    4. Keinerlei Adaperupdates seit Monaten
      Thomas Braun Most Active @alexzi last edited by
      @alexzi
      Zeig mal die Langfassung von
      iob diag
        alexzi @Thomas Braun last edited by
        @Homoran
        strange, beim ersten iob diag kam nicht wirklich was, evtl. hatte ich mich verschrieben und nicht gesehen 🙈 dann kam der Fehler beim iob update
        hier der volle Output von iob diag
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: SYS-Server-Raspi4
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.103-v8+
              Architecture: arm64
        Model		: Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : armhf
        Systemuptime and Load:
         15:50:59 up  4:12,  2 users,  load average: 5.40, 5.92, 5.82
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Wed 2023-12-27 15:50:59 CET
                   Universal time: Wed 2023-12-27 14:50:59 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin docker gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server: 	true
        Desktop: 	LXDE-pi
        Terminal: 	x11
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:           7.8G        1.5G        114M         97M        6.2G        6.1G
        Swap:           99M         21M         78M
        Total:         7.9G        1.5G        193M
                 7813 M total memory
                 1481 M used memory
                  794 M active memory
                 5850 M inactive memory
                  114 M free memory
                  493 M buffer memory
                 5724 M swap cache
                   99 M total swap
                   21 M used swap
                   78 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4      117G   70G   41G  63% /
        devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
        tmpfs          tmpfs     3.9G   11M  3.9G   1% /dev/shm
        tmpfs          tmpfs     3.9G  9.7M  3.9G   1% /run
        tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     782M  4.0K  782M   1% /run/user/1000
        /dev/sda1      ext4      458G   70M  435G   1% /media/pi/792af2c5-30c9-445e-ab6e-cb506092c413
        /dev/sdb2      ext4      117G   16G   96G  14% /tmp/tmp.mMEpdvkZaF
        [Wed Dec 27 11:38:22 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=DC:A6:32:FA:33:E0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=64538962-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Wed Dec 27 11:38:23 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Wed Dec 27 11:38:23 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Wed Dec 27 11:38:25 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        [Wed Dec 27 11:38:44 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: errors=remount-ro
        [Wed Dec 27 12:17:51 2023] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null)
        TARGET                                           SOURCE         FSTYPE          OPTIONS
        /                                                /dev/mmcblk0p2 ext4            rw,noatime
        |-/sys/fs/bpf                                    none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
        |-/run/user/1000/gvfs                            gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        |-/boot                                          /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        |-/tmp/tmp.mMEpdvkZaF                            /dev/sdb2      ext4            rw,relatime
        |-/tmp/tmp.CY9tyJdyoV                            /dev/mmcblk0p2 ext4            rw,relatime
        `-/media/pi/792af2c5-30c9-445e-ab6e-cb506092c413 /dev/sda1      ext4            rw,nosuid,nodev,relatime,errors=remount-ro
        /var:
        1.3G	/var/
        716M	/var/lib
        417M	/var/lib/docker
        415M	/var/lib/docker/overlay2
        310M	/var/lib/docker/overlay2/9a19718ad57ef0af959ba0272376648d9dab28c6da97bab8013bb20f26fad944/diff
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        41G	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        2.2G	/opt/iobroker/iobroker-data/
        1.9G	/opt/iobroker/iobroker-data/history
        233M	/opt/iobroker/iobroker-data/files
        72M	/opt/iobroker/iobroker-data/files/telegram.admin
        52M	/opt/iobroker/iobroker-data/backup-objects
        15M	/opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
        8.9M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
        7.5M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.2afdfa2c.chunk.js.map
        7.2M	/opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
        7.0M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.5d4fbf6a.chunk.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.17.1
        /usr/bin/node 		v18.17.1
        /usr/bin/npm 		9.6.7
        /usr/bin/npx 		9.6.7
        /usr/bin/corepack 	0.18.0
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! invalid: @types/node@14.18.33 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-27T14_51_13_908Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	4.0.24
        admin: 		6.3.5
        javascript: 	6.1.4
        Adapters from github: 	0
        Adapter State
        + system.adapter.admin.0                  : admin                 : SYS-Server-Raspi4                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : SYS-Server-Raspi4                        -  enabled
        + system.adapter.backitup.0               : backitup              : SYS-Server-Raspi4                        -  enabled
        + system.adapter.bring.0                  : bring                 : SYS-Server-Raspi4                        -  enabled
          system.adapter.daswetter.0              : daswetter             : SYS-Server-Raspi4                        - disabled
        + system.adapter.discovery.0              : discovery             : SYS-Server-Raspi4                        -  enabled
        + system.adapter.harmony.0                : harmony               : SYS-Server-Raspi4                        -  enabled
        + system.adapter.history.0                : history               : SYS-Server-Raspi4                        -  enabled
          system.adapter.homeconnect.0            : homeconnect           : SYS-Server-Raspi4                        - disabled
        + system.adapter.info.0                   : info                  : SYS-Server-Raspi4                        -  enabled
        + system.adapter.jarvis.0                 : jarvis                : SYS-Server-Raspi4                        -  enabled
        + system.adapter.javascript.0             : javascript            : SYS-Server-Raspi4                        -  enabled
          system.adapter.meross.0                 : meross                : SYS-Server-Raspi4                        - disabled
        + system.adapter.pi-hole.0                : pi-hole               : SYS-Server-Raspi4                        -  enabled
        + system.adapter.scenes.0                 : scenes                : SYS-Server-Raspi4                        -  enabled
        + system.adapter.shelly.0                 : shelly                : SYS-Server-Raspi4                        -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.smartcontrol.0           : smartcontrol          : SYS-Server-Raspi4                        -  enabled
          system.adapter.telegram.0               : telegram              : SYS-Server-Raspi4                        - disabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : SYS-Server-Raspi4                        -  enabled
          system.adapter.vis.0                    : vis                   : SYS-Server-Raspi4                        -  enabled
        + system.adapter.web.0                    : web                   : SYS-Server-Raspi4                        -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : SYS-Server-Raspi4                        -  enabled
        + system.adapter.yahka.0                  : yahka                 : SYS-Server-Raspi4                        -  enabled
        + system.adapter.zigbee.0                 : zigbee                : SYS-Server-Raspi4                        -  enabled, port: /dev/ttyUSB0
        + instance is alive
        ioBroker-Repositories
        List is empty
        Installed ioBroker-Instances
        Error: Object "system.repositories" not found
        Objects and States
        Objects: 	10043
        States: 	9057
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Hit:3 https://download.docker.com/linux/raspbian buster InRelease
        Hit:4 https://download.mono-project.com/repo/debian stable-raspbianbuster InRelease
        Hit:5 https://deb.nodesource.com/node_18.x buster InRelease
        Reading package lists...
        E: Broken packages
        Pending Updates:
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:33341           0.0.0.0:*               LISTEN      1001       880431     10196/io.yahka.0
        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          27357      1499/smbd
        tcp        0      0 127.0.0.1:45825         0.0.0.0:*               LISTEN      1001       880462     10196/io.yahka.0
        tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          21773      -
        tcp        0      0 127.0.0.1:33763         0.0.0.0:*               LISTEN      1001       880472     10196/io.yahka.0
        tcp        0      0 0.0.0.0:43845           0.0.0.0:*               LISTEN      0          20824      599/rpc.mountd
        tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        30097      590/pihole-FTL
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       867170     8836/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       867163     8836/iobroker.js-co
        tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      116        22872      663/mysqld
        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          27358      1499/smbd
        tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          19417      550/vncserver-x11-c
        tcp        0      0 0.0.0.0:52941           0.0.0.0:*               LISTEN      0          20816      599/rpc.mountd
        tcp        0      0 0.0.0.0:34671           0.0.0.0:*               LISTEN      0          21782      -
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10388      1/init
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       871998     9634/io.jarvis.0
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          21150      682/lighttpd
        tcp        0      0 127.0.0.1:38481         0.0.0.0:*               LISTEN      1001       880467     10196/io.yahka.0
        tcp        0      0 0.0.0.0:47761           0.0.0.0:*               LISTEN      0          20832      599/rpc.mountd
        tcp        0      0 0.0.0.0:35603           0.0.0.0:*               LISTEN      1001       880434     10196/io.yahka.0
        tcp        0      0 0.0.0.0:34517           0.0.0.0:*               LISTEN      1001       880428     10196/io.yahka.0
        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        30091      590/pihole-FTL
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21705      571/sshd
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          28667      1820/cupsd
        tcp6       0      0 :::3389                 :::*                    LISTEN      115        23642      651/xrdp
        tcp6       0      0 :::59709                :::*                    LISTEN      0          20820      599/rpc.mountd
        tcp6       0      0 :::445                  :::*                    LISTEN      0          27355      1499/smbd
        tcp6       0      0 :::2049                 :::*                    LISTEN      0          18803      -
        tcp6       0      0 :::58181                :::*                    LISTEN      998        33414      1699/homebridge
        tcp6       0      0 :::8581                 :::*                    LISTEN      998        30791      1025/hb-service
        tcp6       0      0 :::61991                :::*                    LISTEN      1001       875433     9859/io.harmony.0
        tcp6       0      0 ::1:4711                :::*                    LISTEN      999        30098      590/pihole-FTL
        tcp6       0      0 :::47433                :::*                    LISTEN      0          18667      599/rpc.mountd
        tcp6       0      0 :::139                  :::*                    LISTEN      0          27356      1499/smbd
        tcp6       0      0 :::5900                 :::*                    LISTEN      0          19416      550/vncserver-x11-c
        tcp6       0      0 :::111                  :::*                    LISTEN      0          10182      1/init
        tcp6       0      0 :::51376                :::*                    LISTEN      998        33081      1699/homebridge
        tcp6       0      0 :::8080                 :::*                    LISTEN      0          28229      1312/node /home/Shi
        tcp6       0      0 :::80                   :::*                    LISTEN      0          21151      682/lighttpd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       865126     9117/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       871839     9615/io.web.0
        tcp6       0      0 :::41235                :::*                    LISTEN      998        33101      1699/homebridge
        tcp6       0      0 :::34355                :::*                    LISTEN      0          21784      -
        tcp6       0      0 :::53                   :::*                    LISTEN      999        30093      590/pihole-FTL
        tcp6       0      0 :::45461                :::*                    LISTEN      0          20828      599/rpc.mountd
        tcp6       0      0 ::1:3350                :::*                    LISTEN      0          20850      591/xrdp-sesman
        tcp6       0      0 :::22                   :::*                    LISTEN      0          21715      571/sshd
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          28666      1820/cupsd
        tcp6       0      0 :::57272                :::*                    LISTEN      998        31441      1699/homebridge
        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       875434     9859/io.harmony.0
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          31849      1821/cups-browsed
        udp        0      0 0.0.0.0:37984           0.0.0.0:*                           0          20830      599/rpc.mountd
        udp        0      0 10.100.200.1:5353       0.0.0.0:*                           1001       873134     9300/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           998        33102      1699/homebridge
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           998        33082      1699/homebridge
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           998        30788      1025/hb-service
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17749      419/avahi-daemon: r
        udp        0      0 0.0.0.0:50642           0.0.0.0:*                           0          20814      599/rpc.mountd
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       869574     9562/io.shelly.0
        udp        0      0 0.0.0.0:54839           0.0.0.0:*                           0          21781      -
        udp        0      0 0.0.0.0:46775           0.0.0.0:*                           0          20822      599/rpc.mountd
        udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          21066      -
        udp        0      0 0.0.0.0:48411           0.0.0.0:*                           108        17751      419/avahi-daemon: r
        udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        30090      590/pihole-FTL
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          22856      467/dhcpcd
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11275      1/init
        udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          29120      540/nmbd
        udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          29119      540/nmbd
        udp        0      0 10.100.200.255:137      0.0.0.0:*                           0          29116      540/nmbd
        udp        0      0 10.100.200.1:137        0.0.0.0:*                           0          29115      540/nmbd
        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          19404      540/nmbd
        udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          29122      540/nmbd
        udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          29121      540/nmbd
        udp        0      0 10.100.200.255:138      0.0.0.0:*                           0          29118      540/nmbd
        udp        0      0 10.100.200.1:138        0.0.0.0:*                           0          29117      540/nmbd
        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          19405      540/nmbd
        udp6       0      0 :::546                  :::*                                0          22892      467/dhcpcd
        udp6       0      0 :::37625                :::*                                108        17752      419/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        17750      419/avahi-daemon: r
        udp6       0      0 :::46883                :::*                                0          18665      599/rpc.mountd
        udp6       0      0 :::2049                 :::*                                0          18804      -
        udp6       0      0 :::55946                :::*                                0          20826      599/rpc.mountd
        udp6       0      0 :::44573                :::*                                0          21783      -
        udp6       0      0 :::44931                :::*                                0          20818      599/rpc.mountd
        udp6       0      0 :::53                   :::*                                999        30092      590/pihole-FTL
        udp6       0      0 :::111                  :::*                                0          11278      1/init
        2023-12-27 15:44:23.458  - info: yahka.0 (10196) adding Maurice-Stehlampe-TV with UUID: 9a024b0a-3b72-476e-9703-1562fd95b928
        2023-12-27 15:44:23.463  - info: yahka.0 (10196) adding Maurice-Stehlampe-TV-oben with UUID: bd093dc5-d30a-4ea6-9423-2c9cb8d23107
        2023-12-27 15:44:23.475  - info: yahka.0 (10196) adding Maurice-Stehlampe-TV-unten with UUID: cd87fb94-2c88-410b-bc09-bc9e267e2c9a
        2023-12-27 15:44:23.485  - info: yahka.0 (10196) adding Außenbereich-Bewegungsmelder with UUID: 8db7716d-cf91-48aa-b28a-7dbad46dd014
        2023-12-27 15:44:23.487  - info: yahka.0 (10196) publishing bridge ioBrokerPi4 on 10.100.200.1 using avahi
        2023-12-27 15:44:23.604  - info: yahka.0 (10196) publishing camera Terrasse-Lounge-Kamera on 10.100.200.1 using avahi
        2023-12-27 15:44:23.634  - info: yahka.0 (10196) publishing camera Hof-Haustuer-Kamera on 10.100.200.1 using avahi
        2023-12-27 15:44:26.079  - info: smartcontrol.0 (10281) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.smartcontrol, node: v18.17.1, js-controller: 4.0.24
        2023-12-27 15:44:27.355  - info: pi-hole.0 (10516) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.pi-hole, node: v18.17.1, js-controller: 4.0.24
        2023-12-27 15:44:27.448  - info: harmony.0 (9859) [DISCOVER] Discovered Wohnzimmer (10.100.200.74) and will try to connect
        2023-12-27 15:44:27.822  - info: harmony.0 (9859) [CONNECT] Connecting to Wohnzimmer (10.100.200.74)
        2023-12-27 15:44:29.190  - info: harmony.0 (9859) [CONNECT] Connected to Wohnzimmer (10.100.200.74)
        2023-12-27 15:44:30.051  - info: harmony.0 (9859) [PROCESS] Synced hub config for Wohnzimmer (10.100.200.74)
        2023-12-27 15:44:32.731  - info: bring.0 (10677) starting. Version 1.8.1 in /opt/iobroker/node_modules/iobroker.bring, node: v18.17.1, js-controller: 4.0.24
        2023-12-27 15:44:33.196  - info: vis.0 (10758) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.17.1, js-controller: 4.0.24
        2023-12-27 15:44:33.292  - info: smartcontrol.0 (10281) Adapter admin configuration successfully validated...
        2023-12-27 15:44:33.862  - info: vis.0 (10758) vis license is OK.
        2023-12-27 15:44:33.980  - info: bring.0 (10677) [LOGIN] Successfully logged in as Ali
        2023-12-27 15:44:34.865  - info: vis.0 (10758) Terminated (NO_ERROR): Without reason
        2023-12-27 15:44:35.592  - info: host.SYS-Server-Raspi4 instance system.adapter.vis.0 terminated while should be started once
        2023-12-27 15:44:35.816  - info: smartcontrol.0 (10281) Subscribing to all target devices and trigger states. 4 trigger schedules activated...
        2023-12-27 15:44:38.612  - info: alexa2.0 (9212) Subscribing to states...
        2023-12-27 15:44:38.622  - info: alexa2.0 (9212) Deleting the following states: ["Smart-Home-Devices.9f4e9ab6-8817-4fc0-837c-080303c57239","Smart-Home-Devices.3b42e75f-f188-487d-978b-4b716e9f3647","Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices","Smart-Home-Devices.9f4e9ab6-8817-4fc0-837c-080303c57239.#enabled","Smart-Home-Devices.9f4e9ab6-8817-4fc0-837c-080303c57239.#delete","Smart-Home-Devices.3b42e75f-f188-487d-978b-4b716e9f3647.#enabled","Smart-Home-Devices.3b42e75f-f188-487d-978b-4b716e9f3647.#delete"]
        2023-12-27 15:44:40.302  - info: alexa2.0 (9212) Alexa-Push-Connection (macDms = true) established. Disable Polling
        2023-12-27 15:44:44.730  - info: alexa2.0 (9212) Initialization Done ...
        			v.2023-10-10
                 Icon name: computer
              Architecture: arm64
        Installation: 		native
        Kernel: 		aarch64
        Userland: 		armhf
        Timezone: 		Europe/Berlin (CET, +0100)
        User-ID: 		1000
        X-Server: 		true
        Pending OS-Updates:
        Pending iob updates: 	0
        Nodejs-Installation: 	/usr/bin/nodejs 	v18.17.1
        			/usr/bin/npm 		9.6.7
        			/usr/bin/npx 		9.6.7
        Recommended versions are nodejs 16.20.2 and npm 8.19.4
        MEMORY:
        Mem:           7.8G        1.4G        486M         80M        5.9G        6.2G
        Swap:           99M         21M         78M
        Total:         7.9G        1.4G        565M
        Active iob-Instances: 	20
        List is empty
        ioBroker Core: 		js-controller 		4.0.24
        			admin 			6.3.5
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Objects: 		10043
        States: 		9057
        Size of iob-Database:
        6.5M	/opt/iobroker/iobroker-data/objects.json.migrated
        6.5M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
        6.4M	/opt/iobroker/iobroker-data/objects.jsonl
        4.0K	/opt/iobroker/iobroker-data/objects.json.old
        3.1M	/opt/iobroker/iobroker-data/states.jsonl
        1.5M	/opt/iobroker/iobroker-data/states.json.old
        1.5M	/opt/iobroker/iobroker-data/states.json.migrated
        1.5M	/opt/iobroker/iobroker-data/states.json.bak.migrated
        0	/opt/iobroker/iobroker-data/states.json.broken
        Homoran Glasfaser 3 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @alexzi last edited by
          @alexzi sagte in Keinerlei Adaperupdates seit Monaten:
          Deswegen immer alles zeigen!
          Auch die Eingabezeile
            viel zu hoch!
            viel zu alt
            Terminal: x11
            vollkommen unnötig auf einem Server
            /usr/bin/npm 9.6.7
            auch nicht aktuell
            • Glasfaser
              Glasfaser @alexzi last edited by
              List is empty
              Dazu
              iob stop
              iob setup first
              der Rest zum ( alten ) System von dir , wurde schon oben genannt .
                alexzi @Homoran last edited by
                nach apt full upgrade und reboot sehen die uptime infos zumindest besser aus, ob das gut genug ist kann ich nicht beurteilen. Hatte auch noch den SD-Kopierer laufen, evtl. hat der die hohen Werte mit beeinflusst.
                hier nochmal der Output von iob diag
                wenn das OS viel zu alt ist, Empfehlung? Upgrade von Buster auf 'Name habe ich vergessen' ist ja nicht empfohlen, werde wohl um Neuanfang mit neuem OS nicht rum kommen
                ja, X11 mag unnötig sein, aber ein paar Kleinigkeiten mache ich lieber über die GUI, bin nicht der CLI-Profi, wobei ohne ja eh nichts geht 🙈
                Wie kann ich das umstellen, dass er Boot Target CLI hat?
                wenn ich nodejs mit iob nodejs-update aktualisieren will, zeigt er nichts neueres an.
                ufffff, ich bin echt für jede Hilfe dankbar, egal was ich versuche, nur Probleme, Layer 8. 😢
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : armhf
                 16:36:31 up 16 min,  3 users,  load average: 0.33, 0.46, 0.63
                CPU threads: 4
                Current issues:
                               Local time: Wed 2023-12-27 16:36:31 CET
                           Universal time: Wed 2023-12-27 15:36:31 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       true
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:           7.8G        1.4G        5.0G         59M        1.5G        6.3G
                Swap:           99M          0B         99M
                Total:         7.9G        1.4G        5.1G
                         7813 M total memory
                         1355 M used memory
                          467 M active memory
                         1851 M inactive memory
                         4972 M free memory
                          176 M buffer memory
                         1307 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /dev/root      ext4      117G   70G   42G  63% /
                tmpfs          tmpfs     3.9G  4.5M  3.9G   1% /dev/shm
                tmpfs          tmpfs     3.9G  9.6M  3.9G   1% /run
                [Wed Dec 27 16:19:54 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=DC:A6:32:FA:33:E0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=64538962-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                [Wed Dec 27 16:19:55 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                [Wed Dec 27 16:19:55 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                [Wed Dec 27 16:19:56 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                [Wed Dec 27 16:19:56 2023] EXT4-fs (mmcblk0p2): 4 orphan inodes deleted
                [Wed Dec 27 16:19:56 2023] EXT4-fs (mmcblk0p2): recovery complete
                [Wed Dec 27 16:19:56 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                [Wed Dec 27 16:19:56 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Wed Dec 27 16:19:58 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                `-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                1.2G    /var/
                717M    /var/lib
                7.4M    /opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                /usr/bin/npm            9.6.7
                /usr/bin/npx            9.6.7
                nodejs:
                  Version table:
                Errors in npm tree:
                npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-27T15_36_45_002Z-debug-0.log
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.3.5
                javascript:     6.1.4
                Adapter State
                + instance is alive
                List is empty
                Objects and States
                Objects:        10043
                States:         9057
                Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                Pending Updates: 0
                tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      116        21257      664/mysqld
                tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          26864      1260/smbd
                tcp        0      0 0.0.0.0:40395           0.0.0.0:*               LISTEN      0          20705      599/rpc.mountd
                tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          20288      542/vncserver-x11-c
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11699      1/init
                tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       33071      2219/io.jarvis.0
                tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          20875      669/lighttpd
                tcp        0      0 127.0.0.1:35025         0.0.0.0:*               LISTEN      1001       33416      2593/io.yahka.0
                tcp        0      0 0.0.0.0:39441           0.0.0.0:*               LISTEN      0          18404      599/rpc.mountd
                tcp        0      0 0.0.0.0:45491           0.0.0.0:*               LISTEN      1001       31731      2593/io.yahka.0
                tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        26817      582/pihole-FTL
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21594      600/sshd
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17014      423/cupsd
                tcp        0      0 0.0.0.0:43961           0.0.0.0:*               LISTEN      1001       31729      2593/io.yahka.0
                tcp        0      0 127.0.0.1:39035         0.0.0.0:*               LISTEN      1001       33411      2593/io.yahka.0
                tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          26863      1260/smbd
                tcp        0      0 0.0.0.0:52031           0.0.0.0:*               LISTEN      0          17164      599/rpc.mountd
                tcp        0      0 0.0.0.0:44673           0.0.0.0:*               LISTEN      0          17404      -
                tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          17397      -
                tcp        0      0 127.0.0.1:41605         0.0.0.0:*               LISTEN      1001       34164      2593/io.yahka.0
                tcp        0      0 0.0.0.0:39109           0.0.0.0:*               LISTEN      1001       31727      2593/io.yahka.0
                tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        26823      582/pihole-FTL
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       29006      541/iobroker.js-con
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       28232      541/iobroker.js-con
                tcp6       0      0 :::37035                :::*                    LISTEN      0          17406      -
                tcp6       0      0 :::35819                :::*                    LISTEN      0          20695      599/rpc.mountd
                tcp6       0      0 :::139                  :::*                    LISTEN      0          26862      1260/smbd
                tcp6       0      0 :::5900                 :::*                    LISTEN      0          20287      542/vncserver-x11-c
                tcp6       0      0 :::111                  :::*                    LISTEN      0          8983       1/init
                tcp6       0      0 :::51376                :::*                    LISTEN      998        27232      1650/homebridge
                tcp6       0      0 :::8080                 :::*                    LISTEN      0          27008      1266/node /home/Shi
                tcp6       0      0 :::80                   :::*                    LISTEN      0          20876      669/lighttpd
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26583      1557/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30154      2204/io.web.0
                tcp6       0      0 :::53                   :::*                    LISTEN      999        26819      582/pihole-FTL
                tcp6       0      0 :::22                   :::*                    LISTEN      0          21596      600/sshd
                tcp6       0      0 ::1:3350                :::*                    LISTEN      0          20685      581/xrdp-sesman
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17013      423/cupsd
                tcp6       0      0 :::57272                :::*                    LISTEN      998        30952      1650/homebridge
                tcp6       0      0 :::35613                :::*                    LISTEN      998        27237      1650/homebridge
                tcp6       0      0 :::3389                 :::*                    LISTEN      115        23747      602/xrdp
                tcp6       0      0 :::445                  :::*                    LISTEN      0          26054      1260/smbd
                tcp6       0      0 :::2049                 :::*                    LISTEN      0          17401      -
                tcp6       0      0 :::58181                :::*                    LISTEN      998        31200      1650/homebridge
                tcp6       0      0 :::8581                 :::*                    LISTEN      998        29229      1009/hb-service
                tcp6       0      0 :::61991                :::*                    LISTEN      1001       32370      2441/io.harmony.0
                tcp6       0      0 ::1:4711                :::*                    LISTEN      999        26824      582/pihole-FTL
                tcp6       0      0 :::38759                :::*                    LISTEN      0          20711      599/rpc.mountd
                tcp6       0      0 :::54697                :::*                    LISTEN      0          17168      599/rpc.mountd
                udp        0      0 0.0.0.0:2049            0.0.0.0:*                           0          17400      -
                udp        0      0 0.0.0.0:38990           0.0.0.0:*                           0          17403      -
                udp        0      0 0.0.0.0:56151           0.0.0.0:*                           108        18833      426/avahi-daemon: r
                udp        0      0 0.0.0.0:48823           0.0.0.0:*                           0          20698      599/rpc.mountd
                udp        0      0 0.0.0.0:40652           0.0.0.0:*                           0          18402      599/rpc.mountd
                udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        26816      582/pihole-FTL
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          23758      485/dhcpcd
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11700      1/init
                udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          26763      543/nmbd
                udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          26762      543/nmbd
                udp        0      0 10.100.200.255:137      0.0.0.0:*                           0          26759      543/nmbd
                udp        0      0 10.100.200.1:137        0.0.0.0:*                           0          26758      543/nmbd
                udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          22884      543/nmbd
                udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          26765      543/nmbd
                udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          26764      543/nmbd
                udp        0      0 10.100.200.255:138      0.0.0.0:*                           0          26761      543/nmbd
                udp        0      0 10.100.200.1:138        0.0.0.0:*                           0          26760      543/nmbd
                udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          22885      543/nmbd
                udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       32371      2441/io.harmony.0
                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          20186      546/cups-browsed
                udp        0      0 0.0.0.0:42050           0.0.0.0:*                           0          17170      599/rpc.mountd
                udp        0      0 10.100.200.1:5353       0.0.0.0:*                           1001       34145      1877/io.tr-064.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           998        27238      1650/homebridge
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           998        27233      1650/homebridge
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           998        28407      1009/hb-service
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        18831      426/avahi-daemon: r
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       31317      2122/io.shelly.0
                udp6       0      0 :::2049                 :::*                                0          17402      -
                udp6       0      0 :::60723                :::*                                0          20708      599/rpc.mountd
                udp6       0      0 :::53                   :::*                                999        26818      582/pihole-FTL
                udp6       0      0 :::111                  :::*                                0          8986       1/init
                udp6       0      0 :::33280                :::*                                0          17166      599/rpc.mountd
                udp6       0      0 :::546                  :::*                                0          21416      485/dhcpcd
                udp6       0      0 :::41984                :::*                                0          20693      599/rpc.mountd
                udp6       0      0 :::33820                :::*                                108        18834      426/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                108        18832      426/avahi-daemon: r
                udp6       0      0 :::58941                :::*                                0          17405      -
                2023-12-27 16:21:32.991  - info: yahka.0 (2593) publishing bridge ioBrokerPi4 on 10.100.200.1 using avahi
                2023-12-27 16:21:33.081  - info: yahka.0 (2593) publishing camera Terrasse-Lounge-Kamera on 10.100.200.1 using avahi
                2023-12-27 16:21:33.103  - info: yahka.0 (2593) publishing camera Hof-Haustuer-Kamera on 10.100.200.1 using avahi
                2023-12-27 16:21:33.275  - warn: zigbee.0 (1866) DeviceAvailability:Failed to ping 0x60a423fffead7944 TS0121
                2023-12-27 16:21:34.890  - warn: zigbee.0 (1866) DeviceAvailability:Failed to ping 0x60a423fffef8e119 TS0121
                2023-12-27 16:21:35.974  - info: smartcontrol.0 (2739) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.smartcontrol, node: v18.17.1, js-controller: 4.0.24
                2023-12-27 16:21:36.888  - info: host.SYS-Server-Raspi4 instance system.adapter.bring.0 started with pid 3105
                2023-12-27 16:21:37.212  - info: pi-hole.0 (3006) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.pi-hole, node: v18.17.1, js-controller: 4.0.24
                2023-12-27 16:21:37.955  - info: smartcontrol.0 (2739) Adapter admin configuration successfully validated...
                2023-12-27 16:21:38.943  - info: harmony.0 (2441) [DISCOVER] Discovered Wohnzimmer (10.100.200.74) and will try to connect
                2023-12-27 16:21:39.455  - info: harmony.0 (2441) [CONNECT] Connecting to Wohnzimmer (10.100.200.74)
                2023-12-27 16:21:40.783  - info: harmony.0 (2441) [CONNECT] Connected to Wohnzimmer (10.100.200.74)
                2023-12-27 16:21:41.632  - info: harmony.0 (2441) [PROCESS] Synced hub config for Wohnzimmer (10.100.200.74)
                2023-12-27 16:21:41.890  - info: bring.0 (3105) starting. Version 1.8.1 in /opt/iobroker/node_modules/iobroker.bring, node: v18.17.1, js-controller: 4.0.24
                2023-12-27 16:21:42.067  - info: smartcontrol.0 (2739) Subscribing to all target devices and trigger states. 4 trigger schedules activated...
                2023-12-27 16:21:43.034  - info: bring.0 (3105) [LOGIN] Successfully logged in as Ali
                2023-12-27 16:21:44.064  - info: vis.0 (3152) starting. Version 1.4.16 in /opt/iobroker/node_modules/iobroker.vis, node: v18.17.1, js-controller: 4.0.24
                2023-12-27 16:21:44.462  - info: vis.0 (3152) vis license is OK.
                2023-12-27 16:21:44.625  - info: alexa2.0 (1817) Subscribing to states...
                2023-12-27 16:21:44.635  - info: alexa2.0 (1817) Deleting the following states: ["Smart-Home-Devices.9f4e9ab6-8817-4fc0-837c-080303c57239","Smart-Home-Devices.3b42e75f-f188-487d-978b-4b716e9f3647","Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices","Smart-Home-Devices.9f4e9ab6-8817-4fc0-837c-080303c57239.#enabled","Smart-Home-Devices.9f4e9ab6-8817-4fc0-837c-080303c57239.#delete","Smart-Home-Devices.3b42e75f-f188-487d-978b-4b716e9f3647.#enabled","Smart-Home-Devices.3b42e75f-f188-487d-978b-4b716e9f3647.#delete"]
                2023-12-27 16:21:45.291  - info: vis.0 (3152) Terminated (NO_ERROR): Without reason
                2023-12-27 16:21:45.621  - warn: zigbee.0 (1866) DeviceAvailability:Failed to ping 0x540f57fffe896f3f TS011F
                2023-12-27 16:21:46.009  - info: host.SYS-Server-Raspi4 instance system.adapter.vis.0 terminated while should be started once
                2023-12-27 16:21:46.394  - info: alexa2.0 (1817) Alexa-Push-Connection (macDms = true) established. Disable Polling
                2023-12-27 16:21:52.495  - info: alexa2.0 (1817) Initialization Done ...
                  alexzi @Glasfaser last edited by
                  @glasfaser
                  $ iob setup first
                  Successfully migrated 10930 objects to Redis Sets
                  Existing earlier generated certificate is invalid (too old, validity longer then 345 days or keylength too short). Generating new Certificate!
                  object system.certificates updated
                  object system.repositories created
                  object _design/system updated
                    "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----........-----END CERTIFICATE-----\r\n"
                  Update certificate defaultPrivate
                  The object "system.certificates" was updated successfully.
                  Update certificate defaultPublic
                  pi@SYS-Server-Raspi4:~ $ iob update
                  Used repository: Stable (default)
                  Error: unknown repository is active - "Stable (default)". Known: stable, beta
                  • Glasfaser
                    Glasfaser last edited by Glasfaser
                    @alexzi
                    iob repo del beta
                    iob repo del stable
                    iob repo add stable http://download.iobroker.net/sources-dist.json
                    iob repo add beta http://download.iobroker.net/sources-dist-latest.json
                    iob repo list
                      @glasfaser
                      Danke, ich krieg nen Vogel... 😢
                      pi@SYS-Server-Raspi4:~ $ iob repo del beta
                      Repository "beta" deleted.
                      Active repo(s): Stable (default)
                      pi@SYS-Server-Raspi4:~ $ iob repo del stable
                      Repository "stable" deleted.
                      pi@SYS-Server-Raspi4:~ $ iob repo add stable http://download.iobroker.net/sources-dist.json
                      Repository "stable" added as "http://download.iobroker.net/sources-dist.json"
                      pi@SYS-Server-Raspi4:~ $ iob repo add beta http://download.iobroker.net/sources-dist-latest.json
                      Repository "beta" added as "http://download.iobroker.net/sources-dist-latest.json"
                      pi@SYS-Server-Raspi4:~ $ iob repo list
                      pi@SYS-Server-Raspi4:~ $ iob stop
                      Glasfaser Homoran 2 Replies Last reply Reply Quote 0
                      • Glasfaser
                        @alexzi
                        Mache mal ein :
                        sudo reboot
                        was ist dann
                          @alexzi iob repo unset "Stable (default)"
                          iob repo set stable
                            Richtig, installier da Raspberry OS 12 'Bookworm' komplett neu in der 64Bit Lite Version.
                              Halleluja, das wars, zumindest geht das Update wieder. DANKE
                              Beim Rest muss ich mich reinbeißen.
                              Noch eine generelle Frage: ist es ratsam/empfehlenswert IOB in Docker laufen zu lassen? Wenn ich schon neu anfange, dann hoffentlich richtig (zumindest deutlich besser).
                              • Samson71
                                Samson71 Global Moderator @alexzi last edited by
                                @alexzi
                                Für den "Otto-Normalanwender", der auf seinem PI ausschließlich ioBroker betreibt, bzw. betreiben will, ist (in meinen Augen) weder Docker noch eine Proxmox Umgebung sinnvoll. Du schaffst Dir höchstens mehr Probleme als Dir lieb ist.
                                615
