    4. Iobroker Oberfläche langsam. Störmeldungen
      TT-Tom @tourer4778 last edited by
      @tourer4778
      Der Befehl lautet iob diag, war ein Tippfehler. Bitte nochmal probieren und Ausgabe posten.
        tourer4778 @TT-Tom last edited by tourer4778
        @tt-tom
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : armhf
        Systemuptime and Load:
         08:02:46 up  1:37,  3 users,  load average: 1.78, 2.35, 2.34
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sun 2023-12-24 08:02:46 CET
                   Universal time: Sun 2023-12-24 07:02:46 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.8G        2.1G        1.2G         35M        4.5G        5.5G
        Swap:            99M          0B         99M
        Total:          7.9G        2.1G        1.3G
                 7811 M total memory
                 2123 M used memory
                 4157 M active memory
                 2150 M inactive memory
                 1153 M free memory
                  158 M buffer memory
                 4376 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4      459G   19G  422G   5% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  936K  1.6G   1% /run
        /dev/sda1      vfat      253M   51M  202M  20% /boot
        tmpfs          tmpfs     782M   24K  782M   1% /run/user/1000
        [Sun Dec 24 06:25:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:DB:2E:50 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=6b8e45ad-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Sun Dec 24 06:25:32 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Dec 24 06:25:32 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Sun Dec 24 06:25:35 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        2.3G    /var/
        2.0G    /var/log
        1.9G    /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c
        151M    /var/cache
        Archived and active journals take up 1.8G in the file system.
        /opt/iobroker/backups:
        5.0G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        2.2G    /opt/iobroker/iobroker-data/
        1.3G    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
        366M    /opt/iobroker/iobroker-data/history
        34M     /opt/iobroker/iobroker-data/objects.jsonl
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/heizstab/.pioenvs/heizstab/libFrameworkArduino.a
        24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/heizstab-148/.pioenvs/heizstab-148/libFrameworkArduino.a
        24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/heizstab-147/.pioenvs/heizstab-147/libFrameworkArduino.a
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.12.0
        javascript:     7.1.6
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
          system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
        + system.adapter.esphome.0                : esphome               : raspberrypi                              -  enabled
          system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
          system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
        + system.adapter.heizoel.0                : heizoel               : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
          system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
          system.adapter.ical.2                   : ical                  : raspberrypi                              -  enabled
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.javascript.1             : javascript            : raspberrypi                              -  enabled
        + system.adapter.javascript.2             : javascript            : raspberrypi                              -  enabled
        + system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
          system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1884, bind: 0.0.0.0
        + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
        + system.adapter.operating-hours.0        : operating-hours       : raspberrypi                              -  enabled
        + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        + system.adapter.s7.0                     : s7                    : raspberrypi                              -  enabled
        + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.smartthings.0            : smartthings           : raspberrypi                              -  enabled
        + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
        + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
        + system.adapter.tankerkoenig.1           : tankerkoenig          : raspberrypi                              -  enabled
        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.time-switch.0            : time-switch           : raspberrypi                              -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
          system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "admin"        : 6.13.5   , installed 6.12.0 [Updatable]
        Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
        Adapter    "backitup"     : 2.9.8    , installed 2.8.7  [Updatable]
        Adapter    "email"        : 1.2.1    , installed 1.2.0  [Updatable]
        Adapter    "esphome"      : 0.5.0-beta.8, installed 0.2.4 [Updatable]
        Adapter    "fullybrowser" : 3.0.9    , installed 3.0.6  [Updatable]
        Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
        Adapter    "ical"         : 1.13.5   , installed 1.13.3 [Updatable]
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.5.1    , installed 7.1.6  [Updatable]
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "logparser"    : 2.2.1    , installed 2.2.0  [Updatable]
        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
        Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
        Adapter    "operating-hours": 1.0.6  , installed 1.0.6
        Adapter    "s7"           : 1.4.2    , installed 1.3.15 [Updatable]
        Adapter    "shelly"       : 6.7.0    , installed 6.6.1  [Updatable]
        Adapter    "smartthings"  : 0.1.1    , installed 0.0.4  [Updatable]
        Adapter    "snmp"         : 3.1.0    , installed 3.1.0
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.12 [Updatable]
        Adapter    "synology"     : 3.0.1    , installed 3.0.1
        Adapter    "telegram"     : 3.0.1    , installed 3.0.0  [Updatable]
        Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
        Adapter    "trashschedule": 3.1.2    , installed 2.3.0  [Updatable]
        Adapter    "vis-justgage" : 2.1.0    , installed 2.0.2  [Updatable]
        Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
        Adapter    "vw-connect"   : 0.5.1    , installed 0.5.1
        Adapter    "web"          : 6.2.3    , installed 6.1.10 [Updatable]
        Adapter    "welcome"      : 0.3.0    , installed 0.1.0  [Updatable]
        Adapter    "wled"         : 0.7.2    , installed 0.7.1  [Updatable]
        Adapter    "ws"           : 2.5.10   , installed 2.5.8  [Updatable]
        Objects and States
        Objects:        14551
        States:         12801
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 12
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       67953      6980/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       67548      6980/iobroker.js-co
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15814      500/cupsd
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       69486      7339/io.shelly.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       70930      7232/io.sonoff.0
        tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       71801      7577/python3
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12285      560/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15813      500/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          16391      560/sshd: /usr/sbin
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       67976      7011/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       74776      7727/io.web.0
        udp        0      0 0.0.0.0:52670           0.0.0.0:*                           1001       73237      7954/io.snmp.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15073      476/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16516      598/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       71678      7748/io.wled.0
        udp        0      0 192.168.178.142:5353    0.0.0.0:*                           1001       71810      7577/python3
        udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       71809      7577/python3
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       71804      7577/python3
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       71762      7438/io.esphome.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12757      394/avahi-daemon: r
        udp        0      0 0.0.0.0:51252           0.0.0.0:*                           108        12759      394/avahi-daemon: r
        udp6       0      0 :::36109                :::*                                108        12760      394/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          15182      476/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        12758      394/avahi-daemon: r
        2023-12-24 07:55:50.611  - info: javascript.0 (7073) script.js.IoBroker.Aktive_Ausgänge: ['{\'name\':\'Umwelzpumpe Heizkreislauf AnAus\'}','{\'name\':\'Außensteckdose Straße EinAus\'}']
        2023-12-24 07:57:56.322  - info: heizoel.0 (7499) State value to set for "heizoel.0.2000.data01.dealer.rating.averageRatingLastYear" has to be type "string" but received type "number"
        2023-12-24 07:57:56.330  - info: heizoel.0 (7499) State value to set for "heizoel.0.2000.data02.dealer.rating.averageRating" has to be type "number" but received type "string"
        2023-12-24 07:57:56.332  - info: heizoel.0 (7499) State value to set for "heizoel.0.2000.data02.dealer.rating.averageRatingLastYear" has to be type "number" but received type "string"
        2023-12-24 07:57:57.125  - info: heizoel.0 (7499) State value to set for "heizoel.0.3000.data01.dealer.rating.averageRating" has to be type "number" but received type "string"
        2023-12-24 07:57:57.130  - info: heizoel.0 (7499) State value to set for "heizoel.0.3000.data02.pricing.bestPriceDiff" has to be type "number" but received type "string"
        2023-12-24 07:57:57.151  - info: heizoel.0 (7499) State value to set for "heizoel.0.3000.data03.pricing.bestPriceDiff" has to be type "number" but received type "string"
        2023-12-24 08:00:00.059  - info: javascript.0 (7073) script.js.IoBroker.Astro_Zeiten: Astro: Gültige Zeiten: [aktueller Tag: 10] | [nächster Tag: 4] | [Aktualisiert: 0] | Aktuelle Tageszeit: Morgendämmerung | Kommende Tageszeit: Sonnenaufgang
        2023-12-24 08:00:00.243  - info: host.raspberrypi instance system.adapter.ical.2 started with pid 18919
        2023-12-24 08:00:01.106  - info: javascript.0 (7073) script.js.IoBroker.Aktive_Ausgänge: ['{\'name\':\'Umwelzpumpe Heizkreislauf AnAus\'}','{\'name\':\'Außensteckdose Straße EinAus\'}']
        2023-12-24 08:00:01.107  - info: javascript.0 (7073) script.js.IoBroker.Aktive_Meldungen: ['{\'name\':\'ESP Smartshunt Keine Verbindung\'}','{\'name\':\'ESP MPPT Keine Verbindung\'}','{\'name\':\'ESP_Batterie keine Verbindung\'}','{\'name\':\'ET200SP Gartenhaus Störung\'}','{\'name\':\'ESP Display Keine Verbindung\'}','{\'name\':\'ESP Display Keine Verbindung\'}','{\'name\':\'ESP WLED GH keine Verbindung\'}','{\'name\':\'ESP GHWC kein Verbindung\'}','{\'name\':\'Alexa Tobi keine Verbindung\'}','{\'name\':\'Störung3 Heizstab hat keine Leistung\'}']
        2023-12-24 08:00:02.205  - info: javascript.0 (7073) script.js.IoBroker.Aktive_Ausgänge: ['{\'name\':\'Umwelzpumpe Heizkreislauf AnAus\'}','{\'name\':\'Außensteckdose Straße EinAus\'}']
        2023-12-24 08:00:02.206  - info: javascript.0 (7073) script.js.IoBroker.Aktive_Meldungen: ['{\'name\':\'ESP Smartshunt Keine Verbindung\'}','{\'name\':\'ESP MPPT Keine Verbindung\'}','{\'name\':\'ESP_Batterie keine Verbindung\'}','{\'name\':\'ET200SP Gartenhaus Störung\'}','{\'name\':\'ESP Display Keine Verbindung\'}','{\'name\':\'ESP Display Keine Verbindung\'}','{\'name\':\'ESP WLED GH keine Verbindung\'}','{\'name\':\'ESP GHWC kein Verbindung\'}','{\'name\':\'Alexa Tobi keine Verbindung\'}','{\'name\':\'Störung3 Heizstab hat keine Leistung\'}']
        2023-12-24 08:00:04.283  - info: host.raspberrypi instance system.adapter.ical.1 started with pid 18936
        2023-12-24 08:00:06.161  - info: ical.2 (18919) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
        2023-12-24 08:00:06.777  - warn: trashschedule.0 (7792) (5) nextAfter has no entries. Check configuration of ical (increase preview) and trashschedule!
        2023-12-24 08:00:07.460  - info: ical.2 (18919) processing URL: Geburtstage https://calendar.google.com/calendar/ical/ca71d79fa6dfafec51b6cdcad9b68860f246a5d698139d735d1e234c34b4aa9f%40group.calendar.google.com/private-6c3abd24a81c173d80389123ef459bda/basic.ics
        2023-12-24 08:00:09.260  - info: ical.2 (18919) processing URL: Termine https://calendar.google.com/calendar/ical/tobiasbangert78%40gmail.com/private-af20b004c69d83ed1022fdbbd00428fd/basic.ics
        2023-12-24 08:00:11.594  - info: ical.1 (18936) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
        2023-12-24 08:00:12.520  - info: ical.1 (18936) processing URL: Müll Kalender https://calendar.google.com/calendar/ical/19c4e1646ead3d18594fe439767c040fbf2e1f7c910b7c8b7a60247a416747e7%40group.calendar.google.com/private-88175afa823e06bf5e818e919d73f0f9/basic.ics
        2023-12-24 08:00:12.741  - warn: trashschedule.0 (7792) (5) nextAfter has no entries. Check configuration of ical (increase preview) and trashschedule!
        2023-12-24 08:00:16.721  - info: ical.2 (18919) Terminated (NO_ERROR): Without reason
        2023-12-24 08:00:17.263  - info: host.raspberrypi instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
        2023-12-24 08:00:17.657  - info: ical.1 (18936) Terminated (NO_ERROR): Without reason
        2023-12-24 08:00:18.214  - info: host.raspberrypi instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
          crunchip Forum Testing Most Active @tourer4778 last edited by
          @tourer4778 schon auf die Idee gekommen, vllt mal sämtliche Updates auszuführen?
          vor allem als beta User
          @tourer4778 sagte in Iobroker Oberfläche langsam. Störmeldungen:
          X-Server: true
          ausschalten
            tourer4778 @crunchip last edited by tourer4778
            @crunchip
            Die Updates werden nur angezeigt, weil "Latest" ausgewählt ist. Aber ich kann es ja nicht mehr ändern, weil ich nicht in die Einstellungen komme. Latest wegen vw-connect, den ich aktualisieren habe.
            X-Server, wo kann ich das einstellen ?
              @tourer4778 https://forum.iobroker.net/topic/42952/der-kleine-iobroker-linux-werkzeugkasten?_=1703405292873&lang=de
                @crunchip
                Okay, Stabil konnte ich einstellen.
                Wo kann ich das mit dem X-Server einstellen?
                  @tourer4778
                  Steht auch in dem Link von @crunchip
                    @tt-tom
                    Tut mir leid, auf dem link finde ich nichts in verbindung mit X-Server, wo nach muss ich dort suchen ?
                    Homoran crunchip 2 Replies Last reply Reply Quote 0
                      Homoran Global Moderator Administrators @tourer4778 last edited by
                        @tourer4778 ab RunLevel 5 / graphische Oberfläche(nennt sich x-server)
                          @crunchip
                          Aber bei steht er auf 3, was ja laut dem schreiben okay ist.
                            @tourer4778
                            Hast du trotzdem ein full Raspbian mit Desktop installiert, statt der lite Version?
                              tourer4778 @Homoran last edited by
                              Das kann sein, ich weiß es nicht mehr genau.
                              Schluckt das so viel mehr Leistung?
                                Thomas Braun Most Active @tourer4778 last edited by Thomas Braun
                                @tourer4778
                                sudo apt update
                                sudo apt full-upgrade
                                sudo systemctl set-default multi-user target
                                sudo reboot
                                Dann nochmal
                                iob diag
                                  tourer4778 @Thomas Braun last edited by
                                  @thomas-braun sagte in Iobroker Oberfläche langsam. Störmeldungen:
                                  iob diag
                                  Danke, hat funktioniert. Werde jetzt mal beobachten ...
                                  Copy text starting here:
                                                          v.2023-10-10
                                           Icon name: computer
                                        Architecture: arm64
                                  Installation:           native
                                  Kernel:                 aarch64
                                  Userland:               armhf
                                  Timezone:               Europe/Berlin (CET, +0100)
                                  User-ID:                1000
                                  X-Server:               false
                                  Boot Target:            multi-user.target
                                  Pending OS-Updates:     0
                                  Pending iob updates:    4
                                  Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                          /usr/bin/npm            10.2.3
                                                          /usr/bin/npx            10.2.3
                                  Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                  MEMORY:
                                  Mem:            7.8G        1.9G        4.9G        0.0K        970M        5.8G
                                  Swap:            99M          0B         99M
                                  Total:          7.9G        1.9G        5.0G
                                  Active iob-Instances:   37
                                  Active repo(s): stable
                                  ioBroker Core:          js-controller           5.0.17
                                                          admin                   6.12.0
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                14724
                                  States:                 13024
                                  Size of iob-Database:
                                  23M     /opt/iobroker/iobroker-data/objects.jsonl
                                  9.0M    /opt/iobroker/iobroker-data/objects.json.migrated
                                  9.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                  4.6M    /opt/iobroker/iobroker-data/states.jsonl
                                  680K    /opt/iobroker/iobroker-data/states.json.migrated
                                  680K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                  0       /opt/iobroker/iobroker-data/states.json.broken
                                  === Mark text until here for copying ===
                                    Danke, mein System läuft schon wesentlich besser.
                                    admin errorproblem
                                    1925
