    3. Einsteigerfragen
    4. Installation
    5. vermurkste Installation
      Radix75 @Thomas Braun last edited by
      @thomas-braun said in Daikin Adapter:
      @radix75
      Das war nur der Output aus meinem System, das solltest du nicht in dein Terminal klatschen...
      iob repo list
      aber schon
      Radix1975@raspberrypi5:~ $ iob repo list
      Active repo(s): live-stable , live-beta, live-stable, stable
        Thomas Braun Most Active @Radix75 last edited by
        @radix75 sagte in Daikin Adapter:
        live-stable
        iob repo unset 'live-stable '
        iob repo unset 'live-stable'
        iob repo unset 'live-beta'
        iob repo del 'live-stable '
        iob repo del 'live-stable'
        iob repo del 'live-beta'
        dann
        iob repo list
          live-stable
          dann
          iob repo list
          Radix1975@raspberrypi5:~ $ iob repo unset 'live-stable'
          Repository "live-stable" deactivated.
          Active repo(s): live-beta, stable
          Radix1975@raspberrypi5:~ $ iob repo unset 'live-beta'
          Repository "live-beta" deactivated.
          Active repo(s): stable
          Radix1975@raspberrypi5:~ $ iob repo del 'live-stable '
          Cannot remove repository: Repository "live-stable " not found.
          Radix1975@raspberrypi5:~ $ iob repo del 'live-stable'
          Cannot remove repository: Repository "live-stable" not found.
          Radix1975@raspberrypi5:~ $ iob repo del 'live-beta'
          Cannot remove repository: Repository "live-beta" not found.
            Ich hab das ganze mal abgetrennt!
            hat ja nix mehr mit Daikin zu tun
            @Radix75 bitte den provisorischen Threadtitel anpassen
              Radix75 @Homoran last edited by
              @homoran said in vermurkste Installation:
              Daikin muss ich später noch auf den IOBroker machen wenn der endlich Adapter suchen kann
                @radix75
                iob update
                  @thomas-braun said in vermurkste Installation:
                  @radix75
                  iob update
                  Radix1975@raspberrypi5:~ $ iob update
                  Used repository: stable
                  Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
                  Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
                  Thomas Braun R 2 Replies Last reply Reply Quote 0
                    @radix75
                    iob repo add live-stable http://iobroker.live/repo/sources-dist.json
                    iob repo unset stable
                    iob repo set live-stable
                    iob update
                      Radix75 @Radix75 last edited by
                      @radix75 said in vermurkste Installation:
                      @radix75
                      iob update
                      Ist das Netzwerk so richtig???2e63ea19-d5f9-4686-abda-c92ce7ea0d2a-image.png
                      R Homoran 2 Replies Last reply Reply Quote 0
                        Radix1975@raspberrypi5:~ $ iob repo add live-stable http://iobroker.live/repo/sources-dist.json
                        Repository "live-stable" added as "http://iobroker.live/repo/sources-dist.json"
                        live-stable   : http://iobroker.live/repo/sources-dist.json
                        Radix1975@raspberrypi5:~ $ iob repo unset stable
                        Repository "stable" deactivated.
                        Active repo(s):
                        Radix1975@raspberrypi5:~ $ iob repo set live-stable
                        Repository "live-stable" set as active.
                        Used repository: live-stable
                        Adapter    "admin"        : 6.12.0   , installed 6.12.0
                        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                        Controller "js-controller": 5.0.17   , installed 5.0.17
                          @radix75
                          Dann sollte es wieder funktionieren.
                            Homoran Global Moderator Administrators @Radix75 last edited by
                            @radix75 sagte in vermurkste Installation:
                            äääähm?
                            Das ist die Konfiguration des admins, die passt.
                            Um dein Netzwerk musst du dich kümmern
                              @radix75
                              Funktioniert !
                              Ein großes Dankeschön dafür.
                              Als nächstes würde ich erstmal ein Beckup der Karte machen wollen.
                              Danach müße ich dann nach https://github.com/alexreinert/piVCCU/blob/master/docs/setup/raspberrypi.md
                              piVCCU installieren auch hier hatte ich in der Vergangenheit schon oft das Problem das das Netzwerk nach dem Schritt 6-9 nicht mehr geht.
                              Ich habe auch heute das neue CCU RPI-RF-Modul bekommen hier wahren ja noch Probleme mit dem GPIO aufstecken und die Tatsache das ich nur das Original Netzteil mit UCB C habe zu lösen
                                @radix75
                                Zu pivCCU kann ich nicht viel sagen.
                                  wie bereits gesagt bist du da falsch abgebogen.
                                    mit welchen Kommando kann ich ein Image der SD karte auf einem externen USB Stick schreiben?
                                      Homoran Global Moderator Administrators @Radix75 last edited by Homoran
                                      @radix75 wenn du die Frage stellst, bin ich mir nicht sicher ob das das richtige Vorgehen für dich sein wird
                                        Warum nicht? Wir haben Stunden geraucht um alles einzurichten wenn jetzt was bei der Installation von pivCCU
                                        was schief geht habe ich eine zweite SD Karte. Ich habe ja so ein SD Kartenleser für USB
                                          @radix75 dann nimm die 2te Karte und fang mit OS und piVCCU an.
                                          ich bin mir immer noch nicht sicher ob dein Netzwerk sauber tickt.
                                          So lange hat es nur deswegen gedauert
                                            Können wir das noch irgendwie Herausfinden?
                                            11400
