    4. ZigBee neue Version 1.8.x
      disaster123 last edited by
      habe gerade 1.9.x installiert und in meinem Log kommt nun öfter die Meldung:
      zigbee.1
      2023-12-22 17:36:45.832	error	Error while processing converters: 'TypeError: Cannot read properties of undefined (reading 'state')'
        picky @disaster123 last edited by
        @disaster123 habe mit update das gleiche Problem, aber nur auf einer Instanz von 2, alle Geräte sind OK eigentlich.
          GIT version installieren.. und demnächst bei Fehler.. LOG post und nicht nur eine Zeile...
          eine rückmeldung währe auch hilfreich obs geht
            picky @arteck last edited by picky
            @arteck Habe auf Git Version updatet, Fehler leider noch da.
            zigbee.0
            32124	2023-12-23 09:15:59.332	error	Error while processing converters: 'TypeError: Cannot read properties of undefined (reading 'state')'
            zigbee.0
            32124	2023-12-23 09:15:56.311	error	Error while processing converters: 'TypeError: Cannot read properties of undefined (reading 'state')'
            zigbee.0
            32124	2023-12-23 09:15:46.370	error	Error while processing converters: 'TypeError: Cannot read properties of undefined (reading 'state')'
            zigbee.0
            32124	2023-12-23 09:15:46.335	error	Error while processing converters: 'TypeError: Cannot read properties of undefined (reading 'state')'
            zigbee.0
            32124	2023-12-23 09:15:41.445	error	Error while processing converters: 'TypeError: Cannot read properties of undefined (reading 'state')'
            zigbee.0
            32124	2023-12-23 09:15:41.424	error	Error while processing converters: 'TypeError: Cannot read properties of undefined (reading 'state')'
            zigbee.0
            32124	2023-12-23 09:15:37.208	info	debug devices set to []
            zigbee.0
            32124	2023-12-23 09:15:36.248	info	Zigbee started
            zigbee.0
            32124	2023-12-23 09:15:36.247	info	0xa4c138c9d09a3ac8 (addr 53662): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
            zigbee.0
            32124	2023-12-23 09:15:36.241	info	0x00124b0023420f4b (addr 48610): SNZB-03 - SONOFF Motion sensor (EndDevice)
            zigbee.0
            32124	2023-12-23 09:15:36.236	info	0x00124b002520124c (addr 20528): SNZB-01 - SONOFF Wireless button (EndDevice)
            zigbee.0
            32124	2023-12-23 09:15:36.233	info	0x00124b0029283a99 (addr 16766): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
            zigbee.0
            32124	2023-12-23 09:15:36.219	info	0xa4c138d017cede30 (addr 8323): A1Z - Nous Smart plug (with power monitoring) (Router)
            zigbee.0
            32124	2023-12-23 09:15:36.213	info	0xa4c138c59ef9857b (addr 3463): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
            zigbee.0
            32124	2023-12-23 09:15:36.205	info	0xa4c1385f532db8e6 (addr 1080): A1Z - Nous Smart plug (with power monitoring) (Router)
            zigbee.0
            32124	2023-12-23 09:15:36.189	info	0x7cb03eaa0a076967 (addr 23114): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
            zigbee.0
            32124	2023-12-23 09:15:36.091	info	Currently 8 devices are joined:
            zigbee.0
            32124	2023-12-23 09:15:36.029	info	--> transmitPower : high+
            zigbee.0
            32124	2023-12-23 09:15:35.907	info	Unable to disable LED, unsupported function.
            zigbee.0
            32124	2023-12-23 09:15:35.885	info	Coordinator firmware version: {"type":"EZSP v8","meta":{"product":8,"majorrel":"6","minorrel":"7","maintrel":"9 ","revision":"6.7.9.0 build 405"}}
            zigbee.0
            32124	2023-12-23 09:15:30.418	info	Installed Version: ioBroker/ioBroker.zigbee#73fa2e7fa921ca791bf9e3cedee7f0d7969556e0
            zigbee.0
            32124	2023-12-23 09:15:29.834	info	Starting Zigbee npm ...
            zigbee.0
            32124	2023-12-23 09:15:29.828	info	delete old Backup files. keep only last 10
            zigbee.0
            32124	2023-12-23 09:15:29.604	info	starting. Version 1.9.0 (non-npm: ioBroker/ioBroker.zigbee#73fa2e7fa921ca791bf9e3cedee7f0d7969556e0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
            Die andere Instanz ohne die Fehlermeldung
            zigbee.1
            32132	2023-12-23 09:15:43.384	error	Device 0x00124b0025209c5d "undefined" not described in statesMapping.
            zigbee.1
            32132	2023-12-23 09:15:43.268	info	debug devices set to []
            zigbee.1
            32132	2023-12-23 09:15:43.111	warn	download icon TasterTerasse for undefined Device not available. Check your devices.
            zigbee.1
            32132	2023-12-23 09:15:43.098	info	Zigbee started
            zigbee.1
            32132	2023-12-23 09:15:43.096	info	0xf0d1b800001e0c45 (addr 61348): 4058075208421 - LEDVANCE SMART+ candle E14 dimmable white (Router)
            zigbee.1
            32132	2023-12-23 09:15:43.075	info	0x001788010b262166 (addr 18125): 929002469202 - Philips Hue white A60 bulb E27 1050lm with Bluetooth (Router)
            zigbee.1
            32132	2023-12-23 09:15:43.070	info	0x00124b0024cd13dc (addr 60793): SNZB-02 - SONOFF Temperature and humidity sensor (EndDevice)
            zigbee.1
            32132	2023-12-23 09:15:43.060	info	0x00124b0025209c5d (addr 38821): Not supported (model undefined)(Unknown)
            zigbee.1
            32132	2023-12-23 09:15:43.008	info	Currently 4 devices are joined:
            zigbee.1
            32132	2023-12-23 09:15:42.548	info	--> transmitPower : high+
            zigbee.1
            32132	2023-12-23 09:15:42.506	info	Unable to disable LED, unsupported function.
            zigbee.1
            32132	2023-12-23 09:15:42.495	info	Coordinator firmware version: {"type":"EZSP v8","meta":{"product":8,"majorrel":"6","minorrel":"7","maintrel":"9 ","revision":"6.7.9.0 build 405"}}
            zigbee.1
            32132	2023-12-23 09:15:36.621	info	Installed Version: ioBroker/ioBroker.zigbee#73fa2e7fa921ca791bf9e3cedee7f0d7969556e0
            zigbee.1
            32132	2023-12-23 09:15:35.926	info	Starting Zigbee npm ...
            zigbee.1
            32132	2023-12-23 09:15:35.922	info	delete old Backup files. keep only last 10
            zigbee.1
            32132	2023-12-23 09:15:35.420	info	starting. Version 1.9.0 (non-npm: ioBroker/ioBroker.zigbee#73fa2e7fa921ca791bf9e3cedee7f0d7969556e0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
            Edit:
            Kommt vielleicht von den 2 Steckdosen, die zwar funktionieren , aber seit dem Update den Load Power nicht mehr verändern, auch der Zeitstempel ist noch von gestern in den Objekten Load Power.
              arteck Developer Most Active @picky last edited by arteck
              @picky check nochmal von GIT..
              an den Nous liegt es nicht.. die hab ich gerade getestet
                @arteck
                leider immer noch, die gleiche Fehlermeldung.
                Muss jetzt leider weg, kann erst heute Abend weiter testen.
                  Hadebe @arteck last edited by
                  @arteck Die gute Nachricht zuerst: mit 1.9.0 funktioniert der Aqara Dual Relay Module T2
                  Auffällig in den bisherigen Installationen war, dass nach dem Koppeln die Werte auf den Zigbee-Adapterkacheln teilweise nicht mit denen im Objektbrowser übereinstimmten. Jetzt ist alles gleich. Darüber hinaus wurden Änderungen vom Gerät nicht verarbeitet, was aber über den Entwicklertab funktionierte.
                  Nach den hier beschriebenen Erkenntnissen mit 1.9.0 habe ich auch mal gleich die git-Version versucht - und der Schalter funktionierte. Dann "zurück" auf die freigegebene 1.9.0. - funktioniert.
                  Fragen zu git Version: Worin besteht der Unterschied zwischen einer freigegebenen Version und einer Non-npm git version? Und wenn ich eine git-Version wieder durch eine freigegebene Version ersetze/update habe ich dann noch irgendwelche Reste auf meinem System?
                  Die schlechte Nachricht: Fehlermeldungen DeviceConfigure, die ich nicht einordnen kann. Sind die nur nervig oder ernst zu nehmen (kommen in beiden 1.9.0 Varianten) und sie treten auch bei jeder DP-Wertänderung auf:
                  Prot_20231223_Zigbee-1-9-0_Aqara-T2.txt
                    Hadebe last edited by Hadebe
                    @arteck Fehlermeldung DeviceConfigure auch bei 1.9.1, alle ca. 2 Minuten meldet der Adapter Error - auch ohne Wertänderung. Diese Meldung kommt allerdings nur bei dem Aqara Wall Switch T2
                    Protokollauszug: Prot_20231223_Zigbee-1-9-1_Aqara-T2.txt
                      ich hab gerade die 1.9.2 publiziert auf GIT
                        @arteck Neue Version gecheckt, Fehlermeldung DeviceConfigure auch bei 1.9.2 GIT wie vorher
                        Habe daraufhin nochmals den Switch im Adapter gelöscht, DP im Browser gecheckt, Adapter neu gestartet und neu gekoppelt. Leider keine Besserung.
                        Das Kopplungsprotokoll über die gesamte Dauer von 60sec habe ich angehängt. Die Fehlemeldung ist immer dieselbe. Diese Error-Meldung tritt dann auch bei jeder Kommunikation mit dem Gerät auf (egal ob Kommunikation vom User initiiert oder nur Statusabfrage/-meldung im Hintergrund), also sehr häufig!
                        KoppProt_20231225_Zigbee-1-9-2.txt
                          arteck Developer Most Active @Hadebe last edited by arteck
                          @hadebe guckmal nochmal mit der GIT version
                          wobei ich sehe auch das es noch probleme gibt
                          https://github.com/Koenkk/zigbee2mqtt/issues/18856
                          manbading created this issue in Koenkk/zigbee2mqtt
                          closed [New device support]: Aqara wireless relay controller T2 #18856
                            Hadebe @arteck last edited by Hadebe
                            @arteck unverändert mit 1.9.2b GIT, 1.9.3 GIT, 1.9.4 GIT, 1.9.5 GIT - ohne und mit neu koppeln
                            Ich habe an dem Gerät eine Steckdose (über DP state_i1 schaltbar) und einen Schalter (über DP state_i2 schaltbar) angeschlossen. Beides funktioniert problemlos. Ich bekomme auch eine korrekte Zustandsmeldung im iobroker, wenn ich den Schalter per Hand bediene.
                            Daher die Anregung/Frage, kann man die Fehlermeldung z.B. blocken oder herabstufen. Auf dem Level Error nerven die Meldungen nur.
                            Bei dem issue auf z2m sehe ich allerdings keine direkte Verbindung zu der Fehlermeldung hier außer dass es dasselbe Gerät betrifft.
                              diwoma last edited by
                              Hi, ich habe eine andere Art vom Problemen mit deer V1.9.3 (ich hoffe, es passt noch hier rein, obwohl es sich um einen V1.8.x Thread handelt)
                              ich habe erst heute von einer V1.8.x auf die V 1.9.3 upgedatet und habe seitdem Exceptions die einen Restart auslösen, bis der Host an einen Restart-Loop glaubt und nicht mehr startet.
                              Logmeldungen nach Start und Command zu einer Schalt-Aktion:
                              121
                              Log-Größe: 348.0 KB
                              Zeit
                              Nachricht
                              zigbee.0
                              	2023-12-27 17:32:56.130	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                              zigbee.0
                              	2023-12-27 17:32:56.130	info	terminating
                              zigbee.0
                              	2023-12-27 17:32:55.695	info	Zigbee: disabling joining new devices.
                              zigbee.0
                              	2023-12-27 17:32:55.629	info	cleaned everything up...
                              zigbee.0
                              	2023-12-27 17:32:55.626	error	Cannot read properties of null (reading 'hasOwnProperty')
                              zigbee.0
                              	2023-12-27 17:32:55.626	error	TypeError: Cannot read properties of null (reading 'hasOwnProperty') at /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:628:62 at Array.filter (<anonymous>) at StatesController.publishToState (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:628:34)
                              zigbee.0
                              	2023-12-27 17:32:55.625	error	unhandled promise rejection: Cannot read properties of null (reading 'hasOwnProperty')
                              zigbee.0
                              	2023-12-27 17:32:55.625	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              zigbee.0
                              	2023-12-27 17:32:06.238	info	debug devices set to []
                              zigbee.0
                              	2023-12-27 17:32:06.107	info	Zigbee started
                              zigbee.0
                              	2023-12-27 17:32:06.106	info	0x00158d0009ef6862 (addr 10788): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.106	info	0xa4c1387d37c5bdcc (addr 58825): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.103	info	0x3425b4fffe2f9af3 (addr 8545): E1746 - IKEA TRADFRI signal repeater (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.103	info	0x00158d000926bb27 (addr 48772): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.103	info	0x00158d0009422623 (addr 26658): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.103	info	0x00158d000775afd2 (addr 43188): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.102	info	0x00124b0024c05546 (addr 53231): ZBMINI-L - SONOFF Zigbee smart switch (no neutral) (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.102	info	0x540f57fffe69b55d (addr 10992): ZTS-EU_1gang - Moes Wall touch light switch (1 gang) (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.102	info	0x00158d00075fbd98 (addr 9668): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.101	info	0x00158d0007d49e0d (addr 40105): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.101	info	0x00158d0007e0a744 (addr 51448): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.101	info	0xb4e3f9fffed0a7d3 (addr 46735): LED1949C5 - IKEA TRADFRI LED bulb E12/E14 450/470 lumen, wireless dimmable white spectrum/chandelier opal white (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.100	info	0x00158d0007014491 (addr 55022): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.100	info	0x847127fffec6ac1c (addr 52994): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.100	info	0x00158d0007e4df68 (addr 54725): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.099	info	0x00158d00075f96be (addr 58534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.099	info	0x00158d0007e0a798 (addr 40613): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.099	info	0xa4c1386c002483ef (addr 30546): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.098	info	0x00158d000839dee4 (addr 53766): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.098	info	0xa4c138a0c9746c97 (addr 42626): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.097	info	0x54ef44100016dbee (addr 61351): QBKG38LM - Xiaomi Aqara E1 1 gang switch (without neutral) (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.097	info	0x84fd27fffe636592 (addr 16108): ZTS-EU_1gang - Moes Wall touch light switch (1 gang) (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.097	info	0x5c0272fffe1a08fc (addr 63031): ZTS-EU_2gang - Moes Wall touch light switch (2 gang) (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.096	info	0x54ef44100016e313 (addr 55265): QBKG38LM - Xiaomi Aqara E1 1 gang switch (without neutral) (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.096	info	0x00158d0007e0e614 (addr 62826): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.095	info	0x00158d0007e086a3 (addr 58696): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.095	info	0x00158d000705e33b (addr 54488): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.095	info	0x00158d000704fe0a (addr 10152): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.095	info	0x00158d000705d7eb (addr 19343): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.094	info	0x00158d0008381814 (addr 43381): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.094	info	0xa4c13879937e5fa8 (addr 63902): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.094	info	0x00158d00070b7d44 (addr 59646): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.093	info	0xa4c138b7cb58d6a5 (addr 20661): TS130F - TuYa Curtain/blind switch (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.093	info	0xa4c138ca8b391c07 (addr 16480): TS130F - TuYa Curtain/blind switch (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.093	info	0xa4c138f9c456ced4 (addr 9563): TS130F - TuYa Curtain/blind switch (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.093	info	0xa4c138776188659a (addr 53240): TS130F - TuYa Curtain/blind switch (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.093	info	0xa4c138b098c7b89a (addr 26209): TS130F - TuYa Curtain/blind switch (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.092	info	0xa4c138dd7383733e (addr 56754): TS130F - TuYa Curtain/blind switch (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.092	info	0x00158d0007c0ccb6 (addr 4414): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
                              zigbee.0
                              	2023-12-27 17:32:06.092	info	0xa4c1380bcc7198fc (addr 57782): TS130F - TuYa Curtain/blind switch (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.091	info	0xa4c1389eba0dfb0c (addr 43813): TS130F - TuYa Curtain/blind switch (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.091	info	0xa4c138d03cfd7c87 (addr 16453): TS130F - TuYa Curtain/blind switch (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.091	info	0xa4c138fa86b402b3 (addr 55323): TS130F - TuYa Curtain/blind switch (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.091	info	0xa4c138cf0f4d6c9d (addr 40245): TS130F - TuYa Curtain/blind switch (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.089	info	0xa4c13876abf5c23c (addr 63498): TS130F - TuYa Curtain/blind switch (Router)
                              zigbee.0
                              	2023-12-27 17:32:06.052	info	Currently 45 devices are joined:
                              zigbee.0
                              	2023-12-27 17:32:05.927	info	--> transmitPower : low
                              zigbee.0
                              	2023-12-27 17:32:05.922	info	Unable to disable LED, unsupported function.
                              zigbee.0
                              	2023-12-27 17:32:05.915	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
                              zigbee.0
                              	2023-12-27 17:32:04.471	info	Installed Version: iobroker.zigbee@1.9.3
                              zigbee.0
                              	2023-12-27 17:32:04.394	info	Starting Zigbee npm ...
                              zigbee.0
                              	2023-12-27 17:32:04.394	info	delete old Backup files. keep only last 10
                              zigbee.0
                              	2023-12-27 17:32:04.355	info	starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.1, js-controller: 5.0.17
                              Das passiert glaube ich beim Lesen einer Antwort oder auch bei Lesen einer Meldung von z.B. einem Temperatur-Sensor.
                              Debug-Summary:
                                                      v.2023-10-10
                                 Static hostname: ioBroker
                                       Icon name: computer-container
                                         Chassis: container
                                  Virtualization: lxc
                                Operating System: Debian GNU/Linux 11 (bullseye)
                                          Kernel: Linux 5.15.131-2-pve
                                    Architecture: x86-64
                              Installation:           lxc
                              Kernel:                 x86_64
                              Userland:               amd64
                              Timezone:               Europe/Vienna (CET, +0100)
                              User-ID:                1001
                              X-Server:               false
                              Boot Target:            graphical.target
                              Pending OS-Updates:     2
                              Pending iob updates:    0
                              Nodejs-Installation:    /usr/bin/nodejs         v18.18.1
                                                      /usr/bin/node           v18.18.1
                                                      /usr/bin/npm            9.8.1
                                                      /usr/bin/npx            9.8.1
                                                      /usr/bin/corepack       0.19.0
                              Recommended versions are nodejs 18.19.0 and npm 10.2.3
                              MEMORY:
                              Mem:            4.1G        2.3G        1.4G        0.0K        468M        1.8G
                              Swap:           512M         14M        497M
                              Total:          4.6G        2.3G        1.9G
                              Active iob-Instances:   22
                              Active repo(s): beta
                              ioBroker Core:          js-controller           5.0.17
                                                      admin                   6.13.11
                              Objects type: jsonl
                              States  type: jsonl
                              + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              Objects:                16423
                              States:                 15469
                              Size of iob-Database:
                              32M     /opt/iobroker/iobroker-data/objects.jsonl
                              9.7M    /opt/iobroker/iobroker-data/objects.json.migrated
                              9.7M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                              15M     /opt/iobroker/iobroker-data/states.jsonl
                              1.7M    /opt/iobroker/iobroker-data/states.json.migrated
                              1.7M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                              Ich wollte danach auf eine frühere angebotene Version 1.8.27 zurückgehen und bekam dabei diese Meldung:
                              $ iobroker upgrade zigbee@1.8.27 --debug
                              Update zigbee from @1.9.3 to @1.8.27
                              Installing iobroker.zigbee@1.8.27... (System call)
                              npm ERR! code ETARGET
                              npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-27T16_40_35_310Z-debug-0.log
                              host.ioBroker Cannot install iobroker.zigbee@1.8.27: 1
                              ERROR: Process exited with code 25
                              Ich habe aber (glaube ich) als letzte laufende Version 1.8.25 gehabt und die hat sich dann installieren lassen.
                              Eventuell ist die V1.8.27 nur eine interne Version gewesen, die nie gepusht wurde.
                              arteck 1 Reply Last reply Reply Quote 2
                                arteck Developer Most Active @diwoma last edited by
                                @diwoma
                                ist es mit der 1.9.4 immer noch so ?
                                  @arteck
                                  Muss ich die vom GIT holen?
                                  • David G.
                                    David G. last edited by
                                    Hatte mit der 1.8.25 auch das Problem. Die git Version hat es behoben.
                                      diwoma @arteck last edited by
                                      @arteck
                                      Hi @arteck
                                      Ich habe jetzt auf die Version 1.9.5 upgedated, aber das gleiche Verhalten, sobald ich einen Schalter betätige. Jetzt habe ich das Log ohne Filter herauskopiert:
                                      2023-12-30 07:25:36.820 - info: host.ioBroker instance system.adapter.zigbee.0 started with pid 15027
                                      2023-12-30 07:25:37.775 - info: host.ioBroker iobroker exit 0
                                      2023-12-30 07:25:38.196 - info: zigbee.0 (15027) starting. Version 1.9.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.18.1, js-controller: 5.0.17
                                      2023-12-30 07:25:38.237 - info: zigbee.0 (15027) delete old Backup files. keep only last 10
                                      2023-12-30 07:25:38.237 - info: zigbee.0 (15027) Starting Zigbee npm ...
                                      2023-12-30 07:25:38.340 - info: zigbee.0 (15027) Installed Version: iobroker.zigbee@1.9.5
                                      2023-12-30 07:25:39.798 - info: zigbee.0 (15027) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20230507}}
                                      2023-12-30 07:25:39.806 - info: zigbee.0 (15027) Unable to disable LED, unsupported function.
                                      2023-12-30 07:25:39.811 - info: zigbee.0 (15027) --> transmitPower : low
                                      2023-12-30 07:25:39.822 - info: zigbee.0 (15027) Currently 45 devices are joined:
                                      2023-12-30 07:25:39.868 - info: zigbee.0 (15027) 0xa4c13876abf5c23c (addr 63498): TS130F - TuYa Curtain/blind switch (Router)
                                      2023-12-30 07:25:39.869 - info: zigbee.0 (15027) 0xa4c138cf0f4d6c9d (addr 40245): TS130F - TuYa Curtain/blind switch (Router)
                                      2023-12-30 07:25:39.869 - info: zigbee.0 (15027) 0xa4c138fa86b402b3 (addr 55323): TS130F - TuYa Curtain/blind switch (Router)
                                      2023-12-30 07:25:39.870 - info: zigbee.0 (15027) 0xa4c138d03cfd7c87 (addr 16453): TS130F - TuYa Curtain/blind switch (Router)
                                      2023-12-30 07:25:39.870 - info: zigbee.0 (15027) 0xa4c1389eba0dfb0c (addr 43813): TS130F - TuYa Curtain/blind switch (Router)
                                      2023-12-30 07:25:39.870 - info: zigbee.0 (15027) 0xa4c1380bcc7198fc (addr 57782): TS130F - TuYa Curtain/blind switch (Router)
                                      2023-12-30 07:25:39.871 - info: zigbee.0 (15027) 0x00158d0007c0ccb6 (addr 4414): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
                                      2023-12-30 07:25:39.871 - info: zigbee.0 (15027) 0xa4c138dd7383733e (addr 56754): TS130F - TuYa Curtain/blind switch (Router)
                                      2023-12-30 07:25:39.871 - info: zigbee.0 (15027) 0xa4c138b098c7b89a (addr 26209): TS130F - TuYa Curtain/blind switch (Router)
                                      2023-12-30 07:25:39.871 - info: zigbee.0 (15027) 0xa4c138776188659a (addr 53240): TS130F - TuYa Curtain/blind switch (Router)
                                      2023-12-30 07:25:39.872 - info: zigbee.0 (15027) 0xa4c138f9c456ced4 (addr 9563): TS130F - TuYa Curtain/blind switch (Router)
                                      2023-12-30 07:25:39.872 - info: zigbee.0 (15027) 0xa4c138ca8b391c07 (addr 16480): TS130F - TuYa Curtain/blind switch (Router)
                                      2023-12-30 07:25:39.872 - info: zigbee.0 (15027) 0xa4c138b7cb58d6a5 (addr 20661): TS130F - TuYa Curtain/blind switch (Router)
                                      2023-12-30 07:25:39.872 - info: zigbee.0 (15027) 0x00158d00070b7d44 (addr 59646): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                      2023-12-30 07:25:39.873 - info: zigbee.0 (15027) 0xa4c13879937e5fa8 (addr 63902): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                                      2023-12-30 07:25:39.873 - info: zigbee.0 (15027) 0x00158d0008381814 (addr 43381): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                      2023-12-30 07:25:39.873 - info: zigbee.0 (15027) 0x00158d000705d7eb (addr 19343): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                      2023-12-30 07:25:39.874 - info: zigbee.0 (15027) 0x00158d000704fe0a (addr 10152): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                      2023-12-30 07:25:39.874 - info: zigbee.0 (15027) 0x00158d000705e33b (addr 54488): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                      2023-12-30 07:25:39.874 - info: zigbee.0 (15027) 0x00158d0007e086a3 (addr 58696): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                      2023-12-30 07:25:39.874 - info: zigbee.0 (15027) 0x00158d0007e0e614 (addr 62826): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                      2023-12-30 07:25:39.875 - info: zigbee.0 (15027) 0x54ef44100016e313 (addr 55265): QBKG38LM - Xiaomi Aqara E1 1 gang switch (without neutral) (EndDevice)
                                      2023-12-30 07:25:39.875 - info: zigbee.0 (15027) 0x5c0272fffe1a08fc (addr 63031): ZTS-EU_2gang - Moes Wall touch light switch (2 gang) (EndDevice)
                                      2023-12-30 07:25:39.876 - info: zigbee.0 (15027) 0x84fd27fffe636592 (addr 16108): ZTS-EU_1gang - Moes Wall touch light switch (1 gang) (EndDevice)
                                      2023-12-30 07:25:39.876 - info: zigbee.0 (15027) 0x54ef44100016dbee (addr 61351): QBKG38LM - Xiaomi Aqara E1 1 gang switch (without neutral) (EndDevice)
                                      2023-12-30 07:25:39.877 - info: zigbee.0 (15027) 0xa4c138a0c9746c97 (addr 42626): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                                      2023-12-30 07:25:39.877 - info: zigbee.0 (15027) 0x00158d000839dee4 (addr 53766): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                      2023-12-30 07:25:39.878 - info: zigbee.0 (15027) 0xa4c1386c002483ef (addr 30546): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                                      2023-12-30 07:25:39.878 - info: zigbee.0 (15027) 0x00158d0007e0a798 (addr 40613): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                      2023-12-30 07:25:39.878 - info: zigbee.0 (15027) 0x00158d00075f96be (addr 58534): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                      2023-12-30 07:25:39.879 - info: zigbee.0 (15027) 0x00158d0007e4df68 (addr 54725): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                      2023-12-30 07:25:39.879 - info: zigbee.0 (15027) 0x847127fffec6ac1c (addr 52994): TS0201 - TuYa Temperature & humidity sensor with display (EndDevice)
                                      2023-12-30 07:25:39.879 - info: zigbee.0 (15027) 0x00158d0007014491 (addr 55022): WXKG11LM - Xiaomi Aqara wireless switch (EndDevice)
                                      2023-12-30 07:25:39.880 - info: zigbee.0 (15027) 0xb4e3f9fffed0a7d3 (addr 46735): LED1949C5 - IKEA TRADFRI LED bulb E12/E14 450/470 lumen, wireless dimmable white spectrum/chandelier opal white (Router)
                                      2023-12-30 07:25:39.880 - info: zigbee.0 (15027) 0x00158d0007e0a744 (addr 51448): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                      2023-12-30 07:25:39.880 - info: zigbee.0 (15027) 0x00158d0007d49e0d (addr 40105): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                      2023-12-30 07:25:39.881 - info: zigbee.0 (15027) 0x00158d00075fbd98 (addr 9668): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                      2023-12-30 07:25:39.881 - info: zigbee.0 (15027) 0x540f57fffe69b55d (addr 10992): ZTS-EU_1gang - Moes Wall touch light switch (1 gang) (EndDevice)
                                      2023-12-30 07:25:39.881 - info: zigbee.0 (15027) 0x00124b0024c05546 (addr 53231): ZBMINI-L - SONOFF Zigbee smart switch (no neutral) (EndDevice)
                                      2023-12-30 07:25:39.882 - info: zigbee.0 (15027) 0x00158d000775afd2 (addr 43188): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                      2023-12-30 07:25:39.882 - info: zigbee.0 (15027) 0x00158d0009422623 (addr 26658): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                      2023-12-30 07:25:39.882 - info: zigbee.0 (15027) 0x00158d000926bb27 (addr 48772): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                      2023-12-30 07:25:39.883 - info: zigbee.0 (15027) 0x3425b4fffe2f9af3 (addr 8545): E1746 - IKEA TRADFRI signal repeater (Router)
                                      2023-12-30 07:25:39.883 - info: zigbee.0 (15027) 0xa4c1387d37c5bdcc (addr 58825): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
                                      2023-12-30 07:25:39.883 - info: zigbee.0 (15027) 0x00158d0009ef6862 (addr 10788): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                      2023-12-30 07:25:39.884 - info: zigbee.0 (15027) Zigbee started
                                      2023-12-30 07:25:39.885 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
                                      2023-12-30 07:25:39.890 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
                                      2023-12-30 07:25:39.892 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
                                      2023-12-30 07:25:39.894 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
                                      2023-12-30 07:25:39.895 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
                                      2023-12-30 07:25:39.896 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
                                      2023-12-30 07:25:39.898 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
                                      2023-12-30 07:25:39.899 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
                                      2023-12-30 07:25:39.900 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
                                      2023-12-30 07:25:39.901 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
                                      2023-12-30 07:25:39.902 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
                                      2023-12-30 07:25:39.903 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS130F.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS130F.png
                                      2023-12-30 07:25:39.905 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_3.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_3.png
                                      2023-12-30 07:25:39.909 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/QBKG38LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/QBKG38LM.png
                                      2023-12-30 07:25:39.910 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/ZTS-EU_2gang.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZTS-EU_2gang.png
                                      2023-12-30 07:25:39.911 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/ZTS-EU_1gang.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZTS-EU_1gang.png
                                      2023-12-30 07:25:39.912 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/QBKG38LM.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/QBKG38LM.png
                                      2023-12-30 07:25:39.913 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                                      2023-12-30 07:25:39.914 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                                      2023-12-30 07:25:39.917 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/LED1949C5.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LED1949C5.png
                                      2023-12-30 07:25:39.920 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/ZTS-EU_1gang.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZTS-EU_1gang.png
                                      2023-12-30 07:25:39.921 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/ZBMINI-L.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ZBMINI-L.png
                                      2023-12-30 07:25:39.925 - warn: zigbee.0 (15027) download icon from https://www.zigbee2mqtt.io/images/devices/TS011F_plug_1.jpg saved into /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TS011F_plug_1.png
                                      2023-12-30 07:25:40.169 - info: zigbee.0 (15027) debug devices set to []
                                      2023-12-30 07:25:40.379 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-005-1G angemeldet
                                      2023-12-30 07:25:40.381 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-002-2G angemeldet
                                      2023-12-30 07:25:40.381 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-001-1G angemeldet
                                      2023-12-30 07:25:40.382 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-003-1G angemeldet
                                      2023-12-30 07:25:40.391 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-004-1G angemeldet
                                      2023-12-30 07:25:40.398 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-006-1G angemeldet
                                      2023-12-30 07:25:40.726 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-006 angemeldet
                                      2023-12-30 07:25:40.758 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-005 angemeldet
                                      2023-12-30 07:25:40.826 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-002 angemeldet
                                      2023-12-30 07:25:40.940 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-001 angemeldet
                                      2023-12-30 07:25:40.941 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-003 angemeldet
                                      2023-12-30 07:25:40.942 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-007 angemeldet
                                      2023-12-30 07:25:40.944 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-004 angemeldet
                                      2023-12-30 07:25:40.945 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-044 angemeldet
                                      2023-12-30 07:25:40.947 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-041 angemeldet
                                      2023-12-30 07:25:40.948 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-040 angemeldet
                                      2023-12-30 07:25:40.949 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-043 angemeldet
                                      2023-12-30 07:25:40.984 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-042 angemeldet
                                      2023-12-30 07:25:40.986 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee PLUG-005 angemeldet
                                      2023-12-30 07:25:40.997 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee PLUG-007 angemeldet
                                      2023-12-30 07:25:40.998 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee PLUG-008 angemeldet
                                      2023-12-30 07:25:41.005 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee TRADFRI-001 angemeldet
                                      2023-12-30 07:25:41.014 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee REP-001 angemeldet
                                      2023-12-30 07:26:56.248 - info: javascript.0 (462) script.js.Steuerung.Licht.AutoSwitchOff: Vorratsraum Licht (SW-004-1G): Schalter State true
                                      2023-12-30 07:26:56.250 - info: javascript.0 (462) script.js.Steuerung.Licht.AutoSwitchOff: Vorratsraum Licht (SW-004-1G): Check Autowitch (0_userdata.0.Light.AutoSwitchOff.Vorratsraum) = true
                                      2023-12-30 07:26:56.250 - info: javascript.0 (462) script.js.Steuerung.Licht.AutoSwitchOff: Vorratsraum Licht (SW-004-1G): Set Timeout to 5 min
                                      2023-12-30 07:26:56.250 - info: javascript.0 (462) script.js.Steuerung.Licht.AutoSwitchOff: Vorratsraum Licht (SW-004-1G): Set BlockMovement to false
                                      2023-12-30 07:26:56.250 - info: javascript.0 (462) script.js.Steuerung.Licht.AutoSwitchOff: Vorratsraum Licht (SW-004-1G): Licht durch Schalter eingeschaltet
                                      2023-12-30 07:26:56.250 - info: javascript.0 (462) script.js.Steuerung.Allgemein.LogForDevices: $Vorratsraum Licht (SW-004-1G) eingeschaltet
                                      2023-12-30 07:26:56.464 - error: zigbee.0 (15027) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2023-12-30 07:26:56.464 - error: zigbee.0 (15027) unhandled promise rejection: Cannot read properties of null (reading 'hasOwnProperty')
                                      2023-12-30 07:26:56.464 - error: zigbee.0 (15027) TypeError: Cannot read properties of null (reading 'hasOwnProperty')
                                      at Array.filter ()
                                      2023-12-30 07:26:56.464 - error: zigbee.0 (15027) Cannot read properties of null (reading 'hasOwnProperty')
                                      2023-12-30 07:26:56.468 - info: zigbee.0 (15027) cleaned everything up...
                                      2023-12-30 07:26:56.525 - info: zigbee.0 (15027) Zigbee: disabling joining new devices.
                                      2023-12-30 07:26:56.573 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-006 abgemeldet
                                      2023-12-30 07:26:56.574 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-005 abgemeldet
                                      2023-12-30 07:26:56.575 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-002 abgemeldet
                                      2023-12-30 07:26:56.575 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-001 abgemeldet
                                      2023-12-30 07:26:56.576 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-003 abgemeldet
                                      2023-12-30 07:26:56.577 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-007 abgemeldet
                                      2023-12-30 07:26:56.578 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-004 abgemeldet
                                      2023-12-30 07:26:56.579 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-044 abgemeldet
                                      2023-12-30 07:26:56.581 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-041 abgemeldet
                                      2023-12-30 07:26:56.583 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-040 abgemeldet
                                      2023-12-30 07:26:56.585 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-043 abgemeldet
                                      2023-12-30 07:26:56.587 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee ROLL-042 abgemeldet
                                      2023-12-30 07:26:56.588 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee PLUG-005 abgemeldet
                                      2023-12-30 07:26:56.612 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-005-1G abgemeldet
                                      2023-12-30 07:26:56.614 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-002-2G abgemeldet
                                      2023-12-30 07:26:56.615 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-001-1G abgemeldet
                                      2023-12-30 07:26:56.616 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-003-1G abgemeldet
                                      2023-12-30 07:26:56.619 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee PLUG-007 abgemeldet
                                      2023-12-30 07:26:56.629 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee PLUG-008 abgemeldet
                                      2023-12-30 07:26:56.634 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee TRADFRI-001 abgemeldet
                                      2023-12-30 07:26:56.640 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-004-1G abgemeldet
                                      2023-12-30 07:26:56.641 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee SW-006-1G abgemeldet
                                      2023-12-30 07:26:56.644 - info: javascript.0 (462) script.js.Steuerung.Allgemein.ZigbeeRouterControl: $Zigbee REP-001 abgemeldet
                                      2023-12-30 07:26:56.968 - info: zigbee.0 (15027) terminating
                                      2023-12-30 07:26:56.969 - warn: zigbee.0 (15027) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      2023-12-30 07:26:57.517 - error: host.ioBroker Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2023-12-30 07:26:57.517 - error: host.ioBroker Caught by controller[2]: TypeError: Cannot read properties of null (reading 'hasOwnProperty')
                                      2023-12-30 07:26:57.517 - error: host.ioBroker Caught by controller[2]: at /opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:628:62
                                      2023-12-30 07:26:57.517 - error: host.ioBroker Caught by controller[2]: at Array.filter ()
                                      2023-12-30 07:26:57.517 - error: host.ioBroker Caught by controller[2]: at StatesController.publishToState (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:628:34)
                                      2023-12-30 07:26:57.517 - error: host.ioBroker instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                      2023-12-30 07:26:57.517 - info: host.ioBroker Restart adapter system.adapter.zigbee.0 because enabled
                                      Vielleicht sagt das mehr aus.
                                      Ich schalte wieder auf 1.8.25 zurück, die bei mir funktioniert.
                                      D arteck 2 Replies Last reply Reply Quote 0
                                        diwoma @diwoma last edited by
                                        @diwoma
                                        Memo an mich, vor dem nächsten Update einen Snapshot ziehen!
                                        In der Auswahlliste für die Installation einer früheren Version werden nur 6 Schritte angezeigt. Das ging somit bei mir nur bis V 1.8.27. Wie ich über GIT eine ältere Version auswählen könnte, habe ich nicht herausgefunden.
                                        Also habe ich das nächtliche Backup wieder eingespielt.
                                          arteck Developer Most Active @diwoma last edited by arteck
                                          @diwoma ja und jetzt kann ich schauen woran es liegt...
                                          installier mal von GIT..sollte jetzt gehen
                                          welche Gerät ist das.SW-004-1G. zeigmal die Info Kachel
                                          D 3 Replies Last reply Reply Quote 0
                                            @arteck
                                            Info-Kachel:
                                            1.2k
                                            385
                                            85489
