    4. Support Adapter Energiefluss-erweitert v0.7.7
      dskrt @Homoran last edited by
      @homoran @holgerwolf
      Danke, das Leben kann doch manchmal so einfach sein, wenn man es weiss.
        arteck Developer Most Active @SKB last edited by arteck
        @skb ich hab da mal wieder was
        host.iobroker
        2023-12-21 09:49:24.295	error	instance system.adapter.energiefluss-erweitert.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2023-12-21 09:49:23.649	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-12-21 09:49:23.642	error	Cannot read properties of undefined (reading 'source')
        2023-12-21 09:49:23.640	error	TypeError: Cannot read properties of undefined (reading 'source') at EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1211:77)
        2023-12-21 09:49:23.639	error	unhandled promise rejection: Cannot read properties of undefined (reading 'source')
        2023-12-21 09:49:23.636	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        host.iobroker
        2023-12-21 09:49:20.749	info	instance system.adapter.energiefluss-erweitert.0 started with pid 2428507
        host.iobroker
        2023-12-21 09:48:50.632	info	Restart adapter system.adapter.energiefluss-erweitert.0 because enabled
        host.iobroker
        2023-12-21 09:48:50.631	error	instance system.adapter.energiefluss-erweitert.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2023-12-21 09:48:49.971	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-12-21 09:48:49.959	error	Cannot read properties of undefined (reading 'source')
        2023-12-21 09:48:49.958	error	TypeError: Cannot read properties of undefined (reading 'source') at EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1211:77)
        2023-12-21 09:48:49.955	error	unhandled promise rejection: Cannot read properties of undefined (reading 'source')
        2023-12-21 09:48:49.949	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        host.iobroker
        2023-12-21 09:48:46.857	info	instance system.adapter.energiefluss-erweitert.0 started with pid 2428343
        host.iobroker
        2023-12-21 09:48:16.753	info	Restart adapter system.adapter.energiefluss-erweitert.0 because enabled
        host.iobroker
        2023-12-21 09:48:16.751	error	instance system.adapter.energiefluss-erweitert.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2023-12-21 09:48:16.078	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        2023-12-21 09:48:16.071	error	Cannot read properties of undefined (reading 'source')
        2023-12-21 09:48:16.070	error	TypeError: Cannot read properties of undefined (reading 'source') at EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1211:77)
        2023-12-21 09:48:16.069	error	unhandled promise rejection: Cannot read properties of undefined (reading 'source')
        2023-12-21 09:48:16.064	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        habim adapter ein DP geändert..
        ich habs..passiert wenn du den gleichen DP 2 mal in den Datenquellen aufnimmst unter anderem alias
        • SKB
          SKB Developer Most Active @arteck last edited by
          @arteck Wiso fügst du denn den gleichen DP zweimal hinzu?
          Gut, muß ich wohl anpassen.
          U66 1 Reply Last reply Reply Quote 1
          • U66
            U66 @SKB last edited by U66
            @skb
            Ich hatte heute mal versucht aus einer Webseite ( vis ) etwas in einem Objekt anzeigen zu lassen.
            muss ich da noch etwas Einstellen ?
            Oder wird das so nicht funktionieren.
            mfg Udog
            • SKB
              SKB Developer Most Active @U66 last edited by
              @u66 das ist keine Darstellung, sondern eine Verlinkung auf eine Adresse.
              U66 1 Reply Last reply Reply Quote 0
              • U66
                @skb
                URL öffnen im gleichen Fenster ist dann aber auch Irreführend ?
                Oder ich habs immer noch nicht kappiert.🙄
                • SKB
                  @u66 wieso?
                  Öffnet die Adresse im selben Fenster, statt in einem Overlay Frame.
                  • U66
                    @skb
                    ja jetzt....klappt soweit...stand gerade auf der Leitung
                    Den Link zum Forum konnte ich einbauen
                    Allen besinnliche Feiertage
                    • MichaelF
                      MichaelF last edited by
                      Guten Abend,
                      mir ist leider was doofes passiert. Ich habe ein Shelly Adapter gelöscht und leider im Energiefluss Adapter zwei datenpunkte vergessen zu ändern.
                      Jetzt Startet der Adapter leider nicht mehr, gibt es eine Möglichkeit diese beiden aus der config zu bekommen. Wiederherstellen der Shelly geht leider nicht
                      MichaelF 1 Reply Last reply Reply Quote 0
                      • MichaelF
                        MichaelF @MichaelF last edited by
                        @michaelf said in Test Adapter Energiefluss-erweitert v0.1.x GitHub/Latest:
                        Guten Abend,
                        Erledigt, die neuste Version Installiert und Problem gelöst. Wenn es mal einer sucht 🙂
                        • Elektrofix-OL
                          Elektrofix-OL @SKB last edited by
                          @skb Ich schaffe das irgendwie nicht. ich bekomme einen Fehler "Unknown property 'd'.
                          In css bin ich überhaupt nicht zu hause, mehr als copy/paste schaffe ich nicht.
                          Wärst Du so nett das CSS für Dummis bereitzustellen?
                          • SKB
                            SKB Developer Most Active @Elektrofix-OL last edited by
                            @elektrofix-ol was bitte schaffst Du nicht?
                            Elektrofix-OL 1 Reply Last reply Reply Quote 0
                            • Elektrofix-OL
                              @skb Die Batterie wie im Energieflussadapter zu animieren in Post https://forum.iobroker.net/topic/64734/test-adapter-energiefluss-erweitert-v0-1-x-github-latest/1763 steht zwar eine vermeintliche Anleitung, aber das Funktioniert nicht. Als Datenquelle habe ich den Ladestrom des Akkus angegeben und auch die CSS-Klassen habe ich eingetragen. 7d98a83e-d516-49c7-9b18-6f5f2d2ec438-image.png Bei CSS Stile bekomme ich die Achtungszeichen bef76059-1710-4883-8995-4fb07160a0e8-image.png und mein iPad zeigt keine Animation, weder in Safari noch in Chrome. Selbst beim alten Energieflussadapter funktioniert es nicht mehr, was mache ich falsch?
                              • SKB
                                @elektrofix-ol der Fehler liegt am iPad.
                                IOS animieren diese Dinge nicht.
                                Ganz einfach 🙂
                                C M 2 Replies Last reply Reply Quote 0
                                  c1olli @SKB last edited by
                                  @skb
                                  Dein Adapter ist wirklich klasse. Es hat zwar eine Weile gedauert, aber so langsam tastet man sich an die Funktionen heran.
                                  Kann man das Ganze auch irgendwie live ins Netz stellen?
                                  Eigener Webspace ist vorhanden.
                                  SKB Elektrofix-OL 2 Replies Last reply Reply Quote 0
                                  • SKB
                                    SKB Developer Most Active @c1olli last edited by
                                    @c1olli der Adapter benötigt den Webservice von ioBroker.
                                    Du kannst nur mit einem Reverse-Proxy arbeiten, jedoch dort kann jemand auf die Konfiguration zugreifen.
                                    Dinge von ioBroker zu öffnen bzw. öffentlich zugänglich zu machen, sollte man aufgrund der Sicherheit tunlichst unterlassen.
                                    • Elektrofix-OL
                                      Elektrofix-OL @c1olli last edited by Elektrofix-OL
                                      @c1olli Du kannst eine weiter Admin-instanz einrichten, die du mit Portforwording ins Netz stellst z.B. Port 8082. Du kannst dann die Seite aufrufen mit Deine Adresse und über den Port 8082 vom Netz zugreifen, das mache ich auch so, ABER: SSL und Autentifizierung einschalten und Dein Server sollte Fail2ban haben. Die Instanz sieht bei mir so aus:
                                      Wenn Du Dich angemeldet hat, kannst Du in der Übersicht dann den Engerieflussadapter erreichen.
                                      Den Webservice musst Du dann auch einstellen mit SSL und Authentifizierung.
                                      Homoran SKB 2 Replies Last reply Reply Quote 0
                                        Homoran Global Moderator Administrators @Elektrofix-OL last edited by
                                        @elektrofix-ol Ich halte das für keine gute Idee so etwas allgemeingültig zu empfehlen.
                                        ohne zu wissen welche Skills jeder Lesende mitbringt kann das bei unbedarften Usern richtig in die Hose gehen.
                                        • SKB
                                          @elektrofix-ol ioBroker Admin läuft auf 8081 und der Webserver schon auf 8082.
                                          Außerdem ist diese Lösung nur Benutzern zu empfehlen, die Ahnung davon haben.
                                          Generell ein Port-Fowarding auf einen Dienst ist auch nicht sicher - Reverse Proxy davor läuft besser und sicherer.
                                          C Elektrofix-OL 2 Replies Last reply Reply Quote 1
                                            @skb
                                            Also direkt auf mein Hausnetz zugreifen soll auf keinen Fall passieren.
                                            Schön wäre es die Seite praktisch zu spiegeln und auf dem Webserver laufen zu lassen. So dass eben nur die Werte an den Webserver übergeben werden müssen.
                                            Reverse Proxi sagt mir erst einmal nichts, da werde ich gleich mal googlen.
                                            Aber wenn es so nicht geht ist es auch nicht schlimm, über ioBroker.pro kann ich ja auch zugreifen.
                                            vis
                                            191
                                            4308
                                            5590299
