    4. Node-Red
    5. Array mit Objekten in iOBroker anlegen
    • mickym
      mickym Most Active @HackyPaddy last edited by
      @hackypaddy sagte in Array mit Objekten in iOBroker anlegen:
      @mickym
      Das ist echt ne geile Idee. So baue ich das um.
      Wegen der Abfragen: Es gehen maximal 2 zeitgleich. Lieber aber sequenziell hintereinander. Dann kommen die Antworten auch schneller.
      4 Abfragen gehen garnicht… bricht ab. Entweder stürzt die Anlage ab oder der Node Server.
      Hier noch der Import - um die andere Struktur aufzubauen:
             "id": "449010e92d9ebbd8",
             "type": "inject",
             "z": "517cd16e4d7e6ae4",
             "name": "",
             "props": [
                     "p": "payload"
             "repeat": "",
             "crontab": "",
             "once": false,
             "onceDelay": 0.1,
             "topic": "",
             "payload": "[{\"id\":\"109\",\"name\":\"Kontakt\",\"state\":\"closed\"},{\"id\":\"110\",\"name\":\"BW Fen. R.\",\"state\":\"closed\"}]",
             "payloadType": "json",
             "x": 150,
             "y": 1100,
             "wires": [
                     "c3673c87edd45369"
             "id": "c3673c87edd45369",
             "type": "split",
             "name": "",
             "splt": "\\n",
             "spltType": "str",
             "arraySplt": 1,
             "arraySpltType": "len",
             "stream": false,
             "addname": "topic",
             "x": 310,
             "y": 1100,
             "wires": [
                     "fd333903bf4aaa07"
             "id": "fd333903bf4aaa07",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "to": "\"0_userdata.0.Alarm.\" & payload.id",
                     "tot": "jsonata"
                     "t": "delete",
                     "p": "payload.id",
                     "pt": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 490,
             "y": 1100,
             "wires": [
                     "2ac15ee0675e260f"
             "id": "daa3c3782f2712cc",
             "type": "ioBroker out",
             "name": "",
             "topic": "",
             "ack": "true",
             "autoCreate": "true",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "false",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 1060,
             "y": 1100,
             "wires": []
             "id": "2ac15ee0675e260f",
             "type": "split",
             "name": "",
             "splt": "\\n",
             "spltType": "str",
             "arraySplt": 1,
             "stream": false,
             "addname": "topicName",
             "x": 670,
             "y": 1100,
             "wires": [
                     "801aed56877d211c"
             "id": "801aed56877d211c",
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "to": "topic & \".\" & topicName",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 840,
             "y": 1100,
             "wires": [
                     "daa3c3782f2712cc"
      • mickym
        @mickym
        Hast Du mal versucht mit einer payload die einzelnen Partitionen abzufragen, anstatt das in der Node fest zu verdrahten?
          HackyPaddy @mickym last edited by
          @mickym
          Ne, weil ich nichts genau weiß wie...
          Ich schick Dir gleich mal mein Flow, wie er im Moment aussieht.
          Dann kannst Du das besser nachvollziehen.
          • mickym
            mickym Most Active @HackyPaddy last edited by mickym
            @hackypaddy
            Probiere doch mal wie ich gesagt habe die Partition nicht in der Node zu verwenden sondern mit der payload?
            hast Du denn das schon versucht: https://forum.iobroker.net/post/1098790
            Ich probiere parallel einen Flow zu erstellen, aber Du würdest Dir das Leben viel einfacher machen. Bitte probiere das erst aus.
              @mickym
              hier mal mein Flow, wie ich ihn gerade verwende. Ziel wäre es, die einzelnen Bereiche nacheinander abzufragen. Erst Bereich 1, dann Bereich 2, usw.
                      "id": "21ba77d9f363fc5c",
                      "type": "tab",
                      "label": "Secvest",
                      "disabled": false,
                      "info": "",
                      "env": []
                      "id": "7de9826e28d68b1d",
                      "type": "split",
                      "z": "21ba77d9f363fc5c",
                      "name": "",
                      "splt": "\\n",
                      "spltType": "str",
                      "arraySplt": 1,
                      "stream": false,
                      "addname": "topic",
                      "x": 690,
                      "y": 220,
                      "wires": [
                              "7ae37472e7b5ca96"
                      "id": "7ae37472e7b5ca96",
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "change",
                              "p": "payload.name",
                              "pt": "msg",
                              "from": ".",
                              "fromt": "str",
                              "to": "",
                              "tot": "str"
                              "t": "set",
                              "p": "topic",
                              "pt": "msg",
                              "to": "\"0_userdata.0.Alarm.\" & payload.id & \".\" &  payload.name",
                              "tot": "jsonata"
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "payload.state",
                              "tot": "msg"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 730,
                      "y": 300,
                      "wires": [
                              "3f9d9626684a6018"
                      "id": "3f9d9626684a6018",
                      "name": "",
                      "topic": "",
                      "ack": "true",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 720,
                      "y": 380,
                      "wires": []
                      "id": "736b74f1fd7dfdd5",
                      "type": "Secvest Status",
                      "name": "Bereich 1",
                      "server": "5dc4b66ee70b8720",
                      "partition": "1",
                      "command": "zones",
                      "x": 400,
                      "y": 140,
                      "wires": [
                              "7de9826e28d68b1d"
                      "id": "c9f81194989a2d11",
                      "type": "inject",
                      "name": "Alle 45 Sek.",
                      "props": [
                              "p": "payload"
                              "p": "topic",
                              "vt": "str"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": "1",
                      "topic": "",
                      "payload": "",
                      "payloadType": "date",
                      "x": 130,
                      "y": 100,
                      "wires": [
                              "736b74f1fd7dfdd5",
                              "3149fd696d113580",
                              "427ed92e5fcf9fa0",
                              "a7ae4222d4fc65a0"
                      "id": "3149fd696d113580",
                      "name": "Bereich 2",
                      "partition": "2",
                      "command": "zones",
                      "x": 420,
                      "y": 200,
                      "wires": [
                              "7de9826e28d68b1d"
                      "id": "427ed92e5fcf9fa0",
                      "name": "Bereich 3",
                      "partition": "3",
                      "command": "zones",
                      "x": 400,
                      "y": 260,
                      "wires": [
                              "7de9826e28d68b1d"
                      "id": "a7ae4222d4fc65a0",
                      "name": "Bereich 4",
                      "partition": "4",
                      "command": "zones",
                      "x": 390,
                      "y": 320,
                      "wires": [
                              "7de9826e28d68b1d"
                      "id": "5dc4b66ee70b8720",
                      "type": "ABUS Secvest",
                      "servername": "Secvest",
                      "host": "192.168.10.121",
                      "port": "4433",
                      "user": "Alert",
                      "password": "xxxx"
              • mickym
                @hackypaddy Ja trotzdem probiere es bitte -
                Nimm einfach eine von den Secvest Nodes - mach dahinter eine Debug Node und schau ob Du mit
                einer Inject Node mit einer payload die eine der 3. Partitions enthält abfragst?
                Wie gesagt es geht auch mit 4 Nodes - aber es ist einfach ÜBERFLÜSSIG, wenn der Entwickler anbietet, dass man mit einer payload die Partitionen einzeln abfragen kann.
                • mickym
                  mickym Most Active @mickym last edited by
                  @hackpaddy
                  Hast Du es probiert???
                    @mickym
                    Ich bin noch dabei, aber so wie es aussieht, funktioniert das nicht...
                    • mickym
                      @hackypaddy dann probiere es mal mit den beiden Inject Nodes und schau ob da was rauskommt.
                      In der Node löscht Du Command und Partition bitte.
                             "id": "30a75b4cea8b0f90",
                             "type": "inject",
                             "name": "",
                             "props": [
                                     "p": "payload"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "topic": "",
                             "payload": "{\"command\":\"state\",\"partition\":\"3\"}",
                             "x": 830,
                             "y": 1480,
                             "wires": [
                             "id": "b886fcf335c578ce",
                             "type": "inject",
                             "name": "",
                             "props": [
                                     "p": "payload"
                             "repeat": "",
                             "crontab": "",
                             "once": false,
                             "onceDelay": 0.1,
                             "topic": "",
                             "payload": "{\"command\":\"state\",\"partition\":3}",
                             "x": 830,
                             "y": 1520,
                             "wires": [
                      • mickym
                        So nachdem ich von Dir leider keinen Response bekomme, und das eigentlich gehen müsste, habe ich Dir hier nun einen Flow gebastelt - der den Status abfragt und mit dem ich Deine Secvest Nodes simuliert habe
                        Die Nachricht kommt nur raus, wenn der Status OK ist.
                        Du musst aber vorher in der Statusermittlung die ID der Nodes in die Switch Node eintragen. Wenn Du das mal durchgespielt hast hier mit diesem Flow - dann wirst Du es auch auf den realen Flow umsetzen können:
                               "id": "c05f687368999ce5",
                               "type": "group",
                               "name": "Hauptflow",
                               "style": {
                                   "fill": "#e3f3d3",
                                   "label": true
                               "nodes": [
                                   "edf6186f87bd29cf",
                                   "43d75f1a298e4228",
                                   "5c2a6fd166cadeea",
                                   "1f3ca857652a6f2d",
                                   "d0227b7791f129b7",
                                   "4385c065f4bcf50b",
                                   "2686fd64b3416b63",
                                   "105628d009801c57"
                               "x": 54,
                               "y": 1559,
                               "w": 1612,
                               "h": 82
                               "id": "edf6186f87bd29cf",
                               "type": "debug",
                               "g": "c05f687368999ce5",
                               "name": "Nachricht",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "complete": "payload",
                               "targetType": "msg",
                               "statusVal": "",
                               "statusType": "auto",
                               "x": 1560,
                               "y": 1600,
                               "wires": []
                               "id": "43d75f1a298e4228",
                               "type": "link call",
                               "name": "",
                               "links": [
                                   "0261bc0c575a8179"
                               "linkType": "static",
                               "timeout": "30",
                               "x": 340,
                               "y": 1600,
                               "wires": [
                                       "1f3ca857652a6f2d"
                               "id": "5c2a6fd166cadeea",
                               "type": "inject",
                               "name": "trigger",
                               "props": [
                                       "p": "payload"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "payload": "true",
                               "payloadType": "bool",
                               "x": 150,
                               "y": 1600,
                               "wires": [
                                       "43d75f1a298e4228"
                               "id": "1f3ca857652a6f2d",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "result",
                                       "pt": "msg",
                                       "to": "$flowContext(\"Secvest.partition.\"& next)\t",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 540,
                               "y": 1600,
                               "wires": [
                                       "d0227b7791f129b7"
                               "id": "d0227b7791f129b7",
                               "type": "switch",
                               "name": "Nur wenn OK?",
                               "property": "result",
                               "propertyType": "msg",
                               "rules": [
                                       "t": "cont",
                                       "v": "OK",
                                       "vt": "str"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 1,
                               "x": 740,
                               "y": 1600,
                               "wires": [
                                       "2686fd64b3416b63"
                               "id": "4385c065f4bcf50b",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "Secvest.nextPart",
                                       "pt": "flow",
                                       "to": "next",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1340,
                               "y": 1600,
                               "wires": [
                                       "edf6186f87bd29cf"
                               "id": "2686fd64b3416b63",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "next",
                                       "pt": "msg",
                                       "to": "next + 1",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 940,
                               "y": 1600,
                               "wires": [
                                       "105628d009801c57"
                               "id": "105628d009801c57",
                               "type": "range",
                               "minin": "1",
                               "maxin": "5",
                               "minout": "1",
                               "maxout": "5",
                               "action": "roll",
                               "round": true,
                               "property": "next",
                               "name": "",
                               "x": 1110,
                               "y": 1600,
                               "wires": [
                                       "4385c065f4bcf50b"
                               "id": "79474f37517badfa",
                               "type": "group",
                               "name": "Status",
                               "style": {
                                   "fill": "#ffffbf",
                                   "label": true
                               "nodes": [
                                   "046d20801968277a",
                                   "166f54f5d95776c5",
                                   "967ae311bedb5398",
                                   "f531134c2d277c8e",
                                   "f7e0ad7f8c47e9e2",
                                   "b859b6f87ebdea89",
                                   "acd1fb1a37c75788"
                               "x": 54,
                               "y": 1659,
                               "w": 672,
                               "h": 222
                               "id": "046d20801968277a",
                               "type": "status",
                               "g": "79474f37517badfa",
                               "name": "",
                               "scope": [
                                   "26da1e75ad50f497",
                                   "77406c09f2b4935f",
                                   "a36d2b0336d314d5",
                                   "dca5caeebd3fa237"
                               "x": 140,
                               "y": 1780,
                               "wires": [
                                       "166f54f5d95776c5",
                                       "f531134c2d277c8e"
                               "id": "166f54f5d95776c5",
                               "type": "switch",
                               "name": "",
                               "property": "status.source.id",
                               "rules": [
                                       "t": "eq",
                                       "v": "26da1e75ad50f497",
                                       "vt": "str"
                                       "t": "eq",
                                       "v": "77406c09f2b4935f",
                                       "vt": "str"
                                       "t": "eq",
                                       "v": "a36d2b0336d314d5",
                                       "vt": "str"
                                       "t": "eq",
                                       "v": "dca5caeebd3fa237",
                                       "vt": "str"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 4,
                               "x": 330,
                               "y": 1760,
                               "wires": [
                                       "967ae311bedb5398"
                                       "f7e0ad7f8c47e9e2"
                                       "b859b6f87ebdea89"
                                       "acd1fb1a37c75788"
                               "id": "967ae311bedb5398",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "Secvest.partition.1",
                                       "pt": "flow",
                                       "to": "status.text ",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 580,
                               "y": 1700,
                               "wires": [
                               "id": "f531134c2d277c8e",
                               "type": "debug",
                               "name": "status all",
                               "active": false,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "complete": "status",
                               "statusVal": "",
                               "x": 320,
                               "y": 1840,
                               "wires": []
                               "id": "f7e0ad7f8c47e9e2",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "Secvest.partition.2",
                                       "pt": "flow",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 580,
                               "y": 1740,
                               "wires": [
                               "id": "b859b6f87ebdea89",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "Secvest.partition.3",
                                       "pt": "flow",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 580,
                               "y": 1780,
                               "wires": [
                               "id": "acd1fb1a37c75788",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "Secvest.partition.4",
                                       "pt": "flow",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 580,
                               "y": 1820,
                               "wires": [
                               "id": "b7fe5d925d8e97e6",
                               "type": "group",
                               "name": "Abfrage",
                               "style": {
                                   "fill": "#dbcbe7",
                                   "label": true
                               "nodes": [
                                   "678dc9ba9d8c785f",
                                   "f848c65833d70071",
                                   "40bce79305c4643d",
                                   "26da1e75ad50f497",
                                   "50b76a92e1d49815",
                                   "610c1cd0aa01c457",
                                   "edf0b36304b14ced",
                                   "77406c09f2b4935f",
                                   "b291f001e92e6035",
                                   "94e0553e3cd9b288",
                                   "27712704a9ab0b48",
                                   "a36d2b0336d314d5",
                                   "fd85b9e702df0f23",
                                   "b3e5ed6bd910648d",
                                   "d6c566a7f673e2bf",
                                   "dca5caeebd3fa237",
                                   "6203be293dd53946",
                                   "77ed707586880c2f",
                                   "0261bc0c575a8179",
                                   "c867ec0ddf91ddf0",
                                   "bf53714046156c85",
                                   "de3b72e71c80a313"
                               "x": 54,
                               "y": 1899,
                               "w": 1612,
                               "h": 422
                               "id": "678dc9ba9d8c785f",
                               "type": "switch",
                               "g": "b7fe5d925d8e97e6",
                               "name": "part1",
                               "property": "$random()\t",
                               "propertyType": "jsonata",
                               "rules": [
                                       "t": "lt",
                                       "v": "0.5",
                                       "vt": "num"
                                       "t": "gte",
                                       "v": "0.5",
                                       "vt": "num"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 2,
                               "x": 630,
                               "y": 1960,
                               "wires": [
                                       "f848c65833d70071"
                                       "40bce79305c4643d"
                               "id": "f848c65833d70071",
                               "type": "change",
                               "name": "Ergebnis Ok",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "[{\"id\":\"109\",\"name\":\"Kontakt\",\"state\":\"closed\"},{\"id\":\"110\",\"name\":\"BW Fen. R.\",\"state\":\"closed\"}]",
                                       "tot": "json"
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "to": "part1",
                                       "tot": "str"
                                       "t": "set",
                                       "p": "status",
                                       "pt": "msg",
                                       "to": "{\"fill\":\"green\",\"shape\":\"dot\",\"text\":\"OK\"}",
                                       "tot": "json"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 830,
                               "y": 1940,
                               "wires": [
                                       "26da1e75ad50f497"
                               "id": "40bce79305c4643d",
                               "type": "change",
                               "name": "Ergebnis Nicht Ok",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "[{\"id\":\"109\",\"name\":\"Kontakt\",\"state\":\"closed\"}]",
                                       "tot": "json"
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "to": "part1",
                                       "tot": "str"
                                       "t": "set",
                                       "p": "status",
                                       "pt": "msg",
                                       "to": "{\"fill\":\"red\",\"shape\":\"dot\",\"text\":\"Error\"}",
                                       "tot": "json"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 810,
                               "y": 1980,
                               "wires": [
                                       "26da1e75ad50f497"
                               "id": "26da1e75ad50f497",
                               "type": "function",
                               "name": "Simuliere Secvest Command - Partition 1",
                               "func": "var newMsg;\nnode.status(msg.status);\nnewMsg = {topic:msg.topic, payload:msg.payload}\nreturn msg;",
                               "outputs": 1,
                               "noerr": 0,
                               "initialize": "",
                               "finalize": "",
                               "libs": [],
                               "x": 1120,
                               "y": 1960,
                               "wires": [
                                       "de3b72e71c80a313"
                               "id": "50b76a92e1d49815",
                               "type": "switch",
                               "name": "part2",
                               "rules": [
                                       "t": "lt",
                                       "v": "0.5",
                                       "vt": "num"
                                       "t": "gte",
                                       "v": "0.5",
                                       "vt": "num"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 2,
                               "x": 630,
                               "y": 2060,
                               "wires": [
                                       "610c1cd0aa01c457"
                                       "edf0b36304b14ced"
                               "id": "610c1cd0aa01c457",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "json"
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "to": "part2",
                                       "tot": "str"
                                       "t": "set",
                                       "p": "status",
                                       "pt": "msg",
                                       "tot": "json"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 830,
                               "y": 2040,
                               "wires": [
                                       "77406c09f2b4935f"
                               "id": "edf0b36304b14ced",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "json"
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "to": "part2",
                                       "tot": "str"
                                       "t": "set",
                                       "p": "status",
                                       "pt": "msg",
                                       "tot": "json"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 810,
                               "y": 2080,
                               "wires": [
                                       "77406c09f2b4935f"
                               "id": "77406c09f2b4935f",
                               "type": "function",
                               "name": "Simuliere Secvest Command - Partition 2",
                               "outputs": 1,
                               "noerr": 0,
                               "initialize": "",
                               "finalize": "",
                               "libs": [],
                               "x": 1120,
                               "y": 2060,
                               "wires": [
                                       "de3b72e71c80a313"
                               "id": "b291f001e92e6035",
                               "type": "switch",
                               "name": "part3",
                               "rules": [
                                       "t": "lt",
                                       "v": "0.5",
                                       "vt": "num"
                                       "t": "gte",
                                       "v": "0.5",
                                       "vt": "num"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 2,
                               "x": 630,
                               "y": 2160,
                               "wires": [
                                       "94e0553e3cd9b288"
                                       "27712704a9ab0b48"
                               "id": "94e0553e3cd9b288",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "json"
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "to": "part3",
                                       "tot": "str"
                                       "t": "set",
                                       "p": "status",
                                       "pt": "msg",
                                       "tot": "json"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 830,
                               "y": 2140,
                               "wires": [
                                       "a36d2b0336d314d5"
                               "id": "27712704a9ab0b48",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "json"
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "to": "part3",
                                       "tot": "str"
                                       "t": "set",
                                       "p": "status",
                                       "pt": "msg",
                                       "tot": "json"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 810,
                               "y": 2180,
                               "wires": [
                                       "a36d2b0336d314d5"
                               "id": "a36d2b0336d314d5",
                               "type": "function",
                               "name": "Simuliere Secvest Command - Partition 3",
                               "outputs": 1,
                               "noerr": 0,
                               "initialize": "",
                               "finalize": "",
                               "libs": [],
                               "x": 1120,
                               "y": 2160,
                               "wires": [
                                       "de3b72e71c80a313"
                               "id": "fd85b9e702df0f23",
                               "type": "switch",
                               "name": "part4",
                               "rules": [
                                       "t": "lt",
                                       "v": "0.5",
                                       "vt": "num"
                                       "t": "gte",
                                       "v": "0.5",
                                       "vt": "num"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 2,
                               "x": 630,
                               "y": 2260,
                               "wires": [
                                       "b3e5ed6bd910648d"
                                       "d6c566a7f673e2bf"
                               "id": "b3e5ed6bd910648d",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "json"
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "to": "part4",
                                       "tot": "str"
                                       "t": "set",
                                       "p": "status",
                                       "pt": "msg",
                                       "tot": "json"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 830,
                               "y": 2240,
                               "wires": [
                                       "dca5caeebd3fa237"
                               "id": "d6c566a7f673e2bf",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "json"
                                       "t": "set",
                                       "p": "topic",
                                       "pt": "msg",
                                       "to": "part4",
                                       "tot": "str"
                                       "t": "set",
                                       "p": "status",
                                       "pt": "msg",
                                       "tot": "json"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 810,
                               "y": 2280,
                               "wires": [
                                       "dca5caeebd3fa237"
                               "id": "dca5caeebd3fa237",
                               "type": "function",
                               "name": "Simuliere Secvest Command - Partition 4",
                               "outputs": 1,
                               "noerr": 0,
                               "initialize": "",
                               "finalize": "",
                               "libs": [],
                               "x": 1120,
                               "y": 2260,
                               "wires": [
                                       "de3b72e71c80a313"
                               "id": "6203be293dd53946",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "next",
                                       "pt": "msg",
                                       "to": "$exists($flowContext(\"Secvest.nextPart\")) ? $flowContext(\"Secvest.nextPart\") : 1\t\t",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 220,
                               "y": 2100,
                               "wires": [
                                       "77ed707586880c2f"
                               "id": "77ed707586880c2f",
                               "type": "switch",
                               "name": "",
                               "property": "next",
                               "rules": [
                                       "t": "eq",
                                       "v": "1",
                                       "vt": "num"
                                       "t": "eq",
                                       "v": "2",
                                       "vt": "num"
                                       "t": "eq",
                                       "v": "3",
                                       "vt": "num"
                                       "t": "eq",
                                       "v": "4",
                                       "vt": "num"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 4,
                               "x": 430,
                               "y": 2100,
                               "wires": [
                                       "678dc9ba9d8c785f"
                                       "50b76a92e1d49815"
                                       "b291f001e92e6035"
                                       "fd85b9e702df0f23"
                               "id": "0261bc0c575a8179",
                               "type": "link in",
                               "name": "queryPartition",
                               "links": [],
                               "x": 95,
                               "y": 2100,
                               "wires": [
                                       "6203be293dd53946"
                               "id": "c867ec0ddf91ddf0",
                               "type": "link out",
                               "name": "queryResponse",
                               "mode": "return",
                               "links": [],
                               "x": 1625,
                               "y": 2100,
                               "wires": []
                               "id": "bf53714046156c85",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "delete",
                                       "p": "status",
                                       "pt": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1490,
                               "y": 2100,
                               "wires": [
                                       "c867ec0ddf91ddf0"
                               "id": "de3b72e71c80a313",
                               "type": "junction",
                               "x": 1360,
                               "y": 2100,
                               "wires": [
                                       "bf53714046156c85"
                        Vorerst ist das Thema aber für mich damit erst mal abgeschlossen.
                          @mickym
                          Wow, danke.
                          Ich bin grad unterwegs, deshalb kann ich das nicht so schnell durchtesten...
                          Wenn ich nachher zuhause bin, schau ich mir Deinen Flow mal an und versuche den zu verstehen.
                          Wahnsinn, vielen Dank für deine Arbeit!
                          • mickym
                            @hackypaddy Wie gesagt, wenn Du das mit der payload und den Einzelabrufen in einer Node machen kannst, dann hätte ich mir diese Arbeit sparen können.
                              @mickym
                              Ne das geht ja nicht, also in einer Node.
                              • mickym
                                @hackypaddy Lt. Beschreibung muss das aber gehen.
                                  @mickym
                                  ich bekomm da nichts raus.
                                  Hab mir gerade mal Dein Konstrukt angeschaut (auf dem Handy). Meine Herren, mir raucht der Kopf. Ich setz mich da nachher mal ran und versuch das alles irgendwie zu verstehen.
                                    @mickym
                                    Ich hab jetzt 3 Stunden probiert, und es funktioniert nicht. Und dann fiel es mir wie Schuppen von den Augen, als ich die Beschreibung nochmal genau durchgelesen hab...
                                    Du hast den Command Baustein gemeint. Ja, diesen kannst per payload steuern und dort auch die einzelnen Partitionen abgeben. Aber diesen Baustein nutze ich nicht. Mit diesem Baustein steuert man die Anlage (scharf, unscharf, teilscharf).
                                    Ich nutze nur den Status-Baustein. Dieser ließt die einzelnen Partitionen aus, gibt dann die Zonen aus und dort den Status (auf / zu).
                                    Deshalb hat das vorhin auch nicht funktioniert.
                                    • mickym
                                      @hackypaddy Ok dann kannst Du Dir ja meinen Flow im Genauen anschauen. Kurzfristig kannst Du die Nodes ja hintereinanderschalten und ggf. einfach noch eine delay Node dazwischen machen - wenn Dir meine Lösung zu kompliziert ist.
                                      1.2k
                                      node-red
                                      3703
