      Frank579 @Michael Roling last edited by
      @michael-roling So Überall wo XXX steht hab ich was gelöscht hoffe war nicht zuviel oder habe was übersehen 🙂
      telegram-menu.0
      2023-12-28 01:24:30.204	debug	ChatID to use: XXXX
      telegram-menu.0
      2023-12-28 01:24:30.204	debug	User and ChatID: {"name":"Frank","chatID":"XXXXX"}
      telegram-menu.0
      2023-12-28 01:24:30.204	debug	User "Frank"
      telegram-menu.0
      2023-12-28 01:24:30.205	debug	ChatID to use: XXXX
      telegram-menu.0
      2023-12-28 01:24:30.205	debug	User and ChatID: {"name":"Frank","chatID":"XXXX"}
      telegram-menu.0
      2023-12-28 01:24:30.205	debug	User "Frank"
      telegram-menu.0
      2023-12-28 01:24:30.205	debug	{"Value":"[Frank795]🚮","User":"Frank","Todo":"🚮","groups":{"Test1":["Frank"]}}
      telegram-menu.0
      2023-12-28 01:24:30.205	debug	Groups "Test1"
      telegram-menu.0
      2023-12-28 01:24:30.205	debug	Groups with searched User ["Test1"]
      telegram-menu.0
      2023-12-28 01:24:30.205	debug	Nav: {"Start":{"nav":[["System"],["Home"],["Grafana","Weather","🚮"]],"text":"-","parse_mode":"true"},"System":{"nav":[["Proxmox"],["IOBroker"],["🔙","🚮"]],"text":"-","parse_mode":"true"},"Home":{"nav":[["Licht","Steckdosen"],["Alarmanlage"],["🔙","🚮"]],"text":"-","parse_mode":"false"},"Alarmanlage":{"nav":[["menu:switch-ein.true-aus.false:test1:Start"]],"text":"Choose an action","parse_mode":"true"},"🔙":{"nav":[["menu:back"]],"text":"-","parse_mode":"false"},"🚮":{"nav":[["menu:deleteAll:Start"]],"text":"Choose an action","parse_mode":"false"},"test1":{"switch":[{"id":"0_userdata.0.Test.Auslöser","value":true,"toggle":true,"confirm":"false","returnText":"W&&","ack":"false","parse_mode":"false"}]},"Weather":{"getData":[{"id":"alias.0.Außen.Sensor.MS_außen.ACTUAL","text":"Außen sind es && °C","newline":"true","parse_mode":"false"}]}}
      telegram-menu.0
      2023-12-28 01:24:30.205	debug	Menu: {"Test1":{"Start":{"nav":[["System"],["Home"],["Grafana","Weather","🚮"]],"text":"-","parse_mode":"true"},"System":{"nav":[["Proxmox"],["IOBroker"],["🔙","🚮"]],"text":"-","parse_mode":"true"},"Home":{"nav":[["Licht","Steckdosen"],["Alarmanlage"],["🔙","🚮"]],"text":"-","parse_mode":"false"},"Alarmanlage":{"nav":[["menu:switch-ein.true-aus.false:test1:Start"]],"text":"Choose an action","parse_mode":"true"},"🔙":{"nav":[["menu:back"]],"text":"-","parse_mode":"false"},"🚮":{"nav":[["menu:deleteAll:Start"]],"text":"Choose an action","parse_mode":"false"},"test1":{"switch":[{"id":"0_userdata.0.Test.Auslöser","value":true,"toggle":true,"confirm":"false","returnText":"W&&","ack":"false","parse_mode":"false"}]},"Weather":{"getData":[{"id":"alias.0.Außen.Sensor.MS_außen.ACTUAL","text":"Außen sind es && °C","newline":"true","parse_mode":"false"}]}}}
      telegram-menu.0
      2023-12-28 01:24:30.205	debug	Group: "Test1"
      telegram-menu.0
      2023-12-28 01:24:30.205	debug	Menu to Send: [["menu:deleteAll:Start"]]
      telegram-menu.0
      2023-12-28 01:24:30.205	debug	goBackMenu{"Frank":{"list":["Start","System","Start","Home","Start","Start","System"],"last":"Start"}}
      telegram-menu.0
      2023-12-28 01:24:30.205	debug	Submenu
      telegram-menu.0
      2023-12-28 01:24:30.205	debug	type of "string"
      telegram-menu.0
      2023-12-28 01:24:30.205	debug	CalledValue: "[[\"menu:deleteAll:Start\"]]"
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	callbackData: "deleteAll"
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	splittet Data of callbackData "deleteAll"
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	devicetoswitch: "Start"
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	text: "[[\"menu:deleteAll:Start\"]]"
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	Submenu data [null,null,null,null,"Start"]
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	Nav: {"Start":{"nav":[["System"],["Home"],["Grafana","Weather","🚮"]],"text":"-","parse_mode":"true"},"System":{"nav":[["Proxmox"],["IOBroker"],["🔙","🚮"]],"text":"-","parse_mode":"true"},"Home":{"nav":[["Licht","Steckdosen"],["Alarmanlage"],["🔙","🚮"]],"text":"-","parse_mode":"false"},"Alarmanlage":{"nav":[["menu:switch-ein.true-aus.false:test1:Start"]],"text":"Choose an action","parse_mode":"true"},"🔙":{"nav":[["menu:back"]],"text":"-","parse_mode":"false"},"🚮":{"nav":[["menu:deleteAll:Start"]],"text":"Choose an action","parse_mode":"false"},"test1":{"switch":[{"id":"0_userdata.0.Test.Auslöser","value":true,"toggle":true,"confirm":"false","returnText":"W&&","ack":"false","parse_mode":"false"}]},"Weather":{"getData":[{"id":"alias.0.Außen.Sensor.MS_außen.ACTUAL","text":"Außen sind es && °C","newline":"true","parse_mode":"false"}]}}
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	Menu: undefined
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	Group: "Test1"
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	Menu to Send: [["System"],["Home"],["Grafana","Weather","🚮"]]
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	goBackMenu{"Frank":{"list":["Start","System","Start","Home","Start","Start","System","Start"],"last":"Start"}}
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	Send Nav to Telegram
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	Send this Value : "-"
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	Send this to : "Frank"
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	Instance : "telegram.1"
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	userListWithChatID : [{"name":"Frank","chatID":"XXXX"}]
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	parse_mode : "true"
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	chatId : "XXXX"
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	CalledText found
      telegram-menu.0
      telegram-menu.0
      2023-12-28 01:24:30.206	debug	Datafound: true
      telegram-menu.0
      2023-12-28 01:24:30.238	debug	Sent Value to ["{\"XXXX\":XXX}"] users!
      telegram-menu.0
      2023-12-28 01:24:30.281	debug	Save Message ID
      telegram-menu.0
      2023-12-28 01:24:30.281	debug	RequestMessageIds: {"XXXXX":[{"id":XXX},{"id":XXXX}]}
      telegram-menu.0
      2023-12-28 01:24:30.282	debug	Delete Message for "Frank"
      telegram-menu.0
      telegram.1
      2023-12-28 01:24:30.283	warn	1 of 1 recipients are unknown!
      telegram.1
      2023-12-28 01:24:30.284	warn	1 of 1 recipients are unknown!
      telegram-menu.0
      2023-12-28 01:24:30.324	debug	ChatID to use: XXXXX
      telegram-menu.0
      2023-12-28 01:24:30.325	debug	User and ChatID: {"name":"Frank","chatID":"XXXXX"}
      telegram-menu.0
      2023-12-28 01:24:30.325	debug	User "Frank"
      telegram-menu.0
      2023-12-28 01:24:30.369	debug	Save Message ID
      telegram-menu.0
      2023-12-28 01:24:30.369	debug	RequestMessageIds: {"XXXX":[{"id":XXXX}]}
      • Michael Roling
        Michael Roling Developer @Frank579 last edited by
        @frank579 deswegen hättest du das auch per mail schicken können, dann wäre es nicht öffentich 😉
          @michael-roling Kann ich noch machen wenn du die daten benötigst, deshalb hatte ich ja gefragt 😉
          • Michael Roling
            @frank579 ne schon okay, ich glaube ich weiss wo der fehler liegt. Da muss ich mich morgen mal mit beschäfftigen
              @michael-roling
              Okay Dann geh ich mal wieder zurück und mach Schluss für heute 🙂
              • Michael Roling
                @frank579 ich probiere das mal eben ganz kurz auf die schnelle
                • Michael Roling
                  @frank579 wenn du einmal von github installieren möchtest darfst du das jetzt gerne noch mal tun
                    @michael-roling Mal auf die schnelle sieht das sehr gut aus 👍 👍 👍
                    • Michael Roling
                      @frank579 Okay dann belassen wir es dabei das auf die schnelle funktioniert , ansonsten schauen wir morgen nochmal. Dir noch einen schönen Abend
                        @michael-roling mein kleines Menü funktioniert, kann ich morgen weiter basteln 🙂 Danke wünsch ich dir auch,
                          Willi-Wunder last edited by
                          @michael-roling
                          Hallo Michael, erweitere gerade ein paar Menüs. Dachte eigentlich das das schalten der Wärmepumpe so bisher funktioniert hatte, allerdings jetzt nicht mehr. Wenn ich Warmwasser auf EIN/AUS oder Party schalte, ändert sich zwar in den Objekten der Wert, springt aber wieder nach ein paar Sekunden auf den alten Wert zurück. Ack:true ist aktiviert.
                          Wenn ich die Werte über mein VIS ändere, werden die Einstellungen übernommen. Daher sollte die Steuerung die Änderung auch übernehmen können. Woran könnte dies liegen?
                          • Michael Roling
                            Michael Roling Developer @Willi-Wunder last edited by
                            @willi-wunder du darfst keinen datenpunkt eines Adapter mit ack true setzen.
                            Das sollte der Adapter selbst machen
                              Willi-Wunder @Michael Roling last edited by Willi-Wunder
                              @michael-roling
                              Ja, war der P45 Fehler...... Problem sitzt 45 cm davor 😇
                              Im Helper Text müßte hier doch noch der "Name3" im menu:dyn.Switch stehen, richtig?
                              Was ist der Unterschied zwischen "Menu:switch" und "Menu:dyn.Switch"? Mit dem "Menu:dyn.Switch" könnte ich doch das gleiche erzielen wenn ich nur zwei Sachen (true - false) hinterlege, oder?
                              Bei meinem "Menu:dyn.Switch" der Heizung hab ich noch zwei Fragen:
                              1. Welchen Wert muss ich hier eintragen? Dieser wird ja je nach Auswahl erst gesendet.
                              2. Die neuen Zustände werden nicht umgewandelt.
                              • Michael Roling
                                Michael Roling Developer last edited by
                                • Zu Bild eins, nein muss nicht, das ist ein Beispiel das es auch ohne Name geht. Dann wird das Value auch zum Namen des Button
                                • Frage 2, ja genau damit kann man genau das gleiche machen, nur das menu:dyn.switch halt auch alles andere kann und mehr als 2 buttons
                                • frage 3 einfach ein - einfügen
                                • mit der umwandlung schaue ich mir an
                                • Michael Roling
                                  @willi-wunder das problem sollte behoben sein
                                  • Segway
                                    Segway @Michael Roling last edited by Segway
                                    @michael-roling
                                    Zur Info:
                                    Bisher wurde mir immer kein Update angeboten für den Telegram Menü Adapter. Ich war auf der 0.8.5 Version.
                                    Heute habe ich das Update anliegen auf die neue 1.5.1 upgegradet
                                    Gemacht getan --> es wurde der komplette IoBroker gestoppt ... Ist das so gewollt.
                                    (Also quasi iob stop und dann iob start - so kam es mir vor .... der admin war auch nicht mehr erreichbar.)
                                    • Michael Roling
                                      Michael Roling Developer @Segway last edited by Michael Roling
                                      @segway ja das mit dem update ist richtig das jetzt erst eins auftaucht , welches im STABLE Repo ist. Mit dem anderen weiss ich , das liegt am js-controller, der hat einen bug. Dazu gibt es auch schon ein Issue, da kann ich leider so nichts machen. Es geht kurzzeitig der RAM- Verbrauch extrem hoch
                                      Segway 2 Replies Last reply Reply Quote 0
                                      • Segway
                                        @michael-roling sagte in Test Adapter telegram-menu v.0.9.x:
                                        Okay, wusste ich nicht.
                                        Aber andere Updates von anderen Adaptern hatten das nicht. Liegt dann anscheinen dan besonderen Updateform ?
                                        • Michael Roling
                                          @segway der unterschied von meinem zu anderen Adaptern ist das ich react nutze. Ich hatte das aber schon mal bei den Entwicklern angesprochen und die haben mich drauf hin gewiesen das es das Issue schon gibt. Ich habe da leider keinen Einfluss drauf.
                                          Segway 1 Reply Last reply Reply Quote 1
                                          • Segway
                                            @michael-roling
                                            Habe gerade festgestellt, dass ich folgende Fehlermeldung oder Warning im log habe:
                                            admin.0
                                            	2023-12-29 23:45:08.631	warn	Cannot read file ("telegram-menu.admin"/"telegram-menu.png"): Not exists
                                            1801
                                            791206
