    4. Probleme mit Zigbee.Adapter
    • I
      igor123 @Thomas Braun last edited by
      @thomas-braun sagte in Probleme mit Zigbee.Adapter:
      @igor123 sagte in Probleme mit Zigbee.Adapter:
      Hab das mal ausgeführt - soweit fertig -
      Dann jetzt nochmal die Ausgabe von
      iob diag
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.15.74-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       21:46:24 up 12 days, 13 min,  1 user,  load average: 0.65, 1.11, 1.07
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Thu 2023-12-21 21:46:24 CET
                 Universal time: Thu 2023-12-21 20:46:24 UTC
                       RTC time: n/a
                      Time zone: Europe/Vienna (CET, +0100)
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.9G        1.2G        5.9G        0.0K        731M        6.4G
      Swap:            99M          0B         99M
      Total:          8.0G        1.2G        6.0G
               7897 M total memory
               1241 M used memory
                249 M active memory
               1505 M inactive memory
               5925 M free memory
                175 M buffer memory
                556 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4      235G   14G  210G   6% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  848K  1.6G   1% /run
      /dev/sda1      vfat      253M   50M  203M  20% /boot
      tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
      [Sat Dec  9 21:32:46 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:47:61:6D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=79238543-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sat Dec  9 21:32:48 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat Dec  9 21:32:48 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sat Dec  9 21:32:50 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
      TARGET                SOURCE    FSTYPE OPTIONS
      /                     /dev/sda2 ext4   rw,noatime
      |-/boot               /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      `-/var/lib/piVCCU/dtb /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
      4.9G    /var/
      3.0G    /var/log
      2.9G    /var/log/journal/45677fd33dca4b97838c0214e7692911
      1.2G    /var/cache/apt/archives
      Archived and active journals take up 2.8G in the file system.
      /opt/iobroker/backups:
      383M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.2G    /opt/iobroker/iobroker-data/
      537M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
      331M    /opt/iobroker/iobroker-data/files
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/wolke-3/.pioenvs/wolke-3/libFrameworkArduino.a
      24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.pioenvs/test/libFrameworkArduino.a
      24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/rfid/.pioenvs/rfid/libFrameworkArduino.a
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2256619-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.esphome.0                : esphome               : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
        system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : raspberrypi                              -  enabled
      + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        system.adapter.hmip.0                   : hmip                  : raspberrypi                              - disabled
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
        system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              - disabled
        system.adapter.material.0               : material              : raspberrypi                              - disabled
      + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
        system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
      + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1299
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1299, bind: 0.0.0.0
      + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : raspberrypi                              -  enabled, port: 16021
        system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
      + system.adapter.roomba.0                 : roomba                : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shelly.1                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 192.168.1.99
      + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 192.168.1.99, run as: admin
      + system.adapter.sonoff.1                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
      + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
        system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 1491
      + system.adapter.systeminfo.0             : systeminfo            : raspberrypi                              -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
        system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
        system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
        system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.168.1.99, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
        system.adapter.windows-control.0        : windows-control       : raspberrypi                              - disabled
      + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "deconz"       : 1.3.23   , installed 1.3.23
      Adapter    "fuelpricemonitor": 0.4.0 , installed 0.3.6  [Updatable]
      Adapter    "harmony"      : 1.3.0    , installed 1.3.0
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "hmip"         : 1.20.0   , installed 1.20.0
      Adapter    "hue"          : 3.10.1   , installed 3.10.1
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
      Adapter    "nanoleaf-lightpanels": 1.4.0, installed 1.4.0
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "roomba"       : 1.2.2    , installed 1.2.2
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
      Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
      Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
      Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.73
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "windows-control": 0.1.5  , installed 0.1.5
      Adapter    "wled"         : 0.7.1    , installed 0.7.1
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
      Objects and States
      Objects:        8329
      States:         6957
      Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:5 https://www.pivccu.de/piVCCU stable InRelease
      Reading package lists...
      Pending Updates: 56
      *** Listening Ports ***
      tcp        0      0 192.168.1.99:8084       0.0.0.0:*               LISTEN      1001       11528397   17301/io.socketio.0
      tcp        0      0 192.168.1.99:8082       0.0.0.0:*               LISTEN      1001       11528301   17195/io.web.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12435      765/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       11521841   16407/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11521834   16407/iobroker.js-c
      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          12462      819/dnsmasq
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11524556   16610/io.sonoff.1
      tcp        0      0 0.0.0.0:1300            0.0.0.0:*               LISTEN      1001       11526322   16709/io.mqtt.0
      tcp        0      0 0.0.0.0:1299            0.0.0.0:*               LISTEN      1001       11526321   16709/io.mqtt.0
      tcp        0      0 192.168.1.99:42010      0.0.0.0:*               LISTEN      1001       11523969   16689/io.hm-rpc.0
      tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       11527566   17290/python3.8
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       11524831   16821/io.harmony.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12437      765/sshd: /usr/sbin
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       11526223   16629/io.sonos.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11524428   16426/io.admin.0
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       11524832   16821/io.harmony.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11523827   16598/io.shelly.0
      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          12461      819/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          12458      819/dnsmasq
      udp        0      0 192.168.1.99:5353       0.0.0.0:*                           1001       11530289   17290/python3.8
      udp        0      0 10.0.3.1:5353           0.0.0.0:*                           1001       11530288   17290/python3.8
      udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       11530287   17290/python3.8
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11530280   17290/python3.8
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11530208   17242/io.esphome.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11530155   17211/io.wled.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9081       399/avahi-daemon: r
      udp        0      0 0.0.0.0:36614           0.0.0.0:*                           108        9083       399/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       11526529   16843/io.nanoleaf-l
      udp6       0      0 :::33192                :::*                                108        9084       399/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        9082       399/avahi-daemon: r
      2023-12-21 21:44:39.126  - info: socketio.0 (17301) starting. Version 6.6.0 in /opt/iobroker/node_modules/iobroker.socketio, node: v18.19.0, js-controller: 5.0.17
      2023-12-21 21:44:39.175  - warn: socketio.0 (17301) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
      2023-12-21 21:44:39.223  - info: socketio.0 (17301) socket.io server listening on port 8084
      2023-12-21 21:44:39.782  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.229
      2023-12-21 21:44:39.830  - info: wled.0 (17211) Initialising : " WLED" on IP :  192.168.1.229
      2023-12-21 21:44:40.091  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.16
      2023-12-21 21:44:40.123  - info: wled.0 (17211) WLED connected
      2023-12-21 21:44:42.499  - info: vis-google-fonts.0 (17321) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v18.19.0, js-controller: 5.0.17
      2023-12-21 21:44:43.096  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.26
      2023-12-21 21:44:43.136  - info: vis-google-fonts.0 (17321) Terminated (NO_ERROR): Without reason
      2023-12-21 21:44:43.756  - info: host.raspberrypi instance system.adapter.vis-google-fonts.0 terminated while should be started once
      2023-12-21 21:44:46.103  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.27
      2023-12-21 21:44:48.646  - info: roomba.0 (17265) Subscripe Leafnode: _runCommand.
      2023-12-21 21:44:49.107  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.6
      2023-12-21 21:44:52.112  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.210
      2023-12-21 21:44:55.118  - info: wled.0 (17211) Bonjour service started, new  devices  will  be detected automatically
      2023-12-21 21:45:00.061  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 started with pid 17385
      2023-12-21 21:45:02.684  - info: tvspielfilm.0 (17385) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.19.0, js-controller: 5.0.17
      2023-12-21 21:45:04.818  - info: tvspielfilm.0 (17385) objects written
      2023-12-21 21:45:05.143  - info: wled.0 (17211) WLED initialisation finalized, ready to do my job have fun !
      2023-12-21 21:45:15.335  - info: tvspielfilm.0 (17385) Terminated (NO_ERROR): Without reason
      2023-12-21 21:45:15.942  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
      2023-12-21 21:45:18.473  - info: admin.0 (16426) ==> Connected system.user.admin from ::ffff:192.168.1.22
      2023-12-21 21:45:18.881  - info: zigbee.0 (16677) List of port: [{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2256619","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2256619-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyS0"}]
      2023-12-21 21:45:30.212  - info: admin.0 (16426) <== Disconnect system.user.admin from ::ffff:192.168.1.22
        Thomas Braun Most Active @igor123 last edited by
        Pending Updates: 56
        Da klemmt noch was.
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
          Und statt /dev/ttyACM0 trägst du im Zigbee-Adapter das als COM-Port ein:
          • I
            Pending Updates: 56
            Da klemmt noch was.
            sudo apt update
            sudo reboot
            so - erledigt
            habe ich nun getan
            bleibt dann nur leider auf gelb
              so - erledigt
              iob diag
              sagt?
              • I
                so - erledigt
                iob diag
                sagt?
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                            Kernel: Linux 6.1.21-v7l+
                      Architecture: arm
                Docker          : false
                Kernel          : armv7l
                Userland        : armhf
                 22:08:16 up 8 min,  1 user,  load average: 0.41, 0.74, 0.50
                CPU threads: 4
                Current issues:
                               Local time: Thu 2023-12-21 22:08:16 CET
                           Universal time: Thu 2023-12-21 21:08:16 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            7.9G        1.3G        6.3G        0.0K        280M        6.4G
                Swap:            99M          0B         99M
                Total:          8.0G        1.3G        6.4G
                         7897 M total memory
                         1294 M used memory
                          120 M active memory
                         1340 M inactive memory
                         6322 M free memory
                           39 M buffer memory
                          241 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                tmpfs          tmpfs     1.6G  852K  1.6G   1% /run
                /dev/sda1      vfat      253M   51M  202M  20% /boot
                [Thu Dec 21 21:59:38 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:47:61:6D vc_mem.        mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=79238        543-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Thu Dec 21 21:59:40 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Quota mode: none.
                [Thu Dec 21 21:59:40 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
                [Thu Dec 21 21:59:42 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharse        t=ascii,shortname=mixed,flush,errors=remount-ro
                /var:
                4.9G    /var/
                3.0G    /var/log
                41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.ma        p
                33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.m        ap
                24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/wolke-3/.pioenvs/wo        lke-3/libFrameworkArduino.a
                24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.pioenvs/test/        libFrameworkArduino.a
                24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/rfid/.pioenvs/rfid/        libFrameworkArduino.a
                USB-Devices by-id:
                USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                        500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package        s
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
                + system.adapter.zigbee.0                 : zigbee                : raspberrypi        -  enabled, port: /dev/serial/by-id/usb-dresden_ele        ktronik_ingenieurtechnik_GmbH_ConBee_II_DE2256619-if00
                + instance is alive
                Objects and States
                Objects:        8334
                States:         6960
                Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:3 http://phoscon.de/apt/deconz bullseye InRelease
                Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                Pending Updates: 0
                Proto Recv-Q Send-Q Local Address           Foreign Address         State        User       Inode      PID/Program name
                tcp        0      0 192.168.1.99:42010      0.0.0.0:*               LISTEN        1001       27073      4407/io.hm-rpc.0
                tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN        1001       26964      4351/python3.8
                tcp        0      0 0.0.0.0:1299            0.0.0.0:*               LISTEN        1001       19853      3015/io.mqtt.0
                tcp        0      0 0.0.0.0:1300            0.0.0.0:*               LISTEN        1001       19854      3015/io.mqtt.0
                tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN        0          11142      795/dnsmasq
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN        1001       17029      2442/io.sonoff.1
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN        0          1832       766/sshd: /usr/sbin
                tcp        0      0 192.168.1.99:8084       0.0.0.0:*               LISTEN        1001       23174      4353/io.socketio.0
                tcp        0      0 192.168.1.99:8082       0.0.0.0:*               LISTEN        1001       22993      4247/io.web.0
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN        1001       14423      728/iobroker.js-con
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN        1001       14410      728/iobroker.js-con
                tcp6       0      0 :::8081                 :::*                    LISTEN        1001       15888      1299/io.admin.0
                tcp6       0      0 :::3500                 :::*                    LISTEN        1001       17061      2498/io.sonos.0
                tcp6       0      0 :::22                   :::*                    LISTEN        0          1834       766/sshd: /usr/sbin
                tcp6       0      0 :::61991                :::*                    LISTEN        1001       21723      3646/io.harmony.0
                udp        0      0 0.0.0.0:61991           0.0.0.0:*        1001       21724      3646/io.harmony.0
                udp        0      0 0.0.0.0:5683            0.0.0.0:*        1001       16351      2209/io.shelly.0
                udp        0      0 10.0.3.1:53             0.0.0.0:*        0          11141      795/dnsmasq
                udp        0      0 0.0.0.0:67              0.0.0.0:*        0          11138      795/dnsmasq
                udp        0      0 127.0.0.1:5353          0.0.0.0:*        1001       23116      4351/python3.8
                udp        0      0 10.0.3.1:5353           0.0.0.0:*        1001       23115      4351/python3.8
                udp        0      0 192.168.1.99:5353       0.0.0.0:*        1001       23114      4351/python3.8
                udp        0      0 0.0.0.0:5353            0.0.0.0:*        1001       23106      4351/python3.8
                udp        0      0 0.0.0.0:5353            0.0.0.0:*        1001       26224      4301/io.esphome.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*        1001       22206      4264/io.wled.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*        108        12268      392/avahi-daemon: r
                udp        0      0 0.0.0.0:41294           0.0.0.0:*        108        12270      392/avahi-daemon: r
                udp        0      0 0.0.0.0:1900            0.0.0.0:*        1001       22597      3717/io.nanoleaf-li
                udp6       0      0 :::5353                 :::*        108        12269      392/avahi-daemon: r
                udp6       0      0 :::57676                :::*        108        12271      392/avahi-daemon: r
                2023-12-21 22:07:43.068  - info: host.raspberrypi stopInstance system.adapter.zi        gbee.0 (force=false, process=true)
                2023-12-21 22:07:43.240  - info: zigbee.0 (4621) Got terminate signal TERMINATE_        YOURSELF
                2023-12-21 22:07:43.245  - info: host.raspberrypi stopInstance system.adapter.zi        gbee.0 send kill signal
                2023-12-21 22:07:43.243  - info: zigbee.0 (4621) cleaned everything up...
                2023-12-21 22:07:43.335  - info: zigbee.0 (4621) Zigbee: disabling joining new d        evices.
                2023-12-21 22:07:43.516  - info: zigbee.0 (4621) terminating
                2023-12-21 22:07:43.518  - info: zigbee.0 (4621) Terminated (ADAPTER_REQUESTED_T        ERMINATION): Without reason
                2023-12-21 22:07:43.633  - info: admin.0 (1299) <== Disconnect system.user.admin        from ::ffff:192.168.1.22
                2023-12-21 22:07:43.744  - info: zigbee.0 (4621) terminating
                2023-12-21 22:07:44.184  - info: host.raspberrypi instance system.adapter.zigbee        .0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-12-21 22:07:46.494  - info: host.raspberrypi instance system.adapter.zigbee        .0 started with pid 4877
                2023-12-21 22:07:50.386  - info: zigbee.0 (4877) Plugin sentry Sentry Plugin dis        abled for this process because sending of statistic data is disabled for the sys        tem
                2023-12-21 22:07:50.717  - info: zigbee.0 (4877) starting. Version 1.8.24 in /op        t/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                2023-12-21 22:07:50.811  - info: zigbee.0 (4877) delete old Backup files. keep o        nly last 10
                2023-12-21 22:07:50.813  - info: zigbee.0 (4877) Starting Zigbee  npm ...
                2023-12-21 22:07:51.138  - info: zigbee.0 (4877) Installed Version: iobroker.zig        bee@1.8.24
                2023-12-21 22:07:51.537  - error: zigbee.0 (4877) Starting zigbee-herdsman probl        em : "Error while opening serialport 'Error: Error: No such file or directory, c        annot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee        _II_DE2256619-if00'"
                2023-12-21 22:07:51.538  - error: zigbee.0 (4877) Failed to start Zigbee
                2023-12-21 22:07:51.538  - error: zigbee.0 (4877) Error herdsman start
                2023-12-21 22:08:01.539  - info: zigbee.0 (4877) Try to reconnect. 1 attempts le        ft
                2023-12-21 22:08:01.541  - info: zigbee.0 (4877) Starting Zigbee  npm ...
                2023-12-21 22:08:01.555  - info: zigbee.0 (4877) Installed Version: iobroker.zig        bee@1.8.24
                2023-12-21 22:08:01.704  - error: zigbee.0 (4877) Starting zigbee-herdsman probl        em : "Error while opening serialport 'Error: Error: No such file or directory, c        annot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee        _II_DE2256619-if00'"
                2023-12-21 22:08:01.705  - error: zigbee.0 (4877) Failed to start Zigbee
                2023-12-21 22:08:01.706  - error: zigbee.0 (4877) Error herdsman start
                  Hmmm.
                  apt policy udev
                  sagt?
                  • I
                    Hmmm.
                    apt policy udev
                    sagt?
                    udev:
                      Installiert:           247.3-7+rpi1+deb11u2
                      Installationskandidat: 247.3-7+rpi1+deb11u2
                      Versionstabelle:
                     *** 247.3-7+rpi1+deb11u2 500
                      @igor123
                      echo "deb http://deb.debian.org/debian bullseye-backports main contrib non-free" | sudo tee /etc/apt/sources.list.d/buster-backports.list
                      sudo apt update
                      Dann die Ausgabe von
                      apt policy udev
                      • I
                        igor123 @Thomas Braun last edited by igor123
                        @igor123
                        sudo apt update
                        apt policy udev
                        udev:
                          Versionstabelle:
                        @Thomas-Braun Wobei ich bei sudo apt update glaube ich einen fehler erhalten habe:
                         sudo apt update
                        Holen:1 http://deb.debian.org/debian bullseye-backports InRelease [49,0 kB]
                        OK:2 http://phoscon.de/apt/deconz bullseye InRelease
                        OK:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                        OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                        OK:6 https://apt.pivccu.de/piVCCU stable InRelease
                        Fehl:1 http://deb.debian.org/debian bullseye-backports InRelease
                          Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher                                         Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B8264                                        3E131
                        Paketlisten werden gelesen… Fertig
                        W: GPG-Fehler: http://deb.debian.org/debian bullseye-backports InRelease: Die fo                                        lgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüss                                        el nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                        E: Das Depot »http://deb.debian.org/debian bullseye-backports InRelease« ist nic                                        ht signiert.
                        N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art dur                                        chgeführt werden, daher ist es standardmäßig deaktiviert.
                        N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfigur                                        ation finden Sie in der Handbuchseite apt-secure(8).
                          sudo apt update
                          apt policy udev
                          • I
                            sudo apt update
                            apt policy udev
                            habe ich bereits getan:
                             sudo apt update
                            OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
                            OK:4 http://phoscon.de/apt/deconz bullseye InRelease
                              Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                            W: GPG-Fehler: http://deb.debian.org/debian bullseye-backports InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                            E: Das Depot »http://deb.debian.org/debian bullseye-backports InRelease« ist nicht signiert.
                            N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                            N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                             apt policy udev
                            udev:
                              Versionstabelle:
                              Thomas Braun Most Active @igor123 last edited by Thomas Braun
                              @igor123
                              Solche Fehler sind natürlich wichtig...
                              sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 6ED0E7B82643E131
                              sudo apt update
                              apt policy udev
                              Und mach dein puTTY-Fenster etwas größer, das zerballert die Zeilen sonst.
                              • I
                                @igor123
                                sudo apt update
                                apt policy udev
                                leider das selbe
                                sudo apt update
                                pi@raspberrypi:~ $ apt policy udev
                                udev:
                                  Versionstabelle:
                                edit:
                                Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
                                Executing: /tmp/apt-key-gpghome.RyObX1JTYq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 6ED0E7B82643E131
                                gpg: Empfangen vom Schlüsselserver fehlgeschlagen: Server indicated a failure
                                empfangsfehler..
                                  sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9
                                  • I
                                    auch hier ein fehler
                                    Executing: /tmp/apt-key-gpghome.yYhlYVJCTc/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9
                                      @igor123
                                      Dann zieh ein Backup vom ioBroker und zieh mit dem ganzen Kram auf ein aktuelles Betriebssystem um.
                                      Neuinstallation von
                                      Raspberry 12 'Bookworm' 64Bit Lite
                                      • I
                                        ich verstehe nur nicht ganz warum
                                        was ist den das problem? was versuchen wir eigentlich die ganze zeit genau? 😄
                                        mit /dev/ttyACM0 als COMNamen funkt es ja soweit -
                                        der fehler vom Zigbee-Adapter ist erstmal nicht mehr gekommen
                                        mir fehlen "nurmehr" weiterhin die ganzen states die ich früher hatte.
                                        so wie ich es damals gemacht hatte funktioniert es nun nicht mehr:
                                        https://forum.iobroker.net/topic/50381/busch-jäger-6737-01-es-werden-nicht-alle-objekte-angezeigt?_=1703189610786
                                          Ein veraltetes System.
                                          • I
                                            Und deswegen erhalte ich die states nicht?
                                            1554
