vermurkste Installation
ping6 download.iobroker.net ping download.iobroker.net -
@thomas-braun said in Daikin Adapter:
Da läuft ein X und VNC drauf.
Schalt den Kram AUS!VNC hat der mir einfach installiert nachdem ich in
an gemacht habe
Was X ist weis ich nicht
Ich weis nicht mit welchen Konsolen Kommandos ich es Deinstallieren kann -
ping download.iobroker.netlogin as: Radix1975 Radix1975@192.168.1.225's password: Linux raspberrypi5 6.1.0-rpi7-rpi-2712 #1 SMP PREEMPT Debian 1:6.1.63-1+rpt1 (20 23-11-24) aarch64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Thu Dec 28 13:15:51 2023 from 192.168.1.10 Radix1975@raspberrypi5:~ $ ping6 download.iobroker.net ping download.iobroker.net ping6: download.iobroker.net: Address family for hostname not supported PING download.iobroker.net (93.90.206.45) 56(84) bytes of data. ^C --- download.iobroker.net ping statistics --- 29 packets transmitted, 0 received, 100% packet loss, time 28679ms Radix1975@raspberrypi5:~ $ -
Du sollst ja auch kein VNC anmachen!
sudo systemctl set-default multi-user.target sudo rebootTrag mal die live-Repos ein. Siehe hier:
echad@chet:~ $ iob repo list beta : http://download.iobroker.net/sources-dist-latest.json live-stable : http://iobroker.live/repo/sources-dist.json live-beta : http://iobroker.live/repo/sources-dist-latest.json stable : http://download.iobroker.net/sources-dist.json -
Der host könnte aber gerade down sein. Hier geht der auch nicht.
echad@chet:~ $ ping download.iobroker.net PING download.iobroker.net (93.90.206.45) 56(84) bytes of data. ^C --- download.iobroker.net ping statistics --- 16 packets transmitted, 0 received, 100% packet loss, time 15366ms -
echad@chet:~ $ ping download.iobroker.net PING download.iobroker.net (93.90.206.45) 56(84) bytes of data. ^C --- download.iobroker.net ping statistics --- 16 packets transmitted, 0 received, 100% packet loss, time 15366msso oder wie was soll ich wo und wie eintragen kenne mich mit der Konsole nicht aus
login as: Radix1975 Radix1975@192.168.1.225's password: Linux raspberrypi5 6.1.0-rpi7-rpi-2712 #1 SMP PREEMPT Debian 1:6.1.63-1+rpt1 (20 23-11-24) aarch64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Thu Dec 28 13:31:01 2023 from 192.168.1.10 Radix1975@raspberrypi5:~ $ echad@chet:~ $ iob repo list -bash: echad@chet:~: command not found Radix1975@raspberrypi5:~ $ Radix1975@raspberrypi5:~ $ echad@chet:~ $ iob repo li st -bash: echad@chet:~: command not found Radix1975@raspberrypi5:~ $ -bash: Radix1975@raspberrypi5:~: command not found -bash: -bash:: command not found -bash: Radix1975@raspberrypi5:~: command not found Radix1975@raspberrypi5:~ $ echad@chet:~ $ iob repo list beta : http://download.iobroker.net/sources-dist-latest.json live-stable : http://iobroker.live/repo/sources-dist.json live-beta : http://iobroker.live/repo/sources-dist-latest.json stable : http://download.iobroker.net/sources-dist.json -bash: echad@chet:~: command not found -bash: beta: command not found -bash: live-stable: command not found -bash: live-beta: command not found -bash: stable: command not found Radix1975@raspberrypi5:~ $ -
@homoran said in Daikin Adapter:
@radix75 sagte in Daikin Adapter:
wie
in den Systemeinstellungen über den admin
wenn ich die Adminseite in Broser neu öffne fehlen die gerade erst neu eingetragenen Repos wieder
live-beta : http://iobroker.live/repo/sources-dist-latest.json -
hast du auch gespeichert?
beta kommt auch der Fehler
@radix75 said in Daikin Adapter:
ja habe gespeichert sollten also 4 Repos sein bleiben aber nur immer 2 drin
natürlich!
@thomas-braun sagte in Daikin Adapter:
ist ja der selbe Server
und wenn du die änderst?
das steht vorne
wenn ich über den Schraubenschlüssel die Repos öffne kommen nur 2
Hab mal die Admin Seite in anderen browser geöffnet
login as: Radix1975 Radix1975@192.168.1.225's password: Linux raspberrypi5 6.1.0-rpi7-rpi-2712 #1 SMP PREEMPT Debian 1:6.1.63-1+rpt1 (20 23-11-24) aarch64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Thu Dec 28 13:31:01 2023 from 192.168.1.10 Radix1975@raspberrypi5:~ $ echad@chet:~ $ iob repo list -bash: echad@chet:~: command not found Radix1975@raspberrypi5:~ $ Radix1975@raspberrypi5:~ $ echad@chet:~ $ iob repo li st -bash: echad@chet:~: command not found Radix1975@raspberrypi5:~ $ -bash: Radix1975@raspberrypi5:~: command not found -bash: -bash:: command not found -bash: Radix1975@raspberrypi5:~: command not found Radix1975@raspberrypi5:~ $ echad@chet:~ $ iob repo list beta : http://download.iobroker.net/sources-dist-latest.json live-stable : http://iobroker.live/repo/sources-dist.json live-beta : http://iobroker.live/repo/sources-dist-latest.json stable : http://download.iobroker.net/sources-dist.json -bash: echad@chet:~: command not found -bash: beta: command not found -bash: live-stable: command not found -bash: live-beta: command not found -bash: stable: command not found Radix1975@raspberrypi5:~ $ ^C Radix1975@raspberrypi5:~ $ --- **download.iobroker.net** ping statistics --- -bash: ---: command not found Radix1975@raspberrypi5:~ $ download.iobroker.net** ping statistics -bash: download.iobroker.net**: command not found Radix1975@raspberrypi5:~ $ iob repo list stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): live-stable , live-beta, live-stable, stable Radix1975@raspberrypi5:~ $ ^C Radix1975@raspberrypi5:~ $ -
Das war nur der Output aus meinem System, das solltest du nicht in dein Terminal klatschen...
iob repo listaber schon
Radix1975@raspberrypi5:~ $ iob repo list stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): live-stable , live-beta, live-stable, stable Radix1975@raspberrypi5:~ $ -
live-stable
iob repo unset 'live-stable ' iob repo unset 'live-stable' iob repo unset 'live-beta' iob repo del 'live-stable ' iob repo del 'live-stable' iob repo del 'live-beta'dann
iob repo list
