    4. hm-rpc Probleme
    hm-rpc Probleme
      Mephisto090 @Glasfaser last edited by
      Ich habe jetzt auch mal den Benutzer und Passwort geändert.
      ***** /var/log/lighttpd-error.log *****
      2023-12-28 12:06:47: (../src/server.c.1704) server started (lighttpd/1.4.69)
      2023-12-28 12:06:54: (../src/gw_backend.c.274) establishing connection failed: socket: tcp:127.0.0.1:8183: Connection refused
      2023-12-28 12:06:54: (../src/gw_backend.c.960) all handlers for /esp/system.htm?sid=@Do7MDgegvv@&action=UpdateUI on  are down.
      2023-12-28 12:06:56: (../src/gw_backend.c.351) gw-server re-enabled: tcp:127.0.0.1:8183 127.0.0.1 8183
      2023-12-28 12:07:01: (../src/mod_authn_rega.c.234) could not receive auth answer from rega
      2023-12-28 12:07:01: (../src/mod_auth.c.850) password doesn't match for /api/notready.cgi username: Y\rTKVYU\x14 IP: 192.168.178.61
      2023-12-28 12:07:18: (../src/server.c.1057) [note] graceful shutdown started
      2023-12-28 12:07:18: (../src/server.c.1014) [note] pid 1868 continuing to handle 1 connection(s) in progress
      2023-12-28 12:07:18: (../src/server.c.1704) server started (lighttpd/1.4.69)
      2023-12-28 12:07:27: (../src/server.c.2078) server stopped by UID = 0 PID = 1518
      2023-12-28 12:07:31: (../src/mod_auth.c.850) password doesn't match for / username: Y\rTKVYU\x14 IP: 192.168.178.61
      2023-12-28 12:07:32: (../src/mod_auth.c.850) password doesn't match for / username: Y\rTKVYU\x14 IP: 192.168.178.61
      2023-12-28 12:08:35: (../src/mod_auth.c.850) password doesn't match for / username: Y\rTKVYU\x14 IP: 192.168.178.61
      2023-12-28 12:09:05: (../src/mod_auth.c.850) password doesn't match for / username: Y\rTKVYU\x14 IP: 192.168.178.61
      2023-12-28 12:10:08: (../src/mod_auth.c.850) password doesn't match for / username: Y\rTKVYU\x14 IP: 192.168.178.61
      2023-12-28 12:10:38: (../src/mod_auth.c.850) password doesn't match for / username: Y\rTKVYU\x14 IP: 192.168.178.61
      2023-12-28 12:11:15: (../src/mod_auth.c.850) password doesn't match for / username: Y\rTKVYU\x14 IP: 192.168.178.61
      2023-12-28 13:40:20: (../src/mod_auth.c.850) password doesn't match for / username: D\x07EM IP: 192.168.178.61
      ich bekomme immer als errormeldung password doesn't match for / username:
      @glasfaser said in hm-rpc Probleme:
      @mephisto090 sagte in hm-rpc Probleme:
      Dafür hast jetzt den ganzen Log
      Erlich .... nicht jeder kann so eine Texdatei öffnen ... !?
      Teste mit einem Ping bzw. ob auch der Port erreichbar ist
      ioBrocker Docker > Raspberry
      • Glasfaser
        Glasfaser @Mephisto090 last edited by Glasfaser
        @mephisto090
        Hast du es so ... also alles leer lassen !?
        Edit
        und Benutzer Passwort .. hierbei leer
        M 3 Replies Last reply Reply Quote 0
          Mephisto090 @Glasfaser last edited by Mephisto090
          @mephisto090
          Nein, ich habe im Raspberrmatic (Siehe Bild) dies hier so eingestellt und im iobroker (Siehe Bild) Benutzername und Passwort angeben.
            @glasfaser ohne den hacken bei RaspberryMatic und ohne Benutzerdaten im iobroker habe ich eine verbindung
              @glasfaser jetzt habe ich zwar Daten aber die sind irgendwie alle default.
              • Glasfaser
                Super ... 🙂
                • Glasfaser
                  @mephisto090
                  Warum diese Briefmarke ... kann man schlecht darauz Ziteren .
                  Warum 42010 du hast doch kein Https
                    @glasfaser ich habe es bereits auf HTTP geändert. Ich bekomme trotzdem keinen Daten.
                    hm-rpc.0
                    2023-12-28 14:40:40.615	info	new HMIP devices/channels after filter: 0
                    hm-rpc.0
                    2023-12-28 14:40:40.564	info	xmlrpc <- newDevices 63
                    hm-rpc.0
                    2023-12-28 14:40:40.371	info	xmlrpc -> 0 devices
                    hm-rpc.0
                    2023-12-28 14:40:40.254	info	xmlrpc <- listDevices ["iobroker:hm-rpc.0:ea729473514afae076d1c8e7423b20ed"]
                    hm-rpc.0
                    2023-12-28 14:40:40.234	info	Connected
                    hm-rpc.0
                    2023-12-28 14:40:40.178	info	xmlrpc client is trying to connect to homematic-raspi:2010/ with ["http://192.168.178.61:2010","iobroker:hm-rpc.0:ea729473514afae076d1c8e7423b20ed"]
                    hm-rpc.0
                    2023-12-28 14:40:40.177	info	xmlrpc server is trying to listen on 172.18.0.2:2010
                    hm-rpc.0
                    2023-12-28 14:40:39.966	info	starting. Version 1.15.19 (non-npm: ioBroker/ioBroker.hm-rpc) in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.16
                    hm-rpc.0
                    2023-12-28 14:40:34.575	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    hm-rpc.0
                    2023-12-28 14:40:34.574	info	terminating
                    hm-rpc.0
                    2023-12-28 14:40:34.574	info	Disconnected
                    hm-rpc.0
                    2023-12-28 14:40:34.552	info	xmlrpc -> homematic-raspi:2010/ init ["http://192.168.178.61:2010",""]
                    hm-rpc.0
                    2023-12-28 14:40:34.551	info	Got terminate signal TERMINATE_YOURSELF
                    hm-rpc.0
                    2023-12-28 14:40:34.540	info	Restarting now, because we had a forced reinitialization run
                    hm-rpc.0
                    2023-12-28 14:40:34.504	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:50","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:34.477	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:49","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:34.442	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:48","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:34.419	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:47","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:34.384	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:46","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:34.358	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:45","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:34.332	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:44","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:34.303	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:43","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:34.274	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:42","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:34.239	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:41","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:34.214	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:40","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:34.190	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:39","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:34.163	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:38","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:34.134	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:37","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:34.102	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:36","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:34.055	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:35","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:34.027	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:34","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.998	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:33","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.964	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:32","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.930	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:31","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.900	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:30","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.870	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:29","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.833	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:28","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.809	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:27","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.774	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:26","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.747	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:25","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.716	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:24","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.686	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:23","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.651	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:22","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.623	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:21","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.582	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:20","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.550	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:19","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.522	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:18","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.492	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:17","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.462	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:16","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.436	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:15","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.409	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:14","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.381	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:13","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.353	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:12","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.323	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:11","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.292	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:10","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.257	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:9","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.224	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:8","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.111	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:7","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.067	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:6","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.039	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:5","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:33.008	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:4","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:32.974	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:3","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:32.949	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:2","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:32.915	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:1","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:32.899	info	xmlrpc -> getParamsetDescription ["HmIP-RCV-1:0","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:32.826	info	xmlrpc -> getParamsetDescription ["000420C9A17AB8:0","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:32.807	info	xmlrpc -> getParamsetDescription ["00395F29B1C60E:7","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:32.788	info	xmlrpc -> getParamsetDescription ["00395F29B1C60E:6","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:32.771	info	xmlrpc -> getParamsetDescription ["00395F29B1C60E:5","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:32.753	info	xmlrpc -> getParamsetDescription ["00395F29B1C60E:4","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:32.730	info	xmlrpc -> getParamsetDescription ["00395F29B1C60E:3","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:32.710	info	xmlrpc -> getParamsetDescription ["00395F29B1C60E:2","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:32.428	info	xmlrpc -> getParamsetDescription ["00395F29B1C60E:1","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:32.328	info	xmlrpc -> getParamsetDescription ["00395F29B1C60E:0","VALUES"]
                    hm-rpc.0
                    2023-12-28 14:40:32.117	warn	No image for "HmIP-RFUSB" found.
                    hm-rpc.0
                    2023-12-28 14:40:32.047	info	xmlrpc <- newDevices 63
                    hm-rpc.0
                    2023-12-28 14:40:31.839	info	xmlrpc -> 0 devices
                    hm-rpc.0
                    2023-12-28 14:40:31.786	info	xmlrpc <- listDevices ["iobroker:hm-rpc.0:bc1d4067c78ee25c68e4963e726da3e0"]
                    hm-rpc.0
                    2023-12-28 14:40:31.770	info	Connected
                    hm-rpc.0
                    2023-12-28 14:40:31.727	info	xmlrpc client is trying to connect to homematic-raspi:2010/ with ["http://192.168.178.61:2010","iobroker:hm-rpc.0:bc1d4067c78ee25c68e4963e726da3e0"]
                    hm-rpc.0
                    2023-12-28 14:40:31.726	info	xmlrpc server is trying to listen on 172.18.0.2:2010
                    hm-rpc.0
                    2023-12-28 14:40:31.527	info	starting. Version 1.15.19 (non-npm: ioBroker/ioBroker.hm-rpc) in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.16
                      Super ... 🙂
                      Da hast du recht. Danke schon mal bis dahin 🙂 Jetzt bleibt natürlich die Frage warum er keine aktuellen Daten zieht. 😞
                      ubecker 1 Reply Last reply Reply Quote 0
                      • Glasfaser
                        kein Namen .. gib mal die IP ein
                        • ubecker
                          ubecker @Mephisto090 last edited by
                          @mephisto090 mit aktuellen Daten meinst du die Daten aus deinem Post vorher oder? Das sind Daten der Config von deinem HM Gerät. Dise werden erst dann aktuell wenn das Gerät neu sendet.
                          Wenn du die State betrachtest und einen Wert änderst wird dieser seine Farbe ändern.
                          Hier ein Beispiel von einem Handsender.
                          Eine Taste hat alle Zustände bestätigt und eine Taste noch nicht. Da diese noch nie so benutzt wurde
                          • Glasfaser
                            Glasfaser @ubecker last edited by Glasfaser
                            @ubecker sagte in hm-rpc Probleme:
                            Das ist aber ganz was anderes .( Dazu wird noch zusätzlich ein Dummy Skript gebraucht.)
                            Er hat ein Raumthermostat
                              Homoran Global Moderator Administrators @Mephisto090 last edited by
                              nöö, damit hab ich auf dem Handy
                              nix
                                @mephisto090 ehrlich?
                                gibt es einen User iobroker auf der RM?
                                @homoran said in hm-rpc Probleme:
                                der steht im rpc Adapter! und muss auf der CCU auch entsprechend existieren.
                                Angelegt ist er
                                wo?
                                  ich habe jetzt die IP eingeben und bekomme Werte und kann z.b. auch den Boostmode aktivieren, was auch das Thermoastat mitbekommt. Ich schaue mal ob es jetzt funktioniert. Danke an alle bis hier hin 🙂
                                  Mich wundert nur immer noch warum ich mich nicht mit einem Benutzer anmelden kann?
                                    dann beantworte doch mal die Fragen!
                                    @homoran sagte in hm-rpc Probleme:
                                    Angelegt ist er
                                    wo?
                                    • Glasfaser
                                      Bitte beim nächsten mal auch bei Threaderstellung mit angeben, das du ein Issues eröffnest hast !
                                      // vor 2 Wochen
                                      https://github.com/ioBroker/ioBroker.hm-rpc/issues/1092
                                      Mephisto090 created this issue in ioBroker/ioBroker.hm-rpc
                                      open Keine Inhalte #1092
                                        Mephisto090 @Homoran last edited by Mephisto090
                                        was meinst du mit RM?
                                        // vor 2 Wochen
                                        Alles klar
                                          RaspberryMatic
                                            RaspberryMatic
                                            Ja auf dem Bild sieht man das der Benutzer nagelegt ist. Ich hatte es auch mal mit test (12345) angelegt und probiert. Ging auch nicht
                                            6072
