    4. hm-rpc Probleme
    hm-rpc Probleme
      Mephisto090 @Glasfaser last edited by
      @glasfaser said in hm-rpc Probleme:
      ist deine Liste gekürzt ...
      denn du nutzt Redis , ist der Redis Server außerhalb des Containers !?
      version: "3.4"
      services:
        iobroker:
          container_name: Iobroker
          image: buanet/iobroker:latest
          pull_policy: always
          hostname: iobroker
          restart: always
          labels:
            - "autoheal=true"
            - "com.centurylinklabs.watchtower.enable=true"
          healthcheck:
            test: ["CMD", "curl", "-f", "http://localhost:8081"]
            interval: 30s
            timeout: 2s
            retries: 2
            start_period: 3m30s
          networks:
            io-network:
              ipv4_address: 172.18.0.2
          ports:
            - "1884:1884"
            - "8081-8083:8081-8083"
            - "8400:8400"
            - "42010:42010"
            - "2010:2010"
          environment:
            - IOB_STATESDB_HOST=iobroker-redis
            - IOB_STATESDB_PORT=6379
            - IOB_STATESDB_TYPE=redis
            - IOB_BACKITUP_EXTDB=true
            - PACKAGES=default-mysql-client redis-tools
            - TZ=Europe/Berlin
          volumes:
            - io-data:/opt/iobroker
            - userscripts:/opt/userscripts
          depends_on:
            redis:
              condition: service_healthy
          #mem_swappiness: -1
        redis:
          container_name: Iobroker-Redis
          image: redis:7
          hostname: iobroker-redis
          restart: always
          labels:
            - "autoheal=true"
          healthcheck:
            test: [ "CMD", "redis-cli", "--raw", "incr", "ping" ]
            interval: 30s
            timeout: 2s
            retries: 2
            start_period: 20s
          networks:
            io-network:
              ipv4_address: 172.18.0.3
          volumes:
            - redis-data:/data
          #mem_swappiness: -1
        deconz:
          image: deconzcommunity/deconz:stable
          container_name: Iobroker-Deconz
          hostname: iobroker-deconz
          pull_policy: always
          restart: always
          privileged: true                # This is important! Without it, the deCONZ image won't be able to connect to Conbee II.
          ports:
            - 4080:80
            - 4443:443
            - 5900:5900
          volumes:
            - /etc/localtime:/etc/localtime:ro
            - deconz:/opt/deCONZ
          devices:
            - /dev/ttyACM0                # This is the USB device that Conbee II is running on.
          environment:
            - TZ=Europe/Berlin
            - DECONZ_WEB_PORT=80
            - DECONZ_WS_PORT=443
            - DEBUG_INFO=1
            - DEBUG_APS=0
            - DEBUG_ZCL=0
            - DEBUG_ZDP=0
            - DEBUG_OTA=0
            - DEBUG_HTTP=0
            - DECONZ_DEVICE=/dev/ttyACM0   # This is the USB device that Conbee II is running on.
            - DECONZ_START_VERBOSE=0
            - DECONZ_VNC_MODE=1
            - DECONZ_VNC_PORT=5900
            - DECONZ_VNC_PASSWORD=*****
          logging:
            driver: "json-file"
            options:
              max-size: "50m"
          networks:
            io-network:
              ipv4_address: 172.18.0.4
      volumes:
        userscripts:
        io-data:
        redis-data:
        deconz:
      networks:
        io-network:
          driver: bridge
          ipam:
            config:
              - subnet: 172.18.0.0/16
                gateway: 172.18.0.1
                ip_range: 172.18.0.1/24
        @mephisto090
        Stelle mal so ein :
        geht leider auch nicht. Weder mit 2010 noch mit 42010
        hm-rpc.0
        2023-12-22 19:32:15.234	error	Cannot call init: [http://192.168.178.61:42010, ""] Unknown XML-RPC tag 'TITLE'
        hm-rpc.0
        2023-12-22 19:31:47.641	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
        hm-rpc.0
        2023-12-22 19:31:10.669	error	Cannot call init: [http://192.168.178.61:2010, ""] Unknown XML-RPC tag 'TITLE'
        hm-rpc.0
        2023-12-22 19:30:52.378	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
        hm-rpc.0
        2023-12-22 19:30:18.613	error	Cannot call init: [http://192.168.178.61:2010, ""] Unknown XML-RPC tag 'TITLE'
        hm-rpc.0
        2023-12-22 19:30:18.591	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
        hm-rpc.0
        2023-12-22 19:29:48.600	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
          Homoran Global Moderator Administrators @Mephisto090 last edited by Homoran
          @mephisto090 sagte in hm-rpc Probleme:
          Diese Meldung kommt von der CCU, wenn sie im Bluescreen steht.
          Entweder noch im Booten, oder nicht richtig eingeloggt.
          Muss etwas mit den Credentials zu tun haben
          was steht im syslog der CCU?
            Mephisto090 @Homoran last edited by
            @homoran said in hm-rpc Probleme:
            Der ist lang. Welche stelle willst du haben 🙂
              zu der Zeit wenn der Adapter versucht sich zu verbinden
              ubecker 1 Reply Last reply Reply Quote 0
              • ubecker
                ubecker @Homoran last edited by
                @homoran ich rate mal, da steht stack overflow. Mal sehen ob ich Recht habe
                  Mephisto090 @ubecker last edited by Mephisto090
                  @ubecker said in hm-rpc Probleme:
                  ***** /var/log/lighttpd-access.log *****
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:43:31 +0100] "POST /esp/system.htm?sid=@Do7MDgegvv@&action=UpdateUI HTTP/2.0" 200 871 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:43:33 +0100] "POST /api/homematic.cgi HTTP/2.0" 200 45 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:43:34 +0100] "POST /esp/system.htm?sid=@Do7MDgegvv@&action=UpdateUI HTTP/2.0" 200 871 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:43:38 +0100] "POST /esp/system.htm?sid=@Do7MDgegvv@&action=UpdateUI HTTP/2.0" 200 871 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:43:38 +0100] "POST /api/homematic.cgi HTTP/2.0" 200 45 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:43:40 +0100] "POST /esp/system.htm?sid=@Do7MDgegvv@&action=UpdateUI HTTP/2.0" 200 871 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:43:43 +0100] "POST /api/homematic.cgi HTTP/2.0" 200 45 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:43:43 +0100] "POST /esp/system.htm?sid=@Do7MDgegvv@&action=UpdateUI HTTP/2.0" 200 871 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:43:47 +0100] "POST /esp/system.htm?sid=@Do7MDgegvv@&action=UpdateUI HTTP/2.0" 200 871 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:43:48 +0100] "POST /api/homematic.cgi HTTP/2.0" 200 45 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:43:49 +0100] "POST /esp/system.htm?sid=@Do7MDgegvv@&action=UpdateUI HTTP/2.0" 200 871 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:43:53 +0100] "POST /esp/system.htm?sid=@Do7MDgegvv@&action=UpdateUI HTTP/2.0" 200 871 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:43:53 +0100] "POST /api/homematic.cgi HTTP/2.0" 200 45 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.61 192.168.178.96:42010 - [28/Dec/2023:10:44:00 +0100] "POST / HTTP/1.1" 401 347 "-" "NodeJS XML-RPC Client"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:44:02 +0100] "POST /api/homematic.cgi HTTP/2.0" 200 47 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.61 192.168.178.96:42010 - [28/Dec/2023:10:44:14 +0100] "POST / HTTP/1.1" 401 347 "-" "NodeJS XML-RPC Client"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:44:18 +0100] "POST /esp/system.htm?sid=@Do7MDgegvv@&action=UpdateUI HTTP/2.0" 200 871 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:44:18 +0100] "POST /api/homematic.cgi HTTP/2.0" 200 45 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:44:19 +0100] "POST /esp/system.htm?sid=@Do7MDgegvv@&action=UpdateUI HTTP/2.0" 200 871 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:44:20 +0100] "POST /config/cp_maintenance.cgi?sid=@Do7MDgegvv@ HTTP/2.0" 200 17 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:44:22 +0100] "POST /esp/system.htm?sid=@Do7MDgegvv@&action=UpdateUI HTTP/2.0" 200 871 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:44:22 +0100] "POST /api/homematic.cgi HTTP/2.0" 200 45 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:44:23 +0100] "POST /config/cp_maintenance.cgi?sid=@Do7MDgegvv@ HTTP/2.0" 200 14528 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:44:23 +0100] "POST /api/homematic.cgi HTTP/2.0" 200 154 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:44:25 +0100] "POST /esp/system.htm?sid=@Do7MDgegvv@&action=UpdateUI HTTP/2.0" 200 871 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:44:25 +0100] "GET /pages/index.htm?sid=@Do7MDgegvv@ HTTP/2.0" 200 11638 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:44:25 +0100] "GET /webui/css/extern/nfs_datepicker.css HTTP/2.0" 200 2685 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  192.168.178.59 homematic-raspi - [28/Dec/2023:10:44:25 +0100] "GET /webui/css/extern/jquery.powertip.css HTTP/2.0" 200 1572 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"
                  ***** /var/log/lighttpd-error.log *****
                  2023-12-22 22:55:27: (../src/server.c.1704) server started (lighttpd/1.4.69)
                  2023-12-22 22:56:00: (../src/server.c.1057) [note] graceful shutdown started
                  2023-12-22 22:56:00: (../src/server.c.1014) [note] pid 1865 continuing to handle 0 connection(s) in progress
                  2023-12-22 22:56:00: (../src/server.c.1704) server started (lighttpd/1.4.69)
                  2023-12-22 22:56:00: (../src/server.c.2078) server stopped by UID = 0 PID = 1521
                  2023-12-28 10:44:00: (../src/mod_auth.c.850) password doesn't match for / username: Y\rTKVYU\x14 IP: 192.168.178.61
                  2023-12-28 10:44:14: (../src/mod_auth.c.850) password doesn't match for / username: Y\rTKVYU\x14 IP: 192.168.178.61
                  So Weihnachten ist nun rum und jetzt hatte ich zeit euch mal den Log zu senden. 😄
                  Ich musste den Log stark einkürzen und deswegen nur die stelle wo XML-RPC auftaucht.
                  Ich habe noch ein Log gefunden wo er schreibt password doesn't match was aber eigentlich nicht stimmen kann, da ich das Passwort eins zu eins kopiert habe und sogar schon mal ein User mit Benutzername Test und Passwort Test angelegt hatte.
                  Y\rTKVYU\x14 Das ist irgendwie auch nicht der Username mit dem ich mich versuche einzuloggen, wie man weiter oben auf den Bildern sehen kann. Es kann natürlich sein, dass er im Log verschlüsselt wird.
                  @Bluefox wenn ich das richtig gesehen habe ist dies ja auch dein Adapter. Hast du eine Idee ob es ein Bug vom Adapter sein könnte?
                    nicht richtig.
                    interessant ist alles
                    @homoran sagte in hm-rpc Probleme:
                    was nicht kann sein, was nicht sein darf???
                    logs lügen nicht
                    der steht im rpc Adapter! und muss auf der CCU auch entsprechend existieren.
                    nein
                      Angelegt ist er
                      nicht richtig.
                      Habe 5MB Log. Leider kann ich die nicht hier rein packen oder hast du eine Idee?
                        hast du eine Idee?
                        nicht aus dem Zusammenhang reissen!
                          hast du eine Idee?
                          ich starte jetzt die Zentrale neu und versuche somit den Log klein zu halten
                          M Homoran 2 Replies Last reply Reply Quote 0
                            Mephisto090 @Mephisto090 last edited by
                            @mephisto090 said in hm-rpc Probleme:
                            hast du eine Idee?
                            homematic-raspi-2023-12-28 (4).log
                              wieso?
                              starte die Instanz neu und kopiere nur den entsprechenden Zeitbeteich hier in code-tags rein
                                hast du eine Idee?
                                wieso?
                                Dafür hast jetzt den ganzen Log 🙂
                                Glasfaser Homoran 2 Replies Last reply Reply Quote 0
                                • Glasfaser
                                  Glasfaser @Mephisto090 last edited by
                                  Erlich .... nicht jeder kann so eine Texdatei öffnen ... !?
                                  Teste mit einem Ping bzw. ob auch der Port erreichbar ist
                                  ioBrocker Docker > Raspberry
                                    Ich habe jetzt auch mal den Benutzer und Passwort geändert.
                                    2023-12-28 12:06:47: (../src/server.c.1704) server started (lighttpd/1.4.69)
                                    2023-12-28 12:06:54: (../src/gw_backend.c.274) establishing connection failed: socket: tcp:127.0.0.1:8183: Connection refused
                                    2023-12-28 12:06:54: (../src/gw_backend.c.960) all handlers for /esp/system.htm?sid=@Do7MDgegvv@&action=UpdateUI on  are down.
                                    2023-12-28 12:06:56: (../src/gw_backend.c.351) gw-server re-enabled: tcp:127.0.0.1:8183 127.0.0.1 8183
                                    2023-12-28 12:07:01: (../src/mod_authn_rega.c.234) could not receive auth answer from rega
                                    2023-12-28 12:07:01: (../src/mod_auth.c.850) password doesn't match for /api/notready.cgi username: Y\rTKVYU\x14 IP: 192.168.178.61
                                    2023-12-28 12:07:18: (../src/server.c.1057) [note] graceful shutdown started
                                    2023-12-28 12:07:18: (../src/server.c.1014) [note] pid 1868 continuing to handle 1 connection(s) in progress
                                    2023-12-28 12:07:18: (../src/server.c.1704) server started (lighttpd/1.4.69)
                                    2023-12-28 12:07:27: (../src/server.c.2078) server stopped by UID = 0 PID = 1518
                                    2023-12-28 12:07:31: (../src/mod_auth.c.850) password doesn't match for / username: Y\rTKVYU\x14 IP: 192.168.178.61
                                    2023-12-28 12:07:32: (../src/mod_auth.c.850) password doesn't match for / username: Y\rTKVYU\x14 IP: 192.168.178.61
                                    2023-12-28 12:08:35: (../src/mod_auth.c.850) password doesn't match for / username: Y\rTKVYU\x14 IP: 192.168.178.61
                                    2023-12-28 12:09:05: (../src/mod_auth.c.850) password doesn't match for / username: Y\rTKVYU\x14 IP: 192.168.178.61
                                    2023-12-28 12:10:08: (../src/mod_auth.c.850) password doesn't match for / username: Y\rTKVYU\x14 IP: 192.168.178.61
                                    2023-12-28 12:10:38: (../src/mod_auth.c.850) password doesn't match for / username: Y\rTKVYU\x14 IP: 192.168.178.61
                                    2023-12-28 12:11:15: (../src/mod_auth.c.850) password doesn't match for / username: Y\rTKVYU\x14 IP: 192.168.178.61
                                    2023-12-28 13:40:20: (../src/mod_auth.c.850) password doesn't match for / username: D\x07EM IP: 192.168.178.61
                                    ich bekomme immer als errormeldung password doesn't match for / username:
                                    • Glasfaser
                                      Glasfaser @Mephisto090 last edited by Glasfaser
                                      @mephisto090
                                      Hast du es so ... also alles leer lassen !?
                                      Edit
                                      und Benutzer Passwort .. hierbei leer
                                      M 3 Replies Last reply Reply Quote 0
                                        Mephisto090 @Glasfaser last edited by Mephisto090
                                        @mephisto090
                                        Nein, ich habe im Raspberrmatic (Siehe Bild) dies hier so eingestellt und im iobroker (Siehe Bild) Benutzername und Passwort angeben.
                                          @glasfaser ohne den hacken bei RaspberryMatic und ohne Benutzerdaten im iobroker habe ich eine verbindung
                                            @glasfaser jetzt habe ich zwar Daten aber die sind irgendwie alle default.
                                            6072
