    4. ioBroker startet nicht nach Neuinstallation
      Willi-Wunder @Willi-Wunder last edited by
      Es scheint hier ein generelles Problem vorzuliegen, bullseye geht auch nicht. Hier der Log
      pi@iobroker:~ $ curl -sLf https://iobroker.net/install.sh | bash -
      library: loaded
      Library version=2023-10-13
      Welcome to the ioBroker installer!
      Installer version: 2023-10-13
      You might need to enter your password a couple of times.
      Installing prerequisites (1/4)
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
      Fetched 44.1 kB in 1s (30.8 kB/s)
      Reading package lists... Done
      Changing npm registry to https://registry.npmjs.org
      Processing triggers for man-db (2.9.4-2) ...deb ...rrently installed.)
      Installed acl
      Preparing to unpack .../5-libavahi-compat-libdnssd-dev_0.8-5+deb11u2_arm64.deb Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ....
      Installed libavahi-compat-libdnssd-dev
      Processing triggers for man-db (2.9.4-2) ...4) ...4_arm64.deb ...led.)
      Installed libudev-dev
      Processing triggers for man-db (2.9.4-2) ...u1+rpt2) ...2_arm64.deb ...
      Installed libpam0g-dev
      Processing triggers for man-db (2.9.4-2) ...11u2_arm64.deb .....lled.)
      Installed git
      Extracting templates from packages: 100%
      Preparing to unpack .../09-libcairo-script-interpreter2_1.16.0-5+rpt1_arm64.deb Preparing to unpack .../29-libpixman-1-dev_0.40.0-1.1~deb11u1+rpt1_arm64.deb .. Setting up libcairo2-dev:arm64 (1.16.0-5+rpt1) ...1+deb11u7) .........
      Installed libcairo2-dev
      Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) .... ........
      Installed libpango1.0-dev
      Setting up libjpeg-dev:arm64 (1:2.0.6-4) ...6-4) ...4.deb ....deb ...)
      Installed libjpeg-dev
      Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...lled.)
      Installed libgif-dev
      Preparing to unpack .../0-libgdk-pixbuf2.0-common_2.42.2+dfsg-1+deb11u1_all.deb Preparing to unpack .../2-libgdk-pixbuf-2.0-0_2.42.2+dfsg-1+deb11u1_arm64.deb . Preparing to unpack .../3-gir1.2-gdkpixbuf-2.0_2.42.2+dfsg-1+deb11u1_arm64.deb Preparing to unpack .../6-libgdk-pixbuf2.0-bin_2.42.2+dfsg-1+deb11u1_arm64.deb Preparing to unpack .../7-libgdk-pixbuf-2.0-dev_2.42.2+dfsg-1+deb11u1_arm64.deb Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.2+dfsg-1+deb11u1) ...
      Installed librsvg2-dev
      Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...eb ......
      Installed cmake
      Creating ioBroker user and directory (2/4)
      User iobroker created
      Created /etc/sudoers.d/iobroker
      Directory /opt/iobroker created
      Installing ioBroker (3/4)
      npm ERR! code ECONNRESET
      npm ERR! syscall read
      npm ERR! errno ECONNRESET
      npm ERR! network Invalid response body while trying to fetch https://registry.np mjs.org/@sentry%2Fcore: read ECONNRESET
      npm ERR! network This is a problem related to network connectivity.
      npm ERR! network In most cases you are behind a proxy or have bad network settin gs.
      npm ERR! network
      npm ERR! network If you are behind a proxy, please make sure that the
      npm ERR! network 'proxy' config is set properly. See: 'npm help config'
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12 -22T20_57_17_197Z-debug-0.log
      Finalizing installation (4/4)
      Enabling autostart...
      Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → / lib/systemd/system/iobroker.service.
      Autostart enabled!
      Fixing directory permissions...
      ioBroker was installed successfully
      Open http://192.168.2.230:8081 in a browser and start configuring!
      You need to re-login before doing anything else on the console!
      2023-12-22T20_57_17_197Z-debug-0.log
      2023-12-22T20_54_21_550Z-debug-0.log
      2023-12-22T20_54_20_596Z-debug-0.log
      2023-12-22T20_53_58_221Z-debug-0.log
      • Marc Berg
        Marc Berg Most Active @Willi-Wunder last edited by
        @willi-wunder sagte in ioBroker startet nicht nach Neuinstallation:
        Nein! Doch! Ohhh!
        Ist es der nicht in Code Tags gesetzten Ausgabe zu verdanken, dass da
        (mit Leerzeichen) steht?
          Willi-Wunder @Marc Berg last edited by
          @marc-berg sagte in ioBroker startet nicht nach Neuinstallation:
          Was willst du mir damit sagen? Verstehe ich gerade nicht.
          • Marc Berg
            In deinem Ausdruck des Logs
            ist ein Leerzeichen. Ich wollte wissen, ob das im Original auch so ist.
              Willi-Wunder @Marc Berg last edited by Willi-Wunder
              @marc-berg
              Das alte Putty Fenster werde ich nicht mehr aufrufen können, oder? Hab ein neues offen.
              Ich habe jetzt nochmal curl -sLf https://iobroker.net/install.sh | bash - ausgeführt, vielleicht kommt es ja nochmal.
              Thomas Braun Marc Berg 2 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @Willi-Wunder last edited by
                @willi-wunder
                Dann zieh das Fenster breiter.
                puTTY macht da immer Murks bei Zeilenumbrüchen.
                Ist mit ein Grund, warum ich die Powershell bevorzuge.
                • Marc Berg
                  Marc Berg Most Active @Willi-Wunder last edited by Marc Berg
                  Egal, ich gehe mal davon aus, dass es durch das Reinkopieren verhunzt wurde. Darum immer Text in Code Tags 03025542-0be1-4925-936a-dc88808a313d-grafik.png setzen, dann passiert das nicht.
                  Was auffällt, dass die Installation ewig dauert
                  npm Completed in 2042874ms
                  das sind ja 30min! Vielleicht wird irgendwann ein Timeout erreicht.
                  Du könntest als Workaround mal versuchen, IPv4 priorisieren:
                  sudo nano /etc/gai.conf
                  Dort die Zeile
                  #precedence ::ffff:0:0/96  100
                  suchen und einkommentieren (# löschen). Danach Datei speichern (Strg+o, <Enter>, Strg+x). Neustart ist normal nicht notwendig. Dann nochmal die Installation versuchen.
                  Das ist jetzt aber nur ein Schuss ins Blaue.
                  W 2 Replies Last reply Reply Quote 0
                    @marc-berg
                    Werde ich gleich probieren, interssant das beim zweiten Versuch ein anderer Fehler kommt
                    library: loaded
                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
                    npm ERR! code 24
                    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                    npm ERR! command failed
                    npm ERR! command sh -c node iobroker.js setup first
                    npm ERR! creating conf/iobroker.json
                    npm ERR! Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-22T21_53_43_910Z-debug-0.log
                    Autostart enabled!
                    • Marc Berg
                      @marc-berg
                      Ich denke mal, das sind Folgefehler. Insofern wäre es wohl ratsam, nochmal bei Null zu beginnen. Und dann die lieben Mitbewohner darum bitten, mal nicht die Internet-Leitung lahmzulegen. 🙂
                        Kann ich ausschließen, Kids schlafen, bin nur ich im Netz, hab 50 Mbit Leitung.
                        Ro75 1 Reply Last reply Reply Quote 0
                        • Ro75
                          Ro75 @Willi-Wunder last edited by
                          @willi-wunder Falls du noch eine andere SD-Karte zur Hand haben solltest, probiere die mal. Das 2 Betriebssysteme das gleiche Problem aufweisen, halte ich für fast unmöglich.
                          Ro75.
                            @marc-berg
                            Du wirst es nicht glauben, jetzt geht es.
                            Dort die Zeile #precedence ::ffff:0:0/96 100
                            "#" löschen.
                            Dann setze ich jetzt aber bookworm auf, macht ja dann Sinn. Gibt es eine Erklärung warum das dann vermutlich nur bei mir so ist?
                            Du bist mein Held. 👍 👍 👍
                              @willi-wunder
                              Was hast du denn da für einen Internet-Anbieter?
                                Willi-Wunder @Thomas Braun last edited by
                                Telekom
                                  @willi-wunder
                                  Ich würde sagen, da ist was 'komisch'.
                                  IPv6 sollte eigentlich funktionieren.
                                      @willi-wunder
                                      Keine Ahnung was da richtig wäre.
                                      Bei mir (Vodafone Cable 1GBit / DS Lite) steht das alles auf nativem IPv6.
                                      • Marc Berg
                                        Marc Berg Most Active last edited by
                                        @willi-wunder
                                        Bei mir (auch Telekom) steht das auf „natives IPv6 verwenden“. Bin mir aber nicht 100% sicher, was das bewirkt. Im Internet kann man dazu viele Aussagen finden, die irgendwie alle für mich nicht recht schlüssig sind. Probier's einfach aus.
                                          @marc-berg
                                          Hat mich jetzt interssiert, hab es nochmal ausprobiert, in der Fritz Box unter IPv6 "natives IPv6" aktiviert, jetzt gings pfiffig durch. Vielen Dank an alle und besonders an dich. Wieder etwas gelernt. Fall gelöst. 🙂
                                          Wünsche euche frohe und besinnliche Weihnachten
                                          3864
