    4. ioBroker startet nicht nach Neuinstallation
      Willi-Wunder @Marc Berg last edited by
      @marc-berg
      Werde ich gleich probieren, interssant das beim zweiten Versuch ein anderer Fehler kommt
      pi@iobroker:~ $ curl -sLf https://iobroker.net/install.sh | bash -
      library: loaded
      Library version=2023-10-13
          Welcome to the ioBroker installer!
          Installer version: 2023-10-13
          You might need to enter your password a couple of times.
          Installing prerequisites (1/4)
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists... Done
          Creating ioBroker user and directory (2/4)
      Created /etc/sudoers.d/iobroker
      Directory /opt/iobroker created
          Installing ioBroker (3/4)
      npm ERR! code 24
      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! command failed
      npm ERR! command sh -c node iobroker.js setup first
      npm ERR! creating conf/iobroker.json
      npm ERR! Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-22T21_53_43_910Z-debug-0.log
          Finalizing installation (4/4)
      Enabling autostart...
      Autostart enabled!
      Fixing directory permissions...
          ioBroker was installed successfully
          Open http://192.168.2.230:8081 in a browser and start configuring!
      You need to re-login before doing anything else on the console!
      • Marc Berg
        Marc Berg Most Active @Willi-Wunder last edited by
        @willi-wunder sagte in ioBroker startet nicht nach Neuinstallation:
        @marc-berg
        Ich denke mal, das sind Folgefehler. Insofern wäre es wohl ratsam, nochmal bei Null zu beginnen. Und dann die lieben Mitbewohner darum bitten, mal nicht die Internet-Leitung lahmzulegen. 🙂
          @marc-berg sagte in ioBroker startet nicht nach Neuinstallation:
          Kann ich ausschließen, Kids schlafen, bin nur ich im Netz, hab 50 Mbit Leitung.
          Ro75 1 Reply Last reply Reply Quote 0
          • Ro75
            Ro75 @Willi-Wunder last edited by
            @willi-wunder Falls du noch eine andere SD-Karte zur Hand haben solltest, probiere die mal. Das 2 Betriebssysteme das gleiche Problem aufweisen, halte ich für fast unmöglich.
            Ro75.
              @marc-berg
              Du wirst es nicht glauben, jetzt geht es.
              Dort die Zeile #precedence ::ffff:0:0/96 100
              "#" löschen.
              Dann setze ich jetzt aber bookworm auf, macht ja dann Sinn. Gibt es eine Erklärung warum das dann vermutlich nur bei mir so ist?
              Du bist mein Held. 👍 👍 👍
                Thomas Braun Most Active @Willi-Wunder last edited by
                @willi-wunder
                Was hast du denn da für einen Internet-Anbieter?
                  Willi-Wunder @Thomas Braun last edited by
                  Telekom
                    @willi-wunder
                    Ich würde sagen, da ist was 'komisch'.
                    IPv6 sollte eigentlich funktionieren.
                        @willi-wunder
                        Keine Ahnung was da richtig wäre.
                        Bei mir (Vodafone Cable 1GBit / DS Lite) steht das alles auf nativem IPv6.
                        • Marc Berg
                          Marc Berg Most Active last edited by
                          @willi-wunder
                          Bei mir (auch Telekom) steht das auf „natives IPv6 verwenden“. Bin mir aber nicht 100% sicher, was das bewirkt. Im Internet kann man dazu viele Aussagen finden, die irgendwie alle für mich nicht recht schlüssig sind. Probier's einfach aus.
                            @marc-berg
                            Hat mich jetzt interssiert, hab es nochmal ausprobiert, in der Fritz Box unter IPv6 "natives IPv6" aktiviert, jetzt gings pfiffig durch. Vielen Dank an alle und besonders an dich. Wieder etwas gelernt. Fall gelöst. 🙂
                            Wünsche euche frohe und besinnliche Weihnachten
                            3864
