    4. Jarvis 3.1.8 - zukünftige Strompreise - Skalierung, Farben
      Mike42 @MCU last edited by Mike42
      @mcu - ich denke die negativen Strompreise machen Probleme bei der Erzeugung des Diagramss (es wird nichts gezeigt).. kannst du mal in das JSON schauen?
      tibberlink.0.Homes.xyz.PricesTomorrow (negative prices).json
        MCU @Mike42 last edited by MCU
        @mike42
        Einstellungen
          @mcu was mache ich falsch?
            @mike42 Meldungen in der console? F12
            Was steht im DP?
              @MCU
              <!DOCTYPE html><html lang="en"><head><meta charset="UTF-8"><meta name="viewport" content="width=device-width, initial-scale=1.0"><title>Tibber-Tageswert</title><script src="https://cdn.jsdelivr.net/npm/echarts@5.4.3/dist/echarts.min.js"></script><script src="https://cdnjs.cloudflare.com/ajax/libs/moment.js/2.29.1/moment.min.js"></script></head><body><div id="chart-container" style="width: 100%; height:400px;"></div><script>    var data = [{"time":1703372400000,"value":0.1587,"tax":0.1587,"energy":0,"level":"CHEAP"},{"time":1703376000000,"value":0.1587,"tax":0.1587,"energy":0,"level":"CHEAP"},{"time":1703379600000,"value":0.1584,"tax":0.1587,"energy":-0.0003,"level":"CHEAP"},{"time":1703383200000,"value":0.1576,"tax":0.1586,"energy":-0.001,"level":"CHEAP"},{"time":1703386800000,"value":0.1543,"tax":0.158,"energy":-0.0037,"level":"CHEAP"},{"time":1703390400000,"value":0.1528,"tax":0.1578,"energy":-0.005,"level":"CHEAP"},{"time":1703394000000,"value":0.1537,"tax":0.1579,"energy":-0.0042,"level":"CHEAP"},{"time":1703397600000,"value":0.1553,"tax":0.1582,"energy":-0.0029,"level":"CHEAP"},{"time":1703401200000,"value":0.1552,"tax":0.1581,"energy":-0.0029,"level":"CHEAP"},{"time":1703404800000,"value":0.155,"tax":0.1581,"energy":-0.0031,"level":"CHEAP"},{"time":1703408400000,"value":0.1526,"tax":0.1578,"energy":-0.0052,"level":"CHEAP"},{"time":1703412000000,"value":0.1545,"tax":0.1581,"energy":-0.0036,"level":"CHEAP"},{"time":1703415600000,"value":0.1552,"tax":0.1582,"energy":-0.003,"level":"CHEAP"},{"time":1703419200000,"value":0.1542,"tax":0.158,"energy":-0.0038,"level":"CHEAP"},{"time":1703422800000,"value":0.1561,"tax":0.1583,"energy":-0.0022,"level":"CHEAP"},{"time":1703426400000,"value":0.156,"tax":0.1583,"energy":-0.0023,"level":"CHEAP"},{"time":1703430000000,"value":0.1563,"tax":0.1583,"energy":-0.002,"level":"CHEAP"},{"time":1703433600000,"value":0.1559,"tax":0.1583,"energy":-0.0024,"level":"CHEAP"},{"time":1703437200000,"value":0.1521,"tax":0.1577,"energy":-0.0056,"level":"CHEAP"},{"time":1703440800000,"value":0.1479,"tax":0.157,"energy":-0.0091,"level":"CHEAP"},{"time":1703444400000,"value":0.151,"tax":0.1575,"energy":-0.0065,"level":"CHEAP"},{"time":1703448000000,"value":0.1549,"tax":0.1581,"energy":-0.0032,"level":"CHEAP"},{"time":1703451600000,"value":0.1552,"tax":0.1582,"energy":-0.003,"level":"CHEAP"},{"time":1703455200000,"value":0.1515,"tax":0.1576,"energy":-0.0061,"level":"CHEAP"}];    var chartContainer = document.getElementById("chart-container");    var myChart = echarts.init(chartContainer);    function formatTime(time) {        return moment(time).format("HH");    }    function calculateArrowPosition(hour){       return (hour / 24) * 100 +1 + "%";    }    function updateChart() {        var minValue = Math.min.apply(null, data.map(function (item) {          return item.value;        }));        var yAxisMin = 0.14;        var maxValue = 0.159;        let avgValue = 0.155;        var visualMapPieces =[
                  "gt": 0,
                  "lte": 0.17,
                  "color": "palegreen"
                  "gt": 0.17,
                  "lte": 0.22,
                  "color": "mediumseagreen"
                  "gt": 0.22,
                  "lte": 0.29,
                  "color": "khaki"
                  "gt": 0.29,
                  "lte": 0.33,
                  "color": "orange"
                  "gt": 0.33,
                  "color": "red"
              ];        var values = data.map(item => (item.value-minValue).toFixed(2));        var maxLineValue = Math.max.apply(null, values);        var maxLineIndex = values.indexOf(maxLineValue);        var maxLineData = {time:1703376000000,value:0.159};        var currentHour = new Date().getHours() ;        var colorStops = [];        visualMapPieces.map(piece => {          if(piece["lte"] >=yAxisMin && piece["gt"]<=maxValue){            if(piece["gt"]>=yAxisMin){            colorStops.push({              offset:  ((piece["gt"]-yAxisMin)/(maxValue-yAxisMin)),              color: piece.color            });            }           if(piece["lte"]<=maxValue){            colorStops.push({              offset:  ((piece["lte"]-yAxisMin)/(maxValue-yAxisMin)),              color: piece.color            });           };          };        });        colorStops.push({            offset: 1,            color: colorStops[colorStops.length-1].color        });        colorStops.splice(0, 0, {offset: 0,color:colorStops[0].color});        myChart.setOption({            title: {                text: "Tomorrow-Tageswerte",                show: false,            },            visualMap: {              type: "piecewise",              pieces: visualMapPieces,              dimension: 1,              showLabel: true,              precision: 2,              itemWidth: 6,              orient: "horizontal",              left: "center", calculable: true,selectedMode: "multiple",              bottom: 10,              text: ["High", "Low"],              textStyle: {                color: "white"              },            },            grid: {              right: 10,              left: 10,              containLabel: true            },            areaStyle: {              color: colorStops            },            toolbox: {              feature: {                saveAsImage: {                   backgroundColor: "rgba(38, 37, 37, 1)",                   title: "Speichern",                   name: "TibberHTML Tomorrow 24.12.2023"                },                magicType: {                  type: ["line", "bar"],                  title:{                     line: "Line-Chart",                     bar: "Bar-Chart",                  }                },                dataView: {                  title: "Daten aus der Serie",                  lang: ["Daten der Kurve", "Schließen", "Aktualisieren"],                  optionToContent: function (opt) {                      var table = '<table style="width:100%;"><tbody><tr style="text-align: left;"><th>Stunde</th><th>Wert</th><th>Energie</th><th>Steuer</th><th>Level</th></tr>';                      for (var i = 0; i< opt.series[0].data.length;i++) {                          table += "<tr>";                         for(let x =0; x < opt.series[0].data[i].value.length; x++){                            if(x==0){                               table +=  "<td>" + ("0"+new Date(opt.series[0].data[i].value[x]).getHours()).slice(-2) + "</td>";                            }else{                               table +=  "<td>" + opt.series[0].data[i].value[x] + "</td>";                            }                          }                           table += "</tr>";                      }                      table += "</tbody></table>";                      return table;                  },                  readOnly: true                },              }            },            xAxis: {                type: "time",                axisLabel: {                    show: true,                    formatter: function (value) {                        return formatTime(value);                    }                },                splitNumber: 10,            },            yAxis: {                type: "value",                axisLabel: {                  formatter: function (value) {                     return value.toFixed(3) + " €";                  }                },               min: 0.14,               max: 0.25,            },            series: [{                data: data.map(function (item) {                    var hour = new Date(item.time).getHours();                    return {                       value: [item.time, item.value, item.energy, item.tax, item.level],                        symbol: "circle",                        emphasis: {                          itemStyle: {                            color: "white"                           },                          label: {                            show: true,                            formatter: function (params) {                               return params.data.value[1].toFixed(3) + " €";                            },                            color: "black",                            fontWeight: "bold",                             backgroundColor: "white"                          }                        }                     }                 }),                type: "bar",            }],            tooltip: {              trigger: "axis",              axisPointer: {               type: "shadow"              },              textStyle: {                fontFamily: "Courier",                fontWeight: "bold"              },              formatter: function (params) {                let time = "Start ab: "+ moment(params[0].axisValue).format("HH:mm")+ " Uhr";                let value = "Preis:&nbsp&nbsp&nbsp&nbsp"+params[0].value[1].toFixed(4) + " €";            let energy = "Energie:&nbsp&nbsp"+params[0].value[2].toFixed(4) + " €";            let tax    = "Steuer:&nbsp&nbsp&nbsp"+params[0].value[3].toFixed(4) + " €";            let lev    = "Level:&nbsp&nbsp&nbsp&nbsp"+ params[0].value[4];            return  `${time}<br/>${value}<br/>${energy}<br/>${tax}<br/>${lev}` ;              }            },        })     }    updateChart();      var updateInterval = setInterval(updateChart, 3600000);</script></body></html>
                @mike42 In CodeTags
                  @mcu
                  Uncaught TypeError: Cannot read properties of undefined (reading 'color')
                  at updateChart (about:srcdoc:26:936)
                  at about:srcdoc:26:5789
                    Mike42 @Mike42 last edited by
                    @MCU keine Ahnung, ob der Fehler in der Konsole damit zu tun hat
                      @mike42 Fehler gefunden, muss ihn nur noch beheben. Weiß noch nicht wie. Dauert ein wenig.
                      Hängt mit dem ersten Farbelement zusammen., wenn lte kleiner als max-Wert (15) definiert ist, läuft es. Bei dir ist jetzt 0.17 eingetragen.
                        @mcu
                        habe jetzt auf 0.15 gewechselt:
                            "gt": 0,
                            "lte": 0.15,
                            "gt": 0.15,
                            "lte": 0.22,
                            "gt": 0.22,
                            "lte": 0.29,
                            "color": "khaki"
                            "gt": 0.29,
                            "lte": 0.33,
                            "color": "orange"
                            "gt": 0.33,
                            "color": "red"
                        funktioniert aber immer noch nicht....
                        Korrektur, Script neu gestartet... geht doch
                          @mike42 v1.0.23, sollte jetzt auch mit 0.17 funktionieren.
                            @mcu 👍
                              @mike42 v1.0.24 -< Umstellung auf Linie Problem behoben
                                Maas-Meister last edited by
                                @MCU
                                Moin MCU, ich hoffe das Thema passt hier rein:
                                Ich habe von deiner Homepage das Script "tibberNext2Cheapest v1.0.1" entdeckt.
                                Leider spuckt dieses zwei Fehler aus sobald ich "Startcalc" drücke und die erstellten DPs werden nicht gefüllt.
                                Kannst du dein Script mal aktualisieren oder mir Fehler aufzeigen?
                                // tibberNext2Cheapest v1.0.1
                                // Copyright ©MCU
                                // v1.0.1 - numHours - Anzahl der zusammenhängenden Stunden eingeführt
                                let tibberdataDP            = '0_userdata.0.Meine_Datenpunkte.Tibber'
                                let cheapestNext2HoursDP    = tibberdataDP + '.cheapestNext2Hours';
                                let cheapestNext2StartTSDP  = tibberdataDP + '.cheapestNext2StartTS';
                                let cheapestNext2StartDP    = tibberdataDP + '.cheapestNext2Start';
                                let cheapestSearchAreaDP    = tibberdataDP + '.cheapestArea';
                                let startDP                 = tibberdataDP + '.startCalc';
                                let numHoursDP              = tibberdataDP + '.numHours';
                                createStateAsync(cheapestNext2HoursDP,     {read: true, write: false, name: "Günstigsten 2 Stunden im gewählten Bereich", desc:"Günstige-Stunden-DP", type: "string", role: "", def: "[]" });
                                createStateAsync(cheapestNext2StartTSDP,   {read: true, write: false, name: "Start [TS] der nächsten günstigen 2 Stunden", desc:"Start-DP", type: "number", role: "", def: 0 });
                                createStateAsync(cheapestNext2StartDP,     {read: true, write: false, name: "Start [Text] der nächsten günstigen 2 Stunden", desc:"Start-DP", type: "string", role: "", def: 0 });
                                createStateAsync(cheapestSearchAreaDP,     {read: true, write: true, name: "Bereich für Suche in [h]", desc:"Bereich-DP", type: "number", role: "",unit:"Std.", def: 10 });
                                createStateAsync(startDP,                  {read: true, write: true, name: "Berechnung starten", desc:"Start-DP", type: "boolean", role: "button", def: false });
                                createStateAsync(numHoursDP,               {read: true, write: true, name: "Anzahl der zusammenhängenden Stunde [h]", desc:"Anzahl Stunden-DP", type: "number", role: "",unit:"Std.", def: 2 });
                                let nowHour = new Date().getHours();
                                let tibberInst = '0';
                                let scheduleId ;
                                if(getState(startDP).val){
                                    scheduleId = schedule('00 * * * *', () => {
                                        getCheapest();
                                on({id: cheapestSearchAreaDP, change: "any"}, function (obj) {
                                    getCheapest();
                                on({id: numHoursDP, change: "any"}, function (obj) {
                                    getCheapest();
                                on({id: startDP, change: "any"}, function (obj) {
                                    let value = obj.state.val;
                                    if(value){
                                        getCheapest();
                                        setState(startDP,false)
                                function getCheapest(){
                                    let priceArr = ['PricesToday','PricesTomorrow'];
                                    let tibberData = [];
                                    let searchHours = getState(cheapestSearchAreaDP).val;
                                    for(let x=0;x< priceArr.length;x++){
                                        let tibberLink = $('tibberlink.'+tibberInst+'.Homes.*.'+priceArr[x]+'.json')
                                        if(tibberLink[0] != undefined){
                                            let tblLevel = levelObject(tibberLink[0]);
                                            let dpLeveltbl = getDPLevel(tblLevel,4);
                                            let tibberJSON = JSON.parse(getState(dpLeveltbl+'.json').val);
                                            // tibberJSON
                                            for(let i=0;i<tibberJSON.length;i++){
                                                let obj = {};
                                                obj.hour     = parseInt(tibberJSON[i].startsAt.substring(11,13));
                                                obj.start   = tibberJSON[i].startsAt
                                                obj.startTS = new Date(obj.start).getTime();
                                                obj.value   = tibberJSON[i].total;
                                                tibberData.push(obj);
                                    // log(tibberData)
                                    let cheapest = findCheapestHoursChange(tibberData.slice(nowHour+1,nowHour+1+searchHours),getState(numHoursDP).val);
                                    // log(cheapest)
                                    setState(cheapestNext2HoursDP,JSON.stringify(cheapest));
                                    setState(cheapestNext2StartTSDP,cheapest[0].startTS);
                                    setState(cheapestNext2StartDP,formatDate(cheapest[0].startTS,'DD.MM.YYYY hh:mm:ss'));
                                function findCheapestHoursChange(data, numHours) {
                                  if (numHours < 1 || numHours > data.length) {
                                    console.error("Invalid number of hours");
                                    return [];
                                  let minPrice = Infinity;
                                  let result = [];
                                  for (let i = 0; i < data.length - numHours + 1; i++) {
                                    let priceSum = 0;
                                    const currentHours = data.slice(i, i + numHours);
                                    for (const hour of currentHours) {
                                      priceSum += hour.value;
                                    if (priceSum < minPrice) {
                                      minPrice = priceSum;
                                      result = currentHours;
                                  return result;
                                function findCheapestHours(data) {
                                  let result = [];
                                  for (let i = 0; i < data.length - 1; i++) {
                                    const priceSum = data[i].value + data[i + 1].value;
                                      result = [data[i], data[i + 1]];
                                  return result;
                                17:32:53.574	info	javascript.0 (8885) Start javascript script.js.common.Energie.Tibber_Guenstigste_Stunden
                                17:32:53.606	info	javascript.0 (8885) script.js.common.Energie.Tibber_Guenstigste_Stunden: registered 3 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                17:33:12.309	info	javascript.0 (8885) Stop script script.js.common.Energie.Tibber_Guenstigste_Stunden
                                17:33:12.411	info	javascript.0 (8885) Start javascript script.js.common.Energie.Tibber_Guenstigste_Stunden
                                17:33:12.428	info	javascript.0 (8885) script.js.common.Energie.Tibber_Guenstigste_Stunden: registered 3 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                17:34:34.678	error	javascript.0 (8885) at getCheapest (script.js.common.Energie.Tibber_Guenstigste_Stunden:56:28)
                                17:34:34.678	error	javascript.0 (8885) at Object.<anonymous> (script.js.common.Energie.Tibber_Guenstigste_Stunden:42:9)
                                Besten Dank 🙂
                                  MCU @Maas-Meister last edited by MCU
                                  @maas-meister Stell mal bitte die aktuellen Tibber-Daten rein. Ich habe kein Tibber.
                                  Was steht bei Dir in zeile 56?
                                  Zeig mal Deine Objekte
                                    Maas-Meister @MCU last edited by Maas-Meister
                                    @mcu
                                    Zeile 56:
                                    Daten sind zu viele um diese zu einzufügen
                                    [{"total":0.1331,"energy":0,"tax":0.1331,"startsAt":"2023-12-26T00:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.1331,"energy":0,"tax":0.1331,"startsAt":"2023-12-26T01:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.133,"energy":-0.0001,"tax":0.1331,"startsAt":"2023-12-26T02:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.13,"energy":-0.0027,"tax":0.1327,"startsAt":"2023-12-26T03:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.1287,"energy":-0.0037,"tax":0.1324,"startsAt":"2023-12-26T04:00:00.000+01:00","currency":"EUR","level":"CHEAP"},{"total":0.1309,"energy":-0.0018,"tax":0.1327,"startsAt":"2023-12-26T05:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.1315,"energy":-0.0013,"tax":0.1328,"startsAt":"2023-12-26T06:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.132,"energy":-0.0009,"tax":0.1329,"startsAt":"2023-12-26T07:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.1319,"energy":-0.001,"tax":0.1329,"startsAt":"2023-12-26T08:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.133,"energy":-0.0001,"tax":0.1331,"startsAt":"2023-12-26T09:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.1331,"energy":-0.0001,"tax":0.1332,"startsAt":"2023-12-26T10:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.1331,"energy":0,"tax":0.1331,"startsAt":"2023-12-26T11:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.1331,"energy":0,"tax":0.1331,"startsAt":"2023-12-26T12:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.1331,"energy":0,"tax":0.1331,"startsAt":"2023-12-26T13:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.1338,"energy":0.0006,"tax":0.1332,"startsAt":"2023-12-26T14:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.1451,"energy":0.01,"tax":0.1351,"startsAt":"2023-12-26T15:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.1895,"energy":0.0473,"tax":0.1422,"startsAt":"2023-12-26T16:00:00.000+01:00","currency":"EUR","level":"EXPENSIVE"},{"total":0.1962,"energy":0.053,"tax":0.1432,"startsAt":"2023-12-26T17:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"},{"total":0.197,"energy":0.0537,"tax":0.1433,"startsAt":"2023-12-26T18:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"},{"total":0.1963,"energy":0.053,"tax":0.1433,"startsAt":"2023-12-26T19:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"},{"total":0.1918,"energy":0.0493,"tax":0.1425,"startsAt":"2023-12-26T20:00:00.000+01:00","currency":"EUR","level":"EXPENSIVE"},{"total":0.1854,"energy":0.044,"tax":0.1414,"startsAt":"2023-12-26T21:00:00.000+01:00","currency":"EUR","level":"EXPENSIVE"},{"total":0.1886,"energy":0.0466,"tax":0.142,"startsAt":"2023-12-26T22:00:00.000+01:00","currency":"EUR","level":"EXPENSIVE"},{"total":0.1965,"energy":0.0533,"tax":0.1432,"startsAt":"2023-12-26T23:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"}]
                                    [{"total":0.1823,"energy":0.0414,"tax":0.1409,"startsAt":"2023-12-27T00:00:00.000+01:00","currency":"EUR","level":"EXPENSIVE"},{"total":0.1951,"energy":0.0521,"tax":0.143,"startsAt":"2023-12-27T01:00:00.000+01:00","currency":"EUR","level":"EXPENSIVE"},{"total":0.2017,"energy":0.0576,"tax":0.1441,"startsAt":"2023-12-27T02:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"},{"total":0.1946,"energy":0.0516,"tax":0.143,"startsAt":"2023-12-27T03:00:00.000+01:00","currency":"EUR","level":"EXPENSIVE"},{"total":0.1924,"energy":0.0498,"tax":0.1426,"startsAt":"2023-12-27T04:00:00.000+01:00","currency":"EUR","level":"EXPENSIVE"},{"total":0.1998,"energy":0.056,"tax":0.1438,"startsAt":"2023-12-27T05:00:00.000+01:00","currency":"EUR","level":"EXPENSIVE"},{"total":0.2106,"energy":0.0651,"tax":0.1455,"startsAt":"2023-12-27T06:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"},{"total":0.2253,"energy":0.0774,"tax":0.1479,"startsAt":"2023-12-27T07:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"},{"total":0.2316,"energy":0.0827,"tax":0.1489,"startsAt":"2023-12-27T08:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"},{"total":0.229,"energy":0.0806,"tax":0.1484,"startsAt":"2023-12-27T09:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"},{"total":0.2226,"energy":0.0752,"tax":0.1474,"startsAt":"2023-12-27T10:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"},{"total":0.222,"energy":0.0747,"tax":0.1473,"startsAt":"2023-12-27T11:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"},{"total":0.2209,"energy":0.0738,"tax":0.1471,"startsAt":"2023-12-27T12:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"},{"total":0.2187,"energy":0.0719,"tax":0.1468,"startsAt":"2023-12-27T13:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"},{"total":0.2208,"energy":0.0736,"tax":0.1472,"startsAt":"2023-12-27T14:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"},{"total":0.2283,"energy":0.08,"tax":0.1483,"startsAt":"2023-12-27T15:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"},{"total":0.2281,"energy":0.0798,"tax":0.1483,"startsAt":"2023-12-27T16:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"},{"total":0.2287,"energy":0.0803,"tax":0.1484,"startsAt":"2023-12-27T17:00:00.000+01:00","currency":"EUR","level":"VERY_EXPENSIVE"},{"total":0.2216,"energy":0.0744,"tax":0.1472,"startsAt":"2023-12-27T18:00:00.000+01:00","currency":"EUR","level":"EXPENSIVE"},{"total":0.2103,"energy":0.0648,"tax":0.1455,"startsAt":"2023-12-27T19:00:00.000+01:00","currency":"EUR","level":"EXPENSIVE"},{"total":0.1983,"energy":0.0547,"tax":0.1436,"startsAt":"2023-12-27T20:00:00.000+01:00","currency":"EUR","level":"EXPENSIVE"},{"total":0.1626,"energy":0.0247,"tax":0.1379,"startsAt":"2023-12-27T21:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.1534,"energy":0.017,"tax":0.1364,"startsAt":"2023-12-27T22:00:00.000+01:00","currency":"EUR","level":"NORMAL"},{"total":0.1331,"energy":0,"tax":0.1331,"startsAt":"2023-12-27T23:00:00.000+01:00","currency":"EUR","level":"CHEAP"}]
                                      @maas-meister Da kommt bei mir kein Fehler.
                                      Welche javascript Version?
                                      Tibberlink ist so aufgebaut?
                                      Instanz 0?
                                        @mcu
                                        Version:
                                        v7.1.6
                                        Kann es sein dass ich das "xyz" mit meiner ID ersetzen muss? Würde ja Sinn ergeben.
                                        Finde aber leider im Script nicht wo das hinterlegt ist
                                          @maas-meister Das sucht er sich automatisch. Du nutzt aber Instanz 0?
                                          Setz mal ein log dazwischen
                                            @mcu
                                            311
                                            44932
