    4. [gelöst] js-controller 1.2.0 und sql 1.5.6 funktioniert nicht
      baufuzzi last edited by
      Hallöchen,
      hat sich hier zufällig etwas bewegt? Mit dem Update auf js-controller 1.2.0 hab ich die gleichen Probleme mit dem SQL-Adapter.
      Kann ich noch etwas zusteuern?
      Jakob
        apollon77 last edited by
        Naja ein Log im Debug Modus mit 1.2.0 wäre echt hilfreich.
        Ich kann bisher keine Probleme nachvollziehen 😞
          Einmal Debug-Log:
          sql.0	2017-10-18 21:49:58.715	info	enabled logging of hm-rpc.0.updated
          sql.0	2017-10-18 21:49:58.637	info	Connected to mysql
          sql.0	2017-10-18 21:49:58.636	debug	Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'ts_bool' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.ts_bool (id INTEGER, ts BIGINT, val
          sql.0	2017-10-18 21:49:58.635	debug	CREATE TABLE `iobroker`.ts_bool (id INTEGER, ts BIGINT, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
          sql.0	2017-10-18 21:49:58.631	debug	Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'ts_string' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.ts_string (id INTEGER, ts BIGINT, v
          sql.0	2017-10-18 21:49:58.629	debug	CREATE TABLE `iobroker`.ts_string (id INTEGER, ts BIGINT, val TEXT, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
          sql.0	2017-10-18 21:49:58.626	debug	Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'ts_number' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.ts_number (id INTEGER, ts BIGINT, v
          sql.0	2017-10-18 21:49:58.624	debug	CREATE TABLE `iobroker`.ts_number (id INTEGER, ts BIGINT, val REAL, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
          sql.0	2017-10-18 21:49:58.620	debug	Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'datapoints' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.datapoints (id INTEGER NOT NULL PRI
          sql.0	2017-10-18 21:49:58.618	debug	CREATE TABLE `iobroker`.datapoints (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT, type INTEGER);
          sql.0	2017-10-18 21:49:58.613	debug	Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'sources' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.sources (id INTEGER NOT NULL PRIMAR
          sql.0	2017-10-18 21:49:58.610	debug	CREATE TABLE `iobroker`.sources (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT);
          sql.0	2017-10-18 21:49:58.593	debug	Response: {"code":"ER_DB_CREATE_EXISTS","errno":1007,"sqlMessage":"Can't create database 'iobroker'; database exists","sqlState":"HY000","index":0,"sql":"CREATE DATABASE `iobroker` DEFAULT CHARACTER
          sql.0	2017-10-18 21:49:58.574	debug	CREATE DATABASE `iobroker` DEFAULT CHARACTER SET utf8 DEFAULT COLLATE utf8_general_ci;
          sql.0	2017-10-18 21:49:58.191	info	starting. Version 1.5.6 in C:/ioBroker/node_modules/iobroker.sql, node: v4.5.0
          sql.0	2017-10-18 21:49:58.108	debug	statesDB connected
          sql.0	2017-10-18 21:49:58.050	debug	objectDB connected
          Der Adapter geht dann wieder auf Rot aber keine weiteren Log-Einträge mehr.
          Was ich jetzt kurios finde - sobald ich direkt im Anschluss über die Kommandozeile (wie weiter oben beschrieben) den Adapter mit "… -force -logs" starte, läuft er in der shell sauber und logged auch im iobroker Browser-Log los und macht seinen Job mit seinen x-Einträgen 😮 :?:
          Wo könnte ich ansetzen, eine Idee? Ich weiß, ich müsste mal mein NodeJs updaten... lief bisher ohne murren.
            Die Kombi läuft bei mir ohne Probleme.
            Vielleicht reicht mal ein einfacher Reboot des ioBroker Servers.
            Rainer
            • eric2905
              eric2905 last edited by
              Versuche erst mal den Reboot … tut fast immer gut.
              Was mich etwas irritiert, ist der Hinweis im Log, das alle Tabellen neu angelegt werden sollen, was dann natürlich so nicht geht.
              Wo läuft denn Dein SQL-Server und was für ein Server ist es (MySQL, MS SQL, ....)?
              Gruß,
              Eric
              PS: Läuft bei mir ach ohne Probleme.
              Von unterwegs getippert
                Wenn er läuft und rot ist … wenn DU dann einen weiteren Datenpunkt zum logging dazu konfigurierst kommt die meldung das er enabled wurde?
                Wie sieht denn das Log aus wenn du es per Kommandozeile startest?
                @Eric: Das neu anlegen ist immer so.
                  Danke fürs Feedback.
                  Reboots hab ich einige hinter mir, leider nicht die Lösung.
                  Ich fahre auf dem gleichen Host MySQL (okay MariaDB, ein Problem?) und funktionierte in der Vergangenheit, aktuell auch über die Kommandozeile kopfkratz.
                  Wenn er Rot ist und ich einen weiteren Datenpunkt aktiviere, regt sich leider in keinem Log etwas und es gibt auch kein negatives Feedback beim Einrichten.
                  So sieht das Log aus der Kommandozeile aus (nur ein Ausschnitt):
                  C:\ioBroker>node node_modules/iobroker.sql/main.js -force -logs
                  Cannot find module 'pg-native'
                  2017-10-18 22:27:02.579  - info: sql.0 starting. Version 1.5.6 in C:/ioBroker/node_modules/iobroker.sql, node: v4.5.0
                  2017-10-18 22:27:02.962  - debug: sql.0 CREATE DATABASE `iobroker` DEFAULT CHARACTER SET utf8 DEFAULT COLLATE utf8_general_ci;
                  2017-10-18 22:27:02.982  - debug: sql.0 Response: {"code":"ER_DB_CREATE_EXISTS","errno":1007,"sqlMessage":"Can't create database 'iobroker'; database exists","sqlState":"HY000","index":0,"sql":"CREATE DATABASE `iobroker` DEFAULT CHARACTER SET utf8 DEFAULT COLLATE utf8_general_ci;"}
                  2017-10-18 22:27:03.002  - debug: sql.0 CREATE TABLE `iobroker`.sources    (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT);
                  2017-10-18 22:27:03.008  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'sources' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.sources    (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT);"}
                  2017-10-18 22:27:03.015  - debug: sql.0 CREATE TABLE `iobroker`.datapoints (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT, type INTEGER);
                  2017-10-18 22:27:03.018  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'datapoints' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.datapoints (id INTEGER NOT NULL PRIMARY KEY AUTO_INCREMENT, name TEXT, type INTEGER);"}
                  2017-10-18 22:27:03.025  - debug: sql.0 CREATE TABLE `iobroker`.ts_number  (id INTEGER, ts BIGINT, val REAL,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                  2017-10-18 22:27:03.029  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'ts_number' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.ts_number  (id INTEGER, ts BIGINT, val REAL,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));"}
                  2017-10-18 22:27:03.035  - debug: sql.0 CREATE TABLE `iobroker`.ts_string  (id INTEGER, ts BIGINT, val TEXT,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                  2017-10-18 22:27:03.039  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'ts_string' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.ts_string  (id INTEGER, ts BIGINT, val TEXT,    ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));"}
                  2017-10-18 22:27:03.047  - debug: sql.0 CREATE TABLE `iobroker`.ts_bool    (id INTEGER, ts BIGINT, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));
                  2017-10-18 22:27:03.052  - debug: sql.0 Response: {"code":"ER_TABLE_EXISTS_ERROR","errno":1050,"sqlMessage":"Table 'ts_bool' already exists","sqlState":"42S01","index":0,"sql":"CREATE TABLE `iobroker`.ts_bool    (id INTEGER, ts BIGINT, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts));"}
                  2017-10-18 22:27:03.054  - info: sql.0 Connected to mysql
                  2017-10-18 22:27:03.142  - info: sql.0 enabled logging of hm-rpc.0.updated
                  2017-10-18 22:27:03.144  - info: sql.0 enabled logging of hm-rpc.1.updated
                  2017-10-18 22:27:03.145  - info: sql.0 enabled logging of hm-rpc.0.BidCoS-RF.0.INSTALL_MODE
                  2017-10-18 22:27:03.146  - info: sql.0 enabled logging of hm-rpc.0.BidCoS-RF.1.LEVEL
                  2017-10-18 22:27:03.147  - info: sql.0 enabled logging of hm-rpc.0.BidCoS-RF.1.PRESS_LONG
                  2017-10-18 22:27:03.148  - info: sql.0 enabled logging of hm-rpc.0.BidCoS-RF.1.PRESS_SHORT
                  2017-10-18 22:27:03.149  - info: sql.0 enabled logging of hm-rpc.0.BidCoS-RF.2.LEVEL
                  2017-10-18 22:27:03.151  - info: sql.0 enabled logging of hm-rpc.0.BidCoS-RF.2.PRESS_LONG
                  ....... usw.
                  • eric2905
                    @apollon77:
                    @Eric: Das neu anlegen ist immer so. `
                    Ah, ok. Hatte es im Log gesehen und mich gewundert.
                    Gruß,
                    Eric
                      GerdSo last edited by
                      Kurze Ergänzung von meiner Seite:
                      • mySQL-DB auf dem gleichen Host wie ioBroker
                        mit js-controller 1.2.3 funktioniert der sql-Adapter wieder korrekt. Danke dafür an die Entwickler
                        2802
