    4. Zigbee Stick spinnt *gelöst*
      gluecksmann @Frank579 last edited by
      @frank579
      pi@raspberrypi:~ $ iobroker upgrade zigbee@1.8.24
      This downgrade of "zigbee" will remove the following changes:
      -> 1.8.25
      zhc 16.x
      corr group from exclude dialog
      Would you like to downgrade zigbee from @1.8.25 to @1.8.24 now? [(y)es, (n)o]: y
      Update zigbee from @1.8.25 to @1.8.24
      host.raspberrypi Adapter "system.adapter.zigbee.0" is stopped.
      NPM version: 10.2.3
      Installing iobroker.zigbee@1.8.24... (System call)
      seitdem ruht der See...mal sehen ob da noch was passiert...
        gluecksmann @reutli last edited by
        @reutli
        So, jetzt wieder die früherer Version drauf... aber kommt immer noch die Fehlermeldung wie ganz am Anfang... Einstellungen SInd...
        d7704ac8-c27a-49af-9395-2061addfc502-grafik.png ```
        3deeb232-5f57-4a77-a09a-429d8b588aa3-grafik.png code_text
          Frank579 @gluecksmann last edited by
          @gluecksmann jetzt nochmal komplett iob diag
          R G 2 Replies Last reply Reply Quote 0
            reutli @Frank579 last edited by reutli
            @gluecksmann
            davor auch mal reboot gemacht???
            debug modus im Adapter aktivieren...
            und dann den Adapter nochmals neustarten
            und dann
            @frank579 sagte in Zigbee Stick spinnt:
              @frank579
              *** BASE SYSTEM ***
                Static hostname: raspberrypi
                      Icon name: computer
               Operating System: Raspbian GNU/Linux 10 (buster)
                         Kernel: Linux 5.10.103-v7l+
                   Architecture: arm
              Model           : Raspberry Pi 4 Model B Rev 1.4
              Docker          : false
              Virtualization  : none
              Kernel          : armv7l
              Userland        : armhf
              Systemuptime and Load:
              17:33:54 up  3:22,  1 user,  load average: 0.68, 3.79, 4.41
              CPU threads: 4
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** Time and Time Zones ***
                            Local time: Thu 2023-12-28 17:33:54 CET
                        Universal time: Thu 2023-12-28 16:33:54 UTC
                              RTC time: n/a
                           NTP service: active
                       RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:       tty
              Boot Target:    multi-user.target
              *** MEMORY ***
              Mem:           7.9G        1.6G        4.9G        8.0M        1.5G        6.1G
              Swap:           99M          0B         99M
              Total:         8.0G        1.6G        5.0G
                      7898 M total memory
                      1554 M used memory
                       300 M active memory
                      2506 M inactive memory
                      4885 M free memory
                       184 M buffer memory
                      1273 M swap cache
                        99 M total swap
                         0 M used swap
                        99 M free swap
              Raspberry only:
              oom events: 0
              *** FAILED SERVICES ***
               UNIT            LOAD   ACTIVE SUB    DESCRIPTION
              * lightdm.service loaded failed failed Light Display Manager
              LOAD   = Reflects whether the unit definition was properly loaded.
              ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
              SUB    = The low-level unit activation state, values depend on unit type.
              1 loaded units listed. Pass --all to see loaded but inactive units, too.
              To show all installed unit files use 'systemctl list-unit-files'.
              *** FILESYSTEM ***
              /dev/root      ext4       29G   14G   15G  50% /
              devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
              tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
              tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
              tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
              /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
              tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
              [Thu Dec 28 14:11:43 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=a372f35c-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Thu Dec 28 14:11:44 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
              [Thu Dec 28 14:11:44 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Thu Dec 28 14:11:46 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
              TARGET        SOURCE         FSTYPE OPTIONS
              /             /dev/mmcblk0p2 ext4   rw,noatime
              |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
              `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              413M    /var/
              118M    /var/lib
              102M    /var/cache
              91M     /var/log
              90M     /var/cache/apt
              Archived and active journals take up 8.0M in the file system.
              /opt/iobroker/backups:
              63M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              621M    /opt/iobroker/iobroker-data/
              322M    /opt/iobroker/iobroker-data/files
              143M    /opt/iobroker/iobroker-data/backup-objects
              93M     /opt/iobroker/iobroker-data/sonosCache
              67M     /opt/iobroker/iobroker-data/files/javascript.admin
              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
              30M     /opt/iobroker/iobroker-data/objects.jsonl
              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
              12M     /opt/iobroker/iobroker-data/objects.json.migrated
              USB-Devices by-id:
              /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.19.0
              /usr/bin/node           v18.19.0
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              /usr/bin/corepack       0.22.0
              nodejs:
               Installed: 18.19.0-1nodesource1
               Candidate: 18.19.0-1nodesource1
               Version table:
              *** 18.19.0-1nodesource1 1001
                     500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                     100 /var/lib/dpkg/status
                  18.18.2-1nodesource1 1001
                  18.18.1-1nodesource1 1001
                  18.18.0-1nodesource1 1001
                  18.17.1-1nodesource1 1001
                  18.17.0-1nodesource1 1001
                  18.16.1-1nodesource1 1001
                  18.16.0-1nodesource1 1001
                  18.15.0-1nodesource1 1001
                  18.14.2-1nodesource1 1001
                  18.14.1-1nodesource1 1001
                  18.14.0-1nodesource1 1001
                  18.13.0-1nodesource1 1001
                  18.12.0-1nodesource1 1001
                  18.11.0-1nodesource1 1001
                  18.10.0-1nodesource1 1001
                  18.9.1-1nodesource1 1001
                  18.9.0-1nodesource1 1001
                  18.8.0-1nodesource1 1001
                  18.7.0-1nodesource1 1001
                  18.6.0-1nodesource1 1001
                  18.5.0-1nodesource1 1001
                  18.4.0-1nodesource1 1001
                  18.3.0-1nodesource1 1001
                  18.2.0-1nodesource1 1001
                  18.1.0-1nodesource1 1001
                  18.0.0-1nodesource1 1001
                  10.24.0~dfsg-1~deb10u3 500
              No problems detected
              Errors in npm tree:
              npm ERR! code ELSPROBLEMS
              npm ERR! invalid: iobroker.govee@0.0.5 /opt/iobroker/node_modules/iobroker.govee
              npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-28T16_34_03_703Z-debug-0.log
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.17
              admin:          6.12.0
              javascript:     7.1.6
              npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-12-28T16_34_25_768Z-debug-0.log
              Adapters from github:   1
              Adapter State
              + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
               system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
               system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              - disabled
              + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
              + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
               system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
               system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
               system.adapter.devices.0                : devices               : raspberrypi                              - disabled
              + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
               system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
              + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
              + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
              + system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              -  enabled
               system.adapter.history.0                : history               : raspberrypi                              - disabled
              + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
               system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
               system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
               system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
              + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
              + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
              + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
              + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
              + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
              + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
              + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
              + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
              + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
              + system.adapter.philips-air.1            : philips-air           : raspberrypi                              -  enabled
              + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
              + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
              + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
              + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
               system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
              + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
              + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
              + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
               system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
               system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
               system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
               system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
               system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
               system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
               system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
               system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
               system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
              + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3388-if00
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "admin"        : 6.12.0   , installed 6.12.0
              Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
              Adapter    "awtrix-light" : 0.10.0   , installed 0.10.0
              Adapter    "backitup"     : 2.9.8    , installed 2.9.8
              Adapter    "ble"          : 0.13.4   , installed 0.13.4
              Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
              Adapter    "daswetter"    : 3.1.11   , installed 3.1.11
              Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
              Adapter    "gruenbeck"    : 0.0.42   , installed 0.0.42
              Adapter    "hue"          : 3.10.1   , installed 3.10.1
              Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
              Adapter    "iot"          : 2.0.11   , installed 2.0.11
              Adapter    "javascript"   : 7.1.6    , installed 7.1.6
              Controller "js-controller": 5.0.17   , installed 5.0.17
              Adapter    "meross"       : 1.15.1   , installed 1.15.1
              Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
              Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
              Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
              Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
              Adapter    "philips-air"  : 1.0.3    , installed 1.0.3
              Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
              Adapter    "shelly"       : 6.6.1    , installed 6.6.1
              Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
              Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
              Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
              Adapter    "sonos"        : 3.0.0    , installed 3.0.0
              Adapter    "trashschedule": 2.3.0    , installed 2.3.0
              Adapter    "tuya"         : 3.14.2   , installed 3.14.2
              Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
              Adapter    "weatherunderground": 3.6.0, installed 3.6.0
              Adapter    "web"          : 6.1.10   , installed 6.1.10
              Adapter    "ws"           : 2.5.8    , installed 2.5.8
              Adapter    "zigbee"       : 1.8.25   , installed 1.8.24 [Updatable]
              Objects and States
              Objects:        11296
              States:         9373
              Hit:1 http://archive.raspberrypi.org/debian buster InRelease
              Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18008      642/sshd
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          14831      363/cupsd
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20705      999/io.sonoff.0
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18400      632/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19317      632/iobroker.js-con
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       178386     15017/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       363390     9027/io.web.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          18010      642/sshd
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          14830      363/cupsd
              tcp6       0      0 :::3500                 :::*                    LISTEN      1001       21820      980/io.sonos.0
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19741      1036/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19742      1036/io.tuya.0
              udp        0      0 0.0.0.0:37928           0.0.0.0:*                           1001       21652      911/io.philips-air.
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       21575      856/io.shelly.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18449      631/dhcpcd
              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16300      460/cups-browsed
              udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       24005      1320/io.musiccast.0
              udp        0      0 0.0.0.0:60062           0.0.0.0:*                           108        17435      356/avahi-daemon: r
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17433      356/avahi-daemon: r
              udp        0      0 0.0.0.0:48886           0.0.0.0:*                           1001       21952      1017/io.philips-air
              udp6       0      0 :::546                  :::*                                0          18466      631/dhcpcd
              udp6       0      0 :::5353                 :::*                                108        17434      356/avahi-daemon: r
              udp6       0      0 :::39823                :::*                                108        17436      356/avahi-daemon: r
              2023-12-28 17:33:48.594  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
              2023-12-28 17:33:48.644  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
              2023-12-28 17:33:52.420  - info: philips-air.0 (911) State value to set for "philips-air.0.control.lightBrightness" has to be type "number" but received type "string"
              2023-12-28 17:33:52.429  - info: philips-air.0 (911) State value to set for "philips-air.0.control.airQualityNotificationThreshold" has to be type "number" but received type "string"
              2023-12-28 17:33:52.481  - info: philips-air.0 (911) State value to set for "philips-air.0.status.allergenIndex" has to be type "number" but received type "string"
              2023-12-28 17:33:52.493  - info: philips-air.0 (911) State value to set for "philips-air.0.control.childLock" has to be type "boolean" but received type "string"
              2023-12-28 17:33:52.542  - info: philips-air.0 (911) State value to set for "philips-air.0.device.uptime" has to be type "number" but received type "string"
              2023-12-28 17:33:52.600  - info: philips-air.0 (911) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string"
              2023-12-28 17:33:52.618  - info: philips-air.0 (911) State value to set for "philips-air.0.control.timerHours" has to be type "number" but received type "string"
              2023-12-28 17:33:52.625  - info: philips-air.0 (911) State value to set for "philips-air.0.status.timerMinutes" has to be type "number" but received type "string"
              2023-12-28 17:33:52.640  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string"
              2023-12-28 17:33:52.695  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
              2023-12-28 17:33:52.701  - info: philips-air.0 (911) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
              2023-12-28 17:34:18.240  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
              2023-12-28 17:34:24.323  - warn: sonoff.0 (999) Client [tasmota2] has invalid password or username
              2023-12-28 17:34:38.463  - warn: sonos.0 (980) State "sonos.0.root.192_168_2_145.queue_html" has no existing object, this might lead to an error in future versions
              2023-12-28 17:34:38.598  - warn: sonos.0 (980) State "sonos.0.root.192_168_2_145.queue_html" has no existing object, this might lead to an error in future versions
              2023-12-28 17:34:48.242  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
              2023-12-28 17:35:00.048  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 303
              2023-12-28 17:35:04.662  - info: dwd.0 (303) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
              2023-12-28 17:35:05.205  - info: web.0 (9027) ==> Connected system.user.admin from ::ffff:192.168.2.148
              2023-12-28 17:35:07.075  - info: dwd.0 (303) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-12-28 17:35:07.617  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-12-28 17:35:15.042  - info: web.0 (9027) ==> Connected system.user.admin from ::ffff:192.168.2.148
              2023-12-28 17:35:18.242  - error: philips-air.1 (1017) Error by sending: Error: No reply in 247 seconds.
                Thomas Braun Most Active @gluecksmann last edited by
                @gluecksmann
                iobroker.govee
                nochmal installieren.
                R G 3 Replies Last reply Reply Quote 0
                  reutli @Thomas Braun last edited by
                  @gluecksmann
                  reboot gemacht?
                  debug modus im Adapter aktiviert?
                  Adapter neu gestartet?
                  Wenn ja: zeigen
                  Wenn nein: machen und dann zeigen
                  Sonst kann hier wahrscheinlich keiner mehr weiter helfen...
                    gluecksmann @Thomas Braun last edited by
                    der ist aktuell nicht das Problem...glaub den werfe ich erst mal raus...
                      @reutli
                      Reboot und Adapter neu starten kann ich... Debug Modus ist wo?
                        @gluecksmann
                        @gluecksmann sagte in Zigbee Stick spinnt:
                        Debug Modus ist wo?
                        Auf dem IOBroker im Expertenmodus auf Instanzen Zigbee aufklappen
                        mit Bleistift umstellen
                        Dann mal den ganzen Start aus dem log
                          @frank579
                          Hallo, habe den Adapter neu gestartet...jetzt läuft es wieder... komisch...
                          F R 2 Replies Last reply Reply Quote 0
                            Da wir gerade so plaudern... welchen Zigbee Stick könnt Ihr empfehlen? Gibt da ja den Sonoff ZBDongle ...aber den wohl mit zwei verschiedenen Chipsätzen..
                              @gluecksmann Okay dann bleib trotzdem erst mal auf der Version, bis es was neues gibt 🙂
                              @thomas-braun sagte in Zigbee Stick spinnt:
                              @gluecksmann
                              iobroker.govee
                              Hast du das gemacht einfach nochmal drüber, das alles sauber ist, dann sollte bei iob diag auch nichts auffällige mehr sein ...
                                @frank579
                                Traue mich das kaum... jetzt wo es so schön läuft..
                                  @gluecksmann
                                  Ich hab Hier den von @dimaiv aber als LAN Version. und super Zufrieden, klarer Vorteil ist der LAN Anschluss, muss also nicht im Netzwerkschrank liegen, Liegt bei mir im Büro (zentral) auf dem Schrank
                                    doch mach das, nicht das dich das irgendwann einholt ...
                                      @frank579
                                      Den Adapter gibt es scheinbar nicht mehr... macht erst mal auch nix... bin zufrieden das alles wieder läuft...muss aber mal echt über eine Neuinstallation nachdenken
                                        @gluecksmann sagte in Zigbee Stick spinnt *gelöst*:
                                        Doch, aus dem github.
                                        Das ist auch der Grund, warum der als invalid angezeigt wird.
                                        Also nochmal in aktueller Version aus dem github fischen.
                                          Da finde ich nur govee Local... da erschließt sich mir aber die Funktion, bzw. Inbetriebnahme nicht...aber wie gesagt...nicht schlimm
                                            @gluecksmann
                                            https://github.com/nbuenger/ioBroker.govee
                                            5807
