    4. Nochmal Waschmaschine (Blockly)
    • totocotonio
      totocotonio last edited by
      ier nochmal das Blockly.
      <xml xmlns="http://www.w3.org/1999/xhtml"><block type="variables_set" id="pE;t15K()B2=@=,RY5D_" x="-887" y="-362"><field name="VAR">GrenzWertInWatt</field>
      <value name="VALUE"><block type="math_number" id="OB=)nO2pXH:1HNwm(JpG"><field name="NUM">2.5</field></block></value>
      <next><block type="comment" id="|2tm%?,yK/o3_AA)J{ah"><field name="COMMENT">Steckdose überwachen</field></block></next></block>
      <block type="procedures_defnoreturn" id="l1.gm`YNTt2#Ww;Stf+" x="-312" y="-362"><mutation><arg name="Meldetext"></arg></mutation>
      <field name="NAME">Melden</field>
      <statement name="STACK"><block type="debug" id="SYQu;@N0JgE!W~[JZcZ
      "><field name="Severity">log</field>
      <value name="TEXT"><shadow type="text" id="4+J8c.^+FrkDV^]dAda-"><field name="TEXT">test</field></shadow>
      <block type="variables_get" id="KuX^Hf4/i6gnp|rmq9WR"><field name="VAR">Meldetext</field></block></value>
      <next><block type="telegram" id="wH+*?1;8L0VjK1Z7kg[i"><value name="MESSAGE"><shadow type="text" id="%5P)E^1xJK@PFTHr7#jG"><field name="TEXT">text</field></shadow>
      <block type="variables_get" id="b+NYSEXrl]fx5Ms:F4Jp"><field name="VAR">Meldetext</field></block></value>
      <next><block type="sayit" id="L08o^d?@yXer@xqmnYm~"><field name="INSTANCE">.0</field>
                  <value name="MESSAGE"><shadow type="text" id="*h*{19qD(UEh5(s,SJRw"><field name="TEXT">Die Waschmaschine ist fertig</field></shadow>
                    <block type="variables_get" id="M4mldn4_f3]|4z?b;=gv"><field name="VAR">Meldetext</field></block></value></block></next></block></next></block></statement></block>
      <block type="on_ext" id="n)UklDS{=z!-#^HfL@Ly" x="-1012" y="-287"><mutation items="1"></mutation>
      <value name="OID0"><shadow type="field_oid" id="@Uda~stBc8L/=2DFzrvo"><field name="oid">hm-rpc.0.KEQ0964000.2.POWER</field></shadow></value>
      <statement name="STATEMENT"><block type="controls_if" id="=n/Jfc]x(Ib[NRPJZ%7X"><mutation elseif="3"></mutation>
          <value name="IF0"><block type="logic_compare" id="?m1STicTe5=N-/f:Ji2s"><field name="OP">EQ</field>
              <value name="A"><block type="on_source" id="QjKQBx`PdHENcy)eGM,5"><field name="ATTR">oldState.val</field></block></value>
              <value name="B"><block type="math_number" id=":(p2PWPzD2(~R-q9upeS"><field name="NUM">2.5</field></block></value></block></value>
          <statement name="DO0"><block type="timeouts_settimeout" id="v[ws-ZxN:-nNl,kERlT8"><field name="NAME">Einschaltverzögerung</field>
              <field name="DELAY">10</field>
              <statement name="STATEMENT"><block type="comment" id="UyUTD{W;Ef;u2!)%y5h|"><field name="COMMENT">Funkstecker wurde eingeschaltet</field>
                  <next><block type="comment" id="^wiM;VZ*5RLS-+SMsG7?"><field name="COMMENT">Einschaltleistung abfangen</field></block></next></block></statement></block></statement>
          <value name="IF1"><block type="logic_operation" id="s(;r=_ekdU*dF=_Tsrbb" inline="false"><field name="OP">AND</field>
              <value name="A"><block type="logic_compare" id="d_lZY_VlNaa40/Pob=Um"><field name="OP">GT</field>
                  <value name="A"><block type="on_source" id="`c4GU.`+o2_G+Vdxq;n/"><field name="ATTR">state.val</field></block></value>
                  <value name="B"><block type="variables_get" id="FD[JnQcwajuYLgGmTX`."><field name="VAR">GrenzWertInWatt</field></block></value></block></value>
              <value name="B"><block type="logic_compare" id="zC,(}TPXAvX2yd^k`W._"><field name="OP">EQ</field>
                  <value name="A"><block type="get_value" id=";a;[[bw/v2oQnG9DHZIn"><field name="ATTR">val</field>
                      <field name="OID">javascript.0.WaschmaschineFertig</field></block></value>
                  <value name="B"><block type="logic_boolean" id=";a5=vVD`86hstjR{4y~+"><field name="BOOL">FALSE</field></block></value></block></value></block></value>
          <statement name="DO1"><block type="control" id="S6URE:3#}}.v#e!X.A4D"><mutation delay_input="false"></mutation>
              <value name="VALUE"><block type="logic_boolean" id="QqpwRU?xP?P=bvS9HS[1"><field name="BOOL">TRUE</field></block></value>
              <next><block type="procedures_callnoreturn" id="=!*WIp};Ta`)XeMMk,iR"><mutation name="Melden"><arg name="Meldetext"></arg></mutation>
                  <value name="ARG0"><block type="text" id="{QcAY3oi:,FGG.929?TS"><field name="TEXT">Waschmaschine LÄUFT</field></block></value></block></next></block></statement>
          <value name="IF2"><block type="logic_compare" id="Yuagp|w@)mC+asceXLLu"><field name="OP">GT</field>
              <value name="A"><block type="on_source" id="P(tu4AS{);E?w-p?]{1q"><field name="ATTR">state.val</field></block></value>
              <value name="B"><block type="variables_get" id="ou6,Zi?vbs[;{]@93U`!"><field name="VAR">GrenzWertInWatt</field></block></value></block></value>
          <statement name="DO2"><block type="comment" id="H90l#sdGb5I}Wqsbz=9s"><field name="COMMENT">Timer stoppen</field>
              <next><block type="procedures_callnoreturn" id="zo=cPu~=j#pus6bWVaJl"><mutation name="checkFertig"><arg name="parameter"></arg></mutation>
                  <value name="ARG0"><block type="logic_boolean" id="1SYbGS^3xkqD/Uj?{bvJ"><field name="BOOL">FALSE</field></block></value></block></next></block></statement>
          <value name="IF3"><block type="logic_operation" id="_@|YxZPYI(z3![Q=ZbX4" inline="false"><field name="OP">AND</field>
              <value name="A"><block type="logic_compare" id="Ge6FX#6b5WYoc;wF%%iH"><field name="OP">LT</field>
                  <value name="A"><block type="on_source" id="0Vw33+AwVD~={g{aHa~d"><field name="ATTR">state.val</field></block></value>
                  <value name="B"><block type="variables_get" id="NufLwbvZR1.fEmqJNOTZ"><field name="VAR">GrenzWertInWatt</field></block></value></block></value>
              <value name="B"><block type="logic_compare" id="X[1t=zl25bQ]aHT[:`,8"><field name="OP">EQ</field>
                  <value name="A"><block type="get_value" id="4WFkiPOYU?#zQhOL)0u("><field name="ATTR">val</field>
                  <value name="B"><block type="logic_boolean" id="?jrLY7K)k;1?sa!Ef{VO"><field name="BOOL">TRUE</field></block></value></block></value></block></value>
          <statement name="DO3"><block type="comment" id="}Q59!:8+Dc~b~LwZhq-("><field name="COMMENT">Timer starten</field>
              <next><block type="procedures_callnoreturn" id=";MD%1IF[[H29g_f=vvYH"><mutation name="checkFertig"><arg name="parameter"></arg></mutation>
                  <value name="ARG0"><block type="logic_boolean" id="/yX*,4aU!HHUO#/2U-NR"><field name="BOOL">TRUE</field></block></value></block></next></block></statement></block></statement></block>
      <block type="procedures_defnoreturn" id="sDP?w~)oJD}Z95[?EY0" x="-262" y="-12"><mutation><arg name="parameter"></arg></mutation>
      <field name="NAME">checkFertig</field>
      <statement name="STACK"><block type="comment" id="V2@7jqv5RTl+}q}xfEsZ"><field name="COMMENT">Timer stoppen</field>
      <next><block type="timeouts_cleartimeout" id="y7iPL;/^^,);q|%Pk6;"><field name="NAME">timeout</field>
      <next><block type="controls_if" id="DX-|5t
      M5.|5Qw0p76"><value name="IF0"><block type="logic_compare" id="[-Hs2uzeFf6L7XO4:d6g"><field name="OP">EQ</field>
      <value name="A"><block type="variables_get" id="uT*6f!Y:?Sivq1F-y;7
      "><field name="VAR">parameter</field></block></value>
      <value name="B"><block type="logic_boolean" id="w?1)4.uK{/ey3NJ)NjH:"><field name="BOOL">TRUE</field></block></value></block></value>
      <statement name="DO0"><block type="comment" id="fU`TRz:hy1K[t@GmyY:"><field name="COMMENT">Timer starten</field>
      <next><block type="timeouts_settimeout" id="k%sy5:QdTn+3f@{OZshs"><field name="NAME">timeout</field>
      <field name="DELAY">5</field>
      <statement name="STATEMENT"><block type="control" id="UOquZ.)w|Dv~5_@iC
      HO"><mutation delay_input="false"></mutation>
      <value name="VALUE"><block type="logic_boolean" id="ttQizIf!/AB*HLfb9Kw1"><field name="BOOL">FALSE</field></block></value>
      <next><block type="procedures_callnoreturn" id="HHrpaU=vtt6v1JInTG~l"><mutation name="Melden"><arg name="Meldetext"></arg></mutation>
      <value name="ARG0"><block type="text" id="leE4:W;JI@,LD;n0Gs6r"><field name="TEXT">Die Waschmaschine ist FERTIG</field></block></value></block></next></block></statement></block></next></block></statement></block></next></block></next></block></statement></block></xml>
        LastActionHero last edited by
        mh, wenn ich das einfüge bekomm ich folgende Meldung:
        TypeError: c.nextConnection is null :?:
        • rantanplan
          rantanplan last edited by
          @LastActionHero:
          TypeError: c.nextConnection is null :?: `
          Wenn Du Was Wo einfügst?
            wenn ich den Export von totocotonio kopiere und in ein leeres Block script importieren möchte (Button mit dem Pfeil nach oben, links neben Blöcke prüfen).
            • totocotonio
              Das sollte aber gehen.
              Bei mir hat es einwandfrei funktioniert.
              Neues Script, blockly wählen über die Pfeiltasten einfügen fertg.
                Gerade getestet; kann ich nicht reproduzieren.
                Weder beim Import noch beim Start des Skripts
                Rainer
                  so ein mist, ích habs grade nochmal am laptop probiert und mit IE statt Firefox, gleiches spielchen! Bei google findet man dazu auch nix, was kann das denn schon wieder sein!?
                  Bei Edge spuckt er mir folgendes aus: TypeError: Unable to get property 'isConnected' of undefined or null reference
                    Mir kommt da was.
                    Is_connected sind ggf. Neuere objekte beinAdaptern die in früheren versionen nicht angelegt wurden.
                    Ich muss morgen mal den code überprüfen, bin schon im Bett.
                    Gruß Rainer
                      wäre auf jeden fall geil! besten Dank schonmal!
                        Ich habe mittlerweile den gesamten code gescannt.
                        "is_comnnected" kann ich nicht finden.
                        Ich weiß also nicht wo diese Meldung hinpasst.
                        Tut mir leid. Ich kommen mit deinen Hinweisen der Ursache von dem Fehler nicht auf die Schliche.
                        Rainer
                        • rantanplan
                          @LastActionHero:
                          Bei Edge spuckt er mir folgendes aus: TypeError: Unable to get property 'isConnected' of undefined or null reference `
                          Kannst Du meinen Export auch nicht importieren?
                            @rantanplan:
                            Kannst Du meinen Export auch nicht importieren? `
                            das hat jetzt komischerweise funktioniert! jetzt habe ich nur noch 2 bzw. 3 fragen:
                            1. Den Datenpunkt homestatus.0.sonstige.waschmaschineAN muss ich noch anlegen, korrekt?
                            2. Muss ich noch weitere Datenpunkte anlegen? Soweit ich das überblickt habe, glaube ich nicht?!
                            3. Wie funktioniert die Melde-Funktion? Wo meldet der das hin? das würde ich prinzipiell gerne gegen eine Push-Meldung per Telegramm/EMail ersetzen
                            EDIT
                            Oar ist das nervig, jetzt kann ich zwar die blocks importieren, aber nicht speichern. wenn ich auf speichern klicke nimmt er den befehl einfach nicht an und speichert nichts davon
                            • rantanplan
                              @LastActionHero:
                              1. Den Datenpunkt homestatus.0.sonstige.waschmaschineAN muss ich noch anlegen, korrekt? `
                              Richtig. Die kannst Du benennen wie Du möchtest. Wenn Du die manuell anlegst gib ihr den Typ Logikwert.
                              @LastActionHero:
                              2. Muss ich noch weitere Datenpunkte anlegen? Soweit ich das überblickt habe, glaube ich nicht?! `
                              Jepp, alles andere sind lokale Variablen
                              @LastActionHero:
                              3. Wie funktioniert die Melde-Funktion? Wo meldet der das hin? das würde ich prinzipiell gerne gegen eine Push-Meldung per Telegramm/EMail ersetzen `
                              Einfach den gewünschten Baustein nehmen.
                              @LastActionHero:
                              Oar ist das nervig, jetzt kann ich zwar die blocks importieren, aber nicht speichern. wenn ich auf speichern klicke nimmt er den befehl einfach nicht an und speichert nichts davon `
                              Hast Du unter "sendto" auch die entsprechenden Bausteine? Hast Du die Adapter für Telegram, Mail usw. installiert?
                              Auch mal ins LOG schauen!
                              Ich packe demnächst eine überarbeitete Version ins Forum
                              Darin beachte ich auch die berechtigten Hinweise von Dutchman :oops:
                              • totocotonio
                                da der Thread sich scheinbar als sehr lesenswert erweist,
                                könnte man das fertige Script doch irgendwo zB. in einer Rubrik fertige Scripte
                                veröffentlichen oder :?:
                                  Also ich habe den Datenpunkt der Steckdose und den WaschmaschineAN entsprechend geändert, ansonsten habe ich das script erstmal so belassen wie du es hier gepostet hast. Ich komme garnicht soweit dass ich das log einsehen könnte weil er den block einfach nicht speichert. Im globalen log steht nichts dazu. Es tut sich nichts wenn ich auf speichern klicke. Öffne ich ein anderes script mault er das aktuelle sei noch nicht gespeichert aber selbst wenn ich in dem popup auf speichern klicke passiert nichts.
                                  • rantanplan
                                    @totocotonio:
                                    veröffentlichen oder :?: `
                                    Diese Rubrik gibt es nicht.
                                    Wenn ich fertige Scripts einstelle haben die immer [Vorlage] im Betreff
                                    • totocotonio
                                      noch nicht.
                                      Wäre das nicht etwas was man vielleicht mal überlegen sollte. 😉
                                        fertige Skripte gibt es im Downloadbereich der Homepage.
                                        Ich muss aber die Info eines Skripters bekommen, wenn ein neues, gutes, script von allgemeinem Interesse fertig ist, damit ich es dort einfügen kann.
                                        Rainer
                                          Speicherproblem ist gelöst. Es lag am Telegram Adapter, den hatte ich installiert, danach aber iobroker nicht neugestartet. Die Script instanz hatte die Befehle daher nicht.
                                          • totocotonio
                                            @Homoran:
                                            Ich muss aber die Info eines Skripters bekommen, wenn ein neues, gutes, script von allgemeinem Interesse fertig ist, damit ich es dort einfügen kann. `
                                            Okay,
                                            dann bin ich mal gespannt wie sich unsere Scripter entscheiden. 😉
                                            Ich von meiner Seite aus, bin sehr zufrieden damit und habe es an einigen Geräten laufen. :lol:
                                            1.0k
                                            153
                                            29686
