    3. Einsteigerfragen
    4. Installation
    5. vermurkste Installation
      Thomas Braun Most Active @Radix75 last edited by
      @radix75 sagte in Daikin Adapter:
      versucht auf der neuen Pi 5 ein Beckup der alten Pi zu machen
      Da funktioniert nicht, die Hardware ist anders. Du musst das ordentlich von Grund auf neu installieren.
        Radix75 @Radix75 last edited by Homoran
        Ich habe auch festgestellt das die Instanz Erstellung nicht geht
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: raspberrypi5
               Icon name: computer
                  Kernel: Linux 6.1.0-rpi7-rpi-2712
            Architecture: arm64
        Model		: Raspberry Pi 5 Model B Rev 1.0
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         13:39:53 up 16 min,  3 users,  load average: 0.19, 0.22, 0.18
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Wed 2023-12-27 13:39:53 CET
                   Universal time: Wed 2023-12-27 12:39:53 UTC
                         RTC time: Wed 2023-12-27 12:39:53
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        Radix1975
        /home/Radix1975
        Radix1975 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop: 	LXDE-pi-wayfire
        Terminal: 	wayland
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:            8.4G        1.1G        6.8G         91M        767M        7.3G
        Swap:           104M          0B        104M
        Total:          8.5G        1.1G        6.9G
                 8049 M total memory
                 1055 M used memory
                 1123 M active memory
                  224 M inactive memory
                 6440 M free memory
                   62 M buffer memory
                  670 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        vc_gencmd_read_response returned -1
        error=1 error_msg="Command not registered"
        *** FAILED SERVICES ***
          UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
        * console-setup.service loaded failed failed Set console font and keymap
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  3.8G     0  3.8G   0% /dev
        tmpfs          tmpfs     805M  6.3M  799M   1% /run
        /dev/mmcblk0p2 ext4       58G   14G   42G  25% /
        tmpfs          tmpfs     4.0G  576K  4.0G   1% /dev/shm
        tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
        /dev/mmcblk0p1 vfat      510M   74M  437M  15% /boot/firmware
        tmpfs          tmpfs     805M  176K  805M   1% /run/user/1000
        /dev/sda1      vfat       29G  9.7G   19G  34% /media/Radix1975/A72E-0079
        [Wed Dec 27 13:23:38 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:BC:98:3F vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=749f5341-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
        [Wed Dec 27 13:23:40 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Wed Dec 27 13:23:41 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET                       SOURCE         FSTYPE      OPTIONS
        /                            /dev/mmcblk0p2 ext4        rw,noatime
        |-/run/user/1000/doc         portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        |-/boot/firmware             /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        `-/media/Radix1975/A72E-0079 /dev/sda1      vfat        rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro
        /var:
        1.7G	/var/
        894M	/var/lib
        655M	/var/lib/piVCCU3
        604M	/var/lib/piVCCU3/rootfs
        593M	/var/cache
        Archived and active journals take up 142.3M in the file system.
        /opt/iobroker/backups:
        4.0K	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        16M	/opt/iobroker/iobroker-data/
        15M	/opt/iobroker/iobroker-data/files
        13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
        6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
        1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
        824K	/opt/iobroker/iobroker-data/objects.jsonl
        652K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE1962617-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.19.0
        /usr/bin/node 		v18.19.0
        /usr/bin/npm 		10.2.3
        /usr/bin/npx 		10.2.3
        /usr/bin/corepack 	0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 500
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 500
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0+dfsg1-1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	5.0.17
        admin: 		6.12.0
        javascript: 	"javascript" not found
        Adapters from github: 	0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
        Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
        Objects and States
        Objects: 	144
        States: 	111
        W: http://phoscon.de/apt/deconz/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
        Get:1 http://phoscon.de/apt/deconz bookworm InRelease [4327 B]
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:7 https://apt.pivccu.de/piVCCU stable InRelease
        Fetched 4327 B in 11s (396 B/s)
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          23264      3243/cupsd
        tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      1000       19136      1632/wayvnc
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18704      1237/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17406      1237/iobroker.js-co
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17121      1247/sshd: /usr/sbi
        tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          18024      1579/dnsmasq
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23636      3539/io.admin.0
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          23263      3243/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          17123      1247/sshd: /usr/sbi
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        16855      765/avahi-daemon: r
        udp        0      0 0.0.0.0:50460           0.0.0.0:*                           104        16857      765/avahi-daemon: r
        udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1001       31147      2033/io.discovery.0
        udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          18023      1579/dnsmasq
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          18020      1579/dnsmasq
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          21427      3245/cups-browsed
        udp6       0      0 :::5353                 :::*                                104        16856      765/avahi-daemon: r
        udp6       0      0 fe80::83ce:917a:6b2:546 :::*                                0          18035      934/NetworkManager
        udp6       0      0 :::45886                :::*                                104        16858      765/avahi-daemon: r
        2023-12-27 13:26:54.390  - error: host.raspberrypi5 Error by updating repository "stable" under "http://download.iobroker.net/sources-dist.json": Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
        2023-12-27 13:26:54.799  - info: discovery.0 (2033) Discovering devices with a HF-LPB100 chipset...
        2023-12-27 13:26:54.829  - info: discovery.0 (2033) Discovering mDNS devices...
        2023-12-27 13:26:54.834  - info: discovery.0 (2033) Discovering ping devices...
        2023-12-27 13:26:54.847  - info: discovery.0 (2033) Done discovering serial devices. 3 packages received
        2023-12-27 13:26:54.974  - info: discovery.0 (2033) Discovering UPnP devices...
        2023-12-27 13:26:54.978  - info: discovery.0 (2033) Discovering wifi-mi-light devices...
        2023-12-27 13:26:55.024  - warn: discovery.0 (2033) tr-064.0 not installed
        2023-12-27 13:26:55.025  - info: discovery.0 (2033) Done discovering tr064 devices. 0 packages received
        2023-12-27 13:26:56.478  - info: discovery.0 (2033) Done discovering RESOL VBus devices. 0 packages received
        2023-12-27 13:26:56.981  - info: discovery.0 (2033) Done discovering wifi-mi-light devices. 0 packages received
        2023-12-27 13:26:59.849  - info: discovery.0 (2033) Done discovering SMA Speedwire devices. 0 packages received
        2023-12-27 13:26:59.852  - info: discovery.0 (2033) Done discovering udp devices. 1 packages received
        2023-12-27 13:27:04.804  - info: discovery.0 (2033) Done discovering HF-LPB100 devices. 0 packages received
        2023-12-27 13:27:09.832  - info: discovery.0 (2033) Done discovering mdns devices. 39 packages received
        2023-12-27 13:27:09.975  - info: discovery.0 (2033) Done discovering upnp devices. 273 packages received
        2023-12-27 13:27:19.626  - info: discovery.0 (2033) Done discovering ping devices. 30 packages received
        2023-12-27 13:28:50.889  - info: discovery.0 (2033) Found 51 addresses
        2023-12-27 13:31:30.617  - warn: discovery.0 (2033) write: 10;VERSION;
        2023-12-27 13:31:36.650  - warn: discovery.0 (2033) write: 10;VERSION;
        2023-12-27 13:31:50.743  - info: discovery.0 (2033) Discovery finished. Found new or modified 20 instances
        2023-12-27 13:31:50.863  - info: discovery.0 (2033) Discovery finished
        2023-12-27 13:32:21.203  - info: host.raspberrypi5 iobroker install deconz
        2023-12-27 13:32:21.880  - info: host.raspberrypi5 iobroker Update repository "stable" under "http://download.iobroker.net/sources-dist.json"
        2023-12-27 13:32:47.979  - info: host.raspberrypi5 iobroker exit 0
        iob diag has finished.
        Press any key for a summary
          @radix75
          Schalt den Desktop-Krempel aus.
            Radix75 @Thomas Braun last edited by
            @thomas-braun said in Daikin Adapter:
            @radix75
            ich schreibe gerade eine SD karte mit light version melde mich später nochmal
              Radix75 last edited by Radix75
              So neue SD Karte neues Glück ich fange nochmal bei Null an!
              Ich habe auch absichtlich nur den IO Broker installiert und würde gerne Fehler Stück für Stück beheben
              iob diag
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              Docker          : false
              Kernel          : aarch64
              Userland        : arm64
               20:28:33 up 26 min,  3 users,  load average: 0.36, 0.17, 0.05
              CPU threads: 4
              Current issues:
                             Local time: Wed 2023-12-27 20:28:34 CET
                         Universal time: Wed 2023-12-27 19:28:34 UTC
                               RTC time: Wed 2023-12-27 19:28:34
                            NTP service: active
                        RTC in local TZ: no
              Radix1975
              /home/Radix1975
              Radix1975 adm dialout cdrom sudo audio video plugdev games users input render ne        tdev gpio i2c spi iobroker
              X-Server:       false
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:            8.4G        503M        7.2G        5.9M        799M        7.9G
              Swap:           104M          0B        104M
              Total:          8.5G        503M        7.3G
                       8049 M total memory
                        481 M used memory
                        451 M active memory
                        529 M inactive memory
                       6904 M free memory
                         45 M buffer memory
                        717 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              0 loaded units listed.
              *** FILESYSTEM ***
              tmpfs          tmpfs     805M  5.7M  800M   1% /run
              /dev/mmcblk0p2 ext4       59G  2.9G   53G   6% /
              tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
              /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
              tmpfs          tmpfs     805M     0  805M   0% /run/user/1000
              [Wed Dec 27 20:02:27 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  s        msc95xx.macaddr=D8:3A:DD:BC:98:3F vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x4        0000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=9ad9f164-02 rootfsty        pe=ext4 fsck.repair=yes rootwait
              [Wed Dec 27 20:02:30 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
              [Wed Dec 27 20:02:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
              `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              566M    /var/
              262M    /var/cache
              255M    /var/cache/apt
              163M    /var/lib
              144M    /var/cache/apt/archives
              Archived and active journals take up 40.0M in the file system.
              19M     /opt/iobroker/iobroker-data/
              6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js.map
              2.9M    /opt/iobroker/iobroker-data/states.jsonl
              2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_        iobr-99c23e.847b8ad9.chunk.js
              1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-n        ode_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionD        etai-57e02d.0886b730.chunk.js.map
              920K    /opt/iobroker/iobroker-data/objects.jsonl
              USB-Devices by-id:
              USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
              /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE19626        17-if00
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              nodejs:
                Version table:
                   18.13.0+dfsg1-1 500
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              Adapter State
              + system.adapter.admin.0                  : admin                 : raspberrypi5        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
              + instance is alive
              Objects and States
              Objects:        138
              States:         104
              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
              Pending Updates: 0
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25626      4179/sshd: /usr/sbi
              tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          17659      832/vncserver-x11-c
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16670      822/iobroker.js-con
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15733      822/iobroker.js-con
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15689      821/cupsd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          25628      4179/sshd: /usr/sbi
              tcp6       0      0 :::5900                 :::*                    LISTEN      0          17658      832/vncserver-x11-c
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15688      821/cupsd
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14874      884/io.admin.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        17419      637/avahi-daemon: r
              udp        0      0 0.0.0.0:48785           0.0.0.0:*                           104        17421      637/avahi-daemon: r
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14949      949/cups-browsed
              udp6       0      0 :::5353                 :::*                                104        17420      637/avahi-daemon: r
              udp6       0      0 :::36885                :::*                                104        17422      637/avahi-daemon: r
              udp6       0      0 fe80::1bc9:5af2:f2b:546 :::*                                0          17712      776/NetworkManager
              2023-12-27 20:02:36.843  - info: host.raspberrypi5 Delete state "system.host.raspberrypi5.versions.npmNewestNext"
              2023-12-27 20:02:36.845  - info: host.raspberrypi5 Some obsolete host states deleted.
              2023-12-27 20:02:38.005  - info: admin.0 (884) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
              2023-12-27 20:02:38.020  - info: admin.0 (884) requesting all objects
              2023-12-27 20:02:38.085  - warn: admin.0 (884) Cannot check node.js versions: Error: getaddrinfo EAI_AGAIN nodejs.org
              2023-12-27 20:02:38.106  - info: admin.0 (884) received all objects
              2023-12-27 20:02:38.170  - warn: admin.0 (884) Repository cannot be read: Active repo - stable
              2023-12-27 20:02:38.170  - warn: admin.0 (884) Active repository "stable" cannot be read
              2023-12-27 20:02:38.290  - warn: admin.0 (884) Cannot update news: getaddrinfo EAI_AGAIN iobroker.live
              2023-12-27 20:02:38.303  - info: admin.0 (884) socket.io server listening on port 8081
              2023-12-27 20:02:38.304  - info: admin.0 (884) http server listening on port 8081
              2023-12-27 20:02:38.305  - info: admin.0 (884) Use link "http://127.0.0.1:8081" to configure.
              2023-12-27 20:02:38.310  - warn: admin.0 (884) Cannot update rating: getaddrinfo EAI_AGAIN rating.iobroker.net
              2023-12-27 20:02:40.787  - info: host.raspberrypi5 instance system.adapter.discovery.0 started with pid 942
              2023-12-27 20:02:41.564  - info: discovery.0 (942) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.17
              2023-12-27 20:02:44.784  - info: host.raspberrypi5 instance system.adapter.backitup.0 started with pid 964
              2023-12-27 20:02:45.485  - info: backitup.0 (964) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
              2023-12-27 20:02:45.513  - info: backitup.0 (964) [iobroker] backup will be activated at 02:48 every 1 day(s)
              2023-12-27 20:08:45.530  - info: admin.0 (884) failed connection to socket.io from ::ffff:192.168.1.10: Passport was not initialized
              2023-12-27 20:08:49.762  - info: admin.0 (884) ==> Connected system.user.admin from ::ffff:192.168.1.10
              2023-12-27 20:08:49.975  - info: host.raspberrypi5 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
              2023-12-27 20:09:09.982  - error: host.raspberrypi5 Error by updating repository "stable" under "http://download.iobroker.net/sources-dist.json": Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
              2023-12-27 20:09:36.578  - info: host.raspberrypi5 iobroker install deconz
              2023-12-27 20:09:37.292  - info: host.raspberrypi5 iobroker Update repository "stable" under "http://download.iobroker.net/sources-dist.json"
              2023-12-27 20:09:58.358  - info: host.raspberrypi5 iobroker exit 0
              Bild der Adapterwebseite
              Fehlermeldung
              So warum kommt dieser Fehler?? es lassen sich keine Adapter oder instanzen fertig installieren
                Homoran Global Moderator Administrators @Radix75 last edited by Homoran
                anscheinend hast du immer noch Probleme mit dem Zugriff aufs Internet
                kannst du diese Seite öffnen?
                bei mir klappt das einwandfrei
                  Radix75 @Homoran last edited by
                  @homoran said in Daikin Adapter:
                  Ich kann die Webseite im Browser am PC öffnen es kommt eine sehr große liste die ich hier nicht posten kann
                  Muss ich den Port 8081 in der Fritzbox freigeben????
                  R Homoran 2 Replies Last reply Reply Quote 0
                    Hab mal schon ein Prr Checks gemacht sag mal was dazu ob ein Fehler sichtbar ist
                    Radix1975@raspberrypi5:~ $ netstat -n -a -p TCP
                    (Not all processes could be identified, non-owned process info
                     will not be shown, you would have to be root to see it all.)
                    Active Internet connections (servers and established)
                    Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      -
                    tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      -
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      -
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      -
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      -
                    tcp        0      0 127.0.0.1:33806         127.0.0.1:9000          ESTABLISHED -
                    tcp        0      0 127.0.0.1:51980         127.0.0.1:9001          ESTABLISHED -
                    tcp        0      0 127.0.0.1:9001          127.0.0.1:50920         ESTABLISHED -
                    tcp        0      0 127.0.0.1:58100         127.0.0.1:9000          ESTABLISHED -
                    tcp        0      0 127.0.0.1:33808         127.0.0.1:9000          ESTABLISHED -
                    tcp        0      0 127.0.0.1:9001          127.0.0.1:50906         ESTABLISHED -
                    tcp        0      0 127.0.0.1:9001          127.0.0.1:50890         ESTABLISHED -
                    tcp        0      0 127.0.0.1:50888         127.0.0.1:9001          ESTABLISHED -
                    tcp        0      0 127.0.0.1:58128         127.0.0.1:9000          ESTABLISHED -
                    tcp        0      0 127.0.0.1:50890         127.0.0.1:9001          ESTABLISHED -
                    tcp        0      0 127.0.0.1:9000          127.0.0.1:58146         ESTABLISHED -
                    tcp        0      0 127.0.0.1:9000          127.0.0.1:58112         ESTABLISHED -
                    tcp        0      0 192.168.1.225:22        192.168.1.10:54425      ESTABLISHED -
                    tcp        0      0 127.0.0.1:9001          127.0.0.1:51942         ESTABLISHED -
                    tcp        0      0 127.0.0.1:9001          127.0.0.1:51976         ESTABLISHED -
                    tcp        0      0 127.0.0.1:50906         127.0.0.1:9001          ESTABLISHED -
                    tcp        0      0 127.0.0.1:9001          127.0.0.1:51960         ESTABLISHED -
                    tcp        0      0 127.0.0.1:9000          127.0.0.1:33778         ESTABLISHED -
                    tcp        0      0 127.0.0.1:9001          127.0.0.1:51956         ESTABLISHED -
                    tcp        0      0 127.0.0.1:9000          127.0.0.1:33808         ESTABLISHED -
                    tcp        0      0 127.0.0.1:58112         127.0.0.1:9000          ESTABLISHED -
                    tcp        0      0 127.0.0.1:50912         127.0.0.1:9001          ESTABLISHED -
                    tcp        0      0 127.0.0.1:50920         127.0.0.1:9001          ESTABLISHED -
                    tcp        0      0 127.0.0.1:9000          127.0.0.1:58100         ESTABLISHED -
                    tcp        0      0 127.0.0.1:58110         127.0.0.1:9000          ESTABLISHED -
                    tcp        0      0 127.0.0.1:51942         127.0.0.1:9001          ESTABLISHED -
                    tcp        0      0 127.0.0.1:9000          127.0.0.1:58110         ESTABLISHED -
                    tcp        0      0 127.0.0.1:58146         127.0.0.1:9000          ESTABLISHED -
                    tcp        0      0 127.0.0.1:58132         127.0.0.1:9000          ESTABLISHED -
                    tcp        0      0 127.0.0.1:9001          127.0.0.1:50912         ESTABLISHED -
                    tcp        0      0 127.0.0.1:50882         127.0.0.1:9001          ESTABLISHED -
                    tcp        0      0 127.0.0.1:51960         127.0.0.1:9001          ESTABLISHED -
                    tcp        0      0 127.0.0.1:9000          127.0.0.1:33806         ESTABLISHED -
                    tcp        0      0 127.0.0.1:9000          127.0.0.1:58128         ESTABLISHED -
                    tcp        0      0 127.0.0.1:9001          127.0.0.1:51980         ESTABLISHED -
                    tcp        0      0 127.0.0.1:51976         127.0.0.1:9001          ESTABLISHED -
                    tcp        0      0 127.0.0.1:33796         127.0.0.1:9000          ESTABLISHED -
                    tcp        0      0 127.0.0.1:9001          127.0.0.1:50888         ESTABLISHED -
                    tcp        0      0 127.0.0.1:9000          127.0.0.1:58132         ESTABLISHED -
                    tcp        0      0 127.0.0.1:9000          127.0.0.1:33796         ESTABLISHED -
                    tcp        0      0 127.0.0.1:33778         127.0.0.1:9000          ESTABLISHED -
                    tcp        0      0 127.0.0.1:9001          127.0.0.1:50882         ESTABLISHED -
                    tcp        0      0 127.0.0.1:9000          127.0.0.1:33780         ESTABLISHED -
                    tcp        0      0 127.0.0.1:33780         127.0.0.1:9000          ESTABLISHED -
                    tcp        0      0 127.0.0.1:51956         127.0.0.1:9001          ESTABLISHED -
                    tcp6       0      0 :::22                   :::*                    LISTEN      -
                    tcp6       0      0 :::5900                 :::*                    LISTEN      -
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      -
                    tcp6       0      0 :::8081                 :::*                    LISTEN      -
                    tcp6       0      0 192.168.1.225:8081      192.168.1.10:52751      TIME_WAIT   -
                    tcp6       0      0 192.168.1.225:8081      192.168.1.10:52749      TIME_WAIT   -
                    tcp6       0      0 192.168.1.225:8081      192.168.1.10:52752      TIME_WAIT   -
                    tcp6       0      0 192.168.1.225:8081      192.168.1.10:52753      TIME_WAIT   -
                    tcp6       0      0 192.168.1.225:8081      192.168.1.10:52750      TIME_WAIT   -
                    tcp6       0      0 192.168.1.225:8081      192.168.1.10:52748      TIME_WAIT   -
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           -
                    udp        0      0 0.0.0.0:48785           0.0.0.0:*                           -
                    udp        0      0 192.168.1.225:68        192.168.1.1:67          ESTABLISHED -
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           -
                    udp6       0      0 :::5353                 :::*                                -
                    udp6       0      0 :::36885                :::*                                -
                    udp6       0      0 fe80::1bc9:5af2:f2b:546 :::*                                -
                    raw6       0      0 :::58                   :::*                    7           -
                    Active UNIX domain sockets (servers and established)
                    Proto RefCnt Flags       Type       State         I-Node   PID/Program name     Path
                    unix  3      [ ]         STREAM     CONNECTED     15543    -                    /run/dbus/system_bus_socket
                    unix  3      [ ]         STREAM     CONNECTED     14587    -
                    unix  3      [ ]         STREAM     CONNECTED     34052    -
                    unix  2      [ ACC ]     STREAM     LISTENING     12098    -                    /run/avahi-daemon/socket
                    unix  2      [ ]         DGRAM      CONNECTED     14549    -
                    unix  3      [ ]         STREAM     CONNECTED     15839    -
                    unix  2      [ ACC ]     STREAM     LISTENING     12101    -                    /run/cups/cups.sock
                    unix  2      [ ]         DGRAM                    16828    989/systemd          /run/user/1000/systemd/notify
                    unix  2      [ ACC ]     STREAM     LISTENING     12103    -                    /run/dbus/system_bus_socket
                    unix  2      [ ACC ]     STREAM     LISTENING     16831    989/systemd          /run/user/1000/systemd/private
                    unix  2      [ ACC ]     STREAM     LISTENING     12105    -                    /run/thd.socket
                    unix  2      [ ACC ]     STREAM     LISTENING     16839    989/systemd          /run/user/1000/bus
                    unix  3      [ ]         STREAM     CONNECTED     17591    -                    /run/systemd/journal/stdout
                    unix  2      [ ACC ]     STREAM     LISTENING     16841    989/systemd          /run/user/1000/gnupg/S.dirmngr
                    unix  3      [ ]         STREAM     CONNECTED     16564    -                    /run/systemd/journal/stdout
                    unix  2      [ ACC ]     STREAM     LISTENING     16843    989/systemd          /run/user/1000/gnupg/S.gpg-agent.browser
                    unix  2      [ ]         DGRAM      CONNECTED     12242    -
                    unix  2      [ ACC ]     STREAM     LISTENING     16845    989/systemd          /run/user/1000/gnupg/S.gpg-agent.extra
                    unix  2      [ ACC ]     STREAM     LISTENING     16847    989/systemd          /run/user/1000/gnupg/S.gpg-agent.ssh
                    unix  3      [ ]         STREAM     CONNECTED     16833    989/systemd
                    unix  2      [ ACC ]     STREAM     LISTENING     16849    989/systemd          /run/user/1000/gnupg/S.gpg-agent
                    unix  3      [ ]         STREAM     CONNECTED     14795    -
                    unix  3      [ ]         STREAM     CONNECTED     15535    -
                    unix  3      [ ]         DGRAM      CONNECTED     14556    -
                    unix  2      [ ]         DGRAM      CONNECTED     17649    -
                    unix  3      [ ]         STREAM     CONNECTED     12148    -
                    unix  2      [ ]         DGRAM      CONNECTED     14600    -
                    unix  2      [ ]         STREAM     CONNECTED     34028    -
                    unix  3      [ ]         STREAM     CONNECTED     16545    -
                    unix  3      [ ]         DGRAM      CONNECTED     849      -
                    unix  3      [ ]         STREAM     CONNECTED     14776    -                    /run/systemd/journal/stdout
                    unix  3      [ ]         STREAM     CONNECTED     14840    -
                    unix  2      [ ]         DGRAM      CONNECTED     17651    -                    /tmp/.vncserver-license/0.832
                    unix  3      [ ]         STREAM     CONNECTED     15820    -
                    unix  2      [ ACC ]     STREAM     LISTENING     17671    -                    /tmp/.vnc-vncservice/vncserver-x11.CtrlComms
                    unix  3      [ ]         STREAM     CONNECTED     12155    -
                    unix  3      [ ]         STREAM     CONNECTED     15687    -
                    unix  3      [ ]         STREAM     CONNECTED     14592    -
                    unix  3      [ ]         STREAM     CONNECTED     16784    989/systemd
                    unix  3      [ ]         STREAM     CONNECTED     34053    -
                    unix  3      [ ]         STREAM     CONNECTED     15904    -                    /run/dbus/system_bus_socket
                    unix  2      [ ]         DGRAM      CONNECTED     16559    -
                    unix  3      [ ]         STREAM     CONNECTED     15762    -
                    unix  3      [ ]         STREAM     CONNECTED     14826    -
                    unix  3      [ ]         STREAM     CONNECTED     15541    -                    /run/dbus/system_bus_socket
                    unix  3      [ ]         STREAM     CONNECTED     15044    -
                    unix  3      [ ]         STREAM     CONNECTED     15542    -                    /run/dbus/system_bus_socket
                    unix  3      [ ]         DGRAM      CONNECTED     13460    -
                    unix  3      [ ]         STREAM     CONNECTED     17540    -
                    unix  3      [ ]         DGRAM      CONNECTED     14553    -
                    unix  3      [ ]         STREAM     CONNECTED     15838    -
                    unix  2      [ ]         DGRAM                    14794    -
                    unix  3      [ ]         STREAM     CONNECTED     14760    -
                    unix  3      [ ]         STREAM     CONNECTED     24830    -                    /run/systemd/journal/stdout
                    unix  3      [ ]         STREAM     CONNECTED     14950    -
                    unix  2      [ ]         DGRAM      CONNECTED     16805    989/systemd
                    unix  3      [ ]         STREAM     CONNECTED     16562    -
                    unix  2      [ ]         DGRAM      CONNECTED     844      -
                    unix  3      [ ]         STREAM     CONNECTED     14656    -                    /run/systemd/journal/stdout
                    unix  2      [ ]         DGRAM      CONNECTED     34039    -
                    unix  3      [ ]         STREAM     CONNECTED     15819    -
                    unix  3      [ ]         STREAM     CONNECTED     15544    -                    /run/dbus/system_bus_socket
                    unix  3      [ ]         STREAM     CONNECTED     14808    -                    /run/dbus/system_bus_socket
                    unix  3      [ ]         STREAM     CONNECTED     14595    -                    /run/systemd/journal/stdout
                    unix  2      [ ]         DGRAM      CONNECTED     14839    -
                    unix  2      [ ]         DGRAM      CONNECTED     17500    -
                    unix  3      [ ]         STREAM     CONNECTED     14779    -                    /run/systemd/journal/stdout
                    unix  3      [ ]         STREAM     CONNECTED     15856    -                    /run/dbus/system_bus_socket
                    unix  3      [ ]         STREAM     CONNECTED     12154    -
                    unix  2      [ ]         DGRAM      CONNECTED     15546    -
                    unix  3      [ ]         STREAM     CONNECTED     15761    -
                    unix  3      [ ]         STREAM     CONNECTED     14491    -                    /run/systemd/journal/stdout
                    unix  3      [ ]         STREAM     CONNECTED     14948    -
                    unix  3      [ ]         DGRAM      CONNECTED     13461    -
                    unix  3      [ ]         STREAM     CONNECTED     12160    -
                    unix  3      [ ]         STREAM     CONNECTED     16563    -                    /run/systemd/journal/stdout
                    unix  3      [ ]         DGRAM      CONNECTED     14554    -
                    unix  3      [ ]         STREAM     CONNECTED     14888    -
                    unix  2      [ ]         STREAM     CONNECTED     35867    -
                    unix  3      [ ]         STREAM     CONNECTED     15841    -
                    unix  3      [ ]         STREAM     CONNECTED     15547    -                    /run/dbus/system_bus_socket
                    unix  2      [ ]         DGRAM      CONNECTED     17784    -
                    unix  3      [ ]         STREAM     CONNECTED     12256    -
                    unix  3      [ ]         STREAM     CONNECTED     14813    -
                    unix  3      [ ]         STREAM     CONNECTED     16570    -                    /run/systemd/journal/stdout
                    unix  2      [ ]         DGRAM                    16656    -                    /run/wpa_supplicant/wlan0
                    unix  2      [ ]         DGRAM                    16661    -                    /run/wpa_supplicant/p2p-dev-wlan0
                    unix  3      [ ]         STREAM     CONNECTED     17454    -
                    unix  3      [ ]         STREAM     CONNECTED     853      -                    /run/systemd/journal/stdout
                    unix  3      [ ]         STREAM     CONNECTED     15588    -                    /run/dbus/system_bus_socket
                    unix  3      [ ]         STREAM     CONNECTED     15854    -                    /run/dbus/system_bus_socket
                    unix  3      [ ]         STREAM     CONNECTED     15818    -
                    unix  2      [ ]         STREAM     CONNECTED     17653    -
                    unix  3      [ ]         STREAM     CONNECTED     12145    -
                    unix  3      [ ]         DGRAM      CONNECTED     16830    989/systemd
                    unix  3      [ ]         STREAM     CONNECTED     15538    -
                    unix  3      [ ]         STREAM     CONNECTED     14596    -
                    unix  3      [ ]         STREAM     CONNECTED     16552    -
                    unix  3      [ ]         STREAM     CONNECTED     15902    -
                    unix  3      [ ]         STREAM     CONNECTED     15764    -
                    unix  2      [ ]         DGRAM      CONNECTED     14837    -
                    unix  2      [ ]         DGRAM      CONNECTED     12153    -
                    unix  2      [ ]         DGRAM      CONNECTED     16794    -
                    unix  3      [ ]         STREAM     CONNECTED     14588    -
                    unix  3      [ ]         STREAM     CONNECTED     16868    -
                    unix  2      [ ]         DGRAM      CONNECTED     15550    -
                    unix  3      [ ]         STREAM     CONNECTED     14891    -                    /run/systemd/journal/stdout
                    unix  3      [ ]         STREAM     CONNECTED     15586    -                    /run/dbus/system_bus_socket
                    unix  3      [ ]         STREAM     CONNECTED     17547    -
                    unix  3      [ ]         DGRAM      CONNECTED     14555    -
                    unix  3      [ ]         STREAM     CONNECTED     15840    -
                    unix  3      [ ]         STREAM     CONNECTED     15623    -
                    unix  3      [ ]         STREAM     CONNECTED     14996    -                    /run/dbus/system_bus_socket
                    unix  3      [ ]         STREAM     CONNECTED     15589    -                    /run/dbus/system_bus_socket
                    unix  3      [ ]         STREAM     CONNECTED     14488    -
                    unix  4      [ ]         DGRAM      CONNECTED     13459    -                    /run/systemd/notify
                    unix  2      [ ACC ]     STREAM     LISTENING     13462    -                    /run/systemd/private
                    unix  3      [ ]         STREAM     CONNECTED     15539    -
                    unix  3      [ ]         STREAM     CONNECTED     15903    -                    /run/systemd/journal/stdout
                    unix  3      [ ]         STREAM     CONNECTED     15817    -
                    unix  2      [ ACC ]     STREAM     LISTENING     13464    -                    /run/systemd/userdb/io.systemd.DynamicUser
                    unix  2      [ ACC ]     STREAM     LISTENING     13465    -                    /run/systemd/io.system.ManagedOOM
                    unix  2      [ ACC ]     STREAM     LISTENING     13476    -                    /run/systemd/fsck.progress
                    unix  3      [ ]         STREAM     CONNECTED     15719    -                    /run/dbus/system_bus_socket
                    unix  3      [ ]         STREAM     CONNECTED     14610    -                    /run/systemd/journal/stdout
                    unix  3      [ ]         DGRAM      CONNECTED     16829    989/systemd
                    unix  13     [ ]         DGRAM      CONNECTED     13480    -                    /run/systemd/journal/dev-log
                    unix  7      [ ]         DGRAM      CONNECTED     13482    -                    /run/systemd/journal/socket
                    unix  2      [ ACC ]     STREAM     LISTENING     13484    -                    /run/systemd/journal/stdout
                    unix  3      [ ]         STREAM     CONNECTED     14771    -                    /run/systemd/journal/stdout
                    unix  2      [ ACC ]     SEQPACKET  LISTENING     13486    -                    /run/udev/control
                    unix  3      [ ]         DGRAM      CONNECTED     850      -
                    unix  2      [ ]         DGRAM      CONNECTED     740      -
                    unix  2      [ ]         DGRAM      CONNECTED     13535    -
                    unix  3      [ ]         STREAM     CONNECTED     17508    -
                    unix  3      [ ]         STREAM     CONNECTED     15763    -
                    unix  3      [ ]         STREAM     CONNECTED     16633    -                    /run/dbus/system_bus_socket
                    unix  3      [ ]         STREAM     CONNECTED     14591    -                    /run/systemd/journal/stdout
                    unix  3      [ ]         STREAM     CONNECTED     15037    -                    /run/dbus/system_bus_socket
                    unix  3      [ ]         STREAM     CONNECTED     15873    -                    /run/systemd/journal/stdout
                    unix  2      [ ]         STREAM     CONNECTED     35894    -
                    unix  3      [ ]         STREAM     CONNECTED     24829    -
                    unix  3      [ ]         STREAM     CONNECTED     14657    -                    /run/systemd/journal/stdout
                    unix  3      [ ]         STREAM     CONNECTED     835      -
                    unix  2      [ ACC ]     STREAM     LISTENING     735      -                    /run/systemd/journal/io.systemd.journal
                    Radix1975@raspberrypi5:~ $ node -v
                    v18.19.0
                    Radix1975@raspberrypi5:~ $ npm -v
                    10.2.3
                    Radix1975@raspberrypi5:~ $ cd /opt/iobroker
                    iobroker list instances
                    + instance is alive
                    Radix1975@raspberrypi5:/opt/iobroker $ Radix1975@raspberrypi5:~ $ ps -A | grep iobroker
                        822 ?        00:02:44 iobroker.js-con
                    BLISHED    0      0 127.0.0.1:9000          127.0.0.1:33780         ESTABLISHED -
                      @radix75
                      Da läuft ein X und VNC drauf.
                      Schalt den Kram AUS!
                        unwichtig!
                        kommt der pi da ran?
                        anscheinend ja nicht
                          unwichtig!
                          mus ich die Webseite so wie unten aufrufen? Ich wies nicht wie das geht mit der Konsole
                          login as: Radix1975
                          Radix1975@192.168.1.225's password:
                          Linux raspberrypi5 6.1.0-rpi7-rpi-2712 #1 SMP PREEMPT Debian 1:6.1.63-1+rpt1 (20        23-11-24) aarch64
                          The programs included with the Debian GNU/Linux system are free software;
                          the exact distribution terms for each program are described in the
                          individual files in /usr/share/doc/*/copyright.
                          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                          permitted by applicable law.
                          Last login: Thu Dec 28 10:05:44 2023
                          Radix1975@raspberrypi5:~ $ http://download.iobroker.net/sources-dist.json
                          -bash: http://download.iobroker.net/sources-dist.json: No such file or directory
                            @radix75
                            ping6 download.iobroker.net
                            ping download.iobroker.net
                              @radix75
                              VNC hat der mir einfach installiert nachdem ich inb26525cf-7ba9-4cb3-88fc-9179435b923a-image.png
                              an gemacht habe
                              Was X ist weis ich nicht
                              Ich weis nicht mit welchen Konsolen Kommandos ich es Deinstallieren kann
                              R Thomas Braun 2 Replies Last reply Reply Quote 0
                                login as: Radix1975
                                Last login: Thu Dec 28 13:15:51 2023 from 192.168.1.10
                                Radix1975@raspberrypi5:~ $ ping6 download.iobroker.net
                                ping6: download.iobroker.net: Address family for hostname not supported
                                PING download.iobroker.net (93.90.206.45) 56(84) bytes of data.
                                ^C
                                --- download.iobroker.net ping statistics ---
                                29 packets transmitted, 0 received, 100% packet loss, time 28679ms
                                  @radix75
                                  Du sollst ja auch kein VNC anmachen!
                                  sudo systemctl set-default multi-user.target
                                  sudo reboot
                                  Trag mal die live-Repos ein. Siehe hier:
                                  echad@chet:~ $ iob repo list
                                  live-stable   : http://iobroker.live/repo/sources-dist.json
                                  live-beta     : http://iobroker.live/repo/sources-dist-latest.json
                                    @radix75
                                    Der host könnte aber gerade down sein. Hier geht der auch nicht.
                                    echad@chet:~ $ ping download.iobroker.net
                                    ^C
                                    16 packets transmitted, 0 received, 100% packet loss, time 15366ms
                                      @radix75
                                      ^C
                                      so oder wie was soll ich wo und wie eintragen kenne mich mit der Konsole nicht aus
                                      login as: Radix1975
                                      Last login: Thu Dec 28 13:31:01 2023 from 192.168.1.10
                                      Radix1975@raspberrypi5:~ $ echad@chet:~ $ iob repo list
                                      -bash: echad@chet:~: command not found
                                      Radix1975@raspberrypi5:~ $ Radix1975@raspberrypi5:~ $ echad@chet:~ $ iob repo li                                   st
                                      -bash: Radix1975@raspberrypi5:~: command not found
                                      -bash: -bash:: command not found
                                      -bash: beta: command not found
                                      -bash: live-stable: command not found
                                      -bash: live-beta: command not found
                                      -bash: stable: command not found
                                        wie
                                        in den Systemeinstellungen über den admin
                                          Radix75 @Homoran last edited by Radix75
                                          wie
                                          wenn ich die Adminseite in Broser neu öffne fehlen die gerade erst neu eingetragenen Repos wieder
                                          Homoran R 2 Replies Last reply Reply Quote 0
                                            hast du auch gespeichert?
                                            11408
