    4. [Gelöst] Update js-controller geht nicht
      Stephan1966 @Thomas Braun last edited by
      Hier das Ergebnis, sieht soweit ich das beurteilen kann noch genauso aus!
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypismarthome
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : armhf
      Systemuptime and Load:
       14:56:47 up 2 min,  1 user,  load average: 1.21, 0.66, 0.26
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Tue 2023-12-19 14:56:47 CET
                 Universal time: Tue 2023-12-19 13:56:47 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            3.8G        651M        2.8G        1.0M        302M        3.1G
      Swap:            99M          0B         99M
      Total:          3.9G        651M        2.9G
               3794 M total memory
                651 M used memory
                725 M active memory
                118 M inactive memory
               2840 M free memory
                 41 M buffer memory
                260 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
      * deconz-init.service   loaded failed failed deCONZ: ZigBee gateway -- Initialisation
      * deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
      * deconz-wifi.service   loaded failed failed deCONZ: ZigBee gateway -- WIFI Service
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      3 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G  6.2G   22G  22% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  1.8M  758M   1% /run
      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Tue Dec 19 14:54:28 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:05:E4:1A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6ca1dc68-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Tue Dec 19 14:54:29 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue Dec 19 14:54:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Tue Dec 19 14:54:32 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      1.9G    /var/
      1.1G    /var/log/journal/2db8461036a4455ab0afd36ad1c9f367
      1.1G    /var/log
      658M    /var/cache
      Archived and active journals take up 1.0G in the file system.
      /opt/iobroker/backups:
      396M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      310M    /opt/iobroker/iobroker-data/
      180M    /opt/iobroker/iobroker-data/files
      105M    /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      8.6M    /opt/iobroker/iobroker-data/objects.jsonl
      8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypismarthome                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypismarthome                     -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypismarthome                     -  enabled
      + system.adapter.deconz.1                 : deconz                : raspberrypismarthome                     -  enabled, port: 80
      + system.adapter.discovery.0              : discovery             : raspberrypismarthome                     -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypismarthome                     -  enabled
      + system.adapter.info.0                   : info                  : raspberrypismarthome                     -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypismarthome                     -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypismarthome                     -  enabled
      + system.adapter.net-tools.0              : net-tools             : raspberrypismarthome                     -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypismarthome                     -  enabled
      + system.adapter.pushover.0               : pushover              : raspberrypismarthome                     -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypismarthome                     -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypismarthome                     -  enabled
      + system.adapter.web.0                    : web                   : raspberrypismarthome                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "deconz"       : 1.3.23   , installed 1.3.23
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
      Objects and States
      Objects:        2065
      States:         1769
      Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          14205      816/smbd
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       13015      400/deCONZ
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          14206      816/smbd
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       12989      400/deCONZ
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15042      537/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13070      501/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12123      501/iobroker.js-con
      tcp6       0      0 :::445                  :::*                    LISTEN      0          14203      816/smbd
      tcp6       0      0 :::139                  :::*                    LISTEN      0          14204      816/smbd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15044      537/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13211      662/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17527      1040/io.web.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       16822      1070/io.deconz.1
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15097      400/deCONZ
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12103      749/dhcpcd
      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          14181      750/nmbd
      udp        0      0 192.168.178.48:137      0.0.0.0:*                           0          14180      750/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          14164      750/nmbd
      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          14183      750/nmbd
      udp        0      0 192.168.178.48:138      0.0.0.0:*                           0          14182      750/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          14165      750/nmbd
      udp        0      0 0.0.0.0:41316           0.0.0.0:*                           108        14958      394/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14956      394/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1001       16824      1070/io.deconz.1
      udp6       0      0 :::1900                 :::*                                1001       16823      1070/io.deconz.1
      udp6       0      0 :::45045                :::*                                108        14959      394/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          13027      749/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        14957      394/avahi-daemon: r
      2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"failed to login","function":"send_response","error":{"msg":"failed to login, wrong user name or password","function":"send_response","error":"0000000000000000"}}}
      2023-12-19 14:55:23.658  - error: fritzdect.0 (1025) login not possible, check user and permissions
      2023-12-19 14:55:24.974  - info: host.raspberrypismarthome instance system.adapter.web.0 started with pid 1040
      2023-12-19 14:55:28.042  - info: web.0 (1040) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
      2023-12-19 14:55:28.584  - info: web.0 (1040) socket.io server listening on port 8082
      2023-12-19 14:55:28.603  - info: web.0 (1040) http server listening on port 8082
      2023-12-19 14:55:31.435  - info: vis.0 (1055) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
      2023-12-19 14:55:32.211  - info: vis.0 (1055) Terminated (NO_ERROR): Without reason
      2023-12-19 14:55:32.794  - info: host.raspberrypismarthome instance system.adapter.vis.0 terminated while should be started once
      2023-12-19 14:55:32.972  - info: host.raspberrypismarthome instance system.adapter.deconz.1 started with pid 1070
      2023-12-19 14:55:35.726  - info: deconz.1 (1070) starting. Version 1.3.23 in /opt/iobroker/node_modules/iobroker.deconz, node: v18.19.0, js-controller: 5.0.17
      2023-12-19 14:55:35.883  - info: deconz.1 (1070) deConz Version: 2.24.2; API version: 1.16.0
      2023-12-19 14:55:36.496  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
      2023-12-19 14:55:38.641  - info: host.raspberrypismarthome instance system.adapter.info.0 started with pid 1086
      2023-12-19 14:55:41.025  - info: host.raspberrypismarthome instance system.adapter.iot.0 started with pid 1101
      2023-12-19 14:55:45.888  - info: info.0 (1086) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.17
      2023-12-19 14:55:46.253  - info: info.0 (1086) Reading/updating systemdata.
      2023-12-19 14:55:46.468  - info: iot.0 (1101) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
      2023-12-19 14:55:46.638  - info: iot.0 (1101) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2023-12-19 14:55:47.531  - info: iot.0 (1101) Connection changed: connect "s_glebe66_googlemail_com"
      2023-12-19 14:55:47.731  - info: info.0 (1086) cpu Temp res = {"main":46.251,"cores":[],"max":46.251,"socket":[],"chipset":null}
      2023-12-19 14:55:49.207  - info: alexa2.0 (987) Subscribing to states...
      2023-12-19 14:55:49.216  - info: alexa2.0 (987) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
      2023-12-19 14:55:51.087  - info: alexa2.0 (987) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2023-12-19 14:55:55.552  - info: alexa2.0 (987) Initialization Done ...
      iob diag has finished.
        Thomas Braun Most Active @Stephan1966 last edited by
        @stephan1966 sagte in Update js-controller geht nicht:
        deconz-init.service
        Dann musst du mal schauen, was da klemmen könnte.
        systemctl status deconz*
          @thomas-braun sagte in Update js-controller geht nicht:
          Ergebnis meiner Eingabe!
          pi@raspberrypismarthome:~ $ systemctl status deconz*
          Unit deconz-latest-beta.deb.service could not be found.
            @stephan1966
            Mal mit beta-Zeuch herumgespielt?
            apt policy deconz*
            sagt?
              Kann mich nicht erinnern, hier das Ergebnis:
              pi@raspberrypismarthome:~ $ apt policy deconz*
              N: Paket deconz-latest-beta.deb kann nicht gefunden werden.
              N: Mittels des Musters »deconz-latest-beta.deb« konnte kein Paket gefunden werden.
                @stephan1966
                ls -lAh
                  ls -lAh
                  Ergebnis:
                  pi@raspberrypismarthome:~ $ ls -lAh
                  insgesamt 6,6M
                  drwxr-xr-x 2 root root 4,0K 10. Jan 2023 backup
                  -rw------- 1 pi pi 3,9K 19. Dez 14:54 .bash_history
                  -rw-r--r-- 1 pi pi 220 30. Okt 2021 .bash_logout
                  -rw-r--r-- 1 pi pi 3,7K 18. Dez 12:12 .bashrc
                  drwxr-xr-x 4 pi pi 4,0K 2. Dez 2021 .cache
                  drwx------ 3 pi pi 4,0K 2. Dez 2021 .config
                  -rw-r--r-- 1 pi pi 161K 20. Aug 2021 deCONZ_ConBeeII_0x26720700.bin.GCF
                  -rw-r--r-- 1 pi pi 6,4M 30. Apr 2022 deconz-latest-beta.deb
                  drwxr-xr-x 2 pi pi 4,0K 2. Dez 2021 .iobroker
                  drwxr-xr-x 3 pi pi 4,0K 21. Dez 2021 .local
                  drwxr-xr-x 5 pi pi 4,0K 2. Dez 2021 .npm
                  -rw------- 1 pi pi 36 2. Dez 2021 .npmrc
                  -rw-r--r-- 1 pi pi 807 30. Okt 2021 .profile
                    Thomas Braun Most Active @Stephan1966 last edited by Thomas Braun
                    @stephan1966
                    Das muss da weg:
                    rm deconz-latest-beta.deb
                    Und bitte Auszüge aus der Konsole immer in Code Tags setzen. Liest sich besser.
                      Hier das Ergebnis nachdem ich rm deconz-latest-beta.deb ausgeführt habe: ```
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : armhf
                       09:35:28 up 2 days, 18:41,  1 user,  load average: 0.07, 0.19, 0.22
                      CPU threads: 4
                      Current issues:
                                     Local time: Fri 2023-12-22 09:35:28 CET
                                 Universal time: Fri 2023-12-22 08:35:28 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            3.8G        803M        2.4G        1.0M        625M        2.9G
                      Swap:            99M          0B         99M
                      Total:          3.9G        803M        2.5G
                               3794 M total memory
                                803 M used memory
                                883 M active memory
                                401 M inactive memory
                               2364 M free memory
                                 90 M buffer memory
                                535 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /dev/root      ext4       29G  6.2G   22G  23% /
                      /var:
                      1.9G    /var/
                      1.1G    /var/log
                      658M    /var/cache
                      403M    /opt/iobroker/backups/
                      333M    /opt/iobroker/iobroker-data/
                      106M    /opt/iobroker/iobroker-data/backup-objects
                      28M     /opt/iobroker/iobroker-data/objects.jsonl
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.6
                      Adapter State
                      + instance is alive
                      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                      Objects and States
                      Objects:        2065
                      States:         1761
                      Pending Updates: 0
                      2023-12-22 09:15:38.510  - info: host.raspberrypismarthome stopInstance system.adapter.pushover.0 send kill signal
                      2023-12-22 09:15:38.738  - info: host.raspberrypismarthome iobroker upload [14] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/blockly.js blockly.js application/javascript
                      2023-12-22 09:15:38.760  - info: host.raspberrypismarthome iobroker upload [13] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      2023-12-22 09:15:38.771  - info: host.raspberrypismarthome iobroker upload [12] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      2023-12-22 09:15:38.781  - info: host.raspberrypismarthome iobroker upload [11] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      2023-12-22 09:15:38.792  - info: host.raspberrypismarthome iobroker upload [10] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      2023-12-22 09:15:38.803  - info: host.raspberrypismarthome iobroker upload [9] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      2023-12-22 09:15:38.815  - info: host.raspberrypismarthome iobroker upload [8] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      2023-12-22 09:15:38.825  - info: host.raspberrypismarthome iobroker upload [7] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      2023-12-22 09:15:38.839  - info: host.raspberrypismarthome iobroker upload [6] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      2023-12-22 09:15:38.852  - info: host.raspberrypismarthome iobroker upload [5] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      2023-12-22 09:15:38.864  - info: host.raspberrypismarthome iobroker upload [4] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      2023-12-22 09:15:38.874  - info: host.raspberrypismarthome iobroker upload [3] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/index_m.html index_m.html text/html
                      2023-12-22 09:15:38.884  - info: host.raspberrypismarthome iobroker upload [2] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/jsonConfig.json jsonConfig.json application/json
                      2023-12-22 09:15:38.895  - info: host.raspberrypismarthome iobroker upload [1] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/pushover.png pushover.png image/png
                      2023-12-22 09:15:38.905  - info: host.raspberrypismarthome iobroker upload [0] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/words.js words.js application/javascript
                      2023-12-22 09:15:38.976  - info: pushover.0 (829) terminating
                      2023-12-22 09:15:38.978  - info: pushover.0 (829) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2023-12-22 09:15:39.514  - info: host.raspberrypismarthome stopInstance system.adapter.pushover.0 killing pid 829
                      2023-12-22 09:15:39.611  - info: host.raspberrypismarthome instance system.adapter.pushover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2023-12-22 09:15:39.947  - info: host.raspberrypismarthome iobroker exit 0
                      2023-12-22 09:15:41.597  - info: host.raspberrypismarthome instance system.adapter.pushover.0 started with pid 17654
                      2023-12-22 09:15:44.251  - info: pushover.0 (17654) starting. Version 3.0.6 in /opt/iobroker/node_modules/iobroker.pushover, node: v18.19.0, js-controller: 5.0.17
                      2023-12-22 09:18:40.465  - info: admin.0 (662) ==> Connected system.user.admin from ::ffff:192.168.178.59
                      2023-12-22 09:18:43.110  - info: host.raspberrypismarthome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                        @stephan1966
                        wirft jetzt was raus?
                          @thomas-braun ```
                          Copy text starting here:
                                                  v.2023-10-10
                                   Icon name: computer
                                Architecture: arm64
                          Installation:           native
                          Kernel:                 aarch64
                          Userland:               armhf
                          Timezone:               Europe/Berlin (CET, +0100)
                          User-ID:                1000
                          X-Server:               false
                          Pending OS-Updates:     0
                          Pending iob updates:    0
                          Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                  /usr/bin/npm            10.2.3
                                                  /usr/bin/npx            10.2.3
                          Recommended versions are nodejs 18.19.0 and npm 10.2.3
                          MEMORY:
                          Mem:            3.8G        848M        2.3G        1.0M        626M        2.9G
                          Swap:            99M          0B         99M
                          Total:          3.9G        848M        2.4G
                          Active iob-Instances:   15
                          ioBroker Core:          js-controller           5.0.17
                                                  admin                   6.12.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                2065
                          States:                 1761
                          Size of iob-Database:
                          6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
                          6.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                          6.8M    /opt/iobroker/iobroker-data/states.jsonl
                          488K    /opt/iobroker/iobroker-data/states.json.migrated
                          488K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                          0       /opt/iobroker/iobroker-data/states.json.broken
                            @thomas-braun ```
                            === Mark text until here for copying ===
                            ● deconz-update.service - deCONZ: ZigBee gateway -- Update Service
                                 Loaded: loaded (/lib/systemd/system/deconz-update.service; disabled; vendor preset: enabled)
                                 Active: failed (Result: exit-code) since Tue 2023-12-19 14:54:22 CET; 2 days ago
                                Process: 542 ExecStart=/usr/bin/deCONZ-update2.sh (code=exited, status=203/EXEC)
                               Main PID: 542 (code=exited, status=203/EXEC)
                                    CPU: 3ms
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-update.service: Scheduled restart job, restart counter is at 5.
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: Stopped deCONZ: ZigBee gateway -- Update Service.
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-update.service: Start request repeated too quickly.
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-update.service: Failed with result 'exit-code'.
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: Failed to start deCONZ: ZigBee gateway -- Update Service.
                            ● deconz-init.service - deCONZ: ZigBee gateway -- Initialisation
                                 Loaded: loaded (/lib/systemd/system/deconz-init.service; disabled; vendor preset: enabled)
                                 Active: failed (Result: exit-code) since Tue 2023-12-19 14:54:21 CET; 2 days ago
                                Process: 397 ExecStart=/usr/bin/deCONZ-init.sh (code=exited, status=203/EXEC)
                               Main PID: 397 (code=exited, status=203/EXEC)
                                    CPU: 4ms
                            Dez 19 14:54:21 raspberrypismarthome systemd[1]: Starting deCONZ: ZigBee gateway -- Initialisation...
                            Dez 19 14:54:21 raspberrypismarthome systemd[397]: deconz-init.service: Failed to locate executable /usr/bin/deCONZ-init.sh: No such file or directory
                            Dez 19 14:54:21 raspberrypismarthome systemd[397]: deconz-init.service: Failed at step EXEC spawning /usr/bin/deCONZ-init.sh: No such file or directory
                            Dez 19 14:54:21 raspberrypismarthome systemd[1]: deconz-init.service: Main process exited, code=exited, status=203/EXEC
                            Dez 19 14:54:21 raspberrypismarthome systemd[1]: deconz-init.service: Failed with result 'exit-code'.
                            Dez 19 14:54:21 raspberrypismarthome systemd[1]: Failed to start deCONZ: ZigBee gateway -- Initialisation.
                            ● deconz-wifi.service - deCONZ: ZigBee gateway -- WIFI Service
                                 Loaded: loaded (/lib/systemd/system/deconz-wifi.service; enabled; vendor preset: enabled)
                                Process: 547 ExecStart=/usr/bin/deCONZ-WIFI2.sh (code=exited, status=203/EXEC)
                               Main PID: 547 (code=exited, status=203/EXEC)
                                    CPU: 2ms
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-wifi.service: Scheduled restart job, restart counter is at 5.
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: Stopped deCONZ: ZigBee gateway -- WIFI Service.
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-wifi.service: Start request repeated too quickly.
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: deconz-wifi.service: Failed with result 'exit-code'.
                            Dez 19 14:54:22 raspberrypismarthome systemd[1]: Failed to start deCONZ: ZigBee gateway -- WIFI Service.
                            ● deconz.service - deCONZ: ZigBee gateway -- REST API
                                 Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: enabled)
                                 Active: active (running) since Tue 2023-12-19 14:54:21 CET; 2 days ago
                               Main PID: 400 (deCONZ)
                                  Tasks: 6 (limit: 3933)
                                    CPU: 55min 35.525s
                                 CGroup: /system.slice/deconz.service
                                         └─400 /usr/bin/deCONZ -platform minimal --http-port=80
                            Dez 19 14:54:21 raspberrypismarthome systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
                            Dez 19 14:54:22 raspberrypismarthome deCONZ[400]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
                            Dez 19 14:54:23 raspberrypismarthome deCONZ[400]: libpng warning: iCCP: known incorrect sRGB profile
                            Dez 19 14:54:25 raspberrypismarthome deCONZ[400]: This plugin does not support propagateSizeHints()
                            Dez 19 14:54:28 raspberrypismarthome deCONZ[400]: This plugin does not support propagateSizeHints()
                              ls -lAh /usr/bin/deCONZ-WIFI2.sh
                              ls -lAh /usr/bin/deCONZ-update2.sh
                                pi@raspberrypismarthome:~ $ ls -lAh /usr/bin/deCONZ-WIFI2.sh
                                ls: Zugriff auf '/usr/bin/deCONZ-WIFI2.sh' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                pi@raspberrypismarthome:~ $ ls -lAh /usr/bin/deCONZ-update2.sh
                                ls: Zugriff auf '/usr/bin/deCONZ-update2.sh' nicht möglich: Datei oder Verzeichnis nicht gefunden
                                  @stephan1966
                                  Das ist dann auch der Grund, warum der Service failed.
                                  Ich hab aber kein deconz laufen, keine Ahnung wo der Eintrag für die Services überhaupt herkommt.
                                    Es scheint ja bis auf eine Lampe bei mir alles zu funktionieren, ob die Lampe damit zusammenhängt bekomme ich ja vielleicht noch heraus!
                                    Danke für den Super-Support 👍
                                    2858
