rpt1] (5.50-1.2~deb10u4 Raspbian:oldoldstable [all])
            Inst libcupsimage2 [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf]) []
            Inst libavahi-client-dev [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf]) []
            Inst libavahi-client3 [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf]) []
            Inst cups-ipp-utils [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf]) []
            Inst cups-daemon [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf]) []
            Inst cups-core-drivers [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf]) []
            Inst cups-server-common [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [all]) []
            Inst cups-common [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [all]) []
            Inst cups-client [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf]) []
            Inst cups [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf]) []
            Inst libcups2 [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
            Inst libwebp6 [0.6.1-2+deb10u1] (0.6.1-2+deb10u3 Raspbian:oldoldstable [armhf])
            Inst libtiff5 [4.1.0+git191117-2~deb10u4] (4.1.0+git191117-2~deb10u8 Raspbian:oldoldstable [armhf])
            Inst libcupsfilters1 [1.21.6-5+rpt1] (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
            Inst libpoppler-qt5-1 [0.71.0-5+deb10u1] (0.71.0-5+deb10u3 Raspbian:oldoldstable [armhf]) []
            Inst poppler-utils [0.71.0-5+deb10u1] (0.71.0-5+deb10u3 Raspbian:oldoldstable [armhf]) []
            Inst libnss3 [2:3.42.1-1+deb10u5] (2:3.42.1-1+deb10u7 Raspbian:oldoldstable [armhf]) []
            Inst libpoppler82 [0.71.0-5+deb10u1] (0.71.0-5+deb10u3 Raspbian:oldoldstable [armhf])
            Inst libqpdf21 [8.4.0-2] (8.4.0-2+deb10u1 Raspbian:oldoldstable [armhf])
            Inst cups-filters-core-drivers [1.21.6-5+rpt1] (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
            Inst ghostscript [9.27~dfsg-2+deb10u6] (9.27~dfsg-2+deb10u9 Raspbian:oldoldstable [armhf]) []
            Inst libgs9 [9.27~dfsg-2+deb10u6] (9.27~dfsg-2+deb10u9 Raspbian:oldoldstable [armhf]) []
            Inst libgs9-common [9.27~dfsg-2+deb10u6] (9.27~dfsg-2+deb10u9 Raspbian:oldoldstable [all])
            Inst libavahi-glib1 [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
            Inst cups-browsed [1.21.6-5+rpt1] (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
            Inst libfontembed1 [1.21.6-5+rpt1] (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
            Inst cups-filters [1.21.6-5+rpt1] (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
            Inst cups-ppdc [2.2.10-6+deb10u6] (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
            Inst bluez-cups [5.50-1.2~deb10u3+rpt1] (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf])
            Inst bluez-obexd [5.50-1.2~deb10u3+rpt1] (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf])
            Inst curl [7.64.0-4+deb10u7] (7.64.0-4+deb10u8 Raspbian:oldoldstable [armhf]) []
            Inst libcurl4 [7.64.0-4+deb10u7] (7.64.0-4+deb10u8 Raspbian:oldoldstable [armhf])
            Inst distro-info-data [0.41+deb10u6] (0.41+deb10u8 Raspbian:oldoldstable [all])
            Inst exim4-config [4.92-8+deb10u7] (4.92-8+deb10u8 Raspbian:oldoldstable [all])
            Inst exim4-base [4.92-8+deb10u7] (4.92-8+deb10u8 Raspbian:oldoldstable [armhf])
            Inst exim4-daemon-light [4.92-8+deb10u7] (4.92-8+deb10u8 Raspbian:oldoldstable [armhf])
            Inst ffmpeg [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libavdevice58 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libavfilter7 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libswscale5 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libavformat58 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libavcodec58 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libswresample3 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libpostproc55 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libavresample4 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libavutil56 [7:4.1.10-0+deb10u1+rpt1] (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libraspberrypi-bin [1:1.20220308~buster-1] (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libraspberrypi-doc [1:1.20220308~buster-1] (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libraspberrypi-dev [1:1.20220308~buster-1] (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst raspberrypi-kernel [1:1.20220308~buster-1] (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libraspberrypi0 [1:1.20220308~buster-1] (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst raspberrypi-bootloader [1:1.20220308~buster-1] (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libaom0 [1.0.0-3] (1.0.0-3+deb10u1 Raspbian:oldoldstable [armhf]) []
            Inst libvpx5 [1.7.0-3+deb10u1] (1.7.0-3+deb10u2 Raspbian:oldoldstable [armhf]) []
            Inst libwebpmux3 [0.6.1-2+deb10u1] (0.6.1-2+deb10u3 Raspbian:oldoldstable [armhf])
            Inst firmware-atheros [1:20190114-2+rpt4] (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
            Inst firmware-brcm80211 [1:20190114-2+rpt4] (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
            Inst firmware-libertas [1:20190114-2+rpt4] (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
            Inst firmware-misc-nonfree [1:20190114-2+rpt4] (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
            Inst firmware-realtek [1:20190114-2+rpt4] (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
            Inst libgstreamer-plugins-base1.0-0 [1.14.4-2+deb10u1] (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
            Inst gstreamer1.0-alsa [1.14.4-2+deb10u1] (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
            Inst libflac8 [1.3.2-3+deb10u2] (1.3.2-3+deb10u3 Raspbian:oldoldstable [armhf])
            Inst gstreamer1.0-plugins-base [1.14.4-2+deb10u1] (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
            Inst gstreamer1.0-plugins-bad [1.14.4-1+rvt+deb10u2] (1.14.4-1+rvt+deb10u5 Raspbian:oldoldstable [armhf]) []
            Inst gstreamer1.0-plugins-good [1.14.4-1+rpt1+deb10u2] (1.14.4-1+rpt1+deb10u3 Raspberry Pi Foundation:oldoldstable [armhf]) []
            Inst libde265-0 [1.0.3-1+rpi1+deb10u1] (1.0.11-0+deb10u5+rpi1 Raspbian:oldoldstable [armhf]) []
            Inst libx11-xcb1 [2:1.6.7-1+deb10u2] (2:1.6.7-1+deb10u4 Raspbian:oldoldstable [armhf]) []
            Inst libgstreamer-gl1.0-0 [1.14.4-2+deb10u1] (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf]) []
            Inst libgstreamer-plugins-bad1.0-0 [1.14.4-1+rvt+deb10u2] (1.14.4-1+rvt+deb10u5 Raspbian:oldoldstable [armhf])
            Inst libopenexr23 [2.2.1-4.1+deb10u1] (2.2.1-4.1+deb10u2 Raspbian:oldoldstable [armhf])
            Inst libzbar0 [0.22-1] (0.22-1+deb10u1 Raspbian:oldoldstable [armhf])
            Inst gstreamer1.0-x [1.14.4-2+deb10u1] (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
            Inst libarchive13 [3.3.3-4+deb10u2] (3.3.3-4+deb10u3 Raspbian:oldoldstable [armhf])
            Inst libavahi-compat-libdnssd-dev [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf]) []
            Inst libavahi-compat-libdnssd1 [0.7-4+deb10u1] (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
            Inst libbluetooth-dev [5.50-1.2~deb10u3+rpt1] (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf]) []
            Inst libbluetooth3 [5.50-1.2~deb10u3+rpt1] (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf])
            Inst libfastjson4 [0.99.8-2] (0.99.8-2+deb10u1 Raspbian:oldoldstable [armhf])
            Inst libwebpdemux2 [0.6.1-2+deb10u1] (0.6.1-2+deb10u3 Raspbian:oldoldstable [armhf])
            Inst libwebkit2gtk-4.0-37 [2.38.2-1~deb10u1+rpi1] (2.38.6-0+deb10u1+rpi1 Raspbian:oldoldstable [armhf]) []
            Inst libjavascriptcoregtk-4.0-18 [2.38.2-1~deb10u1+rpi1] (2.38.6-0+deb10u1+rpi1 Raspbian:oldoldstable [armhf])
            Inst libmariadb3 [1:10.3.36-0+deb10u2] (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
            Inst libncursesw5 [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf]) []
            Inst libtinfo5 [6.1+20181013-2+deb10u3] (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
            Inst libpcre2-16-0 [10.32-5] (10.32-5+deb10u1 Raspbian:oldoldstable [armhf])
            Inst libpcre2-posix0 [10.32-5] (10.32-5+deb10u1 Raspbian:oldoldstable [armhf])
            Inst librbd1 [12.2.11+dfsg1-2.1+rpi1] (12.2.11+dfsg1-2.1+rpi1+deb10u1 Raspbian:oldoldstable [armhf]) []
            Inst librados2 [12.2.11+dfsg1-2.1+rpi1] (12.2.11+dfsg1-2.1+rpi1+deb10u1 Raspbian:oldoldstable [armhf])
            Inst libsnmp-base [5.7.3+dfsg-5+deb10u3] (5.7.3+dfsg-5+deb10u4 Raspbian:oldoldstable [all])
            Inst libsnmp30 [5.7.3+dfsg-5+deb10u3] (5.7.3+dfsg-5+deb10u4 Raspbian:oldoldstable [armhf])
            Inst libsynctex2 [2018.20181218.49446-1] (2018.20181218.49446-1+deb10u1 Raspbian:oldoldstable [armhf])
            Inst tcl [8.6.9+1] (8.6.9+1+b1 Raspbian:oldoldstable [armhf])
            Inst tcl8.6 [8.6.9+dfsg-2] (8.6.9+dfsg-2+b1 Raspbian:oldoldstable [armhf])
            Inst tcl8.6-dev [8.6.9+dfsg-2] (8.6.9+dfsg-2+b1 Raspbian:oldoldstable [armhf]) []
            Inst libtcl8.6 [8.6.9+dfsg-2] (8.6.9+dfsg-2+b1 Raspbian:oldoldstable [armhf])
            Inst libudisks2-0 [2.8.1-4] (2.8.1-4+deb10u2 Raspbian:oldoldstable [armhf])
            Inst libva-wayland2 (2.4.0-1 Raspbian:oldoldstable [armhf])
            Inst libvlccore9 [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Inst vlc-plugin-skins2 [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf]) []
            Inst vlc [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf]) []
            Inst vlc-plugin-qt [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf]) []
            Inst libxpm4 [1:3.5.12-1] (1:3.5.12-1+deb10u2 Raspbian:oldoldstable [armhf]) []
            Inst vlc-plugin-video-output [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf]) []
            Inst vlc-l10n [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [all]) []
            Inst vlc-plugin-base [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf]) []
            Inst vlc-data [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [all]) []
            Inst libvlc5 [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf]) []
            Inst vlc-bin [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf]) []
            Inst libvlc-bin [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Inst mariadb-client [1:10.3.36-0+deb10u2] (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [all])
            Inst mariadb-server [1:10.3.36-0+deb10u2] (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [all])
            Inst multiarch-support [2.28-10+rpt2+rpi1+deb10u1] (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
            Inst nodejs [18.0.0-1nodesource1] (18.19.0-1nodesource1 . nodistro:nodistro [armhf])
            Inst openssl [1.1.1n-0+deb10u3] (1.1.1n-0+deb10u6 Raspbian:oldoldstable [armhf])
            Inst python-ipaddress [1.0.17-1] (1.0.17-1+deb10u1 Raspbian:oldoldstable [all])
            Inst python-cryptography [2.6.1-3+deb10u2] (2.6.1-3+deb10u4 Raspbian:oldoldstable [armhf])
            Inst python-werkzeug [0.14.1+dfsg1-4+deb10u1] (0.14.1+dfsg1-4+deb10u2 Raspbian:oldoldstable [all])
            Inst python-flask [1.0.2-3] (1.0.2-3+deb10u1 Raspbian:oldoldstable [all])
            Inst python-urllib3 [1.24.1-1] (1.24.1-1+deb10u2 Raspbian:oldoldstable [all])
            Inst python-requests [2.21.0-1] (2.21.0-1+deb10u1 Raspbian:oldoldstable [all])
            Inst python3-cryptography [2.6.1-3+deb10u2] (2.6.1-3+deb10u4 Raspbian:oldoldstable [armhf])
            Inst python3-distro-info [0.21] (0.21+deb10u1 Raspbian:oldoldstable [all])
            Inst python3-werkzeug [0.14.1+dfsg1-4+deb10u1] (0.14.1+dfsg1-4+deb10u2 Raspbian:oldoldstable [all])
            Inst python3-flask [1.0.2-3] (1.0.2-3+deb10u1 Raspbian:oldoldstable [all])
            Inst python3-renderpm [3.5.13-1+deb10u1] (3.5.13-1+deb10u2 Raspbian:oldoldstable [armhf])
            Inst python3-reportlab-accel [3.5.13-1+deb10u1] (3.5.13-1+deb10u2 Raspbian:oldoldstable [armhf])
            Inst python3-reportlab [3.5.13-1+deb10u1] (3.5.13-1+deb10u2 Raspbian:oldoldstable [all])
            Inst python3-urllib3 [1.24.1-1] (1.24.1-1+deb10u2 Raspbian:oldoldstable [all])
            Inst python3-requests [2.21.0-1] (2.21.0-1+deb10u1 Raspbian:oldoldstable [all])
            Inst rpi-eeprom [13.12-1~buster] (16.0-1~buster Raspberry Pi Foundation:oldoldstable [armhf])
            Inst sudo [1.8.27-1+deb10u4] (1.8.27-1+deb10u5 Raspbian:oldoldstable [armhf])
            Inst tcl-dev [8.6.9+1] (8.6.9+1+b1 Raspbian:oldoldstable [armhf])
            Inst tk [8.6.9+1] (8.6.9+1+b1 Raspbian:oldoldstable [armhf])
            Inst tk-dev [8.6.9+1] (8.6.9+1+b1 Raspbian:oldoldstable [armhf])
            Inst udisks2 [2.8.1-4] (2.8.1-4+deb10u2 Raspbian:oldoldstable [armhf])
            Inst vlc-plugin-notify [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Inst vlc-plugin-samba [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Inst vlc-plugin-video-splitter [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Inst vlc-plugin-visualization [3.0.17.4-0+deb10u2+rpt1] (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Inst wireless-regdb [2018.05.09-0~rpt1] (2022.04.08-2~deb10u1 Raspbian:oldoldstable [all])
            Inst influxdb [1.6.4-1+deb10u1] (1.8.10-1 InfluxDB:repos.influxdata.com [armhf])
            Conf libc6-dbg (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libc6-dev (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libc-dev-bin (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf linux-libc-dev (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libdbus-1-dev (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf dbus-user-session (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf libx11-dev (2:1.6.7-1+deb10u4 Raspbian:oldoldstable [armhf])
            Conf libx11-data (2:1.6.7-1+deb10u4 Raspbian:oldoldstable [all])
            Conf libx11-6 (2:1.6.7-1+deb10u4 Raspbian:oldoldstable [armhf])
            Conf dbus-x11 (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf dbus (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf libdbus-1-3 (1.12.28-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf systemd-sysv (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf])
            Conf libpam-systemd (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf])
            Conf xserver-common (2:1.20.4-1+rpt4+deb10u9 Raspberry Pi Foundation:oldoldstable [all])
            Conf libudev-dev (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf])
            Conf xserver-xorg-core (2:1.20.4-1+rpt4+deb10u9 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf systemd (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf])
            Conf bluez (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf])
            Conf udev (241-7~deb10u9+rpi1 Raspbian:oldoldstable [armhf])
            Conf libdw1 (0.176-1.1+deb10u1 Raspbian:oldoldstable [armhf])
            Conf libelf1 (0.176-1.1+deb10u1 Raspbian:oldoldstable [armhf])
            Conf libunbound8 (1.9.0-2+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libgnutls-dane0 (3.6.7-4+deb10u11 Raspbian:oldoldstable [armhf])
            Conf mariadb-server-core-10.3 (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf libncurses6 (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
            Conf libncurses5-dev (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
            Conf libncursesw5-dev (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
            Conf libncurses-dev (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
            Conf mariadb-client-core-10.3 (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf mariadb-client-10.3 (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf mariadb-server-10.3 (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf python2.7-dev (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libpython2.7-dev (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libpython2.7 (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf])
            Conf python2.7 (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libpython2.7-stdlib (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf])
            Conf python2.7-minimal (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libpython2.7-minimal (2.7.16-2+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libssl-dev (1.1.1n-0+deb10u6 Raspbian:oldoldstable [armhf])
            Conf libssl1.1 (1.1.1n-0+deb10u6 Raspbian:oldoldstable [armhf])
            Conf python3.7-dev (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
            Conf libpython3.7-dev (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
            Conf libpython3.7 (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
            Conf python3.7-venv (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
            Conf python3.7 (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
            Conf libpython3.7-stdlib (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
            Conf python3.7-minimal (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
            Conf libpython3.7-minimal (3.7.3-2+deb10u6 Raspbian:oldoldstable [armhf])
            Conf git-man (1:2.20.1-2+deb10u8 Raspbian:oldoldstable [all])
            Conf libgssapi-krb5-2 (1.17-3+deb10u6 Raspbian:oldoldstable [armhf])
            Conf libkrb5-3 (1.17-3+deb10u6 Raspbian:oldoldstable [armhf])
            Conf libkrb5support0 (1.17-3+deb10u6 Raspbian:oldoldstable [armhf])
            Conf libk5crypto3 (1.17-3+deb10u6 Raspbian:oldoldstable [armhf])
            Conf libnghttp2-14 (1.36.0-2+deb10u2 Raspbian:oldoldstable [armhf])
            Conf libssh2-1 (1.8.0-2.1+deb10u1 Raspbian:oldoldstable [armhf])
            Conf libcurl3-gnutls (7.64.0-4+deb10u8 Raspbian:oldoldstable [armhf])
            Conf libpcre2-8-0 (10.32-5+deb10u1 Raspbian:oldoldstable [armhf])
            Conf git (1:2.20.1-2+deb10u8 Raspbian:oldoldstable [armhf])
            Conf openssh-sftp-server (1:7.9p1-10+deb10u3 Raspbian:oldoldstable [armhf])
            Conf openssh-server (1:7.9p1-10+deb10u3 Raspbian:oldoldstable [armhf])
            Conf openssh-client (1:7.9p1-10+deb10u3 Raspbian:oldoldstable [armhf])
            Conf ssh (1:7.9p1-10+deb10u3 Raspbian:oldoldstable [all])
            Conf tzdata (2021a-0+deb10u12 Raspbian:oldoldstable [all])
            Conf cpio (2.12+dfsg-9+deb10u1 Raspbian:oldoldstable [armhf])
            Conf libisc-export1100 (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
            Conf libdns-export1104 (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
            Conf isc-dhcp-client (4.4.1-2+deb10u3 Raspbian:oldoldstable [armhf])
            Conf isc-dhcp-common (4.4.1-2+deb10u3 Raspbian:oldoldstable [armhf])
            Conf vim-tiny (2:8.1.0875-5+deb10u6 Raspbian:oldoldstable [armhf])
            Conf xxd (2:8.1.0875-5+deb10u6 Raspbian:oldoldstable [armhf])
            Conf vim-common (2:8.1.0875-5+deb10u6 Raspbian:oldoldstable [all])
            Conf libxml2 (2.9.4+dfsg1-7+deb10u6 Raspbian:oldoldstable [armhf])
            Conf bind9-host (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
            Conf libbind9-161 (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
            Conf libisccfg163 (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
            Conf libisccc161 (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
            Conf libdns1104 (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
            Conf libisc1100 (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
            Conf liblwres161 (1:9.11.5.P4+dfsg-5.1+deb10u9 Raspbian:oldoldstable [armhf])
            Conf libc-l10n (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [all])
            Conf locales (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [all])
            Conf ncurses-term (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [all])
            Conf libavahi-common-dev (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libavahi-common-data (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libavahi-common3 (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libavahi-core7 (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
            Conf avahi-daemon (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
            Conf bluetooth (5.50-1.2~deb10u4 Raspbian:oldoldstable [all])
            Conf libcupsimage2 (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
            Conf libavahi-client-dev (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libavahi-client3 (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
            Conf cups-ipp-utils (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
            Conf cups-daemon (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
            Conf cups-core-drivers (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
            Conf cups-server-common (2.2.10-6+deb10u7 Raspbian:oldoldstable [all])
            Conf cups-common (2.2.10-6+deb10u7 Raspbian:oldoldstable [all])
            Conf cups-client (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
            Conf cups (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
            Conf libcups2 (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
            Conf libwebp6 (0.6.1-2+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libtiff5 (4.1.0+git191117-2~deb10u8 Raspbian:oldoldstable [armhf])
            Conf libcupsfilters1 (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libpoppler-qt5-1 (0.71.0-5+deb10u3 Raspbian:oldoldstable [armhf])
            Conf poppler-utils (0.71.0-5+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libnss3 (2:3.42.1-1+deb10u7 Raspbian:oldoldstable [armhf])
            Conf libpoppler82 (0.71.0-5+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libqpdf21 (8.4.0-2+deb10u1 Raspbian:oldoldstable [armhf])
            Conf cups-filters-core-drivers (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf ghostscript (9.27~dfsg-2+deb10u9 Raspbian:oldoldstable [armhf])
            Conf libgs9 (9.27~dfsg-2+deb10u9 Raspbian:oldoldstable [armhf])
            Conf libgs9-common (9.27~dfsg-2+deb10u9 Raspbian:oldoldstable [all])
            Conf libavahi-glib1 (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
            Conf cups-browsed (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libfontembed1 (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf cups-filters (1.21.6-5+rpt1+deb10u1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf cups-ppdc (2.2.10-6+deb10u7 Raspbian:oldoldstable [armhf])
            Conf bluez-cups (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf])
            Conf bluez-obexd (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf])
            Conf curl (7.64.0-4+deb10u8 Raspbian:oldoldstable [armhf])
            Conf libcurl4 (7.64.0-4+deb10u8 Raspbian:oldoldstable [armhf])
            Conf distro-info-data (0.41+deb10u8 Raspbian:oldoldstable [all])
            Conf exim4-config (4.92-8+deb10u8 Raspbian:oldoldstable [all])
            Conf exim4-base (4.92-8+deb10u8 Raspbian:oldoldstable [armhf])
            Conf exim4-daemon-light (4.92-8+deb10u8 Raspbian:oldoldstable [armhf])
            Conf ffmpeg (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libavdevice58 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libavfilter7 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libswscale5 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libavformat58 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libavcodec58 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libswresample3 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libpostproc55 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libavresample4 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libavutil56 (7:4.1.11-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libraspberrypi-bin (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libraspberrypi-doc (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libraspberrypi-dev (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf raspberrypi-kernel (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libraspberrypi0 (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf raspberrypi-bootloader (1:1.20230509~buster-1 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libaom0 (1.0.0-3+deb10u1 Raspbian:oldoldstable [armhf])
            Conf libvpx5 (1.7.0-3+deb10u2 Raspbian:oldoldstable [armhf])
            Conf libwebpmux3 (0.6.1-2+deb10u3 Raspbian:oldoldstable [armhf])
            Conf firmware-atheros (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
            Conf firmware-brcm80211 (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
            Conf firmware-libertas (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
            Conf firmware-misc-nonfree (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
            Conf firmware-realtek (1:20190114+really20220913-0+deb10u1+rpt1 Raspberry Pi Foundation:oldoldstable [all])
            Conf libgstreamer-plugins-base1.0-0 (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
            Conf gstreamer1.0-alsa (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
            Conf libflac8 (1.3.2-3+deb10u3 Raspbian:oldoldstable [armhf])
            Conf gstreamer1.0-plugins-base (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
            Conf gstreamer1.0-plugins-bad (1.14.4-1+rvt+deb10u5 Raspbian:oldoldstable [armhf])
            Conf gstreamer1.0-plugins-good (1.14.4-1+rpt1+deb10u3 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf libde265-0 (1.0.11-0+deb10u5+rpi1 Raspbian:oldoldstable [armhf])
            Conf libx11-xcb1 (2:1.6.7-1+deb10u4 Raspbian:oldoldstable [armhf])
            Conf libgstreamer-gl1.0-0 (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
            Conf libgstreamer-plugins-bad1.0-0 (1.14.4-1+rvt+deb10u5 Raspbian:oldoldstable [armhf])
            Conf libopenexr23 (2.2.1-4.1+deb10u2 Raspbian:oldoldstable [armhf])
            Conf libzbar0 (0.22-1+deb10u1 Raspbian:oldoldstable [armhf])
            Conf gstreamer1.0-x (1.14.4-2+deb10u2 Raspbian:oldoldstable [armhf])
            Conf libarchive13 (3.3.3-4+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libavahi-compat-libdnssd-dev (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libavahi-compat-libdnssd1 (0.7-4+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libbluetooth-dev (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf])
            Conf libbluetooth3 (5.50-1.2~deb10u4 Raspbian:oldoldstable [armhf])
            Conf libfastjson4 (0.99.8-2+deb10u1 Raspbian:oldoldstable [armhf])
            Conf libwebpdemux2 (0.6.1-2+deb10u3 Raspbian:oldoldstable [armhf])
            Conf libwebkit2gtk-4.0-37 (2.38.6-0+deb10u1+rpi1 Raspbian:oldoldstable [armhf])
            Conf libjavascriptcoregtk-4.0-18 (2.38.6-0+deb10u1+rpi1 Raspbian:oldoldstable [armhf])
            Conf libmariadb3 (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf libncursesw5 (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
            Conf libtinfo5 (6.1+20181013-2+deb10u5 Raspbian:oldoldstable [armhf])
            Conf libpcre2-16-0 (10.32-5+deb10u1 Raspbian:oldoldstable [armhf])
            Conf libpcre2-posix0 (10.32-5+deb10u1 Raspbian:oldoldstable [armhf])
            Conf librbd1 (12.2.11+dfsg1-2.1+rpi1+deb10u1 Raspbian:oldoldstable [armhf])
            Conf librados2 (12.2.11+dfsg1-2.1+rpi1+deb10u1 Raspbian:oldoldstable [armhf])
            Conf libsnmp-base (5.7.3+dfsg-5+deb10u4 Raspbian:oldoldstable [all])
            Conf libsnmp30 (5.7.3+dfsg-5+deb10u4 Raspbian:oldoldstable [armhf])
            Conf libsynctex2 (2018.20181218.49446-1+deb10u1 Raspbian:oldoldstable [armhf])
            Conf tcl (8.6.9+1+b1 Raspbian:oldoldstable [armhf])
            Conf tcl8.6 (8.6.9+dfsg-2+b1 Raspbian:oldoldstable [armhf])
            Conf tcl8.6-dev (8.6.9+dfsg-2+b1 Raspbian:oldoldstable [armhf])
            Conf libtcl8.6 (8.6.9+dfsg-2+b1 Raspbian:oldoldstable [armhf])
            Conf libudisks2-0 (2.8.1-4+deb10u2 Raspbian:oldoldstable [armhf])
            Conf libva-wayland2 (2.4.0-1 Raspbian:oldoldstable [armhf])
            Conf libvlccore9 (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf vlc-plugin-skins2 (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf vlc (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf vlc-plugin-qt (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf libxpm4 (1:3.5.12-1+deb10u2 Raspbian:oldoldstable [armhf])
            Conf vlc-plugin-video-output (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf vlc-l10n (3.0.20-0+deb10u1 Raspbian:oldoldstable [all])
            Conf vlc-plugin-base (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf vlc-data (3.0.20-0+deb10u1 Raspbian:oldoldstable [all])
            Conf libvlc5 (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf vlc-bin (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf libvlc-bin (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf mariadb-client (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [all])
            Conf mariadb-server (1:10.3.39-0+deb10u1 Raspbian:oldoldstable [all])
            Conf multiarch-support (2.28-10+rpt2+rpi1+deb10u2 Raspberry Pi Foundation:oldoldstable [armhf])
            Conf nodejs (18.19.0-1nodesource1 . nodistro:nodistro [armhf])
            Conf openssl (1.1.1n-0+deb10u6 Raspbian:oldoldstable [armhf])
            Conf python-ipaddress (1.0.17-1+deb10u1 Raspbian:oldoldstable [all])
            Conf python-cryptography (2.6.1-3+deb10u4 Raspbian:oldoldstable [armhf])
            Conf python-werkzeug (0.14.1+dfsg1-4+deb10u2 Raspbian:oldoldstable [all])
            Conf python-flask (1.0.2-3+deb10u1 Raspbian:oldoldstable [all])
            Conf python-urllib3 (1.24.1-1+deb10u2 Raspbian:oldoldstable [all])
            Conf python-requests (2.21.0-1+deb10u1 Raspbian:oldoldstable [all])
            Conf python3-cryptography (2.6.1-3+deb10u4 Raspbian:oldoldstable [armhf])
            Conf python3-distro-info (0.21+deb10u1 Raspbian:oldoldstable [all])
            Conf python3-werkzeug (0.14.1+dfsg1-4+deb10u2 Raspbian:oldoldstable [all])
            Conf python3-flask (1.0.2-3+deb10u1 Raspbian:oldoldstable [all])
            Conf python3-renderpm (3.5.13-1+deb10u2 Raspbian:oldoldstable [armhf])
            Conf python3-reportlab-accel (3.5.13-1+deb10u2 Raspbian:oldoldstable [armhf])
            Conf python3-reportlab (3.5.13-1+deb10u2 Raspbian:oldoldstable [all])
            Conf python3-urllib3 (1.24.1-1+deb10u2 Raspbian:oldoldstable [all])
            Conf python3-requests (2.21.0-1+deb10u1 Raspbian:oldoldstable [all])
            Conf rpi-eeprom (16.0-1~buster Raspberry Pi Foundation:oldoldstable [armhf])
            Conf sudo (1.8.27-1+deb10u5 Raspbian:oldoldstable [armhf])
            Conf tcl-dev (8.6.9+1+b1 Raspbian:oldoldstable [armhf])
            Conf tk (8.6.9+1+b1 Raspbian:oldoldstable [armhf])
            Conf tk-dev (8.6.9+1+b1 Raspbian:oldoldstable [armhf])
            Conf udisks2 (2.8.1-4+deb10u2 Raspbian:oldoldstable [armhf])
            Conf vlc-plugin-notify (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf vlc-plugin-samba (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf vlc-plugin-video-splitter (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf vlc-plugin-visualization (3.0.20-0+deb10u1 Raspbian:oldoldstable [armhf])
            Conf wireless-regdb (2022.04.08-2~deb10u1 Raspbian:oldoldstable [all])
            Conf influxdb (1.8.10-1 InfluxDB:repos.influxdata.com [armhf])
            W Thomas Braun 2 Replies Last reply Reply Quote 0
              @tklein Davon abgesehen, dass das wohl so ziemlich das komplette Betriebssystem betrifft und wohl wirklich nie upgedated wurde, sieht es für mich nicht fehlerhaft aus. Mal sehen, was @Thomas-Braun meint.
              Gruss, Jürgen
                @wildbill habe noch den screen vom letzten missglückten update gefunden:
                  Thomas Braun Most Active @tklein last edited by
                  @tklein
                  Da fehlt das Ende der Ausgabe.
                    @thomas-braun das war das ende:
                    pi@raspberrypi-iob:~ $ ^C
                    oder meintest du das bild vom raspi?
                      @tklein
                      In der Simulation ist nichts wildes zu sehen. Mal davon abgesehen das ein großer Teil der Updates gar nicht anfallen sollten, weil die aus dem Bereich 'graphische Oberfläche' stammen, die auf einem Server nix zu suchen hat und daher erst gar nicht installiert sein sollten. Macht es alles nur komplizierter.
                      Warum das Ding nicht mehr booten sollte kann ich da jedenfalls nicht sehen. Vielleicht kann man der Langfassung von
                      iob diag
                      was entnehmen. Ist aber eigentlich OT und was für einen eigenen Thread. Vielleicht kann @Homoran das abspalten.
                      T Homoran 3 Replies Last reply Reply Quote 0
                        @thomas-braun vielen dank für deine (bisherigen) bemühungen!
                        ich werden dann warten, bis der post abgespaltet wurde und dort dann den ganzen inhalt/log posten
                          @thomas-braun sagte in Installation verbogen und nie upgedated:
                          erledigt!
                          @tklein bitte provisorischen Threadtitel anpassen!
                            tklein @Homoran last edited by
                            @homoran done & thx
                              @thomas-braun said in Installation verbogen und nie upgedated:
                              iob diag
                              Zur "Verteidung" möcht ich sagen, dass zumindest der iobroker relativ aktuell gehalten wurde 🙂
                              part 1:
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                 Static hostname: raspberrypi-iob
                                       Icon name: computer
                                Operating System: Raspbian GNU/Linux 10 (buster)
                                          Kernel: Linux 5.10.103-v7l+
                                    Architecture: arm
                              Model           : Raspberry Pi 4 Model B Rev 1.2
                              Docker          : false
                              Virtualization  : none
                              Kernel          : armv7l
                              Userland        : armhf
                              Systemuptime and Load:
                               11:23:42 up 1 day, 15:22,  2 users,  load average: 0.91, 0.89, 0.88
                              CPU threads: 4
                              *** RASPBERRY THROTTLING ***
                              Current issues:
                              Previously detected issues:
                              *** Time and Time Zones ***
                                             Local time: Wed 2023-12-20 11:23:42 CET
                                         Universal time: Wed 2023-12-20 10:23:42 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              *** User and Groups ***
                              pi
                              /home/pi
                              pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                              *** X-Server-Setup ***
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:           3.8G        2.5G        392M         65M        990M        1.2G
                              Swap:           10G        1.1G        9.1G
                              Total:          14G        3.6G        9.5G
                                       3837 M total memory
                                       2454 M used memory
                                       1490 M active memory
                                       1820 M inactive memory
                                        392 M free memory
                                        121 M buffer memory
                                        869 M swap cache
                                      10239 M total swap
                                       1126 M used swap
                                       9113 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FAILED SERVICES ***
                                UNIT            LOAD   ACTIVE SUB    DESCRIPTION
                              * lightdm.service loaded failed failed Light Display Manager
                              LOAD   = Reflects whether the unit definition was properly loaded.
                              ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                              SUB    = The low-level unit activation state, values depend on unit type.
                              1 loaded units listed. Pass --all to see loaded but inactive units, too.
                              To show all installed unit files use 'systemctl list-unit-files'.
                              *** FILESYSTEM ***
                              /dev/root      ext4      220G   30G  182G  14% /
                              devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                              tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                              tmpfs          tmpfs     1.9G   81M  1.8G   5% /run
                              tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                              /dev/sda1      vfat      253M   49M  204M  20% /boot
                              tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                              [Mon Dec 18 20:01:09 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:54:0B:45 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=74cbdb6a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                              [Mon Dec 18 20:01:11 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                              [Mon Dec 18 20:01:11 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                              [Mon Dec 18 20:01:13 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
                              TARGET        SOURCE    FSTYPE OPTIONS
                              /             /dev/sda2 ext4   rw,noatime
                              |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                              `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              6.7G    /var/
                              1.4G    /var/cache/apt/archives
                              1.4G    /var/cache/apt
                              1.4G    /var/cache
                              1.1G    /var/lib
                              Archived and active journals take up 79.9M in the file system.
                              /opt/iobroker/backups:
                              1.6G    /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              1.4G    /opt/iobroker/iobroker-data/
                              601M    /opt/iobroker/iobroker-data/backup-objects
                              552M    /opt/iobroker/iobroker-data/files
                              90M     /opt/iobroker/iobroker-data/files/echarts.admin
                              67M     /opt/iobroker/iobroker-data/files/javascript.admin
                              60M     /opt/iobroker/iobroker-data/objects.jsonl
                              52M     /opt/iobroker/iobroker-data/states.jsonl
                              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                              33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                              27M     /opt/iobroker/iobroker-data/objects.json.migrated
                              USB-Devices by-id:
                              /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A94ZVX1D-if00-port0
                              /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2219042-if00
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v18.0.0
                              /usr/bin/node           v18.0.0
                              /usr/bin/npm            8.6.0
                              /usr/bin/npx            8.6.0
                              /usr/bin/corepack       0.10.0
                              nodejs:
                                Installed: 18.0.0-1nodesource1
                                Candidate: 18.19.0-1nodesource1
                                Version table:
                                   18.19.0-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                   18.18.2-1nodesource1 1001
                                   18.18.1-1nodesource1 1001
                                   18.18.0-1nodesource1 1001
                                   18.17.1-1nodesource1 1001
                                   18.17.0-1nodesource1 1001
                                   18.16.1-1nodesource1 1001
                                   18.16.0-1nodesource1 1001
                                   18.15.0-1nodesource1 1001
                                   18.14.2-1nodesource1 1001
                                   18.14.1-1nodesource1 1001
                                   18.14.0-1nodesource1 1001
                                   18.13.0-1nodesource1 1001
                                   18.12.0-1nodesource1 1001
                                   18.11.0-1nodesource1 1001
                                   18.10.0-1nodesource1 1001
                                   18.9.1-1nodesource1 1001
                                   18.9.0-1nodesource1 1001
                                   18.8.0-1nodesource1 1001
                                   18.7.0-1nodesource1 1001
                                   18.6.0-1nodesource1 1001
                                   18.5.0-1nodesource1 1001
                                   18.4.0-1nodesource1 1001
                                   18.3.0-1nodesource1 1001
                                   18.2.0-1nodesource1 1001
                                   18.1.0-1nodesource1 1001
                               *** 18.0.0-1nodesource1 1001
                                      100 /var/lib/dpkg/status
                                   10.24.0~dfsg-1~deb10u3 500
                              No problems detected
                              Errors in npm tree:
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Core adapters versions
                              js-controller:  5.0.17
                              admin:          6.12.0
                              javascript:     7.1.6
                              Adapters from github:   5
                              Adapter State
                              + system.adapter.accuweather.0            : accuweather           : raspberrypi-iob                          -  enabled
                              + system.adapter.admin.0                  : admin                 : raspberrypi-iob                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.alexa2.0                 : alexa2                : raspberrypi-iob                          -  enabled
                                system.adapter.alias-manager.0          : alias-manager         : raspberrypi-iob                          -  enabled
                                system.adapter.apple-find-me.0          : apple-find-me         : raspberrypi-iob                          - disabled
                                system.adapter.apple-find-me.1          : apple-find-me         : raspberrypi-iob                          - disabled
                                system.adapter.apple-find-me.2          : apple-find-me         : raspberrypi-iob                          - disabled
                              + system.adapter.backitup.0               : backitup              : raspberrypi-iob                          -  enabled
                                system.adapter.bmw.0                    : bmw                   : raspberrypi-iob                          - disabled
                                system.adapter.bmw.1                    : bmw                   : raspberrypi-iob                          - disabled
                                system.adapter.bring.0                  : bring                 : raspberrypi-iob                          - disabled
                              + system.adapter.broadlink2.0             : broadlink2            : raspberrypi-iob                          -  enabled
                              + system.adapter.cloud.0                  : cloud                 : raspberrypi-iob                          -  enabled
                                system.adapter.coronavirus-statistics.0 : coronavirus-statistics: raspberrypi-iob                          - disabled
                                system.adapter.daswetter.0              : daswetter             : raspberrypi-iob                          - disabled
                                system.adapter.device-reminder.0        : device-reminder       : raspberrypi-iob                          - disabled
                                system.adapter.device-watcher.0         : device-watcher        : raspberrypi-iob                          - disabled
                                system.adapter.devices.0                : devices               : raspberrypi-iob                          -  enabled
                                system.adapter.discovery.0              : discovery             : raspberrypi-iob                          - disabled
                                system.adapter.dwd.0                    : dwd                   : raspberrypi-iob                          -  enabled
                              + system.adapter.echarts.0                : echarts               : raspberrypi-iob                          -  enabled
                              + system.adapter.email.0                  : email                 : raspberrypi-iob                          -  enabled
                              + system.adapter.enigma2.1                : enigma2               : raspberrypi-iob                          -  enabled
                                system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi-iob                          - disabled
                                system.adapter.feiertage.0              : feiertage             : raspberrypi-iob                          -  enabled
                              + system.adapter.fhem.0                   : fhem                  : raspberrypi-iob                          -  enabled, port: 7072
                              + system.adapter.firetv.0                 : firetv                : raspberrypi-iob                          -  enabled
                                system.adapter.flot.0                   : flot                  : raspberrypi-iob                          -  enabled
                                system.adapter.followthesun.0           : followthesun          : raspberrypi-iob                          - disabled
                                system.adapter.geofency.0               : geofency              : raspberrypi-iob                          - disabled, port: 7999, bind: 0.0.0.0
                                system.adapter.govee.0                  : govee                 : raspberrypi-iob                          - disabled
                                system.adapter.habpanel.0               : habpanel              : raspberrypi-iob                          -  enabled
                              + system.adapter.ham.0                    : ham                   : raspberrypi-iob                          -  enabled
                                system.adapter.history.0                : history               : raspberrypi-iob                          - disabled
                              + system.adapter.homeconnect.0            : homeconnect           : raspberrypi-iob                          -  enabled
                                system.adapter.homekit-controller.0     : homekit-controller    : raspberrypi-iob                          - disabled
                                system.adapter.ical.0                   : ical                  : raspberrypi-iob                          -  enabled
                                system.adapter.ico-cloud.0              : ico-cloud             : raspberrypi-iob                          -  enabled
                              + system.adapter.influxdb.0               : influxdb              : raspberrypi-iob                          -  enabled, port: 8086
                              + system.adapter.info.0                   : info                  : raspberrypi-iob                          -  enabled
                              + system.adapter.iot.1                    : iot                   : raspberrypi-iob                          -  enabled
                              + system.adapter.javascript.0             : javascript            : raspberrypi-iob                          -  enabled
                                system.adapter.labcom.0                 : labcom                : raspberrypi-iob                          -  enabled
                              + system.adapter.linkeddevices.0          : linkeddevices         : raspberrypi-iob                          -  enabled
                              + system.adapter.linux-control.0          : linux-control         : raspberrypi-iob                          -  enabled
                              + system.adapter.meater.0                 : meater                : raspberrypi-iob                          -  enabled
                                system.adapter.meross.0                 : meross                : raspberrypi-iob                          - disabled
                                system.adapter.milight-smart-light.0    : milight-smart-light   : raspberrypi-iob                          - disabled
                                system.adapter.milight-smart-light.2    : milight-smart-light   : raspberrypi-iob                          - disabled
                                system.adapter.milight-smart-light.3    : milight-smart-light   : raspberrypi-iob                          - disabled
                                system.adapter.milight-smart-light.4    : milight-smart-light   : raspberrypi-iob                          - disabled
                              + system.adapter.mqtt.0                   : mqtt                  : raspberrypi-iob                          -  enabled, port: 1888, bind: 192.168.0.20
                                system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi-iob                          -  enabled
                              + system.adapter.nina.0                   : nina                  : raspberrypi-iob                          -  enabled
                                system.adapter.openweathermap.0         : openweathermap        : raspberrypi-iob                          - disabled
                                system.adapter.parcel.0                 : parcel                : raspberrypi-iob                          - disabled
                                system.adapter.pegelalarm.0             : pegelalarm            : raspberrypi-iob                          - disabled
                              + system.adapter.ping.0                   : ping                  : raspberrypi-iob                          -  enabled
                              + system.adapter.pollenflug.0             : pollenflug            : raspberrypi-iob                          -  enabled
                              + system.adapter.pushover.0               : pushover              : raspberrypi-iob                          -  enabled
                              + system.adapter.reolink.0                : reolink               : raspberrypi-iob                          -  enabled
                                system.adapter.ring.0                   : ring                  : raspberrypi-iob                          - disabled
                              + system.adapter.rpi2.0                   : rpi2                  : raspberrypi-iob                          -  enabled
                                system.adapter.sayit.0                  : sayit                 : raspberrypi-iob                          - disabled
                                system.adapter.schoolfree.0             : schoolfree            : raspberrypi-iob                          -  enabled
                              + system.adapter.shelly.0                 : shelly                : raspberrypi-iob                          -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.shelly.1                 : shelly                : raspberrypi-iob                          -  enabled, port: 1889, bind: 0.0.0.0
                              + system.adapter.simple-api.0             : simple-api            : raspberrypi-iob                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi-iob                          - disabled
                              + system.adapter.sonoff.0                 : sonoff                : raspberrypi-iob                          -  enabled, port: 1883, bind: 0.0.0.0
                                system.adapter.sonos.0                  : sonos                 : raspberrypi-iob                          - disabled
                                system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi-iob                          - disabled
                                system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi-iob                          - disabled
                                system.adapter.sql.0                    : sql                   : raspberrypi-iob                          - disabled, port: 3306
                                system.adapter.systeminfo.0             : systeminfo            : raspberrypi-iob                          - disabled
                              + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi-iob                          -  enabled
                              + system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi-iob                          -  enabled
                              + system.adapter.telegram.0               : telegram              : raspberrypi-iob                          -  enabled, port: 8443, bind: 0.0.0.0
                                system.adapter.terminal.0               : terminal              : raspberrypi-iob                          - disabled, port: 8089, bind: 192.168.0.20, run as: admin
                                system.adapter.text2command.0           : text2command          : raspberrypi-iob                          - disabled
                                system.adapter.tr-064.0                 : tr-064                : raspberrypi-iob                          - disabled
                              + system.adapter.trashschedule.0          : trashschedule         : raspberrypi-iob                          -  enabled
                              + system.adapter.tuya.0                   : tuya                  : raspberrypi-iob                          -  enabled
                              + system.adapter.twinkly.0                : twinkly               : raspberrypi-iob                          -  enabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi-iob                          -  enabled
                                system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi-iob                          -  enabled
                                system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi-iob                          - disabled
                                system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi-iob                          -  enabled
                                system.adapter.vis-weather.0            : vis-weather           : raspberrypi-iob                          -  enabled
                                system.adapter.vis.0                    : vis                   : raspberrypi-iob                          - disabled
                                system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi-iob                          - disabled
                              + system.adapter.web.0                    : web                   : raspberrypi-iob                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + system.adapter.wled.0                   : wled                  : raspberrypi-iob                          -  enabled
                                system.adapter.yahka.0                  : yahka                 : raspberrypi-iob                          - disabled
                              + system.adapter.zigbee.0                 : zigbee                : raspberrypi-iob                          -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2219042-if00
                              + instance is alive
                              ioBroker-Repositories
                              Active repo(s): stable
                              Installed ioBroker-Instances
                              Used repository: stable
                              Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
                              Adapter    "admin"        : 6.12.0   , installed 6.12.0
                              Adapter    "alarm"        : 3.4.3    , installed 3.4.3
                              Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                              Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                              Adapter    "bmw"          : 2.5.7    , installed 2.6.3
                              Adapter    "bring"        : 1.8.4    , installed 1.8.4
                              Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                              Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                              Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
                              Adapter    "deconz"       : 1.3.23   , installed 1.3.23
                              Adapter    "device-reminder": 3.0.0  , installed 3.0.0
                              Adapter    "device-watcher": 2.9.6   , installed 2.9.6
                              Adapter    "echarts"      : 1.5.4    , installed 1.5.4
                              Adapter    "email"        : 1.2.0    , installed 1.2.0
                              Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
                              Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                              Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                              Adapter    "fhem"         : 2.0.5    , installed 2.0.5
                              Adapter    "firetv"       : 2.0.2    , installed 2.0.2
                              Adapter    "followthesun" : 0.5.0    , installed 0.5.0
                              Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                              Adapter    "geofency"     : 1.2.4    , installed 1.2.4
                              Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                              Adapter    "ham"          : 5.3.1    , installed 5.3.1
                              Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                              Adapter    "homekit-controller": 0.5.8, installed 0.5.8
                              Adapter    "ico-cloud"    : 1.1.0    , installed 1.1.0
                              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                              Adapter    "iot"          : 2.0.11   , installed 2.0.11
                              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                              Controller "js-controller": 5.0.17   , installed 5.0.17
                              Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                              Adapter    "linux-control": 1.1.5    , installed 1.1.5
                              Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
                              Adapter    "meater"       : 1.0.2    , installed 1.0.2
                              Adapter    "meross"       : 1.15.1   , installed 1.15.1
                              Adapter    "milight"      : 0.4.0    , installed 0.4.0
                              Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
                              Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
                              Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                              Adapter    "nina"         : 0.0.25   , installed 0.0.25
                              Adapter    "openweathermap": 0.4.5   , installed 0.4.5
                              Adapter    "parcel"       : 0.0.27   , installed 0.0.27
                              Adapter    "pegelalarm"   : 1.3.1    , installed 1.3.1
                              Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                              Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                              Adapter    "radar2"       : 2.1.0    , installed 2.1.0
                              Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
                              Adapter    "rflink"       : 2.1.6    , installed 2.1.6
                              Adapter    "ring"         : 5.0.10   , installed 5.0.10
                              Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                              Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
                              Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                              Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                              Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                              Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                              Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
                              Adapter    "sql"          : 2.2.0    , installed 2.2.0
                              Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
                              Adapter    "tankerkoenig" : 3.3.7    , installed 2.1.1  [Updatable]
                              Adapter    "tapo"         : 0.0.8    , installed 0.0.8
                              Adapter    "telegram"     : 3.0.0    , installed 3.0.0
                              Adapter    "telegram-menu": 0.8.5    , installed 0.8.5
                              Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                              Adapter    "text2command" : 3.0.2    , installed 3.0.2
                              Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                              Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                              Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
                              Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
                              Adapter    "vis-justgage" : 2.0.2    , installed 2.0.2
                              Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                              Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                              Adapter    "web"          : 6.1.10   , installed 6.1.10
                              Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                              Adapter    "wled"         : 0.7.1    , installed 0.7.1
                              Adapter    "ws"           : 2.5.8    , installed 2.5.8
                              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                              Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
                              Objects and States
                              Objects:        43552
                              States:         36961
                              Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                              Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              Hit:3 https://repos.influxdata.com/debian buster InRelease
                              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                              Reading package lists...
                              E: Broken packages
                              Pending Updates:
                              *** Listening Ports ***
                              tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      999        19577      626/perl
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18610      518/sshd
                              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          2202187    5032/cupsd
                              tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        19510      483/influxd
                              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          18932      950/exim4
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       27104      1383/io.sonoff.0
                              tcp        0      0 192.168.0.20:1888       0.0.0.0:*               LISTEN      1001       27920      1482/io.mqtt.0
                              tcp        0      0 0.0.0.0:7072            0.0.0.0:*               LISTEN      999        19673      626/perl
                              tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       30118      1512/io.shelly.1
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20438      494/iobroker.js-con
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       22087      494/iobroker.js-con
                              tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       27834      1785/adb
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22451      1240/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28090      1545/io.web.0
                              tcp6       0      0 :::8086                 :::*                    LISTEN      116        22538      483/influxd
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          18612      518/sshd
                              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          2202186    5032/cupsd
                              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       30744      1772/io.simple-api.
                              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          18933      950/exim4
                              tcp6       0      0 :::3306                 :::*                    LISTEN      115        19575      620/mysqld
                              udp        0      0 0.0.0.0:36758           0.0.0.0:*                           108        15778      383/avahi-daemon: r
                              udp        0      0 0.0.0.0:46538           0.0.0.0:*                           1001       742035     1560/io.broadlink2.
                              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       28246      1449/io.tuya.0
                              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       28247      1449/io.tuya.0
                              udp        0      0 0.0.0.0:38435           0.0.0.0:*                           1001       3053473    1560/io.broadlink2.
                              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       3087035    18343/io.shelly.0
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19117      417/dhcpcd
                              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          2203317    5034/cups-browsed
                              udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       28017      1560/io.broadlink2.
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       30007      1468/io.ham.0
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       27435      1886/io.wled.0
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15776      383/avahi-daemon: r
                              udp        0      0 0.0.0.0:56655           0.0.0.0:*                           1001       28042      1560/io.broadlink2.
                              udp        0      0 0.0.0.0:42336           0.0.0.0:*                           1001       33089      1560/io.broadlink2.
                              udp6       0      0 :::546                  :::*                                0          19160      417/dhcpcd
                              udp6       0      0 :::40119                :::*                                108        15779      383/avahi-daemon: r
                              udp6       0      0 :::5353                 :::*                                108        15777      383/avahi-daemon: r
                              2023-12-20 11:25:56.363  - debug: shelly.0 (18343) [httpIoBrokerState] State change 192.168.0.153 (shelly1 / shelly1-34945472D99E / SHSW-1#34945472D99E#1): state: SHSW-1#34945472D99E#1.Relay0.Timer, value: null
                              2023-12-20 11:25:56.364  - warn: shelly.0 (18343) [authEnabled] 192.168.0.153 (shelly1 / shelly1-34945472D99E / SHSW-1#34945472D99E#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-12-20 11:25:56.524  - warn: shelly.0 (18343) [authEnabled] 192.168.0.118 (shellydimmer / shellydimmer-D0E9B5 / SHDM-1#D0E9B5#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-12-20 11:25:56.546  - debug: shelly.0 (18343) [httpIoBrokerState] State change 192.168.0.153 (shelly1 / shelly1-34945472D99E / SHSW-1#34945472D99E#1): state: SHSW-1#34945472D99E#1.uptime, value: 770
                              2023-12-20 11:25:56.676  - debug: shelly.0 (18343) [httpIoBrokerState] State change 192.168.0.118 (shellydimmer / shellydimmer-D0E9B5 / SHDM-1#D0E9B5#1): state: SHDM-1#D0E9B5#1.uptime, value: 153
                              2023-12-20 11:25:56.677  - debug: shelly.0 (18343) [httpIoBrokerState] State change 192.168.0.118 (shellydimmer / shellydimmer-D0E9B5 / SHDM-1#D0E9B5#1): state: SHDM-1#D0E9B5#1.rssi, value: -77
                              2023-12-20 11:25:57.941  - info: host.raspberrypi-iob instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2023-12-20 11:25:58.539  - info: host.raspberrypi-iob instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2023-12-20 11:26:00.371  - debug: shelly.0 (18343) CoAP status package received: {"3332":"SHDM-1#D0E9B5#2","3412":38400,"3420":2304,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,0],[0,5101,30],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4101,0],[0,4103,1],[0,6102,0],[0,6109,0],[0,6104,0],[0,3104,42.86],[0,3105,109.14],[0,6101,0],[0,9101,"white"]]}
                              2023-12-20 11:26:00.372  - debug: shelly.0 (18343) [CoAP Server] Status update received for SHDM-1#D0E9B5#2: {"G":[[0,9103,0],[0,1101,0],[0,5101,30],[0,2101,0],[0,2102,""],[0,2103,0],[0,2201,0],[0,2202,""],[0,2203,0],[0,4101,0],[0,4103,1],[0,6102,0],[0,6109,0],[0,6104,0],[0,3104,42.86],[0,3105,109.14],[0,6101,0],[0,9101,"white"]]}
                              2023-12-20 11:26:00.372  - debug: shelly.0 (18343) CoAP device description request for SHDM-1#D0E9B5#2 to 192.168.0.118(0)
                              2023-12-20 11:26:00.375  - debug: shelly.0 (18343) [CoAP] State change 192.168.0.118 (shellydimmer / shellydimmer-D0E9B5 / SHDM-1#D0E9B5#1): state: SHDM-1#D0E9B5#1.lights.Energy, value: 0.02
                              2023-12-20 11:26:00.377  - debug: shelly.0 (18343) [CoAP] State change 192.168.0.118 (shellydimmer / shellydimmer-D0E9B5 / SHDM-1#D0E9B5#1): state: SHDM-1#D0E9B5#1.temperatureC, value: 42.86
                              2023-12-20 11:26:00.377  - debug: shelly.0 (18343) [CoAP] State change 192.168.0.118 (shellydimmer / shellydimmer-D0E9B5 / SHDM-1#D0E9B5#1): state: SHDM-1#D0E9B5#1.temperatureF, value: 109.14
                              2023-12-20 11:26:00.419  - debug: shelly.0 (18343) CoAP response: {"3332":"SHDM-1#D0E9B5#2"}
                              2023-12-20 11:26:00.420  - debug: shelly.0 (18343) Device description received: {"3332":"SHDM-1#D0E9B5#2"} / {"blk":[{"I":1,"D":"light_0"},{"I":2,"D":"input_0"},{"I":3,"D":"input_1"},{"I":4,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":4},{"I":1101,"T":"S","D":"output","R":"0/1","L":1},{"I":5101,"T":"S","D":"brightness","R":"1/100","L":1},{"I":2101,"T":"S","D":"input","R":"0/1","L":2},{"I":2102,"T":"EV","D":"inputEvent","R":["S/L",""],"L":2},{"I":2103,"T":"EVC","D":"inputEventCnt","R":"U16","L":2},{"I":2201,"T":"S","D":"input","R":"0/1","L":3},{"I":2202,"T":"EV","D":"inputEvent","R":["S/L",""],"L":3},{"I":2203,"T":"EVC","D":"inputEventCnt","R":"U16","L":3},{"I":4101,"T":"P","D":"power","U":"W","R":["0/230","-1"],"L":1},{"I":4103,"T":"E","D":"energy","U":"Wmin","R":["U32","-1"],"L":1},{"I":6102,"T":"A","D":"overpower","R":["0/1","-1"],"L":1},{"I":6109,"T":"P","D":"overpowerValue","U":"W","R":["U32","-1"],"L":1},{"I":6104,"T":"A","D":"loadError","R":"0/1","L":1},{"I":3104,"T":"T","D":"deviceTemp","U":"C","R":["-40/300","999"],"L":4},{"I":3105,"T":"T","D":"deviceTemp","U":"F","R":["-40/572","999"],"L":4},{"I":6101,"T":"A","D":"overtemp","R":["0/1","-1"],"L":4},{"I":9101,"T":"S","D":"mode","R":"color/white","L":4}]}
                              2023-12-20 11:26:00.421  - debug: shelly.0 (18343) [CoAP Server] Received device description for SHDM-1#D0E9B5#2 (192.168.0.118): {"blk":[{"I":1,"D":"light_0"},{"I":2,"D":"input_0"},{"I":3,"D":"input_1"},{"I":4,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":4},{"I":1101,"T":"S","D":"output","R":"0/1","L":1},{"I":5101,"T":"S","D":"brightness","R":"1/100","L":1},{"I":2101,"T":"S","D":"input","R":"0/1","L":2},{"I":2102,"T":"EV","D":"inputEvent","R":["S/L",""],"L":2},{"I":2103,"T":"EVC","D":"inputEventCnt","R":"U16","L":2},{"I":2201,"T":"S","D":"input","R":"0/1","L":3},{"I":2202,"T":"EV","D":"inputEvent","R":["S/L",""],"L":3},{"I":2203,"T":"EVC","D":"inputEventCnt","R":"U16","L":3},{"I":4101,"T":"P","D":"power","U":"W","R":["0/230","-1"],"L":1},{"I":4103,"T":"E","D":"energy","U":"Wmin","R":["U32","-1"],"L":1},{"I":6102,"T":"A","D":"overpower","R":["0/1","-1"],"L":1},{"I":6109,"T":"P","D":"overpowerValue","U":"W","R":["U32","-1"],"L":1},{"I":6104,"T":"A","D":"loadError","R":"0/1","L":1},{"I":3104,"T":"T","D":"deviceTemp","U":"C","R":["-40/300","999"],"L":4},{"I":3105,"T":"T","D":"deviceTemp","U":"F","R":["-40/572","999"],"L":4},{"I":6101,"T":"A","D":"overtemp","R":["0/1","-1"],"L":4},{"I":9101,"T":"S","D":"mode","R":"color/white","L":4}]}
                              2023-12-20 11:26:00.443  - warn: shelly.0 (18343) State value to set for "shelly.0.SHDM-1#D0E9B5#1.temperatureF" has value "109.14" greater than max "100"
                              2023-12-20 11:26:05.852  - debug: shelly.0 (18343) CoAP data ignored: {"3332":"SHSW-1#34945472D99E#2","3412":38400,"3420":1280,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,0],[0,2101,0],[0,2102,""],[0,2103,0]]}
                              2023-12-20 11:26:07.005  - warn: shelly.0 (18343) [authEnabled] 192.168.0.118 (shellydimmer / shellydimmer-D0E9B5 / SHDM-1#D0E9B5#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-12-20 11:26:07.099  - debug: shelly.0 (18343) [httpIoBrokerState] State change 192.168.0.118 (shellydimmer / shellydimmer-D0E9B5 / SHDM-1#D0E9B5#1): state: SHDM-1#D0E9B5#1.uptime, value: 164
                              2023-12-20 11:26:07.368  - debug: shelly.0 (18343) [httpIoBrokerState] State change 192.168.0.153 (shelly1 / shelly1-34945472D99E / SHSW-1#34945472D99E#1): state: SHSW-1#34945472D99E#1.Relay0.Timer, value: null
                              2023-12-20 11:26:07.387  - warn: shelly.0 (18343) [authEnabled] 192.168.0.153 (shelly1 / shelly1-34945472D99E / SHSW-1#34945472D99E#1): This device is not protected via restricted login (see adapter documentation for details)
                              2023-12-20 11:26:07.466  - debug: shelly.0 (18343) [httpIoBrokerState] State change 192.168.0.153 (shelly1 / shelly1-34945472D99E / SHSW-1#34945472D99E#1): state: SHSW-1#34945472D99E#1.uptime, value: 781
                              2023-12-20 11:26:07.466  - debug: shelly.0 (18343) [httpIoBrokerState] State change 192.168.0.153 (shelly1 / shelly1-34945472D99E / SHSW-1#34945472D99E#1): state: SHSW-1#34945472D99E#1.rssi, value: -80
                                part 2
                                                        v.2023-10-10
                                         Icon name: computer
                                      Architecture: arm
                                Installation:           native
                                Kernel:                 armv7l
                                Userland:               armhf
                                Timezone:               Europe/Berlin (CET, +0100)
                                User-ID:                1000
                                X-Server:               false
                                Boot Target:            graphical.target
                                Pending OS-Updates:
                                Pending iob updates:    1
                                Nodejs-Installation:    /usr/bin/nodejs         v18.0.0
                                                        /usr/bin/npm            8.6.0
                                                        /usr/bin/npx            8.6.0
                                Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                MEMORY:
                                Mem:           3.8G        2.5G        598M         53M        734M        1.1G
                                Swap:           10G        1.2G        9.0G
                                Total:          14G        3.7G        9.6G
                                Active iob-Instances:   41
                                ioBroker Core:          js-controller           5.0.17
                                                        admin                   6.12.0
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                43552
                                States:                 36943
                                Size of iob-Database:
                                67M     /opt/iobroker/iobroker-data/objects.jsonl
                                27M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                4.0K    /opt/iobroker/iobroker-data/objects.json.old
                                0       /opt/iobroker/iobroker-data/objects.json.broken
                                49M     /opt/iobroker/iobroker-data/states.jsonl
                                7.9M    /opt/iobroker/iobroker-data/states.json.migrated
                                7.9M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                6.3M    /opt/iobroker/iobroker-data/states.json.old
                                0       /opt/iobroker/iobroker-data/states.json.broken
                                  @tklein sagte in Linuxneustart nach Systemupdate nicht möglich // Paketupdate:
                                  Dann mach es dir einfach und zieh mit dem Stand auf ein frisches 64Bit Raspberry OS 'Bookworm' Lite um und lass den Trümmerhaufen da hinter dir.
                                  Tip am Rande: Schalt den Debug-Modus für den shelly aus.
                                    tklein @Thomas Braun last edited by
                                    --> die zig zigbee devices machen es mir echt nicht leicht. ferner bin ich mir bei der hardware auch noch nicht so sicher
                                    --> danke, hatte ich erst kürzlich eingeschaltet, da eine instanz mit http/coap nicht mehr schalten konnte. ich trage jetzt den iobroker mit dem port 5683 dort ein.
                                      Durch 'Updatescheu' wird es aber auch nicht leichter.
                                      Den RPI4 kannst du mit gescheitem Setup (sprich so schlank wie möglich) doch noch gut weiter verwenden.
                                      1385
