    4. Probleme mit Zigbee.Adapter
      Thomas Braun Most Active @igor123 last edited by
      @igor123 sagte in Probleme mit Zigbee.Adapter:
      Vor einigen Tagen hatte ich den js controller installiert und genauso Nodejs - evtl. ist hier was schief gelaufen?
      Kann man vielleicht anhand der Langfassung der Ausgabe von
      iob diag
      sagen.
      • I
        igor123 @Thomas Braun last edited by
        @thomas-braun sagte in Probleme mit Zigbee.Adapter:
        iob diag
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 5.15.74-v7l+
              Architecture: arm
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
         21:21:06 up 11 days, 23:48,  1 user,  load average: 0.85, 0.69, 0.63
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Thu 2023-12-21 21:21:06 CET
                   Universal time: Thu 2023-12-21 20:21:06 UTC
                         RTC time: n/a
                        Time zone: Europe/Vienna (CET, +0100)
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.9G        1.7G        4.3G        0.0K        2.0G        6.0G
        Swap:            99M          0B         99M
        Total:          8.0G        1.7G        4.4G
                 7897 M total memory
                 1660 M used memory
                 1046 M active memory
                 2377 M inactive memory
                 4273 M free memory
                  206 M buffer memory
                 1756 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4      235G   13G  210G   6% /
        devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  848K  1.6G   1% /run
        /dev/sda1      vfat      253M   50M  203M  20% /boot
        tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
        [Sat Dec  9 21:32:46 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:47:61:6D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=79238543-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Sat Dec  9 21:32:48 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Sat Dec  9 21:32:48 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Sat Dec  9 21:32:50 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
        4.5G    /var/
        3.0G    /var/log
        2.9G    /var/log/journal/45677fd33dca4b97838c0214e7692911
        822M    /var/cache
        Archived and active journals take up 2.8G in the file system.
        /opt/iobroker/backups:
        383M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.2G    /opt/iobroker/iobroker-data/
        537M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
        331M    /opt/iobroker/iobroker-data/files
        41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/wolke-3/.pioenvs/wolke-3/libFrameworkArduino.a
        24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.pioenvs/test/libFrameworkArduino.a
        24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/rfid/.pioenvs/rfid/libFrameworkArduino.a
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2256619-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.5.1
        /usr/bin/node           v20.5.1
        /usr/bin/npm            9.8.0
        /usr/bin/npx            9.8.0
        /usr/bin/corepack       0.19.0
        nodejs:
          Installed: 20.5.1-deb-1nodesource1
          Candidate: 20.5.1-deb-1nodesource1
          Version table:
         *** 20.5.1-deb-1nodesource1 100
                100 /var/lib/dpkg/status
             16.20.2-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.12.0
        javascript:     7.1.6
        Adapters from github:   1
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        + system.adapter.esphome.0                : esphome               : raspberrypi                              -  enabled
          system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
          system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : raspberrypi                              -  enabled
        + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
          system.adapter.hmip.0                   : hmip                  : raspberrypi                              - disabled
        + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
          system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              - disabled
          system.adapter.material.0               : material              : raspberrypi                              - disabled
        + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
          system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
        + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1299
        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1299, bind: 0.0.0.0
        + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : raspberrypi                              -  enabled, port: 16021
          system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
        + system.adapter.roomba.0                 : roomba                : raspberrypi                              -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.shelly.1                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 192.168.1.99
        + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 192.168.1.99, run as: admin
        + system.adapter.sonoff.1                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
        + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
        + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
          system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 1491
        + system.adapter.systeminfo.0             : systeminfo            : raspberrypi                              -  enabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
          system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
          system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
          system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.168.1.99, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
        + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
          system.adapter.windows-control.0        : windows-control       : raspberrypi                              - disabled
        + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "backitup"     : 2.8.7    , installed 2.8.7
        Adapter    "deconz"       : 1.3.23   , installed 1.3.23
        Adapter    "fuelpricemonitor": 0.4.0 , installed 0.3.6  [Updatable]
        Adapter    "harmony"      : 1.3.0    , installed 1.3.0
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "hmip"         : 1.20.0   , installed 1.20.0
        Adapter    "hue"          : 3.10.1   , installed 3.10.1
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
        Adapter    "material"     : 1.3.1    , installed 1.3.1
        Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
        Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
        Adapter    "nanoleaf-lightpanels": 1.4.0, installed 1.4.0
        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
        Adapter    "roomba"       : 1.2.2    , installed 1.2.2
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
        Adapter    "synology"     : 3.0.1    , installed 3.0.1
        Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
        Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
        Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
        Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.73
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
        Adapter    "windows-control": 0.1.5  , installed 0.1.5
        Adapter    "wled"         : 0.7.1    , installed 0.7.1
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
        Objects and States
        Objects:        8329
        States:         6939
        Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
        Hit:5 https://www.pivccu.de/piVCCU stable InRelease
        Reading package lists...
        Pending Updates: 128
        *** Listening Ports ***
        tcp        0      0 192.168.1.99:8084       0.0.0.0:*               LISTEN      1001       5727015    2925/io.socketio.0
        tcp        0      0 192.168.1.99:8082       0.0.0.0:*               LISTEN      1001       5726928    2783/io.web.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12435      765/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5722808    1678/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5722803    1678/iobroker.js-co
        tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          12462      819/dnsmasq
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       5726272    1993/io.sonoff.1
        tcp        0      0 0.0.0.0:1300            0.0.0.0:*               LISTEN      1001       5727509    2165/io.mqtt.0
        tcp        0      0 0.0.0.0:1299            0.0.0.0:*               LISTEN      1001       5727508    2165/io.mqtt.0
        tcp        0      0 192.168.1.99:42010      0.0.0.0:*               LISTEN      1001       11456098   4789/io.hm-rpc.0
        tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       5729169    2907/python3.8
        tcp6       0      0 :::61991                :::*                    LISTEN      1001       5728354    2341/io.harmony.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12437      765/sshd: /usr/sbin
        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       7245397    13935/io.sonos.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5722866    1701/io.admin.0
        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       5728355    2341/io.harmony.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       5727392    1979/io.shelly.0
        udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          12461      819/dnsmasq
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          12458      819/dnsmasq
        udp        0      0 192.168.1.99:5353       0.0.0.0:*                           1001       5731427    2907/python3.8
        udp        0      0 10.0.3.1:5353           0.0.0.0:*                           1001       5731426    2907/python3.8
        udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       5731425    2907/python3.8
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       5731418    2907/python3.8
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       5731369    2842/io.esphome.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       5726938    2803/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9081       399/avahi-daemon: r
        udp        0      0 0.0.0.0:36614           0.0.0.0:*                           108        9083       399/avahi-daemon: r
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       5727715    2367/io.nanoleaf-li
        udp6       0      0 :::33192                :::*                                108        9084       399/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        9082       399/avahi-daemon: r
        2023-12-21 21:12:53.984  - warn: sonos.0 (13935) State "sonos.0.root.192_168_1_7.current_track_number" has no existing object, this might lead to an error in future versions
        2023-12-21 21:12:54.263  - warn: sonos.0 (13935) State "sonos.0.root.192_168_1_7.current_track_number" has no existing object, this might lead to an error in future versions
        2023-12-21 21:15:00.026  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 started with pid 6308
        2023-12-21 21:15:02.442  - info: tvspielfilm.0 (6308) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.5.1, js-controller: 5.0.17
        2023-12-21 21:15:04.573  - info: tvspielfilm.0 (6308) objects written
        2023-12-21 21:15:15.087  - info: tvspielfilm.0 (6308) Terminated (NO_ERROR): Without reason
        2023-12-21 21:15:15.653  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
        2023-12-21 21:15:57.855  - warn: sonos.0 (13935) State "sonos.0.root.192_168_1_7.current_track_number" has no existing object, this might lead to an error in future versions
        2023-12-21 21:16:10.635  - warn: sonos.0 (13935) State "sonos.0.root.192_168_1_7.current_track_number" has no existing object, this might lead to an error in future versions
        2023-12-21 21:16:20.732  - warn: sonos.0 (13935) State "sonos.0.root.192_168_1_7.current_track_number" has no existing object, this might lead to an error in future versions
        2023-12-21 21:16:26.604  - warn: sonos.0 (13935) State "sonos.0.root.192_168_1_7.current_track_number" has no existing object, this might lead to an error in future versions
        2023-12-21 21:16:32.160  - warn: sonos.0 (13935) State "sonos.0.root.192_168_1_7.current_track_number" has no existing object, this might lead to an error in future versions
        2023-12-21 21:20:00.055  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 started with pid 6757
        2023-12-21 21:20:02.425  - info: tvspielfilm.0 (6757) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.5.1, js-controller: 5.0.17
        2023-12-21 21:20:04.544  - info: tvspielfilm.0 (6757) objects written
        2023-12-21 21:20:15.058  - info: tvspielfilm.0 (6757) Terminated (NO_ERROR): Without reason
        2023-12-21 21:20:15.615  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
        2023-12-21 21:20:25.026  - info: host.raspberrypi instance system.adapter.fuelpricemonitor.0 started with pid 6786
        2023-12-21 21:20:27.164  - info: fuelpricemonitor.0 (6786) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        2023-12-21 21:20:27.327  - info: fuelpricemonitor.0 (6786) starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.fuelpricemonitor, node: v20.5.1, js-controller: 5.0.17
        2023-12-21 21:20:27.349  - info: fuelpricemonitor.0 (6786) Started with JSON-Explorer version 0.1.12
        2023-12-21 21:20:27.444  - info: fuelpricemonitor.0 (6786) Delay execution by 23744ms to better spread API calls
        2023-12-21 21:20:57.406  - info: fuelpricemonitor.0 (6786) Terminated (NO_ERROR): Without reason
        2023-12-21 21:20:57.932  - info: fuelpricemonitor.0 (6786) cleaned everything up...
        2023-12-21 21:20:57.972  - info: host.raspberrypi instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
          Ernsthaft?
          nodejs ist auch falsch installiert.
          iob stop
          iob fix
          iob nodejs-update
          sollte das wieder auf Spur bringen.
          • I
            iob stop iob fix iob nodejs-update
            da sieht man mal wieder wie wenig ahnung von dem ganzen habe und es doch irgendwie so halb funkt 😄
            Hab das mal ausgeführt - soweit fertig - den fehler vom Zigbee-Adapter erhielt ich nun nicht mehr - danke für die rasche hilfe!
            Das Problem mit dem states habe ich nur leider weiterhin 😕
              Dann jetzt nochmal die Ausgabe von
              iob diag
              • I
                iob diag
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm
                Docker          : false
                Kernel          : armv7l
                Userland        : armhf
                 21:46:24 up 12 days, 13 min,  1 user,  load average: 0.65, 1.11, 1.07
                CPU threads: 4
                Current issues:
                               Local time: Thu 2023-12-21 21:46:24 CET
                           Universal time: Thu 2023-12-21 20:46:24 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            7.9G        1.2G        5.9G        0.0K        731M        6.4G
                Swap:            99M          0B         99M
                Total:          8.0G        1.2G        6.0G
                         7897 M total memory
                         1241 M used memory
                          249 M active memory
                         1505 M inactive memory
                         5925 M free memory
                          175 M buffer memory
                          556 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /dev/root      ext4      235G   14G  210G   6% /
                `-/var/lib/piVCCU/dtb /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                /var:
                4.9G    /var/
                3.0G    /var/log
                1.2G    /var/cache/apt/archives
                USB-Devices by-id:
                /usr/bin/nodejs         v18.19.0
                /usr/bin/node           v18.19.0
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                /usr/bin/corepack       0.22.0
                nodejs:
                  Installed: 18.19.0-1nodesource1
                  Candidate: 18.19.0-1nodesource1
                  Version table:
                 *** 18.19.0-1nodesource1 1001
                        500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                     18.18.2-1nodesource1 1001
                     18.18.1-1nodesource1 1001
                     18.18.0-1nodesource1 1001
                     18.17.1-1nodesource1 1001
                     18.17.0-1nodesource1 1001
                     18.16.1-1nodesource1 1001
                     18.16.0-1nodesource1 1001
                     18.15.0-1nodesource1 1001
                     18.14.2-1nodesource1 1001
                     18.14.1-1nodesource1 1001
                     18.14.0-1nodesource1 1001
                     18.13.0-1nodesource1 1001
                     18.12.0-1nodesource1 1001
                     18.11.0-1nodesource1 1001
                     18.10.0-1nodesource1 1001
                     18.9.1-1nodesource1 1001
                     18.9.0-1nodesource1 1001
                     18.8.0-1nodesource1 1001
                     18.7.0-1nodesource1 1001
                     18.6.0-1nodesource1 1001
                     18.5.0-1nodesource1 1001
                     18.4.0-1nodesource1 1001
                     18.3.0-1nodesource1 1001
                     18.2.0-1nodesource1 1001
                     18.1.0-1nodesource1 1001
                     18.0.0-1nodesource1 1001
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        8329
                States:         6957
                Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                Pending Updates: 56
                tcp        0      0 192.168.1.99:8084       0.0.0.0:*               LISTEN      1001       11528397   17301/io.socketio.0
                tcp        0      0 192.168.1.99:8082       0.0.0.0:*               LISTEN      1001       11528301   17195/io.web.0
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       11521841   16407/iobroker.js-c
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11521834   16407/iobroker.js-c
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11524556   16610/io.sonoff.1
                tcp        0      0 0.0.0.0:1300            0.0.0.0:*               LISTEN      1001       11526322   16709/io.mqtt.0
                tcp        0      0 0.0.0.0:1299            0.0.0.0:*               LISTEN      1001       11526321   16709/io.mqtt.0
                tcp        0      0 192.168.1.99:42010      0.0.0.0:*               LISTEN      1001       11523969   16689/io.hm-rpc.0
                tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       11527566   17290/python3.8
                tcp6       0      0 :::61991                :::*                    LISTEN      1001       11524831   16821/io.harmony.0
                tcp6       0      0 :::3500                 :::*                    LISTEN      1001       11526223   16629/io.sonos.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11524428   16426/io.admin.0
                udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       11524832   16821/io.harmony.0
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11523827   16598/io.shelly.0
                udp        0      0 192.168.1.99:5353       0.0.0.0:*                           1001       11530289   17290/python3.8
                udp        0      0 10.0.3.1:5353           0.0.0.0:*                           1001       11530288   17290/python3.8
                udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       11530287   17290/python3.8
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11530280   17290/python3.8
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11530208   17242/io.esphome.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11530155   17211/io.wled.0
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       11526529   16843/io.nanoleaf-l
                2023-12-21 21:44:39.126  - info: socketio.0 (17301) starting. Version 6.6.0 in /opt/iobroker/node_modules/iobroker.socketio, node: v18.19.0, js-controller: 5.0.17
                2023-12-21 21:44:39.175  - warn: socketio.0 (17301) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                2023-12-21 21:44:39.223  - info: socketio.0 (17301) socket.io server listening on port 8084
                2023-12-21 21:44:39.782  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.229
                2023-12-21 21:44:39.830  - info: wled.0 (17211) Initialising : " WLED" on IP :  192.168.1.229
                2023-12-21 21:44:40.091  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.16
                2023-12-21 21:44:40.123  - info: wled.0 (17211) WLED connected
                2023-12-21 21:44:42.499  - info: vis-google-fonts.0 (17321) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v18.19.0, js-controller: 5.0.17
                2023-12-21 21:44:43.096  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.26
                2023-12-21 21:44:43.136  - info: vis-google-fonts.0 (17321) Terminated (NO_ERROR): Without reason
                2023-12-21 21:44:43.756  - info: host.raspberrypi instance system.adapter.vis-google-fonts.0 terminated while should be started once
                2023-12-21 21:44:46.103  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.27
                2023-12-21 21:44:48.646  - info: roomba.0 (17265) Subscripe Leafnode: _runCommand.
                2023-12-21 21:44:49.107  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.6
                2023-12-21 21:44:52.112  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.210
                2023-12-21 21:44:55.118  - info: wled.0 (17211) Bonjour service started, new  devices  will  be detected automatically
                2023-12-21 21:45:00.061  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 started with pid 17385
                2023-12-21 21:45:02.684  - info: tvspielfilm.0 (17385) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.19.0, js-controller: 5.0.17
                2023-12-21 21:45:04.818  - info: tvspielfilm.0 (17385) objects written
                2023-12-21 21:45:05.143  - info: wled.0 (17211) WLED initialisation finalized, ready to do my job have fun !
                2023-12-21 21:45:15.335  - info: tvspielfilm.0 (17385) Terminated (NO_ERROR): Without reason
                2023-12-21 21:45:15.942  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
                2023-12-21 21:45:18.473  - info: admin.0 (16426) ==> Connected system.user.admin from ::ffff:192.168.1.22
                2023-12-21 21:45:18.881  - info: zigbee.0 (16677) List of port: [{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2256619","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2256619-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyS0"}]
                2023-12-21 21:45:30.212  - info: admin.0 (16426) <== Disconnect system.user.admin from ::ffff:192.168.1.22
                  Pending Updates: 56
                  Da klemmt noch was.
                  sudo apt update
                  sudo apt full-upgrade
                  sudo reboot
                    Und statt /dev/ttyACM0 trägst du im Zigbee-Adapter das als COM-Port ein:
                    • I
                      Pending Updates: 56
                      Da klemmt noch was.
                      sudo apt update
                      sudo reboot
                      so - erledigt
                      habe ich nun getan
                      bleibt dann nur leider auf gelb
                        so - erledigt
                        iob diag
                        sagt?
                        • I
                          so - erledigt
                          iob diag
                          sagt?
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                      Kernel: Linux 6.1.21-v7l+
                                Architecture: arm
                          Docker          : false
                          Kernel          : armv7l
                          Userland        : armhf
                           22:08:16 up 8 min,  1 user,  load average: 0.41, 0.74, 0.50
                          CPU threads: 4
                          Current issues:
                                         Local time: Thu 2023-12-21 22:08:16 CET
                                     Universal time: Thu 2023-12-21 21:08:16 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            7.9G        1.3G        6.3G        0.0K        280M        6.4G
                          Swap:            99M          0B         99M
                          Total:          8.0G        1.3G        6.4G
                                   7897 M total memory
                                   1294 M used memory
                                    120 M active memory
                                   1340 M inactive memory
                                   6322 M free memory
                                     39 M buffer memory
                                    241 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          tmpfs          tmpfs     1.6G  852K  1.6G   1% /run
                          /dev/sda1      vfat      253M   51M  202M  20% /boot
                          [Thu Dec 21 21:59:38 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:47:61:6D vc_mem.        mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=79238        543-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Thu Dec 21 21:59:40 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Quota mode: none.
                          [Thu Dec 21 21:59:40 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
                          [Thu Dec 21 21:59:42 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharse        t=ascii,shortname=mixed,flush,errors=remount-ro
                          /var:
                          4.9G    /var/
                          3.0G    /var/log
                          41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.ma        p
                          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.m        ap
                          24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/wolke-3/.pioenvs/wo        lke-3/libFrameworkArduino.a
                          24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.pioenvs/test/        libFrameworkArduino.a
                          24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/rfid/.pioenvs/rfid/        libFrameworkArduino.a
                          USB-Devices by-id:
                          USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                            Version table:
                                  500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package        s
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.12.0
                          javascript:     7.1.6
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
                          + system.adapter.zigbee.0                 : zigbee                : raspberrypi        -  enabled, port: /dev/serial/by-id/usb-dresden_ele        ktronik_ingenieurtechnik_GmbH_ConBee_II_DE2256619-if00
                          + instance is alive
                          Objects and States
                          Objects:        8334
                          States:         6960
                          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                          Hit:3 http://phoscon.de/apt/deconz bullseye InRelease
                          Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                          Pending Updates: 0
                          Proto Recv-Q Send-Q Local Address           Foreign Address         State        User       Inode      PID/Program name
                          tcp        0      0 192.168.1.99:42010      0.0.0.0:*               LISTEN        1001       27073      4407/io.hm-rpc.0
                          tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN        1001       26964      4351/python3.8
                          tcp        0      0 0.0.0.0:1299            0.0.0.0:*               LISTEN        1001       19853      3015/io.mqtt.0
                          tcp        0      0 0.0.0.0:1300            0.0.0.0:*               LISTEN        1001       19854      3015/io.mqtt.0
                          tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN        0          11142      795/dnsmasq
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN        1001       17029      2442/io.sonoff.1
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN        0          1832       766/sshd: /usr/sbin
                          tcp        0      0 192.168.1.99:8084       0.0.0.0:*               LISTEN        1001       23174      4353/io.socketio.0
                          tcp        0      0 192.168.1.99:8082       0.0.0.0:*               LISTEN        1001       22993      4247/io.web.0
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN        1001       14423      728/iobroker.js-con
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN        1001       14410      728/iobroker.js-con
                          tcp6       0      0 :::8081                 :::*                    LISTEN        1001       15888      1299/io.admin.0
                          tcp6       0      0 :::3500                 :::*                    LISTEN        1001       17061      2498/io.sonos.0
                          tcp6       0      0 :::22                   :::*                    LISTEN        0          1834       766/sshd: /usr/sbin
                          tcp6       0      0 :::61991                :::*                    LISTEN        1001       21723      3646/io.harmony.0
                          udp        0      0 0.0.0.0:61991           0.0.0.0:*        1001       21724      3646/io.harmony.0
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*        1001       16351      2209/io.shelly.0
                          udp        0      0 10.0.3.1:53             0.0.0.0:*        0          11141      795/dnsmasq
                          udp        0      0 0.0.0.0:67              0.0.0.0:*        0          11138      795/dnsmasq
                          udp        0      0 127.0.0.1:5353          0.0.0.0:*        1001       23116      4351/python3.8
                          udp        0      0 10.0.3.1:5353           0.0.0.0:*        1001       23115      4351/python3.8
                          udp        0      0 192.168.1.99:5353       0.0.0.0:*        1001       23114      4351/python3.8
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*        1001       23106      4351/python3.8
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*        1001       26224      4301/io.esphome.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*        1001       22206      4264/io.wled.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*        108        12268      392/avahi-daemon: r
                          udp        0      0 0.0.0.0:41294           0.0.0.0:*        108        12270      392/avahi-daemon: r
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*        1001       22597      3717/io.nanoleaf-li
                          udp6       0      0 :::5353                 :::*        108        12269      392/avahi-daemon: r
                          udp6       0      0 :::57676                :::*        108        12271      392/avahi-daemon: r
                          2023-12-21 22:07:43.068  - info: host.raspberrypi stopInstance system.adapter.zi        gbee.0 (force=false, process=true)
                          2023-12-21 22:07:43.240  - info: zigbee.0 (4621) Got terminate signal TERMINATE_        YOURSELF
                          2023-12-21 22:07:43.245  - info: host.raspberrypi stopInstance system.adapter.zi        gbee.0 send kill signal
                          2023-12-21 22:07:43.243  - info: zigbee.0 (4621) cleaned everything up...
                          2023-12-21 22:07:43.335  - info: zigbee.0 (4621) Zigbee: disabling joining new d        evices.
                          2023-12-21 22:07:43.516  - info: zigbee.0 (4621) terminating
                          2023-12-21 22:07:43.518  - info: zigbee.0 (4621) Terminated (ADAPTER_REQUESTED_T        ERMINATION): Without reason
                          2023-12-21 22:07:43.633  - info: admin.0 (1299) <== Disconnect system.user.admin        from ::ffff:192.168.1.22
                          2023-12-21 22:07:43.744  - info: zigbee.0 (4621) terminating
                          2023-12-21 22:07:44.184  - info: host.raspberrypi instance system.adapter.zigbee        .0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2023-12-21 22:07:46.494  - info: host.raspberrypi instance system.adapter.zigbee        .0 started with pid 4877
                          2023-12-21 22:07:50.386  - info: zigbee.0 (4877) Plugin sentry Sentry Plugin dis        abled for this process because sending of statistic data is disabled for the sys        tem
                          2023-12-21 22:07:50.717  - info: zigbee.0 (4877) starting. Version 1.8.24 in /op        t/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                          2023-12-21 22:07:50.811  - info: zigbee.0 (4877) delete old Backup files. keep o        nly last 10
                          2023-12-21 22:07:50.813  - info: zigbee.0 (4877) Starting Zigbee  npm ...
                          2023-12-21 22:07:51.138  - info: zigbee.0 (4877) Installed Version: iobroker.zig        bee@1.8.24
                          2023-12-21 22:07:51.537  - error: zigbee.0 (4877) Starting zigbee-herdsman probl        em : "Error while opening serialport 'Error: Error: No such file or directory, c        annot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee        _II_DE2256619-if00'"
                          2023-12-21 22:07:51.538  - error: zigbee.0 (4877) Failed to start Zigbee
                          2023-12-21 22:07:51.538  - error: zigbee.0 (4877) Error herdsman start
                          2023-12-21 22:08:01.539  - info: zigbee.0 (4877) Try to reconnect. 1 attempts le        ft
                          2023-12-21 22:08:01.541  - info: zigbee.0 (4877) Starting Zigbee  npm ...
                          2023-12-21 22:08:01.555  - info: zigbee.0 (4877) Installed Version: iobroker.zig        bee@1.8.24
                          2023-12-21 22:08:01.704  - error: zigbee.0 (4877) Starting zigbee-herdsman probl        em : "Error while opening serialport 'Error: Error: No such file or directory, c        annot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee        _II_DE2256619-if00'"
                          2023-12-21 22:08:01.705  - error: zigbee.0 (4877) Failed to start Zigbee
                          2023-12-21 22:08:01.706  - error: zigbee.0 (4877) Error herdsman start
                            Hmmm.
                            apt policy udev
                            sagt?
                            • I
                              Hmmm.
                              apt policy udev
                              sagt?
                              udev:
                                Installiert:           247.3-7+rpi1+deb11u2
                                Installationskandidat: 247.3-7+rpi1+deb11u2
                                Versionstabelle:
                               *** 247.3-7+rpi1+deb11u2 500
                                @igor123
                                echo "deb http://deb.debian.org/debian bullseye-backports main contrib non-free" | sudo tee /etc/apt/sources.list.d/buster-backports.list
                                sudo apt update
                                Dann die Ausgabe von
                                apt policy udev
                                • I
                                  igor123 @Thomas Braun last edited by igor123
                                  @igor123
                                  sudo apt update
                                  apt policy udev
                                  udev:
                                    Versionstabelle:
                                  @Thomas-Braun Wobei ich bei sudo apt update glaube ich einen fehler erhalten habe:
                                   sudo apt update
                                  Holen:1 http://deb.debian.org/debian bullseye-backports InRelease [49,0 kB]
                                  OK:2 http://phoscon.de/apt/deconz bullseye InRelease
                                  OK:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                  OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                  OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  OK:6 https://apt.pivccu.de/piVCCU stable InRelease
                                  Fehl:1 http://deb.debian.org/debian bullseye-backports InRelease
                                    Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher                                         Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B8264                                        3E131
                                  Paketlisten werden gelesen… Fertig
                                  W: GPG-Fehler: http://deb.debian.org/debian bullseye-backports InRelease: Die fo                                        lgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüss                                        el nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                                  E: Das Depot »http://deb.debian.org/debian bullseye-backports InRelease« ist nic                                        ht signiert.
                                  N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art dur                                        chgeführt werden, daher ist es standardmäßig deaktiviert.
                                  N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfigur                                        ation finden Sie in der Handbuchseite apt-secure(8).
                                    sudo apt update
                                    apt policy udev
                                    • I
                                      sudo apt update
                                      apt policy udev
                                      habe ich bereits getan:
                                       sudo apt update
                                      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                      OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                      OK:4 http://phoscon.de/apt/deconz bullseye InRelease
                                        Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                                      W: GPG-Fehler: http://deb.debian.org/debian bullseye-backports InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                                      E: Das Depot »http://deb.debian.org/debian bullseye-backports InRelease« ist nicht signiert.
                                      N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                                      N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                                       apt policy udev
                                      udev:
                                        Versionstabelle:
                                        Thomas Braun Most Active @igor123 last edited by Thomas Braun
                                        @igor123
                                        Solche Fehler sind natürlich wichtig...
                                        sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 6ED0E7B82643E131
                                        sudo apt update
                                        apt policy udev
                                        Und mach dein puTTY-Fenster etwas größer, das zerballert die Zeilen sonst.
                                        • I
                                          @igor123
                                          sudo apt update
                                          apt policy udev
                                          leider das selbe
                                          sudo apt update
                                          pi@raspberrypi:~ $ apt policy udev
                                          udev:
                                            Versionstabelle:
                                          edit:
                                          Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
                                          Executing: /tmp/apt-key-gpghome.RyObX1JTYq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 6ED0E7B82643E131
                                          gpg: Empfangen vom Schlüsselserver fehlgeschlagen: Server indicated a failure
                                          empfangsfehler..
                                            sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9
                                            1562
