    4. ioBroker startet nicht nach Neuinstallation
      Willi-Wunder @Thomas Braun last edited by Homoran
      Okay, gerade nochmal alles neu gemacht, Image Lite ohne Desktop ausgewählt, nach Anleitung @Thomas-Braun
      ausgeführt, gleicher Fehler, siehe Log. Ab dem Punkt Installation 3/4 Iobroker hat es ca. 25 min. gedauert, dann kommt zwar ioBroker was installed successfully, kann diesen aber nicht über die Adresse aufrufen.
      pi@iobroker:~ $ curl -sLf https://iobroker.net/install.sh | bash -
      library: loaded
      Library version=2023-10-13
          Welcome to the ioBroker installer!
          Installer version: 2023-10-13
          You might need to enter your password a couple of times.
          Installing prerequisites (1/4)
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Reading package lists... Done
          Node.js not found. Installing...
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Building dependency tree... Done
      ca-certificates is already the newest version (20230311).
      curl is already the newest version (7.88.1-10+deb12u4).
      gnupg is already the newest version (2.2.40-1.1).
      gnupg set to manually installed.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node        _18.x nodistro main
       Processing triggers for man-db (2.11.2-2) ...ource1_arm64.deb ...led.)
      Installed nodejs
      Node.js Installed successfully!
      Changing npm registry to https://registry.npmjs.org
       Processing triggers for man-db (2.11.2-2) ...arm64.deb ... installed.)
      Installed acl
       Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-10) ...-10_arm64.deb ...
      Installed libavahi-compat-libdnssd-dev
       Processing triggers for man-db (2.11.2-2) ...1) ...1_arm64.deb ...ed.)
      Installed libudev-dev
       Processing triggers for man-db (2.11.2-2) ...eb12u1) ...1_arm64.deb ...
      Installed libpam0g-dev
       Processing triggers for man-db (2.11.2-2) ...m64.deb ......installed.)
      Installed git
      Extracting templates from packages: 100%
       Preparing to unpack .../10-libcairo-script-interpreter2_1.16.0-7+rpt1_arm64.deb        Setting up libcairo2-dev:arm64 (1.16.0-7+rpt1) ....u3) ...t1) .........
      Installed libcairo2-dev
       Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ...m64.deb ... ....
      Installed libpango1.0-dev
       Setting up libjpeg-dev:arm64 (1:2.1.5-2) ...5-2) ...4.deb ....deb ...)
      Installed libjpeg-dev
       Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ... installed.)
      Installed libgif-dev
       Preparing to unpack .../16-libgdk-pixbuf-2.0-dev_2.42.10+dfsg-1+b1_arm64.deb ..        Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.10+dfsg-1+b1) ........
      Installed librsvg2-dev
       Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) .....nstalled.)
      Installed cmake
          Creating ioBroker user and directory (2/4)
      User iobroker created
      Created /etc/sudoers.d/iobroker
      Directory /opt/iobroker created
          Installing ioBroker (3/4)
      npm ERR! code ECONNRESET
      npm ERR! network aborted
      npm ERR! network This is a problem related to network connectivity.
      npm ERR! network In most cases you are behind a proxy or have bad network settin        gs.
      npm ERR! network
      npm ERR! network If you are behind a proxy, please make sure that the
      npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12        -22T16_47_20_580Z-debug-0.log
          Finalizing installation (4/4)
      Enabling autostart...
      Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /        lib/systemd/system/iobroker.service.
      Autostart enabled!
      Fixing directory permissions...
          Open http://192.168.2.230:8081 in a browser and start configuring!
      You need to re-login before doing anything else on the console!
      Und jetzt? 😕
      Iobroker Status
       pi@iobroker:~ $ iobroker status
      Uncaught Rejection: Error: /opt/iobroker/iobroker-data/iobroker.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/iobroker.json'
          at Object.openSync (node:fs:596:3)
          at Object.readFileSync (node:fs:464:35)
          at Object.readFileSync (/opt/iobroker/node_modules/jsonfile/index.js:50:22)
          at dbConnect (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/dbConnection.js:63:39)
          at CLIProcess.status (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/cli/cliProcess.js:194:9)
          at processCommand (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js:483:25)
          at Object.execute (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js:2705:5)
          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:40)
          at Module._compile (node:internal/modules/cjs/loader:1356:14)
          at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
        A Former User last edited by
        @willi-wunder sagte in ioBroker startet nicht nach Neuinstallation:
        Und jetzt?
        Moin,
        kann es sein, dass Deine Netzwerkanbindung nicht gut ist?
        Denn da steht ja,
        npm ERR! network
        Es kann auch mal wieder sein, dass der Server ausgelastet ist, vielleicht später noch einmal mit dem Befehl versuchen,, das Skript sollte dann ja 1 und 2 überspringen.
        VG
        Bernd
          Homoran Global Moderator Administrators @Willi-Wunder last edited by
          der mag nicht ins Internet
            A Former User @Homoran last edited by A Former User
            @homoran sagte in ioBroker startet nicht nach Neuinstallation:
            Moin,
            doch, denn Punkt 1, die prerequisites kann er ja holen!
            VG
            Bernd
            P.S.: aktuell ist die Verbindung von hier zum iobroker.net ok, wie es vom TE aus sieht
            ❯ ping iobroker.net
            PING iobroker.net (82.165.135.239) 56(84) Bytes an Daten.
            64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=1 ttl=56 Zeit=13.5 ms
            64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=2 ttl=56 Zeit=13.0 ms
            64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=3 ttl=56 Zeit=12.9 ms
            64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=4 ttl=56 Zeit=12.9 ms
            64 Bytes von s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=5 ttl=56 Zeit=12.6 ms
            ^C
            --- iobroker.net ping-Statistik ---
            5 Pakete übertragen, 5 empfangen, 0% packet loss, time 4006ms
            rtt min/avg/max/mdev = 12.584/12.970/13.529/0.307 ms
            ❯ traceroute iobroker.net
            traceroute to iobroker.net (82.165.135.239), 30 hops max, 60 byte packets
             1  _gateway (192.168.178.1)  0.317 ms  0.501 ms  0.582 ms
             2  lo0.irai0010.as9136.net (62.176.224.222)  4.709 ms  4.797 ms  4.769 ms
             3  ae0-181.irci0006.as9136.net (62.176.238.143)  4.794 ms  4.767 ms  4.733 ms
             4  et-0-0-0-0.cfrc2101.as9136.net (62.176.251.11)  11.192 ms  11.251 ms  11.224 ms
             5  decix.bb-a.fra3.fra.de.net.ionos.com (80.81.192.123)  11.437 ms  11.444 ms  11.670 ms
             6  lo-0-0.rc-a.bap.rhr.de.net.ionos.com (212.227.117.208)  17.202 ms  18.543 ms  18.463 ms
             7  port-channel-2.gw-distdh-a.kw.nbz.fr.net.ionos.com (195.20.243.9)  16.602 ms  13.515 ms  14.033 ms
             8  ae-1.gw-prtr-a0110-a.kw.nbz.fr.net.ionos.com (195.20.243.81)  19.131 ms * *
             9  s21181212.onlinehome-server.info (82.165.135.239)  19.532 ms  15.488 ms  14.474 ms
              Willi-Wunder @Guest last edited by
              @dp20eic sagte in ioBroker startet nicht nach Neuinstallation:
              Moin,
              Wäre mir nicht bekannt, läuft hier alles. Mein System Rasp scheint ja auch keine Probleme zu haben, der hat aber eine Fest IP. Mal die Netzwerk Einstellung in den anderen kopieren? Wo steht das genau drin? Hab mittlerweile einen zweiten Rasp bekommen, somit kann ich auf beide zugreifen.......
              Thomas Braun ? 2 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @Willi-Wunder last edited by
                @willi-wunder
                IPv6 aktiv?
                  A Former User @Willi-Wunder last edited by
                  Moin,
                  damit ist ja auch nicht nur Dein Netzwerk gemeint, es kann ja sein, dass jemand zum iobroker.net auf der Leitung steht, dass Du vielleicht bis zu Deinem Provider eine stabile Leitung hast ist ja nur die halbe Miete.
                  VG
                  Bernd
                    Nein, bin mir aber nicht sicher. Wie kann ich das prüfen? Der andere Rasp läuft ja auch.......
                    • Marc Berg
                      Marc Berg Most Active @Willi-Wunder last edited by
                      ping registry.npmjs.org
                      vom Raspi aus.
                        @marc-berg sagte in ioBroker startet nicht nach Neuinstallation:
                        pi@iobroker:~ $ ping registry.npmjs.org
                        PING registry.npmjs.org(2606:4700::6810:23 (2606:4700::6810:23)) 56 data bytes
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=1 ttl=57 time=210 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=3 ttl=57 time=202 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=4 ttl=57 time=225 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=5 ttl=57 time=217 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=8 ttl=57 time=209 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=9 ttl=57 time=175 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=10 ttl=57 time=181 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=11 ttl=57 time=221 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=12 ttl=57 time=218 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=13 ttl=57 time=213 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=14 ttl=57 time=208 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=15 ttl=57 time=214 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=16 ttl=57 time=216 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=17 ttl=57 time=217 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=18 ttl=57 time=215 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=19 ttl=57 time=222 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=20 ttl=57 time=220 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=21 ttl=57 time=219 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=22 ttl=57 time=219 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=23 ttl=57 time=214 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=24 ttl=57 time=213 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=25 ttl=57 time=217 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=26 ttl=57 time=215 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=27 ttl=57 time=214 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=28 ttl=57 time=216 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=29 ttl=57 time=222 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=31 ttl=57 time=222 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=33 ttl=57 time=228 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=36 ttl=57 time=216 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=37 ttl=57 time=217 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=39 ttl=57 time=217 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=40 ttl=57 time=220 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=41 ttl=57 time=215 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=42 ttl=57 time=216 ms
                        64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=43 ttl=57 time=220 ms
                        Ist das jetzt gut oder schlecht?
                        • Marc Berg
                          Das heißt zumindest, dass IPv6 eingerichtet ist und funktioniert. Gut, dass es funktioniert. Schlecht, dass die Ursache weiter unklar bleibt.
                            Willi-Wunder @Marc Berg last edited by
                            @marc-berg
                            Das sudo apt update && sudo apt full-upgrade hat er doch auch ausgeführt, daher gehe ich davon aus, dass die Internetverbindung eigentlich paßt.
                            W Homoran 2 Replies Last reply Reply Quote 0
                              Willi-Wunder @Willi-Wunder last edited by Homoran
                              Hab jetzt nochmal curl -sLf https://iobroker.net/install.sh | bash - ausgeführt, log ist
                              npm ERR! code ENOTEMPTY
                              npm ERR! syscall rename
                              npm ERR! path /opt/iobroker/node_modules/iobroker.admin
                              npm ERR! dest /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
                              npm ERR! errno -39
                              npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.admin' -> '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
                              npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-22T19_13_30_176Z-debug-0.log
                              Autostart enabled!
                                @marc-berg
                                das geht zum linux Repo. das sind andere Server
                                Der Fehler bei dir trat auf, als das InstallTionsskript auf den npm-server zugreifen wollte
                                  ping iobroker.net
                                  Sieht bei mir auch gut aus, hmm
                                  pi@iobroker:~ $ ping iobroker.net
                                  PING iobroker.net (82.165.135.239) 56(84) bytes of data.
                                  64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=1 ttl=56 time=16.8 ms
                                  64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=2 ttl=56 time=14.8 ms
                                  ^C
                                  --- iobroker.net ping statistics ---
                                  60 packets transmitted, 60 received, 0% packet loss, time 59091ms
                                  rtt min/avg/max/mdev = 14.449/15.131/17.219/0.487 ms
                                  • Marc Berg
                                    @willi-wunder
                                    was sagt eigentlich das besagte Log:
                                      @marc-berg
                                      Das Verzeichnis scheint es nicht zu geben......
                                      • Marc Berg
                                        Marc Berg Most Active @Willi-Wunder last edited by Marc Berg
                                        @marc-berg
                                        Das ist ein verstecktes. Du musst das Anzeigen aktivieren. Womit guckst du da?
                                          @marc-berg
                                          Mit WinSCP .......war aber gerade auf dem aktiven System, sorry. Auf den neuen kann ich mich gerade nicht einloggen mit root......
                                          Marc Berg Thomas Braun 3 Replies Last reply Reply Quote 0
                                          • Marc Berg
                                            Aber doch mit "pi"?
                                            Und dann Strg+Alt+H, um versteckte Dateien anzuzeigen.
                                            3865
