    4. [Neuer Adapter] Life360
    • CKMartens
      CKMartens last edited by CKMartens
      @bananajoe Hast Du das Problem lösen können. Bei mir zeigt er seit heute um 08:30 den gleichen Fehler gleiche an.
      @MiGoller Ich habe den Adapter testweise komplett deinstalliert und neu installiert, was aber keine Änderung gebracht hat.
      Hier das Debug-Log
      2023-12-20 16:05:33.433 - debug: life360.0 (78741) Objects client ready ... initialize now
      2023-12-20 16:05:33.718 - debug: life360.0 (78741) Objects create System PubSub Client
      2023-12-20 16:05:33.718 - debug: life360.0 (78741) Objects create User PubSub Client
      2023-12-20 16:05:33.854 - debug: life360.0 (78741) Objects client initialize lua scripts
      2023-12-20 16:05:33.858 - debug: life360.0 (78741) Objects connected to redis: 127.0.0.1:9001
      2023-12-20 16:05:33.958 - debug: life360.0 (78741) Redis States: Use Redis connection: 127.0.0.1:9000
      2023-12-20 16:05:33.988 - debug: life360.0 (78741) States create System PubSub Client
      2023-12-20 16:05:33.989 - debug: life360.0 (78741) States create User PubSub Client
      2023-12-20 16:05:34.091 - debug: life360.0 (78741) States connected to redis: 127.0.0.1:9000
      2023-12-20 16:05:34.319 - info: life360.0 (78741) starting. Version 0.2.21 (non-npm: MiGoller/ioBroker.life360#888e08024c2d93d86aa6eb74f281c574dce86c42) in /opt/iobroker/node_modules/iobroker.life360, node: v18.17.1, js-controller: 5.0.17
      2023-12-20 16:05:34.339 - debug: life360.0 (78741) Fetching Life360 cloud data ...
      2023-12-20 16:05:34.341 - debug: life360.0 (78741) Not authenticated against Life360. Will try to connect ...
      2023-12-20 16:05:34.341 - debug: life360.0 (78741) Connecting to Life360 service ...
      2023-12-20 16:05:34.351 - info: life360.0 (78741) Polling enabled every 60 seconds.
      2023-12-20 16:05:34.518 - error: life360.0 (78741) Connection established but failed to authenticate. Check your credentials!
      2023-12-20 16:05:34.519 - debug: life360.0 (78741) Auth tokens deleted.
      2023-12-20 16:05:34.521 - info: life360.0 (78741) Waiting for online operations to finish ...
      2023-12-20 16:05:34.524 - debug: life360.0 (78741) Not authenticated against Life360. Will try to connect ...
      2023-12-20 16:05:34.524 - debug: life360.0 (78741) Connecting to Life360 service ...
      2023-12-20 16:05:34.611 - error: life360.0 (78741) Connection established but failed to authenticate. Check your credentials!
      2023-12-20 16:05:34.612 - debug: life360.0 (78741) Auth tokens deleted.
      2023-12-20 16:05:34.613 - info: life360.0 (78741) Waiting for online operations to finish ...
      2023-12-20 16:05:34.614 - debug: life360.0 (78741) Not authenticated against Life360. Will try to connect ...
      2023-12-20 16:05:34.614 - debug: life360.0 (78741) Connecting to Life360 service ...
      2023-12-20 16:05:34.693 - error: life360.0 (78741) Connection established but failed to authenticate. Check your credentials!
      2023-12-20 16:05:34.693 - debug: life360.0 (78741) Auth tokens deleted.
      2023-12-20 16:05:34.694 - info: life360.0 (78741) Waiting for online operations to finish ...
      2023-12-20 16:05:34.696 - debug: life360.0 (78741) Not authenticated against Life360. Will try to connect ...
      2023-12-20 16:05:34.696 - debug: life360.0 (78741) Connecting to Life360 service ...
      2023-12-20 16:05:34.765 - error: life360.0 (78741) Connection established but failed to authenticate. Check your credentials!
      2023-12-20 16:05:34.765 - debug: life360.0 (78741) Auth tokens deleted.
      2023-12-20 16:05:34.767 - info: life360.0 (78741) Waiting for online operations to finish ...
      2023-12-20 16:05:34.767 - debug: life360.0 (78741) Not authenticated against Life360. Will try to connect ...
      2023-12-20 16:05:34.767 - debug: life360.0 (78741) Connecting to Life360 service ...
      2023-12-20 16:05:34.841 - error: life360.0 (78741) Connection established but failed to authenticate. Check your credentials!
      2023-12-20 16:05:34.842 - debug: life360.0 (78741) Auth tokens deleted.
      2023-12-20 16:05:34.843 - info: life360.0 (78741) Waiting for online operations to finish ...
      2023-12-20 16:05:34.843 - debug: life360.0 (78741) Not authenticated against Life360. Will try to connect ...
      2023-12-20 16:05:34.843 - debug: life360.0 (78741) Connecting to Life360 service ...
      2023-12-20 16:05:34.910 - error: life360.0 (78741) Connection established but failed to authenticate. Check your credentials!
      2023-12-20 16:05:34.910 - debug: life360.0 (78741) Auth tokens deleted.
      2023-12-20 16:05:34.911 - info: life360.0 (78741) Waiting for online operations to finish ...
      2023-12-20 16:05:34.912 - error: life360.0 (78741) Failed to connect or to login for 6 times. Aborting ...
      2023-12-20 16:05:34.912 - error: life360.0 (78741) Error: Error: Connection established but failed to authenticate. Check your credentials!
      2023-12-20 16:05:34.912 - debug: life360.0 (78741) Pushing cloud_data to callback function
      2023-12-20 16:05:34.913 - warn: life360.0 (78741) No data received from Life360 cloud services!
      2023-12-20 16:05:35.523 - debug: life360.0 (78741) Auth tokens deleted.
      2023-12-20 16:05:35.614 - debug: life360.0 (78741) Auth tokens deleted.
      2023-12-20 16:05:35.695 - debug: life360.0 (78741) Auth tokens deleted.
      2023-12-20 16:05:35.767 - debug: life360.0 (78741) Auth tokens deleted.
      2023-12-20 16:05:35.844 - debug: life360.0 (78741) Auth tokens deleted.
      2023-12-20 16:05:35.913 - debug: life360.0 (78741) Auth tokens deleted.
      Auf GitHub sind bereits mehrer Merldungen: https://github.com/MiGoller/ioBroker.life360/issues/83 und https://github.com/MiGoller/ioBroker.life360/issues/76
      benbensimpson created this issue in MiGoller/ioBroker.life360
      closed Verbindungsproblem 20.12.23 Check your credentials! #83
      juggi1962 created this issue in MiGoller/ioBroker.life360
      closed Die Verbindung wurde hergestellt, die Authentifizierung konnte jedoch nicht durchgeführt werden. Überprüfen Sie Ihre Anmeldedaten! #76
      • Merlin123
        Merlin123 last edited by
        @ckmartens Aktuell geht es bei mir auch nicht
        • BananaJoe
          BananaJoe Most Active last edited by
          und bei mir auch nicht, ich stoppe mal den Adapter
          App funktioniert noch
          Rababersaft 1 Reply Last reply Reply Quote 0
          • Rababersaft
            Rababersaft @BananaJoe last edited by
            @bananajoe
            bei mir auch genau dieselben Fehlermeldungen...😑
            • Knallochse
              Knallochse last edited by Knallochse
              Auf Github ist zu lesen, dass der Entwickler am Problem arbeitet.
              Ich kann aber sagen das @MiGoller immer Zeitnah Probleme am Adapter beseitigt hat. Gebt Ihm einfach Zeit. Er wird sich sicher melden, sobald es wieder geht.
              MiGoller 1 Reply Last reply Reply Quote 1
              • MiGoller
                MiGoller Developer @Knallochse last edited by
                Hallo zusammen, bitte noch etwas Geduld. Ich gehe grad noch meinem regulärem Job nach. Heute Abend gibt es den nächsten Stand. Auf meinem Entwicklungs-Server läuft der Adapter wieder. Werde nachher das Release vorbereiten.
                MiGoller 1 Reply Last reply Reply Quote 3
                • MiGoller
                  MiGoller Developer @MiGoller last edited by MiGoller
                  Update auf v0.2.22 steht per NPM oder über GitHub zur Verfügung. Ich drücke die Daumen... Euch und mir.
                  V Knallochse BananaJoe 3 Replies Last reply Reply Quote 4
                  • V
                    Verblizz @MiGoller last edited by
                    @migoller
                    läuft bei mir damit wieder, vielen Dank für Deinen Einsatz!
                    Rababersaft 1 Reply Last reply Reply Quote 2
                    • Rababersaft
                      Rababersaft @Verblizz last edited by Rababersaft
                      @verblizz
                      @migoller
                      dito, hier auch wieder 👍
                      Danke für den super schnellen Einsatz 😊
                      • Knallochse
                        Knallochse @MiGoller last edited by
                        @migoller Bei mir läuft es auch wieder. Vielen Dank für deinen hervorragenden Support.
                        • BananaJoe
                          BananaJoe Most Active @MiGoller last edited by
                          @migoller Funktioniert! Was haben sie diesmal wieder böses geändert?
                            Sandy last edited by Sandy
                            bei mir funktioniert es auch wieder, danke 🙂
                            LG Sandy
                            Rababersaft 1 Reply Last reply Reply Quote 1
                            • MiGoller
                              MiGoller Developer @BananaJoe last edited by
                              @bananajoe , bei der Abfrage der API müssen nun ein paar Header gesetzt sein, die in der Vergangenheit wohl eher optional waren; bislang funktionierte es auch ohne. Der API-Request nutzt jetzt die Browser-Kennung von Android statt von iOS Geräten. In dem Zusammenhang greift dann eine neue URL für die Authentifizierung.
                              Life360 scheint aber schon eine neue Version der API vorzubereiten. Zumindest bei iOS Geräten werden basierend auf der eindeutigen Device-ID mittels https://launchdarkly.com/ Einstellungen übermittelt. Hatte ich vorher auch noch nicht bei Life360 gesehen.
                              Langweilig wird es nicht damit. Life360 "schützt" den Service mit einer Closed-Source-API.
                              • Rababersaft
                                Rababersaft @Sandy last edited by
                                @sandy
                                Bei den Adaptern auf extern... (also die Katze 😻 ) und Life360 auswählen, Installieren/Updaten und freuen... 👌
                                  Pischleuder last edited by
                                  Guten Morgen,
                                  nachdem es mit der Version 0..2.22 zunächst zwei Tage fehlerfrei funktionierte, ist seit heute wieder Schluss - bei Euch auch ?
                                  Frohe Weihnachten Euch allen !
                                    michael 1975 last edited by
                                    Guten Morgen bei mir geht seit heute auch nichts mehr.
                                    Gruß Michael
                                      MrDisaster04 last edited by
                                      Guten Morgen,
                                      kann ich bestätigen bei mir geht es seit heute Morgen auch nicht mehr.
                                      Frohe Weihnachten noch.
                                      Thomas
                                      CKMartens 1 Reply Last reply Reply Quote 0
                                      • CKMartens
                                        CKMartens @MrDisaster04 last edited by
                                        @mrdisaster04 Ja fing um 2:30 heut nacht an.
                                        2023-12-24 02:31:18.433 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
                                        2023-12-24 02:31:18.438 - info: life360.0 (129585) Waiting for online operations to finish ...
                                        2023-12-24 02:31:18.438 - info: life360.0 (129585) Disconnected from Life360 cloud services.
                                        2023-12-24 02:31:18.680 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
                                        2023-12-24 02:31:18.681 - info: life360.0 (129585) Waiting for online operations to finish ...
                                        2023-12-24 02:31:18.923 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
                                        2023-12-24 02:31:18.924 - info: life360.0 (129585) Waiting for online operations to finish ...
                                        2023-12-24 02:31:19.270 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
                                        2023-12-24 02:31:19.271 - info: life360.0 (129585) Waiting for online operations to finish ...
                                        2023-12-24 02:31:19.495 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
                                        2023-12-24 02:31:19.497 - info: life360.0 (129585) Waiting for online operations to finish ...
                                        2023-12-24 02:31:19.732 - error: life360.0 (129585) Connection established but failed to authenticate. Check your credentials!
                                        2023-12-24 02:31:19.733 - info: life360.0 (129585) Waiting for online operations to finish ...
                                        2023-12-24 02:31:19.733 - error: life360.0 (129585) Failed to connect or to login for 6 times. Aborting ...
                                        2023-12-24 02:31:19.734 - error: life360.0 (129585) Error: Error: Connection established but failed to authenticate. Check your credentials!
                                        2023-12-24 02:31:19.734 - warn: life360.0 (129585) No data received from Life360 cloud services!
                                        MiGoller 1 Reply Last reply Reply Quote 0
                                        • MiGoller
                                          MiGoller Developer @CKMartens last edited by
                                          Guten Morgen zusammen, das ist ja eine Bescherung. Dier Störung behandeln wir in Github unter https://github.com/MiGoller/ioBroker.life360/issues/86 .
                                          Bislang kann ich den Fehler allerdings nicht nachstellen: Es läuft bei mir auf dem produktiven wie auch auf meinem Entwicklungsserver ohne Probleme. Das macht es mir grad schwierig, etwas zu tun. Bislang sieht es so aus, als würde auch das Neuinstallieren des Adapters nicht helfen, wenn das Problem aufgetreten ist.
                                          Ich versuche, einen einfachen Checker zu programmieren, mit dem Ihr die Funktionalität ohne den Adapter testen könnt. Das an Heiligabend... macht meine Family nicht happy.
                                          CKMartens created this issue in MiGoller/ioBroker.life360
                                          closed Wieder verbindungsprobleme Error: Error: Connection established but failed to authenticate. Check your credentials! #86
                                          • MiGoller
                                            Bei einem Benutzer war das Life360 Kennwort abgelaufen. Ist beim erneuten Anmelden in der mobilen App aufgefallen. Das neue Passwort im ioBroker eingetragen. und dann lief es wieder. Mal schauen, ob das ein Einzelfall ist.
                                            adapter geoposition life360 präsenzmelder
                                            85
                                            708
                                            167037
