    4. Keine Verbindung mehr zu iobroker
      Thomas Braun Most Active @obstbauer last edited by
      @obstbauer sagte in Keine Verbindung mehr zu iobroker:
      soll ich die Langfassung hier einfügen ?
      Ja.
      • O
        ich weiß der Desktop läuft noch, ich werde das ändern, wenn alles wieder stabil läuft
        Skript v.2023-10-25
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model		: Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         22:23:36 up  7:48,  2 users,  load average: 1.76, 1.51, 1.47
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Wed 2023-12-27 22:23:36 CET
                   Universal time: Wed 2023-12-27 21:23:36 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server: 	true
        Desktop: 	LXDE-pi
        Terminal: 	x11
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:            3.8G        1.0G        365M         65M        2.4G        2.6G
        Swap:            99M          0B         99M
        Total:          3.9G        1.0G        465M
                 3794 M total memory
                 1024 M used memory
                 1589 M active memory
                 1563 M inactive memory
                  368 M free memory
                    7 M buffer memory
                 2393 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       59G   18G   39G  31% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G  7.8M  1.9G   1% /dev/shm
        tmpfs          tmpfs     759M  1.3M  758M   1% /run
        /dev/sda1      ext4      3.7T  2.8T  772G  79% /mount/toshiba_1
        /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
        tmpfs          tmpfs     380M   28K  380M   1% /run/user/1000
        [Wed Dec 27 14:35:18 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:A8:66:23 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=33928f17-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Wed Dec 27 14:35:19 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Wed Dec 27 14:35:19 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Wed Dec 27 14:35:22 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        [Wed Dec 27 14:35:24 2023] EXT4-fs (sda1): warning: mounting fs with errors, running e2fsck is recommended
        [Wed Dec 27 14:35:25 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
        [Wed Dec 27 14:36:18 2023] EXT4-fs error (device sda1): ext4_lookup:1839: inode #232962: comm stat: deleted inode referenced: 236870
        [Wed Dec 27 14:36:18 2023] EXT4-fs error (device sda1): ext4_lookup:1839: inode #232962: comm stat: deleted inode referenced: 236868
        [Wed Dec 27 14:36:18 2023] EXT4-fs error (device sda1): ext4_lookup:1839: inode #232962: comm stat: deleted inode referenced: 236864
        [Wed Dec 27 14:36:18 2023] EXT4-fs error (device sda1): ext4_lookup:1839: inode #232962: comm stat: deleted inode referenced: 236869
        [Wed Dec 27 14:36:18 2023] EXT4-fs error (device sda1): ext4_lookup:1839: inode #232962: comm stat: deleted inode referenced: 236867
        [Wed Dec 27 14:36:18 2023] EXT4-fs error (device sda1): ext4_lookup:1839: inode #232962: comm stat: deleted inode referenced: 236865
        [Wed Dec 27 14:40:34 2023] EXT4-fs (sda1): error count since last fsck: 2616
        [Wed Dec 27 14:40:34 2023] EXT4-fs (sda1): initial error at time 1679237384: ext4_lookup:1840: inode 232962
        [Wed Dec 27 14:40:34 2023] EXT4-fs (sda1): last error at time 1703684179: ext4_lookup:1839: inode 232962
        Show mounted filesystems:
        TARGET                       SOURCE         FSTYPE         OPTIONS
        /                            /dev/mmcblk0p2 ext4           rw,noatime
        |-/dev                       devtmpfs       devtmpfs       rw,relatime,size=1678472k,nr_inodes=419618,mode=755
        | |-/dev/shm                 tmpfs          tmpfs          rw,nosuid,nodev
        | |-/dev/pts                 devpts         devpts         rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | `-/dev/mqueue              mqueue         mqueue         rw,nosuid,nodev,noexec,relatime
        |-/proc                      proc           proc           rw,relatime
        | `-/proc/sys/fs/binfmt_misc systemd-1      autofs         rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |-/sys                       sysfs          sysfs          rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security     securityfs     securityfs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup           cgroup2        cgroup2        rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore           pstore         pstore         rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf              bpf            bpf            rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug        debugfs        debugfs        rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/tracing      tracefs        tracefs        rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/config       configfs       configfs       rw,nosuid,nodev,noexec,relatime
        | `-/sys/fs/fuse/connections fusectl        fusectl        rw,nosuid,nodev,noexec,relatime
        |-/run                       tmpfs          tmpfs          rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
        | |-/run/lock                tmpfs          tmpfs          rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs          sunrpc         rpc_pipefs     rw,relatime
        | `-/run/user/1000           tmpfs          tmpfs          rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
        |   `-/run/user/1000/gvfs    gvfsd-fuse     fuse.gvfsd-fus rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        |-/mount/toshiba_1           /dev/sda1      ext4           rw,relatime
        `-/boot                      /dev/mmcblk0p1 vfat           rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remoun
        /var:
        6.9G	/var/
        5.2G	/var/log
        4.0G	/var/log/journal/8c1e10bfe3864fdca0aaa920fec2e173
        1.1G	/var/lib
        Archived and active journals take up 3.9G in the file system.
        /opt/iobroker/backups:
        3.2G	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.8G	/opt/iobroker/iobroker-data/
        153M	/opt/iobroker/iobroker-data/files
        62M	/opt/iobroker/iobroker-data/history
        52M	/opt/iobroker/iobroker-data/files/javascript.admin
        35M	/opt/iobroker/iobroker-data/backup-objects
        1.6G	/opt/iobroker/iobroker-data/objects.jsonl
        21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        9.1M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
        8.9M	/opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
        8.9M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/2.3d2d025f.chunk.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-1a86_USB_Single_Serial_558E108164-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v16.20.2
        /usr/bin/node 		v16.20.2
        /usr/bin/npm 		8.19.4
        /usr/bin/npx 		8.19.4
        /usr/bin/corepack 	0.17.0
        nodejs:
          Installed: 16.20.2-deb-1nodesource1
          Candidate: 16.20.2-deb-1nodesource1
          Version table:
         *** 16.20.2-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
        Core adapters versions
        js-controller: 	4.0.23
        admin: 		6.12.0
        javascript: 	7.0.3
        Adapters from github: 	0
        Adapter State
        No connection to databases possible ...
        ioBroker-Repositories
        Installed ioBroker-Instances
        Objects and States
        Objects: 	1
        States: 	1
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:3 http://deb.debian.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 https://archive.raspbian.org/raspbian buster InRelease
        Hit:6 https://apt.grafana.com stable InRelease
        Get:7 https://deb.nodesource.com/node_16.x bullseye InRelease [4586 B]
        Hit:8 https://repos.influxdata.com/debian stable InRelease
        Hit:9 https://repos.influxdata.com/debian bullseye InRelease
        Hit:10 http://weewx.com/apt/python3 buster InRelease
        Fetched 4586 B in 5s (842 B/s)
        Reading package lists... Done
        N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'https://archive.raspbian.org/raspbian buster InRelease' doesn't support architecture 'arm64'
        N: Skipping acquire of configured file 'contrib/binary-arm64/Packages' as repository 'https://archive.raspbian.org/raspbian buster InRelease' doesn't support architecture 'arm64'
        N: Skipping acquire of configured file 'non-free/binary-arm64/Packages' as repository 'https://archive.raspbian.org/raspbian buster InRelease' doesn't support architecture 'arm64'
        Pending Updates: 0
        *** Listening Ports ***
        Netid            State             Recv-Q            Send-Q                         Local Address:Port                          Peer Address:Port            Process
        udp              UNCONN            0                 0                                    0.0.0.0:631                                0.0.0.0:*                users:(("cups-browsed",pid=735,fd=7))
        udp              UNCONN            0                 0                                    0.0.0.0:5353                               0.0.0.0:*                users:(("avahi-daemon",pid=440,fd=12))
        udp              UNCONN            0                 0                                    0.0.0.0:34224                              0.0.0.0:*                users:(("avahi-daemon",pid=440,fd=14))
        udp              UNCONN            0                 0                                    0.0.0.0:68                                 0.0.0.0:*                users:(("dhcpcd",pid=508,fd=13))
        udp              UNCONN            0                 0                                          *:546                                      *:*                users:(("dhcpcd",pid=508,fd=16))
        udp              UNCONN            0                 0                                          *:5353                                     *:*                users:(("avahi-daemon",pid=440,fd=13))
        udp              UNCONN            0                 0                                          *:39262                                    *:*                users:(("avahi-daemon",pid=440,fd=15))
        tcp              LISTEN            0                 511                                  0.0.0.0:80                                 0.0.0.0:*                users:(("nginx",pid=757,fd=6),("nginx",pid=756,fd=6),("nginx",pid=755,fd=6),("nginx",pid=754,fd=6),("nginx",pid=753,fd=6))
        tcp              LISTEN            0                 128                                127.0.0.1:631                                0.0.0.0:*                users:(("cupsd",pid=591,fd=7))
        tcp              LISTEN            0                 128                                  0.0.0.0:22                                 0.0.0.0:*                users:(("sshd",pid=646,fd=3))
        tcp              LISTEN            0                 1024                                 0.0.0.0:2812                               0.0.0.0:*                users:(("monit",pid=566,fd=5))
        tcp              LISTEN            0                 4096                               127.0.0.1:8088                               0.0.0.0:*                users:(("influxd",pid=603,fd=3))
        tcp              LISTEN            0                 80                                 127.0.0.1:3306                               0.0.0.0:*                users:(("mariadbd",pid=732,fd=21))
        tcp              LISTEN            0                 5                                    0.0.0.0:5900                               0.0.0.0:*                users:(("vncserver-x11-c",pid=636,fd=12))
        tcp              LISTEN            0                 511                                     [::]:80                                    [::]:*                users:(("nginx",pid=757,fd=7),("nginx",pid=756,fd=7),("nginx",pid=755,fd=7),("nginx",pid=754,fd=7),("nginx",pid=753,fd=7))
        tcp              LISTEN            0                 128                                     [::]:22                                    [::]:*                users:(("sshd",pid=646,fd=4))
        tcp              LISTEN            0                 1024                                    [::]:2812                                  [::]:*                users:(("monit",pid=566,fd=6))
        tcp              LISTEN            0                 4096                                       *:3000                                     *:*                users:(("grafana",pid=1238,fd=9))
        tcp              LISTEN            0                 2                                      [::1]:3350                                  [::]:*                users:(("xrdp-sesman",pid=641,fd=11))
        tcp              LISTEN            0                 128                                    [::1]:631                                   [::]:*                users:(("cupsd",pid=591,fd=6))
        tcp              LISTEN            0                 2                                          *:3389                                     *:*                users:(("xrdp",pid=733,fd=11))
        tcp              LISTEN            0                 511                                        *:8080                                     *:*                users:(("node /home/Shin",pid=1217,fd=21))
        tcp              LISTEN            0                 4096                                       *:8086                                     *:*                users:(("influxd",pid=603,fd=29))
        tcp              LISTEN            0                 5                                       [::]:5900                                  [::]:*                users:(("vncserver-x11-c",pid=636,fd=11))
        2023-12-27 22:24:52.282  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-12-27 22:24:52.283  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.2
        2023-12-27 22:24:52.284  - info: host.raspberrypi ip addresses: 192.168.178.72 2003:de:a713:a200:9644:8a14:166b:382f fe80::aa74:964:1a9c:1acd
        2023-12-27 22:25:22.310  - error: host.raspberrypi No connection to databases possible, restart
        2023-12-27 22:25:22.324  - info: host.raspberrypi iobroker _restart
        2023-12-27 22:25:27.732  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
        2023-12-27 22:25:27.738  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-12-27 22:25:27.739  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.2
        2023-12-27 22:25:27.740  - info: host.raspberrypi ip addresses: 192.168.178.72 2003:de:a713:a200:9644:8a14:166b:382f fe80::aa74:964:1a9c:1acd
        2023-12-27 22:25:57.766  - error: host.raspberrypi No connection to databases possible, restart
        2023-12-27 22:25:57.783  - info: host.raspberrypi iobroker _restart
        2023-12-27 22:26:03.868  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
        2023-12-27 22:26:03.880  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-12-27 22:26:03.882  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.2
        2023-12-27 22:26:03.884  - info: host.raspberrypi ip addresses: 192.168.178.72 2003:de:a713:a200:9644:8a14:166b:382f fe80::aa74:964:1a9c:1acd
        2023-12-27 22:26:06.035  - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
        2023-12-27 22:26:10.857  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
        2023-12-27 22:26:10.868  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-12-27 22:26:10.869  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.2
        2023-12-27 22:26:10.871  - info: host.raspberrypi ip addresses: 192.168.178.72 2003:de:a713:a200:9644:8a14:166b:382f fe80::aa74:964:1a9c:1acd
        2023-12-27 22:26:13.043  - error: host.raspberrypi-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
        2023-12-27 22:26:17.742  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
        2023-12-27 22:26:17.752  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
        2023-12-27 22:26:17.754  - info: host.raspberrypi hostname: raspberrypi, node: v16.20.2
        2023-12-27 22:26:17.756  - info: host.raspberrypi ip addresses: 192.168.178.72 2003:de:a713:a200:9644:8a14:166b:382f fe80::aa74:964:1a9c:1acd
        Glasfaser 2 Replies Last reply Reply Quote 0
        • Glasfaser
          Glasfaser @obstbauer last edited by Glasfaser
          die json ist zu groß , deshalb geht es nicht
          mache mal
          iob stop
          iob fix
          sudo reboot
          • O
            obstbauer @Glasfaser last edited by obstbauer
            @glasfaser super klasse, es geht wieder, vielen Dank!
            Kann mir noch jemand fürs Verständis erklären wie das passieren konnte (wie gesagt es gab einen Stromausfall) ? Und woher weiß ich dass die 1.6 GB zu groß sind ?
            • Glasfaser
              der ist aber schon sehr alt .. und auch vom letzten Stand "4.0.24" auch nicht aktuell
              Neu ist JS 5
              dazu aber erst ein Backup machen zur Sicherheit dann
              iob stop
              iob update
              iob upgrade self
              iob start
              /usr/bin/npm 8.19.4
              /usr/bin/npx 8.19.4
              Auch sehr alt .
              dazu :
              iob nodejs-update
              • Glasfaser
                Das liegt erstmal am Stromausfall von dir ... Daten wurden noch nicht weggeschrieben und du hast noch die alte 4.0.23 dort wurde es noch nicht damit abgefangen !
                • Glasfaser
                  Glasfaser last edited by Glasfaser
                  diesen Fehler scheine ich zu haben:
                  Dazu gibt es einen Thread
                  siehe hier :
                  https://forum.iobroker.net/topic/53378/server-cannot-start-inmem-objects-on-port-9001
                  Klar ...funktioniert es wieder ...
                  ein bekannter Fehler ( Stromausfall ) 😉
                  • O
                    @glasfaser ich versuche die updates jetzt durchzuführen, Sicherung ist erstellt
                    weitere Verständnisfrage: Werden diese Versionen nicht mit aktualisiert wenn ich das System aktualisiere mit sudo apt upgrade oder is das durch meine grafana key fehler einfach zu lange nicht mehr gemacht worden ?
                    • Glasfaser
                      nein nur dein
                      • O
                        @glasfaser also muss ich in Zukunft selbst immer von Hand diese updates machen und schauen, dass alles aktuell ist?
                        • Glasfaser
                          @obstbauer
                          ja , Node per Konsole
                          und ab JS 5 ist jetzt neu per Admin WebUI ein update zu machen ... wie halt auch die Adapter
                          • O
                            @glasfaser Hallo,
                            ich habe mal wieder nach aktuellen Updates geschaut
                            Was meinst du genau? Wo kann ich das im Admin WebUI finden ? Konnte da nix finden wie bei den Adaptern...
                              Homoran Global Moderator Administrators @obstbauer last edited by
                              @obstbauer welche controller Version hast du?
                                @obstbauer
                                Raspbian GNU/Linux 10
                                ist tot, muss durch v12 ersetzt werden. Neuinstallation der 64Bit-Lite-Version.
                                • O
                                  @homoran Admin 6.13.15
                                  Ich habe release 11 bullseye
                                  node v18.19.0
                                    @obstbauer fehlt nur noch die gefragte Version des js-controllers.
                                    • O
                                      Node.js: v18.19.0
                                      NPM: 10.2.3
                                      js-controller 5.0.17
                                        danke!
                                        damit sollte es gehen.
                                        Der Button dafür sollte wie bisher unter hosts zu finden sein
                                        1500
