    4. ioBroker startet nicht nach Neuinstallation
      Willi-Wunder last edited by
      @marc-berg sagte in ioBroker startet nicht nach Neuinstallation:
      ping registry.npmjs.org
      pi@iobroker:~ $ ping registry.npmjs.org
      PING registry.npmjs.org(2606:4700::6810:23 (2606:4700::6810:23)) 56 data bytes
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=1 ttl=57 time=210 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=3 ttl=57 time=202 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=4 ttl=57 time=225 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=5 ttl=57 time=217 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=8 ttl=57 time=209 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=9 ttl=57 time=175 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=10 ttl=57 time=181 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=11 ttl=57 time=221 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=12 ttl=57 time=218 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=13 ttl=57 time=213 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=14 ttl=57 time=208 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=15 ttl=57 time=214 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=16 ttl=57 time=216 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=17 ttl=57 time=217 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=18 ttl=57 time=215 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=19 ttl=57 time=222 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=20 ttl=57 time=220 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=21 ttl=57 time=219 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=22 ttl=57 time=219 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=23 ttl=57 time=214 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=24 ttl=57 time=213 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=25 ttl=57 time=217 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=26 ttl=57 time=215 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=27 ttl=57 time=214 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=28 ttl=57 time=216 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=29 ttl=57 time=222 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=31 ttl=57 time=222 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=33 ttl=57 time=228 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=36 ttl=57 time=216 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=37 ttl=57 time=217 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=39 ttl=57 time=217 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=40 ttl=57 time=220 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=41 ttl=57 time=215 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=42 ttl=57 time=216 ms
      64 bytes from 2606:4700::6810:23 (2606:4700::6810:23): icmp_seq=43 ttl=57 time=220 ms
      Ist das jetzt gut oder schlecht?
      • Marc Berg
        Marc Berg Most Active @Willi-Wunder last edited by
        @willi-wunder sagte in ioBroker startet nicht nach Neuinstallation:
        Das heißt zumindest, dass IPv6 eingerichtet ist und funktioniert. Gut, dass es funktioniert. Schlecht, dass die Ursache weiter unklar bleibt.
          Willi-Wunder @Marc Berg last edited by
          @marc-berg
          Das sudo apt update && sudo apt full-upgrade hat er doch auch ausgeführt, daher gehe ich davon aus, dass die Internetverbindung eigentlich paßt.
          W Homoran 2 Replies Last reply Reply Quote 0
            Willi-Wunder @Willi-Wunder last edited by Homoran
            Hab jetzt nochmal curl -sLf https://iobroker.net/install.sh | bash - ausgeführt, log ist
                Installing ioBroker (3/4)
            npm ERR! code ENOTEMPTY
            npm ERR! syscall rename
            npm ERR! path /opt/iobroker/node_modules/iobroker.admin
            npm ERR! dest /opt/iobroker/node_modules/.iobroker.admin-TtUA2igk
            npm ERR! errno -39
            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.admin' -> '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk'
            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-22T19_13_30_176Z-debug-0.log
                Finalizing installation (4/4)
            Enabling autostart...
            Autostart enabled!
            Fixing directory permissions...
                ioBroker was installed successfully
                Open http://192.168.2.230:8081 in a browser and start configuring!
              Homoran Global Moderator Administrators @Willi-Wunder last edited by
              @marc-berg
              das geht zum linux Repo. das sind andere Server
              Der Fehler bei dir trat auf, als das InstallTionsskript auf den npm-server zugreifen wollte
                Willi-Wunder @Guest last edited by
                @dp20eic sagte in ioBroker startet nicht nach Neuinstallation:
                ping iobroker.net
                Sieht bei mir auch gut aus, hmm
                pi@iobroker:~ $ ping iobroker.net
                PING iobroker.net (82.165.135.239) 56(84) bytes of data.
                64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=1 ttl=56 time=16.8 ms
                64 bytes from s21181212.onlinehome-server.info (82.165.135.239): icmp_seq=2 ttl=56 time=14.8 ms
                ^C
                --- iobroker.net ping statistics ---
                60 packets transmitted, 60 received, 0% packet loss, time 59091ms
                rtt min/avg/max/mdev = 14.449/15.131/17.219/0.487 ms
                • Marc Berg
                  @willi-wunder
                  was sagt eigentlich das besagte Log:
                    @marc-berg
                    Das Verzeichnis scheint es nicht zu geben......
                    • Marc Berg
                      Marc Berg Most Active @Willi-Wunder last edited by Marc Berg
                      @marc-berg
                      Das ist ein verstecktes. Du musst das Anzeigen aktivieren. Womit guckst du da?
                        @marc-berg
                        Mit WinSCP .......war aber gerade auf dem aktiven System, sorry. Auf den neuen kann ich mich gerade nicht einloggen mit root......
                        Marc Berg Thomas Braun 3 Replies Last reply Reply Quote 0
                        • Marc Berg
                          Aber doch mit "pi"?
                          Und dann Strg+Alt+H, um versteckte Dateien anzuzeigen.
                            @marc-berg
                            Super, danke, jetzt aber......
                            • Marc Berg
                              Aber den Ping vorhin hast du auf dem richtigen gemacht!?
                                Thomas Braun Most Active @Willi-Wunder last edited by
                                Macht man ohnehin NIE.
                                  @marc-berg
                                  Ja, in Putty ist das Fenster ja noch aktiv wo ich installiere...... 😳
                                  • Marc Berg
                                    Irgendwie passt das Log inhaltlich nicht zu den Connection-Problemen, die oben angezeigt wurden. Hab' erstmal keine Idee mehr.
                                      @marc-berg
                                      Gib mehrere Logs......denke die große Datei war vom ersten Versuch mit dem Netzwerkproblemen, danach kamen die weiteren Versuche.....
                                      2023-12-22T16_47_20_580Z-debug-0.log
                                      • Marc Berg
                                        Zeig mal noch die beiden kleinen davor.
                                          @marc-berg
                                          Leider zu spät, SD Karte gerade platt gemacht, probiere jetzt die V11 aus, ist zwar nicht Sinn und Zweck der Geschichte, aber ein Freund hatte damit nie Probleme gehabt. Mal schauen was dann hier im Log steht. Sollte eigentlich eine simple Geschichte sein, scheinbar aber gerade nicht. 🤕
                                          Danke für deine Unterstützung.
                                          Ro75 1 Reply Last reply Reply Quote 0
                                          • Ro75
                                            Ro75 @Willi-Wunder last edited by
                                            @willi-wunder schon mal eine "frische" SD-Card benutzt?
                                            Ro75.
                                            3865
