    3. Einsteigerfragen
    4. Installation
    5. vermurkste Installation
      Homoran Global Moderator Administrators @Radix75 last edited by
      @radix75 sagte in Daikin Adapter:
      das steht vorne
      Browsercache gelöscht?
        Radix75 @Homoran last edited by
        Hab mal die Admin Seite in anderen browser geöffnet
        login as: Radix1975
        Radix1975@192.168.1.225's password:
        Linux raspberrypi5 6.1.0-rpi7-rpi-2712 #1 SMP PREEMPT Debian 1:6.1.63-1+rpt1 (20                                   23-11-24) aarch64
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Thu Dec 28 13:31:01 2023 from 192.168.1.10
        Radix1975@raspberrypi5:~ $ echad@chet:~ $ iob repo list
        -bash: echad@chet:~: command not found
        Radix1975@raspberrypi5:~ $ Radix1975@raspberrypi5:~ $ echad@chet:~ $ iob repo li                                   st
        -bash: Radix1975@raspberrypi5:~: command not found
        -bash: -bash:: command not found
        live-stable   : http://iobroker.live/repo/sources-dist.json
        live-beta     : http://iobroker.live/repo/sources-dist-latest.json
        -bash: beta: command not found
        -bash: live-stable: command not found
        -bash: live-beta: command not found
        -bash: stable: command not found
        Radix1975@raspberrypi5:~ $ ^C
        Radix1975@raspberrypi5:~ $ --- **download.iobroker.net** ping statistics ---
        -bash: ---: command not found
        Radix1975@raspberrypi5:~ $ download.iobroker.net** ping statistics
        -bash: download.iobroker.net**: command not found
        Radix1975@raspberrypi5:~ $ iob repo list
        Active repo(s): live-stable , live-beta, live-stable, stable
          Thomas Braun Most Active @Radix75 last edited by
          @radix75
          Das war nur der Output aus meinem System, das solltest du nicht in dein Terminal klatschen...
          iob repo list
          aber schon
            Radix75 @Thomas Braun last edited by
            @thomas-braun said in Daikin Adapter:
            @radix75
            iob repo list
            aber schon
              live-stable
              iob repo unset 'live-stable '
              iob repo unset 'live-stable'
              iob repo unset 'live-beta'
              iob repo del 'live-stable '
              iob repo del 'live-stable'
              iob repo del 'live-beta'
              dann
              iob repo list
                live-stable
                dann
                iob repo list
                Radix1975@raspberrypi5:~ $ iob repo unset 'live-stable'
                Repository "live-stable" deactivated.
                Active repo(s): live-beta, stable
                Radix1975@raspberrypi5:~ $ iob repo unset 'live-beta'
                Repository "live-beta" deactivated.
                Active repo(s): stable
                Radix1975@raspberrypi5:~ $ iob repo del 'live-stable '
                Cannot remove repository: Repository "live-stable " not found.
                Radix1975@raspberrypi5:~ $ iob repo del 'live-stable'
                Cannot remove repository: Repository "live-stable" not found.
                Radix1975@raspberrypi5:~ $ iob repo del 'live-beta'
                Cannot remove repository: Repository "live-beta" not found.
                  Ich hab das ganze mal abgetrennt!
                  hat ja nix mehr mit Daikin zu tun
                  @Radix75 bitte den provisorischen Threadtitel anpassen
                    @homoran said in vermurkste Installation:
                    Daikin muss ich später noch auf den IOBroker machen wenn der endlich Adapter suchen kann
                      @radix75
                      iob update
                        @thomas-braun said in vermurkste Installation:
                        @radix75
                        iob update
                        Radix1975@raspberrypi5:~ $ iob update
                        Used repository: stable
                        Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
                        Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
                        Thomas Braun R 2 Replies Last reply Reply Quote 0
                          @radix75
                          iob repo add live-stable http://iobroker.live/repo/sources-dist.json
                          iob repo unset stable
                          iob repo set live-stable
                          iob update
                            Radix75 @Radix75 last edited by
                            @radix75 said in vermurkste Installation:
                            @radix75
                            iob update
                            Ist das Netzwerk so richtig???2e63ea19-d5f9-4686-abda-c92ce7ea0d2a-image.png
                            R Homoran 2 Replies Last reply Reply Quote 0
                              Radix1975@raspberrypi5:~ $ iob repo add live-stable http://iobroker.live/repo/sources-dist.json
                              Repository "live-stable" added as "http://iobroker.live/repo/sources-dist.json"
                              Radix1975@raspberrypi5:~ $ iob repo unset stable
                              Repository "stable" deactivated.
                              Active repo(s):
                              Radix1975@raspberrypi5:~ $ iob repo set live-stable
                              Repository "live-stable" set as active.
                              Used repository: live-stable
                              Adapter    "admin"        : 6.12.0   , installed 6.12.0
                              Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                              Controller "js-controller": 5.0.17   , installed 5.0.17
                                @radix75
                                Dann sollte es wieder funktionieren.
                                  @radix75 sagte in vermurkste Installation:
                                  äääähm?
                                  Das ist die Konfiguration des admins, die passt.
                                  Um dein Netzwerk musst du dich kümmern
                                    @radix75
                                    Funktioniert !
                                    Ein großes Dankeschön dafür.
                                    Als nächstes würde ich erstmal ein Beckup der Karte machen wollen.
                                    Danach müße ich dann nach https://github.com/alexreinert/piVCCU/blob/master/docs/setup/raspberrypi.md
                                    piVCCU installieren auch hier hatte ich in der Vergangenheit schon oft das Problem das das Netzwerk nach dem Schritt 6-9 nicht mehr geht.
                                    Ich habe auch heute das neue CCU RPI-RF-Modul bekommen hier wahren ja noch Probleme mit dem GPIO aufstecken und die Tatsache das ich nur das Original Netzteil mit UCB C habe zu lösen
                                      @radix75
                                      Zu pivCCU kann ich nicht viel sagen.
                                        wie bereits gesagt bist du da falsch abgebogen.
                                          mit welchen Kommando kann ich ein Image der SD karte auf einem externen USB Stick schreiben?
                                            Homoran Global Moderator Administrators @Radix75 last edited by Homoran
                                            @radix75 wenn du die Frage stellst, bin ich mir nicht sicher ob das das richtige Vorgehen für dich sein wird
                                            1.2k
                                            11403
