    3. Einsteigerfragen
    4. Installation
    5. vermurkste Installation
      Thomas Braun Most Active @Radix75 last edited by
      @radix75
      Das war nur der Output aus meinem System, das solltest du nicht in dein Terminal klatschen...
      iob repo list
      aber schon
        Radix75 @Thomas Braun last edited by
        @thomas-braun said in Daikin Adapter:
        @radix75
        iob repo list
        aber schon
        Radix1975@raspberrypi5:~ $ iob repo list
        Active repo(s): live-stable , live-beta, live-stable, stable
          @radix75 sagte in Daikin Adapter:
          live-stable
          iob repo unset 'live-stable '
          iob repo unset 'live-stable'
          iob repo unset 'live-beta'
          iob repo del 'live-stable '
          iob repo del 'live-stable'
          iob repo del 'live-beta'
          dann
          iob repo list
            live-stable
            dann
            iob repo list
            Radix1975@raspberrypi5:~ $ iob repo unset 'live-stable'
            Repository "live-stable" deactivated.
            Active repo(s): live-beta, stable
            Radix1975@raspberrypi5:~ $ iob repo unset 'live-beta'
            Repository "live-beta" deactivated.
            Active repo(s): stable
            Radix1975@raspberrypi5:~ $ iob repo del 'live-stable '
            Cannot remove repository: Repository "live-stable " not found.
            Radix1975@raspberrypi5:~ $ iob repo del 'live-stable'
            Cannot remove repository: Repository "live-stable" not found.
            Radix1975@raspberrypi5:~ $ iob repo del 'live-beta'
            Cannot remove repository: Repository "live-beta" not found.
              Ich hab das ganze mal abgetrennt!
              hat ja nix mehr mit Daikin zu tun
              @Radix75 bitte den provisorischen Threadtitel anpassen
                Radix75 @Homoran last edited by
                @homoran said in vermurkste Installation:
                Daikin muss ich später noch auf den IOBroker machen wenn der endlich Adapter suchen kann
                  @radix75
                  iob update
                    @thomas-braun said in vermurkste Installation:
                    @radix75
                    iob update
                    Radix1975@raspberrypi5:~ $ iob update
                    Used repository: stable
                    Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
                    Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
                    Thomas Braun R 2 Replies Last reply Reply Quote 0
                      @radix75
                      iob repo add live-stable http://iobroker.live/repo/sources-dist.json
                      iob repo unset stable
                      iob repo set live-stable
                      iob update
                        Radix75 @Radix75 last edited by
                        @radix75 said in vermurkste Installation:
                        @radix75
                        iob update
                        Ist das Netzwerk so richtig???2e63ea19-d5f9-4686-abda-c92ce7ea0d2a-image.png
                        R Homoran 2 Replies Last reply Reply Quote 0
                          Radix1975@raspberrypi5:~ $ iob repo add live-stable http://iobroker.live/repo/sources-dist.json
                          Repository "live-stable" added as "http://iobroker.live/repo/sources-dist.json"
                          live-stable   : http://iobroker.live/repo/sources-dist.json
                          Radix1975@raspberrypi5:~ $ iob repo unset stable
                          Repository "stable" deactivated.
                          Active repo(s):
                          Radix1975@raspberrypi5:~ $ iob repo set live-stable
                          Repository "live-stable" set as active.
                          Used repository: live-stable
                          Adapter    "admin"        : 6.12.0   , installed 6.12.0
                          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                          Controller "js-controller": 5.0.17   , installed 5.0.17
                            @radix75
                            Dann sollte es wieder funktionieren.
                              Homoran Global Moderator Administrators @Radix75 last edited by
                              @radix75 sagte in vermurkste Installation:
                              äääähm?
                              Das ist die Konfiguration des admins, die passt.
                              Um dein Netzwerk musst du dich kümmern
                                @radix75
                                Funktioniert !
                                Ein großes Dankeschön dafür.
                                Als nächstes würde ich erstmal ein Beckup der Karte machen wollen.
                                Danach müße ich dann nach https://github.com/alexreinert/piVCCU/blob/master/docs/setup/raspberrypi.md
                                piVCCU installieren auch hier hatte ich in der Vergangenheit schon oft das Problem das das Netzwerk nach dem Schritt 6-9 nicht mehr geht.
                                Ich habe auch heute das neue CCU RPI-RF-Modul bekommen hier wahren ja noch Probleme mit dem GPIO aufstecken und die Tatsache das ich nur das Original Netzteil mit UCB C habe zu lösen
                                  @radix75
                                  Zu pivCCU kann ich nicht viel sagen.
                                    wie bereits gesagt bist du da falsch abgebogen.
                                      mit welchen Kommando kann ich ein Image der SD karte auf einem externen USB Stick schreiben?
                                        Homoran Global Moderator Administrators @Radix75 last edited by Homoran
                                        @radix75 wenn du die Frage stellst, bin ich mir nicht sicher ob das das richtige Vorgehen für dich sein wird
                                          Warum nicht? Wir haben Stunden geraucht um alles einzurichten wenn jetzt was bei der Installation von pivCCU
                                          was schief geht habe ich eine zweite SD Karte. Ich habe ja so ein SD Kartenleser für USB
                                            @radix75 dann nimm die 2te Karte und fang mit OS und piVCCU an.
                                            ich bin mir immer noch nicht sicher ob dein Netzwerk sauber tickt.
                                            So lange hat es nur deswegen gedauert
                                            1.0k
                                            11399
