    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      ThomKast last edited by ThomKast
      @tombox
      Hi. Habe auf die 0.4.2 aus Git aktualisiert. Das Protokoll zeigt einen erfolgreichen login und dann "get vehicles failed". Hast Du einen Tip?
      vw-connect.0
      2023-12-22 18:56:21.891	error	Get Vehicles Failed
      vw-connect.0
      2023-12-22 18:56:21.889	error	410
      vw-connect.0
      2023-12-22 18:56:21.888	error	"fault filter abort"
      vw-connect.0
      2023-12-22 18:56:21.761	info	Login successful
      vw-connect.0
      2023-12-22 18:56:19.820	info	Login in with skodae
      vw-connect.0
      2023-12-22 18:56:19.770	info	starting. Version 0.4.2 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.17.1, js-controller: 4.0.24
      Habe den Adapter mal deinstalliert und neu installiert und auf das LOG auf "debug" gestellt. Nun ist noch ein "error: invalid protocol" aufgetaucht.
      vw-connect.0
      2023-12-22 19:18:14.268	error	Get Vehicles Failed
      vw-connect.0
      2023-12-22 19:18:14.267	error	410
      vw-connect.0
      2023-12-22 19:18:14.266	error	"fault filter abort"
      vw-connect.0
      2023-12-22 19:18:14.180	info	Login successful
      vw-connect.0
      2023-12-22 19:18:13.955	debug	Error: Invalid protocol: skodaconnect:
      vw-connect.0
      2023-12-22 19:18:13.530	debug	{"date":"Fri, 22 Dec 2023 18:18:13 GMT","content-length":"0","connection":"close","apigw-requestid":"QW3j4icrFiAEPjg=","x-content-type-options":"nosniff","x-xss-protection":"0","cache-control":"no-cache, no-store, max-age=0, must-revalidate","pragma":"no-cache","expires":"0","strict-transport-security":"max-age=31536000; includeSubDomains; preload","x-frame-options":"DENY","location":"https://identity.vwgroup.io/oidc/v1/oauth/sso?clientId=f9a2359a-b776-46d9-bd0c-db1904343117@apps_vw-dilab_com&relayState=a3644b9a13fdf0d3c815faf2283f6ec978a41228&userId=1f0757be-fbb0-435c-8dd6-337881edec1b&HMAC=211981248c7046df2a9e78052d1f9bfc2b0bed8d443b2b6a4215b9fbe4ee26c3","content-language":"en-US"}
      vw-connect.0
      2023-12-22 19:18:13.529	debug	""
      vw-connect.0
      2023-12-22 19:18:13.269	debug	emailPasswordForm2
      vw-connect.0
      2023-12-22 19:18:12.987	debug	parseEmailForm
      vw-connect.0
      2023-12-22 19:18:12.441	info	Login in with skodae
      vw-connect.0
      2023-12-22 19:18:12.387	info	starting. Version 0.4.2 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.17.1, js-controller: 4.0.24
      Zusätzlich ist auch noch der Baum mit den Datenpunkten rudiminetär... Da stimmt jetzt nix mehr.
      Hilfe 🤕 😀
        tombox @ThomKast last edited by
        @thomkast Skoda hat ioBroker blockiert. Es ist mit 0.5.0 behoben aber parking position ist deaktiviert und minimum interval sind 10min
        T I 2 Replies Last reply Reply Quote 0
          ThomKast @tombox last edited by
          @tombox
          Echt jetzt? Geht ja gar nicht...
          Die 0.5.0 funzt wieder. Super vielen Dank für Deine Mühe 👍.
          Wünsche Dir eine frohe Weihnacht.
          • I
            ichderarnd @tombox last edited by
            @tombox sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
            Woran machst Du fest, dass Skoda hier absichtlich den ioBroker ausgesperrt hat?
              leonundjulie @ichderarnd last edited by
              Guten Morgen. Da ich mich in den nächsten Tag wieder dem VV wieder näher will, habe ich zunächst auf die GitHub Version 0.51 upgedated.
              Was sagt mir folgendes Fehlermeldung im Protokoll?
                Sneak-L8 @leonundjulie last edited by
                @leonundjulie Dein Auto bzw. die App liefert Dir keine Trip-Daten. Um die Fehlermeldung loszuwerden sollst Du den Abruf jener in den Einstellungen des Adapters ausschalten.
                  Mutanten last edited by
                  Hallo
                  ich kann nur auf Version 0.0.67 updaten.
                  Wenn ich es über Github versuche kommen folgende Meldungen:
                  $ iobroker url npm i iobroker.vw-connect --host raspberrypi-dashboard --debug
                  install npm
                  NPM version: 10.2.3Installing npm... (System call)
                  up to date in 13s159 packages are looking for funding run npm fund for details
                  host.raspberrypi-dashboard Cannot install npm: 0
                  ERROR: Process exited with code 25
                  Was mache ich falsch?
                  Node.js: v18.19.0
                  NPM: 10.2.3
                  Gruß, Michael
                    TT-Tom last edited by
                    @mutanten
                    versuche mal folgende Befehle in de Konsole.
                    iob stop
                    iob fix
                    iob start
                      leonundjulie @Sneak-L8 last edited by
                      @sneak-l8 danke … aber welchemFunktion muss in den Einstellungen deaktiviert werden (ich habe schon verschiedene ohne Erfolg gewählt😧 ).
                        Vor allem bei den letzten drei Punkten die Haken entfernen.
                          tombox @Mutanten last edited by
                          @mutanten Für die aktuelle Version auf latest repo umstellen
                            @sneak-l8 danke, so klappt es. Heist also, dass der VW ID.3 das nicht unterstützt? Oder ginge es, wenn ich im Auto in den Einstellungen etwas ändere (meine mal was diesbezügliches gelesen zu haben, finde es aber nicht wieder)?
                              @leonundjulie Es wird funktionieren, wenn VW das unterstützt. Wenn Du in der VW App diese Daten entdecken solltest, dann kannst Du es noch mal probieren und Dich melden, wenn es dann nicht geht.
                              Aber was VW nicht anbietet, kann der Adapter auch nicht zaubern...
                              • Nightly
                                Nightly last edited by
                                Hallo, seit kurzem kriege ich beim Start des Adapters folgenden Fehler: Error in consent form. Please accept the Data Privacy Statement in the app after relogin
                                Habe mich auf der Handy-App ab-/angemeldet und gechecked, ob da irgendwo ein Consent verlangt wird. Ebenso über den Browser. Habe nirgends eine fehlende Einverständniserklärung gefunden. Weiss gerade nicht mehr weiter.
                                Vielen Dank.
                                • BananaJoe
                                  BananaJoe Most Active @Nightly last edited by
                                  @nightly welches Fahrzeug / welche Login-Seite hast du gewählt? Welche App? Was hast du für die Anmeldung im Adapter gewählt?
                                  Ich bin von Skoda auf VW gewechselt, meine Anmeldedaten blieben aber gleich. Jede Marke hat(te) aber seine eigene Login-Seite und damita musste ich auch separat die Datenschutz- und sonstigen Dinge akzeptieren.
                                  Nightly 1 Reply Last reply Reply Quote 0
                                    lesiflo Most Active last edited by lesiflo
                                    gelöscht
                                      Michi 0 last edited by
                                      Hi Zusammen,
                                      hab seit ein paar Tagen einen Skoda Enyaq und hab mir dann natürlich sofort diesen Adapter installiert und alle Login-Daten eingegeben.
                                      Leider bekomme ich folgende Fehlermeldung:
                                      No Token received. Please try to logout and login in the VW app or select type VWv2 in the settings
                                      Hab mich sowohl mit der Handy-App als auch am PC ein- und ausgeloggt. Keine Änderung...
                                      Hat jemand ne Ahnung wo ich noch was umstellen/einstellen muss?
                                        Michi 0 @Michi 0 last edited by
                                        Hat sich erledigt... Nachdem ich alle Login-Typen durchgespielt und mir die Fehlermeldungen im Log angesehen habe, habe ich eine dort angegebene https Adresse eingegeben und bin endlich bei der fehlenden Freigabeseite gelandet. Danach wieder auf den Enyaq - Login umgestellt und jetzt läufts!
                                          Mutanten @TT-Tom last edited by
                                          @tt-tom hat nichts gebracht
                                            Mutanten @tombox last edited by
                                            @tombox das wars, danke
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            399
                                            3091
                                            1605929
