    3. Einsteigerfragen
    4. Installation
    5. vermurkste Installation
      Homoran Global Moderator Administrators @Radix75 last edited by
      @radix75 sagte in Daikin Adapter:
      bleiben aber nur immer 2 drin
      und wenn du die änderst?
        Thomas Braun Most Active @Radix75 last edited by
        @radix75
        iob repo list
        anschauen .
          Radix75 @Homoran last edited by
          @homoran said in Daikin Adapter:
          das steht vorne
          wenn ich über den Schraubenschlüssel die Repos öffne kommen nur 2
            das steht vorne
            Browsercache gelöscht?
              Hab mal die Admin Seite in anderen browser geöffnet
              login as: Radix1975
              Radix1975@192.168.1.225's password:
              Linux raspberrypi5 6.1.0-rpi7-rpi-2712 #1 SMP PREEMPT Debian 1:6.1.63-1+rpt1 (20                                   23-11-24) aarch64
              The programs included with the Debian GNU/Linux system are free software;
              the exact distribution terms for each program are described in the
              individual files in /usr/share/doc/*/copyright.
              Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
              permitted by applicable law.
              Last login: Thu Dec 28 13:31:01 2023 from 192.168.1.10
              Radix1975@raspberrypi5:~ $ echad@chet:~ $ iob repo list
              -bash: echad@chet:~: command not found
              Radix1975@raspberrypi5:~ $ Radix1975@raspberrypi5:~ $ echad@chet:~ $ iob repo li                                   st
              -bash: Radix1975@raspberrypi5:~: command not found
              -bash: -bash:: command not found
              live-stable   : http://iobroker.live/repo/sources-dist.json
              live-beta     : http://iobroker.live/repo/sources-dist-latest.json
              -bash: beta: command not found
              -bash: live-stable: command not found
              -bash: live-beta: command not found
              -bash: stable: command not found
              Radix1975@raspberrypi5:~ $ ^C
              Radix1975@raspberrypi5:~ $ --- **download.iobroker.net** ping statistics ---
              -bash: ---: command not found
              Radix1975@raspberrypi5:~ $ download.iobroker.net** ping statistics
              -bash: download.iobroker.net**: command not found
              Radix1975@raspberrypi5:~ $ iob repo list
              Active repo(s): live-stable , live-beta, live-stable, stable
                @radix75
                Das war nur der Output aus meinem System, das solltest du nicht in dein Terminal klatschen...
                iob repo list
                aber schon
                  Radix75 @Thomas Braun last edited by
                  @thomas-braun said in Daikin Adapter:
                  @radix75
                  iob repo list
                  aber schon
                    live-stable
                    iob repo unset 'live-stable '
                    iob repo unset 'live-stable'
                    iob repo unset 'live-beta'
                    iob repo del 'live-stable '
                    iob repo del 'live-stable'
                    iob repo del 'live-beta'
                    dann
                    iob repo list
                      live-stable
                      dann
                      iob repo list
                      Radix1975@raspberrypi5:~ $ iob repo unset 'live-stable'
                      Repository "live-stable" deactivated.
                      Active repo(s): live-beta, stable
                      Radix1975@raspberrypi5:~ $ iob repo unset 'live-beta'
                      Repository "live-beta" deactivated.
                      Active repo(s): stable
                      Radix1975@raspberrypi5:~ $ iob repo del 'live-stable '
                      Cannot remove repository: Repository "live-stable " not found.
                      Radix1975@raspberrypi5:~ $ iob repo del 'live-stable'
                      Cannot remove repository: Repository "live-stable" not found.
                      Radix1975@raspberrypi5:~ $ iob repo del 'live-beta'
                      Cannot remove repository: Repository "live-beta" not found.
                        Ich hab das ganze mal abgetrennt!
                        hat ja nix mehr mit Daikin zu tun
                        @Radix75 bitte den provisorischen Threadtitel anpassen
                          @homoran said in vermurkste Installation:
                          Daikin muss ich später noch auf den IOBroker machen wenn der endlich Adapter suchen kann
                            @radix75
                            iob update
                              @thomas-braun said in vermurkste Installation:
                              @radix75
                              iob update
                              Radix1975@raspberrypi5:~ $ iob update
                              Used repository: stable
                              Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
                              Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
                              Thomas Braun R 2 Replies Last reply Reply Quote 0
                                @radix75
                                iob repo add live-stable http://iobroker.live/repo/sources-dist.json
                                iob repo unset stable
                                iob repo set live-stable
                                iob update
                                  Radix75 @Radix75 last edited by
                                  @radix75 said in vermurkste Installation:
                                  @radix75
                                  iob update
                                  Ist das Netzwerk so richtig???2e63ea19-d5f9-4686-abda-c92ce7ea0d2a-image.png
                                  R Homoran 2 Replies Last reply Reply Quote 0
                                    Radix1975@raspberrypi5:~ $ iob repo add live-stable http://iobroker.live/repo/sources-dist.json
                                    Repository "live-stable" added as "http://iobroker.live/repo/sources-dist.json"
                                    Radix1975@raspberrypi5:~ $ iob repo unset stable
                                    Repository "stable" deactivated.
                                    Active repo(s):
                                    Radix1975@raspberrypi5:~ $ iob repo set live-stable
                                    Repository "live-stable" set as active.
                                    Used repository: live-stable
                                    Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                                    Controller "js-controller": 5.0.17   , installed 5.0.17
                                      @radix75
                                      Dann sollte es wieder funktionieren.
                                        @radix75 sagte in vermurkste Installation:
                                        äääähm?
                                        Das ist die Konfiguration des admins, die passt.
                                        Um dein Netzwerk musst du dich kümmern
                                          @radix75
                                          Funktioniert !
                                          Ein großes Dankeschön dafür.
                                          Als nächstes würde ich erstmal ein Beckup der Karte machen wollen.
                                          Danach müße ich dann nach https://github.com/alexreinert/piVCCU/blob/master/docs/setup/raspberrypi.md
                                          piVCCU installieren auch hier hatte ich in der Vergangenheit schon oft das Problem das das Netzwerk nach dem Schritt 6-9 nicht mehr geht.
                                          Ich habe auch heute das neue CCU RPI-RF-Modul bekommen hier wahren ja noch Probleme mit dem GPIO aufstecken und die Tatsache das ich nur das Original Netzteil mit UCB C habe zu lösen
                                            @radix75
                                            Zu pivCCU kann ich nicht viel sagen.
                                            11403
