    4. lametric Adapter müllt Protokoll voll
      Meckii last edited by Meckii
      Eben noch was im Log entdeckt.
      lametric has an invalid jsonConfig: [{"instancePath":"","schemaPath":"#/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"iconPosition"},"message":"must NOT have additional properties"}]
        So nochmal mit dem lametric adapter im debug-modus (hab heute Morgen erst rausgefunden wie das geht)
        2023-12-27 07:38:02.267 - info: host.iobroker stopInstance system.adapter.lametric.0 (force=false, process=true)
        2023-12-27 07:38:02.282 - info: lametric.0 (1109) Got terminate signal TERMINATE_YOURSELF
        2023-12-27 07:38:02.289 - debug: lametric.0 (1109) clearing refresh state timeout
        2023-12-27 07:38:02.291 - debug: lametric.0 (1109) clearing refresh app timeout
        2023-12-27 07:38:02.295 - info: lametric.0 (1109) terminating
        2023-12-27 07:38:02.299 - debug: lametric.0 (1109) Plugin sentry destroyed
        2023-12-27 07:38:02.304 - info: lametric.0 (1109) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-12-27 07:38:02.347 - info: host.iobroker stopInstance system.adapter.lametric.0 send kill signal
        2023-12-27 07:38:02.808 - info: lametric.0 (1109) terminating
        2023-12-27 07:38:02.904 - info: host.iobroker instance system.adapter.lametric.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-12-27 07:38:05.467 - info: host.iobroker instance system.adapter.lametric.0 started with pid 1125
        2023-12-27 07:38:08.899 - debug: lametric.0 (1125) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2023-12-27 07:38:08.969 - debug: lametric.0 (1125) Objects client ready ... initialize now
        2023-12-27 07:38:08.974 - debug: lametric.0 (1125) Objects create System PubSub Client
        2023-12-27 07:38:08.977 - debug: lametric.0 (1125) Objects create User PubSub Client
        2023-12-27 07:38:09.020 - debug: lametric.0 (1125) Objects client initialize lua scripts
        2023-12-27 07:38:09.036 - debug: lametric.0 (1125) Objects connected to redis: 127.0.0.1:9001
        2023-12-27 07:38:09.075 - debug: lametric.0 (1125) Redis States: Use Redis connection: 127.0.0.1:9000
        2023-12-27 07:38:09.092 - debug: lametric.0 (1125) States create System PubSub Client
        2023-12-27 07:38:09.094 - debug: lametric.0 (1125) States create User PubSub Client
        2023-12-27 07:38:09.153 - debug: lametric.0 (1125) States connected to redis: 127.0.0.1:9000
        2023-12-27 07:38:09.224 - debug: lametric.0 (1125) Plugin sentry Initialize Plugin (enabled=true)
        2023-12-27 07:38:10.537 - info: lametric.0 (1125) starting. Version 3.1.1 in /opt/iobroker/node_modules/iobroker.lametric, node: v18.18.2, js-controller: 5.0.16
        2023-12-27 07:38:10.620 - info: lametric.0 (1125) Starting - connecting to http://192.168.7.45:8080
        2023-12-27 07:38:10.624 - debug: lametric.0 (1125) re-creating refresh state timeout
        2023-12-27 07:38:10.629 - debug: lametric.0 (1125) sending "GET" request to "/api/v2/device" with http on port 8080 without data
        2023-12-27 07:38:10.818 - debug: lametric.0 (1125) received 200 response from "http://192.168.7.45:8080/api/v2/device" with content: {"audio":{"available":true,"volume":46,"volume_limit":{"max":100,"min":0},"volume_range":{"max":100,"min":0}},"bluetooth":{"active":false,"address":"14:F5:F9:31:C3:63","available":true,"discoverable":true,"mac":"14:F5:F9:31:C3:63","name":"LM3161","pairable":false},"display":{"brightness":100,"brightness_limit":{"max":100,"min":2},"brightness_mode":"auto","brightness_range":{"max":100,"min":0},"height":8,"on":true,"screensaver":{"enabled":true,"modes":{"time_based":{"enabled":false},"when_dark":{"enabled":true}},"widget":"1_com.lametric.clock"},"type":"mixed","width":37},"id":"62745","mode":"auto","model":"sa8","name":"TIME","os_version":"3.0.21","serial_number":"SA830100316100W00BP9","wifi":{"active":true,"address":"14:F5:F9:30:B4:F3","available":true,"encryption":"WPA","essid":"Laubhaufen","ip":"192.168.7.45","mode":"dhcp","netmask":"255.255.255.0","strength":100}}
        2023-12-27 07:38:10.848 - debug: lametric.0 (1125) API is online
        2023-12-27 07:38:10.856 - debug: lametric.0 (1125) [apps] re-creating refresh timeout
        2023-12-27 07:38:10.857 - debug: lametric.0 (1125) sending "GET" request to "/api/v2/device/apps" with http on port 8080 without data
        2023-12-27 07:38:10.906 - debug: lametric.0 (1125) received 200 response from "http://192.168.7.45:8080/api/v2/device/apps" with content: {"com.lametric.clock":{"actions":{"clock.alarm":{"enabled":{"data_type":"bool","name":"enabled","required":false},"time":{"data_type":"string","format":"[0-9]{2}:[0-9]{2}(?::[0-9]{2})?","name":"time","required":false},"wake_with_radio":{"data_type":"bool","name":"wake_with_radio","required":false}},"clock.clockface":{"icon":{"data_type":"string","name":"icon","required":false},"type":{"data_type":"string","format":"weather|page_a_day|custom|none","name":"type","required":false}},"settings.dateFormats":{}},"package":"com.lametric.clock","title":"Clock","triggers":{"alarm":{"snooze":{"data_type":"bool","name":"snooze"}}},"vendor":"LaMetric","version":"2.8.3","version_code":"44","widgets":{"1_com.lametric.clock":{"index":0,"package":"com.lametric.clock","settings":{"_title":"Uhr"},"visible":false}}},"com.lametric.countdown":{"actions":{"countdown.configure":{"duration":{"data_type":"int","name":"duration","required":false},"start_now":{"data_type":"bool","name":"start_now","required":false}},"countdown.pause":{},"countdown.reset":{},"countdown.start":{}},"package":"com.lametric.countdown","title":"Timer","triggers":{"finished":{"duration":{"data_type":"int","name":"duration"}},"paused":{"duration":{"data_type":"int","name":"duration"}},"reset":{"duration":{"data_type":"int","name":"duration"}},"resumed":{"duration":{"data_type":"int","name":"duration"}},"started":{"duration":{"data_type":"int","name":"duration"}}},"vendor":"LaMetric","version":"1.2.1","version_code":"19","widgets":{"6_com.lametric.countdown":{"index":6,"package":"com.lametric.countdown","settings":{"_title":"Timer"},"visible":false}}},"com.lametric.custommessage":{"package":"com.lametric.custommessage","title":"Message Board","triggers":{},"vendor":"LaMetric","version":"1.2.8","version_code":"28","widgets":{"3_com.lametric.custommessage":{"index":3,"package":"com.lametric.custommessage","settings":{"_title":"Message Board"},"visible":false}}},"com.lametric.diy.devwidget":{"actions":{"status":{}},"package":"com.lametric.diy.devwidget","title":"My Data DIY","triggers":{},"vendor":"LaMetric","version":"2.0.2","version_code":"48","widgets":{"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx":{"index":2,"package":"com.lametric.diy.devwidget","settings":{"_title":"My Data DIY"},"visible":false}}},"com.lametric.radio":{"actions":{"radio.next":{},"radio.play":{},"radio.play.at":{"idx":{"data_type":"int","name":"idx","required":false}},"radio.prev":{},"radio.state":{},"radio.stop":{}},"package":"com.lametric.radio","title":"Radio","triggers":{},"vendor":"LaMetric","version":"1.4.20","version_code":"74","widgets":{"4_com.lametric.radio":{"index":4,"package":"com.lametric.radio","settings":{"_title":"Radio"},"visible":false}}},"com.lametric.stopwatch":{"actions":{"stopwatch.pause":{},"stopwatch.reset":{},"stopwatch.start":{}},"package":"com.lametric.stopwatch","title":"Stopwatch","triggers":{},"vendor":"LaMetric","version":"1.2.0","version_code":"16","widgets":{"5_com.lametric.stopwatch":{"index":5,"package":"com.lametric.stopwatch","settings":{"_title":"Stopwatch"},"visible":false}}},"com.lametric.weather":{"actions":{"weather.forecast":{},"weather.get.cc":{},"weather.setProduct":{}},"package":"com.lametric.weather","title":"Weather","triggers":{},"vendor":"LaMetric","version":"1.2.2","version_code":"32","widgets":{"2_com.lametric.weather":{"index":1,"package":"com.lametric.weather","settings":{"_title":"Wetter"},"visible":true}}}}
        2023-12-27 07:38:10.933 - debug: lametric.0 (1125) [apps] found (keep): apps.1_com_lametric.clock
        2023-12-27 07:38:11.044 - debug: lametric.0 (1125) [apps] found (keep): apps.6_com_lametric.countdown
        2023-12-27 07:38:11.099 - debug: lametric.0 (1125) [apps] found (keep): apps.3_com_lametric.custommessage
        2023-12-27 07:38:11.144 - debug: lametric.0 (1125) [apps] found (keep): apps.xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
        2023-12-27 07:38:11.145 - debug: lametric.0 (1125) [mydatadiy] found app widget with uuid "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
        2023-12-27 07:38:11.279 - debug: lametric.0 (1125) [apps] found (keep): apps.4_com_lametric.radio
        2023-12-27 07:38:11.343 - debug: lametric.0 (1125) [apps] found (keep): apps.5_com_lametric.stopwatch
        2023-12-27 07:38:11.394 - debug: lametric.0 (1125) [apps] found (keep): apps.2_com_lametric.weather
        2023-12-27 07:38:11.504 - warn: lametric.0 (1125) (device) Unable to execute action: TypeError: Cannot read properties of undefined (reading 'active')
        2023-12-27 07:38:11.507 - debug: lametric.0 (1125) [mydatadiy] collecting states
        2023-12-27 07:38:11.508 - debug: lametric.0 (1125) [mydatadiy] found 0 dynamic states: []
        2023-12-27 07:38:11.510 - debug: lametric.0 (1125) [mydatadiy] found foreign states: []
        2023-12-27 07:38:11.511 - debug: lametric.0 (1125) [mydatadiy] refresh output state with config: [{"icon":"3983","text":"Meckii","hideif":"","duration":5},{"icon":"2867","text":"Lina","hideif":"","duration":5},{"icon":"7756","text":"Paul","hideif":"","duration":5}]
        2023-12-27 07:38:11.513 - debug: lametric.0 (1125) [mydatadiy] completed - frame update to [{"text":"Meckii","duration":5000,"icon":"3983"},{"text":"Lina","duration":5000,"icon":"2867"},{"text":"Paul","duration":5000,"icon":"7756"}]
        2023-12-27 07:38:11.541 - debug: lametric.0 (1125) [mydatadiy] pusing changes to device - app xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
        2023-12-27 07:38:11.543 - debug: lametric.0 (1125) sending "POST" request to "/api/v2/widget/update/com.lametric.diy.devwidget/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" with http on port 8080 with data: {"frames":[{"text":"Meckii","duration":5000,"icon":"3983"},{"text":"Lina","duration":5000,"icon":"2867"},{"text":"Paul","duration":5000,"icon":"7756"}]}
        2023-12-27 07:38:11.720 - debug: lametric.0 (1125) API is offline
        2023-12-27 07:38:11.750 - debug: lametric.0 (1125) received 200 response from "http://192.168.7.45:8080/api/v2/widget/update/com.lametric.diy.devwidget/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" with content: ""
          Thomas Braun Most Active @Meckii last edited by
          @meckii
          Warum zieht die Kiste denn hier eine alte nodejs ran?
            Meckii @Thomas Braun last edited by Meckii
            Oh das kann sein.
            Ich glaube ich habe bei dier vielen Rumprobiererrei den Log mit einem anderen Raspberry mit einem 32bit system gemacht. Ich wollte das 32/64 Bit ausschließen...
            Also das war dann Bullseye 32bit das erste Bookworm 64bit...
              Inzwischen gibt es einen issue bei github...
              https://github.com/klein0r/ioBroker.lametric/issues/169
              Meckiilino created this issue in klein0r/ioBroker.lametric
              closed Cannot read properties of undefined (reading 'active') #169
              • haus-automatisierung
                haus-automatisierung Developer Most Active @Meckii last edited by
                @meckii Danke, ist gelöst ab 3.1.2 - lag daran, dass die 2022er Modelle über die API scheinbar kein bluetooth low energy status ausliefern. Bitte schauen, ob Du die aktuellste Firmware 3.0.21 installiert hast (gibts erst ein paar Tage). Da sind wohl auch einige Bugfixes enthalten.
                  Meckii @haus-automatisierung last edited by
                  Die Version 3.0.21 gibt es schon und wurde bereits am 24.12.23 installiert.
                  (Habe die Lametric von meiner Frau bekommen)
                  Vielen Dank den lametric Adapter habe ich bereits über github installiert - beim starten wird er nun grün und der Fehler ist weg...
                  haus-automatisierung 1 Reply Last reply Reply Quote 1
                    @meckii Bitte nie über GitHub installieren. Lieber über npm wenn Du die letzte klar definiere Version haben möchtest.
                      Da war der Adapter in der heute von dir angepassten Version aber noch nicht verfügber...Screenshot 2023-12-27 145800.png
                        haus-automatisierung Developer Most Active @Meckii last edited by haus-automatisierung
                        @meckii Klar, der liegt seit heute morgen auf npm
                          Habe es jetzt wieder aus npm installiert - vielen Dank fürs fixen und die Tipps!
                          735
