    4. Node-Red
    5. Array mit Objekten in iOBroker anlegen
    • mickym
      mickym Most Active @HackyPaddy last edited by mickym
      @hackypaddy
      Probiere doch mal wie ich gesagt habe die Partition nicht in der Node zu verwenden sondern mit der payload?
      hast Du denn das schon versucht: https://forum.iobroker.net/post/1098790
      Ich probiere parallel einen Flow zu erstellen, aber Du würdest Dir das Leben viel einfacher machen. Bitte probiere das erst aus.
        HackyPaddy @mickym last edited by
        @mickym
        hier mal mein Flow, wie ich ihn gerade verwende. Ziel wäre es, die einzelnen Bereiche nacheinander abzufragen. Erst Bereich 1, dann Bereich 2, usw.
                "id": "21ba77d9f363fc5c",
                "type": "tab",
                "label": "Secvest",
                "disabled": false,
                "info": "",
                "env": []
                "id": "7de9826e28d68b1d",
                "type": "split",
                "z": "21ba77d9f363fc5c",
                "name": "",
                "splt": "\\n",
                "spltType": "str",
                "arraySplt": 1,
                "arraySpltType": "len",
                "stream": false,
                "addname": "topic",
                "x": 690,
                "y": 220,
                "wires": [
                        "7ae37472e7b5ca96"
                "id": "7ae37472e7b5ca96",
                "type": "change",
                "name": "",
                "rules": [
                        "t": "change",
                        "p": "payload.name",
                        "pt": "msg",
                        "from": ".",
                        "fromt": "str",
                        "to": "",
                        "tot": "str"
                        "t": "set",
                        "p": "topic",
                        "pt": "msg",
                        "to": "\"0_userdata.0.Alarm.\" & payload.id & \".\" &  payload.name",
                        "tot": "jsonata"
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "payload.state",
                        "tot": "msg"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 730,
                "y": 300,
                "wires": [
                        "3f9d9626684a6018"
                "id": "3f9d9626684a6018",
                "type": "ioBroker out",
                "name": "",
                "topic": "",
                "ack": "true",
                "autoCreate": "true",
                "stateName": "",
                "role": "",
                "payloadType": "",
                "readonly": "",
                "stateUnit": "",
                "stateMin": "",
                "stateMax": "",
                "x": 720,
                "y": 380,
                "wires": []
                "id": "736b74f1fd7dfdd5",
                "type": "Secvest Status",
                "name": "Bereich 1",
                "server": "5dc4b66ee70b8720",
                "partition": "1",
                "command": "zones",
                "x": 400,
                "y": 140,
                "wires": [
                        "7de9826e28d68b1d"
                "id": "c9f81194989a2d11",
                "type": "inject",
                "name": "Alle 45 Sek.",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": "1",
                "topic": "",
                "payload": "",
                "payloadType": "date",
                "x": 130,
                "y": 100,
                "wires": [
                        "736b74f1fd7dfdd5",
                        "3149fd696d113580",
                        "427ed92e5fcf9fa0",
                        "a7ae4222d4fc65a0"
                "id": "3149fd696d113580",
                "name": "Bereich 2",
                "partition": "2",
                "command": "zones",
                "x": 420,
                "y": 200,
                "wires": [
                        "7de9826e28d68b1d"
                "id": "427ed92e5fcf9fa0",
                "name": "Bereich 3",
                "partition": "3",
                "command": "zones",
                "x": 400,
                "y": 260,
                "wires": [
                        "7de9826e28d68b1d"
                "id": "a7ae4222d4fc65a0",
                "name": "Bereich 4",
                "partition": "4",
                "command": "zones",
                "x": 390,
                "y": 320,
                "wires": [
                        "7de9826e28d68b1d"
                "id": "5dc4b66ee70b8720",
                "type": "ABUS Secvest",
                "servername": "Secvest",
                "host": "192.168.10.121",
                "port": "4433",
                "user": "Alert",
                "password": "xxxx"
        • mickym
          @hackypaddy Ja trotzdem probiere es bitte -
          Nimm einfach eine von den Secvest Nodes - mach dahinter eine Debug Node und schau ob Du mit
          einer Inject Node mit einer payload die eine der 3. Partitions enthält abfragst?
          Wie gesagt es geht auch mit 4 Nodes - aber es ist einfach ÜBERFLÜSSIG, wenn der Entwickler anbietet, dass man mit einer payload die Partitionen einzeln abfragen kann.
          • mickym
            mickym Most Active @mickym last edited by
            @hackpaddy
            Hast Du es probiert???
              @mickym
              Ich bin noch dabei, aber so wie es aussieht, funktioniert das nicht...
              • mickym
                @hackypaddy dann probiere es mal mit den beiden Inject Nodes und schau ob da was rauskommt.
                In der Node löscht Du Command und Partition bitte.
                       "id": "30a75b4cea8b0f90",
                       "type": "inject",
                       "z": "517cd16e4d7e6ae4",
                       "name": "",
                       "props": [
                               "p": "payload"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "{\"command\":\"state\",\"partition\":\"3\"}",
                       "payloadType": "json",
                       "x": 830,
                       "y": 1480,
                       "wires": [
                       "id": "b886fcf335c578ce",
                       "type": "inject",
                       "name": "",
                       "props": [
                               "p": "payload"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "{\"command\":\"state\",\"partition\":3}",
                       "x": 830,
                       "y": 1520,
                       "wires": [
                • mickym
                  So nachdem ich von Dir leider keinen Response bekomme, und das eigentlich gehen müsste, habe ich Dir hier nun einen Flow gebastelt - der den Status abfragt und mit dem ich Deine Secvest Nodes simuliert habe
                  Die Nachricht kommt nur raus, wenn der Status OK ist.
                  Du musst aber vorher in der Statusermittlung die ID der Nodes in die Switch Node eintragen. Wenn Du das mal durchgespielt hast hier mit diesem Flow - dann wirst Du es auch auf den realen Flow umsetzen können:
                         "id": "c05f687368999ce5",
                         "type": "group",
                         "name": "Hauptflow",
                         "style": {
                             "fill": "#e3f3d3",
                             "label": true
                         "nodes": [
                             "edf6186f87bd29cf",
                             "43d75f1a298e4228",
                             "5c2a6fd166cadeea",
                             "1f3ca857652a6f2d",
                             "d0227b7791f129b7",
                             "4385c065f4bcf50b",
                             "2686fd64b3416b63",
                             "105628d009801c57"
                         "x": 54,
                         "y": 1559,
                         "w": 1612,
                         "h": 82
                         "id": "edf6186f87bd29cf",
                         "type": "debug",
                         "g": "c05f687368999ce5",
                         "name": "Nachricht",
                         "active": true,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "complete": "payload",
                         "targetType": "msg",
                         "statusVal": "",
                         "statusType": "auto",
                         "x": 1560,
                         "y": 1600,
                         "wires": []
                         "id": "43d75f1a298e4228",
                         "type": "link call",
                         "name": "",
                         "links": [
                             "0261bc0c575a8179"
                         "linkType": "static",
                         "timeout": "30",
                         "x": 340,
                         "y": 1600,
                         "wires": [
                                 "1f3ca857652a6f2d"
                         "id": "5c2a6fd166cadeea",
                         "type": "inject",
                         "name": "trigger",
                         "props": [
                                 "p": "payload"
                         "repeat": "",
                         "crontab": "",
                         "once": false,
                         "onceDelay": 0.1,
                         "topic": "",
                         "payload": "true",
                         "payloadType": "bool",
                         "x": 150,
                         "y": 1600,
                         "wires": [
                                 "43d75f1a298e4228"
                         "id": "1f3ca857652a6f2d",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "result",
                                 "pt": "msg",
                                 "to": "$flowContext(\"Secvest.partition.\"& next)\t",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 540,
                         "y": 1600,
                         "wires": [
                                 "d0227b7791f129b7"
                         "id": "d0227b7791f129b7",
                         "type": "switch",
                         "name": "Nur wenn OK?",
                         "property": "result",
                         "propertyType": "msg",
                         "rules": [
                                 "t": "cont",
                                 "v": "OK",
                                 "vt": "str"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 1,
                         "x": 740,
                         "y": 1600,
                         "wires": [
                                 "2686fd64b3416b63"
                         "id": "4385c065f4bcf50b",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "Secvest.nextPart",
                                 "pt": "flow",
                                 "to": "next",
                                 "tot": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1340,
                         "y": 1600,
                         "wires": [
                                 "edf6186f87bd29cf"
                         "id": "2686fd64b3416b63",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "next",
                                 "pt": "msg",
                                 "to": "next + 1",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 940,
                         "y": 1600,
                         "wires": [
                                 "105628d009801c57"
                         "id": "105628d009801c57",
                         "type": "range",
                         "minin": "1",
                         "maxin": "5",
                         "minout": "1",
                         "maxout": "5",
                         "action": "roll",
                         "round": true,
                         "property": "next",
                         "name": "",
                         "x": 1110,
                         "y": 1600,
                         "wires": [
                                 "4385c065f4bcf50b"
                         "id": "79474f37517badfa",
                         "type": "group",
                         "name": "Status",
                         "style": {
                             "fill": "#ffffbf",
                             "label": true
                         "nodes": [
                             "046d20801968277a",
                             "166f54f5d95776c5",
                             "967ae311bedb5398",
                             "f531134c2d277c8e",
                             "f7e0ad7f8c47e9e2",
                             "b859b6f87ebdea89",
                             "acd1fb1a37c75788"
                         "x": 54,
                         "y": 1659,
                         "w": 672,
                         "h": 222
                         "id": "046d20801968277a",
                         "type": "status",
                         "g": "79474f37517badfa",
                         "name": "",
                         "scope": [
                             "26da1e75ad50f497",
                             "77406c09f2b4935f",
                             "a36d2b0336d314d5",
                             "dca5caeebd3fa237"
                         "x": 140,
                         "y": 1780,
                         "wires": [
                                 "166f54f5d95776c5",
                                 "f531134c2d277c8e"
                         "id": "166f54f5d95776c5",
                         "type": "switch",
                         "name": "",
                         "property": "status.source.id",
                         "rules": [
                                 "t": "eq",
                                 "v": "26da1e75ad50f497",
                                 "vt": "str"
                                 "t": "eq",
                                 "v": "77406c09f2b4935f",
                                 "vt": "str"
                                 "t": "eq",
                                 "v": "a36d2b0336d314d5",
                                 "vt": "str"
                                 "t": "eq",
                                 "v": "dca5caeebd3fa237",
                                 "vt": "str"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 4,
                         "x": 330,
                         "y": 1760,
                         "wires": [
                                 "967ae311bedb5398"
                                 "f7e0ad7f8c47e9e2"
                                 "b859b6f87ebdea89"
                                 "acd1fb1a37c75788"
                         "id": "967ae311bedb5398",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "Secvest.partition.1",
                                 "pt": "flow",
                                 "to": "status.text ",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 580,
                         "y": 1700,
                         "wires": [
                         "id": "f531134c2d277c8e",
                         "type": "debug",
                         "name": "status all",
                         "active": false,
                         "tosidebar": true,
                         "console": false,
                         "tostatus": false,
                         "complete": "status",
                         "statusVal": "",
                         "x": 320,
                         "y": 1840,
                         "wires": []
                         "id": "f7e0ad7f8c47e9e2",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "Secvest.partition.2",
                                 "pt": "flow",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 580,
                         "y": 1740,
                         "wires": [
                         "id": "b859b6f87ebdea89",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "Secvest.partition.3",
                                 "pt": "flow",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 580,
                         "y": 1780,
                         "wires": [
                         "id": "acd1fb1a37c75788",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "Secvest.partition.4",
                                 "pt": "flow",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 580,
                         "y": 1820,
                         "wires": [
                         "id": "b7fe5d925d8e97e6",
                         "type": "group",
                         "name": "Abfrage",
                         "style": {
                             "fill": "#dbcbe7",
                             "label": true
                         "nodes": [
                             "678dc9ba9d8c785f",
                             "f848c65833d70071",
                             "40bce79305c4643d",
                             "26da1e75ad50f497",
                             "50b76a92e1d49815",
                             "610c1cd0aa01c457",
                             "edf0b36304b14ced",
                             "77406c09f2b4935f",
                             "b291f001e92e6035",
                             "94e0553e3cd9b288",
                             "27712704a9ab0b48",
                             "a36d2b0336d314d5",
                             "fd85b9e702df0f23",
                             "b3e5ed6bd910648d",
                             "d6c566a7f673e2bf",
                             "dca5caeebd3fa237",
                             "6203be293dd53946",
                             "77ed707586880c2f",
                             "0261bc0c575a8179",
                             "c867ec0ddf91ddf0",
                             "bf53714046156c85",
                             "de3b72e71c80a313"
                         "x": 54,
                         "y": 1899,
                         "w": 1612,
                         "h": 422
                         "id": "678dc9ba9d8c785f",
                         "type": "switch",
                         "g": "b7fe5d925d8e97e6",
                         "name": "part1",
                         "property": "$random()\t",
                         "propertyType": "jsonata",
                         "rules": [
                                 "t": "lt",
                                 "v": "0.5",
                                 "vt": "num"
                                 "t": "gte",
                                 "v": "0.5",
                                 "vt": "num"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 2,
                         "x": 630,
                         "y": 1960,
                         "wires": [
                                 "f848c65833d70071"
                                 "40bce79305c4643d"
                         "id": "f848c65833d70071",
                         "type": "change",
                         "name": "Ergebnis Ok",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "[{\"id\":\"109\",\"name\":\"Kontakt\",\"state\":\"closed\"},{\"id\":\"110\",\"name\":\"BW Fen. R.\",\"state\":\"closed\"}]",
                                 "tot": "json"
                                 "t": "set",
                                 "p": "topic",
                                 "pt": "msg",
                                 "to": "part1",
                                 "tot": "str"
                                 "t": "set",
                                 "p": "status",
                                 "pt": "msg",
                                 "to": "{\"fill\":\"green\",\"shape\":\"dot\",\"text\":\"OK\"}",
                                 "tot": "json"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 830,
                         "y": 1940,
                         "wires": [
                                 "26da1e75ad50f497"
                         "id": "40bce79305c4643d",
                         "type": "change",
                         "name": "Ergebnis Nicht Ok",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "to": "[{\"id\":\"109\",\"name\":\"Kontakt\",\"state\":\"closed\"}]",
                                 "tot": "json"
                                 "t": "set",
                                 "p": "topic",
                                 "pt": "msg",
                                 "to": "part1",
                                 "tot": "str"
                                 "t": "set",
                                 "p": "status",
                                 "pt": "msg",
                                 "to": "{\"fill\":\"red\",\"shape\":\"dot\",\"text\":\"Error\"}",
                                 "tot": "json"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 810,
                         "y": 1980,
                         "wires": [
                                 "26da1e75ad50f497"
                         "id": "26da1e75ad50f497",
                         "type": "function",
                         "name": "Simuliere Secvest Command - Partition 1",
                         "func": "var newMsg;\nnode.status(msg.status);\nnewMsg = {topic:msg.topic, payload:msg.payload}\nreturn msg;",
                         "outputs": 1,
                         "noerr": 0,
                         "initialize": "",
                         "finalize": "",
                         "libs": [],
                         "x": 1120,
                         "y": 1960,
                         "wires": [
                                 "de3b72e71c80a313"
                         "id": "50b76a92e1d49815",
                         "type": "switch",
                         "name": "part2",
                         "rules": [
                                 "t": "lt",
                                 "v": "0.5",
                                 "vt": "num"
                                 "t": "gte",
                                 "v": "0.5",
                                 "vt": "num"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 2,
                         "x": 630,
                         "y": 2060,
                         "wires": [
                                 "610c1cd0aa01c457"
                                 "edf0b36304b14ced"
                         "id": "610c1cd0aa01c457",
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "json"
                                 "t": "set",
                                 "p": "topic",
                                 "pt": "msg",
                                 "to": "part2",
                                 "tot": "str"
                                 "t": "set",
                                 "p": "status",
                                 "pt": "msg",
                                 "tot": "json"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 830,
                         "y": 2040,
                         "wires": [
                                 "77406c09f2b4935f"
                         "id": "edf0b36304b14ced",
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "json"
                                 "t": "set",
                                 "p": "topic",
                                 "pt": "msg",
                                 "to": "part2",
                                 "tot": "str"
                                 "t": "set",
                                 "p": "status",
                                 "pt": "msg",
                                 "tot": "json"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 810,
                         "y": 2080,
                         "wires": [
                                 "77406c09f2b4935f"
                         "id": "77406c09f2b4935f",
                         "type": "function",
                         "name": "Simuliere Secvest Command - Partition 2",
                         "outputs": 1,
                         "noerr": 0,
                         "initialize": "",
                         "finalize": "",
                         "libs": [],
                         "x": 1120,
                         "y": 2060,
                         "wires": [
                                 "de3b72e71c80a313"
                         "id": "b291f001e92e6035",
                         "type": "switch",
                         "name": "part3",
                         "rules": [
                                 "t": "lt",
                                 "v": "0.5",
                                 "vt": "num"
                                 "t": "gte",
                                 "v": "0.5",
                                 "vt": "num"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 2,
                         "x": 630,
                         "y": 2160,
                         "wires": [
                                 "94e0553e3cd9b288"
                                 "27712704a9ab0b48"
                         "id": "94e0553e3cd9b288",
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "json"
                                 "t": "set",
                                 "p": "topic",
                                 "pt": "msg",
                                 "to": "part3",
                                 "tot": "str"
                                 "t": "set",
                                 "p": "status",
                                 "pt": "msg",
                                 "tot": "json"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 830,
                         "y": 2140,
                         "wires": [
                                 "a36d2b0336d314d5"
                         "id": "27712704a9ab0b48",
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "json"
                                 "t": "set",
                                 "p": "topic",
                                 "pt": "msg",
                                 "to": "part3",
                                 "tot": "str"
                                 "t": "set",
                                 "p": "status",
                                 "pt": "msg",
                                 "tot": "json"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 810,
                         "y": 2180,
                         "wires": [
                                 "a36d2b0336d314d5"
                         "id": "a36d2b0336d314d5",
                         "type": "function",
                         "name": "Simuliere Secvest Command - Partition 3",
                         "outputs": 1,
                         "noerr": 0,
                         "initialize": "",
                         "finalize": "",
                         "libs": [],
                         "x": 1120,
                         "y": 2160,
                         "wires": [
                                 "de3b72e71c80a313"
                         "id": "fd85b9e702df0f23",
                         "type": "switch",
                         "name": "part4",
                         "rules": [
                                 "t": "lt",
                                 "v": "0.5",
                                 "vt": "num"
                                 "t": "gte",
                                 "v": "0.5",
                                 "vt": "num"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 2,
                         "x": 630,
                         "y": 2260,
                         "wires": [
                                 "b3e5ed6bd910648d"
                                 "d6c566a7f673e2bf"
                         "id": "b3e5ed6bd910648d",
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "json"
                                 "t": "set",
                                 "p": "topic",
                                 "pt": "msg",
                                 "to": "part4",
                                 "tot": "str"
                                 "t": "set",
                                 "p": "status",
                                 "pt": "msg",
                                 "tot": "json"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 830,
                         "y": 2240,
                         "wires": [
                                 "dca5caeebd3fa237"
                         "id": "d6c566a7f673e2bf",
                         "type": "change",
                         "rules": [
                                 "t": "set",
                                 "p": "payload",
                                 "pt": "msg",
                                 "tot": "json"
                                 "t": "set",
                                 "p": "topic",
                                 "pt": "msg",
                                 "to": "part4",
                                 "tot": "str"
                                 "t": "set",
                                 "p": "status",
                                 "pt": "msg",
                                 "tot": "json"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 810,
                         "y": 2280,
                         "wires": [
                                 "dca5caeebd3fa237"
                         "id": "dca5caeebd3fa237",
                         "type": "function",
                         "name": "Simuliere Secvest Command - Partition 4",
                         "outputs": 1,
                         "noerr": 0,
                         "initialize": "",
                         "finalize": "",
                         "libs": [],
                         "x": 1120,
                         "y": 2260,
                         "wires": [
                                 "de3b72e71c80a313"
                         "id": "6203be293dd53946",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "set",
                                 "p": "next",
                                 "pt": "msg",
                                 "to": "$exists($flowContext(\"Secvest.nextPart\")) ? $flowContext(\"Secvest.nextPart\") : 1\t\t",
                                 "tot": "jsonata"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 220,
                         "y": 2100,
                         "wires": [
                                 "77ed707586880c2f"
                         "id": "77ed707586880c2f",
                         "type": "switch",
                         "name": "",
                         "property": "next",
                         "rules": [
                                 "t": "eq",
                                 "v": "1",
                                 "vt": "num"
                                 "t": "eq",
                                 "v": "2",
                                 "vt": "num"
                                 "t": "eq",
                                 "v": "3",
                                 "vt": "num"
                                 "t": "eq",
                                 "v": "4",
                                 "vt": "num"
                         "checkall": "true",
                         "repair": false,
                         "outputs": 4,
                         "x": 430,
                         "y": 2100,
                         "wires": [
                                 "678dc9ba9d8c785f"
                                 "50b76a92e1d49815"
                                 "b291f001e92e6035"
                                 "fd85b9e702df0f23"
                         "id": "0261bc0c575a8179",
                         "type": "link in",
                         "name": "queryPartition",
                         "links": [],
                         "x": 95,
                         "y": 2100,
                         "wires": [
                                 "6203be293dd53946"
                         "id": "c867ec0ddf91ddf0",
                         "type": "link out",
                         "name": "queryResponse",
                         "mode": "return",
                         "links": [],
                         "x": 1625,
                         "y": 2100,
                         "wires": []
                         "id": "bf53714046156c85",
                         "type": "change",
                         "name": "",
                         "rules": [
                                 "t": "delete",
                                 "p": "status",
                                 "pt": "msg"
                         "action": "",
                         "property": "",
                         "from": "",
                         "to": "",
                         "reg": false,
                         "x": 1490,
                         "y": 2100,
                         "wires": [
                                 "c867ec0ddf91ddf0"
                         "id": "de3b72e71c80a313",
                         "type": "junction",
                         "x": 1360,
                         "y": 2100,
                         "wires": [
                                 "bf53714046156c85"
                  Vorerst ist das Thema aber für mich damit erst mal abgeschlossen.
                    @mickym
                    Wow, danke.
                    Ich bin grad unterwegs, deshalb kann ich das nicht so schnell durchtesten...
                    Wenn ich nachher zuhause bin, schau ich mir Deinen Flow mal an und versuche den zu verstehen.
                    Wahnsinn, vielen Dank für deine Arbeit!
                    • mickym
                      @hackypaddy Wie gesagt, wenn Du das mit der payload und den Einzelabrufen in einer Node machen kannst, dann hätte ich mir diese Arbeit sparen können.
                        @mickym
                        Ne das geht ja nicht, also in einer Node.
                        • mickym
                          @hackypaddy Lt. Beschreibung muss das aber gehen.
                            @mickym
                            ich bekomm da nichts raus.
                            Hab mir gerade mal Dein Konstrukt angeschaut (auf dem Handy). Meine Herren, mir raucht der Kopf. Ich setz mich da nachher mal ran und versuch das alles irgendwie zu verstehen.
                              @mickym
                              Ich hab jetzt 3 Stunden probiert, und es funktioniert nicht. Und dann fiel es mir wie Schuppen von den Augen, als ich die Beschreibung nochmal genau durchgelesen hab...
                              Du hast den Command Baustein gemeint. Ja, diesen kannst per payload steuern und dort auch die einzelnen Partitionen abgeben. Aber diesen Baustein nutze ich nicht. Mit diesem Baustein steuert man die Anlage (scharf, unscharf, teilscharf).
                              Ich nutze nur den Status-Baustein. Dieser ließt die einzelnen Partitionen aus, gibt dann die Zonen aus und dort den Status (auf / zu).
                              Deshalb hat das vorhin auch nicht funktioniert.
                              • mickym
                                @hackypaddy Ok dann kannst Du Dir ja meinen Flow im Genauen anschauen. Kurzfristig kannst Du die Nodes ja hintereinanderschalten und ggf. einfach noch eine delay Node dazwischen machen - wenn Dir meine Lösung zu kompliziert ist.
                                1.2k
                                node-red
                                3703
