    4. Modbus adapter
    Modbus adapter
      Schtallone @Schtallone last edited by
      @schtallone said in Modbus adapter:
      @homoran said in Modbus adapter:
      @schtallone sagte in Modbus adapter:
      sondern eine Art Stub-Connection.
      das macht Ärger!
      ändern und dann hier berichten.
      bin gespannt
      Moin, so habe nun die Zähler schon hintereinander geschaltet im Modbus.
      ICh würde sagen, es sind weniger Fehler, aber es läuft nicht fehlerfrei... Es wird immer noch ständig connected/disconnected!
      2023-09-29 10:05:34.427  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:06:34.429  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:08:04.029  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:09:04.029  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:09:44.937  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:10:00.042  - info: host.iobroker instance system.adapter.dwd.0 started with pid 4236
      2023-09-29 10:10:03.339  - info: dwd.0 (4236) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 10:10:03.976  - info: dwd.0 (4236) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 10:10:04.501  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 10:10:44.939  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:13:44.042  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:14:44.045  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:15:00.050  - info: host.iobroker instance system.adapter.dwd.0 started with pid 4492
      2023-09-29 10:15:02.230  - info: dwd.0 (4492) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 10:15:03.194  - info: dwd.0 (4492) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 10:15:03.720  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 10:15:34.161  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:16:34.163  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:16:54.046  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:17:54.048  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:18:44.940  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:19:44.943  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:19:58.881  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Netz.WhExported, feature disabled (or below threshold) processing normally)
      2023-09-29 10:20:00.045  - info: host.iobroker instance system.adapter.dwd.0 started with pid 4734
      2023-09-29 10:20:03.547  - info: dwd.0 (4734) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 10:20:04.111  - info: dwd.0 (4734) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 10:20:04.662  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 10:20:54.955  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:21:54.956  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:22:44.955  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:23:44.957  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:24:54.957  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:25:00.044  - info: host.iobroker instance system.adapter.dwd.0 started with pid 4987
      2023-09-29 10:25:02.260  - info: dwd.0 (4987) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 10:25:03.063  - info: dwd.0 (4987) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 10:25:03.583  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 10:25:11.776  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Netz.WhImported, feature disabled (or below threshold) processing normally)
      2023-09-29 10:25:54.959  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:26:14.699  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:27:14.703  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:28:48.567  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:29:48.569  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:30:00.333  - info: host.iobroker instance system.adapter.dwd.0 started with pid 5243
      2023-09-29 10:30:03.779  - info: dwd.0 (5243) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 10:30:04.268  - info: dwd.0 (5243) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 10:30:04.787  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 10:30:38.575  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:31:38.577  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:32:48.577  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:33:48.579  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:35:00.051  - info: host.iobroker instance system.adapter.dwd.0 started with pid 5486
      2023-09-29 10:35:01.831  - info: dwd.0 (5486) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 10:35:02.703  - info: dwd.0 (5486) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 10:35:03.223  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 10:35:58.588  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:36:58.589  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:39:28.591  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:40:00.044  - info: host.iobroker instance system.adapter.dwd.0 started with pid 5743
      2023-09-29 10:40:03.951  - info: dwd.0 (5743) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 10:40:04.594  - info: dwd.0 (5743) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 10:40:05.114  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 10:40:28.593  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:41:48.597  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:42:48.599  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:44:38.611  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:45:00.068  - info: host.iobroker instance system.adapter.dwd.0 started with pid 6001
      2023-09-29 10:45:01.969  - info: dwd.0 (6001) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 10:45:02.651  - info: dwd.0 (6001) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 10:45:03.175  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 10:45:38.613  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:49:48.620  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:50:00.103  - info: host.iobroker instance system.adapter.dwd.0 started with pid 6246
      2023-09-29 10:50:04.870  - info: dwd.0 (6246) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 10:50:05.987  - info: dwd.0 (6246) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 10:50:06.546  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 10:50:48.622  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:51:18.620  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:52:18.622  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:53:55.611  - info: shelly.0 (381) [MQTT] Device with client id "shellyplus1pm-3c610579bd34" connected!
      2023-09-29 10:53:55.673  - info: shelly.0 (381) [MQTT] Device with client id "shellyplus1pm-a8032abc230c" connected!
      2023-09-29 10:53:55.683  - info: shelly.0 (381) [MQTT] Device with client id "shellyplus1pm-a8032ab94e10" connected!
      2023-09-29 10:53:55.703  - info: shelly.0 (381) [MQTT] Device with client id "shellyplus1-441793a820f4" connected!
      2023-09-29 10:53:55.753  - info: shelly.0 (381) [MQTT] Device with client id "shellyplus1pm-3c610579df44" connected!
      2023-09-29 10:53:55.852  - info: shelly.0 (381) [MQTT] Device with client id "shellyplus1pm-4855199a5d7c" connected!
      2023-09-29 10:53:55.867  - info: shelly.0 (381) [MQTT] Device with client id "shellyplus1pm-a8032ab96980" connected!
      2023-09-29 10:53:56.015  - info: shelly.0 (381) [MQTT] Device with client id "shellyplus1pm-7c87ce65d794" connected!
      2023-09-29 10:54:08.630  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:55:00.040  - info: host.iobroker instance system.adapter.dwd.0 started with pid 6503
      2023-09-29 10:55:01.967  - info: dwd.0 (6503) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 10:55:02.733  - info: dwd.0 (6503) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 10:55:03.266  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 10:55:08.631  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 10:58:18.645  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 10:59:18.645  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:00:00.044  - info: host.iobroker instance system.adapter.dwd.0 started with pid 6759
      2023-09-29 11:00:05.144  - info: dwd.0 (6759) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 11:00:06.888  - info: dwd.0 (6759) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 11:00:07.446  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 11:02:08.648  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:03:08.650  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:04:54.336  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:05:00.046  - info: host.iobroker instance system.adapter.dwd.0 started with pid 7006
      2023-09-29 11:05:01.856  - info: dwd.0 (7006) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 11:05:02.769  - info: dwd.0 (7006) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 11:05:03.291  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 11:05:54.338  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:09:18.653  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:10:00.056  - info: host.iobroker instance system.adapter.dwd.0 started with pid 7270
      2023-09-29 11:10:03.018  - info: dwd.0 (7270) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 11:10:03.730  - info: dwd.0 (7270) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 11:10:04.257  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 11:10:18.655  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:12:28.663  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:13:28.665  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:14:51.229  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Netz.WhImported, feature disabled (or below threshold) processing normally)
      2023-09-29 11:15:00.060  - info: host.iobroker instance system.adapter.dwd.0 started with pid 7528
      2023-09-29 11:15:01.957  - info: dwd.0 (7528) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 11:15:02.916  - info: dwd.0 (7528) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 11:15:03.437  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 11:15:38.672  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:16:38.673  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:19:18.678  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:20:00.045  - info: host.iobroker instance system.adapter.dwd.0 started with pid 7771
      2023-09-29 11:20:02.628  - info: dwd.0 (7771) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 11:20:03.644  - info: dwd.0 (7771) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 11:20:04.168  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 11:20:18.681  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:22:58.686  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:23:58.688  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:25:00.043  - info: host.iobroker instance system.adapter.dwd.0 started with pid 8030
      2023-09-29 11:25:01.874  - info: dwd.0 (8030) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 11:25:02.671  - info: dwd.0 (8030) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 11:25:03.192  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 11:28:04.875  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:29:04.876  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:30:00.040  - info: host.iobroker instance system.adapter.dwd.0 started with pid 8284
      2023-09-29 11:30:02.846  - info: dwd.0 (8284) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 11:30:03.997  - info: dwd.0 (8284) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 11:30:04.519  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 11:30:18.692  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:31:18.693  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:33:38.703  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:34:38.705  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:35:00.046  - info: host.iobroker instance system.adapter.dwd.0 started with pid 8528
      2023-09-29 11:35:02.239  - info: dwd.0 (8528) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 11:35:03.210  - info: dwd.0 (8528) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 11:35:03.737  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 11:35:08.695  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:36:08.697  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:37:48.701  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:38:48.702  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:40:00.061  - info: host.iobroker instance system.adapter.dwd.0 started with pid 8782
      2023-09-29 11:40:04.300  - info: dwd.0 (8782) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 11:40:04.703  - info: dwd.0 (8782) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 11:40:05.230  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 11:41:28.712  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:42:28.713  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:45:00.070  - info: host.iobroker instance system.adapter.dwd.0 started with pid 9042
      2023-09-29 11:45:01.882  - info: dwd.0 (9042) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 11:45:02.831  - info: dwd.0 (9042) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 11:45:03.355  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 11:45:04.914  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:46:04.915  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:47:08.719  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:48:08.721  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:48:34.423  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:49:34.426  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:50:00.068  - info: host.iobroker instance system.adapter.dwd.0 started with pid 9287
      2023-09-29 11:50:04.201  - info: dwd.0 (9287) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 11:50:05.237  - info: dwd.0 (9287) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 11:50:05.925  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 11:54:38.728  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:55:00.049  - info: host.iobroker instance system.adapter.dwd.0 started with pid 9554
      2023-09-29 11:55:01.898  - info: dwd.0 (9554) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 11:55:02.600  - info: dwd.0 (9554) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 11:55:03.213  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 11:55:38.729  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:58:17.731  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 11:59:17.733  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 11:59:57.730  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:00:00.067  - info: host.iobroker instance system.adapter.dwd.0 started with pid 9800
      2023-09-29 12:00:06.138  - info: dwd.0 (9800) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 12:00:07.189  - info: dwd.0 (9800) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 12:00:07.823  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 12:00:57.733  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:02:12.188  - error: modbus.0 (325) Can not set value: Attempt to access memory outside buffer bounds
      2023-09-29 12:02:44.151  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:03:44.154  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:04:17.743  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:04:22.069  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Netz.WhImported, feature disabled (or below threshold) processing normally)
      2023-09-29 12:05:00.039  - info: host.iobroker instance system.adapter.dwd.0 started with pid 10061
      2023-09-29 12:05:01.844  - info: dwd.0 (10061) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 12:05:03.537  - info: dwd.0 (10061) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 12:05:04.081  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 12:05:17.745  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:06:20.686  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Netz.WhImported, feature disabled (or below threshold) processing normally)
      2023-09-29 12:08:14.158  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:09:14.160  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:09:34.175  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:10:00.072  - info: host.iobroker instance system.adapter.dwd.0 started with pid 10322
      2023-09-29 12:10:04.188  - info: dwd.0 (10322) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 12:10:05.526  - info: dwd.0 (10322) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 12:10:06.052  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 12:10:34.177  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:13:14.278  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:14:14.280  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:15:00.051  - info: host.iobroker instance system.adapter.dwd.0 started with pid 10564
      2023-09-29 12:15:02.066  - info: dwd.0 (10564) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 12:15:03.144  - info: dwd.0 (10564) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 12:15:03.665  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 12:15:38.785  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:16:38.787  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:20:00.038  - info: host.iobroker instance system.adapter.dwd.0 started with pid 10818
      2023-09-29 12:20:03.547  - info: dwd.0 (10818) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 12:20:03.990  - info: dwd.0 (10818) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 12:20:04.512  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 12:24:28.808  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:25:00.043  - info: host.iobroker instance system.adapter.dwd.0 started with pid 11073
      2023-09-29 12:25:02.646  - info: dwd.0 (11073) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 12:25:03.728  - info: dwd.0 (11073) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 12:25:04.254  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 12:25:28.810  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:26:28.816  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:27:28.819  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:30:00.041  - info: host.iobroker instance system.adapter.dwd.0 started with pid 11317
      2023-09-29 12:30:03.593  - info: dwd.0 (11317) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 12:30:05.182  - info: dwd.0 (11317) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 12:30:05.710  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 12:31:03.920  - error: modbus.0 (325) Can not set value: Attempt to access memory outside buffer bounds
      2023-09-29 12:33:48.856  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:34:48.858  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:35:00.061  - info: host.iobroker instance system.adapter.dwd.0 started with pid 11574
      2023-09-29 12:35:01.889  - info: dwd.0 (11574) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 12:35:02.699  - info: dwd.0 (11574) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 12:35:03.232  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 12:36:08.856  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:37:08.858  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:39:44.271  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:40:00.057  - info: host.iobroker instance system.adapter.dwd.0 started with pid 11834
      2023-09-29 12:40:03.560  - info: dwd.0 (11834) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 12:40:04.313  - info: dwd.0 (11834) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 12:40:04.835  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 12:40:44.273  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:41:08.868  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:42:08.870  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:42:34.080  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:43:34.082  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:44:18.069  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Netz.WhExported, feature disabled (or below threshold) processing normally)
      2023-09-29 12:44:58.883  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:45:00.063  - info: host.iobroker instance system.adapter.dwd.0 started with pid 12078
      2023-09-29 12:45:02.342  - info: dwd.0 (12078) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 12:45:03.270  - info: dwd.0 (12078) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 12:45:03.806  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 12:45:58.887  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:46:51.751  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Netz.WhExported, feature disabled (or below threshold) processing normally)
      2023-09-29 12:46:54.833  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:47:54.835  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:49:34.841  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:50:00.061  - info: host.iobroker instance system.adapter.dwd.0 started with pid 12338
      2023-09-29 12:50:04.047  - info: dwd.0 (12338) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 12:50:05.136  - info: dwd.0 (12338) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 12:50:05.693  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 12:50:34.844  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:51:44.845  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:52:44.847  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:55:00.048  - info: host.iobroker instance system.adapter.dwd.0 started with pid 12594
      2023-09-29 12:55:01.884  - info: dwd.0 (12594) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 12:55:02.737  - info: dwd.0 (12594) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 12:55:03.258  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 12:55:44.854  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:56:44.855  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:57:54.429  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 12:58:54.432  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 12:59:14.313  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:00:00.040  - info: host.iobroker instance system.adapter.dwd.0 started with pid 12838
      2023-09-29 13:00:04.417  - info: dwd.0 (12838) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 13:00:05.361  - info: dwd.0 (12838) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 13:00:05.938  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 13:00:14.316  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:00:38.923  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:01:38.924  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:02:08.923  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:03:08.925  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:05:00.055  - info: host.iobroker instance system.adapter.dwd.0 started with pid 13093
      2023-09-29 13:05:02.237  - info: dwd.0 (13093) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 13:05:02.966  - info: dwd.0 (13093) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 13:05:03.496  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 13:06:58.928  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:07:58.931  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:09:48.927  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:10:00.038  - info: host.iobroker instance system.adapter.dwd.0 started with pid 13344
      2023-09-29 13:10:04.287  - info: dwd.0 (13344) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 13:10:04.882  - info: dwd.0 (13344) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 13:10:05.402  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 13:10:48.929  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:13:08.930  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:14:08.932  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:14:52.852  - error: modbus.0 (325) Can not set value: Attempt to access memory outside buffer bounds
      2023-09-29 13:15:00.044  - info: host.iobroker instance system.adapter.dwd.0 started with pid 13587
      2023-09-29 13:15:01.838  - info: dwd.0 (13587) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 13:15:02.690  - info: dwd.0 (13587) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 13:15:03.235  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 13:15:18.935  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:16:18.937  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:17:18.939  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:18:18.942  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:20:00.045  - info: host.iobroker instance system.adapter.dwd.0 started with pid 13846
      2023-09-29 13:20:03.506  - info: dwd.0 (13846) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 13:20:04.135  - info: dwd.0 (13846) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 13:20:04.657  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 13:20:08.951  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:21:08.952  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:25:00.070  - info: host.iobroker instance system.adapter.dwd.0 started with pid 14102
      2023-09-29 13:25:02.484  - info: dwd.0 (14102) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 13:25:03.075  - info: dwd.0 (14102) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 13:25:03.598  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 13:27:28.979  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:28:28.983  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:29:48.977  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:30:00.124  - info: host.iobroker instance system.adapter.dwd.0 started with pid 14349
      2023-09-29 13:30:04.193  - info: dwd.0 (14349) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 13:30:04.627  - info: dwd.0 (14349) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 13:30:05.151  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 13:30:48.979  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:32:48.991  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:33:49.003  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:35:00.050  - info: host.iobroker instance system.adapter.dwd.0 started with pid 14605
      2023-09-29 13:35:01.831  - info: dwd.0 (14605) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 13:35:02.843  - info: dwd.0 (14605) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 13:35:03.435  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 13:35:14.741  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:36:14.742  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:37:04.665  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:37:11.353  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Netz.WhExported, feature disabled (or below threshold) processing normally)
      2023-09-29 13:38:04.666  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:40:00.077  - info: host.iobroker instance system.adapter.dwd.0 started with pid 14861
      2023-09-29 13:40:03.773  - info: dwd.0 (14861) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 13:40:04.342  - info: dwd.0 (14861) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 13:40:04.879  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 13:40:41.541  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Netz.WhImported, feature disabled (or below threshold) processing normally)
      2023-09-29 13:41:24.511  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:42:24.513  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:43:21.090  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Netz.WhImported, feature disabled (or below threshold) processing normally)
      2023-09-29 13:44:04.278  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:45:00.042  - info: host.iobroker instance system.adapter.dwd.0 started with pid 15106
      2023-09-29 13:45:02.204  - info: dwd.0 (15106) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 13:45:03.102  - info: dwd.0 (15106) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 13:45:03.632  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 13:45:04.281  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:45:58.255  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:46:58.256  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:49:08.267  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:50:00.052  - info: host.iobroker instance system.adapter.dwd.0 started with pid 15361
      2023-09-29 13:50:03.451  - info: dwd.0 (15361) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 13:50:04.153  - info: dwd.0 (15361) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 13:50:04.688  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 13:50:08.268  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:50:34.519  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:51:34.521  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:51:54.292  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:52:54.294  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:53:54.330  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:54:54.332  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:55:00.167  - info: host.iobroker instance system.adapter.dwd.0 started with pid 15605
      2023-09-29 13:55:02.959  - info: dwd.0 (15605) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 13:55:03.428  - info: dwd.0 (15605) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 13:55:03.950  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 13:56:04.310  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:57:04.313  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 13:57:41.001  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Netz.WhImported, feature disabled (or below threshold) processing normally)
      2023-09-29 13:58:11.053  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Netz.WhImported, feature disabled (or below threshold) processing normally)
      2023-09-29 13:58:24.313  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 13:58:47.628  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Keller.Wasserzaehler.ACTUAL, feature disabled (or below threshold) processing normally)
      2023-09-29 13:59:24.316  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:00:00.043  - info: host.iobroker instance system.adapter.dwd.0 started with pid 15860
      2023-09-29 14:00:07.288  - info: dwd.0 (15860) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 14:00:08.233  - info: dwd.0 (15860) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 14:00:08.833  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 14:00:18.283  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:01:18.285  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:01:44.094  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:02:44.096  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:04:24.332  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:05:00.040  - info: host.iobroker instance system.adapter.dwd.0 started with pid 16120
      2023-09-29 14:05:02.025  - info: dwd.0 (16120) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 14:05:02.801  - info: dwd.0 (16120) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 14:05:03.322  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 14:05:24.334  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:06:44.324  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:07:44.326  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:08:44.564  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:09:44.565  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:10:00.048  - info: host.iobroker instance system.adapter.dwd.0 started with pid 16363
      2023-09-29 14:10:04.090  - info: dwd.0 (16363) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 14:10:04.514  - info: dwd.0 (16363) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 14:10:05.053  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 14:10:53.892  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:11:53.895  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:12:25.175  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:13:25.177  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:14:04.806  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:15:00.045  - info: host.iobroker instance system.adapter.dwd.0 started with pid 16620
      2023-09-29 14:15:02.205  - info: dwd.0 (16620) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 14:15:03.143  - info: dwd.0 (16620) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 14:15:03.665  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 14:15:04.807  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:15:38.737  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Netz.WhImported, feature disabled (or below threshold) processing normally)
      2023-09-29 14:16:04.919  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:17:04.921  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:18:04.349  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:19:04.351  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:19:54.128  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:20:00.043  - info: host.iobroker instance system.adapter.dwd.0 started with pid 16877
      2023-09-29 14:20:03.599  - info: dwd.0 (16877) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 14:20:04.467  - info: dwd.0 (16877) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 14:20:05.001  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 14:20:54.129  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:22:04.818  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:23:04.821  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:23:24.591  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:24:24.593  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:25:00.043  - info: host.iobroker instance system.adapter.dwd.0 started with pid 17122
      2023-09-29 14:25:01.936  - info: dwd.0 (17122) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 14:25:02.660  - info: dwd.0 (17122) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 14:25:03.188  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 14:25:54.688  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:26:54.690  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:27:14.703  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:28:14.704  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:29:44.836  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:30:00.057  - info: host.iobroker instance system.adapter.dwd.0 started with pid 17377
      2023-09-29 14:30:03.559  - info: dwd.0 (17377) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 14:30:04.389  - info: dwd.0 (17377) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 14:30:04.915  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 14:30:44.838  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:31:53.131  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:32:53.132  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:34:34.165  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:35:00.046  - info: host.iobroker instance system.adapter.dwd.0 started with pid 17633
      2023-09-29 14:35:01.880  - info: dwd.0 (17633) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 14:35:02.491  - info: dwd.0 (17633) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 14:35:03.046  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 14:35:34.167  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:36:08.377  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:37:08.379  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:40:00.060  - info: host.iobroker instance system.adapter.dwd.0 started with pid 17877
      2023-09-29 14:40:03.951  - info: dwd.0 (17877) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 14:40:04.653  - info: dwd.0 (17877) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 14:40:05.177  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 14:41:28.367  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:42:28.369  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:43:18.390  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:44:18.392  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:45:00.049  - info: host.iobroker instance system.adapter.dwd.0 started with pid 18137
      2023-09-29 14:45:01.925  - info: dwd.0 (18137) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 14:45:02.706  - info: dwd.0 (18137) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 14:45:03.227  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 14:45:43.067  - error: modbus.0 (325) Can not set value: Attempt to access memory outside buffer bounds
      2023-09-29 14:46:48.376  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:47:48.378  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:48:48.377  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:49:48.379  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:50:00.047  - info: host.iobroker instance system.adapter.dwd.0 started with pid 18392
      2023-09-29 14:50:03.766  - info: dwd.0 (18392) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 14:50:04.406  - info: dwd.0 (18392) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 14:50:05.006  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 14:53:38.382  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:54:38.384  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:55:00.087  - info: host.iobroker instance system.adapter.dwd.0 started with pid 18634
      2023-09-29 14:55:02.836  - info: dwd.0 (18634) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 14:55:03.508  - info: dwd.0 (18634) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 14:55:04.033  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 14:55:38.385  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:56:38.387  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 14:58:46.856  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Keller.Wasserzaehler.ACTUAL, feature disabled (or below threshold) processing normally)
      2023-09-29 14:58:58.395  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 14:59:58.396  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:00:00.104  - info: host.iobroker instance system.adapter.dwd.0 started with pid 18890
      2023-09-29 15:00:09.251  - info: dwd.0 (18890) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 15:00:10.475  - info: dwd.0 (18890) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 15:00:11.048  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 15:01:04.770  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:02:04.773  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:04:04.245  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:05:00.053  - info: host.iobroker instance system.adapter.dwd.0 started with pid 19144
      2023-09-29 15:05:01.932  - info: dwd.0 (19144) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 15:05:02.823  - info: dwd.0 (19144) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 15:05:03.359  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 15:05:04.247  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:06:14.249  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:07:14.251  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:08:04.293  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:09:04.295  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:10:00.045  - info: host.iobroker instance system.adapter.dwd.0 started with pid 19387
      2023-09-29 15:10:03.544  - info: dwd.0 (19387) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 15:10:04.209  - info: dwd.0 (19387) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 15:10:04.729  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 15:10:24.270  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:11:24.273  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:12:14.268  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:13:14.270  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:14:28.422  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:15:00.043  - info: host.iobroker instance system.adapter.dwd.0 started with pid 19643
      2023-09-29 15:15:01.866  - info: dwd.0 (19643) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 15:15:02.897  - info: dwd.0 (19643) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 15:15:03.419  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 15:15:28.423  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:16:48.430  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:17:48.432  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:19:58.452  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:20:00.065  - info: host.iobroker instance system.adapter.dwd.0 started with pid 19895
      2023-09-29 15:20:03.960  - info: dwd.0 (19895) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 15:20:04.595  - info: dwd.0 (19895) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 15:20:05.145  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 15:20:58.453  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:25:00.052  - info: host.iobroker instance system.adapter.dwd.0 started with pid 20138
      2023-09-29 15:25:02.025  - info: dwd.0 (20138) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 15:25:02.950  - info: dwd.0 (20138) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 15:25:03.474  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 15:25:28.459  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:26:28.461  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:27:28.470  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:28:28.471  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:29:48.484  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:30:00.045  - info: host.iobroker instance system.adapter.dwd.0 started with pid 20396
      2023-09-29 15:30:02.661  - info: dwd.0 (20396) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 15:30:04.027  - info: dwd.0 (20396) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 15:30:04.552  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 15:30:48.486  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:34:38.490  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:35:00.044  - info: host.iobroker instance system.adapter.dwd.0 started with pid 20652
      2023-09-29 15:35:01.948  - info: dwd.0 (20652) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 15:35:02.905  - info: dwd.0 (20652) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 15:35:03.427  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 15:35:38.492  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:40:00.046  - info: host.iobroker instance system.adapter.dwd.0 started with pid 20895
      2023-09-29 15:40:02.589  - info: dwd.0 (20895) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 15:40:04.059  - info: dwd.0 (20895) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 15:40:04.580  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 15:40:18.503  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:41:18.505  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:42:38.679  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:43:38.681  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:45:00.046  - info: host.iobroker instance system.adapter.dwd.0 started with pid 21152
      2023-09-29 15:45:03.571  - info: dwd.0 (21152) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 15:45:04.050  - info: dwd.0 (21152) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 15:45:04.574  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 15:45:49.653  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:46:49.655  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:50:00.119  - info: host.iobroker instance system.adapter.dwd.0 started with pid 21409
      2023-09-29 15:50:06.685  - info: dwd.0 (21409) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 15:50:07.699  - info: dwd.0 (21409) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 15:50:08.256  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 15:50:09.657  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:51:09.660  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 15:55:00.055  - info: host.iobroker instance system.adapter.dwd.0 started with pid 21651
      2023-09-29 15:55:01.732  - info: dwd.0 (21651) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 15:55:02.418  - info: dwd.0 (21651) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 15:55:02.940  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 15:58:19.689  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 15:59:19.691  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 16:00:00.641  - info: host.iobroker instance system.adapter.dwd.0 started with pid 21907
      2023-09-29 16:00:07.198  - info: dwd.0 (21907) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 16:00:08.639  - info: dwd.0 (21907) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 16:00:09.185  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 16:00:29.568  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 16:01:29.569  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 16:02:19.778  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 16:03:19.780  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 16:05:00.052  - info: host.iobroker instance system.adapter.dwd.0 started with pid 22154
      2023-09-29 16:05:02.291  - info: dwd.0 (22154) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 16:05:03.096  - info: dwd.0 (22154) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 16:05:03.635  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 16:05:29.794  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 16:06:29.796  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 16:07:23.546  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 16:08:23.548  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 16:08:47.140  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Keller.Wasserzaehler.ACTUAL, feature disabled (or below threshold) processing normally)
      2023-09-29 16:08:54.787  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 16:09:54.788  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 16:10:00.039  - info: host.iobroker instance system.adapter.dwd.0 started with pid 22411
      2023-09-29 16:10:01.732  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Netz.WhImported, feature disabled (or below threshold) processing normally)
      2023-09-29 16:10:04.303  - info: dwd.0 (22411) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 16:10:04.713  - info: dwd.0 (22411) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 16:10:05.235  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 16:10:39.797  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 16:11:39.799  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 16:12:58.867  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 16:13:58.868  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 16:14:59.825  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 16:15:00.045  - info: host.iobroker instance system.adapter.dwd.0 started with pid 22666
      2023-09-29 16:15:02.389  - info: dwd.0 (22666) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 16:15:03.268  - info: dwd.0 (22666) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 16:15:03.795  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 16:15:59.832  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 16:17:19.840  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 16:17:39.168  - info: sourceanalytix.0 (7247) Device reset detected for alias.0.Netz.WhExported, feature disabled (or below threshold) processing normally)
      2023-09-29 16:18:19.845  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 16:19:23.965  - info: modbus.0 (325) Disconnected from slave 192.168.1.47
      2023-09-29 16:19:37.933  - info: admin.0 (279) ==> Connected system.user.admin from ::ffff:192.168.1.119
      2023-09-29 16:20:00.306  - info: host.iobroker instance system.adapter.dwd.0 started with pid 22911
      2023-09-29 16:20:09.136  - info: dwd.0 (22911) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.1, js-controller: 5.0.12
      2023-09-29 16:20:09.835  - info: dwd.0 (22911) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-09-29 16:20:10.363  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-09-29 16:20:23.967  - info: modbus.0 (325) Connected to slave 192.168.1.47
      2023-09-29 16:20:52.095  - error: modbus.0 (325) Can not set value: Attempt to access memory outside buffer bounds
      eine Frage noch: Ist das ständige Connect/Disconnect so gewollt bzw. in Ordnung?
      • Glasfaser
        Glasfaser @Schtallone last edited by
        @schtallone sagte in Modbus adapter:
        Ich hatte ich auch das Problem , wie ich schon mal dir geschrieben habe
        https://forum.iobroker.net/post/1048153
        aber es lag an Shelly , deshalb habe ich die Bauteile auf Tasmota geflasht und seit dem ist alles ruhig.
        Homoran S 2 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @Glasfaser last edited by
          @glasfaser sagte in Modbus adapter:
          ohne jetzt den Link gelesen zu haben, was hat shelly mit modbus zu schaffen?
            Schtallone @Glasfaser last edited by
            @glasfaser said in Modbus adapter:
            Also bei mir hat der Shelly Adapter keinen Einfluss auf das Connect/Disconnect Verhalten. Auch eine Datenabfrageintervall von 5000ms zeigt keine wirkliche Veränderung. Ich werden den Wert noch höher machen und beobachten.
            Aber ist es denn allgemein vorgesehen, dass der Adapter connceted, Daten abruft und dann wieder disconected?
              Homoran Global Moderator Administrators @Schtallone last edited by
              @schtallone ich hab das Verhalten nicht.
              weder bei dem einen mit tcp, noch bei den anderen mit RTU.
              Kann aber sein, dass nur meine alte Admin version das nicht im log zeigt.
                benni86 last edited by
                Hallo, ich habe eine kurze Modbus-Anfängerfrage. Ich habe meine Wärmepumpe eingerichtet (Typ: Master). Bezüglich der Eingangsregister ist alles klar (sind ja read only), aber was ich nicht verstehe sind die Holding Register. Abfrage und CW, aus welcher Sicht ist das gesehen? Was muss ich einstellen, wenn ich nur von der Wärmepumpe lesen möchte?
                  Homoran Global Moderator Administrators @benni86 last edited by
                  @benni86 sagte in Modbus adapter:
                  wieso willst du Holdingregister nur lesen?
                  Holdingregister sind zum Beschreiben.
                  Abfrage ist klar, wenn du deren Wert abfragen willst, Cyclic Write solltest du tunlichst vermeiden wenn die Werte in ein EEPROM geschrieben werden.
                  Das hält nur ca. 100.000 Schreibvorgänge
                    benni86 @Homoran last edited by
                    @homoran danke für deine Erklärung. Wieso ich es nur lesen will? Mir reicht erstmal die Anzeige des Betriebsmodi, habe grade keinen usecase diesen auch zu ändern. Der Hinweis ist gut mit den Schreibzyklen: das vermeide ich zuverlässig wenn ich CW deaktiviere? Wenn es sich bei CW ums Schreiben ins Register des Geräts handelt, wieso gibts die Option dann auch bei Eingangsregistern die doch nur zum lesen sind? Und ist mein beobachtetes Verhalten korrekt, dass wenn ich bei Holding Registern poll nicht aktiviert habe dann liest er auch keine Werte? Schreiben würde er sie auch nur mit aktiviertem poll meiner Beobachtung nach. Ist mein Verständnis korrekt?
                      socke85 @benni86 last edited by
                      @Bluefox und Community: Ich nutze den Adapter für meinen Wechselrichter und meine Wärmepumpe. Vielen Dank für diesen Adapter!
                      Mit dem Wechselrichter funktioniert das super und eigentlich auch mit der Wärmepumpe. Neuerdings ist der Adapter aber immer gelb und im Log habe ich die Meldung
                      "Poll error count: 6 code: "App Timeout"
                      Ich habe versucht das nachzuvollziehen, indem ich mal Logstufe silly gewählt und per Wireshark den Traffic aufgezeichnet habe.
                      Hier ein Auszug aus dem Log:
                      modbus.0
                      2023-12-04 21:29:46.368	debug	[DevID_1/inputRegs] Poll address 31104 DONE
                      modbus.0
                      2023-12-04 21:29:46.368	debug	[DevID_1/inputRegs] Poll address 36101 DONE
                      modbus.0
                      2023-12-04 21:29:46.366	debug	[DevID_1/inputRegs] Poll address 31104 - 2 registers
                      modbus.0
                      2023-12-04 21:29:46.366	debug	[DevID_1/inputRegs] Poll address 36101 - 4 registers
                      modbus.0
                      2023-12-04 21:29:16.563	warn	Poll error count: 7 code: "App Timeout"
                      modbus.0
                      2023-12-04 21:29:16.368	debug	[DevID_1/inputRegs] Poll address 30006 DONE
                      modbus.0
                      2023-12-04 21:29:16.367	debug	[DevID_1/inputRegs] Poll address 30006 - 1 registers
                      Per Wireshark wirkt auch alles wie es soll, d.h. query für register 30006, response und dann noch ein ACK, alles in time. Anschließend der nächste query für 36101 inkl. response und ACK. Zwischen diesen beiden Abfragen kommt die Fehlermeldung "Poll error count: 7 code: "App Timeout""
                      Hier die allgemeinen Settings für die Instanz:
                      Bildschirmfoto 2023-12-04 um 21.39.59.png Bildschirmfoto 2023-12-04 um 21.40.06.png
                      Long Story short, die Kommunikation mit der Wärmepumpe sieht gut aus. Die Meldung kann ich mir nicht erklären - liegt evtl. an den allgemeinen Einstellungen?
                      Danke für eure Hilfe!
                        socke85 @socke85 last edited by
                        @socke85 Push 👥 👍
                          Homoran Global Moderator Administrators @socke85 last edited by Homoran
                          @socke85 sagte in Modbus adapter:
                          @socke85 Push 👥 👍
                          und wo pushst du die Konfigurationen?
                            worxweis @bkuerby last edited by
                            @bkuerby
                            Hallo!
                            Hast du deine WPCU Abfrage damals zum laufen bekommen?
                            Ich will das jetzt auch gerade umsetzen. Ich habe dazu eine Raspi 4 mit IOBroker und Modbus Adapter. Verbunden über einen Seriell zu USB Adapter.
                            Ich bekomme auch schon bei den meisten Registern Werte, nur ergeben diese Werte keinen Sinn!
                            Hast du vielleicht eine Lösung, wie du die Werte umrechnest?
                              fliegema last edited by fliegema
                              Update: 1 aufgrund der sehr freundlichen Hinweise wurden die Logs mit eingefügt.
                              Moin Freunde des Modbuses,
                              ich habe folgende Modbus RTU 4 Channel Karte: RS485 TTL Controller welche dann mit einem Eletechsup ET69C02 Modbus TCP fähig wird.
                              Über den ioBroker Adpater schaffe ich alle 4 Kanäle zu schalten, allerdings nur für das Relais 1 auch den Status abzufragen.
                              Habe mich zunächst mit ModBusTool von Github herangetastet. Es scheint, dass ich den Status der einzelnen Relais nur unter der Adresse 0 abfragen kann. Kann man hier auch schick sehen (mit read coils):
                              Leider bekomme ich das im Modbus Adapter nicht hin. Wie auch im ModbusTool bekomme ich einen Poll / error code 2 von der Platine das die diese abfrage verweigert, sobald ich pro Relais eine coil abfrage mache auf der jeweiligen Adresse.
                              Update (Log nachträglich eingefügt, da ich mittlerweile ein Platine mit 8 Relais dran habe sind hier mehr Coils als in den anderen Screenshots)
                              modbus.2 2025-08-24 14:31:59.990	info	Disconnected from slave 10.8.2.14
                              modbus.2 2025-08-24 14:31:59.990	debug	Closing client on purpose.
                              modbus.2 2025-08-24 14:31:58.992	debug	Cleaning up request fifo.
                              modbus.2 2025-08-24 14:31:58.992	debug	Clearing timeout of the current request.
                              modbus.2 2025-08-24 14:31:58.992	debug	Socket closed with error
                              modbus.2 2025-08-24 14:31:58.990	warn	[DevID_4] Poll error count: 1 code: {"err":"timeout","timeout":5000}
                              modbus.2 2025-08-24 14:31:58.989	error	Client in error state.
                              modbus.2 2025-08-24 14:31:58.989	error	Request timed out.
                              modbus.2 2025-08-24 14:31:58.989	warn	Error: undefined
                              modbus.2 2025-08-24 14:31:53.988	debug	[DevID_4/coils] Poll address 0 - 1 bits
                              modbus.2 2025-08-24 14:31:53.987	debug	[DevID_4] Poll start ---------------------
                              modbus.2 2025-08-24 14:31:53.987	info	Connected to slave 10.8.2.14
                              modbus.2 2025-08-24 14:31:53.872	debug	Initialize Objects for holdingRegs: []
                              modbus.2 2025-08-24 14:31:53.872	debug	Initialize Objects for inputRegs: []
                              modbus.2 2025-08-24 14:31:53.872	debug	Add coils.4.7_Relais-4-8: {"_id":"coils.4.7_Relais-4-8","type":"state","common":{"name":"Relais-4-8","role":"switch","type":"boolean","read":false,"write":true,"def":false},"native":{"regType":"coils","address":7,"deviceId":4,"poll":false,"wp":false}}
                              modbus.2 2025-08-24 14:31:53.871	debug	Add coils.4.6_Relais-4-7: {"_id":"coils.4.6_Relais-4-7","type":"state","common":{"name":"Relais-4-7","role":"switch","type":"boolean","read":false,"write":true,"def":false},"native":{"regType":"coils","address":6,"deviceId":4,"poll":false,"wp":false}}
                              modbus.2 2025-08-24 14:31:53.871	debug	Add coils.4.5_Relais-4-6: {"_id":"coils.4.5_Relais-4-6","type":"state","common":{"name":"Relais-4-6","role":"switch","type":"boolean","read":false,"write":true,"def":false},"native":{"regType":"coils","address":5,"deviceId":4,"poll":false,"wp":false}}
                              modbus.2 2025-08-24 14:31:53.871	debug	Add coils.4.4_Relais-4-5: {"_id":"coils.4.4_Relais-4-5","type":"state","common":{"name":"Relais-4-5","role":"switch","type":"boolean","read":false,"write":true,"def":false},"native":{"regType":"coils","address":4,"deviceId":4,"poll":false,"wp":false}}
                              modbus.2 2025-08-24 14:31:53.871	debug	Add coils.4.3_Relais-4-4: {"_id":"coils.4.3_Relais-4-4","type":"state","common":{"name":"Relais-4-4","role":"switch","type":"boolean","read":false,"write":true,"def":false},"native":{"regType":"coils","address":3,"deviceId":4,"poll":false,"wp":false}}
                              modbus.2 2025-08-24 14:31:53.871	debug	Add coils.4.2_Relais-4-3: {"_id":"coils.4.2_Relais-4-3","type":"state","common":{"name":"Relais-4-3","role":"switch","type":"boolean","read":false,"write":true,"def":false},"native":{"regType":"coils","address":2,"deviceId":4,"poll":false,"wp":false}}
                              modbus.2 2025-08-24 14:31:53.871	debug	Add coils.4.1_Relais-4-2: {"_id":"coils.4.1_Relais-4-2","type":"state","common":{"name":"Relais-4-2","role":"switch","type":"boolean","read":false,"write":true,"def":false},"native":{"regType":"coils","address":1,"deviceId":4,"poll":false,"wp":false}}
                              modbus.2 2025-08-24 14:31:53.871	debug	Add coils.4.0_Relais-4-1: {"_id":"coils.4.0_Relais-4-1","type":"state","common":{"name":"Relais-4-1","role":"switch","type":"boolean","read":true,"write":true,"def":false},"native":{"regType":"coils","address":0,"deviceId":4,"poll":true,"wp":false}}
                              modbus.2 2025-08-24 14:31:53.870	debug	Initialize Objects for coils: [{"_address":0,"deviceId":4,"name":"Relais-4-1","description":"Relais-4-1","formula":"","role":"switch","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"address":0,"id":"coils.4.0_Relais-4-1","len":1},{"_address":1,"deviceId":4,"name":"Relais-4-2","description":"Relais-4-2","formula":"","role":"switch","room":"","poll":false,"wp":false,"cw":false,"isScale":false,"address":1,"id":"coils.4.1_Relais-4-2"},{"_address":2,"deviceId":4,"name":"Relais-4-3","description":"Relais-4-3","formula":"","role":"switch","room":"","poll":false,"wp":false,"cw":false,"isScale":false,"address":2,"id":"coils.4.2_Relais-4-3"},{"_address":3,"deviceId":4,"name":"Relais-4-4","description":"Relais-4-4","formula":"","role":"switch","room":"","poll":false,"wp":false,"cw":false,"isScale":false,"address":3,"id":"coils.4.3_Relais-4-4"},{"_address":4,"deviceId":4,"name":"Relais-4-5","description":"Relais-4-5","formula":"","role":"switch","room":"","poll":false,"wp":false,"cw":false,"isScale":false,"address":4,"id":"coils.4.4_Relais-4-5"},{"_address":5,"deviceId":4,"name":"Relais-4-6","description":"Relais-4-6","formula":"","role":"switch","room":"","poll":false,"wp":false,"cw":false,"isScale":false,"address":5,"id":"coils.4.5_Relais-4-6"},{"_address":6,"deviceId":4,"name":"Relais-4-7","description":"Relais-4-7","formula":"","role":"switch","room":"","poll":false,"wp":false,"cw":false,"isScale":false,"address":6,"id":"coils.4.6_Relais-4-7"},{"_address":7,"deviceId":4,"name":"Relais-4-8","description":"Relais-4-8","formula":"","role":"switch","room":"","poll":false,"wp":false,"cw":false,"isScale":false,"address":7,"id":"coils.4.7_Relais-4-8"}]
                              modbus.2 2025-08-24 14:31:53.870	debug	Initialize Objects for disInputs: []
                              modbus.2 2025-08-24 14:31:53.827	info	starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.19.4, js-controller: 7.0.6
                              Log aus dem ModBus Tool, leider nur als Screenshot möglich.
                              Meine Modbus Adapter Einstellungen sind wie folgt:
                              Allgemein:
                              Diskrete Ausgänge:
                              Hat einer von Euch eine Idee, wie ich als Datenpunkt den Status aus Adresse 0 bekomme? Dann kann ich zwar umständlich aber per Skript mir manuelle Datenpunkte schalten. Grund ist, das ich den aktuellen Status von Relais 2-4 nicht sehe:
                                Homoran Global Moderator Administrators @fliegema last edited by Homoran
                                @fliegema sagte in Modbus adapter:
                                du hast ja auch nur bei 1 die Abfrage aktiviert
                                  fliegema @Homoran last edited by fliegema
                                  @homoran said in Modbus adapter:
                                  fu hast ja auch nur bei 1 die Abfrage aktiviert
                                  Hi, danke für die schnelle Rückmeldung. Dies ist bewusst so, weil sobald ich bei den anderen Adressen die Abfrage setze, ich einen Poll error / timeout bekomme. Genau das gleiche auch mit dem ModbusTool.
                                    dann gehört diese Info auch bewusst in den Post!
                                    einen Poll error
                                    und der wäre?
                                    geheim?
                                      einen Poll error
                                      und der wäre?
                                      geheim?
                                      ganz und gar nicht, jedoch steht nur ein timeout drin (erwähnt) und via ModBusTool ein Error Code 2 sprich Platine verweigert die Abfrage (auch erwähnt)
                                        erwähnt
                                        hast du ohne Kennzeichnung die schwarze Briefmarke später hinzugefügt?
                                        LOGS immer als text in code-tags!
                                        EDITs immer kennzeichnen
                                          erwähnt
                                          ich habe die beiden Screenshots unter den bestehenden Text (erwähnt) nachträglich aufgrund Deines Beitrages eingefügt.
                                            @fliegema
                                            das ist aber auch kein debug-log
                                            modbus modbus adapter
                                            140
                                            978
                                            369053
