    3. Entwicklung
    4. Daten aus Fronius Solarweb auslesen
      habe am WE den js-Controller upgedatet.
      Jetzt sehe ich im log Fehler des Fronius Adapters
      fronius-solarweb.0
      	2023-12-06 16:38:27.366	error	Error: read ECONNRESET
      fronius-solarweb.0
      	2023-12-06 16:38:27.366	error	https://swqapi.solarweb.com/pvsystems/langeZahl/aggdata
      fronius-solarweb.0
      	2023-12-06 16:38:27.358	error	Error: read ECONNRESET
      fronius-solarweb.0
      	2023-12-06 16:38:27.357	error	https://swqapi.solarweb.com/pvsystems/langeZahl/aggdata/years/2023
      fronius-solarweb.0
      	2023-12-06 16:38:27.175	error	Error: read ECONNRESET
      fronius-solarweb.0
      	2023-12-06 16:38:27.175	error	https://swqapi.solarweb.com/pvsystems/langeZahl/weather/current
      fronius-solarweb.0
      	2023-12-06 16:38:26.984	error	Error: read ECONNRESET
      fronius-solarweb.0
      	2023-12-06 16:38:26.984	error	https://swqapi.solarweb.com/pvsystems/langeZahl/histdata?from=1701787111708&to=1701873506708
      fronius-solarweb.0
      	2023-12-06 16:38:26.929	error	Error: read ECONNRESET
      fronius-solarweb.0
      	2023-12-06 16:38:26.928	error	https://swqapi.solarweb.com/pvsystems/langeZahl/flowdata
      Neustart mit debug level bringt
      starting. Version 0.0.3 (non-npm: TA2k/ioBroker.fronius-solarweb#cf999langezahl ) in C:/ioBroker/node_modules/iobroker.fronius-solarweb, node: v16.15.1, js-controller: 5.0.16
      Und dann nichts mehr, Adapter bleibt gelb
      Doch mittlerweile sehe ich:
      2023-12-06 16:56:26.494 - debug: fronius-solarweb.0 (3600) Objects client ready ... initialize now
      2023-12-06 16:56:26.495 - debug: fronius-solarweb.0 (3600) Objects create System PubSub Client
      2023-12-06 16:56:26.496 - debug: fronius-solarweb.0 (3600) Objects create User PubSub Client
      2023-12-06 16:56:26.592 - debug: fronius-solarweb.0 (3600) Objects client initialize lua scripts
      2023-12-06 16:56:26.596 - debug: fronius-solarweb.0 (3600) Objects connected to redis: 127.0.0.1:9001
      2023-12-06 16:56:26.597 - silly: fronius-solarweb.0 (3600) redis psubscribe cfg.o.system.user.*
      2023-12-06 16:56:26.648 - silly: fronius-solarweb.0 (3600) redis psubscribe cfg.o.enum.*
      2023-12-06 16:56:26.650 - silly: fronius-solarweb.0 (3600) objectDB connected
      2023-12-06 16:56:26.652 - debug: fronius-solarweb.0 (3600) Redis States: Use Redis connection: 127.0.0.1:9000
      2023-12-06 16:56:26.695 - debug: fronius-solarweb.0 (3600) States create System PubSub Client
      2023-12-06 16:56:26.696 - debug: fronius-solarweb.0 (3600) States create User PubSub Client
      2023-12-06 16:56:26.762 - debug: fronius-solarweb.0 (3600) States connected to redis: 127.0.0.1:9000
      2023-12-06 16:56:26.762 - silly: fronius-solarweb.0 (3600) statesDB connected
      2023-12-06 16:56:26.805 - debug: fronius-solarweb.0 (3600) Plugin sentry Initialize Plugin (enabled=true)
      2023-12-06 16:56:27.134 - info: fronius-solarweb.0 (3600) starting. Version 0.0.3 (non-npm: TA2k/ioBroker.fronius-solarweb#langeZahl) in C:/ioBroker/node_modules/iobroker.fronius-solarweb, node: v16.15.1, js-controller: 5.0.16
      2023-12-06 16:56:27.184 - silly: fronius-solarweb.0 (3600) States system redis pmessage system.adapter.fronius-solarweb.0.logLevel/system.adapter.fronius-solarweb.0.logLevel:{"val":"silly","ack":true,"ts":1701878187182,"q":0,"from":"system.adapter.fronius-solarweb.0","lc":1701878187182}
      2023-12-06 16:56:27.192 - silly: fronius-solarweb.0 (3600) States user redis pmessage fronius-solarweb.0.*/fronius-solarweb.0.info.connection:{"val":false,"ack":true,"ts":1701878187191,"q":0,"from":"system.adapter.fronius-solarweb.0","user":"system.user.admin","lc":1701877169527}
      Verbindet sich nicht mit Dienst
      Webzugang zum Fronius solarweb über Browser geht aber
      Hat jemand eine Idee? Liegt es am neuen js-Controller, hat Fronius Solarweb etwas geändert oder habe ich sonstwas verschusselt?
      Vielen Dank!
        reutli @klassisch last edited by
        @klassisch
        muss das nicht eher da rein: https://forum.iobroker.net/topic/51550/test-adapter-fronius-solarweb/99?
        Ich nutze den Adapter nicht...
        Ansonsten mal ein issue in Github aufmachen...
          klassisch Most Active @reutli last edited by
          @reutli Vielen Dank und Sorry! Habe die Frage mal dort platziert.
            Snopy_16 @c1olli last edited by Snopy_16
            @c1olli
            wie hast du das gelöst?
            EDIT: Hat sich erledigt
              TimoWald @Snopy_16 last edited by
              Bei mir sind sämtliche Datenpunkte vertauscht. Ist der Fehler bekannt?
              zb. Bei ertrag stehen die KM, usw.
              Symo Gen24 8 plus mit FW 1.27.3-1
                Snopy_16 @JB_Sullivan last edited by
                @jb_sullivan
                Ich will mir auch noch eigene Spalten (berechnet aus Datenpunkten) in der Tabelle anzeigen lassen.
                Autarkiegrad, Eigenverbrauchverhältnis, ...
                Wie muss die Berechnungsformel z.B.: für den Eigenverbrauch % in Javascript aussehen?
                Komme mit meinen bescheiden JS Kenntnissen einfach nicht dahinter.
                Kannst du mir bitte behilflich sein?
                • JB_Sullivan
                  JB_Sullivan @Snopy_16 last edited by JB_Sullivan
                  @snopy_16
                  so z.B. für den Eigenverbrauch in %. Ist halt viel rumgemache um einen neuen Wert zu errechnen. Funktioniert aber mit allem was du ausrechnen willst nach dem gleichen Prinzip.
                  var idDp3 = "0_userdata.0.Solarweb.Current.05_Annual_Months.02_February.Energy.EnergySelfConsumptionTotal";
                  var idDp4 = "0_userdata.0.Solarweb.Current.05_Annual_Months.02_February.Energy.EnergyProductionTotal";
                  var dp3, dp4, ergebnis2;
                  dp3 = getState(idDp3).val;
                  dp4 = getState(idDp4).val;
                  ergebnis2 = Math.round((dp3/dp4)*100 * 100)/100;
                  HTML+=" <td align=right bgcolor=#F2F5A9>" + ergebnis2 + " %</td>";		//
                    @jb_sullivan
                    Super👍
                    Herzlichen Dank😁
                      @JB_Sullivan
                      Habs zwischenzeitlich so hingebogen - funktioniert auch. War für mich aber auch eine schwere Geburt🤔
                      HTML+=" <td align=right bgcolor=#A9F5BC>" + Math.round((getState("0_userdata.0.Solarweb.Current.05_Annual_Months.02_February.Energy.EnergySelfConsumptionTotal").val / getState("0_userdata.0.Solarweb.Current.05_Annual_Months.02_February.Energy.EnergyProductionTotal").val) * 1000) / 10 + " %</td>"; //Eigenverbrauchsverhältnis
                      Trotzdem nochmal vielen Dank für deine Hilfe und Input
                      • maximal1981
                        maximal1981 last edited by
                        hab mal eine Frage:
                        was ist der Unterscheid zwischen:
                        0_userdata.0.Solarweb.Current.05_Annual_Months.12_December.Energy.EnergyDirectConsumption
                        und
                        0_userdata.0.Solarweb.Current.05_Annual_Months.12_December.Energy.EnergySelfConsumption?
                        Ich hab nämlich seit kurzem einen Wattpilot in Betrieb, und ich vermute, dass ich den Konsum nicht sehe, da ich auf EnergyDirectConsumption schaue
                          Strobelix @maximal1981 last edited by
                          @maximal1981
                          Self = Eigenverbrauch und der errechnet sich aus Direktverbrauch + Batterieladung
                          Eigenverbrauch ist als inkl Batterieladung, Direktverbrauch ist ohne
                          maximal1981 1 Reply Last reply Reply Quote 0
                          • JB_Sullivan
                            Hat heute irgendwer Solarweb Werte bekommen? Auch mit DP forcing kommt bei mir nix an. Alle Werte für die neue Woche stehen noch auf Null.
                            K maloross 2 Replies Last reply Reply Quote 0
                              klassisch Most Active @JB_Sullivan last edited by
                              @jb_sullivan Ich schaue gerne nach. Welche Werte ändern sich in SolarWeb tagsüber?
                              Der Wert in history.fronius-solarweb.0.MEINE NUMMER.day.EnergyProductionTotal.values.25.json
                              wurde heute zum einzigen und letzten Mal gegen 00:17 geändert.
                              Die gestrige Tagesdatei wurde kurz vor 18:00 nochmals befüllt.
                              Also schon ein Unterschied.
                              Die Datei fronius-solarweb.0.MEINENUMMER.total.EnergyProductionTotal.values.total
                              wurde zuletzt gegen 07:47 geändert.
                              Der Adapter hat keine Fehlermeldungen im log hinterlassen.
                              • maloross
                                maloross @JB_Sullivan last edited by
                                @jb_sullivan
                                Die heutige Werte sind bei mir zuletzt um 18:45 Uhr geändert worden:
                                Im Ordner "Current" wurden Tag, Woche, Wochentag abgerufen und befüllt, scheint also zu funktionieren.
                                  klassisch Most Active @maloross last edited by
                                  @maloross Wo ist der Ordner "current"?
                                  maloross 1 Reply Last reply Reply Quote 0
                                  • maloross
                                    maloross @klassisch last edited by
                                    @klassisch ups sry, dass sind die Daten, die von einem Skript generiert werden, dass hier veröffentlicht wurde. Hier beziehe ich meine Daten für diverse Auswertungen;
                                    aber auch im Adapter habe ich aktuelle Daten von heute. Die sind im Ordner "day" wie z.B. EnergyDirecConsumption, EnergyProduction, EnergyPurchased usw.
                                    • JB_Sullivan
                                      Vielen Dank für die Antworte - hmmmmm dann muss ich mal abwarten, denn ich habe nix an meinem System verändert von gestern auf heute.
                                      letzte Aktualisierung um 00:02 Uhr
                                      • maloross
                                        @jb_sullivan das finde ich auch sehr seltsam.
                                        Noch zur Info: Ich habe Update-Intervall auf 120 Minuten eingestellt, vielleicht führen kürzere Intervalle zu einem solchen Verhalten. Ist aber nur eine Vermutung.
                                        • JB_Sullivan
                                          JB_Sullivan @maloross last edited by
                                          @maloross
                                          Wir sprechen aber von Strobelix seinem Skript und nicht von tombox seinem Adapter? Also ich hatte bis jetzt immer den Aktualisierungsintervall auf 60 Minuten stehen. Nun habe ich es aber auch mal auf 120 Minuten erhöht.
                                          Alle Skripte wurden neu gestartet - es werden aber nur Value 0,0 abgeholt.
                                          • maloross
                                            @jb_sullivan ich nutze hauptsächlich das Skript von Strobelix für die Statistik, habe aber auch einige Werte aus dem Adapter für meine Statistiken.
                                            Beim Skript hatte ich mehrfach Fehler und habe dann aus Verzweiflung das Intervall erhöht. Seitdem habe ich keine weiteren Ausfälle mehr gehabt - ob es da aber einen Zusammenhang gibt??
                                            1.0k
                                            619
                                            184512
