    4. Test Adapter onvif camera v1.x.x
    • David G.
      Wollte mir den Adapter auch gerade mal anschauen.
      Allerdings möchte die Installation nicht durchlaufen.
      $ iobroker url https://github.com/iobroker-community-adapters/ioBroker.onvif --host iobroker --debug
      install iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f
      NPM version: 10.2.3Installing iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f... (System call)
      npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.onvif.git
      npm ERR! code 2
      host.iobroker Cannot install iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f: 2
      ERROR: Process exited with code 25
      Skript v.2023-10-10
      *** BASE SYSTEM ***                                            Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
      Operating System: Debian GNU/Linux 12 (bookworm)                        Kernel: Linux 6.1.0-13-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
      model name      : 12th Gen Intel(R) Core(TM) i3-12100
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       16:16:13 up 6 days,  4:40,  2 users,  load average: 0.84, 0.96, 0.64
      CPU threads: 1
      *** Time and Time Zones ***
                     Local time: Thu 2023-12-28 16:16:13 CET
                 Universal time: Thu 2023-12-28 15:16:13 UTC
                       RTC time: Thu 2023-12-28 15:16:13
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      iobroker
      /home/iobroker
      iobroker tty dialout cdrom floppy sudo audio dip video plugdev users netdev
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.3G        4.0G        2.1G        487K        1.5G        3.3G
      Swap:           1.0G        520K        1.0G
      Total:          8.3G        4.0G        3.1G
               6933 M total memory
               3787 M used memory
                744 M active memory
               3703 M inactive memory
               1995 M free memory
                250 M buffer memory
               1195 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.4G     0  3.4G   0% /dev
      tmpfs          tmpfs     694M  520K  693M   1% /run
      /dev/sda1      ext4       31G  9.3G   20G  32% /
      tmpfs          tmpfs     3.4G     0  3.4G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     694M     0  694M   0% /run/user/1000
      [sudo] password for iobroker:
      [Fri Dec 22 11:35:23 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Dec 22 11:35:23 2023] EXT4-fs (sda1): re-mounted. Quota mode: none.
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      1.3G    /var/
      575M    /var/log
      559M    /var/log/journal/c2f62aa20c614a09b8a2622bde83939a
      531M    /var/cache
      Archived and active journals take up 79.1M in the file system.
      /opt/iobroker/backups:
      1.1G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.1G    /opt/iobroker/iobroker-data/
      717M    /opt/iobroker/iobroker-data/files
      278M    /opt/iobroker/iobroker-data/backup-objects
      153M    /opt/iobroker/iobroker-data/files/vis-2
      111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup
      111M    /opt/iobroker/iobroker-data/files/0_userdata.0/SqlBackup/sql.sql
      43M     /opt/iobroker/iobroker-data/objects.jsonl
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      34M     /opt/iobroker/iobroker-data/states.jsonl
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_e28d28580194eb11a604aa5b3d98b6d1-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   8
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
      + system.adapter.adb.0                    : adb                   : iobroker                                 -  enabled
      + system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.birthdays.0              : birthdays             : iobroker                                 - disabled
        system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 - disabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        system.adapter.daswetter.1              : daswetter             : iobroker                                 - disabled
        system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
      + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
        system.adapter.devices.0                : devices               : iobroker                                 - disabled
        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      + system.adapter.google-sharedlocations.0 : google-sharedlocations: iobroker                                 -  enabled
        system.adapter.hass.0                   : hass                  : iobroker                                 - disabled, port: 8123
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
        system.adapter.iceroad.0                : iceroad               : iobroker                                 - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
        system.adapter.logparser.0              : logparser             : iobroker                                 - disabled
      + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
      + system.adapter.lovelace.1               : lovelace              : iobroker                                 -  enabled, port: 8092, bind: 0.0.0.0, run as: admin
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
        system.adapter.nina.0                   : nina                  : iobroker                                 - disabled
      + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
      + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
        system.adapter.parcel.0                 : parcel                : iobroker                                 - disabled
        system.adapter.parcel.1                 : parcel                : iobroker                                 - disabled
        system.adapter.parser.0                 : parser                : iobroker                                 - disabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.places.0                 : places                : iobroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
        system.adapter.proxy.0                  : proxy                 : iobroker                                 - disabled
        system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
      + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
        system.adapter.rest-api.0               : rest-api              : iobroker                                 - disabled, port: 8093, bind: 0.0.0.0, run as: admin
        system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
        system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
        system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1888, bind: 192.168.99.33
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sony-bravia.0            : sony-bravia           : iobroker                                 -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 - disabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.telegram.1               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 - disabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
        system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 - disabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
        system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
        system.adapter.vw-connect.0             : vw-connect            : iobroker                                 - disabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      + system.adapter.wireguard.0              : wireguard             : iobroker                                 -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_e28d28580194eb11a604aa5b3d98b6d1-if00-port0
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "accuweather"  : 1.3.2    , installed 1.3.2
      Adapter    "adb"          : 0.0.7    , installed 0.0.7
      Adapter    "adguard"      : 0.0.8    , installed 0.0.8
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "backitup"     : 2.9.8    , installed 2.8.7  [Updatable]
      Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
      Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
      Adapter    "countdown"    : 2.2.0    , installed 2.2.0
      Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
      Adapter    "device-reminder": 3.0.0  , installed 3.0.0
      Adapter    "device-watcher": 2.9.6   , installed 2.9.6
      Adapter    "echarts"      : 1.5.4    , installed 1.5.4
      Adapter    "email"        : 1.2.1    , installed 1.2.0  [Updatable]
      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "hmip"         : 1.20.0   , installed 1.20.0
      Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
      Adapter    "icons-material-png": 0.1.0, installed 0.1.1
      Adapter    "imap"         : 0.1.1    , installed 0.1.1
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.12 [Updatable]
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "logparser"    : 2.2.0    , installed 2.2.0
      Adapter    "lovelace"     : 3.0.1    , installed 4.0.12
      Adapter    "moma"         : 1.2.9    , installed 1.2.9
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "notification-manager": 1.0.0, installed 1.0.0
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "openweathermap": 0.4.5   , installed 0.4.5
      Adapter    "parcel"       : 0.0.27   , installed 0.1.1
      Adapter    "parser"       : 2.0.7    , installed 2.0.7
      Adapter    "places"       : 1.1.2    , installed 1.1.2
      Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "reolink"      : 1.0.2    , installed 1.0.2
      Adapter    "rest-api"     : 1.1.0    , installed 1.1.0
      Adapter    "roborock"     : 0.4.4    , installed 0.4.4
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "telegram"     : 3.0.1    , installed 3.0.0  [Updatable]
      Adapter    "telegram-menu": 1.5.1    , installed 0.8.5  [Updatable]
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vw-connect"   : 0.0.67   , installed 0.0.67
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "wireguard"    : 1.6.1    , installed 1.6.1
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "zigbee"       : 1.8.25   , installed 1.8.24 [Updatable]
      Objects and States
      Objects:        32736
      States:         29860
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
      Reading package lists...
      Pending Updates: 6
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       10986669   1474482/iobroker.js
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       10986662   1474482/iobroker.js
      tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1000       10989477   1475102/adb
      tcp        0      0 192.168.99.33:42010     0.0.0.0:*               LISTEN      1000       10987316   1474629/io.hm-rpc.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       10988468   1474941/io.sonoff.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       10987646   1474704/io.mqtt.0
      tcp        0      0 192.168.99.33:1888      0.0.0.0:*               LISTEN      1000       10988338   1474919/io.shelly.0
      tcp        0      0 192.168.99.33:49292     0.0.0.0:*               LISTEN      1000       10987374   1474644/io.hm-rpc.1
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13251      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16486      534/sshd: /usr/sbin
      tcp6       0      0 :::8091                 :::*                    LISTEN      1000       10993483   1476066/io.lovelace
      tcp6       0      0 :::8092                 :::*                    LISTEN      1000       10993587   1476106/io.lovelace
      tcp6       0      0 :::8083                 :::*                    LISTEN      1000       10994313   1476222/io.web.1
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       10994197   1476204/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       10986790   1474500/io.admin.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       10993665   1476123/io.simple-a
      tcp6       0      0 :::111                  :::*                    LISTEN      0          13257      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          16500      534/sshd: /usr/sbin
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       10995213   1476298/io.upnp.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14482      425/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13254      1/init
      udp        0      0 192.168.99.33:5353      0.0.0.0:*                           1000       10989088   1474991/io.tr-064.0
      udp6       0      0 :::111                  :::*                                0          13260      1/init
      2023-12-28 16:13:16.540  - info: fb-checkpresence.0 (1476275) createFbDeviceObjects finished successfully
      2023-12-28 16:13:16.541  - info: fb-checkpresence.0 (1476275) states successfully subscribed
      2023-12-28 16:13:16.541  - info: fb-checkpresence.0 (1476275) loop successfully started
      2023-12-28 16:14:17.666  - info: host.iobroker iobroker url https://github.com/iobroker-community-adapters/ioBroker.onvif --host iobroker --debug
      2023-12-28 16:14:18.869  - info: host.iobroker iobroker install iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f
      2023-12-28 16:14:19.270  - info: host.iobroker iobroker NPM version: 10.2.3Installing iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f... (System call)2023-12-28 16:14:27.410  - info: host.iobroker iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.onvif.git
      2023-12-28 16:14:31.684  - info: host.iobroker iobroker npm ERR! code 2
      2023-12-28 16:14:31.686  - info: host.iobroker iobroker npm ERR! path /opt/iobroker/node_modules/json2iob
      2023-12-28 16:14:31.692  - info: host.iobroker iobroker npm ERR! command failed
      2023-12-28 16:14:31.693  - info: host.iobroker iobroker npm ERR! command sh -c npm run build
      2023-12-28 16:14:31.694  - info: host.iobroker iobroker npm ERR! > json2iob@2.6.0 build
      2023-12-28 16:14:31.695  - info: host.iobroker iobroker npm ERR! > tsc
      2023-12-28 16:14:31.696  - info: host.iobroker iobroker npm ERR!
      2023-12-28 16:14:31.697  - info: host.iobroker iobroker npm ERR! error TS2688: Cannot find type definition file for 'bl'.
      2023-12-28 16:14:31.698  - info: host.iobroker iobroker npm ERR!   The file is in the program because:
      2023-12-28 16:14:31.699  - info: host.iobroker iobroker npm ERR!     Entry point for implicit type library 'bl'
      2023-12-28 16:14:31.701  - info: host.iobroker iobroker
      2023-12-28 16:14:31.702  - info: host.iobroker iobroker npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-28T15_14_19_468Z-debug-0.log
      2023-12-28 16:14:31.749  - error: host.iobroker iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.onvif.git npm ERR! code 2npm ERR! path /opt/iobroker/node_modules/json2iobnpm ERR! command failednpm ERR! command sh -c npm run buildnpm ERR! > json2iob@2.6.0 buildnpm ERR! > tscnpm ERR! npm ERR! error TS2688: Cannot find type definition file for 'bl'.npm ERR!   The file is in the program because:npm ERR!     Entry point for implicit type library 'bl'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-28T15_14_19_Copy text starting here:
      • wendy2702
        @david-g
        https://forum.iobroker.net/search?term=Error 25&in=titlesposts
          Thomas Braun Most Active @David G. last edited by Thomas Braun
          @david-g
          Hau die anderen Updates drauf. Insbesondere den js-controller.
          • David G.
            @wendy2702 sagte in Test Adapter onvif camera v1.0.0:
            @david-g
            Die Lösungen zu dem Problem sind so weit ich weiß in iob fix eingebaut.
            @thomas-braun sagte in Test Adapter onvif camera v1.0.0:
            @david-g
            Habe alles aktualisiert. Meldung bleibt identisch.
            Thomas Braun wendy2702 2 Replies Last reply Reply Quote 0
              @david-g sagte in Test Adapter onvif camera v1.0.0:
              Muss aber was individuelles bei dir sein, hier läuft es nämlich einwandfrei durch:
              echad@chet:~ $ iobroker url https://github.com/iobroker-community-adapters/ioBroker.onvif --debug
              NPM version: 10.2.4
              added 29 packages, removed 149 packages, and changed 1 package in 26s
              106 packages are looking for funding
                run `npm fund` for details
              upload [1] onvif.admin /opt/iobroker/node_modules/iobroker.onvif/admin/jsonConfig.json jsonConfig.json application/json
              upload [0] onvif.admin /opt/iobroker/node_modules/iobroker.onvif/admin/onvif.png onvif.png image/png
              echad@chet:~ $
              • wendy2702
                wendy2702 @David G. last edited by
                Ist das so? Dann habe ich das nicht mitbekommen.
                Kann aber auch nicht sehen das der Fix lief.
                • David G.
                  David G. @wendy2702 last edited by
                  Jepp,
                  kann es leider nicht zitieren.
                  Oh, muss ich versehentlich gelöscht haben, als ich das Ergebnis vom iob diag von der Kurz- zu Langfassung abgeändert habe...
                  wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
                  • wendy2702
                    @david-g OK.
                    Da steht aber auch „sollte“ was für mich keine 100% Garantie ist das es auch wirklich dein spezielles Problem löst.
                      @david-g
                      Das ist aber kein Fix zu deinem Problem. Das ist was anderes bei dir.
                      • David G.
                        Nach den Updates und einem erneuten iob fix hat sich die Meldung verändert:
                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-28T17_56_02_375Z-debug-0.log
                        npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.onvif.git npm ERR! code 2npm ERR! path /opt/iobroker/node_modules/json2iobnpm ERR! command failednpm ERR! command sh -c npm run buildnpm ERR! > json2iob@2.6.0 buildnpm ERR! > tscnpm ERR! npm ERR! error TS2688: Cannot find type definition file for 'bl'.npm ERR! The file is in the program because:npm ERR! Entry point for implicit type library 'bl'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-12-28T17_56_02_375Z-debug-0.loghost.iobroker Cannot install iobroker-community-adapters/ioBroker.onvif#4032e14fe6267e5fd2e13857bd36a06378007c7f: 2
                        Suche das Log nachher mal raus was da steht.
                        EDIT
                        Hier der Inhalt der Logdatei:
                        0 verbose cli /usr/bin/node /usr/bin/npm
                        1 info using npm@10.2.3
                        2 info using node@v18.19.0
                        3 timing npm:load:whichnode Completed in 10ms
                        4 timing config:load:defaults Completed in 2ms
                        5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 5ms
                        6 timing config:load:builtin Completed in 5ms
                        7 timing config:load:cli Completed in 2ms
                        8 timing config:load:env Completed in 0ms
                        9 timing config:load:file:/opt/iobroker/node_modules/json2iob/.npmrc Completed in 0ms
                        10 timing config:load:project Completed in 2ms
                        11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
                        12 timing config:load:user Completed in 1ms
                        13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                        14 timing config:load:global Completed in 0ms
                        15 timing config:load:setEnvs Completed in 1ms
                        16 timing config:load Completed in 13ms
                        17 timing npm:load:configload Completed in 13ms
                        18 timing config:load:flatten Completed in 2ms
                        19 timing npm:load:mkdirpcache Completed in 0ms
                        20 timing npm:load:mkdirplogs Completed in 0ms
                        21 verbose title npm run build
                        22 verbose argv "run" "build"
                        23 timing npm:load:setTitle Completed in 1ms
                        24 timing npm:load:display Completed in 0ms
                        25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-12-28T17_56_12_453Z-
                        26 verbose logfile /home/iobroker/.npm/_logs/2023-12-28T17_56_12_453Z-debug-0.log
                        27 timing npm:load:logFile Completed in 6ms
                        28 timing npm:load:timers Completed in 0ms
                        29 timing npm:load:configScope Completed in 1ms
                        30 timing npm:load Completed in 41ms
                        31 silly logfile start cleaning logs, removing 1 files
                        32 silly logfile done cleaning log files
                        33 timing command:run Completed in 2634ms
                        34 verbose exit 2
                        35 timing npm Completed in 2705ms
                        36 verbose code 2
                          Thomas Braun Most Active last edited by
                          @david-g
                          Da geht ein build in die Hose. Das Modul muss nichtmal was mit onvif zu tun haben. Solange das da quer in der Pipeline hängt geht da nix mehr.
                            @david-g
                            cd /opt/iobroker
                            npm ls json2iob
                            • David G.
                              David G. @Thomas Braun last edited by
                              iobroker@iobroker:/opt/iobroker$ npm ls json2iob
                              iobroker.inst@3.0.0 /opt/iobroker
                              └─┬ iobroker.parcel@0.1.1
                                └── json2iob@2.4.8
                              Thomas Braun T 2 Replies Last reply Reply Quote 0
                                Was ist denn das für eine alte Beta-Version?
                                Aktuell wäre:
                                github:	0.2.6
                                latest:	0.2.6 for 13 days
                                stable:	0.0.27 for 8 months
                                  tombox @David G. last edited by
                                  @david-g ich habe json2iob mit 2.6 auf typescript umgestellt. es scheint so als könnte er die bei dr nicht bauen.
                                  • David G.
                                    Wenn ich parcels über git aktualisieren möchte kommt
                                    $ iobroker url https://github.com/TA2k/ioBroker.parcel --host iobroker --debug
                                    install TA2k/ioBroker.parcel#7f9960d7b7bdc06f76d552999c52efbf5b92e636
                                    NPM version: 10.2.3Installing TA2k/ioBroker.parcel#7f9960d7b7bdc06f76d552999c52efbf5b92e636... (System call)
                                    npm WARN skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.parcel.git
                                    npm ERR! code 2
                                    npm ERR! > tsc
                                    host.iobroker Cannot install TA2k/ioBroker.parcel#7f9960d7b7bdc06f76d552999c52efbf5b92e636: 2
                                    Aber du bist da der dev von beiden Adaptern, bin ich hier ja nicht so verkehrt.
                                      @david-g wie sieht es aus wenn du über parcel über npm installierst
                                      • David G.
                                        David G. @tombox last edited by
                                        @tombox
                                        $ iobroker url iobroker.parcel@latest --host iobroker --debug
                                        install iobroker.parcel@latest
                                        NPM version: 10.2.3Installing iobroker.parcel@latest... (System call)
                                        npm ERR! code 2
                                        host.iobroker Cannot install iobroker.parcel@latest: 2
                                          @david-g ok dann nochmal onvif via GitHub und mir dann alle aktuellen logs aus
                                          zusenden via email
                                          tombox2020@gmail.com
                                            Mars last edited by
                                            Ich habe meine Kamera in einem anderen Netzwerk wie mein iobroker läuft.
                                            Kameras z.b. 192.168.10.50 und
                                            iobroker z.b. 192.168.1.60
                                            iobroker Netzwerk kann Kamera ip anpingen. Der Adapter findet aber keine Kameras!
                                            Sucht der Adapter immer nur in dem Netzwerk in dem auch der iobroker ist?
                                            Ich finde weder über die automatische Suche meine Kamers noch über die manuelle Suche. Wobei ich mir bei der manuellen suche mit dem Port unsicher bin.
                                            Viell, hat hier jemand feedback ob das so geht wie ich das Vorhabe.
                                            Ziel ist einfach, dass die Kameras in einem isolierten Netzwerk sind weil die ja von außen zugänglich sind,
                                            31.7k
                                            79.8k
                                            339
                                            50826
