    4. Test lovelace 5.x
    Test lovelace 5.x
      pafade89 @Garfonso last edited by
      @garfonso
      Besteht eine Chance, das du dir das nochmal genauer anguckst ?
      Hätte einige Anwendungsfälle dafür und custom gibt es leider nicht so viel Auswahl.
      Außerdem passiert bei den custom auch viel direkt in der Karte was nicht so nett ist.
      VG P
        andi2055 last edited by
        nach dem Update von 3 auf 4.1.0 konnte ich die Instanz nicht mehr starten.
        lovelace.0
        2023-12-18 21:21:21.859	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        lovelace.0
        2023-12-18 21:21:21.856	error	Cannot read properties of null (reading 'length')
        lovelace.0
        2023-12-18 21:21:21.855	error	TypeError: Cannot read properties of null (reading 'length') at TodoModule.processManualEntity (/opt/iobroker/node_modules/iobroker.lovelace/lib/modules/todo.js:349:46)
        lovelace.0
        2023-12-18 21:21:21.855	error	unhandled promise rejection: Cannot read properties of null (reading 'length')
        lovelace.0
        2023-12-18 21:21:21.855	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        lovelace.0
        2023-12-18 21:21:21.854	warn	Cannot parse todo items of lovelace.0.control.shopping_list: null, TypeError: todoList.items is not iterable
        lovelace.0
        2023-12-18 21:21:21.492	warn	Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
        lovelace.0
        2023-12-18 21:21:18.979	warn	Cannot parse todo items of lovelace.0.control.shopping_list: null, TypeError: Cannot read properties of null (reading 'length')
        lovelace.0
        2023-12-18 21:21:18.699	warn	Hue present but no saturation id found for alias.0.OG.Ankleide_Licht_Hue.HUE. Saturation won't work.
        lovelace.0
        2023-12-18 21:21:18.498	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        lovelace.0
        2023-12-18 21:21:18.495	error	Cannot read properties of null (reading 'length')
        lovelace.0
        2023-12-18 21:21:18.495	error	TypeError: Cannot read properties of null (reading 'length') at TodoModule.processManualEntity (/opt/iobroker/node_modules/iobroker.lovelace/lib/modules/todo.js:349:46)
        lovelace.0
        2023-12-18 21:21:18.494	error	unhandled promise rejection: Cannot read properties of null (reading 'length')
        lovelace.0
        2023-12-18 21:21:18.494	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        In den Datenpunkten steht wirklich "NULL" als String drin. Keine Ahnung woher das kommt. Habe ich manuell gelöscht und danach startete der Adapter. Vielleicht haben andere auch das Problem?
          Hat jemand noch eine Idee wie ich diese Meldung weg bekomme?
          Im Alias gibt es auch SATURATION
          Danke!
          • Garfonso
            Garfonso Developer @pafade89 last edited by Garfonso
            @pafade89 said in Test lovelace 4.x:
            Ja, das gucke ich mir an. Weiß nur nicht wann.
            Kann die denn mehr als die normale History-Graph-Card? Oder Sensor?
            @andi2055 said in Test lovelace 4.x:
            Danke für den Report. Fixe ich.
            Wie ist denn die Rolle? Wie sehen die Attribute aus (lovelace-Instanzeinstellungen, letzter Tab, Attribute anzeigen und mal beim entity gucken)? Wie sieht das Gerät im Geräte-Tab aus? Steht da der State (noch) unter SATURATION?
            Irgendwie scheint das Saturation nicht als Saturation erkannt zu werden. 😕
              @Garfonso
              ich habe gestern folgenden Fehler im Log gehabt:
              2023-12-20 21:40:14.449 - warn: lovelace.0 (65110) No browser ID in browser_mod request: {"type":"browser_mod/recall_id","id":2}
              Dieser Fehler war schon in der 3.0.1 bei mir vorhanden, sah nur ein bisschen anders aus.
              Was kann man hier tun?
              VG P
              • Skyx3
                Skyx3 @Skyx3 last edited by
                @skyx3 said in Test lovelace 4.x:
                @garfonso Nachdem Update auf 4.X startet der Adapter nicht mehr, im Log kommt unentwegt der Fehler "Could not get user id for admin - Trying with username"
                Gibt es schon etwas Neues zu dieser Fehlermeldung?
                  Wenn ich bei neuen Datenpunkten "Lovelace" aktivieren möchte, kommt folgender Fehler:
                  Liegt das an Lovelace 4.1.0 oder an Admin 6.13.5?
                  David G. A 2 Replies Last reply Reply Quote 0
                  • David G.
                    David G. @andi2055 last edited by
                    @andi2055
                    Bei mir geht es.
                    Admin 6.12.0
                    Lovelace 4.0.12
                      andi2055 @andi2055 last edited by
                      @andi2055
                      ok, mit Admin 6.13.11 funktioniert es wieder...
                      • Garfonso
                        Du:
                        das hier melden. Und vielleicht versuchen rauszufinden, was passiert, damit diese Meldung kommt, damit ich mir das genauer angucken kann.
                        Ich:
                        ich muss da was implementieren... den request "recall_id" kannte ich bisher aber nicht und die Warnung bemängelt auch, dass da keine Browser ID drin steht (sieht man ja auch nicht). Da müsste ich suchen, was da los ist. Hab ich bei mir noch nicht gesehen -> von daher wäre es ech hilfreich, wenn du irgendwie mal rumspielen könntest und gucken, wann das im log kommt, also was du (vermutlich mit browser mod?) da machst.
                        Oh, das hab ich übersehen. Danke, dass du nachfragst...
                        Dazu nachfragen:
                        0) passiert dsa mit 4.1 auch?
                        1. hast du authentifizierung an?
                        2. hat dein User "admin" irgendwie einen Namen oder so? Bzw. Warum ist der kleingeschrieben? (oder ist der das immer?)
                        • XBiT
                          XBiT last edited by
                          @Garfonso
                          Mit v4.1.0 habe ich folgende Probleme:
                          Beim starten vom Adapter kommt über 99x diese Meldung im Log
                          warn	Could not get user id for admin - Trying with username
                          läuft danach aber soweit...
                          Beim öffnen einer "MAP" Karte kommen x mal diese Meldungen im Log
                          mit einen Adroid Tablet:
                          Log from UI Unhandled promise rejection from Chrome WebView 120.0.6099.144 on Android 13TypeError: Cannot read properties of undefined (reading 'latitude')computeDomain (src/panels/lovelace/cards/hui-map-card.ts:387:41)apply (node_modules/memoize-one/dist/memoize-one.esm.js:37:34)render (src/panels/lovelace/cards/hui-map-card.ts:166:26)render (src/lit-element.ts:160:23)update (src/reactive-element.ts:1329:13)performUpdate (src/reactive-element.ts:1261:16)scheduleUpdate (src/reactive-element.ts:1233:24)
                          mit einen Win_11 PC:
                          Log from UI Unhandled promise rejection from Chrome 120.0.0.0 on Windows 10 TypeError: Cannot read properties of undefined (reading 'latitude') computeDomain (src/panels/lovelace/cards/hui-map-card.ts:387:41) apply (node_modules/memoize-one/dist/memoize-one.esm.js:37:34) render (src/panels/lovelace/cards/hui-map-card.ts:166:26) render (src/lit-element.ts:160:23) update (src/reactive-element.ts:1329:13) performUpdate (src/reactive-element.ts:1261:16) scheduleUpdate (src/reactive-element.ts:1233:24)
                          danach ist Lovelace fast nicht mehr bedienbar, alles ist träge und zäh erst ein Neustart der Instanz hilft hier bis man wieder auf eine Seite mit einer Map geht.
                          Auch wird auf der Map Karte nicht mehr der Verlauf/Bewegung angezeigt.
                          Garfonso 1 Reply Last reply Reply Quote 1
                          • Garfonso
                            Garfonso Developer @XBiT last edited by
                            @xbit
                            Hm.. hab ich beides bei mir nicht. 😕
                            Rein aus Interesse, wie sieht bei dir das system.user.admin Objekt aus? Hat das ein common.name Feld?
                            Der Crash beim Laden der Map sieht auch merkwürdig aus. Hast du geo_location entities, die keine History aktiviert haben? Dann hab ich den Fehler vielleicht gefunden (und in der nächsten Version behoben). Ansonsten hab ich auf gut Glück attribute drinnen gelassen. kopfkratz Du nutzt aber die standard Map Karte und nicht eine custom, oder?
                            XBiT 2 Replies Last reply Reply Quote 0
                            • XBiT
                              XBiT @Garfonso last edited by
                              @garfonso
                              system.user.admin
                                "type": "user",
                                "common": {
                                  "name": "Stephan",
                                  "password": "*EDIT einganzlangercode*",
                                  "dontDelete": true,
                                  "enabled": true
                                "native": {},
                                "_id": "system.user.admin",
                                "acl": {
                                  "object": 1636,
                                  "owner": "system.user.admin",
                                "enums": {},
                                "user": "system.user.admin",
                                "ts": 1651084242439
                              History ist bei folgenden Daten von google-sharedlocations an (accuracy, address, battery, lat, long).
                              Karte ist die Standard Map.
                              • XBiT
                                @garfonso
                                Besten Dank 4.1.1 läuft wieder. 👍
                                  pafade89 @Garfonso last edited by pafade89
                                  @garfonso sagte in Test lovelace 4.x:
                                  Habe folgendes gefunden:
                                  "The statistics graph card allows you to display a graph of statistics data for each of the entities listed."
                                  Damit kann man also zum Beispiel auch Balkendiagramme anzeigen lassen.
                                  Du:
                                  das hier melden. Und vielleicht versuchen rauszufinden, was passiert, damit diese Meldung kommt, damit ich mir das >genauer angucken kann.
                                  Ich:
                                  ich muss da was implementieren... den request "recall_id" kannte ich bisher aber nicht und die Warnung bemängelt auch, >dass da keine Browser ID drin steht (sieht man ja auch nicht). Da müsste ich suchen, was da los ist. Hab ich bei mir noch >nicht gesehen -> von daher wäre es ech hilfreich, wenn du irgendwie mal rumspielen könntest und gucken, wann das im >log kommt, also was du (vermutlich mit browser mod?) da machst.
                                  Seit dem letzten Update habe ich diesen Fehler nicht mehr reproduzieren können.
                                  VG P
                                    kptkip last edited by
                                    Beim Iphone/Ipad kann man sich ja Ne Website als Webapp auf den Home Bildschirm legen.
                                    Bei manchen Seiten wird das dann auch nicht als Tab im Safari angezeigt sondern ohne Browser-Adressleiste als eigenständiges Programm.
                                    Dazu benötigt die Website laut Apple folgende Meta-Tags:
                                    <meta name="apple-mobile-web-app-capable" content="yes" />
                                    Obwohl in der HTML-Ausgabe des Lovelace-Adapters dieser Tag angegeben ist, erscheint die Visualisierung auf meinem IPhone ganz normal im Browser, wenn ich mir ne webapp angelegt habe.
                                    Ist das bei euch auch so?
                                      lessthanmore @kptkip last edited by
                                      @kptkip Nein, läuft hier auf iPad und iPhone wie es soll ohne Adressleiste.
                                      Dazu habe ich einfach die URL in Safari aufgerufen und ein Lesezeichen dem Home-Bildschirm hinzugefügt.
                                      Auf dem iPad nutze ich allerdings Kiosker Pro, aber auch da wird es ohne Adressleiste angezeigt.
                                        kptkip @lessthanmore last edited by kptkip
                                        @lessthanmore Danke für die Rückmeldung. Genau so habe ich es auch gemacht.
                                        Habs gerade nochmal auf dem Handy meiner Frau ausprobiert - dort klappt es.
                                        Komisch... Dann liegt es wohl an meinem Handy...
                                          kptkip @kptkip last edited by
                                          Hab nun eine spezifischere Beobachtung:
                                          Bei einem Bookmark von der Startseite ([IP_DES_SERVERS]:8091) klappt das mit der Web-App.
                                          Bei einem Bookmark von einer Unterseite (z.B. [IP_DES_SERVERS]:8091/lovelace/eingang) klappt es nicht. Da taucht die Browserleiste wieder auf
                                            @Garfonso
                                            Ich habe nun heraus gefunden wann die Meldung kommt:
                                            lovelace.0 (599) No browser ID in browser_mod request: {"type":"browser_mod/recall_id","id":2}
                                            Wenn ich lovelace zum Beispiel auf dem Smartphone öffne und dann den Browser für viele Stunden nicht benutze. Wird er dann direkt mit Lovelace geöffnet wieder aufgerufen kommt die Meldung.
                                            VG P
                                            898
                                            354393
