    4. ioBroker hängt Sekunden, keine Daten auf Admin
    • Domi920
      Domi920 @Thomas Braun last edited by
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       13:15:07 up 13 min,  2 users,  load average: 1.27, 2.65, 1.96
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      ~ Arm frequency capping has occurred
      ~ Throttling has occurred
      ~ Soft temperature limit has occurred
      *** Time and Time Zones ***
                     Local time: Fri 2023-12-22 13:15:07 CET
                 Universal time: Fri 2023-12-22 12:15:07 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            7.8G        3.7G        2.8G        1.0M        1.4G        4.0G
      Swap:            99M          0B         99M
      Total:          7.9G        3.7G        2.9G
               7811 M total memory
               3676 M used memory
               4386 M active memory
                477 M inactive memory
               2767 M free memory
                 84 M buffer memory
               1282 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4      459G   17G  423G   4% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
      /dev/sda1      vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
      [Fri Dec 22 13:02:06 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:B1:64:81 vc_mem.        mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2e346        55c-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-ser        ial-consoles
      [Fri Dec 22 13:02:08 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Quota mode: none.
      [Fri Dec 22 13:02:08 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
      [Fri Dec 22 13:02:10 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharse        t=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.4G    /var/
      1.1G    /var/log/journal/e0851a663b704fa9bee2cff6ee1ce265
      1.1G    /var/log
      890M    /var/cache
      Archived and active journals take up 1.0G in the file system.
      /opt/iobroker/backups:
      5.7G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.6G    /opt/iobroker/iobroker-data/
      706M    /opt/iobroker/iobroker-data/history
      457M    /opt/iobroker/iobroker-data/files
      223M    /opt/iobroker/iobroker-data/backup-objects
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      70M     /opt/iobroker/iobroker-data/objects.jsonl
      51M     /opt/iobroker/iobroker-data/states.jsonl
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.ma        p
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m        ap
      18M     /opt/iobroker/iobroker-data/files/vis.0/main/vis-views.json
      USB-Devices by-id:
      USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   9
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.162.2.9, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.alexa2.1                 : alexa2                : raspberrypi                              -  enabled
        system.adapter.alexa2.2                 : alexa2                : raspberrypi                              - disabled
        system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
        system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
      + system.adapter.ecovacs-deebot.1         : ecovacs-deebot        : raspberrypi                              -  enabled
        system.adapter.ecovacs-deebot.2         : ecovacs-deebot        : raspberrypi                              - disabled
      + system.adapter.firetv.0                 : firetv                : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
        system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : raspberrypi                              -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
      + system.adapter.homekit-controller.0     : homekit-controller    : raspberrypi                              -  enabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.material.0               : material              : raspberrypi                              - disabled
      + system.adapter.maxcube.0                : maxcube               : raspberrypi                              -  enabled, port: 62910, bind: 0.0.0.0
      + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
        system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
      + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 192.162.2.9
        system.adapter.octoprint.0              : octoprint             : raspberrypi                              - disabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
        system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              - disabled
      + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
        system.adapter.switchbot-ble.0          : switchbot-ble         : raspberrypi                              - disabled
      + system.adapter.switchbot-hub.0          : switchbot-hub         : raspberrypi                              -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
      + system.adapter.text2command.1           : text2command          : raspberrypi                              -  enabled
      + system.adapter.text2command.2           : text2command          : raspberrypi                              -  enabled
      + system.adapter.text2command.3           : text2command          : raspberrypi                              -  enabled
      + system.adapter.time-switch.0            : time-switch           : raspberrypi                              -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.162.2.9, run as: admin
      + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
        system.adapter.worx.0                   : worx                  : raspberrypi                              - disabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: tcp://192.162.2.15:6638
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
      Adapter    "firetv"       : 2.0.2    , installed 2.0.2
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "fuelpricemonitor": 0.4.0 , installed 0.4.0
      Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
      Adapter    "homekit-controller": 0.5.8, installed 0.5.8
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "maxcube"      : 1.0.4    , installed 1.0.4
      Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "telegram"     : 3.0.0    , installed 3.0.0
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
      Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "wled"         : 0.7.1    , installed 0.7.1
      Adapter    "worx"         : 2.3.4    , installed 2.3.4
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
      Objects and States
      Objects:        31159
      States:         26088
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:6 https://linux.teamviewer.com/deb stable InRelease
      Hit:7 https://apt.grafana.com stable InRelease
      Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          12005      570/vncserver-x11-c
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       19543      1292/io.shelly.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       17973      1236/io.sonoff.0
      tcp        0      0 127.0.0.1:5939          0.0.0.0:*               LISTEN      0          12028      611/teamviewerd
      tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       36228      9430/nc
      tcp        0      0 192.162.2.9:1880        0.0.0.0:*               LISTEN      1001       16191      1145/node-red
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15710      547/cupsd
      tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       17271      1496/adb
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17534      703/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15947      703/iobroker.js-con
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11973      584/sshd: /usr/sbin
      tcp        0      0 192.162.2.9:8081        0.0.0.0:*               LISTEN      1001       17613      1022/io.admin.0
      tcp        0      0 192.162.2.9:8082        0.0.0.0:*               LISTEN      1001       21528      1661/io.web.0
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          12004      570/vncserver-x11-c
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15709      547/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          11975      584/sshd: /usr/sbin
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        16412      552/influxd
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       19545      1461/io.simple-api.
      tcp6       0      0 :::3000                 :::*                    LISTEN      116        15929      702/grafana
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23956      1742/io.homekit-con
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       20610      1689/io.wled.0
      udp        0      0 192.162.2.9:5353        0.0.0.0:*                           1001       17256      1243/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11877      401/avahi-daemon: r
      udp        0      0 0.0.0.0:54507           0.0.0.0:*                           1001       18076      1325/io.broadlink2.
      udp        0      0 0.0.0.0:50452           0.0.0.0:*                           1001       18077      1325/io.broadlink2.
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       20810      1258/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       20811      1258/io.tuya.0
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       15286      1325/io.broadlink2.
      udp        0      0 0.0.0.0:60090           0.0.0.0:*                           108        11879      401/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12177      455/dhcpcd
      udp        0      0 0.0.0.0:57662           0.0.0.0:*                           1001       20486      1325/io.broadlink2.
      udp        0      0 0.0.0.0:41518           0.0.0.0:*                           1001       18080      1325/io.broadlink2.
      udp        0      0 0.0.0.0:53814           0.0.0.0:*                           1001       18078      1325/io.broadlink2.
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15729      644/cups-browsed
      udp6       0      0 :::5353                 :::*                                108        11878      401/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          12255      455/dhcpcd
      udp6       0      0 :::45627                :::*                                108        11880      401/avahi-daemon: r
      • Domi920
        habe ich weglassen müssen weil das sehr viele Einträge vom Alexa2 Adapter sind (Einkaufliste aktualisiert, ...)
          Thomas Braun Most Active @Domi920 last edited by
          @domi920
          Jetzt schaut es doch ganz ordentlich aus.
          Domi920 1 Reply Last reply Reply Quote 0
          • Domi920
            @thomas-braun Super das hört man gerne! 🙂 🙂
            Dann lasse ich es mal so und schaue ob es in Zukunft noch Probleme gibt.
            Vielen Dank für Deine großartige Hilfe & Deine Tipps für eine Neuinstallation!
            Gruß Dominik
            • Winni
              Winni @Homoran last edited by
              @homoran sagte in ioBroker hängt Sekunden, keine Daten auf Admin:
              @winni sagte in ioBroker hängt Sekunden, keine Daten auf Admin:
              Warum?
              Naja, bis zum Start des Restore auf dem pi5 hat die Aktion bei mir keine Stunde gedauert.
              Homoran Domi920 2 Replies Last reply Reply Quote 0
                Homoran Global Moderator Administrators @Domi920 last edited by
                @domi920 sagte in ioBroker hängt Sekunden, keine Daten auf Admin:
                nicht unbedingt als leistungsrelevant einstufen oder?
                und wo kommt die load average von >3 her?
                das ist schon erheblich!
                üblich wäre imho zwischen 1 und 2
                  Homoran Global Moderator Administrators @Winni last edited by
                  Warum?
                  da wird das Restore am längsten gedauert haben.
                  Aber
                  • OS brennen
                  • curl... ausführen
                  dauert auch nicht länger
                  • Domi920
                    Domi920 @Winni last edited by
                    @winni Hast du auch Grafana & InfluxDB installiert? Wahrscheinlich muss man das zuvor wieder installieren, oder macht das der Adapter BackItUp auch? Gesichert wäre ja alles.
                    Läuft der Lüfter bei deinem Raspberry 5 dauerhaft?
                    Gibt es auch eine Geschwindigkeitsregulierung?
                    Homoran Winni 2 Replies Last reply Reply Quote 0
                      und das belastet deinen Server nicht?
                      hattest du irgendwo mal ein top gepostet?
                      • Domi920
                        Domi920 @Homoran last edited by
                        @homoran wie kann man herausfinden warum der load average so groß ist?
                        Aktuell siehts wieder besser aus.
                        Möglicherweise liegt es auch an den ganzen Updates die ich gestern gemacht habe.
                        Hier nochmal aktuell top:
                        top
                        top - 14:51:36 up 1 day,  1:49,  2 users,  load average: 0,91, 0,98, 1,08
                        Tasks: 209 total,   2 running, 207 sleeping,   0 stopped,   0 zombie
                        %CPU(s): 10,6 us,  1,8 sy,  0,0 ni, 87,2 id,  0,0 wa,  0,0 hi,  0,3 si,  0,0 st
                        MiB Spch:   7811,3 total,    672,6 free,   4559,8 used,   2579,0 buff/cache
                        MiB Swap:    100,0 total,    100,0 free,      0,0 used.   3128,5 avail Spch
                            PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
                            703 iobroker  20   0 5814412 779680  45280 R  19,2   9,7 467:57.14 iobroker.js-con
                         467160 iobroker  20   0 1498368 683984  44248 S  15,2   8,6 138:19.97 io.javascript.0
                           1104 iobroker  20   0  786060 121976  37476 S   2,6   1,5  61:36.79 io.influxdb.0
                         826455 iobroker  20   0 5157004  95596  41900 S   2,6   1,2   0:42.48 io.ecovacs-deeb
                           1033 iobroker  20   0  758204 103368  37376 S   2,3   1,3  54:41.62 io.history.0
                         493122 iobroker  20   0  724916 133944  43456 S   2,3   1,7   2:19.92 io.tr-064.0
                            702 grafana   20   0 1613188 145416 100544 S   1,3   1,8   3:29.21 grafana
                           1661 iobroker  20   0 1097024 248792  38744 S   1,3   3,1  10:37.49 io.web.0
                           1486 iobroker  20   0  760416 116452  37412 S   1,0   1,5  15:37.88 io.sourceanalyt
                           1274 iobroker  20   0  995312 148092  39080 S   0,7   1,9   9:56.92 io.zigbee.0
                           1292 iobroker  20   0  769312 103660  37468 S   0,7   1,3   7:38.87 io.shelly.0
                         495934 iobroker  20   0  969140 111796  44328 S   0,7   1,4   2:17.75 io.alexa2.0
                         904605 pi        20   0   10380   3628   2876 R   0,7   0,0   0:00.16 top
                             15 root      20   0       0      0      0 I   0,3   0,0   2:18.29 rcu_preempt
                            401 avahi     20   0    7204   3436   2848 S   0,3   0,0   1:20.06 avahi-daemon
                           1145 iobroker  20   0 1069288 213508  40372 S   0,3   2,7   4:23.88 node-red
                           1285 iobroker  20   0  685944  79496  37332 S   0,3   1,0   1:28.47 io.firetv.0
                           1496 iobroker  20   0  238212   5124   4696 S   0,3   0,1   1:09.61 adb
                           1514 iobroker  20   0  768552 114264  43260 S   0,3   1,4   7:59.03 io.statistics.0
                           1523 iobroker  20   0 5143712  83436  40000 S   0,3   1,0   1:33.19 io.switchbot-hu
                           1534 iobroker  20   0 1020232 176308  38656 S   0,3   2,2   3:25.02 io.tankerkoenig
                           1689 iobroker  20   0  696044  94728  37468 S   0,3   1,2   4:13.09 io.wled.0
                           1706 iobroker  20   0  682804  75244  37220 S   0,3   0,9   1:26.95 io.vis-inventwo
                           1742 iobroker  20   0 2796520  97020  38044 S   0,3   1,2   5:30.11 io.homekit-cont
                         484617 iobroker  20   0 5199828 163588  45772 S   0,3   2,0  11:34.87 io.tuya.0
                         901893 root      20   0       0      0      0 I   0,3   0,0   0:01.02 kworker/3:0-events_freezable_power_
                              1 root      20   0  164920  10420   7664 S   0,0   0,1   0:03.12 systemd
                              2 root      20   0       0      0      0 S   0,0   0,0   0:00.15 kthreadd
                              3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
                              4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
                              5 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 slub_flushwq
                              6 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 netns
                              8 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/0:0H-events_highpri
                             10 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu_wq
                             11 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_kthread
                             12 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_rude_kthread
                             13 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_trace_kthread
                             14 root      20   0       0      0      0 S   0,0   0,0   0:20.15 ksoftirqd/0
                             16 root      rt   0       0      0      0 S   0,0   0,0   0:00.20 migration/0
                             17 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/0
                             18 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/1
                             19 root      rt   0       0      0      0 S   0,0   0,0   0:00.20 migration/1
                             20 root      20   0       0      0      0 S   0,0   0,0   0:07.14 ksoftirqd/1
                             22 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/1:0H-kblockd
                             23 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/2
                             24 root      rt   0       0      0      0 S   0,0   0,0   0:00.20 migration/2
                             25 root      20   0       0      0      0 S   0,0   0,0   0:06.87 ksoftirqd/2
                             27 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/2:0H-kblockd
                             28 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/3
                             29 root      rt   0       0      0      0 S   0,0   0,0   0:00.21 migration/3
                             30 root      20   0       0      0      0 S   0,0   0,0   0:07.08 ksoftirqd/3
                             32 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/3:0H-events_highpri
                             33 root      20   0       0      0      0 S   0,0   0,0   0:00.01 kdevtmpfs
                             34 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 inet_frag_wq
                             36 root      20   0       0      0      0 S   0,0   0,0   0:00.00 kauditd
                             38 root      20   0       0      0      0 S   0,0   0,0   0:00.13 khungtaskd
                             40 root      20   0       0      0      0 S   0,0   0,0   0:00.00 oom_reaper
                             41 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 writeback
                             42 root      20   0       0      0      0 S   0,0   0,0   0:06.68 kcompactd0
                             43 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kintegrityd
                             44 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kblockd
                             45 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 blkcg_punt_bio
                             46 root     -51   0       0      0      0 S   0,0   0,0   0:00.00 watchdogd
                             49 root       0 -20       0      0      0 I   0,0   0,0   0:02.14 kworker/3:1H-kblockd
                             50 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rpciod
                             51 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 xprtiod
                             55 root      20   0       0      0      0 S   0,0   0,0   0:00.35 kswapd0
                             56 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 nfsiod
                             57 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kthrotld
                             65 root      20   0       0      0      0 S   0,0   0,0   0:00.05 hwrng
                             66 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 iscsi_conn_clea
                             67 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 nvme-wq
                             68 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 nvme-reset-wq
                             69 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 nvme-delete-wq
                             71 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 DWC Notificatio
                             72 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 uas
                             73 root       1 -19       0      0      0 S   0,0   0,0   0:00.02 vchiq-slot/0
                             74 root       1 -19       0      0      0 S   0,0   0,0   0:00.00 vchiq-recy/0
                             75 root       0 -20       0      0      0 S   0,0   0,0   0:00.00 vchiq-sync/0
                             76 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 zswap-shrink
                             77 root       0 -20       0      0      0 I   0,0   0,0   0:00.04 kworker/u9:0-hci0
                             98 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 sdhci
                             99 root     -51   0       0      0      0 S   0,0   0,0   3:07.08 irq/38-mmc0
                            100 root      20   0       0      0      0 S   0,0   0,0   0:00.00 scsi_eh_0
                            101 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 scsi_tmf_0
                            102 root       0 -20       0      0      0 I   0,0   0,0   0:01.89 kworker/2:1H-kblockd
                          @domi920
                          Der Javascript-Adapter jappst wohl. Vermutlich ein Skript ungünstig gebaut.
                            indem man sich top ansieht.
                            und ja <1 ist besser als >3
                              @thomas-braun sagte in ioBroker hängt Sekunden, keine Daten auf Admin:
                              @domi920
                              naja, im Moment sieht es für mich nicht besorgniserregend aus
                              • Domi920
                                @thomas-braun Wie viel Auslastung wäre für Javascript "normal"?
                                Gibt es eine feinere Möglichkeit das Skript leicht zu finden als jedes einzelne Skript zu deaktivieren?
                                Homoran W Glasfaser 3 Replies Last reply Reply Quote 0
                                  das kommt auf die Auslastung deiner Instanz an.
                                  Wie geschrieben halte ich 15% eines CPU Kerns nicht für schlimm.
                                  Wenn es dann wieder klemmt und dann dort ein wesentlich höherer Wert auftaucht kann man da weitersuchen
                                  • Winni
                                    Winni @Domi920 last edited by
                                    @domi920 Nein, auf meinem 5er läuft nur iobroker und pi-hole. Ausserdem nutze ich ihn noch als Samba-Server mit einer 2tb Samsung ssd. Als "Gehäuse", wenn man es so bezeichnen will, habe ich ein GeeekPi Raspberry Pi 4 Cluster Gehäuse. Ich finde es praktisch, man kommt einfach an alle Anschlüsse hin und optisch gefällt es mir auch. 81lszc2ulPL.AC_SL1500.jpg Da ist pro pi ein kleiner Lüfter, der immer läuft wenn der pi läuft. Im Falle des 5er ist das immer. Der Lüfter ist aber so leise, dass ich wirklich nichts höre, bin aber nicht mehr der Jüngste. Die Temperatur des 5er so liegt meist zwischen 40 bis 45 °C.
                                      Wildbill @Domi920 last edited by
                                      @domi920 50%, also die Hälfte der Scripte deaktivieren und beobachten. Bleibt das Problem, liegt die Ursache in den verbliebenen 50%. Davon dann eben wieder die Hälfte bis das Problem verschwindet. Dann hast Du das Problem auf eine überschaubare Anzahl oder sogar DAS eine Script eingeschränkt.
                                      Beliebt sind Scripte mit Timeout-Funktion und Intervall, wenn die nicht sauber wieder gestoppt werden und immer wieder starten. Auch Trigger in Trigger (was eh falsch ist) kann zu solchen Problemen führen.
                                      Gruss, Jürgen
                                      Domi920 1 Reply Last reply Reply Quote 1
                                        @winni so was hatte ich mir 2015 mit Pi2 gebaut
                                        hab danach das Cluster nicht mehr in Angriff genommen 😁
                                        • Domi920
                                          @homoran Habe schon relativ viele Skripte weil unser Haus zu 80% über den ioBroker läuft ☺
                                          Wenn ich den Adapter neustarte dann kann es schon mal 60 - 80 % Auslastung bei den JavaScript Adapter geben, aber nach einigen fällt dieser auf meist 15 - 25 % ca 🙂
                                          Aber direkt eine Funktion gibt es nicht die die Auslastung einzelner Skripte anzeigt?
                                            klar!
                                            in dem Moment werden alle Scripte neu kompiliert
                                            4747
